path: root/mm/memory.c
2014-09-26mm: softdirty: keep bit when zapping file ptePeter Feiner
This fixes the same bug as b43790eedd31 ("mm: softdirty: don't forget to save file map softdiry bit on unmap") and 9aed8614af5a ("mm/memory.c: don't forget to set softdirty on file mapped fault") where the return value of pte_*mksoft_dirty was being ignored. To be sure that no other pte/pmd "mk" function return values were being ignored, I annotated the functions in arch/x86/include/asm/pgtable.h with __must_check and rebuilt. The userspace effect of this bug is that the softdirty mark might be lost if a file mapped pte get zapped. Signed-off-by: Peter Feiner <pfeiner@google.com> Acked-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Jamie Liu <jamieliu@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> [3.12+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-22Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fixes from Paolo Bonzini: "Two very simple bugfixes, affecting all supported architectures" [ Two? There's three commits in here. Oh well, I guess Paolo didn't count the preparatory symbol export ] * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: correct null pid check in kvm_vcpu_yield_to() KVM: check for !is_zero_pfn() in kvm_is_mmio_pfn() mm: export symbol dependencies of is_zero_pfn()
2014-09-14mm: export symbol dependencies of is_zero_pfn()Ard Biesheuvel
In order to make the static inline function is_zero_pfn() callable by modules, export its symbol dependencies 'zero_pfn' and (for s390 and mips) 'zero_page_mask'. We need this for KVM, as CONFIG_KVM is a tristate for all supported architectures except ARM and arm64, and testing a pfn whether it refers to the zero page is required to correctly distinguish the zero page from other special RAM ranges that may also have the PG_reserved bit set, but need to be treated as MMIO memory. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-08-29x86,mm: fix pte_special versus pte_numaHugh Dickins
Sasha Levin has shown oopses on ffffea0003480048 and ffffea0003480008 at mm/memory.c:1132, running Trinity on different 3.16-rc-next kernels: where zap_pte_range() checks page->mapping to see if PageAnon(page). Those addresses fit struct pages for pfns d2001 and d2000, and in each dump a register or a stack slot showed d2001730 or d2000730: pte flags 0x730 are PCD ACCESSED PROTNONE SPECIAL IOMAP; and Sasha's e820 map has a hole between cfffffff and 100000000, which would need special access. Commit c46a7c817e66 ("x86: define _PAGE_NUMA by reusing software bits on the PMD and PTE levels") has broken vm_normal_page(): a PROTNONE SPECIAL pte no longer passes the pte_special() test, so zap_pte_range() goes on to try to access a non-existent struct page. Fix this by refining pte_special() (SPECIAL with PRESENT or PROTNONE) to complement pte_numa() (SPECIAL with neither PRESENT nor PROTNONE). A hint that this was a problem was that c46a7c817e66 added pte_numa() test to vm_normal_page(), and moved its is_zero_pfn() test from slow to fast path: This was papering over a pte_special() snag when the zero page was encountered during zap. This patch reverts vm_normal_page() to how it was before, relying on pte_special(). It still appears that this patch may be incomplete: aren't there other places which need to be handling PROTNONE along with PRESENT? For example, pte_mknuma() clears _PAGE_PRESENT and sets _PAGE_NUMA, but on a PROT_NONE area, that would make it pte_special(). This is side-stepped by the fact that NUMA hinting faults skipped PROT_NONE VMAs and there are no grounds where a NUMA hinting fault on a PROT_NONE VMA would be interesting. Fixes: c46a7c817e66 ("x86: define _PAGE_NUMA by reusing software bits on the PMD and PTE levels") Reported-by: Sasha Levin <sasha.levin@oracle.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: <stable@vger.kernel.org> [3.16] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08arm64,ia64,ppc,s390,sh,tile,um,x86,mm: remove default gate areaAndy Lutomirski
The core mm code will provide a default gate area based on FIXADDR_USER_START and FIXADDR_USER_END if !defined(__HAVE_ARCH_GATE_AREA) && defined(AT_SYSINFO_EHDR). This default is only useful for ia64. arm64, ppc, s390, sh, tile, 64-bit UML, and x86_32 have their own code just to disable it. arm, 32-bit UML, and x86_64 have gate areas, but they have their own implementations. This gets rid of the default and moves the code into ia64. This should save some code on architectures without a gate area: it's now possible to inline the gate_area functions in the default case. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Acked-by: Nathan Lynch <nathan_lynch@mentor.com> Acked-by: H. Peter Anvin <hpa@linux.intel.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [in principle] Acked-by: Richard Weinberger <richard@nod.at> [for um] Acked-by: Will Deacon <will.deacon@arm.com> [for arm64] Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Nathan Lynch <Nathan_Lynch@mentor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08mm: memcontrol: rewrite uncharge APIJohannes Weiner
