Currently, memory hotplug calls setup_per_zone_wmarks() and
calculate_zone_inactive_ratio(), but doesn't call
setup_per_zone_lowmem_reserve().
It means the number of reserved pages aren't updated even if memory hot
plug occur. This patch fixes it.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
should be __meminit.
Commit bce7394a3e ("page-allocator: reset wmark_min and inactive ratio of
zone when hotplug happens") introduced invalid section references. Now,
setup_per_zone_inactive_ratio() is marked __init and then it can't be
referenced from memory hotplug code.
This patch marks it as __meminit and also marks caller as __ref.
Cc: Yasunori Goto <y-goto@jp.fujitsu.com>
If CONFIG_FLATMEM is enabled pfn is calculated in online_page() more than
once. It is possible to optimize that and use value established at
beginning of that function.
Signed-off-by: Daniel Kiper <dkiper@net-space.pl>
Acked-by: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Christoph Lameter <cl@linux.com>
Acked-by: David Rientjes <rientjes@google.com>
Reviewed-by: Jesper Juhl <jj@chaosbits.net>
PG_buddy can be converted to _mapcount == -2. So the PG_compound_lock can
be added to page->flags without overflowing (because of the sparse section
bits increasing) with CONFIG_X86_PAE=y and CONFIG_X86_PAT=y. This also
has to move the memory hotplug code from _mapcount to lru.next to avoid
any risk of clashes. We can't use lru.next for PG_buddy removal, but
memory hotplug can use lru.next even more easily than the mapcount
instead.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
sync
With the introduction of the boolean sync parameter, the API looks a
little inconsistent as offlining is still an int. Convert offlining to a
bool for the sake of being tidy.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Andy Whitcroft <apw@shadowen.org>
synchronous compaction in the faster path
Migration synchronously waits for writeback if the initial passes fails.
Callers of memory compaction do not necessarily want this behaviour if the
caller is latency sensitive or expects that synchronous migration is not
going to have a significantly better success rate.
This patch adds a sync parameter to migrate_pages() allowing the caller to
indicate if wait_on_page_writeback() is allowed within migration or not.
For reclaim/compaction, try_to_compact_pages() is first called
asynchronously, direct reclaim runs and then try_to_compact_pages() is
called synchronously as there is a greater expectation that it'll succeed.
[akpm@linux-foundation.org: build/merge fix]
Now, memory_hotplug_(un)lock() is used for add/remove/offline pages
for avoiding races with hibernation. But this should be held in
online_pages(), too. It seems asymmetric.
There are cases where one has to avoid a race with memory hotplug
notifier and his own local code, and hotplug v.s. hotplug.
This will add a generic solution for avoiding races. In other view,
having lock here has no big impacts. online pages is tend to be
done by udev script at el against each memory section one by one.
Then, it's better to have lock here, too.
Cc: <stable@kernel.org> # 2.6.37
Reviewed-by: Christoph Lameter <cl@linux.com>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
Presently hwpoison is using lock_system_sleep() to prevent a race with
memory hotplug. However lock_system_sleep() is a no-op if
CONFIG_HIBERNATION=n. Therefore we need a new lock.
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Suggested-by: Hugh Dickins <hughd@google.com>
Simple code for reducing list_empty(&source) check.
Signed-off-by: Bob Liu <lliubbo@gmail.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Wu Fengguang <fengguang.wu@intel.com>
If not_managed is true all pages will be putback to lru, so break the loop
earlier to skip other pages isolate.
Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Now, sysfs interface of memory hotplug shows whether the section is
removable or not. But it checks only migrateype of pages and doesn't
check details of cluster of pages.
Next, memory hotplug's set_migratetype_isolate() has the same kind of
check, too.
This patch adds the function __count_unmovable_pages() and makes above 2
checks to use the same logic. Then, is_removable and hotremove code uses
the same logic. No changes in the hotremove logic itself.
TODO: need to find a way to check RECLAMABLE. But, considering bit,
calling shrink_slab() against a range before starting memory hotremove
sounds better. If so, this patch's logic doesn't need to be changed.
Reported-by: Michal Hocko <mhocko@suse.cz>
Presently update_nr_listpages() doesn't have a role. That's because lists
passed is always empty just after calling migrate_pages. The
migrate_pages cleans up page list which have failed to migrate before
returning by aaa994b3.
