path: root/mm
2010-03-06mm: change anon_vma linking to fix multi-process server scalability issueRik van Riel
The old anon_vma code can lead to scalability issues with heavily forking workloads. Specifically, each anon_vma will be shared between the parent process and all its child processes. In a workload with 1000 child processes and a VMA with 1000 anonymous pages per process that get COWed, this leads to a system with a million anonymous pages in the same anon_vma, each of which is mapped in just one of the 1000 processes. However, the current rmap code needs to walk them all, leading to O(N) scanning complexity for each page. This can result in systems where one CPU is walking the page tables of 1000 processes in page_referenced_one, while all other CPUs are stuck on the anon_vma lock. This leads to catastrophic failure for a benchmark like AIM7, where the total number of processes can reach in the tens of thousands. Real workloads are still a factor 10 less process intensive than AIM7, but they are catching up. This patch changes the way anon_vmas and VMAs are linked, which allows us to associate multiple anon_vmas with a VMA. At fork time, each child process gets its own anon_vmas, in which its COWed pages will be instantiated. The parents' anon_vma is also linked to the VMA, because non-COWed pages could be present in any of the children. This reduces rmap scanning complexity to O(1) for the pages of the 1000 child processes, with O(N) complexity for at most 1/N pages in the system. This reduces the average scanning cost in heavily forking workloads from O(N) to 2. The only real complexity in this patch stems from the fact that linking a VMA to anon_vmas now involves memory allocations. This means vma_adjust can fail, if it needs to attach a VMA to anon_vma structures. This in turn means error handling needs to be added to the calling functions. A second source of complexity is that, because there can be multiple anon_vmas, the anon_vma linking in vma_adjust can no longer be done under "the" anon_vma lock. To prevent the rmap code from walking up an incomplete VMA, this patch introduces the VM_LOCK_RMAP VMA flag. This bit flag uses the same slot as the NOMMU VM_MAPPED_COPY, with an ifdef in mm.h to make sure it is impossible to compile a kernel that needs both symbolic values for the same bitflag. Some test results: Without the anon_vma changes, when AIM7 hits around 9.7k users (on a test box with 16GB RAM and not quite enough IO), the system ends up running >99% in system time, with every CPU on the same anon_vma lock in the pageout code. With these changes, AIM7 hits the cross-over point around 29.7k users. This happens with ~99% IO wait time, there never seems to be any spike in system time. The anon_vma lock contention appears to be resolved. [akpm@linux-foundation.org: cleanups] Signed-off-by: Rik van Riel <riel@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm/memcontrol.c: fix "integer as NULL pointer" sparse warningThiago Farina
mm/memcontrol.c:2548:32: warning: Using plain integer as NULL pointer Signed-off-by: Thiago Farina <tfransosi@gmail.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06readahead: introduce FMODE_RANDOM for POSIX_FADV_RANDOMWu Fengguang
This fixes inefficient page-by-page reads on POSIX_FADV_RANDOM. POSIX_FADV_RANDOM used to set ra_pages=0, which leads to poor performance: a 16K read will be carried out in 4 _sync_ 1-page reads. In other places, ra_pages==0 means - it's ramfs/tmpfs/hugetlbfs/sysfs/configfs - some IO error happened where multi-page read IO won't help or should be avoided. POSIX_FADV_RANDOM actually want a different semantics: to disable the *heuristic* readahead algorithm, and to use a dumb one which faithfully submit read IO for whatever application requests. So introduce a flag FMODE_RANDOM for POSIX_FADV_RANDOM. Note that the random hint is not likely to help random reads performance noticeably. And it may be too permissive on huge request size (its IO size is not limited by read_ahead_kb). In Quentin's report (http://lkml.org/lkml/2009/12/24/145), the overall (NFS read) performance of the application increased by 313%! Tested-by: Quentin Barnes <qbarnes+nfs@yahoo-inc.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: David Howells <dhowells@redhat.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Chuck Lever <chuck.lever@oracle.com> Cc: <stable@kernel.org> [2.6.33.x] Cc: <qbarnes+nfs@yahoo-inc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm/migrate.c: kill anon local variable from migrate_page_copyKOSAKI Motohiro
commit 01b1ae63c2 ("memcg: simple migration handling") removed mem_cgroup_uncharge_cache_page() call from migrate_page_copy. Local variable `anon' is now unused. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm/mempolicy.c: fix indentation of the comments of do_migrate_pagesKOSAKI Motohiro
