path: root/mm/memcontrol.c
2009-01-08cgroups: use hierarchy_mutex in memory controllerPaul Menage
Update the memory controller to use its hierarchy_mutex rather than calling cgroup_lock() to protected against cgroup_mkdir()/cgroup_rmdir() from occurring in its hierarchy. Signed-off-by: Paul Menage <menage@google.com> Tested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: fix shmem's swap accountingKAMEZAWA Hiroyuki
Now, you can see following even when swap accounting is enabled. 1. Create Group 01, and 02. 2. allocate a "file" on tmpfs by a task under 01. 3. swap out the "file" (by memory pressure) 4. Read "file" from a task in group 02. 5. the charge of "file" is moved to group 02. This is not ideal behavior. This is because SwapCache which was loaded by read-ahead is not taken into account.. This is a patch to fix shmem's swapcache behavior. - remove mem_cgroup_cache_charge_swapin(). - Add SwapCache handler routine to mem_cgroup_cache_charge(). By this, shmem's file cache is charged at add_to_page_cache() with GFP_NOWAIT. - pass the page of swapcache to shrink_mem_cgroup. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: fix LRU accounting for SwapCacheKAMEZAWA Hiroyuki
Now, a page can be deleted from SwapCache while do_swap_page(). memcg-fix-swap-accounting-leak-v3.patch handles that, but, LRU handling is still broken. (above behavior broke assumption of memcg-synchronized-lru patch.) This patch is a fix for LRU handling (especially for per-zone counters). At charging SwapCache, - Remove page_cgroup from LRU if it's not used. - Add page cgroup to LRU if it's not linked to. Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: use css_tryget in memcgKAMEZAWA Hiroyuki
From:KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> css_tryget() newly is added and we can know css is alive or not and get refcnt of css in very safe way. ("alive" here means "rmdir/destroy" is not called.) This patch replaces css_get() to css_tryget(), where I cannot explain why css_get() is safe. And removes memcg->obsolete flag. Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: fix double free and make refcnt saneKAMEZAWA Hiroyuki
1. Fix double-free BUG in error route of mem_cgroup_create(). mem_cgroup_free() itself frees per-zone-info. 2. Making refcnt of memcg simple. Add 1 refcnt at creation and call free when refcnt goes down to 0. Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: fix swap accounting leakKAMEZAWA Hiroyuki
Fix swapin charge operation of memcg. Now, memcg has hooks to swap-out operation and checks SwapCache is really unused or not. That check depends on contents of struct page. I.e. If PageAnon(page) && page_mapped(page), the page is recoginized as still-in-use. Now, reuse_swap_page() calles delete_from_swap_cache() before establishment of any rmap. Then, in followinig sequence (Page fault with WRITE) try_charge() (charge += PAGESIZE) commit_charge() (Check page_cgroup is used or not..) reuse_swap_page() -> delete_from_swapcache() -> mem_cgroup_uncharge_swapcache() (charge -= PAGESIZE) ...... New charge is uncharged soon.... To avoid this, move commit_charge() after page_mapcount() goes up to 1. By this, try_charge() (usage += PAGESIZE) reuse_swap_page() (may usage -= PAGESIZE if PCG_USED is set) commit_charge() (If page_cgroup is not marked as PCG_USED, add new charge.) Accounting will be correct. Changelog (v2) -> (v3) - fixed invalid charge to swp_entry==0. - updated documentation. Changelog (v1) -> (v2) - fixed comment. [nishimura@mxp.nes.nec.co.jp: swap accounting leak doc fix] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Tested-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: change try_to_free_pages to hierarchical_reclaimDaisuke Nishimura
mem_cgroup_hierarchicl_reclaim() works properly even when !use_hierarchy now (by memcg-hierarchy-avoid-unnecessary-reclaim.patch), so, instead of try_to_free_mem_cgroup_pages(), it should be used in many cases. The only exception is force_empty. The group has no children in this case. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: avoid deadlock caused by race between oom and cpuset_attachDaisuke Nishimura