The memcg uncharging code that is involved towards the end of a page's lifetime - truncation, reclaim, swapout, migration - is impressively complicated and fragile. Because anonymous and file pages were always charged before they had their page->mapping established, uncharges had to happen when the page type could still be known from the context; as in unmap for anonymous, page cache removal for file and shmem pages, and swap cache truncation for swap pages. However, these operations happen well before the page is actually freed, and so a lot of synchronization is necessary: - Charging, uncharging, page migration, and charge migration all need to take a per-page bit spinlock as they could race with uncharging. - Swap cache truncation happens during both swap-in and swap-out, and possibly repeatedly before the page is actually freed. This means that the memcg swapout code is called from many contexts that make no sense and it has to figure out the direction from page state to make sure memory and memory+swap are always correctly charged. - On page migration, the old page might be unmapped but then reused, so memcg code has to prevent untimely uncharging in that case. Because this code - which should be a simple charge transfer - is so special-cased, it is not reusable for replace_page_cache(). But now that charged pages always have a page->mapping, introduce mem_cgroup_uncharge(), which is called after the final put_page(), when we know for sure that nobody is looking at the page anymore. For page migration, introduce mem_cgroup_migrate(), which is called after the migration is successful and the new page is fully rmapped. Because the old page is no longer uncharged after migration, prevent double charges by decoupling the page's memcg association (PCG_USED and pc->mem_cgroup) from the page holding an actual charge. The new bits PCG_MEM and PCG_MEMSW represent the respective charges and are transferred to the new page during migration. mem_cgroup_migrate() is suitable for replace_page_cache() as well, which gets rid of mem_cgroup_replace_page_cache(). However, care needs to be taken because both the source and the target page can already be charged and on the LRU when fuse is splicing: grab the page lock on the charge moving side to prevent changing pc->mem_cgroup of a page under migration. Also, the lruvecs of both pages change as we uncharge the old and charge the new during migration, and putback may race with us, so grab the lru lock and isolate the pages iff on LRU to prevent races and ensure the pages are on the right lruvec afterward. Swap accounting is massively simplified: because the page is no longer uncharged as early as swap cache deletion, a new mem_cgroup_swapout() can transfer the page's memory+swap charge (PCG_MEMSW) to the swap entry before the final put_page() in page reclaim. Finally, page_cgroup changes are now protected by whatever protection the page itself offers: anonymous pages are charged under the page table lock, whereas page cache insertions, swapin, and migration hold the page lock. Uncharging happens under full exclusion with no outstanding references. Charging and uncharging also ensure that the page is off-LRU, which serializes against charge migration. Remove the very costly page_cgroup lock and set pc->flags non-atomically. [mhocko@suse.cz: mem_cgroup_charge_statistics needs preempt_disable] [vdavydov@parallels.com: fix flags definition] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Tested-by: Jet Chen <jet.chen@intel.com> Acked-by: Michal Hocko <mhocko@suse.cz> Tested-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08mm: memcontrol: rewrite charge APIJohannes Weiner
These patches rework memcg charge lifetime to integrate more naturally with the lifetime of user pages. This drastically simplifies the code and reduces charging and uncharging overhead. The most expensive part of charging and uncharging is the page_cgroup bit spinlock, which is removed entirely after this series. Here are the top-10 profile entries of a stress test that reads a 128G sparse file on a freshly booted box, without even a dedicated cgroup (i.e. executing in the root memcg). Before: 15.36% cat [kernel.kallsyms] [k] copy_user_generic_string 13.31% cat [kernel.kallsyms] [k] memset 11.48% cat [kernel.kallsyms] [k] do_mpage_readpage 4.23% cat [kernel.kallsyms] [k] get_page_from_freelist 2.38% cat [kernel.kallsyms] [k] put_page 2.32% cat [kernel.kallsyms] [k] __mem_cgroup_commit_charge 2.18% kswapd0 [kernel.kallsyms] [k] __mem_cgroup_uncharge_common 1.92% kswapd0 [kernel.kallsyms] [k] shrink_page_list 1.86% cat [kernel.kallsyms] [k] __radix_tree_lookup 1.62% cat [kernel.kallsyms] [k] __pagevec_lru_add_fn After: 15.67% cat [kernel.kallsyms] [k] copy_user_generic_string 13.48% cat [kernel.kallsyms] [k] memset 11.42% cat [kernel.kallsyms] [k] do_mpage_readpage 3.98% cat [kernel.kallsyms] [k] get_page_from_freelist 2.46% cat [kernel.kallsyms] [k] put_page 2.13% kswapd0 [kernel.kallsyms] [k] shrink_page_list 1.88% cat [kernel.kallsyms] [k] __radix_tree_lookup 1.67% cat [kernel.kallsyms] [k] __pagevec_lru_add_fn 1.39% kswapd0 [kernel.kallsyms] [k] free_pcppages_bulk 1.30% cat [kernel.kallsyms] [k] kfree As you can see, the memcg footprint has shrunk quite a bit. text data bss dec hex filename 37970 9892 400 48262 bc86 mm/memcontrol.o.old 35239 9892 400 45531 b1db mm/memcontrol.o This patch (of 4): The memcg charge API charges pages