path: root/mm
2009-09-14Merge branch 'kvm-updates/2.6.32' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.32' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (202 commits) MAINTAINERS: update KVM entry KVM: correct error-handling code KVM: fix compile warnings on s390 KVM: VMX: Check cpl before emulating debug register access KVM: fix misreporting of coalesced interrupts by kvm tracer KVM: x86: drop duplicate kvm_flush_remote_tlb calls KVM: VMX: call vmx_load_host_state() only if msr is cached KVM: VMX: Conditionally reload debug register 6 KVM: Use thread debug register storage instead of kvm specific data KVM guest: do not batch pte updates from interrupt context KVM: Fix coalesced interrupt reporting in IOAPIC KVM guest: fix bogus wallclock physical address calculation KVM: VMX: Fix cr8 exiting control clobbering by EPT KVM: Optimize kvm_mmu_unprotect_page_virt() for tdp KVM: Document KVM_CAP_IRQCHIP KVM: Protect update_cr8_intercept() when running without an apic KVM: VMX: Fix EPT with WP bit change during paging KVM: Use kvm_{read,write}_guest_virt() to read and write segment descriptors KVM: x86 emulator: Add adc and sbb missing decoder flags KVM: Add missing #include ...
2009-09-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: slub: fix slab_pad_check() slub: release kobject if sysfs_create_group failed in sysfs_slab_add SLUB: fix ARCH_KMALLOC_MINALIGN cases 64 and 256 SLUB: Fix some coding style issues SLUB: Drop write permission to /proc/slabinfo slab: remove duplicate kmem_cache_init_late() declarations slub: change kmem_cache->align to record the real alignment slub: use size and objsize orders to disable debug flags slub: add option to disable higher order debugging slabs
2009-09-14Merge branches 'slab/cleanups' and 'slab/fixes' into for-linusPekka Enberg
2009-09-14vfs: Remove generic_osync_inode() and sync_page_range{_nolock}()Jan Kara
Remove these three functions since nobody uses them anymore. Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14vfs: Introduce new helpers for syncing after writing to O_SYNC file or ↵Jan Kara
IS_SYNC inode Introduce new function for generic inode syncing (vfs_fsync_range) and use it from fsync() path. Introduce also new helper for syncing after a sync write (generic_write_sync) using the generic function. Use these new helpers for syncing from generic VFS functions. This makes O_SYNC writes to block devices acquire i_mutex for syncing. If we really care about this, we can make block_fsync() drop the i_mutex and reacquire it before it returns. CC: Evgeniy Polyakov <zbr@ioremap.net> CC: ocfs2-devel@oss.oracle.com CC: Joel Becker <joel.becker@oracle.com> CC: Felix Blyakher <felixb@sgi.com> CC: xfs@oss.sgi.com CC: Anton Altaparmakov <aia21@cantab.net> CC: linux-ntfs-dev@lists.sourceforge.net CC: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> CC: linux-ext4@vger.kernel.org CC: tytso@mit.edu Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14vfs: Rename generic_file_aio_write_nolockChristoph Hellwig
generic_file_aio_write_nolock() is now used only by block devices and raw character device. Filesystems should use __generic_file_aio_write() in case generic_file_aio_write() doesn't suit them. So rename the function to blkdev_aio_write() and move it to fs/blockdev.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14vfs: Remove syncing from generic_file_direct_write() and ↵Jan Kara
generic_file_buffered_write() generic_file_direct_write() and generic_file_buffered_write() called generic_osync_inode() if it was called on O_SYNC file or IS_SYNC inode. But this is superfluous since generic_file_aio_write() does the syncing as well. Also XFS and OCFS2 which call these functions directly handle syncing themselves. So let's have a single place where syncing happens: generic_file_aio_write(). We slightly change the behavior by syncing only the range of file to which the write happened for buffered writes but that should be all that is required. CC: ocfs2-devel@oss.oracle.com CC: Joel Becker <joel.becker@oracle.com> CC: Felix Blyakher <felixb@sgi.com> CC: xfs@oss.sgi.com Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14vfs: Export __generic_file_aio_write() and add some commentsJan Kara