[PATCH] page migration: handle freeing of pages in migrate_pages()
Do not leave pages on the lists passed to migrate_pages(). Seems that we will
not need any postprocessing of pages. This will simplify the handling of
pages by the callers of migrate_pages().
At that time, we thought we don't need any postprocessing of pages. But
the situation is changed. The compaction need to know the number of
failed to migrate for COMPACTPAGEFAILED stat
This patch makes new rule for caller of migrate_pages to call
putback_lru_pages. So caller need to clean up the lists so it has a
chance to postprocess the pages. [suggested by Christoph Lameter]
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
Acked-by: Christoph Lameter <cl@linux.com>
scan_lru_pages returns pfn. So, it's type should be "unsigned long"
not "int".
Note: I guess this has been work until now because memory hotplug tester's
machine has not very big memory....
physical address < 32bit << PAGE_SHIFT.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
lru_add_drain_all() uses schedule_on_each_cpu() which is synchronous.
There is no reason to call flush_scheduled_work() after
lru_add_drain_all(). Drop the spurious calls.
This is to prepare for the deprecation and removal of
flush_scheduled_work().
next_active_pageblock() is for finding next _used_ freeblock. It skips
several blocks when it finds there are a chunk of free pages lager than
pageblock. But it has 2 bugs.
1. We have no lock. page_order(page) - pageblock_order can be minus.
2. pageblocks_stride += is wrong. it should skip page_order(p) of pages.
Add global mutex zonelists_mutex to fix the possible race:
CPU0 CPU1 CPU2
(1) zone->present_pages += online_pages;
(2) build_all_zonelists();
(3) alloc_page();
(4) free_page();
(5) build_all_zonelists();
(6) __build_all_zonelists();
(7) zone->pageset = alloc_percpu();
In step (3,4), zone->pageset still points to boot_pageset, so bad
things may happen if 2+ nodes are in this state. Even if only 1 node
is accessing the boot_pageset, (3) may still consume too much memory
to fail the memory allocations in step (7).
Besides, atomic operation ensures alloc_percpu() in step (7) will never fail
since there is a new fresh memory block added in step(6).
[haicheng.li@linux.intel.com: hold zonelists_mutex when build_all_zonelists]
Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Reviewed-by: Andi Kleen <andi.kleen@intel.com>
Cc: Tejun Heo <tj@kernel.org>
For each new populated zone of hotadded node, need to update its pagesets
with dynamically allocated per_cpu_pageset struct for all possible CPUs:
1) Detach zone->pageset from the shared boot_pageset
at end of __build_all_zonelists().
2) Use mutex to protect zone->pageset when it's still
shared in onlined_pages()
Otherwises, multiple zones of different nodes would share same boot strapping
boot_pageset for same CPU, which will finally cause below kernel panic:
kernel BUG at mm/page_alloc.c:1239!
invalid opcode: 0000 [#1] SMP
Call Trace:
[<ffffffff811300c1>] __alloc_pages_nodemask+0x131/0x7b0
[<ffffffff81162e67>] alloc_pages_current+0x87/0xd0
[<ffffffff81128407>] __page_cache_alloc+0x67/0x70
[<ffffffff811325f0>] __do_page_cache_readahead+0x120/0x260
[<ffffffff81132751>] ra_submit+0x21/0x30
[<ffffffff811329c6>] ondemand_readahead+0x166/0x2c0
[<ffffffff81132ba0>] page_cache_async_readahead+0x80/0xa0
[<ffffffff8112a0e4>] generic_file_aio_read+0x364/0x670
[<ffffffff81266cfa>] nfs_file_read+0xca/0x130
[<ffffffff8117b20a>] do_sync_read+0xfa/0x140
[<ffffffff8117bf75>] vfs_read+0xb5/0x1a0
[<ffffffff8117c151>] sys_read+0x51/0x80
[<ffffffff8103c032>] system_call_fastpath+0x16/0x1b
RIP [<ffffffff8112ff13>] get_page_from_freelist+0x883/0x900
RSP <ffff88000d1e78a8>
---[ end trace 4bda28328b9990db ]
[akpm@linux-foundation.org: merge fix]
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Enable users to online CPUs even if the CPUs belongs to a numa node which
doesn't have onlined local memory.