before they are rmapped - i.e. have an actual "type" - and so every callsite needs its own set of charge and uncharge functions to know what type is being operated on. Worse, uncharge has to happen from a context that is still type-specific, rather than at the end of the page's lifetime with exclusive access, and so requires a lot of synchronization. Rewrite the charge API to provide a generic set of try_charge(), commit_charge() and cancel_charge() transaction operations, much like what's currently done for swap-in: mem_cgroup_try_charge() attempts to reserve a charge, reclaiming pages from the memcg if necessary. mem_cgroup_commit_charge() commits the page to the charge once it has a valid page->mapping and PageAnon() reliably tells the type. mem_cgroup_cancel_charge() aborts the transaction. This reduces the charge API and enables subsequent patches to drastically simplify uncharging. As pages need to be committed after rmap is established but before they are added to the LRU, page_add_new_anon_rmap() must stop doing LRU additions again. Revive lru_cache_add_active_or_unevictable(). [hughd@google.com: fix shmem_unuse] [hughd@google.com: Add comments on the private use of -EAGAIN] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06mm: change confusing #ifdef use in __access_remote_vmRik van Riel
This patch changes confusing #ifdef use in __access_remote_vm into merely ugly #ifdef use. Addresses bug https://bugzilla.kernel.org/show_bug.cgi?id=81651 Signed-off-by: Rik van Riel <riel@redhat.com> Reported-by: David Binderman <dcb314@hotmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06mm: mark fault_around_bytes __read_mostlyKirill A. Shutemov
fault_around_bytes can only be changed via debugfs. Let's mark it read-mostly. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Suggested-by: David Rientjes <rientjes@google.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06mm: close race between do_fault_around() and fault_around_bytes_set()Kirill A. Shutemov
Things can go wrong if fault_around_bytes will be changed under do_fault_around(): between fault_around_mask() and fault_around_pages(). Let's read fault_around_bytes only once during do_fault_around() and calculate mask based on the reading. Note: fault_around_bytes can only be updated via debug interface. Also I've tried but was not able to trigger a bad behaviour without the patch. So I would not consider this patch as urgent. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06mm: describe mmap_sem rules for __lock_page_or_retry() and callersPaul Cassella
Add a comment describing the circumstances in which __lock_page_or_retry() will or will not release the mmap_sem when returning 0. Add comments to lock_page_or_retry()'s callers (filemap_fault(), do_swap_page()) noting the impact on VM_FAULT_RETRY returns. Add comments on up the call tree, particularly replacing the false "We return with mmap_sem still held" comments. Signed-off-by: Paul Cassella <cassella@cray.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06mm/memory.c: don't forget to set softdirty on file mapped faultCyrill Gorcunov
Otherwise we may not notice that pte was softdirty because pte_mksoft_dirty helper _returns_ new pte but doesn't modify the argument. In case if page fault happend on dirty filemapping the newly created pte may loose softdirty bit thus if a userspace program is tracking memory changes with help of a memory tracker (CONFIG_MEM_SOFT_DIRTY) it might miss modification of a memory page (which in worts case may lead to data inconsistency). Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06mm: make copy_pte_range static againJerome Marchand
Commit 71e3aac0724f ("thp: transparent hugepage core") adds copy_pte_range prototype to huge_mm.h. I'm not sure why (or if) this function have been used outside of memory.c, but it currently isn't. This patch makes copy_pte_range() static again. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06mm/memory.c: use entry = ACCESS_ONCE(*pte) in handle_pte_fault()Hugh Dickins
Use ACCESS_ONCE() in handle_pte_fault() when getting the entry or orig_pte upon which all subsequent decisions and pte_same() tests will be made. I have no evidence that its lack is responsible for the mm/filemap.c:202 BUG_ON(page_mapped(page)) in __delete_from_page_cache() found by trinity, and I am not optimistic that it will fix it. But I have found no other explanation, and ACCESS_ONCE() here will surely not hurt. If gcc does re-access the pte before passing it down, then that would be disastrous for correct page fault handling, and certainly could explain the page_mapped() BUGs seen (concurrent fault causing page to be mapped in a second time on top of itself: mapcount 2 for a single pte). Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-30mm: debugfs: move rounddown_pow_of_two() out from do_fault pathAndrey Ryabinin
