path: root/mm/migrate.c
2015-11-05mm, migrate: count pages failing all retries in vmstat and tracepointVlastimil Babka
Migration tries up to 10 times to migrate pages that return -EAGAIN until it gives up. If some pages fail all retries, they are counted towards the number of failed pages that migrate_pages() returns. They should also be counted in the /proc/vmstat pgmigrate_fail and in the mm_migrate_pages tracepoint. Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: David Rientjes <rientjes@google.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-01memcg: fix dirty page migrationGreg Thelen
The problem starts with a file backed dirty page which is charged to a memcg. Then page migration is used to move oldpage to newpage. Migration: - copies the oldpage's data to newpage - clears oldpage.PG_dirty - sets newpage.PG_dirty - uncharges oldpage from memcg - charges newpage to memcg Clearing oldpage.PG_dirty decrements the charged memcg's dirty page count. However, because newpage is not yet charged, setting newpage.PG_dirty does not increment the memcg's dirty page count. After migration completes newpage.PG_dirty is eventually cleared, often in account_page_cleaned(). At this time newpage is charged to a memcg so the memcg's dirty page count is decremented which causes underflow because the count was not previously incremented by migration. This underflow causes balance_dirty_pages() to see a very large unsigned number of dirty memcg pages which leads to aggressive throttling of buffered writes by processes in non root memcg. This issue: - can harm performance of non root memcg buffered writes. - can report too small (even negative) values in memory.stat[(total_)dirty] counters of all memcg, including the root. To avoid polluting migrate.c with #ifdef CONFIG_MEMCG checks, introduce page_memcg() and set_page_memcg() helpers. Test: 0) setup and enter limited memcg mkdir /sys/fs/cgroup/test echo 1G > /sys/fs/cgroup/test/memory.limit_in_bytes echo $$ > /sys/fs/cgroup/test/cgroup.procs 1) buffered writes baseline dd if=/dev/zero of=/data/tmp/foo bs=1M count=1k sync grep ^dirty /sys/fs/cgroup/test/memory.stat 2) buffered writes with compaction antagonist to induce migration yes 1 > /proc/sys/vm/compact_memory & rm -rf /data/tmp/foo dd if=/dev/zero of=/data/tmp/foo bs=1M count=1k kill % sync grep ^dirty /sys/fs/cgroup/test/memory.stat 3) buffered writes without antagonist, should match baseline rm -rf /data/tmp/foo dd if=/dev/zero of=/data/tmp/foo bs=1M count=1k sync grep ^dirty /sys/fs/cgroup/test/memory.stat (speed, dirty residue) unpatched patched 1) 841 MB/s 0 dirty pages 886 MB/s 0 dirty pages 2) 611 MB/s -33427456 dirty pages 793 MB/s 0 dirty pages 3) 114 MB/s -33427456 dirty pages 891 MB/s 0 dirty pages Notice that unpatched baseline performance (1) fell after migration (3): 841 -> 114 MB/s. In the patched kernel, post migration performance matches baseline. Fixes: c4843a7593a9 ("memcg: add per cgroup dirty page accounting") Signed-off-by: Greg Thelen <gthelen@google.com> Reported-by: Dave Hansen <dave.hansen@intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: <stable@vger.kernel.org> [4.2+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-22mm: migrate: hugetlb: putback destination hugepage to active listNaoya Horiguchi
Since commit bcc54222309c ("mm: hugetlb: introduce page_huge_active") each hugetlb page maintains its active flag to avoid a race condition betwe= en multiple calls of isolate_huge_page(), but current kernel doesn't set the f= lag on a hugepage allocated by migration because the proper putback routine isn= 't called. This means that users could still encounter the race referred to by bcc54222309c in this special case, so this patch fixes it. Fixes: bcc54222309c ("mm: hugetlb: introduce page_huge_active") Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Andi Kleen <andi@firstfloor.org> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> [4.1.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10mm: introduce idle page trackingVladimir Davydov
Knowing the portion of memory that is not used by a certain application or memory cgroup (idle memory) can be useful for partitioning the system efficiently, e.g. by setting memory cgroup limits appropriately. Currently, the only means to estimate the amount of idle memory provided by the kernel is /proc/PID/{clear_refs,smaps}: the user can clear the access bit for all pages mapped to a particular process by writing 1 to clear_refs, wait for some time, and then count smaps:Referenced. However, this method has two serious shortcomings: - it does not count unmapped file pages - it affects the reclaimer logic To overcome these drawbacks, this patch introduces two new page flags, Idle and Young, and a new sysfs file, /sys/kernel/mm/page_idle/bitmap. A page's Idle flag can only be set from userspace by setting bit in /sys/kernel/mm/page_idle/bitmap at the offset corresponding to the page, and it is cleared whenever the page is accessed either through page tables (it is cleared in page_referenced() in this case) or using the read(2) system call (mark_page_accessed()). Thus by setting the Idle flag for pages of a particular workload, which can be found e.g. by reading /proc/PID/pagemap, waiting for some time to let the workload access its working set, and then reading the bitmap file, one can estimate the amount of pages that are not used by the workload. The Young page flag is used to avoid interference with the memory reclaimer. A page's Young flag is set whenever the Access bit of a page table entry pointing to the page is cleared by writing to the bitmap file. If page_referenced() is called on a Young page, it will add 1 to its return value, therefore concealing the fact that the Access bit was cleared. Note, since there is no room for extra page flags on 32 bit, this feature uses extended page flags when compiled on 32 bit. [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: kpageidle requires an MMU] [akpm@linux-foundation.org: decouple from page-flags rework] Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Reviewed-by: Andres Lagar-Cavilla <andreslc@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Greg Thelen <gthelen@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08mm: rename alloc_pages_exact_node() to __alloc_pages_node()Vlastimil Babka