mpol_rebind_mm(), which can be called from cpuset_attach(), does down_write(mm->mmap_sem). This means down_write(mm->mmap_sem) can be called under cgroup_mutex. OTOH, page fault path does down_read(mm->mmap_sem) and calls mem_cgroup_try_charge_xxx(), which may eventually calls mem_cgroup_out_of_memory(). And mem_cgroup_out_of_memory() calls cgroup_lock(). This means cgroup_lock() can be called under down_read(mm->mmap_sem). If those two paths race, deadlock can happen. This patch avoid this deadlock by: - remove cgroup_lock() from mem_cgroup_out_of_memory(). - define new mutex (memcg_tasklist) and serialize mem_cgroup_move_task() (->attach handler of memory cgroup) and mem_cgroup_out_of_memory. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: remove mem_cgroup_try_chargeDaisuke Nishimura
After previous patch, mem_cgroup_try_charge is not used by anyone, so we can remove it. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: don't trigger oom at page migrationDaisuke Nishimura
I think triggering OOM at mem_cgroup_prepare_migration would be just a bit overkill. Returning -ENOMEM would be enough for mem_cgroup_prepare_migration. The caller would handle the case anyway. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: show real limit under hierarchy modeKAMEZAWA Hiroyuki
Show "real" limit of memcg. This helps my debugging and maybe useful for users. While testing hierarchy like this mount -t cgroup none /cgroup -t memory mkdir /cgroup/A set use_hierarchy==1 to "A" mkdir /cgroup/A/01 mkdir /cgroup/A/01/02 mkdir /cgroup/A/01/03 mkdir /cgroup/A/01/03/04 mkdir /cgroup/A/08 mkdir /cgroup/A/08/01 .... and set each own limit to them, "real" limit of each memcg is unclear. This patch shows real limit by checking all ancestors. Changelog: (v1) -> (v2) - remove "if" and use "min(a,b)" Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: fix calculation of active_ratioKOSAKI Motohiro
Currently, inactive_ratio of memcg is calculated at setting limit. because page_alloc.c does so and current implementation is straightforward porting. However, memcg introduced hierarchy feature recently. In hierarchy restriction, memory limit is not only decided memory.limit_in_bytes of current cgroup, but also parent limit and sibling memory usage. Then, The optimal inactive_ratio is changed frequently. So, everytime calculation is better. Tested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: swappinessKOSAKI Motohiro
Currently, /proc/sys/vm/swappiness can change swappiness ratio for global reclaim. However, memcg reclaim doesn't have tuning parameter for itself. In general, the optimal swappiness depend on workload. (e.g. hpc workload need to low swappiness than the others.) Then, per cgroup swappiness improve administrator tunability. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: protect prev_priorityKOSAKI Motohiro
Currently, mem_cgroup doesn't have own lock and almost its member doesn't need. (e.g. mem_cgroup->info is protected by zone lock, mem_cgroup->stat is per cpu variable) However, there is one explict exception. mem_cgroup->prev_priorit need lock, but doesn't protect. Luckly, this is NOT bug because prev_priority isn't used for current reclaim code. However, we plan to use prev_priority future again. Therefore, fixing is better. In addition, we plan to reuse this lock for another member. Then "reclaim_param_lock" name is better than "prev_priority_lock". Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: show reclaim statKOSAKI Motohiro
Add the following four fields to memory.stat file: - inactive_ratio - recent_rotated_anon - recent_rotated_file - recent_scanned_anon - recent_scanned_file Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: remove mem_cgroup_cal_reclaim()KOSAKI Motohiro
Now, get_scan_ratio() return correct value although memcg reclaim. Then, mem_cgroup_calc_reclaim() can be removed. So, memcg reclaim get the same capability of anon/file reclaim balancing as global reclaim now. Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: add zone_reclaim_statKOSAKI Motohiro
Introduce mem_cgroup_per_zone::reclaim_stat member and its statics collecting function. Now, get_scan_ratio() can calculate correct value on memcg reclaim. [hugh@veritas.com: avoid reclaim_stat oops when disabled] Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: add mem_cgroup_zone_nr_pages()KOSAKI Motohiro
Introduce mem_cgroup_zone_nr_pages(). It is called by zone_nr_pages() helper function. This patch doesn't have any behavior change. Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: add inactive_anon_is_low()KOSAKI Motohiro