do_fault_around() expects fault_around_bytes rounded down to nearest page order. Instead of calling rounddown_pow_of_two every time in fault_around_pages()/fault_around_mask() we could do round down when user changes fault_around_bytes via debugfs interface. This also fixes bug when user set fault_around_bytes to 0. Result of rounddown_pow_of_two(0) is not defined, therefore fault_around_bytes == 0 doesn't work without this patch. Let's set fault_around_bytes to PAGE_SIZE if user sets to something less than PAGE_SIZE [akpm@linux-foundation.org: tweak code layout] Fixes: a9b0f861("mm: nominate faultaround area in bytes rather than page order") Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: <stable@vger.kernel.org> [3.15.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-07-23mm: do not call do_fault_around for non-linear faultKonstantin Khlebnikov
Ingo Korb reported that "repeated mapping of the same file on tmpfs using remap_file_pages sometimes triggers a BUG at mm/filemap.c:202 when the process exits". He bisected the bug to d7c1755179b8 ("mm: implement ->map_pages for shmem/tmpfs"), although the bug was actually added by commit 8c6e50b0290c ("mm: introduce vm_ops->map_pages()"). The problem is caused by calling do_fault_around for a _non-linear_ fault. In this case pgoff is shifted and might become negative during calculation. Faulting around non-linear page-fault makes no sense and breaks the logic in do_fault_around because pgoff is shifted. Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Reported-by: Ingo Korb <ingo.korb@tu-dortmund.de> Tested-by: Ingo Korb <ingo.korb@tu-dortmund.de> Cc: Hugh Dickins <hughd@google.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Dave Jones <davej@redhat.com> Cc: Ning Qu <quning@google.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: <stable@vger.kernel.org> [3.15.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04mm: document do_fault_around() featureKirill A. Shutemov
Some clarification on how faultaround works. [akpm@linux-foundation.org: tweak comment text] Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04mm: nominate faultaround area in bytes rather than page orderKirill A. Shutemov
There is evidencs that the faultaround feature is less relevant on architectures with page size bigger then 4k. Which makes sense since page fault overhead per byte of mapped area should be less there. Let's rework the feature to specify faultaround area in bytes instead of page order. It's 64 kilobytes for now. The patch effectively disables faultaround on architectures with page size >= 64k (like ppc64). It's possible that some other size of faultaround area is relevant for a platform. We can expose `fault_around_bytes' variable to arch-specific code once such platforms will be found. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Hugh Dickins <hughd@google.com> Cc: Madhavan Srinivasan <maddy@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Andi Kleen <ak@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Dave Hansen <dave.hansen@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04mm: fix typo in comment in do_fault_around()Kirill A. Shutemov
2014-06-04mm: move get_user_pages()-related code to separate fileKirill A. Shutemov
mm/memory.c is overloaded: over 4k lines. get_user_pages() code is pretty much self-contained let's move it to separate file. No other changes made. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04x86: define _PAGE_NUMA by reusing software bits on the PMD and PTE levelsMel Gorman
_PAGE_NUMA is currently an alias of _PROT_PROTNONE to trap NUMA hinting faults on x86. Care is taken such that _PAGE_NUMA is used only in situations where the VMA flags distinguish between NUMA hinting faults and prot_none faults. This decision was x86-specific and conceptually it is difficult requiring special casing to distinguish between PROTNONE and NUMA ptes based on context. Fundamentally, we only need the _PAGE_NUMA bit to tell the difference between an entry that is really unmapped and a page that is protected for NUMA hinting faults as if the PTE is not present then a fault will be trapped. Swap PTEs on x86-64 use the bits after _PAGE_GLOBAL for the offset. This patch shrinks the maximum possible swap size and uses the bit to uniquely distinguish between NUMA hinting ptes and swap ptes. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Anvin <hpa@zytor.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Noonan <steven@uplinklabs.net> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-22Merge tag 'v3.15-rc6' into sched/core, to pick up the latest fixesIngo Molnar
2014-05-07mm/numa: Remove BUG_ON() in __handle_mm_fault()Rik van Riel
Changing PTEs and PMDs to pte_numa & pmd_numa is done with the mmap_sem held for reading, which means a pmd can be instantiated and turned into a numa one while __handle_mm_fault() is examining the value of old_pmd. If that happens, __handle_mm_fault() should just return and let the page fault retry, instead of throwing an oops. This is handled by the test for pmd_trans_huge(*pmd) below. Signed-off-by: Rik van Riel <riel@redhat.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reported-by: Sunil Pandey <sunil.k.pandey@intel.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: linux-mm@kvack.org Cc: lwoodman@redhat.com Cc: dave.hansen@intel.com Link: http://lkml.kernel.org/r/20140429153615.2d72098e@annuminas.surriel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-25mm: split 'tlb_flush_mmu()' into tlb flushing and memory freeing partsLinus Torvalds