Currently, do_migrate_pages() have very long comment and this is not indent properly. I often misunderstand it is function starting commnents and confused it. this patch fixes it. note: this patch doesn't break 80 column rule. I guess original author intended this indentaion, but an accident corrupted it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06memory-hotplug: create /sys/firmware/memmap entry for new memoryakpm@linux-foundation.org
A memmap is a directory in sysfs which includes 3 text files: start, end and type. For example: start: 0x100000 end: 0x7e7b1cff type: System RAM Interface firmware_map_add was not called explicitly. Remove it and add function firmware_map_add_hotplug as hotplug interface of memmap. Each memory entry has a memmap in sysfs, When we hot-add new memory, sysfs does not export memmap entry for it. We add a call in function add_memory to function firmware_map_add_hotplug. Add a new function add_sysfs_fw_map_entry() to create memmap entry, it will be called when initialize memmap and hot-add memory. [akpm@linux-foundation.org: un-kernedoc a no longer kerneldoc comment] Signed-off-by: Shaohui Zheng <shaohui.zheng@intel.com> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: fix mbind vma merge problemKOSAKI Motohiro
Strangely, current mbind() doesn't merge vma with neighbor vma although it's possible. Unfortunately, many vma can reduce performance... This patch fixes it. reproduced program ---------------------------------------------------------------- #include <numaif.h> #include <numa.h> #include <sys/mman.h> #include <stdio.h> #include <unistd.h> #include <stdlib.h> #include <string.h> static unsigned long pagesize; int main(int argc, char** argv) { void* addr; int ch; int node; struct bitmask *nmask = numa_allocate_nodemask(); int err; int node_set = 0; char buf[128]; while ((ch = getopt(argc, argv, "n:")) != -1){ switch (ch){ case 'n': node = strtol(optarg, NULL, 0); numa_bitmask_setbit(nmask, node); node_set = 1; break; default: ; } } argc -= optind; argv += optind; if (!node_set) numa_bitmask_setbit(nmask, 0); pagesize = getpagesize(); addr = mmap(NULL, pagesize*3, PROT_READ|PROT_WRITE, MAP_ANON|MAP_PRIVATE, 0, 0); if (addr == MAP_FAILED) perror("mmap "), exit(1); fprintf(stderr, "pid = %d \n" "addr = %p\n", getpid(), addr); /* make page populate */ memset(addr, 0, pagesize*3); /* first mbind */ err = mbind(addr+pagesize, pagesize, MPOL_BIND, nmask->maskp, nmask->size, MPOL_MF_MOVE_ALL); if (err) error("mbind1 "); /* second mbind */ err = mbind(addr, pagesize*3, MPOL_DEFAULT, NULL, 0, 0); if (err) error("mbind2 "); sprintf(buf, "cat /proc/%d/maps", getpid()); system(buf); return 0; } ---------------------------------------------------------------- result without this patch addr = 0x7fe26ef09000 [snip] 7fe26ef09000-7fe26ef0a000 rw-p 00000000 00:00 0 7fe26ef0a000-7fe26ef0b000 rw-p 00000000 00:00 0 7fe26ef0b000-7fe26ef0c000 rw-p 00000000 00:00 0 7fe26ef0c000-7fe26ef0d000 rw-p 00000000 00:00 0 => 0x7fe26ef09000-0x7fe26ef0c000 have three vmas. result with this patch addr = 0x7fc9ebc76000 [snip] 7fc9ebc76000-7fc9ebc7a000 rw-p 00000000 00:00 0 7fffbe690000-7fffbe6a5000 rw-p 00000000 00:00 0 [stack] => 0x7fc9ebc76000-0x7fc9ebc7a000 have only one vma. [minchan.kim@gmail.com: fix file offset passed to vma_merge()] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: restore zone->all_unreclaimable to independence wordKOSAKI Motohiro
commit e815af95 ("change all_unreclaimable zone member to flags") changed all_unreclaimable member to bit flag. But it had an undesireble side effect. free_one_page() is one of most hot path in linux kernel and increasing atomic ops in it can reduce kernel performance a bit. Thus, this patch revert such commit partially. at least all_unreclaimable shouldn't share memory word with other zone flags. [akpm@linux-foundation.org: fix patch interaction] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Huang Shijie <shijie8@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: remove free_hot_page()Li Hong
free_hot_page() is just a wrapper around free_hot_cold_page() with parameter 'cold = 0'. After adding a clear comment for free_hot_cold_page(), it is reasonable to remove a level of call. [akpm@linux-foundation.org: fix build] Signed-off-by: Li Hong <lihong.hi@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Li Ming Chun <macli@brc.ubc.ca> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm/page_alloc.c: adjust a call site to trace_mm_page_free_directLi Hong
Move a call of trace_mm_page_free_direct() from free_hot_page() to free_hot_cold_page(). It is clearer and close to kmemcheck_free_shadow(), as it is done in function __free_pages_ok(). Signed-off-by: Li Hong <lihong.hi@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Li Ming Chun <macli@brc.ubc.ca> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm/page_alloc.c: remove duplicate call to trace_mm_page_free_directLi Hong