Rename __generic_file_aio_write_nolock() to __generic_file_aio_write(), add comments to write helpers explaining how they should be used and export __generic_file_aio_write() since it will be used by some filesystems. CC: ocfs2-devel@oss.oracle.com CC: Joel Becker <joel.becker@oracle.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14vfs: Introduce filemap_fdatawait_rangeJan Kara
This simple helper saves some filesystems conversion from byte offset to page numbers and also makes the fdata* interface more complete. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14slub: fix slab_pad_check()Eric Dumazet
When SLAB_POISON is used and slab_pad_check() finds an overwrite of the slab padding, we call restore_bytes() on the whole slab, not only on the padding. Acked-by: Christoph Lameer <cl@linux-foundation.org> Reported-by: Zdenek Kabelac <zdenek.kabelac@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-09-11Merge branch 'writeback' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'writeback' of git://git.kernel.dk/linux-2.6-block: writeback: check for registered bdi in flusher add and inode dirty writeback: add name to backing_dev_info writeback: add some debug inode list counters to bdi stats writeback: get rid of pdflush completely writeback: switch to per-bdi threads for flushing data writeback: move dirty inodes from super_block to backing_dev_info writeback: get rid of generic_sync_sb_inodes() export
2009-09-11Merge branch 'kmemleak' of git://linux-arm.org/linux-2.6Linus Torvalds
* 'kmemleak' of git://linux-arm.org/linux-2.6: kmemleak: Improve the "Early log buffer exceeded" error message kmemleak: fix sparse warning for static declarations kmemleak: fix sparse warning over overshadowed flags kmemleak: move common painting code together kmemleak: add clear command support kmemleak: use bool for true/false questions kmemleak: Do no create the clean-up thread during kmemleak_disable() kmemleak: Scan all thread stacks kmemleak: Don't scan uninitialized memory when kmemcheck is enabled kmemleak: Ignore the aperture memory hole on x86_64 kmemleak: Printing of the objects hex dump kmemleak: Do not report alloc_bootmem blocks as leaks kmemleak: Save the stack trace for early allocations kmemleak: Mark the early log buffer as __initdata kmemleak: Dump object information on request kmemleak: Allow rescheduling during an object scanning
2009-09-11kmemleak: Improve the "Early log buffer exceeded" error messageCatalin Marinas
Based on a suggestion from Jaswinder, clarify what the user would need to do to avoid this error message from kmemleak. Reported-by: Jaswinder Singh Rajput <jaswinder@kernel.org> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-09-11writeback: check for registered bdi in flusher add and inode dirtyJens Axboe
Also a debugging aid. We want to catch dirty inodes being added to backing devices that don't do writeback. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11writeback: add name to backing_dev_infoJens Axboe
This enables us to track who does what and print info. Its main use is catching dirty inodes on the default_backing_dev_info, so we can fix that up. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11writeback: add some debug inode list counters to bdi statsJens Axboe
Add some debug entries to be able to inspect the internal state of the writeback details. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11writeback: get rid of pdflush completelyJens Axboe
It is now unused, so kill it off. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11writeback: switch to per-bdi threads for flushing dataJens Axboe
This gets rid of pdflush for bdi writeout and kupdated style cleaning. pdflush writeout suffers from lack of locality and also requires more threads to handle the same workload, since it has to work in a non-blocking fashion against each queue. This also introduces lumpy behaviour and potential request starvation, since pdflush can be starved for queue access if others are accessing it. A sample ffsb workload that does random writes to files is about 8% faster here on a simple SATA drive during the benchmark phase. File layout also seems a LOT more smooth in vmstat: r b swpd free buff cache si so bi bo in cs us sy id wa 0 1 0 608848 2652 375372 0 0 0 71024 604 24 1 10 48 42 0 1 0 549644 2712 433736 0 0 0 60692 505 27 1 8 48 44 1 0 0 476928 2784 505192 0 0 4 29540 553 24 0 9 53 37 0 1 0 457972 2808 524008 0 0 0 54876 331 16 0 4 38 58 0 1 0 366128 2928 614284 0 0 4 