The mmu-gather operation 'tlb_flush_mmu()' has done two things: the actual tlb flush operation, and the batched freeing of the pages that the TLB entries pointed at. This splits the operation into separate phases, so that the forced batched flushing done by zap_pte_range() can now do the actual TLB flush while still holding the page table lock, but delay the batched freeing of all the pages to after the lock has been dropped. This in turn allows us to avoid a race condition between set_page_dirty() (as called by zap_pte_range() when it finds a dirty shared memory pte) and page_mkclean(): because we now flush all the dirty page data from the TLB's while holding the pte lock, page_mkclean() will be held up walking the (recently cleaned) page tables until after the TLB entries have been flushed from all CPU's. Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Tested-by: Dave Hansen <dave.hansen@intel.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Russell King - ARM Linux <linux@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-22mm: make fixup_user_fault() check the vma access rights tooLinus Torvalds
fixup_user_fault() is used by the futex code when the direct user access fails, and the futex code wants it to either map in the page in a usable form or return an error. It relied on handle_mm_fault() to map the page, and correctly checked the error return from that, but while that does map the page, it doesn't actually guarantee that the page will be mapped with sufficient permissions to be then accessed. So do the appropriate tests of the vma access rights by hand. [ Side note: arguably handle_mm_fault() could just do that itself, but we have traditionally done it in the caller, because some callers - notably get_user_pages() - have been able to access pages even when they are mapped with PROT_NONE. Maybe we should re-visit that design decision, but in the meantime this is the minimal patch. ] Found by Dave Jones running his trinity tool. Reported-by: Dave Jones <davej@redhat.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07mm: remove unused arg of set_page_dirty_balance()Miklos Szeredi
There's only one caller of set_page_dirty_balance() and that will call it with page_mkwrite == 0. The page_mkwrite argument was unused since commit b827e496c893 "mm: close page_mkwrite races". Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07memcg: rename high level charging functionsMichal Hocko
mem_cgroup_newpage_charge is used only for charging anonymous memory so it is better to rename it to mem_cgroup_charge_anon. mem_cgroup_cache_charge is used for file backed memory so rename it to mem_cgroup_charge_file. Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07mm: add debugfs tunable for fault_around_orderKirill A. Shutemov
Let's allow people to tweak faultaround at runtime. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Dave Chinner <david@fromorbit.com> Cc: Ning Qu <quning@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07mm: introduce vm_ops->map_pages()Kirill A. Shutemov
Here's new version of faultaround patchset. It took a while to tune it and collect performance data. First patch adds new callback ->map_pages to vm_operations_struct. ->map_pages() is called when VM asks to map easy accessible pages. Filesystem should find and map pages associated with offsets from "pgoff" till "max_pgoff". ->map_pages() is called with page table locked and must not block. If it's not possible to reach a page without blocking, filesystem should skip it. Filesystem should use do_set_pte() to setup page table entry. Pointer to entry associated with offset "pgoff" is passed in "pte" field in vm_fault structure. Pointers to entries for other offsets should be calculated relative to "pte". Currently VM use ->map_pages only on read page fault path. We try to map FAULT_AROUND_PAGES a time. FAULT_AROUND_PAGES is 16 for now. Performance data for different FAULT_AROUND_ORDER is below. TODO: - implement ->map_pages() for shmem/tmpfs; - modify get_user_pages() to be able to use ->map_pages() and implement mmap(MAP_POPULATE|MAP_NONBLOCK) on top. ========================================================================= Tested on 4-socket machine (120 threads) with 128GiB of RAM. Few real-world workloads. The sweet spot for FAULT_AROUND_ORDER here is somewhere between 3 and 5. Let's say 4 :) Linux build (make -j60) FAULT_AROUND_ORDER Baseline 1 3 4 5 7 9 minor-faults 283,301,572 247,151,987 212,215,789 204,772,882 199,568,944 194,703,779 193,381,485 time, seconds 151.227629483 153.920996480 151.356125472 150.863792049 150.879207877 151.150764954 151.450962358 Linux rebuild (make -j60) FAULT_AROUND_ORDER Baseline 1 3 4 5 7 9 minor-faults 5,396,854 4,148,444 2,855,286 2,577,282 2,361,957 2,169,573 2,112,643 time, seconds 27.404543757 27.559725591 27.030057426 26.855045126 26.678618635 26.974523490 26.761320095 Git test suite (make -j60 test) FAULT_AROUND_ORDER Baseline 1 3 4 5 7 9 minor-faults 129,591,823 99,200,751 66,106,718 57,606,410 51,510,808 45,776,813 44,085,515 time, seconds 66.087215026 64.784546905 64.401156567 65.282708668 66.034016829 66.793780811 67.237810413 Two synthetic tests: access every word in file in sequential/random order. It doesn't improve much after FAULT_AROUND_ORDER == 4. Sequential access 16GiB file FAULT_AROUND_ORDER Baseline 1 3 4 5 7 9 1 thread minor-faults 