alloc_pages_exact_node() was introduced in commit 6484eb3e2a81 ("page allocator: do not check NUMA node ID when the caller knows the node is valid") as an optimized variant of alloc_pages_node(), that doesn't fallback to current node for nid == NUMA_NO_NODE. Unfortunately the name of the function can easily suggest that the allocation is restricted to the given node and fails otherwise. In truth, the node is only preferred, unless __GFP_THISNODE is passed among the gfp flags. The misleading name has lead to mistakes in the past, see for example commits 5265047ac301 ("mm, thp: really limit transparent hugepage allocation to local node") and b360edb43f8e ("mm, mempolicy: migrate_to_node should only migrate to node"). Another issue with the name is that there's a family of alloc_pages_exact*() functions where 'exact' means exact size (instead of page order), which leads to more confusion. To prevent further mistakes, this patch effectively renames alloc_pages_exact_node() to __alloc_pages_node() to better convey that it's an optimized variant of alloc_pages_node() not intended for general usage. Both functions get described in comments. It has been also considered to really provide a convenience function for allocations restricted to a node, but the major opinion seems to be that __GFP_THISNODE already provides that functionality and we shouldn't duplicate the API needlessly. The number of users would be small anyway. Existing callers of alloc_pages_exact_node() are simply converted to call __alloc_pages_node(), with the exception of sba_alloc_coherent() which open-codes the check for NUMA_NO_NODE, so it is converted to use alloc_pages_node() instead. This means it no longer performs some VM_BUG_ON checks, and since the current check for nid in alloc_pages_node() uses a 'nid < 0' comparison (which includes NUMA_NO_NODE), it may hide wrong values which would be previously exposed. Both differences will be rectified by the next patch. To sum up, this patch makes no functional changes, except temporarily hiding potentially buggy callers. Restricting the checks in alloc_pages_node() is left for the next patch which can in turn expose more existing buggy callers. Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Robin Holt <robinmholt@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Christoph Lameter <cl@linux.com> Acked-by: Michael Ellerman <mpe@ellerman.id.au> Cc: Mel Gorman <mgorman@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Greg Thelen <gthelen@google.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Cliff Whickman <cpw@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08mm/hwpoison: fix race between soft_offline_page and unpoison_memoryWanpeng Li
Wanpeng Li reported a race between soft_offline_page() and unpoison_memory(), which causes the following kernel panic: BUG: Bad page state in process bash pfn:97000 page:ffffea00025c0000 count:0 mapcount:1 mapping: (null) index:0x7f4fdbe00 flags: 0x1fffff80080048(uptodate|active|swapbacked) page dumped because: PAGE_FLAGS_CHECK_AT_FREE flag(s) set bad because of flags: flags: 0x40(active) Modules linked in: snd_hda_codec_hdmi i915 rpcsec_gss_krb5 nfsv4 dns_resolver bnep rfcomm nfsd bluetooth auth_rpcgss nfs_acl nfs rfkill lockd grace sunrpc i2c_algo_bit drm_kms_helper snd_hda_codec_realtek snd_hda_codec_generic drm snd_hda_intel fscache snd_hda_codec x86_pkg_temp_thermal coretemp kvm_intel snd_hda_core snd_hwdep kvm snd_pcm snd_seq_dummy snd_seq_oss crct10dif_pclmul snd_seq_midi crc32_pclmul snd_seq_midi_event ghash_clmulni_intel snd_rawmidi aesni_intel lrw gf128mul snd_seq glue_helper ablk_helper snd_seq_device cryptd fuse snd_timer dcdbas serio_raw mei_me parport_pc snd mei ppdev i2c_core video lp soundcore parport lpc_ich shpchp mfd_core ext4 mbcache jbd2 sd_mod e1000e ahci ptp libahci crc32c_intel libata pps_core CPU: 3 PID: 2211 Comm: bash Not tainted 4.2.0-rc5-mm1+ #45 Hardware name: Dell Inc. OptiPlex 7020/0F5C5X, BIOS A03 01/08/2015 Call Trace: dump_stack+0x48/0x5c bad_page+0xe6/0x140 free_pages_prepare+0x2f9/0x320 ? uncharge_list+0xdd/0x100 free_hot_cold_page+0x40/0x170 __put_single_page+0x20/0x30 put_page+0x25/0x40 unmap_and_move+0x1a6/0x1f0 migrate_pages+0x100/0x1d0 ? kill_procs+0x100/0x100 ? unlock_page+0x6f/0x90 __soft_offline_page+0x127/0x2a0 soft_offline_page+0xa6/0x200 This race is explained like below: CPU0 CPU1 soft_offline_page __soft_offline_page TestSetPageHWPoison unpoison_memory PageHWPoison check (true) TestClearPageHWPoison put_page -> release refcount held by get_hwpoison_page in unpoison_memory put_page -> release refcount held by isolate_lru_page in __soft_offline_page migrate_pages The second put_page() releases refcount held by isolate_lru_page() which will lead to unmap_and_move() releases the last refcount of page and w/ mapcount still 1 since try_to_unmap() is not called if there is only one user map the page. Anyway, the page refcount and mapcount will still mess if the page is mapped by multiple users. This race was introduced by commit 4491f71260 ("mm/memory-failure: set PageHWPoison before migrate_pages()"), which focuses on preventing the reuse of successfully migrated page. Before this commit we prevent the reuse by changing the migratetype to MIGRATE_ISOLATE during soft offlining, which has the following problems, so simply reverting the commit is not a best option: 1) it doesn't eliminate the reuse completely, because set_migratetype_isolate() can fail to set MIGRATE_ISOLATE to the target page if the pageblock of the page contains one or more unmovable pages (i.e. has_unmovable_pages() returns true). 2) the original code changes migratetype to MIGRATE_ISOLATE forcibly, and sets it to MIGRATE_MOVABLE forcibly after soft offline, regardless of the original migratetype state, which could impact other subsystems like memory hotplug or compaction. This patch moves PageSetHWPoison just after put_page() in unmap_and_move(), which closes up the reported race window and minimizes another race window b/w SetPageHWPoison and reallocation (which causes the reuse of soft-offlined page.) The latter race window still exists but it's acceptable, because it's rare and effectively the same as ordinary "containment failure" case even if it happens, so keep the window open is acceptable. Fixes: 4491f71260 ("mm/memory-failure: set PageHWPoison before migrate_pages()") Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reported-by: Wanpeng Li <wanpeng.li@hotmail.com> Tested-by: Wanpeng Li <wanpeng.li@hotmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04mm: fix status code which move_pages() returns for zero pageKirill A. Shutemov
The manpage for move_pages(2) specifies that status code for zero page is supposed to be -EFAULT. Currently kernel return -ENOENT in this case. follow_page() can do it for us, if we would ask for FOLL_DUMP. The use of FOLL_DUMP also means that the upper layer page tables pages are no longer allocated. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Christoph Lameter <cl@linux.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-07mm/memory-failure: set PageHWPoison before migrate_pages()Naoya Horiguchi
Now page freeing code doesn't consider PageHWPoison as a bad page, so by setting it before completing the page containment, we can prevent the error page from being reused just after successful page migration. I added TTU_IGNORE_HWPOISON for try_to_unmap() to make sure that the page table entry is transformed into migration entry, not to hwpoison entry. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Dean Nelson <dnelson@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-07mm: check __PG_HWPOISON separately from PAGE_FLAGS_CHECK_AT_*Naoya Horiguchi
The race condition addressed in commit add05cecef80 ("mm: soft-offline: don't free target page in successful page migration") was not closed completely, because that can happen not only for soft-offline, but also for hard-offline. Consider that a slab page is about to be freed into buddy pool, and then an uncorrected memory error hits the page just after entering __free_one_page(), then VM_BUG_ON_PAGE(page->flags & PAGE_FLAGS_CHECK_AT_PREP) is triggered, despite the fact that it's not necessary because the data on the affected page is not consumed. To solve it, this patch drops __PG_HWPOISON from page flag checks at allocation/free time. I think it's justified because __PG_HWPOISON flags is defined to prevent the page from being reused, and setting it outside the page's alloc-free cycle is a designed behavior (not a bug.) For recent months, I was annoyed about BUG_ON when soft-offlined page remains on lru cache list for a while, which is avoided by calling put_page() instead of putback_lru_page() in page migration's success path. This means that this patch reverts a major change from commit add05cecef80 about the new refcounting rule of soft-offlined pages, so "reuse window" revives. This will be closed by a subsequent patch. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Dean Nelson <dnelson@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm: clarify that the function operates on hugepage pteAneesh Kumar K.V
