commit 926f2ae04f183098cf9a30521776fb2759c8afeb upstream.
mpol_parse_str() made lots 'err' variable related bug. Because it is ugly
and reviewing unfriendly.
This patch simplifies it.
Cc: Ravikiran Thirumalai <kiran@scalex86.org>
Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
commit 12821f5fb942e795f8009ece14bde868893bd811 upstream.
commit 71fe804b6d5 (mempolicy: use struct mempolicy pointer in
shmem_sb_info) added mpol=local mount option. but its feature is broken
since it was born. because such code always return 1 (i.e. mount
failure).
This patch fixes it.
commit d69b2e63e9172afb4d07c305601b79a55509ac4c upstream.
Currently, following mount operation cause mount error.
% mount -t tmpfs -ompol=bind:0 none /tmp
Because commit 71fe804b6d5 (mempolicy: use struct mempolicy pointer in
shmem_sb_info) corrupted MPOL_BIND parse code.
This patch restore the needed one.
commit 413b43deab8377819aba1dbad2abf0c15d59b491 upstream.
Fix an 'oops' when a tmpfs mount point is mounted with the mpol=default
mempolicy.
Upon remounting a tmpfs mount point with 'mpol=default' option, the mount
code crashed with a null pointer dereference. The initial problem report
was on 2.6.27, but the problem exists in mainline 2.6.34-rc as well. On
examining the code, we see that mpol_new returns NULL if default mempolicy
was requested. This 'NULL' mempolicy is accessed to store the node mask
resulting in oops.
The following patch fixes it.
Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org>
commit f3186a9c51eabe75b2780153ed7f07778d78b16e upstream.
Comparing with existing code, it's a simpler way to use kzalloc_node()
to ensure that each unused alien cache entry is NULL.
CC: Eric Dumazet <eric.dumazet@gmail.com>
Acked-by: Andi Kleen <ak@linux.intel.com>
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Acked-by: Matt Mackall <mpm@selenic.com>
Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
commit 0141450f66c3c12a3aaa869748caa64241885cdf upstream.
This fixes inefficient page-by-page reads on POSIX_FADV_RANDOM.
POSIX_FADV_RANDOM used to set ra_pages=0, which leads to poor performance:
a 16K read will be carried out in 4 _sync_ 1-page reads.
In other places, ra_pages==0 means
- it's ramfs/tmpfs/hugetlbfs/sysfs/configfs
- some IO error happened
where multi-page read IO won't help or should be avoided.
POSIX_FADV_RANDOM actually want a different semantics: to disable the
*heuristic* readahead algorithm, and to use a dumb one which faithfully
submit read IO for whatever application requests.
So introduce a flag FMODE_RANDOM for POSIX_FADV_RANDOM.
Note that the random hint is not likely to help random reads performance
noticeably. And it may be too permissive on huge request size (its IO
size is not limited by read_ahead_kb).
In Quentin's report (http://lkml.org/lkml/2009/12/24/145), the overall
(NFS read) performance of the application increased by 313%!
Tested-by: Quentin Barnes <qbarnes+nfs@yahoo-inc.com>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Chuck Lever <chuck.lever@oracle.com>
Cc: <qbarnes+nfs@yahoo-inc.com>
Presently the oom-killer is memcg aware and it finds the worst process
from processes under memcg(s) in oom. Then, it kills victim's child
first.
It may kill a child in another cgroup and may not be any help for
recovery. And it will break the assumption users have.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Acked-by: David Rientjes <rientjes@google.com>
Cc: <stable@kernel.org>
x86-32 has had a static test for copy_on_user() overflow for a while.
This test currently fails in mm/migrate.c resulting in an
allyesconfig/allmodconfig build failure on x86-32:
In function ‘copy_from_user’,
inlined from ‘do_pages_stat’ at
/home/hpa/kernel/git/mm/migrate.c:1012:
/home/hpa/kernel/git/arch/x86/include/asm/uaccess_32.h:212: error:
call to ‘copy_from_user_overflow’ declared
Make the logic more explicit and therefore easier for gcc to
understand.
v2: rewrite the loop entirely using a more normal structure for a
chunked-data loop (Linus Torvalds)
Reported-by: Len Brown <lenb@kernel.org>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Reviewed-and-Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Arjan van de Ven <arjan@linux.kernel.org>
We incorrectly depended on the 'node_state/node_isset()' functions
testing the node range, rather than checking it explicitly. That's not
reliable, even if it might often happen to work. So do the proper
explicit test.
Reported-by: Marcus Meissner <meissner@suse.de>
Acked-and-tested-by: Brice Goglin <Brice.Goglin@inria.fr>
Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: stable@kernel.org
hugetlb_sysfs_add_hstate is called by hugetlb_register_node directly
during init and also indirectly via sysfs after init.