The zonlists(pg_data_t.node_zonelists[]) of a numa node are created either
in system boot/init period, or at the time of local memory online. For a
numa node without onlined local memory, its zonelists are not initialized
at present. As a result, any memory allocation operations executed by
CPUs within this node will fail. In fact, an out-of-memory error is
triggered when attempt to online CPUs before memory comes to online.
This patch tries to create zonelists for such numa nodes, so that the
memory allocation for this node can be fallback'ed to other nodes.
[akpm@linux-foundation.org: remove unneeded export]
Signed-off-by: minskey guo<chaohong.guo@intel.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
- introduce dump_page() to print the page info for debugging some error
condition.
- convert three mm users: bad_page(), print_bad_pte() and memory offline
failure.
- print an extra field: the symbolic names of page->flags
Example dump_page() output:
[ 157.521694] page:ffffea0000a7cba8 count:2 mapcount:1 mapping:ffff88001c901791 index:0x147
[ 157.525570] page flags: 0x100000000100068(uptodate|lru|active|swapbacked)
Cc: Alex Chiang <achiang@hp.com>
Cc: Mel Gorman <mel@linux.vnet.ibm.com>
A memmap is a directory in sysfs which includes 3 text files: start, end
and type. For example:
start: 0x100000
end: 0x7e7b1cff
type: System RAM
Interface firmware_map_add was not called explicitly. Remove it and add
function firmware_map_add_hotplug as hotplug interface of memmap.
Each memory entry has a memmap in sysfs, When we hot-add new memory, sysfs
does not export memmap entry for it. We add a call in function add_memory
to function firmware_map_add_hotplug.
Add a new function add_sysfs_fw_map_entry() to create memmap entry, it
will be called when initialize memmap and hot-add memory.
[akpm@linux-foundation.org: un-kernedoc a no longer kerneldoc comment]
Signed-off-by: Shaohui Zheng <shaohui.zheng@intel.com>
Acked-by: Andi Kleen <ak@linux.intel.com>
Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
__free_pages_bootmem() is a __meminit function - which has been called
from put_pages_bootmem thus causes a section mismatch warning.
We were warned by the following warning:
LD mm/built-in.o
WARNING: mm/built-in.o(.text+0x26b22): Section mismatch in reference
from the function put_page_bootmem() to the function
.meminit.text:__free_pages_bootmem()
The function put_page_bootmem() references
the function __meminit __free_pages_bootmem().
This is often because put_page_bootmem lacks a __meminit
annotation or the annotation of __free_pages_bootmem is wrong.
Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com>
Cc: Badari Pulavarty <pbadari@us.ibm.com>
It has no references outside memory_hotplug.c.
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
The previous patch enables page migration of ksm pages, but that soon gets
into trouble: not surprising, since we're using the ksm page lock to lock
operations on its stable_node, but page migration switches the page whose
lock is to be used for that. Another layer of locking would fix it, but
do we need that yet?
Do we actually need page migration of ksm pages? Yes, memory hotremove
needs to offline sections of memory: and since we stopped allocating ksm
pages with GFP_HIGHUSER, they will tend to be GFP_HIGHUSER_MOVABLE
candidates for migration.
But KSM is currently unconscious of NUMA issues, happily merging pages
from different NUMA nodes: at present the rule must be, not to use
MADV_MERGEABLE where you care about NUMA. So no, NUMA page migration of
ksm pages does not make sense yet.
So, to complete support for ksm swapping we need to make hotremove safe.
ksm_memory_callback() take ksm_thread_mutex when MEM_GOING_OFFLINE and
release it when MEM_OFFLINE or MEM_CANCEL_OFFLINE. But if mapped pages
are freed before migration reaches them, stable_nodes may be left still
pointing to struct pages which have been removed from the system: the
stable_node needs to identify a page by pfn rather than page pointer, then
it can safely prune them when MEM_OFFLINE.
And make NUMA migration skip PageKsm pages where it skips PageReserved.
But it's only when we reach unmap_and_move() that the page lock is taken
and we can be sure that raised pagecount has prevented a PageAnon from
being upgraded: so add offlining arg to migrate_pages(), to migrate ksm
page when offlining (has sufficient locking) but reject it otherwise.
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Izik Eidus <ieidus@redhat.com>
Cc: Chris Wright <chrisw@redhat.com>
When memory is hot-removed, its node must be cleared in N_HIGH_MEMORY if
there are no present pages left.