The inactive_anon_is_low() is key component of active/inactive anon balancing on reclaim. However current inactive_anon_is_low() function only consider global reclaim. Therefore, we need following ugly scan_global_lru() condition. if (lru == LRU_ACTIVE_ANON && (!scan_global_lru(sc) || inactive_anon_is_low(zone))) { shrink_active_list(nr_to_scan, zone, sc, priority, file); return 0; it cause that memcg reclaim always deactivate pages when shrink_list() is called. To make mem_cgroup_inactive_anon_is_low() improve active/inactive anon balancing of memcgroup. Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: "Pekka Enberg" <penberg@cs.helsinki.fi> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: add null check to page_cgroup_zoneinfo()KOSAKI Motohiro
If CONFIG_CGROUP_MEM_RES_CTLR_SWAP=y, page_cgroup::mem_cgroup can be NULL. Therefore null checking is better. A later patch uses this function. Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: hierarchy avoid unnecessary reclaimDaisuke Nishimura
If hierarchy is not used, no tree-walk is necessary. Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: swapout refcnt fixKAMEZAWA Hiroyuki
css's refcnt is dropped before end of following access. Hold it until end of access. Reported-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: memory swap controller: fix limit checkDaisuke Nishimura
There are scatterd calls of res_counter_check_under_limit(), and most of them don't take mem+swap accounting into account. define mem_cgroup_check_under_limit() and avoid direct use of res_counter_check_limit(). Reported-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: check group leader fixNikanth Karthikesan
Remove unnecessary codes (...fragments of not-implemented functionalilty...) Reported-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: revert gfp mask fixKAMEZAWA Hiroyuki
My patch, memcg-fix-gfp_mask-of-callers-of-charge.patch changed gfp_mask of callers of charge to be GFP_HIGHUSER_MOVABLE for showing what will happen at memory reclaim. But in recent discussion, it's NACKed because it sounds ugly. This patch is for reverting it and add some clean up to gfp_mask of callers of charge. No behavior change but need review before generating HUNK in deep queue. This patch also adds explanation to meaning of gfp_mask passed to charge functions in memcontrol.h. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: fix reclaim result checksKAMEZAWA Hiroyuki
check_under_limit logic was wrong and this check should be against mem_over_limit rather than mem. Reported-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Jan Blunck <jblunck@suse.de> Cc: Hirokazu Takahashi <taka@valinux.co.jp> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: avoid unnecessary system-wide-oom-killerKAMEZAWA Hiroyuki
Current mmtom has new oom function as pagefault_out_of_memory(). It's added for select bad process rathar than killing current. When memcg hit limit and calls OOM at page_fault, this handler called and system-wide-oom handling happens. (means kernel panics if panic_on_oom is true....) To avoid overkill, check memcg's recent behavior before starting system-wide-oom. And this patch also fixes to guarantee "don't accnout against process with TIF_MEMDIE". This is necessary for smooth OOM. [akpm@linux-foundation.org: build fix] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Jan Blunck <jblunck@suse.de> Cc: Hirokazu Takahashi <taka@valinux.co.jp> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: memory cgroup hierarchy feature selectorBalbir Singh
Don't enable multiple hierarchy support by default. This patch introduces a features element that can be set to enable the nested depth hierarchy feature. This feature can only be enabled when the cgroup for which the feature this is enabled, has no children. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: memory cgroup hierarchical reclaimBalbir Singh
This patch introduces hierarchical reclaim. When an ancestor goes over its limit, the charging routine points to the parent that is above its limit. The reclaim process then starts from the last scanned child of the ancestor and reclaims until the ancestor goes below its limit. [akpm@linux-foundation.org: coding-style fixes] [d-nishimura@mtf.biglobe.ne.jp: mem_cgroup_from_res_counter should handle both mem->res and mem->memsw] Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: memory cgroup resource counters for hierarchyBalbir Singh