This patch removes the __init tag from hugetlb_sysfs_add_hstate.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
The cache alias problem will happen if the changes of user shared mapping
is not flushed before copying, then user and kernel mapping may be mapped
into two different cache line, it is impossible to guarantee the coherence
after iov_iter_copy_from_user_atomic. So the right steps should be:
flush_dcache_page(page);
kmap_atomic(page);
write to page;
kunmap_atomic(page);
More precisely, we might create two new APIs flush_dcache_user_page and
flush_dcache_kern_page to replace the two flush_dcache_page accordingly.
Here is a snippet tested on omap2430 with VIPT cache, and I think it is
not ARM-specific:
int val = 0x11111111;
fd = open("abc", O_RDWR);
addr = mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0);
*(addr+0) = 0x44444444;
tmp = *(addr+0);
*(addr+1) = 0x77777777;
write(fd, &val, sizeof(int));
close(fd);
The results are not always 0x11111111 0x77777777 at the beginning as expected. Sometimes we see 0x44444444 0x77777777.
Signed-off-by: Anfei <anfei.zhou@gmail.com>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: <linux-arch@vger.kernel.org>
Improve handling of fragmented per-CPU vmaps. We previously don't free
up per-CPU maps until all its addresses have been used and freed. So
fragmented blocks could fill up vmalloc space even if they actually had
no active vmap regions within them.
Add some logic to allow all CPUs to have these blocks purged in the case
of failure to allocate a new vm area, and also put some logic to trim
such blocks of a current CPU if we hit them in the allocation path (so
as to avoid a large build up of them).
Christoph reported some vmap allocation failures when using the per CPU
vmap APIs in XFS, which cannot be reproduced after this patch and the
previous bug fix.
Cc: linux-mm@kvack.org
Tested-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Nick Piggin <npiggin@suse.de>
RCU list walking of the per-cpu vmap cache was broken. It did not use
RCU primitives, and also the union of free_list and rcu_head is
obviously wrong (because free_list is indeed the list we are RCU
walking).
While we are there, remove a couple of unused fields from an earlier
iteration.
These APIs aren't actually used anywhere, because of problems with the
XFS conversion. Christoph has now verified that the problems are solved
with these patches. Also it is an exported interface, so I think it
will be good to be merged now (and Christoph wants to get the XFS
changes into their local tree).
After memory pressure has forced it to dip into the reserves, 2.6.32's
5f8dcc21211a3d4e3a7a5ca366b469fb88117f61 "page-allocator: split per-cpu
list into one-list-per-migrate-type" has been returning MIGRATE_RESERVE
pages to the MIGRATE_MOVABLE free_list: in some sense depleting reserves.
Fix that in the most straightforward way (which, considering the overheads
of alternative approaches, is Mel's preference): the right migratetype is
already in page_private(page), but free_pcppages_bulk() wasn't using it.
How did this bug show up? As a 20% slowdown in my tmpfs loop kbuild
swapping tests, on PowerMac G5 with SLUB allocator. Bisecting to that
commit was easy, but explaining the magnitude of the slowdown not easy.
The same effect appears, but much less markedly, with SLAB, and even
less markedly on other machines (the PowerMac divides into fewer zones
than x86, I think that may be a factor). We guess that lumpy reclaim
of short-lived high-order pages is implicated in some way, and probably
this bug has been tickling a poor decision somewhere in page reclaim.
But instrumentation hasn't told me much, I've run out of time and
imagination to determine exactly what's going on, and shouldn't hold up
the fix any longer: it's valid, and might even fix other misbehaviours.
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Acked-by: Mel Gorman <mel@csn.ul.ie>
It's a simplified 'read_cache_page()' which takes a page allocation
flag, so that different paths can control how aggressive the memory
allocations are that populate a address space.
In particular, the intel GPU object mapping code wants to be able to do
a certain amount of own internal memory management by automatically
shrinking the address space when memory starts getting tight. This
allows it to dynamically use different memory allocation policies on a
per-allocation basis, rather than depend on the (static) address space
gfp policy.
The actual new function is a one-liner, but re-organizing the helper
functions to the point where you can do this with a single line of code
is what most of the patch is all about.
Tested-by: Chris Wilson <chris@chris-wilson.co.uk>
In free_unmap_area_noflush(), va->flags is marked as VM_LAZY_FREE first, and
then vmap_lazy_nr is increased atomically.
But, in __purge_vmap_area_lazy(), while traversing of vmap_are_list, nr
is counted by checking VM_LAZY_FREE is set to va->flags. After counting
the variable nr, kernel reads vmap_lazy_nr atomically and checks a
BUG_ON condition whether nr is greater than vmap_lazy_nr to prevent
vmap_lazy_nr from being negative.
The problem is that, if interrupted right after marking VM_LAZY_FREE,
increment of vmap_lazy_nr can be delayed. Consequently, BUG_ON
condition can be met because nr is counted more than vmap_lazy_nr.