trace_mm_page_free_direct() is called in function __free_pages(). But it is called again in free_hot_page() if order == 0 and produce duplicate records in trace file for mm_page_free_direct event. As below: K-PID CPU# TIMESTAMP FUNCTION gnome-terminal-1567 [000] 4415.246466: mm_page_free_direct: page=ffffea0003db9f40 pfn=1155800 order=0 gnome-terminal-1567 [000] 4415.246468: mm_page_free_direct: page=ffffea0003db9f40 pfn=1155800 order=0 gnome-terminal-1567 [000] 4415.246506: mm_page_alloc: page=ffffea0003db9f40 pfn=1155800 order=0 migratetype=0 gfp_flags=GFP_KERNEL gnome-terminal-1567 [000] 4415.255557: mm_page_free_direct: page=ffffea0003db9f40 pfn=1155800 order=0 gnome-terminal-1567 [000] 4415.255557: mm_page_free_direct: page=ffffea0003db9f40 pfn=1155800 order=0 This patch removes the first call and adds a call to trace_mm_page_free_direct() in __free_pages_ok(). Signed-off-by: Li Hong <lihong.hi@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Li Ming Chun <macli@brc.ubc.ca> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm, lockdep: annotate reclaim context to zone reclaim tooKOSAKI Motohiro
Commit cf40bd16fd ("lockdep: annotate reclaim context") introduced reclaim context annotation. But it didn't annotate zone reclaim. This patch do it. The point is, commit cf40bd16fd annotate __alloc_pages_direct_reclaim but zone-reclaim doesn't use __alloc_pages_direct_reclaim. current call graph is __alloc_pages_nodemask get_page_from_freelist zone_reclaim() __alloc_pages_slowpath __alloc_pages_direct_reclaim try_to_free_pages Actually, if zone_reclaim_mode=1, VM never call __alloc_pages_direct_reclaim in usual VM pressure. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Nick Piggin <npiggin@suse.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06vmscan: get_scan_ratio() cleanupKOSAKI Motohiro
The get_scan_ratio() should have all scan-ratio related calculations. Thus, this patch move some calculation into get_scan_ratio. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06vmscan: check high watermark after shrink zoneMinchan Kim
Kswapd checks that zone has sufficient pages free via zone_watermark_ok(). If any zone doesn't have enough pages, we set all_zones_ok to zero. !all_zone_ok makes kswapd retry rather than sleeping. I think the watermark check before shrink_zone() is pointless. Only after kswapd has tried to shrink the zone is the check meaningful. Move the check to after the call to shrink_zone(). [akpm@linux-foundation.org: fix comment, layout] Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: use rlimit helpersJiri Slaby
Make sure compiler won't do weird things with limits. E.g. fetching them twice may return 2 different values after writable limits are implemented. I.e. either use rlimit helpers added in 3e10e716abf3c71bdb5d86b8f507f9e72236c9cd ("resource: add helpers for fetching rlimits") or ACCESS_ONCE if not applicable. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: mlock_vma_pages_range() only return success or failureKOSAKI Motohiro
Currently, mlock_vma_pages_range() only return len or 0. then current error handling of mmap_region() is meaningless complex. This patch makes simplify and makes consist with brk() code. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamewzawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: mlock_vma_pages_range() never return negative valueKOSAKI Motohiro
Currently, mlock_vma_pages_range() never return negative value. Then, we can remove some worthless error check. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamewzawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: count swap usageKAMEZAWA Hiroyuki
A frequent questions from users about memory management is what numbers of swap ents are user for processes. And this information will give some hints to oom-killer. Besides we can count the number of swapents per a process by scanning /proc/<pid>/smaps, this is very slow and not good for usual process information handler which works like 'ps' or 'top'. (ps or top is now enough slow..) This patch adds a counter of swapents to mm_counter and update is at each swap events. Information is exported via /proc/<pid>/status file as [kamezawa@bluextal memory]$ cat /proc/self/status Name: cat State: R (running) Tgid: 2910 Pid: 2910 PPid: 2823 TracerPid: 0 Uid: 500 500 500 500 Gid: 500 500 500 500 FDSize: 256 Groups: 500 VmPeak: 82696 kB VmSize: 82696 kB VmLck: 0 kB VmHWM: 432 kB VmRSS: 432 kB VmData: 172 kB VmStk: 84 kB VmExe: 48 kB VmLib: 1568 kB VmPTE: 40 kB VmSwap: 0 kB <=============== this. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: avoid false sharing of mm_counterKAMEZAWA Hiroyuki