Add support for building hierarchies in resource counters. Cgroups allows us to build a deep hierarchy, but we currently don't link the resource counters belonging to the memory controller control groups, in the same fashion as the corresponding cgroup entries in the cgroup hierarchy. This patch provides the infrastructure for resource counters that have the same hiearchy as their cgroup counter parts. These set of patches are based on the resource counter hiearchy patches posted by Pavel Emelianov. NOTE: Building hiearchies is expensive, deeper hierarchies imply charging the all the way up to the root. It is known that hiearchies are expensive, so the user needs to be careful and aware of the trade-offs before creating very deep ones. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: add mem_cgroup_disabled()Hirokazu Takahashi
We check mem_cgroup is disabled or not by checking mem_cgroup_subsys.disabled. I think it has more references than expected, now. replacing if (mem_cgroup_subsys.disabled) with if (mem_cgroup_disabled()) give us good look, I think. [kamezawa.hiroyu@jp.fujitsu.com: fix typo] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: synchronized LRUKAMEZAWA Hiroyuki
A big patch for changing memcg's LRU semantics. Now, - page_cgroup is linked to mem_cgroup's its own LRU (per zone). - LRU of page_cgroup is not synchronous with global LRU. - page and page_cgroup is one-to-one and statically allocated. - To find page_cgroup is on what LRU, you have to check pc->mem_cgroup as - lru = page_cgroup_zoneinfo(pc, nid_of_pc, zid_of_pc); - SwapCache is handled. And, when we handle LRU list of page_cgroup, we do following. pc = lookup_page_cgroup(page); lock_page_cgroup(pc); .....................(1) mz = page_cgroup_zoneinfo(pc); spin_lock(&mz->lru_lock); .....add to LRU spin_unlock(&mz->lru_lock); unlock_page_cgroup(pc); But (1) is spin_lock and we have to be afraid of dead-lock with zone->lru_lock. So, trylock() is used at (1), now. Without (1), we can't trust "mz" is correct. This is a trial to remove this dirty nesting of locks. This patch changes mz->lru_lock to be zone->lru_lock. Then, above sequence will be written as spin_lock(&zone->lru_lock); # in vmscan.c or swap.c via global LRU mem_cgroup_add/remove/etc_lru() { pc = lookup_page_cgroup(page); mz = page_cgroup_zoneinfo(pc); if (PageCgroupUsed(pc)) { ....add to LRU } spin_lock(&zone->lru_lock); # in vmscan.c or swap.c via global LRU This is much simpler. (*) We're safe even if we don't take lock_page_cgroup(pc). Because.. 1. When pc->mem_cgroup can be modified. - at charge. - at account_move(). 2. at charge the PCG_USED bit is not set before pc->mem_cgroup is fixed. 3. at account_move() the page is isolated and not on LRU. Pros. - easy for maintenance. - memcg can make use of laziness of pagevec. - we don't have to duplicated LRU/Active/Unevictable bit in page_cgroup. - LRU status of memcg will be synchronized with global LRU's one. - # of locks are reduced. - account_move() is simplified very much. Cons. - may increase cost of LRU rotation. (no impact if memcg is not configured.) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: mem+swap controller coreKAMEZAWA Hiroyuki
This patch implements per cgroup limit for usage of memory+swap. However there are SwapCache, double counting of swap-cache and swap-entry is avoided. Mem+Swap controller works as following. - memory usage is limited by memory.limit_in_bytes. - memory + swap usage is limited by memory.memsw_limit_in_bytes. This has following benefits. - A user can limit total resource usage of mem+swap. Without this, because memory resource controller doesn't take care of usage of swap, a process can exhaust all the swap (by memory leak.) We can avoid this case. And Swap is shared resource but it cannot be reclaimed (goes back to memory) until it's used. This characteristic can be trouble when the memory is divided into some parts by cpuset or memcg. Assume group A and group B. After some application executes, the system can be.. Group A -- very large free memory space but occupy 99% of swap. Group B -- under memory shortage but cannot use swap...it's nearly full. Ability to set appropriate swap limit for each group is required. Maybe someone wonder "why not swap but mem+swap ?" - The global