It is highly probable when vmalloc/vfree are called frequently. This
scenario have been verified by adding delay between marking VM_LAZY_FREE
and increasing vmap_lazy_nr in free_unmap_area_noflush().
Even the vmap_lazy_nr is for checking high watermark, it never be the
strict watermark. Although the BUG_ON condition is to prevent
vmap_lazy_nr from being negative, vmap_lazy_nr is signed variable. So,
it could go down to negative value temporarily.
Consequently, removing the BUG_ON condition is proper.
A possible BUG_ON message is like the below.
kernel BUG at mm/vmalloc.c:517!
invalid opcode: 0000 [#1] SMP
EIP: 0060:[<c04824a4>] EFLAGS: 00010297 CPU: 3
EIP is at __purge_vmap_area_lazy+0x144/0x150
EAX: ee8a8818 EBX: c08e77d4 ECX: e7c7ae40 EDX: c08e77ec
ESI: 000081fe EDI: e7c7ae60 EBP: e7c7ae64 ESP: e7c7ae3c
DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
Call Trace:
[<c0482ad9>] free_unmap_vmap_area_noflush+0x69/0x70
[<c0482b02>] remove_vm_area+0x22/0x70
[<c0482c15>] __vunmap+0x45/0xe0
[<c04831ec>] vmalloc+0x2c/0x30
Code: 8d 59 e0 eb 04 66 90 89 cb 89 d0 e8 87 fe ff ff 8b 43 20 89 da 8d 48 e0 8d 43 20 3b 04 24 75 e7 fe 05 a8 a5 a3 c0 e9 78 ff ff ff <0f> 0b eb fe 90 8d b4 26 00 00 00 00 56 89 c6 b8 ac a5 a3 c0 31
EIP: [<c04824a4>] __purge_vmap_area_lazy+0x144/0x150 SS:ESP 0068:e7c7ae3c
[ See also http://marc.info/?l=linux-kernel&m=126335856228090&w=2 ]
Signed-off-by: Yongseok Koh <yongseok.koh@samsung.com>
commit f2260e6b (page allocator: update NR_FREE_PAGES only as necessary)
made one minor regression. if __rmqueue() was failed, NR_FREE_PAGES stat
go wrong. this patch fixes it.
Reported-by: Huang Shijie <shijie8@gmail.com>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Fix a problem in NOMMU mmap with ramfs whereby a shared mmap can happen
over the end of a truncation. The problem is that
ramfs_nommu_check_mappings() checks that the reduced file size against the
VMA tree, but not the vm_region tree.
The following sequence of events can cause the problem:
fd = open("/tmp/x", O_RDWR|O_TRUNC|O_CREAT, 0600);
ftruncate(fd, 32 * 1024);
a = mmap(NULL, 32 * 1024, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0);
b = mmap(NULL, 16 * 1024, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0);
munmap(a, 32 * 1024);
ftruncate(fd, 16 * 1024);
c = mmap(NULL, 32 * 1024, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0);
Mapping 'a' creates a vm_region covering 32KB of the file. Mapping 'b'
sees that the vm_region from 'a' is covering the region it wants and so
shares it, pinning it in memory.
Mapping 'a' then goes away and the file is truncated to the end of VMA
'b'. However, the region allocated by 'a' is still in effect, and has
_not_ been reduced.
Mapping 'c' is then created, and because there's a vm_region covering the
desired region, get_unmapped_area() is _not_ called to repeat the check,
and the mapping is granted, even though the pages from the latter half of
the mapping have been discarded.
However:
d = mmap(NULL, 16 * 1024, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0);
Mapping 'd' should work, and should end up sharing the region allocated by
'a'.
To deal with this, we shrink the vm_region struct during the truncation,
lest do_mmap_pgoff() take it as licence to share the full region
automatically without calling the get_unmapped_area() file op again.
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Greg Ungerer <gerg@snapgear.com>
get_unmapped_area() is unnecessary for NOMMU as no-one calls it.
In split_vma(), there's no need to check if the VMA being split has a
region that's in use by more than one VMA because:
(1) The preceding test prohibits splitting of non-anonymous VMAs and regions
(eg: file or chardev backed VMAs).
(2) Anonymous regions can't be mapped multiple times because there's no handle
by which to refer to the already existing region.
(3) If a VMA has previously been split, then the region backing it has also
been split into two regions, each of usage 1.
The vm_usage count field in struct vm_region does not need to be atomic as
it's only even modified whilst nommu_region_sem is write locked.
Current mem_cgroup_force_empty() only ensures mem->res.usage == 0 on
success. But this doesn't guarantee memcg's LRU is really empty, because
there are some cases in which !PageCgrupUsed pages exist on memcg's LRU.
For example:
- Pages can be uncharged by its owner process while they are on LRU.