92168 710 58 0 13 53 34 0 1 0 295092 3000 684140 0 0 0 62924 572 23 0 9 53 37 0 1 0 236592 3064 741704 0 0 4 58256 523 17 0 8 48 44 0 1 0 165608 3132 811464 0 0 0 57460 560 21 0 8 54 38 0 1 0 102952 3200 873164 0 0 4 74748 540 29 1 10 48 41 0 1 0 48604 3252 926472 0 0 0 53248 469 29 0 7 47 45 where vanilla tends to fluctuate a lot in the creation phase: r b swpd free buff cache si so bi bo in cs us sy id wa 1 1 0 678716 5792 303380 0 0 0 74064 565 50 1 11 52 36 1 0 0 662488 5864 319396 0 0 4 352 302 329 0 2 47 51 0 1 0 599312 5924 381468 0 0 0 78164 516 55 0 9 51 40 0 1 0 519952 6008 459516 0 0 4 78156 622 56 1 11 52 37 1 1 0 436640 6092 541632 0 0 0 82244 622 54 0 11 48 41 0 1 0 436640 6092 541660 0 0 0 8 152 39 0 0 51 49 0 1 0 332224 6200 644252 0 0 4 102800 728 46 1 13 49 36 1 0 0 274492 6260 701056 0 0 4 12328 459 49 0 7 50 43 0 1 0 211220 6324 763356 0 0 0 106940 515 37 1 10 51 39 1 0 0 160412 6376 813468 0 0 0 8224 415 43 0 6 49 45 1 1 0 85980 6452 886556 0 0 4 113516 575 39 1 11 54 34 0 2 0 85968 6452 886620 0 0 0 1640 158 211 0 0 46 54 A 10 disk test with btrfs performs 26% faster with per-bdi flushing. A SSD based writeback test on XFS performs over 20% better as well, with the throughput being very stable around 1GB/sec, where pdflush only manages 750MB/sec and fluctuates wildly while doing so. Random buffered writes to many files behave a lot better as well, as does random mmap'ed writes. A separate thread is added to sync the super blocks. In the long term, adding sync_supers_bdi() functionality could get rid of this thread again. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11writeback: move dirty inodes from super_block to backing_dev_infoJens Axboe
This is a first step at introducing per-bdi flusher threads. We should have no change in behaviour, although sb_has_dirty_inodes() is now ridiculously expensive, as there's no easy way to answer that question. Not a huge problem, since it'll be deleted in subsequent patches. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-10hugetlbfs: export vma_kernel_pagsize to modulesJoerg Roedel
This function is required by KVM. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-08shmfs: use 'check_acl' instead of 'permission'Linus Torvalds
shmfs wants purely standard POSIX ACL semantics, so we can use the new generic VFS layer POSIX ACL checking rather than cooking our own 'permission()' function. Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-08kmemleak: fix sparse warning for static declarationsLuis R. Rodriguez
This fixes these sparse warnings: mm/kmemleak.c:1179:6: warning: symbol 'start_scan_thread' was not declared. Should it be static? mm/kmemleak.c:1194:6: warning: symbol 'stop_scan_thread' was not declared. Should it be static? Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-09-08kmemleak: fix sparse warning over overshadowed flagsLuis R. Rodriguez
A secondary irq_save is not required as a locking before it was already disabling irqs. This fixes this sparse warning: mm/kmemleak.c:512:31: warning: symbol 'flags' shadows an earlier one mm/kmemleak.c:448:23: originally declared here Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-09-08kmemleak: move common painting code togetherLuis R. Rodriguez
When painting grey or black we do the same thing, bring this together into a helper and identify coloring grey or black explicitly with defines. This makes this a little easier to read. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-09-08kmemleak: add clear command supportLuis R. Rodriguez
In an ideal world your kmemleak output will be small, when its not (usually during initial bootup) you can use the clear command to ingore previously reported and unreferenced kmemleak objects. We do this by painting all currently reported unreferenced objects grey. We paint them grey instead of black to allow future scans on the same objects as such objects could still potentially reference newly allocated objects in the future. To test a critical section on demand with a clean /sys/kernel/debug/kmemleak you can do: echo clear > /sys/kernel/debug/kmemleak test your kernel or modules echo scan > /sys/kernel/debug/kmemleak Then as usual to get your report with: cat /sys/kernel/debug/kmemleak Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-09-08kmemleak: use bool for true/false questionsLuis R. Rodriguez