LRU(kswapd) can swap out arbitrary pages. Swap-out means to move account from memory to swap...there is no change in usage of mem+swap. In other words, when we want to limit the usage of swap without affecting global LRU, mem+swap limit is better than just limiting swap. Accounting target information is stored in swap_cgroup which is per swap entry record. Charge is done as following. map - charge page and memsw. unmap - uncharge page/memsw if not SwapCache. swap-out (__delete_from_swap_cache) - uncharge page - record mem_cgroup information to swap_cgroup. swap-in (do_swap_page) - charged as page and memsw. record in swap_cgroup is cleared. memsw accounting is decremented. swap-free (swap_free()) - if swap entry is freed, memsw is uncharged by PAGE_SIZE. There are people work under never-swap environments and consider swap as something bad. For such people, this mem+swap controller extension is just an overhead. This overhead is avoided by config or boot option. (see Kconfig. detail is not in this patch.) TODO: - maybe more optimization can be don in swap-in path. (but not very safe.) But we just do simple accounting at this stage. [nishimura@mxp.nes.nec.co.jp: make resize limit hold mutex] [hugh@veritas.com: memswap controller core swapcache fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: mem+swap controller KconfigKAMEZAWA Hiroyuki
Config and control variable for mem+swap controller. This patch adds CONFIG_CGROUP_MEM_RES_CTLR_SWAP (memory resource controller swap extension.) For accounting swap, it's obvious that we have to use additional memory to remember "who uses swap". This adds more overhead. So, it's better to offer "choice" to users. This patch adds 2 choices. This patch adds 2 parameters to enable swap extension or not. - CONFIG - boot option Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: handle swap cachesKAMEZAWA Hiroyuki
SwapCache support for memory resource controller (memcg) Before mem+swap controller, memcg itself should handle SwapCache in proper way. This is cut-out from it. In current memcg, SwapCache is just leaked and the user can create tons of SwapCache. This is a leak of account and should be handled. SwapCache accounting is done as following. charge (anon) - charged when it's mapped. (because of readahead, charge at add_to_swap_cache() is not sane) uncharge (anon) - uncharged when it's dropped from swapcache and fully unmapped. means it's not uncharged at unmap. Note: delete from swap cache at swap-in is done after rmap information is established. charge (shmem) - charged at swap-in. this prevents charge at add_to_page_cache(). uncharge (shmem) - uncharged when it's dropped from swapcache and not on shmem's radix-tree. at migration, check against 'old page' is modified to handle shmem. Comparing to the old version discussed (and caused troubles), we have advantages of - PCG_USED bit. - simple migrating handling. So, situation is much easier than several months ago, maybe. [hugh@veritas.com: memcg: handle swap caches build fix] Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: new force_empty to free pages under groupKAMEZAWA Hiroyuki
By memcg-move-all-accounts-to-parent-at-rmdir.patch, there is no leak of memory usage and force_empty is removed. This patch adds "force_empty" again, in reasonable manner. memory.force_empty file works when #echo 0 (or some) > memory.force_empty and have following function. 1. only works when there are no task in this cgroup. 2. free all page under this cgroup as much as possible. 3. page which cannot be freed will be moved up to parent. 4. Then, memcg will be empty after above echo returns. This is much better behavior than old "force_empty" which just forget all accounts. This patch also check signal_pending() and above "echo" can be stopped by "Ctrl-C". [akpm@linux-foundation.org: cleanup] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: reduce size of mem_cgroup by using nr_cpu_idsJan Blunck
As Jan Blunck <jblunck@suse.de> pointed out, allocating per-cpu stat for memcg to the size of NR_CPUS is not good. This patch changes mem_cgroup's cpustat allocation not based on NR_CPUS but based on nr_cpu_ids. Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: move all acccounting to parent at rmdir()KAMEZAWA Hiroyuki