- race between mem_cgroup_add_lru_list() and __mem_cgroup_uncharge_common().
So there can be a case in which the usage is zero but some of the LRUs are not empty.
OTOH, mem_cgroup_del_lru_list(), which can be called asynchronously with
rmdir, accesses the mem_cgroup, so this access can cause a problem if it
races with rmdir because the mem_cgroup might have been freed by rmdir.
Actually, I saw a bug which seems to be caused by this race.
[1530745.949906] BUG: unable to handle kernel NULL pointer dereference at 0000000000000230
[1530745.950651] IP: [<ffffffff810fbc11>] mem_cgroup_del_lru_list+0x30/0x80
[1530745.950651] PGD 3863de067 PUD 3862c7067 PMD 0
[1530745.950651] Oops: 0002 [#1] SMP
[1530745.950651] last sysfs file: /sys/devices/system/cpu/cpu7/cache/index1/shared_cpu_map
[1530745.950651] CPU 3
[1530745.950651] Modules linked in: configs ipt_REJECT xt_tcpudp iptable_filter ip_tables x_tables bridge stp nfsd nfs_acl auth_rpcgss exportfs autofs4 hidp rfcomm l2cap crc16 bluetooth lockd sunrpc ib_iser rdma_cm ib_cm iw_cm ib_sa ib_mad ib_core ib_addr iscsi_tcp bnx2i cnic uio ipv6 cxgb3i cxgb3 mdio libiscsi_tcp libiscsi scsi_transport_iscsi dm_mirror dm_multipath scsi_dh video output sbs sbshc battery ac lp kvm_intel kvm sg ide_cd_mod cdrom serio_raw tpm_tis tpm tpm_bios acpi_memhotplug button parport_pc parport rtc_cmos rtc_core rtc_lib e1000 i2c_i801 i2c_core pcspkr dm_region_hash dm_log dm_mod ata_piix libata shpchp megaraid_mbox sd_mod scsi_mod megaraid_mm ext3 jbd uhci_hcd ohci_hcd ehci_hcd [last unloaded: freq_table]
[1530745.950651] Pid: 19653, comm: shmem_test_02 Tainted: G M 2.6.32-mm1-00701-g2b04386 #3 Express5800/140Rd-4 [N8100-1065]
[1530745.950651] RIP: 0010:[<ffffffff810fbc11>] [<ffffffff810fbc11>] mem_cgroup_del_lru_list+0x30/0x80
[1530745.950651] RSP: 0018:ffff8803863ddcb8 EFLAGS: 00010002
[1530745.950651] RAX: 00000000000001e0 RBX: ffff8803abc02238 RCX: 00000000000001e0
[1530745.950651] RDX: 0000000000000000 RSI: ffff88038611a000 RDI: ffff8803abc02238
[1530745.950651] RBP: ffff8803863ddcc8 R08: 0000000000000002 R09: ffff8803a04c8643
[1530745.950651] R10: 0000000000000000 R11: ffffffff810c7333 R12: 0000000000000000
[1530745.950651] R13: ffff880000017f00 R14: 0000000000000092 R15: ffff8800179d0310
[1530745.950651] FS: 0000000000000000(0000) GS:ffff880017800000(0000) knlGS:0000000000000000
[1530745.950651] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[1530745.950651] CR2: 0000000000000230 CR3: 0000000379d87000 CR4: 00000000000006e0
[1530745.950651] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[1530745.950651] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[1530745.950651] Process shmem_test_02 (pid: 19653, threadinfo ffff8803863dc000, task ffff88038612a8a0)
[1530745.950651] Stack:
[1530745.950651] ffffea00040c2fe8 0000000000000000 ffff8803863ddd98 ffffffff810c739a
[1530745.950651] <0> 00000000863ddd18 000000000000000c 0000000000000000 0000000000000000
[1530745.950651] <0> 0000000000000002 0000000000000000 ffff8803863ddd68 0000000000000046
[1530745.950651] Call Trace:
[1530745.950651] [<ffffffff810c739a>] release_pages+0x142/0x1e7
[1530745.950651] [<ffffffff810c778f>] ? pagevec_move_tail+0x6e/0x112
[1530745.950651] [<ffffffff810c781e>] pagevec_move_tail+0xfd/0x112
[1530745.950651] [<ffffffff810c78a9>] lru_add_drain+0x76/0x94
[1530745.950651] [<ffffffff810dba0c>] exit_mmap+0x6e/0x145
[1530745.950651] [<ffffffff8103f52d>] mmput+0x5e/0xcf
[1530745.950651] [<ffffffff81043ea8>] exit_mm+0x11c/0x129
[1530745.950651] [<ffffffff8108fb29>] ? audit_free+0x196/0x1c9
[1530745.950651] [<ffffffff81045353>] do_exit+0x1f5/0x6b7
[1530745.950651] [<ffffffff8106133f>] ? up_read+0x2b/0x2f
[1530745.950651] [<ffffffff8137d187>] ? lockdep_sys_exit_thunk+0x35/0x67
[1530745.950651] [<ffffffff81045898>] do_group_exit+0x83/0xb0
[1530745.950651] [<ffffffff810458dc>] sys_exit_group+0x17/0x1b
[1530745.950651] [<ffffffff81002c1b>] system_call_fastpath+0x16/0x1b
[1530745.950651] Code: 54 53 0f 1f 44 00 00 83 3d cc 29 7c 00 00 41 89 f4 75 63 eb 4e 48 83 7b 08 00 75 04 0f 0b eb fe 48 89 df e8 18 f3 ff ff 44 89 e2 <48> ff 4c d0 50 48 8b 05 2b 2d 7c 00 48 39 43 08 74 39 48 8b 4b
[1530745.950651] RIP [<ffffffff810fbc11>] mem_cgroup_del_lru_list+0x30/0x80
[1530745.950651] RSP <ffff8803863ddcb8>
[1530745.950651] ---[ end trace c3419c1bb8acc34f ]---
[1530745.950651] Fixing recursive fault but reboot is needed!