We have confusing functions to clear pmd, pmd_clear_* and pmd_clear. Add _huge_ to pmdp_clear functions so that we are clear that they operate on hugepage pte. We don't bother about other functions like pmdp_set_wrprotect, pmdp_clear_flush_young, because they operate on PTE bits and hence indicate they are operating on hugepage ptes Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm: soft-offline: don't free target page in successful page migrationNaoya Horiguchi
Stress testing showed that soft offline events for a process iterating "mmap-pagefault-munmap" loop can trigger VM_BUG_ON(PAGE_FLAGS_CHECK_AT_PREP) in __free_one_page(): Soft offlining page 0x70fe1 at 0x70100008d000 Soft offlining page 0x705fb at 0x70300008d000 page:ffffea0001c3f840 count:0 mapcount:0 mapping: (null) index:0x2 flags: 0x1fffff80800000(hwpoison) page dumped because: VM_BUG_ON_PAGE(page->flags & ((1 << 25) - 1)) ------------[ cut here ]------------ kernel BUG at /src/linux-dev/mm/page_alloc.c:585! invalid opcode: 0000 [#1] SMP DEBUG_PAGEALLOC Modules linked in: cfg80211 rfkill crc32c_intel microcode ppdev parport_pc pcspkr serio_raw virtio_balloon parport i2c_piix4 virtio_blk virtio_net ata_generic pata_acpi floppy CPU: 3 PID: 1779 Comm: test_base_madv_ Not tainted 4.0.0-v4.0-150511-1451-00009-g82360a3730e6 #139 RIP: free_pcppages_bulk+0x52a/0x6f0 Call Trace: drain_pages_zone+0x3d/0x50 drain_local_pages+0x1d/0x30 on_each_cpu_mask+0x46/0x80 drain_all_pages+0x14b/0x1e0 soft_offline_page+0x432/0x6e0 SyS_madvise+0x73c/0x780 system_call_fastpath+0x12/0x17 Code: ff 89 45 b4 48 8b 45 c0 48 83 b8 a8 00 00 00 00 0f 85 e3 fb ff ff 0f 1f 00 0f 0b 48 8b 7d 90 48 c7 c6 e8 95 a6 81 e8 e6 32 02 00 <0f> 0b 8b 45 cc 49 89 47 30 41 8b 47 18 83 f8 ff 0f 85 10 ff ff RIP [<ffffffff811a806a>] free_pcppages_bulk+0x52a/0x6f0 RSP <ffff88007a117d28> ---[ end trace 53926436e76d1f35 ]--- When soft offline successfully migrates page, the source page is supposed to be freed. But there is a race condition where a source page looks isolated (i.e. the refcount is 0 and the PageHWPoison is set) but somewhat linked to pcplist. Then another soft offline event calls drain_all_pages() and tries to free such hwpoisoned page, which is forbidden. This odd page state seems to happen due to the race between put_page() in putback_lru_page() and __pagevec_lru_add_fn(). But I don't want to play with tweaking drain code as done in commit 9ab3b598d2df "mm: hwpoison: drop lru_add_drain_all() in __soft_offline_page()", or to change page freeing code for this soft offline's purpose. Instead, let's think about the difference between hard offline and soft offline. There is an interesting difference in how to isolate the in-use page between these, that is, hard offline marks PageHWPoison of the target page at first, and doesn't free it by keeping its refcount 1. OTOH, soft offline tries to free the target page then marks PageHWPoison. This difference might be the source of complexity and result in bugs like the above. So making soft offline isolate with keeping refcount can be a solution for this problem. We can pass to page migration code the "reason" which shows the caller, so let's use this more to avoid calling putback_lru_page() when called from soft offline, which effectively does the isolation for soft offline. With this change, target pages of soft offline never be reused without changing migratetype, so this patch also removes the related code. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Tony Luck <tony.luck@intel.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15mm/migrate: check-before-clear PageSwapCacheNaoya Horiguchi
With the page flag sanitization patchset, an invalid usage of ClearPageSwapCache() is detected in migration_page_copy(). migrate_page_copy() is shared by both normal and hugepage (both thp and hugetlb) code path, so let's check PageSwapCache() and clear it if it's set to avoid misuse of the invalid clear operation. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14mm: numa: remove migrate_ratelimitedMel Gorman
This code is dead since commit 9e645ab6d089 ("sched/numa: Continue PTE scanning even if migrate rate limited") so remove it. Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14mm/migrate: mark unmap_and_move() "noinline" to avoid ICE in gcc 4.7.3Geert Uytterhoeven
With gcc version 4.7.3 (Ubuntu/Linaro 4.7.3-12ubuntu1) : mm/migrate.c: In function `migrate_pages': mm/migrate.c:1148:1: internal compiler error: in push_minipool_fix, at config/arm/arm.c:13500 Please submit a full bug report, with preprocessed source if appropriate. See <file:///usr/share/doc/gcc-4.7/README.Bugs> for instructions. Preprocessed source stored into /tmp/ccPoM1tr.out file, please attach this to your bugreport. make[1]: *** [mm/migrate.o] Error 1 make: *** [mm/migrate.o] Error 2 Mark unmap_and_move() (which is used in a single place only) "noinline" to work around this compiler bug. [akpm@linux-foundation.org: make it conditional on gcc-4.7.3 and arm] [khilman@kernel.org: fine-tune compiler versions] [akpm@linux-foundation.org: fix comment] Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Reported-by: Kevin Hilman <khilman@kernel.org> Cc: Marc Zyngier <marc.zyngier@arm.com> Tested-by: Kevin Hilman <khilman@linaro.org> Tested-by: Lina Iyer <lina.iyer@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12mm: convert p[te|md]_mknonnuma and remaining page table manipulationsMel Gorman
With PROT_NONE, the traditional page table manipulation functions are sufficient. [andre.przywara@arm.com: fix compiler warning in pmdp_invalidate()] [akpm@linux-foundation.org: fix build with STRICT_MM_TYPECHECKS] Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Jones <davej@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12mm: numa: do not dereference pmd outside of the lock during NUMA hinting faultMel Gorman