Considering the nature of per mm stats, it's the shared object among threads and can be a cache-miss point in the page fault path. This patch adds per-thread cache for mm_counter. RSS value will be counted into a struct in task_struct and synchronized with mm's one at events. Now, in this patch, the event is the number of calls to handle_mm_fault. Per-thread value is added to mm at each 64 calls. rough estimation with small benchmark on parallel thread (2threads) shows [before] 4.5 cache-miss/faults [after] 4.0 cache-miss/faults Anyway, the most contended object is mmap_sem if the number of threads grows. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: clean up mm_counterKAMEZAWA Hiroyuki
Presently, per-mm statistics counter is defined by macro in sched.h This patch modifies it to - defined in mm.h as inlinf functions - use array instead of macro's name creation. This patch is for reducing patch size in future patch to modify implementation of per-mm counter. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-05Merge branch 'slab-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'slab-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: SLUB: Fix per-cpu merge conflict failslab: add ability to filter slab caches slab: fix regression in touched logic dma kmalloc handling fixes slub: remove impossible condition slab: initialize unused alien cache entry as NULL at alloc_alien_cache(). SLUB: Make slub statistics use this_cpu_inc SLUB: this_cpu: Remove slub kmem_cache fields SLUB: Get rid of dynamic DMA kmalloc cache allocation SLUB: Use this_cpu operations in slub
2010-03-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits) init: Open /dev/console from rootfs mqueue: fix typo "failues" -> "failures" mqueue: only set error codes if they are really necessary mqueue: simplify do_open() error handling mqueue: apply mathematics distributivity on mq_bytes calculation mqueue: remove unneeded info->messages initialization mqueue: fix mq_open() file descriptor leak on user-space processes fix race in d_splice_alias() set S_DEAD on unlink() and non-directory rename() victims vfs: add NOFOLLOW flag to umount(2) get rid of ->mnt_parent in tomoyo/realpath hppfs can use existing proc_mnt, no need for do_kern_mount() in there Mirror MS_KERNMOUNT in ->mnt_flags get rid of useless vfsmount_lock use in put_mnt_ns() Take vfsmount_lock to fs/internal.h get rid of insanity with namespace roots in tomoyo take check for new events in namespace (guts of mounts_poll()) to namespace.c Don't mess with generic_permission() under ->d_lock in hpfs sanitize const/signedness for udf nilfs: sanitize const/signedness in dealing with ->d_name.name ... Fix up fairly trivial (famous last words...) conflicts in drivers/infiniband/core/uverbs_main.c and security/tomoyo/realpath.c
2010-03-04SLUB: Fix per-cpu merge conflictStephen Rothwell
The slab tree adds a percpu variable usage case (commit 9dfc6e68bfe6ee452efb1a4e9ca26a9007f2b864 "SLUB: Use this_cpu operations in slub"), but the percpu tree removes the prefixing of percpu variables (commit dd17c8f72993f9461e9c19250e3f155d6d99df22 "percpu: remove per_cpu__ prefix"), thus causing the following compilation error: CC mm/slub.o mm/slub.c: In function ‘alloc_kmem_cache_cpus’: mm/slub.c:2078: error: implicit declaration of function ‘per_cpu_var’ mm/slub.c:2078: warning: assignment makes pointer from integer without a cast make[1]: *** [mm/slub.o] Error 1 Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2010-03-04Merge branches 'slab/cleanups', 'slab/failslab', 'slab/fixes' and ↵Pekka Enberg
'slub/percpu' into slab-for-linus
2010-03-03kill unused invalidate_inode_pages helperChristoph Hellwig
No one is calling this anymore as everyone has switched to invalidate_mapping_pages long time ago. Also update a few references to it in comments. nfs has two more, but I can't easily figure what they are actually referring to, so I left them as-is. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-03Merge branch 'x86-bootmem-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-bootmem-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits) early_res: Need to save the allocation name in drop_range_partial() sparsemem: Fix compilation on PowerPC early_res: Add free_early_partial() x86: Fix non-bootmem compilation on PowerPC core: Move early_res from arch/x86 to kernel/ x86: Add find_fw_memmap_area Move round_up/down to kernel.h x86: Make 32bit support NO_BOOTMEM early_res: Enhance check_and_double_early_res x86: Move back find_e820_area to e820.c x86: Add find_early_area_size x86: Separate early_res related code from e820.c x86: Move bios page reserve early to head32/64.c sparsemem: Put mem map for one node together. sparsemem: Put usemap for one node together x86: Make 64 bit use early_res instead of bootmem before slab x86: Only call dma32_reserve_bootmem 64bit !CONFIG_NUMA x86: Make early_node_mem get mem > 4 GB if possible x86: Dynamically increase early_res array size x86: Introduce max_early_res and early_res_count ...