The problem here is pages on LRU may contain pointer to stale memcg. To
make res->usage to be 0, all pages on memcg must be uncharged or moved to
another(parent) memcg. Moved page_cgroup have already removed from
original LRU, but uncharged page_cgroup contains pointer to memcg withou
PCG_USED bit. (This asynchronous LRU work is for improving performance.)
If PCG_USED bit is not set, page_cgroup will never be added to memcg's
LRU. So, about pages not on LRU, they never access stale pointer. Then,
what we have to take care of is page_cgroup _on_ LRU list. This patch
fixes this problem by making mem_cgroup_force_empty() visit all LRUs
before exiting its loop and guarantee there are no pages on its LRU.
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Commit f50de2d3 (vmscan: have kswapd sleep for a short interval and double
check it should be asleep) can cause kswapd to enter an infinite loop if
running on a single-CPU system. If all zones are unreclaimble,
sleeping_prematurely return 1 and kswapd will call balance_pgdat() again.
but it's totally meaningless, balance_pgdat() doesn't anything against
unreclaimable zone!
Reported-by: Will Newton <will.newton@gmail.com>
Tested-by: Will Newton <will.newton@gmail.com>
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
The current check for 'backward merging' within add_active_range() does
not seem correct. start_pfn must be compared against
early_node_map[i].start_pfn (and NOT against .end_pfn) to find out whether
the new region is backward-mergeable with the existing range.
Signed-off-by: Kazuhisa Ichikawa <ki@epsilou.com>
If __block_prepare_write() was failed in block_write_begin(), the
allocated blocks can be outside of ->i_size.
But new truncate_pagecache() in vmtuncate() does nothing if new < old.
It means the above usage is not working anymore.
So, this patch fixes it by removing "new < old" check. It would need
more cleanup/change. But, now -rc and truncate working is in progress,
so, this tried to fix it minimum change.
Acked-by: Nick Piggin <npiggin@suse.de>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
sz is in bytes, MAX_ORDER_NR_PAGES is in pages.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Acked-by: David Gibson <dwg@au1.ibm.com>
__pcpu_ptr_to_addr() can be overridden by the architecture and might not
behave well if passed a NULL pointer. So avoid calling it until we have
verified that its arg is not NULL.
Cc: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Acked-by: Tejun Heo <tj@kernel.org>
Some archs such as blackfin, would like to have an arch specific
probe_kernel_read() and probe_kernel_write() implementation which can
fall back to the generic implementation if no special operations are
needed.
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Ingo Molnar <mingo@elte.hu>
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
The MMU code uses the copy_*_user_page() variants in access_process_vm()
rather than copy_*_user() as the former includes an icache flush. This
is important when doing things like setting software breakpoints with
gdb. So switch the NOMMU code over to do the same.
This patch makes the reasonable assumption that copy_from_user_page()
won't fail - which is probably fine, as we've checked the VMA from which
we're copying is usable, and the copy is not allowed to cross VMAs. The
one case where it might go wrong is if the VMA is a device rather than
RAM, and that device returns an error which - in which case rubbish will
be returned rather than EIO.
Signed-off-by: Jie Zhang <jie.zhang@analog.com>
Acked-by: David McCullough <david_mccullough@mcafee.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Greg Ungerer <gerg@uclinux.org>
When working with FDPIC, there are many shared mappings of read-only
code regions between applications (the C library, applet packages like
busybox, etc.), but the current do_mmap_pgoff() function will issue an
icache flush whenever a VMA is added to an MM instead of only doing it
when the map is initially created.
The flush can instead be done when a region is first mmapped PROT_EXEC.