Automatic NUMA balancing depends on being able to protect PTEs to trap a fault and gather reference locality information. Very broadly speaking it would mark PTEs as not present and use another bit to distinguish between NUMA hinting faults and other types of faults. It was universally loved by everybody and caused no problems whatsoever. That last sentence might be a lie. This series is very heavily based on patches from Linus and Aneesh to replace the existing PTE/PMD NUMA helper functions with normal change protections. I did alter and add parts of it but I consider them relatively minor contributions. At their suggestion, acked-bys are in there but I've no problem converting them to Signed-off-by if requested. AFAIK, this has received no testing on ppc64 and I'm depending on Aneesh for that. I tested trinity under kvm-tool and passed and ran a few other basic tests. At the time of writing, only the short-lived tests have completed but testing of V2 indicated that long-term testing had no surprises. In most cases I'm leaving out detail as it's not that interesting. specjbb single JVM: There was negligible performance difference in the benchmark itself for short runs. However, system activity is higher and interrupts are much higher over time -- possibly TLB flushes. Migrations are also higher. Overall, this is more overhead but considering the problems faced with the old approach I think we just have to suck it up and find another way of reducing the overhead. specjbb multi JVM: Negligible performance difference to the actual benchmark but like the single JVM case, the system overhead is noticeably higher. Again, interrupts are a major factor. autonumabench: This was all over the place and about all that can be reasonably concluded is that it's different but not necessarily better or worse. autonumabench 3.18.0-rc5 3.18.0-rc5 mmotm-20141119 protnone-v3r3 User NUMA01 32380.24 ( 0.00%) 21642.92 ( 33.16%) User NUMA01_THEADLOCAL 22481.02 ( 0.00%) 22283.22 ( 0.88%) User NUMA02 3137.00 ( 0.00%) 3116.54 ( 0.65%) User NUMA02_SMT 1614.03 ( 0.00%) 1543.53 ( 4.37%) System NUMA01 322.97 ( 0.00%) 1465.89 (-353.88%) System NUMA01_THEADLOCAL 91.87 ( 0.00%) 49.32 ( 46.32%) System NUMA02 37.83 ( 0.00%) 14.61 ( 61.38%) System NUMA02_SMT 7.36 ( 0.00%) 7.45 ( -1.22%) Elapsed NUMA01 716.63 ( 0.00%) 599.29 ( 16.37%) Elapsed NUMA01_THEADLOCAL 553.98 ( 0.00%) 539.94 ( 2.53%) Elapsed NUMA02 83.85 ( 0.00%) 83.04 ( 0.97%) Elapsed NUMA02_SMT 86.57 ( 0.00%) 79.15 ( 8.57%) CPU NUMA01 4563.00 ( 0.00%) 3855.00 ( 15.52%) CPU NUMA01_THEADLOCAL 4074.00 ( 0.00%) 4136.00 ( -1.52%) CPU NUMA02 3785.00 ( 0.00%) 3770.00 ( 0.40%) CPU NUMA02_SMT 1872.00 ( 0.00%) 1959.00 ( -4.65%) System CPU usage of NUMA01 is worse but it's an adverse workload on this machine so I'm reluctant to conclude that it's a problem that matters. On the other workloads that are sensible on this machine, system CPU usage is great. Overall time to complete the benchmark is comparable 3.18.0-rc5 3.18.0-rc5 mmotm-20141119protnone-v3r3 User 59612.50 48586.44 System 460.22 1537.45 Elapsed 1442.20 1304.29 NUMA alloc hit 5075182 5743353 NUMA alloc miss 0 0 NUMA interleave hit 0 0 NUMA alloc local 5075174 5743339 NUMA base PTE updates 637061448 443106883 NUMA huge PMD updates 1243434 864747 NUMA page range updates 1273699656 885857347 NUMA hint faults 1658116 1214277 NUMA hint local faults 959487 754113 NUMA hint local percent 57 62 NUMA pages migrated 5467056 61676398 The NUMA pages migrated look terrible but when I looked at a graph of the activity over time I see that the massive spike in migration activity was during NUMA01. This correlates with high system CPU usage and could be simply down to bad luck but any modifications that affect that workload would be related to scan rates and migrations, not the protection mechanism. For all other workloads, migration activity was comparable. Overall, headline performance figures are comparable but the overhead is higher, mostly in interrupts. To some extent, higher overhead from this approach was anticipated but not to this degree. It's going to be necessary to reduce this again with a separate series in the future. It's still worth going ahead with this series though as it's likely to avoid constant headaches with Xen and is probably easier to maintain. This patch (of 10): A transhuge NUMA hinting fault may find the page is migrating and should wait until migration completes. The check is race-prone because the pmd is deferenced outside of the page lock and while the race is tiny, it'll be larger if the PMD is cleared while marking PMDs for hinting fault. This patch closes the race. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Jones <davej@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Kirill Shutemov <kirill.shutemov@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Rik van Riel <riel@redhat.com> Cc: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-11mm/hugetlb: take page table lock in follow_huge_pmd()Naoya Horiguchi
We have a race condition between move_pages() and freeing hugepages, where move_pages() calls follow_page(FOLL_GET) for hugepages internally and tries to get its refcount without preventing concurrent freeing. This race crashes the kernel, so this patch fixes it by moving FOLL_GET code for hugepages into follow_huge_pmd() with taking the page table lock. This patch intentionally removes page==NULL check after pte_page. This is justified because pte_page() never returns NULL for any architectures or configurations. This patch changes the behavior of follow_huge_pmd() for tail pages and then tail pages can be pinned/returned. So the caller must be changed to properly handle the returned tail pages. We could have a choice to add the similar locking to follow_huge_(addr|pud) for consistency, but it's not necessary because currently these functions don't support FOLL_GET flag, so let's leave it for future development. Here is the reproducer: $ cat movepages.c #include <stdio.h> #include <stdlib.h> #include <numaif.h> #define ADDR_INPUT 0x700000000000UL #define HPS 0x200000 #define PS 0x1000 int main(int argc, char *argv[]) { int i; int nr_hp = strtol(argv[1], NULL, 0); int nr_p = nr_hp * HPS / PS; int ret; void **addrs; int *status; int *nodes; pid_t pid; pid = strtol(argv[2], NULL, 0); addrs = malloc(sizeof(char *) * nr_p + 1); status = malloc(sizeof(char *) * nr_p + 1); nodes = malloc(sizeof(char *) * nr_p + 1); while (1) { for (i = 0; i < nr_p; i++) { addrs[i] = (void *)ADDR_INPUT + i * PS; nodes[i] = 1; status[i] = 0; } ret = numa_move_pages(pid, nr_p, addrs, nodes, status, MPOL_MF_MOVE_ALL); if (ret == -1) err("move_pages"); for (i = 0; i < nr_p; i++) { addrs[i] = (void *)ADDR_INPUT + i * PS; nodes[i] = 0; status[i] = 0; } ret = numa_move_pages(pid, nr_p, addrs, nodes, status, MPOL_MF_MOVE_ALL); if (ret == -1) err("move_pages"); } return 0; } $ cat hugepage.c #include <stdio.h> #include <sys/mman.h> #include <string.h> #define ADDR_INPUT 0x700000000000UL #define HPS 0x200000 int main(int argc, char *argv[]) { int nr_hp = strtol(argv[1], NULL, 0); char *p; while (1) { p = mmap((void *)ADDR_INPUT, nr_hp * HPS, PROT_READ | PROT_WRITE, MAP_PRIVATE | MAP_ANONYMOUS | MAP_HUGETLB, -1, 0); if (p != (void *)ADDR_INPUT) { perror("mmap"); break; } memset(p, 0, nr_hp * HPS); munmap(p, nr_hp * HPS); } } $ sysctl vm.nr_hugepages=40 $ ./hugepage 10 & $ ./movepages 10 $(pgrep -f hugepage) Fixes: e632a938d914 ("mm: migrate: add hugepage migration code to move_pages()") Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reported-by: Hugh Dickins <hughd@google.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Luiz Capitulino <lcapitulino@redhat.com> Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Steve Capper <steve.capper@linaro.org> Cc: <stable@vger.kernel.org> [3.12+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-10rmap: drop support of non-linear mappingsKirill A. Shutemov
We don't create non-linear mappings anymore. Let's drop code which handles them in rmap. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-17vm_area_operations: kill ->migrate()Al Viro