This patch provides a function to move account information of a page between mem_cgroups and rewrite force_empty to make use of this. This moving of page_cgroup is done under - lru_lock of source/destination mem_cgroup is held. - lock_page_cgroup() is held. Then, a routine which touches pc->mem_cgroup without lock_page_cgroup() should confirm pc->mem_cgroup is still valid or not. Typical code can be following. (while page is not under lock_page()) mem = pc->mem_cgroup; mz = page_cgroup_zoneinfo(pc) spin_lock_irqsave(&mz->lru_lock); if (pc->mem_cgroup == mem) ...../* some list handling */ spin_unlock_irqrestore(&mz->lru_lock); Of course, better way is lock_page_cgroup(pc); .... unlock_page_cgroup(pc); But you should confirm the nest of lock and avoid deadlock. If you treats page_cgroup from mem_cgroup's LRU under mz->lru_lock, you don't have to worry about what pc->mem_cgroup points to. moved pages are added to head of lru, not to tail. Expected users of this routine is: - force_empty (rmdir) - moving tasks between cgroup (for moving account information.) - hierarchy (maybe useful.) force_empty(rmdir) uses this move_account and move pages to its parent. This "move" will not cause OOM (I added "oom" parameter to try_charge().) If the parent is busy (not enough memory), force_empty calls try_to_free_page() and reduce usage. Purpose of this behavior is - Fix "forget all" behavior of force_empty and avoid leak of accounting. - By "moving first, free if necessary", keep pages on memory as much as possible. Adding a switch to change behavior of force_empty to - free first, move if necessary - free all, if there is mlocked/busy pages, return -EBUSY. is under consideration. (I'll add if someone requtests.) This patch also removes memory.force_empty file, a brutal debug-only interface. Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: simple migration handlingKAMEZAWA Hiroyuki
Now, management of "charge" under page migration is done under following manner. (Assume migrate page contents from oldpage to newpage) before - "newpage" is charged before migration. at success. - "oldpage" is uncharged at somewhere(unmap, radix-tree-replace) at failure - "newpage" is uncharged. - "oldpage" is charged if necessary (*1) But (*1) is not reliable....because of GFP_ATOMIC. This patch tries to change behavior as following by charge/commit/cancel ops. before - charge PAGE_SIZE (no target page) success - commit charge against "newpage". failure - commit charge against "oldpage". (PCG_USED bit works effectively to avoid double-counting) - if "oldpage" is obsolete, cancel charge of PAGE_SIZE. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: fix gfp_mask of callers of chargeKAMEZAWA Hiroyuki
Fix misuse of gfp_kernel. Now, most of callers of mem_cgroup_charge_xxx functions uses GFP_KERNEL. I think that this is from the fact that page_cgroup *was* dynamically allocated. But now, we allocate all page_cgroup at boot. And mem_cgroup_try_to_free_pages() reclaim memory from GFP_HIGHUSER_MOVABLE + specified GFP_RECLAIM_MASK. * This is because we just want to reduce memory usage. "Where we should reclaim from ?" is not a problem in memcg. This patch modifies gfp masks to be GFP_HIGUSER_MOVABLE if possible. Note: This patch is not for fixing behavior but for showing sane information in source code. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: introduce charge-commit-cancel style of functionsKAMEZAWA Hiroyuki
There is a small race in do_swap_page(). When the page swapped-in is charged, the mapcount can be greater than 0. But, at the same time some process (shares it ) call unmap and make mapcount 1->0 and the page is uncharged. CPUA CPUB mapcount == 1. (1) charge if mapcount==0 zap_pte_range() (2) mapcount 1 => 0. (3) uncharge(). (success) (4) set page's rmap() mapcount 0=>1 Then, this swap page's account is leaked. For fixing this, I added a new interface. - charge account to res_counter by PAGE_SIZE and try to free pages if necessary. - commit register page_cgroup and add to LRU if necessary. - cancel uncharge PAGE_SIZE because of do_swap_page failure. CPUA (1) charge (always) (2) set page's rmap (mapcount > 0) (3) commit charge was necessary or not after set_pte(). This protocol uses PCG_USED bit on page_cgroup for avoiding over accounting. Usual mem_cgroup_charge_common() does charge -> commit at a time. And this patch also adds following function to clarify all charges. - mem_cgroup_newpage_charge() ....replacement for mem_cgroup_charge() called against newly allocated anon pages. - mem_cgroup_charge_migrate_fixup() called only from remove_migration_ptes(). we'll have to rewrite this later.(this patch just keeps old behavior) This function will be removed by additional patch to make migration clearer. Good for clarifying "what we do" Then, we have 4 following charge points. - newpage - swap-in - add-to-cache. - migration. [akpm@linux-foundation.org: add missing inline directives to stubs] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: make mem_cgroup_resize_limit() staticKOSAKI Motohiro