Note that we may not rely on the first mapping of a region being
executable - it's possible for it to be PROT_READ only, so we have to
remember whether we've flushed the region or not, and then flush the
entire region when a bit of it is made executable.
However, this also affects the brk area. That will no longer be
executable. We can mprotect() it to PROT_EXEC on MPU-mode kernels, but
for NOMMU mode kernels, when it increases the brk allocation, making
sys_brk() flush the extra from the icache should suffice. The brk area
probably isn't used by NOMMU programs since the brk area can only use up
the leavings from the stack allocation, where the stack allocation is
larger than requested.
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6
* 'slab/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6:
SLAB: Fix lockdep annotation breakage
Move sys_mmap_pgoff() from mm/util.c to mm/mmap.c and mm/nommu.c,
where we'd expect to find such code: especially now that it contains
the MAP_HUGETLB handling. Revert mm/util.c to how it was in 2.6.32.
This patch just ignores MAP_HUGETLB in the nommu case, as in 2.6.32,
whereas 2.6.33-rc2 reported -ENOSYS. Perhaps validate_mmap_request()
should reject it with -EINVAL? Add that later if necessary.
Commit ce79ddc8e2376a9a93c7d42daf89bfcbb9187e62 ("SLAB: Fix lockdep annotations
for CPU hotplug") broke init_node_lock_keys() off-slab logic which causes
lockdep false positives.
Fix that up by reverting the logic back to original while keeping CPU hotplug
fixes intact.
Reported-and-tested-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Reported-and-tested-by: Andi Kleen <andi@firstfloor.org>
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-misc-2.6
* 'sysctl' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-misc-2.6:
SYSCTL: Add a mutex to the page_alloc zone order sysctl
SYSCTL: Print binary sysctl warnings (nearly) only once
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6:
HWPOISON: Add PROC_FS dependency to hwpoison injector v2
The zone list code clearly cannot tolerate concurrent writers (I couldn't
find any locks for that), so simply add a global mutex. No need for RCU
in this case.
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (36 commits)
powerpc/gc/wii: Remove get_irq_desc()
powerpc/gc/wii: hlwd-pic: convert irq_desc.lock to raw_spinlock
powerpc/gamecube/wii: Fix off-by-one error in ugecon/usbgecko_udbg
powerpc/mpic: Fix problem that affinity is not updated
powerpc/mm: Fix stupid bug in subpge protection handling
powerpc/iseries: use DECLARE_COMPLETION_ONSTACK for non-constant completion
powerpc: Fix MSI support on U4 bridge PCIe slot
powerpc: Handle VSX alignment faults correctly in little-endian mode
powerpc/mm: Fix typo of cpumask_clear_cpu()
powerpc/mm: Fix hash_utils_64.c compile errors with DEBUG enabled.
powerpc: Convert BUG() to use unreachable()
powerpc/pseries: Make declarations of cpu_hotplug_driver_lock() ANSI compatible.
powerpc/pseries: Don't panic when H_PROD fails during cpu-online.
powerpc/mm: Fix a WARN_ON() with CONFIG_DEBUG_PAGEALLOC and CONFIG_DEBUG_VM
powerpc/defconfigs: Set HZ=100 on pseries and ppc64 defconfigs
powerpc/defconfigs: Disable token ring in powerpc defconfigs
powerpc/defconfigs: Reduce 64bit vmlinux by making acenic and cramfs modules
powerpc/pseries: Select XICS and PCI_MSI PSERIES
powerpc/85xx: Wrong variable returned on error
powerpc/iseries: Convert to proc_fops
The injector filter requires stable_page_flags() which is supplied
by procfs. So make it dependent on that.
Also add ifdefs around the filter code in memory-failure.c so that
when the filter is disabled due to missing dependencies the whole
code still builds.
Reported-by: Ingo Molnar
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, irq: Allow 0xff for /proc/irq/[n]/smp_affinity on an 8-cpu system
Makefile: Unexport LC_ALL instead of clearing it
x86: Fix objdump version check in arch/x86/tools/chkobjdump.awk
x86: Reenable TSC sync check at boot, even with NONSTOP_TSC
x86: Don't use POSIX character classes in gen-insn-attr-x86.awk
Makefile: set LC_CTYPE, LC_COLLATE, LC_NUMERIC to C
x86: Increase MAX_EARLY_RES; insufficient on 32-bit NUMA
x86: Fix checking of SRAT when node 0 ram is not from 0
x86, cpuid: Add "volatile" to asm in native_cpuid()
x86, msr: msrs_alloc/free for CONFIG_SMP=n
x86, amd: Get multi-node CPU info from NodeId MSR instead of PCI config space
x86: Add IA32_TSC_AUX MSR and use it
x86, msr/cpuid: Register enough minors for the MSR and CPUID drivers
initramfs: add missing decompressor error check
bzip2: Add missing checks for malloc returning NULL
bzip2/lzma/gzip: pre-boot malloc doesn't return NULL on failure
Memory balloon drivers can allocate a large amount of memory which is not
movable but could be freed to accomodate memory hotplug remove.