the only instance this method has ever grown was one in kernfs - one that call ->migrate() of another vm_ops if it exists. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-15Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "Highlights: - AMD KFD driver merge This is the AMD HSA interface for exposing a lowlevel interface for GPGPU use. They have an open source userspace built on top of this interface, and the code looks as good as it was going to get out of tree. - Initial atomic modesetting work The need for an atomic modesetting interface to allow userspace to try and send a complete set of modesetting state to the driver has arisen, and been suffering from neglect this past year. No more, the start of the common code and changes for msm driver to use it are in this tree. Ongoing work to get the userspace ioctl finished and the code clean will probably wait until next kernel. - DisplayID 1.3 and tiled monitor exposed to userspace. Tiled monitor property is now exposed for userspace to make use of. - Rockchip drm driver merged. - imx gpu driver moved out of staging Other stuff: - core: panel - MIPI DSI + new panels. expose suggested x/y properties for virtual GPUs - i915: Initial Skylake (SKL) support gen3/4 reset work start of dri1/ums removal infoframe tracking fixes for lots of things. - nouveau: tegra k1 voltage support GM204 modesetting support GT21x memory reclocking work - radeon: CI dpm fixes GPUVM improvements Initial DPM fan control - rcar-du: HDMI support added removed some support for old boards slave encoder driver for Analog Devices adv7511 - exynos: Exynos4415 SoC support - msm: a4xx gpu support atomic helper conversion - tegra: iommu support universal plane support ganged-mode DSI support - sti: HDMI i2c improvements - vmwgfx: some late fixes. - qxl: use suggested x/y properties" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (969 commits) drm: sti: fix module compilation issue drm/i915: save/restore GMBUS freq across suspend/resume on gen4 drm: sti: correctly cleanup CRTC and planes drm: sti: add HQVDP plane drm: sti: add cursor plane drm: sti: enable auxiliary CRTC drm: sti: fix delay in VTG programming drm: sti: prepare sti_tvout to support auxiliary crtc drm: sti: use drm_crtc_vblank_{on/off} instead of drm_vblank_{on/off} drm: sti: fix hdmi avi infoframe drm: sti: remove event lock while disabling vblank drm: sti: simplify gdp code drm: sti: clear all mixer control drm: sti: remove gpio for HDMI hot plug detection drm: sti: allow to change hdmi ddc i2c adapter drm/doc: Document drm_add_modes_noedid() usage drm/i915: Remove '& 0xffff' from the mask given to WA_REG() drm/i915: Invert the mask and val arguments in wa_add() and WA_REG() drm: Zero out DRM object memory upon cleanup drm/i915/bdw: Fix the write setting up the WIZ hashing mode ...
2014-12-13mm: unmapped page migration avoid unmap+remap overheadHugh Dickins
Page migration's __unmap_and_move(), and rmap's try_to_unmap(), were created for use on pages almost certainly mapped into userspace. But nowadays compaction often applies them to unmapped page cache pages: which may exacerbate contention on i_mmap_rwsem quite unnecessarily, since try_to_unmap_file() makes no preliminary page_mapped() check. Now check page_mapped() in __unmap_and_move(); and avoid repeating the same overhead in rmap_walk_file() - don't remove_migration_ptes() when we never inserted any. (The PageAnon(page) comment blocks now look even sillier than before, but clean that up on some other occasion. And note in passing that try_to_unmap_one() does not use a migration entry when PageSwapCache, so remove_migration_ptes() will then not update that swap entry to newpage pte: not a big deal, but something else to clean up later.) Davidlohr remarked in "mm,fs: introduce helpers around the i_mmap_mutex" conversion to i_mmap_rwsem, that "The biggest winner of these changes is migration": a part of the reason might be all of that unnecessary taking of i_mmap_mutex in page migration; and it's rather a shame that I didn't get around to sending this patch in before his - this one is much less useful after Davidlohr's conversion to rwsem, but still good. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09mm/balloon_compaction: redesign ballooned pages managementKonstantin Khlebnikov
Sasha Levin reported KASAN splash inside isolate_migratepages_range(). Problem is in the function __is_movable_balloon_page() which tests AS_BALLOON_MAP in page->mapping->flags. This function has no protection against anonymous pages. As result it tried to check address space flags inside struct anon_vma. Further investigation shows more problems in current implementation: * Special branch in __unmap_and_move() never works: balloon_page_movable() checks page flags and page_count. In __unmap_and_move() page is locked, reference counter is elevated, thus balloon_page_movable() always fails. As a result execution goes to the normal migration path. virtballoon_migratepage() returns MIGRATEPAGE_BALLOON_SUCCESS instead of MIGRATEPAGE_SUCCESS, move_to_new_page() thinks this is an error code and assigns newpage->mapping to NULL. Newly migrated page lose connectivity with balloon an all ability for further migration. * lru_lock erroneously required in isolate_migratepages_range() for isolation ballooned page. This function releases lru_lock periodically, this makes migration mostly impossible for some pages. * balloon_page_dequeue have a tight race with balloon_page_isolate: balloon_page_isolate could be executed in parallel with dequeue between picking page from list and locking page_lock. Race is rare because they use trylock_page() for locking. This patch fixes all of them. Instead of fake mapping with special flag this patch uses special state of page->_mapcount: PAGE_BALLOON_MAPCOUNT_VALUE = -256. Buddy allocator uses PAGE_BUDDY_MAPCOUNT_VALUE = -128 for similar purpose. Storing mark directly in struct page makes everything safer and easier. PagePrivate is used to mark pages present in page list (i.e. not isolated, like PageLRU for normal pages). It replaces special rules for reference counter and makes balloon migration similar to migration of normal pages. This flag is protected by page_lock together with link to the balloon device. Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Link: http://lkml.kernel.org/p/53E6CEAA.9020105@oracle.com Cc: Rafael Aquini <aquini@redhat.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: <stable@vger.kernel.org> [3.8+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-02mm: migrate: Close race between migration completion and mprotectMel Gorman
A migration entry is marked as write if pte_write was true at the time the entry was created. The VMA protections are not double checked when migration entries are being removed as mprotect marks write-migration-entries as read. It means that potentially we take a spurious fault to mark PTEs write again but it's straight-forward. However, there is a race between write migrations being marked read and migrations finishing. This potentially allows a PTE to be write that should have been read. Close this race by double checking the VMA permissions using maybe_mkwrite when migration completes. [torvalds@linux-foundation.org: use maybe_mkwrite] Cc: stable@vger.kernel.org Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08mm: memcontrol: rewrite uncharge APIJohannes Weiner
