path: root/net/ax25/ax25_dev.c
2006-07-09[AX.25]: Use kzallocRalf Baechle
Replace kzalloc instead of kmalloc + memset. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