2010-03-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: add __percpu sparse annotations to what's left percpu: add __percpu sparse annotations to fs percpu: add __percpu sparse annotations to core kernel subsystems local_t: Remove leftover local.h this_cpu: Remove pageset_notifier this_cpu: Page allocator conversion percpu, x86: Generic inc / dec percpu instructions local_t: Move local.h include to ringbuffer.c and ring_buffer_benchmark.c module: Use this_cpu_xx to dynamically allocate counters local_t: Remove cpu_local_xx macros percpu: refactor the code in pcpu_[de]populate_chunk() percpu: remove compile warnings caused by __verify_pcpu_ptr() percpu: make accessors check for percpu pointer in sparse percpu: add __percpu for sparse. percpu: make access macros universal percpu: remove per_cpu__ prefix.
2010-03-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1341 commits) virtio_net: remove forgotten assignment be2net: fix tx completion polling sis190: fix cable detect via link status poll net: fix protocol sk_buff field bridge: Fix build error when IGMP_SNOOPING is not enabled bnx2x: Tx barriers and locks scm: Only support SCM_RIGHTS on unix domain sockets. vhost-net: restart tx poll on sk_sndbuf full vhost: fix get_user_pages_fast error handling vhost: initialize log eventfd context pointer vhost: logging thinko fix wireless: convert to use netdev_for_each_mc_addr ethtool: do not set some flags, if others failed ipoib: returned back addrlen check for mc addresses netlink: Adding inode field to /proc/net/netlink axnet_cs: add new id bridge: Make IGMP snooping depend upon BRIDGE. bridge: Add multicast count/interval sysfs entries bridge: Add hash elasticity/max sysfs entries bridge: Add multicast_snooping sysfs toggle ... Trivial conflicts in Documentation/feature-removal-schedule.txt
2010-03-01sparsemem: Fix compilation on PowerPCYinghai Lu
Stephen reported: build (powerpc ppc64_defconfig) produced these warnings: mm/sparse.c: In function 'sparse_init': mm/sparse.c:488: warning: unused variable 'map_count' mm/sparse.c:484: warning: unused variable 'size2' mm/sparse.c:481: warning: unused variable 'map_map' mm/sparse.c: At top level: mm/sparse.c:442: warning: 'sparse_early_mem_maps_alloc_node' defined but not used Introduced by commit 9bdac914240759457175ac0d6529a37d2820bc4d ("sparsemem: Put mem map for one node together"). Conditionalize the bits appropriately based on the setting of CONFIG_SPARSEMEM_ALLOC_MEM_MAP_TOGETHER. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Tested-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <4B895682.1080706@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-03-01Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits) ARM: Eliminate decompressor -Dstatic= PIC hack ARM: 5958/1: ARM: U300: fix inverted clk round rate ARM: 5956/1: misplaced parentheses ARM: 5955/1: ep93xx: move timer defines into core.c and document ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c ARM: 5953/1: ep93xx: fix broken build of clock.c ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig ARM: 5949/1: NUC900 add gpio virtual memory map ARM: 5948/1: Enable timer0 to time4 clock support for nuc910 ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk ARM: make_coherent(): fix problems with highpte, part 2 MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself ARM: 5945/1: ep93xx: include correct irq.h in core.c ARM: 5933/1: amba-pl011: support hardware flow control ARM: 5930/1: Add PKMAP area description to memory.txt. ARM: 5929/1: Add checks to detect overlap of memory regions. ARM: 5928/1: Change type of VMALLOC_END to unsigned long. ARM: 5927/1: Make delimiters of DMA area globally visibly. ARM: 5926/1: Add "Virtual kernel memory..." printout. ARM: 5920/1: OMAP4: Enable L2 Cache ... Fix up trivial conflict in arch/arm/mach-mx25/clock.c
2010-02-28Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/firmware/iscsi_ibft.c
2010-02-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (187 commits) sh: remove dead LED code for migo-r and ms7724se sh: ecovec build fix for CONFIG_I2C=n sh: ecovec r-standby support sh: ms7724se r-standby support sh: SH-Mobile R-standby register save/restore clocksource: Fix up a registration/IRQ race in the sh drivers. sh: ms7724: modify scan_timing for KEYSC sh: ms7724: Add sh_sir support sh: mach-ecovec24: Add sh_sir support sh: wire up SET/GET_UNALIGN_CTL. sh: allow alignment fault mode to be configured at kernel boot. sh: sh7724: Update FSI/SPU2 clock sh: always enable sh7724 vpu_clk and set to 166MHz on Ecovec sh: add sh7724 kick callback to clk_div4_table sh: introduce struct clk_div4_table sh: clock-cpg div4 set_rate() shift fix sh: Turn on speculative return for SH7785 and SH7786 sh: Merge legacy and dynamic PMB modes. sh: Use uncached I/O helpers in PMB setup. sh: Provide uncached I/O helpers. ...