2009-09-08kmemleak: Do no create the clean-up thread during kmemleak_disable()Catalin Marinas
The kmemleak_disable() function could be called from various contexts including IRQ. It creates a clean-up thread but the kthread_create() function has restrictions on which contexts it can be called from, mainly because of the kthread_create_lock. The patch changes the kmemleak clean-up thread to a workqueue. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reported-by: Eric Paris <eparis@redhat.com>
2009-09-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: don't assume existence of cpu0
2009-09-05Merge branch 'slab/urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'slab/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: slub: Fix kmem_cache_destroy() with SLAB_DESTROY_BY_RCU
2009-09-05page-allocator: always change pageblock ownership when anti-fragmentation is ↵Mel Gorman
disabled On low-memory systems, anti-fragmentation gets disabled as fragmentation cannot be avoided on a sufficiently large boundary to be worthwhile. Once disabled, there is a period of time when all the pageblocks are marked MOVABLE and the expectation is that they get marked UNMOVABLE at each call to __rmqueue_fallback(). However, when MAX_ORDER is large the pageblocks do not change ownership because the normal criteria are not met. This has the effect of prematurely breaking up too many large contiguous blocks. This is most serious on NOMMU systems which depend on high-order allocations to boot. This patch causes pageblocks to change ownership on every fallback when anti-fragmentation is disabled. This prevents the large blocks being prematurely broken up. This is a fix to commit 49255c619fbd482d704289b5eb2795f8e3b7ff2e [page allocator: move check for disabled anti-fragmentation out of fastpath] and the problem affects 2.6.31-rc8. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Tested-by: Paul Mundt <lethal@linux-sh.org> Cc: David Howells <dhowells@redhat.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-05nommu: fix error handling in do_mmap_pgoff()David Howells
Fix the error handling in do_mmap_pgoff(). If do_mmap_shared_file() or do_mmap_private() fail, we jump to the error_put_region label at which point we cann __put_nommu_region() on the region - but we haven't yet added the region to the tree, and so __put_nommu_region() may BUG because the region tree is empty or it may corrupt the region tree. To get around this, we can afford to add the region to the region tree before calling do_mmap_shared_file() or do_mmap_private() as we keep nommu_region_sem write-locked, so no-one can race with us by seeing a transient region. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-04kmemleak: Scan all thread stacksCatalin Marinas
This patch changes the for_each_process() loop with the do_each_thread()/while_each_thread() pair. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-09-04kmemleak: Don't scan uninitialized memory when kmemcheck is enabledPekka Enberg
Ingo Molnar reported the following kmemcheck warning when running both kmemleak and kmemcheck enabled: PM: Adding info for No Bus:vcsa7 WARNING: kmemcheck: Caught 32-bit read from uninitialized memory (f6f6e1a4) d873f9f600000000c42ae4c1005c87f70000000070665f666978656400000000 i i i i u u u u i i i i i i i i i i i i i i i i i i i i i u u u ^ Pid: 3091, comm: kmemleak Not tainted (2.6.31-rc7-tip #1303) P4DC6 EIP: 0060:[<c110301f>] EFLAGS: 00010006 CPU: 0 EIP is at scan_block+0x3f/0xe0 EAX: f40bd700 EBX: f40bd780 ECX: f16b46c0 EDX: 00000001 ESI: f6f6e1a4 EDI: 00000000 EBP: f10f3f4c ESP: c2605fcc DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 CR0: 8005003b CR2: e89a4844 CR3: 30ff1000 CR4: 000006f0 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 DR6: ffff4ff0 DR7: 00000400 [<c110313c>] scan_object+0x7c/0xf0 [<c1103389>] kmemleak_scan+0x1d9/0x400 [<c1103a3c>] kmemleak_scan_thread+0x4c/0xb0 [<c10819d4>] kthread+0x74/0x80 [<c10257db>] kernel_thread_helper+0x7/0x3c [<ffffffff>] 0xffffffff kmemleak: 515 new suspected memory leaks (see /sys/kernel/debug/kmemleak) kmemleak: 42 new suspected memory leaks (see /sys/kernel/debug/kmemleak) The problem here is that kmemleak will scan partially initialized objects that makes kmemcheck complain. Fix that up by skipping uninitialized memory regions when kmemcheck is enabled. Reported-by: Ingo Molnar <mingo@elte.hu> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-09-03slub: Fix kmem_cache_destroy() with SLAB_DESTROY_BY_RCUEric Dumazet