Prior to calling the memory hotplug notifier chain the memory in the
pageblock is isolated. Currently, if the migrate type is not
MIGRATE_MOVABLE the isolation will not proceed, causing the memory removal
for that page range to fail.
Rather than failing pageblock isolation if the migrateteype is not
MIGRATE_MOVABLE, this patch checks if all of the pages in the pageblock,
and not on the LRU, are owned by a registered balloon driver (or other
entity) using a notifier chain. If all of the non-movable pages are owned
by a balloon, they can be freed later through the memory notifier chain
and the range can still be isolated in set_migratetype_isolate().
Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com>
Cc: Brian King <brking@linux.vnet.ibm.com>
Cc: Gerald Schaefer <geralds@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus
* 'cpumask-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
cpumask: rename tsk_cpumask to tsk_cpus_allowed
cpumask: don't recommend set_cpus_allowed hack in Documentation/cpu-hotplug.txt
cpumask: avoid dereferencing struct cpumask
cpumask: convert drivers/idle/i7300_idle.c to cpumask_var_t
cpumask: use modern cpumask style in drivers/scsi/fcoe/fcoe.c
cpumask: avoid deprecated function in mm/slab.c
cpumask: use cpu_online in kernel/perf_event.c
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
Keys: KEYCTL_SESSION_TO_PARENT needs TIF_NOTIFY_RESUME architecture support
NOMMU: Optimise away the {dac_,}mmap_min_addr tests
security/min_addr.c: make init_mmap_min_addr() static
keys: PTR_ERR return of wrong pointer in keyctl_get_security()
* 'kmemleak' of git://linux-arm.org/linux-2.6:
kmemleak: fix kconfig for crc32 build error
kmemleak: Reduce the false positives by checking for modified objects
kmemleak: Show the age of an unreferenced object
kmemleak: Release the object lock before calling put_object()
kmemleak: Scan the _ftrace_events section in modules
kmemleak: Simplify the kmemleak_scan_area() function prototype
kmemleak: Do not use off-slab management with SLAB_NOLEAKTRACE
I added blk_run_backing_dev on page_cache_async_readahead so readahead I/O
is unpluged to improve throughput on especially RAID environment.
The normal case is, if page N become uptodate at time T(N), then T(N) <=
T(N+1) holds. With RAID (and NFS to some degree), there is no strict
ordering, the data arrival time depends on runtime status of individual
disks, which breaks that formula. So in do_generic_file_read(), just
after submitting the async readahead IO request, the current page may well
be uptodate, so the page won't be locked, and the block device won't be
implicitly unplugged:
if (PageReadahead(page))
page_cache_async_readahead()
if (!PageUptodate(page))
goto page_not_up_to_date;
page_not_up_to_date:
lock_page_killable(page);
Therefore explicit unplugging can help.
Following is the test result with dd.
#dd if=testdir/testfile of=/dev/null bs=16384
-2.6.30-rc6
1048576+0 records in
1048576+0 records out
17179869184 bytes (17 GB) copied, 224.182 seconds, 76.6 MB/s
-2.6.30-rc6-patched
17179869184 bytes (17 GB) copied, 206.465 seconds, 83.2 MB/s
(7Disks RAID-0 Array)
-2.6.30-rc6
1054976+0 records in
1054976+0 records out
17284726784 bytes (17 GB) copied, 212.233 seconds, 81.4 MB/s
-2.6.30-rc6-patched
17284726784 bytes (17 GB) copied, 198.878 seconds, 86.9 MB/s
(7Disks RAID-5 Array)
The patch was found to improve performance with the SCST scsi target
driver. See
http://sourceforge.net/mailarchive/forum.php?thread_name=a0272b440906030714g67eabc5k8f847fb1e538cc62%40mail.gmail.com&forum_name=scst-devel
[akpm@linux-foundation.org: unbust comment layout]
[akpm@linux-foundation.org: "fix" CONFIG_BLOCK=n]
Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp>
Acked-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Tested-by: Ronald <intercommit@gmail.com>
Cc: Bart Van Assche <bart.vanassche@gmail.com>
Cc: Vladislav Bolkhovitin <vst@vlnb.net>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
These days we use cpumask_empty() which takes a pointer.
Replacing
error = 0;
if (error)
op
with nothing is not quite an equivalent transformation ;-)
Found one system that boot from socket1 instead of socket0, SRAT get rejected...