In such a situation, kswapd must also be stopped since it has nothing left
to do.
Signed-off-by: David Rientjes <rientjes@google.com>
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Nishanth Aravamudan <nacc@us.ibm.com>
Cc: Adam Litke <agl@us.ibm.com>
Cc: Andy Whitcroft <apw@canonical.com>
Cc: Eric Whitney <eric.whitney@hp.com>
Christoph pointed out inc_zone_page_state(NR_ISOLATED) should be placed
in right after isolate_page().
This patch does it.
Allow memory hotplug and hibernation in the same kernel
Memory hotplug and hibernation were exclusive in Kconfig. This is
obviously a problem for distribution kernels who want to support both in
the same image.
After some discussions with Rafael and others the only problem is with
parallel memory hotadd or removal while a hibernation operation is in
process. It was also working for s390 before.
This patch removes the Kconfig level exclusion, and simply makes the
memory add / remove functions grab the pm_mutex to exclude against
hibernation.
Fixes a regression - old kernels didn't exclude memory hotadd and
hibernation.
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
With CONFIG_MEMORY_HOTPLUG I got following warning:
WARNING: vmlinux.o(.text+0x1276b0): Section mismatch in reference from
the function hotadd_new_pgdat() to the function
.meminit.text:free_area_init_node()
The function hotadd_new_pgdat() references
the function __meminit free_area_init_node().
This is often because hotadd_new_pgdat lacks a __meminit
annotation or the annotation of free_area_init_node is wrong.
Use __ref to fix this.
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Originally, walk_memory_resource() was introduced to traverse all memory
of "System RAM" for detecting memory hotplug/unplug range. For doing so,
flags of IORESOUCE_MEM|IORESOURCE_BUSY was used and this was enough for
memory hotplug.
But for using other purpose, /proc/kcore, this may includes some firmware
area marked as IORESOURCE_BUSY | IORESOUCE_MEM. This patch makes the
check strict to find out busy "System RAM".
Note: PPC64 keeps their own walk_memory_resouce(), which walk through
ppc64's lmb informaton. Because old kclist_add() is called per lmb, this
patch makes no difference in behavior, finally.
And this patch removes CONFIG_MEMORY_HOTPLUG check from this function.
Because pfn_valid() just show "there is memmap or not* and cannot be used
for "there is physical memory or not", this function is useful in generic
to scan physical memory range.
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Américo Wang <xiyou.wangcong@gmail.com>
Cc: Roland Dreier <rolandd@cisco.com>
Sizing of memory allocations shouldn't depend on the number of physical
pages found in a system, as that generally includes (perhaps a huge amount
of) non-RAM pages. The amount of what actually is usable as storage
should instead be used as a basis here.
In line with that, the memory hotplug code should update num_physpages in
a way that it retains its original (post-boot) meaning; in particular,
decreasing the value should at best be done with great care - this patch
doesn't try to ever decrease this value at all as it doesn't really seem
meaningful to do so.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
In my test, 128M memory is hot added, but zone's pcp batch is 0, which is
an obvious error. When pages are onlined, zone pcp should be updated
accordingly.
[akpm@linux-foundation.org: fix warnings]
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Cc: Yakui Zhao <yakui.zhao@intel.com>
Solve two problems.
Whenever memory hotplug sucessfully happens, zone->present_pages
have to be changed.
1) Now memory hotplug calls setup_per_zone_wmark_min only when
online_pages called, not offline_pages.
It breaks balance.
2) If zone->present_pages is changed, we also have to change
zone->inactive_ratio. That's because inactive_ratio depends on
zone->present_pages.
Change the names of two functions. It doesn't affect behavior.
Presently, setup_per_zone_pages_min() changes low, high of zone as well as
min. So a better name is setup_per_zone_wmarks(). That's because Mel
changed zone->pages_[hig/low/min] to zone->watermark array in "page
allocator: replace the watermark-related union in struct zone with a
watermark[] array".
* setup_per_zone_pages_min => setup_per_zone_wmarks
Of course, we have to change init_per_zone_pages_min, too. There are not
pages_min any more.
* init_per_zone_pages_min => init_per_zone_wmark_min
GFP_HIGHUSER_PAGECACHE is just an alias for GFP_HIGHUSER_MOVABLE, making
that harder to track down: remove it, and its out-of-work brothers
GFP_NOFS_PAGECACHE and GFP_USER_PAGECACHE.