2010-02-26failslab: add ability to filter slab cachesDmitry Monakhov
This patch allow to inject faults only for specific slabs. In order to preserve default behavior cache filter is off by default (all caches are faulty). One may define specific set of slabs like this: # mark skbuff_head_cache as faulty echo 1 > /sys/kernel/slab/skbuff_head_cache/failslab # Turn on cache filter (off by default) echo 1 > /sys/kernel/debug/failslab/cache-filter # Turn on fault injection echo 1 > /sys/kernel/debug/failslab/times echo 1 > /sys/kernel/debug/failslab/probability Acked-by: David Rientjes <rientjes@google.com> Acked-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2010-02-26early_res: Add free_early_partial()Yinghai Lu
To free partial areas in pcpu_setup... Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Tejun Heo <tj@kernel.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> LKML-Reference: <4B85E245.5030001@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25Merge branches 'clks' and 'pnx' into develRussell King
2010-02-22memcg: fix oom killing a child process in an other cgroupKAMEZAWA Hiroyuki
Presently the oom-killer is memcg aware and it finds the worst process from processes under memcg(s) in oom. Then, it kills victim's child first. It may kill a child in another cgroup and may not be any help for recovery. And it will break the assumption users have. This patch fixes it. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: David Rientjes <rientjes@google.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-22x86: Fix non-bootmem compilation on PowerPCYinghai Lu
These build errors on some non-x86 platforms (PowerPC for example): mm/page_alloc.c: In function '__alloc_memory_core_early': mm/page_alloc.c:3468: error: implicit declaration of function 'find_early_area' mm/page_alloc.c:3483: error: implicit declaration of function 'reserve_early_without_check' The function is only needed on CONFIG_NO_BOOTMEM. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Johannes Weiner <hannes@saeurebad.de> Cc: Mel Gorman <mel@csn.ul.ie> LKML-Reference: <4B747239.4070907@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-21mm: Make copy_from_user() in migrate.c statically predictableH. Peter Anvin
x86-32 has had a static test for copy_on_user() overflow for a while. This test currently fails in mm/migrate.c resulting in an allyesconfig/allmodconfig build failure on x86-32: In function ‘copy_from_user’, inlined from ‘do_pages_stat’ at /home/hpa/kernel/git/mm/migrate.c:1012: /home/hpa/kernel/git/arch/x86/include/asm/uaccess_32.h:212: error: call to ‘copy_from_user_overflow’ declared Make the logic more explicit and therefore easier for gcc to understand. v2: rewrite the loop entirely using a more normal structure for a chunked-data loop (Linus Torvalds) Reported-by: Len Brown <lenb@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Reviewed-and-Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Arjan van de Ven <arjan@linux.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-20MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itselfRussell King
On VIVT ARM, when we have multiple shared mappings of the same file in the same MM, we need to ensure that we have coherency across all copies. We do this via make_coherent() by making the pages uncacheable. This used to work fine, until we allowed highmem with highpte - we now have a page table which is mapped as required, and is not available for modification via update_mmu_cache(). Ralf Beache suggested getting rid of the PTE value passed to update_mmu_cache(): On MIPS update_mmu_cache() calls __update_tlb() which walks pagetables to construct a pointer to the pte again. Passing a pte_t * is much more elegant. Maybe we might even replace the pte argument with the pte_t? Ben Herrenschmidt would also like the pte pointer for PowerPC: Passing the ptep in there is exactly what I want. I want that -instead- of the PTE value, because I have issue on some ppc cases, for I$/D$ coherency, where set_pte_at() may decide to mask out the _PAGE_EXEC. So, pass in the mapped page table pointer into update_mmu_cache(), and remove the PTE value, updating all implementations and call sites to suit. Includes a fix from Stephen Rothwell: sparc: fix fallout from update_mmu_cache API change Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-16Merge branch 'master' of ↵David S. Miller