The memcg uncharging code that is involved towards the end of a page's lifetime - truncation, reclaim, swapout, migration - is impressively complicated and fragile. Because anonymous and file pages were always charged before they had their page->mapping established, uncharges had to happen when the page type could still be known from the context; as in unmap for anonymous, page cache removal for file and shmem pages, and swap cache truncation for swap pages. However, these operations happen well before the page is actually freed, and so a lot of synchronization is necessary: - Charging, uncharging, page migration, and charge migration all need to take a per-page bit spinlock as they could race with uncharging. - Swap cache truncation happens during both swap-in and swap-out, and possibly repeatedly before the page is actually freed. This means that the memcg swapout code is called from many contexts that make no sense and it has to figure out the direction from page state to make sure memory and memory+swap are always correctly charged. - On page migration, the old page might be unmapped but then reused, so memcg code has to prevent untimely uncharging in that case. Because this code - which should be a simple charge transfer - is so special-cased, it is not reusable for replace_page_cache(). But now that charged pages always have a page->mapping, introduce mem_cgroup_uncharge(), which is called after the final put_page(), when we know for sure that nobody is looking at the page anymore. For page migration, introduce mem_cgroup_migrate(), which is called after the migration is successful and the new page is fully rmapped. Because the old page is no longer uncharged after migration, prevent double charges by decoupling the page's memcg association (PCG_USED and pc->mem_cgroup) from the page holding an actual charge. The new bits PCG_MEM and PCG_MEMSW represent the respective charges and are transferred to the new page during migration. mem_cgroup_migrate() is suitable for replace_page_cache() as well, which gets rid of mem_cgroup_replace_page_cache(). However, care needs to be taken because both the source and the target page can already be charged and on the LRU when fuse is splicing: grab the page lock on the charge moving side to prevent changing pc->mem_cgroup of a page under migration. Also, the lruvecs of both pages change as we uncharge the old and charge the new during migration, and putback may race with us, so grab the lru lock and isolate the pages iff on LRU to prevent races and ensure the pages are on the right lruvec afterward. Swap accounting is massively simplified: because the page is no longer uncharged as early as swap cache deletion, a new mem_cgroup_swapout() can transfer the page's memory+swap charge (PCG_MEMSW) to the swap entry before the final put_page() in page reclaim. Finally, page_cgroup changes are now protected by whatever protection the page itself offers: anonymous pages are charged under the page table lock, whereas page cache insertions, swapin, and migration hold the page lock. Uncharging happens under full exclusion with no outstanding references. Charging and uncharging also ensure that the page is off-LRU, which serializes against charge migration. Remove the very costly page_cgroup lock and set pc->flags non-atomically. [mhocko@suse.cz: mem_cgroup_charge_statistics needs preempt_disable] [vdavydov@parallels.com: fix flags definition] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Tested-by: Jet Chen <jet.chen@intel.com> Acked-by: Michal Hocko <mhocko@suse.cz> Tested-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-26mm: fix direct reclaim writeback regressionHugh Dickins
Shortly before 3.16-rc1, Dave Jones reported: WARNING: CPU: 3 PID: 19721 at fs/xfs/xfs_aops.c:971 xfs_vm_writepage+0x5ce/0x630 [xfs]() CPU: 3 PID: 19721 Comm: trinity-c61 Not tainted 3.15.0+ #3 Call Trace: xfs_vm_writepage+0x5ce/0x630 [xfs] shrink_page_list+0x8f9/0xb90 shrink_inactive_list+0x253/0x510 shrink_lruvec+0x563/0x6c0 shrink_zone+0x3b/0x100 shrink_zones+0x1f1/0x3c0 try_to_free_pages+0x164/0x380 __alloc_pages_nodemask+0x822/0xc90 alloc_pages_vma+0xaf/0x1c0 handle_mm_fault+0xa31/0xc50 etc. 970 if (WARN_ON_ONCE((current->flags & (PF_MEMALLOC|PF_KSWAPD)) == 971 PF_MEMALLOC)) I did not respond at the time, because a glance at the PageDirty block in shrink_page_list() quickly shows that this is impossible: we don't do writeback on file pages (other than tmpfs) from direct reclaim nowadays. Dave was hallucinating, but it would have been disrespectful to say so. However, my own /var/log/messages now shows similar complaints WARNING: CPU: 1 PID: 28814 at fs/ext4/inode.c:1881 ext4_writepage+0xa7/0x38b() WARNING: CPU: 0 PID: 27347 at fs/ext4/inode.c:1764 ext4_writepage+0xa7/0x38b() from stressing some mmotm trees during July. Could a dirty xfs or ext4 file page somehow get marked PageSwapBacked, so fail shrink_page_list()'s page_is_file_cache() test, and so proceed to mapping->a_ops->writepage()? Yes, 3.16-rc1's commit 68711a746345 ("mm, migration: add destination page freeing callback") has provided such a way to compaction: if migrating a SwapBacked page fails, its newpage may be put back on the list for later use with PageSwapBacked still set, and nothing will clear it. Whether that can do anything worse than issue WARN_ON_ONCEs, and get some statistics wrong, is unclear: easier to fix than to think through the consequences. Fixing it here, before the put_new_page(), addresses the bug directly, but is probably the worst place to fix it. Page migration is doing too many parts of the job on too many levels: fixing it in move_to_new_page() to complement its SetPageSwapBacked would be preferable, except why is it (and newpage->mapping and newpage->index) done there, rather than down in migrate_page_move_mapping(), once we are sure of success? Not a cleanup to get into right now, especially not with memcg cleanups coming in 3.17. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-23mm: let mm_find_pmd fix buggy race with THP faultHugh Dickins
Trinity has reported: BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: __lock_acquire (kernel/locking/lockdep.c:3070 (discriminator 1)) CPU: 6 PID: 16173 Comm: trinity-c364 Tainted: G W 3.15.0-rc1-next-20140415-sasha-00020-gaa90d09 #398 lock_acquire (arch/x86/include/asm/current.h:14 kernel/locking/lockdep.c:3602) _raw_spin_lock (include/linux/spinlock_api_smp.h:143 kernel/locking/spinlock.c:151) remove_migration_pte (mm/migrate.c:137) rmap_walk (mm/rmap.c:1628 mm/rmap.c:1699) remove_migration_ptes (mm/migrate.c:224) migrate_pages (mm/migrate.c:922 mm/migrate.c:960 mm/migrate.c:1126) migrate_misplaced_page (mm/migrate.c:1733) __handle_mm_fault (mm/memory.c:3762 mm/memory.c:3812 mm/memory.c:3925) handle_mm_fault (mm/memory.c:3948) __get_user_pages (mm/memory.c:1851) __mlock_vma_pages_range (mm/mlock.c:255) __mm_populate (mm/mlock.c:711) SyS_mlockall (include/linux/mm.h:1799 mm/mlock.c:817 mm/mlock.c:791) I believe this comes about because, whereas collapsing and splitting THP functions take anon_vma lock in write mode (which excludes concurrent rmap walks), faulting THP functions (write protection and misplaced NUMA) do not - and mostly they do not need to. But they do use a pmdp_clear_flush(), set_pmd_at() sequence which, for an instant (indeed, for a long instant, given the inter-CPU TLB flush in there), leaves *pmd neither present not trans_huge. Which can confuse a concurrent rmap walk, as when removing migration ptes, seen in the dumped trace. Although that rmap walk has a 4k page to insert, anon_vmas containing THPs are in no way segregated from 4k-page anon_vmas, so the 4k-intent mm_find_pmd() does need to cope with that instant when a trans_huge pmd is temporarily absent. I don't think we need strengthen the locking at the THP end: it's easily handled with an ACCESS_ONCE() before testing both conditions. And since mm_find_pmd() had only one caller who wanted a THP rather than a pmd, let's slightly repurpose it to fail when it hits a THP or non-present pmd, and open code split_huge_page_address() again. Signed-off-by: Hugh Dickins <hughd@google.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Lameter <cl@gentwo.org> Cc: Dave Jones <davej@redhat.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04hugetlb: rename hugepage_migration_support() to ..._supported()Naoya Horiguchi