Since we're making that improvement to hotremove_migrate_alloc(), I think
we can now also remove one of the "o"s from its comment.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Show node to memory section relationship with symlinks in sysfs
Add /sys/devices/system/node/nodeX/memoryY symlinks for all
the memory sections located on nodeX. For example:
/sys/devices/system/node/node1/memory135 -> ../../memory/memory135
indicates that memory section 135 resides on node1.
Also revises documentation to cover this change as well as updating
Documentation/ABI/testing/sysfs-devices-memory to include descriptions
of memory hotremove files 'phys_device', 'phys_index', and 'state'
that were previously not described there.
In addition to it always being a good policy to provide users with
the maximum possible amount of physical location information for
resources that can be hot-added and/or hot-removed, the following
are some (but likely not all) of the user benefits provided by
this change.
Immediate:
- Provides information needed to determine the specific node
on which a defective DIMM is located. This will reduce system
downtime when the node or defective DIMM is swapped out.
- Prevents unintended onlining of a memory section that was
previously offlined due to a defective DIMM. This could happen
during node hot-add when the user or node hot-add assist script
onlines _all_ offlined sections due to user or script inability
to identify the specific memory sections located on the hot-added
node. The consequences of reintroducing the defective memory
could be ugly.
- Provides information needed to vary the amount and distribution
of memory on specific nodes for testing or debugging purposes.
Future:
- Will provide information needed to identify the memory
sections that need to be offlined prior to physical removal
of a specific node.
Symlink creation during boot was tested on 2-node x86_64, 2-node
ppc64, and 2-node ia64 systems. Symlink creation during physical
memory hot-add tested on a 2-node x86_64 system.
Signed-off-by: Gary Hade <garyhade@us.ibm.com>
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
After adding a node into the machine, top cpuset's mems isn't updated.
By reviewing the code, we found that the update function
cpuset_track_online_nodes()
was invoked after node_states[N_ONLINE] changes. It is wrong because
N_ONLINE just means node has pgdat, and if node has/added memory, we use
N_HIGH_MEMORY. So, We should invoke the update function after
node_states[N_HIGH_MEMORY] changes, just like its commit says.
This patch fixes it. And we use notifier of memory hotplug instead of
direct calling of cpuset_track_online_nodes().
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
Cc: Paul Menage <menage@google.com
During hotplug memory remove, memory regions should be released on a
PAGES_PER_SECTION size chunks. This mirrors the code in add_memory where
resources are requested on a PAGES_PER_SECTION size.
Attempting to release the entire memory region fails because there is not
a single resource for the total number of pages being removed. Instead
the resources for the pages are split in PAGES_PER_SECTION size chunks as
requested during memory add.
Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com>
On large memory systems, the VM can spend way too much time scanning
through pages that it cannot (or should not) evict from memory. Not only
does it use up CPU time, but it also provokes lock contention and can
leave large systems under memory presure in a catatonic state.
This patch series improves VM scalability by:
1) putting filesystem backed, swap backed and unevictable pages
onto their own LRUs, so the system only scans the pages that it
can/should evict from memory
2) switching to two handed clock replacement for the anonymous LRUs,
so the number of pages that need to be scanned when the system
starts swapping is bound to a reasonable number
3) keeping unevictable pages off the LRU completely, so the
VM does not waste CPU time scanning them. ramfs, ramdisk,
SHM_LOCKED shared memory segments and mlock()ed VMA pages
are keept on the unevictable list.
This patch:
isolate_lru_page logically belongs to be in vmscan.c than migrate.c.
It is tough, because we don't need that function without memory migration
so there is a valid argument to have it in migrate.c. However a
subsequent patch needs to make use of it in the core mm, so we can happily
move it to vmscan.c.
Also, make the function a little more generic by not requiring that it
adds an isolated page to a given list. Callers can do that.
Note that we now have '__isolate_lru_page()', that does
something quite different, visible outside of vmscan.c
for use with memory controller. Methinks we need to
rationalize these names/purposes. --lts
[akpm@linux-foundation.org: fix mm/memory_hotplug.c build]
Signed-off-by: Nick Piggin <npiggin@suse.de>
Signed-off-by: Rik van Riel <riel@redhat.com>
Signed-off-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
There is nothing architecture specific about remove_memory().
remove_memory() function is common for all architectures which support
hotplug memory remove. Instead of duplicating it in every architecture,
collapse them into arch neutral function.