4,195,437 2,098,275 525,068 262,251 131,170 32,856 8,282 time, seconds 7.250461742 6.461711074 5.493859139 5.488488147 5.707213983 5.898510832 5.109232856 8 threads minor-faults 33,557,540 16,892,728 4,515,848 2,366,999 1,423,382 442,732 142,339 time, seconds 16.649304881 9.312555263 6.612490639 6.394316732 6.669827501 6.75078944 6.371900528 32 threads minor-faults 134,228,222 67,526,810 17,725,386 9,716,537 4,763,731 1,668,921 537,200 time, seconds 49.164430543 29.712060103 12.938649729 10.175151004 11.840094583 9.594081325 9.928461797 60 threads minor-faults 251,687,988 126,146,952 32,919,406 18,208,804 10,458,947 2,733,907 928,217 time, seconds 86.260656897 49.626551828 22.335007632 17.608243696 16.523119035 16.339489186 16.326390902 120 threads minor-faults 503,352,863 252,939,677 67,039,168 35,191,827 19,170,091 4,688,357 1,471,862 time, seconds 124.589206333 79.757867787 39.508707872 32.167281632 29.972989292 28.729834575 28.042251622 Random access 1GiB file 1 thread minor-faults 262,636 132,743 34,369 17,299 8,527 3,451 1,222 time, seconds 15.351890914 16.613802482 16.569227308 15.179220992 16.557356122 16.578247824 15.365266994 8 threads minor-faults 2,098,948 1,061,871 273,690 154,501 87,110 25,663 7,384 time, seconds 15.040026343 15.096933500 14.474757288 14.289129964 14.411537468 14.296316837 14.395635804 32 threads minor-faults 8,390,734 4,231,023 1,054,432 528,847 269,242 97,746 26,881 time, seconds 20.430433109 21.585235358 22.115062928 14.872878951 14.880856305 14.883370649 14.821261690 60 threads minor-faults 15,733,258 7,892,809 1,973,393 988,266 594,789 164,994 51,691 time, seconds 26.577302548 25.692397770 18.728863715 20.153026398 21.619101933 17.745086260 17.613215273 120 threads minor-faults 31,471,111 15,816,616 3,959,209 1,978,685 1,008,299 264,635 96,010 time, seconds 41.835322703 40.459786095 36.085306105 35.313894834 35.814445675 36.552633793 34.289210594 Touch only one page in page table in 16GiB file FAULT_AROUND_ORDER Baseline 1 3 4 5 7 9 1 thread minor-faults 8,372 8,324 8,270 8,260 8,249 8,239 8,237 time, seconds 0.039892712 0.045369149 0.051846126 0.063681685 0.079095975 0.17652406 0.541213386 8 threads minor-faults 65,731 65,681 65,628 65,620 65,608 65,599 65,596 time, seconds 0.124159196 0.488600638 0.156854426 0.191901957 0.242631486 0.543569456 1.677303984 32 threads minor-faults 262,388 262,341 262,285 262,276 262,266 262,257 263,183 time, seconds 0.452421421 0.488600638 0.565020946 0.648229739 0.789850823 1.651584361 5.000361559 60 threads minor-faults 491,822 491,792 491,723 491,711 491,701 491,691 491,825 time, seconds 0.763288616 0.869620515 0.980727360 1.161732354 1.466915814 3.04041448 9.308612938 120 threads minor-faults 983,466 983,655 983,366 983,372 983,363 984,083 984,164 time, seconds 1.595846553 1.667902182 2.008959376 2.425380942 2.941368804 5.977807890 18.401846125 This patch (of 2): Introduce new vm_ops callback ->map_pages() and uses it for mapping easy accessible pages around fault address. On read page fault, if filesystem provides ->map_pages(), we try to map up to FAULT_AROUND_PAGES pages around page fault address in hope to reduce number of minor page faults. We call ->map_pages first and use ->fault() as fallback if page by the offset is not ready to be mapped (cold page cache or something). Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Dave Chinner <david@fromorbit.com> Cc: Ning Qu <quning@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07mm/memory.c: update comment in unmap_single_vma()Davidlohr Bueso
The described issue now occurs inside mmap_region(). And unfortunately is still valid. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-04mm: get_user_pages(write,force) refuse to COW in shared areasHugh Dickins
get_user_pages(write=1, force=1) has always had odd behaviour on write- protected shared mappings: although it demands FMODE_WRITE-access to the underlying object (do_mmap_pgoff sets neither VM_SHARED nor VM_MAYWRITE without that), it ends up with do_wp_page substituting private anonymous Copied-On-Write pages for the shared file pages in the area. That was long ago intentional, as a safety measure to prevent ptrace setting a breakpoint (or POKETEXT or POKEDATA) from inadvertently corrupting the underlying executable. Yet exec and dynamic loaders open the file read-only, and use MAP_PRIVATE rather than MAP_SHARED. The traditional odd behaviour still causes surprises and bugs in mm, and is probably not what any caller wants - even the comment on the flag says "You do not want this" (although it's undoubtedly necessary for overriding userspace protections in some contexts, and good when !write). Let's stop doing that. But it would be dangerous to remove the long- standing safety at this stage, so just make get_user_pages(write,force) fail with EFAULT when applied to a write-protected shared area. Infiniband may in future want to force write through to underlying object: we can add another FOLL_flag later to enable that if required. Odd though the old behaviour was, there is no doubt that we may turn out to break userspace with this change, and have to revert it quickly. Issue a WARN_ON_ONCE to help debug the changed case (easily triggered by userspace, so only once to prevent spamming the logs); and delay a few associated cleanups until this change is proved. get_user_pages callers who might see trouble from this change: ptrace poking, or writing to /proc/<pid>/mem drivers/infiniband/ drivers/media/v4l2-core/ drivers/gpu/drm/exynos/exynos_drm_gem.c drivers/staging/tidspbridge/core/tiomap3430.c if they ever apply get_user_pages to write-protected shared mappings of an object which was opened for writing. I went to apply the same change to mm/nommu.c, but retreated. NOMMU has no place for COW, and its VM_flags conventions are not the same: I'd be more likely to screw up NOMMU than make an improvement there. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm: consolidate code to setup pteKirill A. Shutemov