kmem_cache_destroy() should call rcu_barrier() *after* kmem_cache_close() and *before* sysfs_slab_remove() or risk rcu_free_slab() being called after kmem_cache is deleted (kfreed). rmmod nf_conntrack can crash the machine because it has to kmem_cache_destroy() a SLAB_DESTROY_BY_RCU enabled cache. Cc: <stable@kernel.org> Reported-by: Zdenek Kabelac <zdenek.kabelac@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-09-03slub: release kobject if sysfs_create_group failed in sysfs_slab_addXiaotian Feng
When CONFIG_SLUB_DEBUG is enabled, sysfs_slab_add should unlink and put the kobject if sysfs_create_group failed. Otherwise, sysfs_slab_add returns error then free kmem_cache s, thus memory of s->kobj is leaked. Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-09-01percpu: don't assume existence of cpu0Tejun Heo
percpu incorrectly assumed that cpu0 was always there which led to the following warning and eventual oops on sparc machines w/o cpu0. WARNING: at mm/percpu.c:651 pcpu_map+0xdc/0x100() Modules linked in: Call Trace: [000000000045eb70] warn_slowpath_common+0x50/0xa0 [000000000045ebdc] warn_slowpath_null+0x1c/0x40 [00000000004d493c] pcpu_map+0xdc/0x100 [00000000004d59a4] pcpu_alloc+0x3e4/0x4e0 [00000000004d5af8] __alloc_percpu+0x18/0x40 [00000000005b112c] __percpu_counter_init+0x4c/0xc0 ... Unable to handle kernel NULL pointer dereference ... I7: <sysfs_new_dirent+0x30/0x120> Disabling lock debugging due to kernel taint Caller[000000000053c1b0]: sysfs_new_dirent+0x30/0x120 Caller[000000000053c7a4]: create_dir+0x24/0xc0 Caller[000000000053c870]: sysfs_create_dir+0x30/0x80 Caller[00000000005990e8]: kobject_add_internal+0xc8/0x200 ... Kernel panic - not syncing: Attempted to kill the idle task! This patch fixes the problem by backporting parts from devel branch to make percpu core not depend on the existence of cpu0. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Meelis Roos <mroos@linux.ee> Cc: David Miller <davem@davemloft.net>
2009-08-30SLUB: fix ARCH_KMALLOC_MINALIGN cases 64 and 256Aaro Koskinen
If the minalign is 64 bytes, then the 96 byte cache should not be created because it would conflict with the 128 byte cache. If the minalign is 256 bytes, patching the size_index table should not result in a buffer overrun. The calculation "(i - 1) / 8" used to access size_index[] is moved to a separate function as suggested by Christoph Lameter. Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-08-27kmemleak: Printing of the objects hex dumpSergey Senozhatsky
Introducing printing of the objects hex dump to the seq file. The number of lines to be printed is limited to HEX_MAX_LINES to prevent seq file spamming. The actual number of printed bytes is less than or equal to (HEX_MAX_LINES * HEX_ROW_SIZE). (slight adjustments by Catalin Marinas) Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@mail.by> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-08-27kmemleak: Do not report alloc_bootmem blocks as leaksCatalin Marinas
This patch sets the min_count for alloc_bootmem objects to 0 so that they are never reported as leaks. This is because many of these blocks are only referred via the physical address which is not looked up by kmemleak. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi>
2009-08-27kmemleak: Save the stack trace for early allocationsCatalin Marinas
Before slab is initialised, kmemleak save the allocations in an early log buffer. They are later recorded as normal memory allocations. This patch adds the stack trace saving to the early log buffer, otherwise the information shown for such objects only refers to the kmemleak_init() function. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-08-27kmemleak: Mark the early log buffer as __initdataCatalin Marinas
This buffer isn't needed after kmemleak was initialised so it can be freed together with the .init.data section. This patch also marks functions conditionally accessing the early log variables with __ref. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-08-27kmemleak: Dump object information on requestCatalin Marinas