[akpm@linux-foundation.org: fix the export]
Cc: Gary Hade <garyhade@us.ibm.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Memory may be hot-removed on a per-memory-block basis, particularly on
POWER where the SPARSEMEM section size often matches the memory-block
size. A user-level agent must be able to identify which sections of
memory are likely to be removable before attempting the potentially
expensive operation. This patch adds a file called "removable" to the
memory directory in sysfs to help such an agent. In this patch, a memory
block is considered removable if;
o It contains only MOVABLE pageblocks
o It contains only pageblocks with free pages regardless of pageblock type
On the other hand, a memory block starting with a PageReserved() page will
never be considered removable. Without this patch, the user-agent is
forced to choose a memory block to remove randomly.
Sample output of the sysfs files:
./memory/memory0/removable: 0
./memory/memory1/removable: 0
./memory/memory2/removable: 0
./memory/memory3/removable: 0
./memory/memory4/removable: 0
./memory/memory5/removable: 0
./memory/memory6/removable: 0
./memory/memory7/removable: 1
./memory/memory8/removable: 0
./memory/memory9/removable: 0
./memory/memory10/removable: 0
./memory/memory11/removable: 0
./memory/memory12/removable: 0
./memory/memory13/removable: 0
./memory/memory14/removable: 0
./memory/memory15/removable: 0
./memory/memory16/removable: 0
./memory/memory17/removable: 1
./memory/memory18/removable: 1
./memory/memory19/removable: 1
./memory/memory20/removable: 1
./memory/memory21/removable: 1
./memory/memory22/removable: 1
zonelists in online_pages()
If zonelist is required to be rebuilt in online_pages(), there is no need
to recalculate vm_total_pages in that function, as it has been updated in
the call build_all_zonelists().
Signed-off-by: Kent Liu <kent.liu@linux.intel.com>
- Change some naming
* Magic -> types
* MIX_INFO -> MIX_SECTION_INFO
* Change definition of bootmem type from direct hex value
- __free_pages_bootmem() becomes __meminit.
Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Cc: Johannes Weiner <hannes@saeurebad.de>
Make the needlessly global register_page_bootmem_info_section() static.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
free_area_init_node() gets passed in the node id as well as the node
descriptor. This is redundant as the function can trivially get the node
descriptor itself by means of NODE_DATA() and the node's id.
I checked all the users and NODE_DATA() seems to be usable everywhere
from where this function is called.
Signed-off-by: Johannes Weiner <hannes@saeurebad.de>
Trying to online a new memory section that was added via memory hotplug
sometimes results in crashes when the new pages are added via __free_page.
Reason for that is that the pageblock bitmap isn't initialized and hence
contains random stuff. That means that get_pageblock_migratetype()
returns also random stuff and therefore
list_add(&page->lru,
&zone->free_area[order].free_list[migratetype]);
in __free_one_page() tries to do a list_add to something that isn't even
necessarily a list.
This happens since 86051ca5eaf5e560113ec7673462804c54284456 ("mm: fix
usemap initialization") which makes sure that the pageblock bitmap gets
only initialized for pages present in a zone. Unfortunately for hot-added
memory the zones "grow" after the memmap and the pageblock memmap have
been initialized. Which means that the new pages have an unitialized
bitmap. To solve this the calls to grow_zone_span() and grow_pgdat_span()
are moved to __add_zone() just before the initialization happens.
The patch also moves the two functions since __add_zone() is the only
caller and I didn't want to add a forward declaration.
Add a check to online_pages() to test for failure of
walk_memory_resource(). This fixes a condition where a failure
of walk_memory_resource() can lead to online_pages() returning
success without the requested pages being onlined.
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
Cc: Keith Mannthey <kmannth@us.ibm.com>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: Paul Jackson <pj@sgi.com>
__add_zone calls memmap_init_zone twice if memory gets attached to an empty
zone. Once via init_currently_empty_zone and once explictly right after that
call.
Looks like this is currently not a bug, however the call is superfluous and
might lead to subtle bugs if memmap_init_zone gets changed. So make sure it
is called only once.