Extract and consolidate code to setup pte from do_read_fault(), do_cow_fault() and do_shared_fault(). Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm: consolidate code to call vm_ops->page_mkwrite()Kirill A. Shutemov
There are two functions which need to call vm_ops->page_mkwrite(): do_shared_fault() and do_wp_page(). We can consolidate preparation code. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm: introduce do_shared_fault() and drop do_fault()Kirill A. Shutemov
Introduce do_shared_fault(). The function does what do_fault() does for write faults to shared mappings Unlike do_fault(), do_shared_fault() is relatively clean and straight-forward. Old do_fault() is not needed anymore. Let it die. [lliubbo@gmail.com: fix NULL pointer dereference] Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Bob Liu <bob.liu@oracle.com> Cc: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm: introduce do_cow_fault()Kirill A. Shutemov
Introduce do_cow_fault(). The function does what do_fault() does for write page faults to private mappings. Unlike do_fault(), do_read_fault() is relatively clean and straight-forward. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm: introduce do_read_fault()Kirill A. Shutemov
Introduce do_read_fault(). The function does what do_fault() does for read page faults. Unlike do_fault(), do_read_fault() is pretty clean and straightforward. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm: do_fault(): extract to call vm_ops->do_fault() to separate functionKirill A. Shutemov
Extract code to vm_ops->do_fault() and basic error handling to separate function. The code will be reused. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm: rename __do_fault() -> do_fault()Kirill A. Shutemov
Current __do_fault() is awful and unmaintainable. These patches try to sort it out by split __do_fault() into three destinct codepaths: - to handle read page fault; - to handle write page fault to private mappings; - to handle write page fault to shared mappings; I also found page refcount leak in PageHWPoison() path of __do_fault(). This patch (of 7): do_fault() is unused: no reason for underscores. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm/memory.c: mark functions as staticRashika Kheria
mark functions as static in memory.c because they are not used outside this file. This eliminates the following warnings in mm/memory.c: mm/memory.c:3530:5: warning: no previous prototype for `numa_migrate_prep' [-Wmissing-prototypes] mm/memory.c:3545:5: warning: no previous prototype for `do_numa_page' [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-25mm, thp: fix infinite loop on memcg OOMKirill A. Shutemov
Masayoshi Mizuma reported a bug with the hang of an application under the memcg limit. It happens on write-protection fault to huge zero page If we successfully allocate a huge page to replace zero page but hit the memcg limit we need to split the zero page with split_huge_page_pmd() and fallback to small pages. The other part of the problem is that VM_FAULT_OOM has special meaning in do_huge_pmd_wp_page() context. __handle_mm_fault() expects the page to be split if it sees VM_FAULT_OOM and it will will retry page fault handling. This causes an infinite loop if the page was not split. do_huge_pmd_wp_zero_page_fallback() can return VM_FAULT_OOM if it failed to allocate one small page, so fallback to small pages will not help. The solution for this part is to replace VM_FAULT_OOM with VM_FAULT_FALLBACK is fallback required. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reported-by: Masayoshi Mizuma <m.mizuma@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-25mm, hwpoison: release page on PageHWPoison() in __do_fault()Kirill A. Shutemov
It seems we forget to release page after detecting HW error. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23mm: dump page when hitting a VM_BUG_ON using VM_BUG_ON_PAGESasha Levin
Most of the VM_BUG_ON assertions are performed on a page. Usually, when one of these assertions fails we'll get a BUG_ON with a call stack and the registers. I've recently noticed based on the requests to add a small piece of code that dumps the page to various VM_BUG_ON sites that the page dump is quite useful to people debugging issues in mm. This patch adds a VM_BUG_ON_PAGE(cond, page) which beyond doing what VM_BUG_ON() does, also dumps the page before executing the actual BUG_ON. [akpm@linux-foundation.org: fix up includes] Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23mm: print more details for bad_page()Dave Hansen