By writing dump=<addr> to the kmemleak file, kmemleak will look up an object with that address and dump the information it has about it to syslog. This is useful in debugging memory leaks. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-08-27kmemleak: Allow rescheduling during an object scanningCatalin Marinas
If the object size is bigger than a predefined value (4K in this case), release the object lock during scanning and call cond_resched(). Re-acquire the lock after rescheduling and test whether the object is still valid. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-08-26mm: fix for infinite churning of mlocked pagesMinchan Kim
An mlocked page might lose the isolatation race. This causes the page to clear PG_mlocked while it remains in a VM_LOCKED vma. This means it can be put onto the [in]active list. We can rescue it by using try_to_unmap() in shrink_page_list(). But now, As Wu Fengguang pointed out, vmscan has a bug. If the page has PG_referenced, it can't reach try_to_unmap() in shrink_page_list() but is put into the active list. If the page is referenced repeatedly, it can remain on the [in]active list without being moving to the unevictable list. This patch fixes it. Reported-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KOSAKI Motohiro <<kosaki.motohiro@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-19SLUB: Fix some coding style issuesAmerigo Wang
Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-08-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: use the right flag for get_vm_area() percpu, sparc64: fix sparse possible cpu map handling init: set nr_cpu_ids before setup_per_cpu_areas()
2009-08-18mm: build_zonelists(): move clear node_load[] to __build_all_zonelists()Bo Liu
If node_load[] is cleared everytime build_zonelists() is called,node_load[] will have no help to find the next node that should appear in the given node's fallback list. Because of the bug, zonelist's node_order is not calculated as expected. This bug affects on big machine, which has asynmetric node distance. [synmetric NUMA's node distance] 0 1 2 0 10 12 12 1 12 10 12 2 12 12 10 [asynmetric NUMA's node distance] 0 1 2 0 10 12 20 1 12 10 14 2 20 14 10 This (my bug) is very old but no one has reported this for a long time. Maybe because the number of asynmetric NUMA is very small and they use cpuset for customizing node memory allocation fallback. [akpm@linux-foundation.org: fix CONFIG_NUMA=n build] Signed-off-by: Bo Liu <bo-liu@hotmail.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-18nommu: check fd read permission in validate_mmap_request()Graff Yang
According to the POSIX (1003.1-2008), the file descriptor shall have been opened with read permission, regardless of the protection options specified to mmap(). The ltp test cases mmap06/07 need this. Signed-off-by: Graff Yang <graff.yang@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-18mm: revert "oom: move oom_adj value"KOSAKI Motohiro
The commit 2ff05b2b (oom: move oom_adj value) moveed the oom_adj value to the mm_struct. It was a very good first step for sanitize OOM. However Paul Menage reported the commit makes regression to his job scheduler. Current OOM logic can kill OOM_DISABLED process. Why? His program has the code of similar to the following. ... set_oom_adj(OOM_DISABLE); /* The job scheduler never killed by oom */ ... if (vfork() == 0) { set_oom_adj(0); /* Invoked child can be killed */ execve("foo-bar-cmd"); } .... vfork() parent and child are shared the same mm_struct. then above set_oom_adj(0) doesn't only change oom_adj for vfork() child, it's also change oom_adj for vfork() parent. Then, vfork() parent (job scheduler) lost OOM immune and it was killed. Actually, fork-setting-exec idiom is very frequently used in userland program. We must not break this assumption. Then, this patch revert commit 2ff05b2b and related commit. Reverted commit list --------------------- - commit 2ff05b2b4e (oom: move oom_adj value from task_struct to mm_struct) - commit 4d8b9135c3 (oom: avoid unnecessary mm locking and scanning for OOM_DISABLE) - commit 8123681022 (oom: only oom kill exiting tasks with attached memory) - commit 933b787b57 (mm: copy over oom_adj value at fork time) Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-18SLUB: Drop write permission to /proc/slabinfoWANG Cong
SLUB does not support writes to /proc/slabinfo so there should not be write permission to do that either. Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