2010-02-17percpu: add __percpu sparse annotations to core kernel subsystemsTejun Heo
Add __percpu sparse annotations to core subsystems. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: linux-mm@kvack.org Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Eric Biederman <ebiederm@xmission.com>
2010-02-12sparsemem: Put mem map for one node together.Yinghai Lu
Add vmemmap_alloc_block_buf for mem map only. It will fallback to the old way if it cannot get a block that big. Before this patch, when a node have 128g ram installed, memmap are split into two parts or more. [ 0.000000] [ffffea0000000000-ffffea003fffffff] PMD -> [ffff880100600000-ffff88013e9fffff] on node 1 [ 0.000000] [ffffea0040000000-ffffea006fffffff] PMD -> [ffff88013ec00000-ffff88016ebfffff] on node 1 [ 0.000000] [ffffea0070000000-ffffea007fffffff] PMD -> [ffff882000600000-ffff8820105fffff] on node 0 [ 0.000000] [ffffea0080000000-ffffea00bfffffff] PMD -> [ffff882010800000-ffff8820507fffff] on node 0 [ 0.000000] [ffffea00c0000000-ffffea00dfffffff] PMD -> [ffff882050a00000-ffff8820709fffff] on node 0 [ 0.000000] [ffffea00e0000000-ffffea00ffffffff] PMD -> [ffff884000600000-ffff8840205fffff] on node 2 [ 0.000000] [ffffea0100000000-ffffea013fffffff] PMD -> [ffff884020800000-ffff8840607fffff] on node 2 [ 0.000000] [ffffea0140000000-ffffea014fffffff] PMD -> [ffff884060a00000-ffff8840709fffff] on node 2 [ 0.000000] [ffffea0150000000-ffffea017fffffff] PMD -> [ffff886000600000-ffff8860305fffff] on node 3 [ 0.000000] [ffffea0180000000-ffffea01bfffffff] PMD -> [ffff886030800000-ffff8860707fffff] on node 3 [ 0.000000] [ffffea01c0000000-ffffea01ffffffff] PMD -> [ffff888000600000-ffff8880405fffff] on node 4 [ 0.000000] [ffffea0200000000-ffffea022fffffff] PMD -> [ffff888040800000-ffff8880707fffff] on node 4 [ 0.000000] [ffffea0230000000-ffffea023fffffff] PMD -> [ffff88a000600000-ffff88a0105fffff] on node 5 [ 0.000000] [ffffea0240000000-ffffea027fffffff] PMD -> [ffff88a010800000-ffff88a0507fffff] on node 5 [ 0.000000] [ffffea0280000000-ffffea029fffffff] PMD -> [ffff88a050a00000-ffff88a0709fffff] on node 5 [ 0.000000] [ffffea02a0000000-ffffea02bfffffff] PMD -> [ffff88c000600000-ffff88c0205fffff] on node 6 [ 0.000000] [ffffea02c0000000-ffffea02ffffffff] PMD -> [ffff88c020800000-ffff88c0607fffff] on node 6 [ 0.000000] [ffffea0300000000-ffffea030fffffff] PMD -> [ffff88c060a00000-ffff88c0709fffff] on node 6 [ 0.000000] [ffffea0310000000-ffffea033fffffff] PMD -> [ffff88e000600000-ffff88e0305fffff] on node 7 [ 0.000000] [ffffea0340000000-ffffea037fffffff] PMD -> [ffff88e030800000-ffff88e0707fffff] on node 7 after patch will get [ 0.000000] [ffffea0000000000-ffffea006fffffff] PMD -> [ffff880100200000-ffff88016e5fffff] on node 0 [ 0.000000] [ffffea0070000000-ffffea00dfffffff] PMD -> [ffff882000200000-ffff8820701fffff] on node 1 [ 0.000000] [ffffea00e0000000-ffffea014fffffff] PMD -> [ffff884000200000-ffff8840701fffff] on node 2 [ 0.000000] [ffffea0150000000-ffffea01bfffffff] PMD -> [ffff886000200000-ffff8860701fffff] on node 3 [ 0.000000] [ffffea01c0000000-ffffea022fffffff] PMD -> [ffff888000200000-ffff8880701fffff] on node 4 [ 0.000000] [ffffea0230000000-ffffea029fffffff] PMD -> [ffff88a000200000-ffff88a0701fffff] on node 5 [ 0.000000] [ffffea02a0000000-ffffea030fffffff] PMD -> [ffff88c000200000-ffff88c0701fffff] on node 6 [ 0.000000] [ffffea0310000000-ffffea037fffffff] PMD -> [ffff88e000200000-ffff88e0701fffff] on node 7 -v2: change buf to vmemmap_buf instead according to Ingo also add CONFIG_SPARSEMEM_ALLOC_MEM_MAP_TOGETHER according to Ingo -v3: according to Andrew, use sizeof(name) instead of hard coded 15 Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <1265793639-15071-19-git-send-email-yinghai@kernel.org> Cc: Christoph Lameter <cl@linux-foundation.org> Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-02-12sparsemem: Put usemap for one node togetherYinghai Lu