Sparse output following warnings. mm/memcontrol.c:782:5: warning: symbol 'mem_cgroup_resize_limit' was not declared. Should it be static? cleanup here. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23memcg: fix page_cgroup allocationKAMEZAWA Hiroyuki
page_cgroup_init() is called from mem_cgroup_init(). But at this point, we cannot call alloc_bootmem(). (and this caused panic at boot.) This patch moves page_cgroup_init() to init/main.c. Time table is following: == parse_args(). # we can trust mem_cgroup_subsys.disabled bit after this. .... cgroup_init_early() # "early" init of cgroup. .... setup_arch() # memmap is allocated. ... page_cgroup_init(); mem_init(); # we cannot call alloc_bootmem after this. .... cgroup_init() # mem_cgroup is initialized. == Before page_cgroup_init(), mem_map must be initialized. So, I added page_cgroup_init() to init/main.c directly. (*) maybe this is not very clean but - cgroup_init_early() is too early - in cgroup_init(), we have to use vmalloc instead of alloc_bootmem(). use of vmalloc area in x86-32 is important and we should avoid very large vmalloc() in x86-32. So, we want to use alloc_bootmem() and added page_cgroup_init() directly to init/main.c [akpm@linux-foundation.org: remove unneeded/bad mem_cgroup_subsys declaration] [akpm@linux-foundation.org: fix build] Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Tested-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20memcg: allocate all page_cgroup at bootKAMEZAWA Hiroyuki
Allocate all page_cgroup at boot and remove page_cgroup poitner from struct page. This patch adds an interface as struct page_cgroup *lookup_page_cgroup(struct page*) All FLATMEM/DISCONTIGMEM/SPARSEMEM and MEMORY_HOTPLUG is supported. Remove page_cgroup pointer reduces the amount of memory by - 4 bytes per PAGE_SIZE. - 8 bytes per PAGE_SIZE if memory controller is disabled. (even if configured.) On usual 8GB x86-32 server, this saves 8MB of NORMAL_ZONE memory. On my x86-64 server with 48GB of memory, this saves 96MB of memory. I think this reduction makes sense. By pre-allocation, kmalloc/kfree in charge/uncharge are removed. This means - we're not necessary to be afraid of kmalloc faiulre. (this can happen because of gfp_mask type.) - we can avoid calling kmalloc/kfree. - we can avoid allocating tons of small objects which can be fragmented. - we can know what amount of memory will be used for this extra-lru handling. I added printk message as "allocated %ld bytes of page_cgroup" "please try cgroup_disable=memory option if you don't want" maybe enough informative for users. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20memcg: atomic ops for page_cgroup->flagsKAMEZAWA Hiroyuki
This patch makes page_cgroup->flags to be atomic_ops and define functions (and macros) to access it. Before trying to modify memory resource controller, this atomic operation on flags is necessary. Most of flags in this patch is for LRU and modfied under mz->lru_lock but we'll add another flags which is not for LRU soon. For example, we'll place LOCK bit on flags field. We need atomic operation to modify LRU bit without LOCK. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20memcg: optimize per-cpu statisticsKAMEZAWA Hiroyuki
Some obvious optimization to memcg. I found mem_cgroup_charge_statistics() is a little big (in object) and does unnecessary address calclation. This patch is for optimization to reduce the size of this function. And res_counter_charge() is 'likely' to succeed. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20memcg: make page->mapping NULL before unchargeKAMEZAWA Hiroyuki
This patch tries to make page->mapping to be NULL before mem_cgroup_uncharge_cache_page() is called. "page->mapping == NULL" is a good check for "whether the page is still radix-tree or not". This patch also adds BUG_ON() to mem_cgroup_uncharge_cache_page(); Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Unevictable LRU Page StatisticsLee Schermerhorn