We already have a function named hugepages_supported(), and the similar name hugepage_migration_support() is a bit unconfortable, so let's rename it hugepage_migration_supported(). Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04mm, migration: add destination page freeing callbackDavid Rientjes
Memory migration uses a callback defined by the caller to determine how to allocate destination pages. When migration fails for a source page, however, it frees the destination page back to the system. This patch adds a memory migration callback defined by the caller to determine how to free destination pages. If a caller, such as memory compaction, builds its own freelist for migration targets, this can reuse already freed memory instead of scanning additional memory. If the caller provides a function to handle freeing of destination pages, it is called when page migration fails. If the caller passes NULL then freeing back to the system will be handled as usual. This patch introduces no functional change. Signed-off-by: David Rientjes <rientjes@google.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Greg Thelen <gthelen@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04mm: numa: add migrated transhuge pages to LRU the same way as base pagesMel Gorman
Migration of misplaced transhuge pages uses page_add_new_anon_rmap() when putting the page back as it avoided an atomic operations and added the new page to the correct LRU. A side-effect is that the page gets marked activated as part of the migration meaning that transhuge and base pages are treated differently from an aging perspective than base page migration. This patch uses page_add_anon_rmap() and putback_lru_page() on completion of a transhuge migration similar to base page migration. It would require fewer atomic operations to use lru_cache_add without taking an additional reference to the page. The downside would be that it's still different to base page migration and unevictable pages may be added to the wrong LRU for cleaning up later. Testing of the usual workloads did not show any adverse impact to the change. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Sasha Levin <sasha.levin@oracle.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-20mm: fix swapops.h:131 bug if remap_file_pages raced migrationHugh Dickins
Add remove_linear_migration_ptes_from_nonlinear(), to fix an interesting little include/linux/swapops.h:131 BUG_ON(!PageLocked) found by trinity: indicating that remove_migration_ptes() failed to find one of the migration entries that was temporarily inserted. The problem comes from remap_file_pages()'s switch from vma_interval_tree (good for inserting the migration entry) to i_mmap_nonlinear list (no good for locating it again); but can only be a problem if the remap_file_pages() range does not cover the whole of the vma (zap_pte() clears the range). remove_migration_ptes() needs a file_nonlinear method to go down the i_mmap_nonlinear list, applying linear location to look for migration entries in those vmas too, just in case there was this race. The file_nonlinear method does need rmap_walk_control.arg to do this; but it never needed vma passed in - vma comes from its own iteration. Reported-and-tested-by: Dave Jones <davej@redhat.com> Reported-and-tested-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-10mm: fix GFP_THISNODE callers and clarifyJohannes Weiner
GFP_THISNODE is for callers that implement their own clever fallback to remote nodes. It restricts the allocation to the specified node and does not invoke reclaim, assuming that the caller will take care of it when the fallback fails, e.g. through a subsequent allocation request without GFP_THISNODE set. However, many current GFP_THISNODE users only want the node exclusive aspect of the flag, without actually implementing their own fallback or triggering reclaim if necessary. This results in things like page migration failing prematurely even when there is easily reclaimable memory available, unless kswapd happens to be running already or a concurrent allocation attempt triggers the necessary reclaim. Convert all callsites that don't implement their own fallback strategy to __GFP_THISNODE. This restricts the allocation a single node too, but at the same time allows the allocator to enter the slowpath, wake kswapd, and invoke direct reclaim if necessary, to make the allocation happen when memory is full. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Rik van Riel <riel@redhat.com> Cc: Jan Stancek <jstancek@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-27mm/migrate.c: fix setting of cpupid on page migration twice against normal pageWanpeng Li
Commit 7851a45cd3f6 ("mm: numa: Copy cpupid on page migration") copies over the cpupid at page migration time. It is unnecessary to set it again in alloc_misplaced_dst_page(). Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23sched/numa: fix setting of cpupid on page migration twiceWanpeng Li
Commit 7851a45cd3f6 ("mm: numa: Copy cpupid on page migration") copiess over the cpupid at page migration time. It is unnecessary to set it again in migrate_misplaced_transhuge_page(). Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23mm: dump page when hitting a VM_BUG_ON using VM_BUG_ON_PAGESasha Levin
Most of the VM_BUG_ON assertions are performed on a page. Usually, when one of these assertions fails we'll get a BUG_ON with a call stack and the registers. I've recently noticed based on the requests to add a small piece of code that dumps the page to various VM_BUG_ON sites that the page dump is quite useful to people debugging issues in mm. This patch adds a VM_BUG_ON_PAGE(cond, page) which beyond doing what VM_BUG_ON() does, also dumps the page before executing the actual BUG_ON. [akpm@linux-foundation.org: fix up includes] Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/migrate: remove unused function, fail_migrate_page()Joonsoo Kim
fail_migrate_page() isn't used anywhere, so remove it. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Christoph Lameter <cl@linux.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/migrate: remove putback_lru_pages, fix comment on putback_movable_pagesJoonsoo Kim
Some part of putback_lru_pages() and putback_movable_pages() is duplicated, so it could confuse us what we should use. We can remove putback_lru_pages() since it is not really needed now. This makes us undestand and maintain the code more easily. And comment on putback_movable_pages() is stale now, so fix it. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Christoph Lameter <cl@linux.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/migrate: correct failure handling if !hugepage_migration_support()Joonsoo Kim