Could save some buffer space instead of applying one by one. Could help that system that is going to use early_res instead of bootmem less entries in early_res make search more faster on system with more memory. Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <1265793639-15071-18-git-send-email-yinghai@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-02-12x86: Make 64 bit use early_res instead of bootmem before slabYinghai Lu
Finally we can use early_res to replace bootmem for x86_64 now. Still can use CONFIG_NO_BOOTMEM to enable it or not. -v2: fix 32bit compiling about MAX_DMA32_PFN -v3: folded bug fix from LKML message below Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <4B747239.4070907@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-02-08Merge branch 'sh/dmaengine'Paul Mundt
Conflicts: arch/sh/drivers/dma/dma-sh.c
2010-02-06Fix potential crash with sys_move_pagesLinus Torvalds
We incorrectly depended on the 'node_state/node_isset()' functions testing the node range, rather than checking it explicitly. That's not reliable, even if it might often happen to work. So do the proper explicit test. Reported-by: Marcus Meissner <meissner@suse.de> Acked-and-tested-by: Brice Goglin <Brice.Goglin@inria.fr> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-05Merge branch 'sh/stable-updates'Paul Mundt
2010-02-02hugetlb: fix section mismatchesJeff Mahoney
hugetlb_sysfs_add_hstate is called by hugetlb_register_node directly during init and also indirectly via sysfs after init. This patch removes the __init tag from hugetlb_sysfs_add_hstate. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-02mm: flush dcache before writing into page to avoid aliasanfei zhou
The cache alias problem will happen if the changes of user shared mapping is not flushed before copying, then user and kernel mapping may be mapped into two different cache line, it is impossible to guarantee the coherence after iov_iter_copy_from_user_atomic. So the right steps should be: flush_dcache_page(page); kmap_atomic(page); write to page; kunmap_atomic(page); flush_dcache_page(page); More precisely, we might create two new APIs flush_dcache_user_page and flush_dcache_kern_page to replace the two flush_dcache_page accordingly. Here is a snippet tested on omap2430 with VIPT cache, and I think it is not ARM-specific: int val = 0x11111111; fd = open("abc", O_RDWR); addr = mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0); *(addr+0) = 0x44444444; tmp = *(addr+0); *(addr+1) = 0x77777777; write(fd, &val, sizeof(int)); close(fd); The results are not always 0x11111111 0x77777777 at the beginning as expected. Sometimes we see 0x44444444 0x77777777. Signed-off-by: Anfei <anfei.zhou@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: <linux-arch@vger.kernel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-02mm: purge fragmented percpu vmap blocksNick Piggin
Improve handling of fragmented per-CPU vmaps. We previously don't free up per-CPU maps until all its addresses have been used and freed. So fragmented blocks could fill up vmalloc space even if they actually had no active vmap regions within them. Add some logic to allow all CPUs to have these blocks purged in the case of failure to allocate a new vm area, and also put some logic to trim such blocks of a current CPU if we hit them in the allocation path (so as to avoid a large build up of them). Christoph reported some vmap allocation failures when using the per CPU vmap APIs in XFS, which cannot be reproduced after this patch and the previous bug fix. Cc: linux-mm@kvack.org Cc: stable@kernel.org Tested-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Nick Piggin <npiggin@suse.de> -- Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