Report unevictable pages per zone and system wide. Kosaki Motohiro added support for memory controller unevictable statistics. [riel@redhat.com: fix printk in show_free_areas()] [akpm@linux-foundation.org: fix units in /proc/vmstats] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Debugged-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Unevictable LRU InfrastructureLee Schermerhorn
When the system contains lots of mlocked or otherwise unevictable pages, the pageout code (kswapd) can spend lots of time scanning over these pages. Worse still, the presence of lots of unevictable pages can confuse kswapd into thinking that more aggressive pageout modes are required, resulting in all kinds of bad behaviour. Infrastructure to manage pages excluded from reclaim--i.e., hidden from vmscan. Based on a patch by Larry Woodman of Red Hat. Reworked to maintain "unevictable" pages on a separate per-zone LRU list, to "hide" them from vmscan. Kosaki Motohiro added the support for the memory controller unevictable lru list. Pages on the unevictable list have both PG_unevictable and PG_lru set. Thus, PG_unevictable is analogous to and mutually exclusive with PG_active--it specifies which LRU list the page is on. The unevictable infrastructure is enabled by a new mm Kconfig option [CONFIG_]UNEVICTABLE_LRU. A new function 'page_evictable(page, vma)' in vmscan.c tests whether or not a page may be evictable. Subsequent patches will add the various !evictable tests. We'll want to keep these tests light-weight for use in shrink_active_list() and, possibly, the fault path. To avoid races between tasks putting pages [back] onto an LRU list and tasks that might be moving the page from non-evictable to evictable state, the new function 'putback_lru_page()' -- inverse to 'isolate_lru_page()' -- tests the "evictability" of a page after placing it on the LRU, before dropping the reference. If the page has become unevictable, putback_lru_page() will redo the 'putback', thus moving the page to the unevictable list. This way, we avoid "stranding" evictable pages on the unevictable list. [akpm@linux-foundation.org: fix fallout from out-of-order merge] [riel@redhat.com: fix UNEVICTABLE_LRU and !PROC_PAGE_MONITOR build] [nishimura@mxp.nes.nec.co.jp: remove redundant mapping check] [kosaki.motohiro@jp.fujitsu.com: unevictable-lru-infrastructure: putback_lru_page()/unevictable page handling rework] [kosaki.motohiro@jp.fujitsu.com: kill unnecessary lock_page() in vmscan.c] [kosaki.motohiro@jp.fujitsu.com: revert migration change of unevictable lru infrastructure] [kosaki.motohiro@jp.fujitsu.com: revert to unevictable-lru-infrastructure-kconfig-fix.patch] [kosaki.motohiro@jp.fujitsu.com: restore patch failure of vmstat-unevictable-and-mlocked-pages-vm-events.patch] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Debugged-by: Benjamin Kidwell <benjkidwell@yahoo.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmscan: split LRU lists into anon & file setsRik van Riel
Split the LRU lists in two, one set for pages that are backed by real file systems ("file") and one for pages that are backed by memory and swap ("anon"). The latter includes tmpfs. The advantage of doing this is that the VM will not have to scan over lots of anonymous pages (which we generally do not want to swap out), just to find the page cache pages that it should evict. This patch has the infrastructure and a basic policy to balance how much we scan the anon lists and how much we scan the file lists. The big policy changes are in separate patches. [lee.schermerhorn@hp.com: collect lru meminfo statistics from correct offset] [kosaki.motohiro@jp.fujitsu.com: prevent incorrect oom under split_lru] [kosaki.motohiro@jp.fujitsu.com: fix pagevec_move_tail() doesn't treat unevictable page] [hugh@veritas.com: memcg swapbacked pages active] [hugh@veritas.com: splitlru: BDI_CAP_SWAP_BACKED] [akpm@linux-foundation.org: fix /proc/vmstat units] [nishimura@mxp.nes.nec.co.jp: memcg: fix handling of shmem migration] [kosaki.motohiro@jp.fujitsu.com: adjust Quicklists field of /proc/meminfo] [kosaki.motohiro@jp.fujitsu.com: fix style issue of get_scan_ratio()] Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