[ 0.000000] SRAT: Node 1 PXM 0 0-a0000
[ 0.000000] SRAT: Node 1 PXM 0 100000-80000000
[ 0.000000] SRAT: Node 1 PXM 0 100000000-2080000000
[ 0.000000] SRAT: Node 0 PXM 1 2080000000-4080000000
[ 0.000000] SRAT: Node 2 PXM 2 4080000000-6080000000
[ 0.000000] SRAT: Node 3 PXM 3 6080000000-8080000000
[ 0.000000] SRAT: Node 4 PXM 4 8080000000-a080000000
[ 0.000000] SRAT: Node 5 PXM 5 a080000000-c080000000
[ 0.000000] SRAT: Node 6 PXM 6 c080000000-e080000000
[ 0.000000] SRAT: Node 7 PXM 7 e080000000-10080000000
[ 0.000000] NUMA: Allocated memnodemap from 500000 - 701040
[ 0.000000] NUMA: Using 20 for the hash shift.
[ 0.000000] Adding active range (0, 0x2080000, 0x4080000) 0 entries of 3200 used
[ 0.000000] Adding active range (1, 0x0, 0x96) 1 entries of 3200 used
[ 0.000000] Adding active range (1, 0x100, 0x7f750) 2 entries of 3200 used
[ 0.000000] Adding active range (1, 0x100000, 0x2080000) 3 entries of 3200 used
[ 0.000000] Adding active range (2, 0x4080000, 0x6080000) 4 entries of 3200 used
[ 0.000000] Adding active range (3, 0x6080000, 0x8080000) 5 entries of 3200 used
[ 0.000000] Adding active range (4, 0x8080000, 0xa080000) 6 entries of 3200 used
[ 0.000000] Adding active range (5, 0xa080000, 0xc080000) 7 entries of 3200 used
[ 0.000000] Adding active range (6, 0xc080000, 0xe080000) 8 entries of 3200 used
[ 0.000000] Adding active range (7, 0xe080000, 0x10080000) 9 entries of 3200 used
[ 0.000000] SRAT: PXMs only cover 917504MB of your 1048566MB e820 RAM. Not used.
[ 0.000000] SRAT: SRAT not used.
the early_node_map is not sorted because node0 with non zero start come first.
so try to sort it right away after all regions are registered.
also fixs refression by 8716273c (x86: Export srat physical topology)
-v2: make it more solid to handle cross node case like node0 [0,4g), [8,12g) and node1 [4g, 8g), [12g, 16g)
-v3: update comments.
Reported-and-tested-by: Jens Axboe <jens.axboe@oracle.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <4B2579D2.3010201@kernel.org>
In NOMMU mode clamp dac_mmap_min_addr to zero to cause the tests on it to be
skipped by the compiler. We do this as the minimum mmap address doesn't make
any sense in NOMMU mode.
mmap_min_addr and round_hint_to_min() can be discarded entirely in NOMMU mode.
Acked-by: Eric Paris <eparis@redhat.com>
Signed-off-by: James Morris <jmorris@namei.org>
* 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (34 commits)
HWPOISON: Remove stray phrase in a comment
HWPOISON: Try to allocate migration page on the same node
HWPOISON: Don't do early filtering if filter is disabled
HWPOISON: Add a madvise() injector for soft page offlining
HWPOISON: Add soft page offline support
HWPOISON: Undefine short-hand macros after use to avoid namespace conflict
HWPOISON: Use new shake_page in memory_failure
HWPOISON: Use correct name for MADV_HWPOISON in documentation
HWPOISON: mention HWPoison in Kconfig entry
HWPOISON: Use get_user_page_fast in hwpoison madvise
HWPOISON: add an interface to switch off/on all the page filters
HWPOISON: add memory cgroup filter
memcg: add accessor to mem_cgroup.css
memcg: rename and export try_get_mem_cgroup_from_page()
HWPOISON: add page flags filter
mm: export stable page flags
HWPOISON: limit hwpoison injector to known page types
HWPOISON: add fs/device filters
HWPOISON: return 0 to indicate success reliably
HWPOISON: make semantics of IGNORED/DELAYED clear
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (38 commits)
direct I/O fallback sync simplification
ocfs: stop using do_sync_mapping_range
cleanup blockdev_direct_IO locking
make generic_acl slightly more generic
sanitize xattr handler prototypes
libfs: move EXPORT_SYMBOL for d_alloc_name
vfs: force reval of target when following LAST_BIND symlinks (try #7)
ima: limit imbalance msg
Untangling ima mess, part 3: kill dead code in ima
Untangling ima mess, part 2: deal with counters
Untangling ima mess, part 1: alloc_file()
O_TRUNC open shouldn't fail after file truncation
ima: call ima_inode_free ima_inode_free
IMA: clean up the IMA counts updating code
ima: only insert at inode creation time
ima: valid return code from ima_inode_alloc
fs: move get_empty_filp() deffinition to internal.h
Sanitize exec_permission_lite()
Kill cached_lookup() and real_lookup()
Kill path_lookup_open()
Trivial conflicts in fs/direct-io.c