bad_page() is cool in that it prints out a bunch of data about the page. But, I can never remember which page flags are good and which are bad, or whether ->index or ->mapping is required to be NULL. This patch allows bad/dump_page() callers to specify a string about why they are dumping the page and adds explanation strings to a number of places. It also adds a 'bad_flags' argument to bad_page(), which it then dumps out separately from the flags which are actually set. This way, the messages will show specifically why the page was bad, *specifically* which flags it is complaining about, if it was a page flag combination which was the problem. [akpm@linux-foundation.org: switch to pr_alert] Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Reviewed-by: Christoph Lameter <cl@linux.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm: create a separate slab for page->ptl allocationKirill A. Shutemov
If DEBUG_SPINLOCK and DEBUG_LOCK_ALLOC are enabled spinlock_t on x86_64 is 72 bytes. For page->ptl they will be allocated from kmalloc-96 slab, so we loose 24 on each. An average system can easily allocate few tens thousands of page->ptl and overhead is significant. Let's create a separate slab for page->ptl allocation to solve this. To make sure that it really works this time, some numbers from my test machine (just booted, no load): Before: # grep '^\(kmalloc-96\|page->ptl\)' /proc/slabinfo kmalloc-96 31987 32190 128 30 1 : tunables 120 60 8 : slabdata 1073 1073 92 After: # grep '^\(kmalloc-96\|page->ptl\)' /proc/slabinfo page->ptl 27516 28143 72 53 1 : tunables 120 60 8 : slabdata 531 531 9 kmalloc-96 3853 5280 128 30 1 : tunables 120 60 8 : slabdata 176 176 0 Note that the patch is useful not only for debug case, but also for PREEMPT_RT, where spinlock_t is always bloated. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21dma-debug: introduce debug_dma_assert_idle()Dan Williams
Record actively mapped pages and provide an api for asserting a given page is dma inactive before execution proceeds. Placing debug_dma_assert_idle() in cow_user_page() flagged the violation of the dma-api in the NET_DMA implementation (see commit 77873803363c "net_dma: mark broken"). The implementation includes the capability to count, in a limited way, repeat mappings of the same page that occur without an intervening unmap. This 'overlap' counter is limited to the few bits of tag space in a radix tree. This mechanism is added to mitigate false negative cases where, for example, a page is dma mapped twice and debug_dma_assert_idle() is called after the page is un-mapped once. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-20mm: fix build of split ptlock codeOlof Johansson
Commit 597d795a2a78 ('mm: do not allocate page->ptl dynamically, if spinlock_t fits to long') restructures some allocators that are compiled even if USE_SPLIT_PTLOCKS arn't used. It results in compilation failure: mm/memory.c:4282:6: error: 'struct page' has no member named 'ptl' mm/memory.c:4288:12: error: 'struct page' has no member named 'ptl' Add in the missing ifdef. Fixes: 597d795a2a78 ('mm: do not allocate page->ptl dynamically, if spinlock_t fits to long') Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-20mm: do not allocate page->ptl dynamically, if spinlock_t fits to longKirill A. Shutemov
In struct page we have enough space to fit long-size page->ptl there, but we use dynamically-allocated page->ptl if size(spinlock_t) is larger than sizeof(int). It hurts 64-bit architectures with CONFIG_GENERIC_LOCKBREAK, where sizeof(spinlock_t) == 8, but it easily fits into struct page. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-20Revert "mm: create a separate slab for page->ptl allocation"Linus Torvalds
This reverts commit ea1e7ed33708c7a760419ff9ded0a6cb90586a50. Al points out that while the commit *does* actually create a separate slab for the page->ptl allocation, that slab is never actually used, and the code continues to use kmalloc/kfree. Damien Wyart points out that the original patch did have the conversion to use kmem_cache_alloc/free, so it got lost somewhere on its way to me. Revert the half-arsed attempt that didn't do anything. If we really do want the special slab (remember: this is all relevant just for debug builds, so it's not necessarily all that critical) we might as well redo the patch fully. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Andrew Morton <akpm@linux-foundation.org> Cc: Kirill A Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-15mm: create a separate slab for page->ptl allocationKirill A. Shutemov
If DEBUG_SPINLOCK and DEBUG_LOCK_ALLOC are enabled spinlock_t on x86_64 is 72 bytes. For page->ptl they will be allocated from kmalloc-96 slab, so we loose 24 on each. An average system can easily allocate few tens thousands of page->ptl and overhead is significant. Let's create a separate slab for page->ptl allocation to solve this. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-15mm: properly separate the bloated ptl from the regular casePeter Zijlstra
Use kernel/bounds.c to convert build-time spinlock_t size check into a preprocessor symbol and apply that to properly separate the page::ptl situation. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