We should remove the page from the list if we fail with ENOSYS, since migrate_pages() consider error cases except -ENOMEM and -EAGAIN as permanent failure and it assumes that the page would be removed from the list. Without this patch, we could overcount number of failure. In addition, we should put back the new hugepage if !hugepage_migration_support(). If not, we would leak hugepage memory. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Christoph Lameter <cl@linux.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/migrate: add comment about permanent failure pathNaoya Horiguchi
Let's add a comment about where the failed page goes to, which makes code more readable. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Christoph Lameter <cl@linux.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Acked-by: Rafael Aquini <aquini@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm: numa: trace tasks that fail migration due to rate limitingMel Gorman
A low local/remote numa hinting fault ratio is potentially explained by failed migrations. This patch adds a tracepoint that fires when migration fails due to migration rate limitation. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm: numa: limit scope of lock for NUMA migrate rate limitingMel Gorman
NUMA migrate rate limiting protects a migration counter and window using a lock but in some cases this can be a contended lock. It is not critical that the number of pages be perfect, lost updates are acceptable. Reduce the importance of this lock. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm: numa: make NUMA-migrate related functions staticMel Gorman
numamigrate_update_ratelimit and numamigrate_isolate_page only have callers in mm/migrate.c. This patch makes them static. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/rmap: make rmap_walk to get the rmap_walk_control argumentJoonsoo Kim
In each rmap traverse case, there is some difference so that we need function pointers and arguments to them in order to handle these For this purpose, struct rmap_walk_control is introduced in this patch, and will be extended in following patch. Introducing and extending are separate, because it clarify changes. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Hillf Danton <dhillf@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mmu_notifier: call mmu_notifier_invalidate_range() from VMMJoerg Roedel
Add calls to the new mmu_notifier_invalidate_range() function to all places in the VMM that need it. Signed-off-by: Joerg Roedel <jroedel@suse.de> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Jérôme Glisse <jglisse@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Rik van Riel <riel@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Jay Cornwall <Jay.Cornwall@amd.com> Cc: Oded Gabbay <Oded.Gabbay@amd.com> Cc: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Oded Gabbay <oded.gabbay@amd.com>
2013-12-21aio/migratepages: make aio migrate pages saneBenjamin LaHaise
The arbitrary restriction on page counts offered by the core migrate_page_move_mapping() code results in rather suspicious looking fiddling with page reference counts in the aio_migratepage() operation. To fix this, make migrate_page_move_mapping() take an extra_count parameter that allows aio to tell the code about its own reference count on the page being migrated. While cleaning up aio_migratepage(), make it validate that the old page being passed in is actually what aio_migratepage() expects to prevent misbehaviour in the case of races. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
2013-12-18mm: numa: defer TLB flush for THP migration as long as possibleMel Gorman
THP migration can fail for a variety of reasons. Avoid flushing the TLB to deal with THP migration races until the copy is ready to start. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18mm: numa: avoid unnecessary disruption of NUMA hinting during migrationMel Gorman
do_huge_pmd_numa_page() handles the case where there is parallel THP migration. However, by the time it is checked the NUMA hinting information has already been disrupted. This patch adds an earlier check with some helpers. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18mm: numa: avoid unnecessary work on the failure pathMel Gorman
If a PMD changes during a THP migration then migration aborts but the failure path is doing more work than is necessary. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18mm: numa: call MMU notifiers on THP migrationMel Gorman
MMU notifiers must be called on THP page migration or secondary MMUs will get very confused. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-18mm: numa: serialise parallel get_user_page against THP migrationMel Gorman
Base pages are unmapped and flushed from cache and TLB during normal page migration and replaced with a migration entry that causes any parallel NUMA hinting fault or gup to block until migration completes. THP does not unmap pages due to a lack of support for migration entries at a PMD level. This allows races with get_user_pages and get_user_pages_fast which commit 3f926ab945b6 ("mm: Close races between THP migration and PMD numa clearing") made worse by introducing a pmd_clear_flush(). This patch forces get_user_page (fast and normal) on a pmd_numa page to go through the slow get_user_page path where it will serialise against THP migration and properly account for the NUMA hinting fault. On the migration side the page table lock is taken for each PTE update. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Alex Thorlton <athorlton@sgi.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-21mm: thp: give transparent hugepage code a separate copy_pageDave Hansen
Right now, the migration code in migrate_page_copy() uses copy_huge_page() for hugetlbfs and thp pages: if (PageHuge(page) || PageTransHuge(page)) copy_huge_page(newpage, page); So, yay for code reuse. But: void copy_huge_page(struct page *dst, struct page *src) { struct hstate *h = page_hstate(src); and a non-hugetlbfs page has no page_hstate(). This works 99% of the time because page_hstate() determines the hstate from the page order alone. Since the page order of a THP page matches the default hugetlbfs page order, it works. But, if you change the default huge page size on the boot command-line (say default_hugepagesz=1G), then we might not even *have* a 2MB hstate so page_hstate() returns null and copy_huge_page() oopses pretty fast since copy_huge_page() dereferences the hstate: void copy_huge_page(struct page *dst, struct page *src) { struct hstate *h = page_hstate(src); if (unlikely(pages_per_huge_page(h) > MAX_ORDER_NR_PAGES)) { ... Mel noticed that the migration code is really the only user of these functions. This moves all the copy code over to migrate.c and makes copy_huge_page() work for THP by checking for it explicitly. I believe the bug was introduced in commit b32967ff101a ("mm: numa: Add THP migration for the NUMA working set scanning fault case") [akpm@linux-foundation.org: fix coding-style and comment text, per Naoya Horiguchi] Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Acked-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Tested-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
