path: root/mm/internal.h
2017-08-11mm, mprotect: flush TLB if potentially racing with a parallel reclaim ↵Mel Gorman
leaving stale TLB entries commit 3ea277194daaeaa84ce75180ec7c7a2075027a68 upstream. Nadav Amit identified a theoritical race between page reclaim and mprotect due to TLB flushes being batched outside of the PTL being held. He described the race as follows: CPU0 CPU1 ---- ---- user accesses memory using RW PTE [PTE now cached in TLB] try_to_unmap_one() ==> ptep_get_and_clear() ==> set_tlb_ubc_flush_pending() mprotect(addr, PROT_READ) ==> change_pte_range() ==> [ PTE non-present - no flush ] user writes using cached RW PTE ... try_to_unmap_flush() The same type of race exists for reads when protecting for PROT_NONE and also exists for operations that can leave an old TLB entry behind such as munmap, mremap and madvise. For some operations like mprotect, it's not necessarily a data integrity issue but it is a correctness issue as there is a window where an mprotect that limits access still allows access. For munmap, it's potentially a data integrity issue although the race is massive as an munmap, mmap and return to userspace must all complete between the window when reclaim drops the PTL and flushes the TLB. However, it's theoritically possible so handle this issue by flushing the mm if reclaim is potentially currently batching TLB flushes. Other instances where a flush is required for a present pte should be ok as either the page lock is held preventing parallel reclaim or a page reference count is elevated preventing a parallel free leading to corruption. In the case of page_mkclean there isn't an obvious path that userspace could take advantage of without using the operations that are guarded by this patch. Other users such as gup as a race with reclaim looks just at PTEs. huge page variants should be ok as they don't race with reclaim. mincore only looks at PTEs. userfault also should be ok as if a parallel reclaim takes place, it will either fault the page back in or read some of the data before the flush occurs triggering a fault. Note that a variant of this patch was acked by Andy Lutomirski but this was for the x86 parts on top of his PCID work which didn't make the 4.13 merge window as expected. His ack is dropped from this version and there will be a follow-on patch on top of PCID that will include his ack. [akpm@linux-foundation.org: tweak comments] [akpm@linux-foundation.org: fix spello] Link: http://lkml.kernel.org/r/20170717155523.emckq2esjro6hf3z@suse.de Reported-by: Nadav Amit <nadav.amit@gmail.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Andy Lutomirski <luto@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07mm, compaction: make full priority ignore pageblock suitabilityVlastimil Babka
Several people have reported premature OOMs for order-2 allocations (stack) due to OOM rework in 4.7. In the scenario (parallel kernel build and dd writing to two drives) many pageblocks get marked as Unmovable and compaction free scanner struggles to isolate free pages. Joonsoo Kim pointed out that the free scanner skips pageblocks that are not movable to prevent filling them and forcing non-movable allocations to fallback to other pageblocks. Such heuristic makes sense to help prevent long-term fragmentation, but premature OOMs are relatively more urgent problem. As a compromise, this patch disables the heuristic only for the ultimate compaction priority. Link: http://lkml.kernel.org/r/20160906135258.18335-5-vbabka@suse.cz Reported-by: Ralf-Peter Rohbeck <Ralf-Peter.Rohbeck@quantum.com> Reported-by: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com> Reported-by: Olaf Hering <olaf@aepfle.de> Suggested-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-07mm, compaction: make whole_zone flag ignore cached scanner positionsVlastimil Babka
Patch series "make direct compaction more deterministic") This is mostly a followup to Michal's oom detection rework, which highlighted the need for direct compaction to provide better feedback in reclaim/compaction loop, so that it can reliably recognize when compaction cannot make further progress, and allocation should invoke OOM killer or fail. We've discussed this at LSF/MM [1] where I proposed expanding the async/sync migration mode used in compaction to more general "priorities". This patchset adds one new priority that just overrides all the heuristics and makes compaction fully scan all zones. I don't currently think that we need more fine-grained priorities, but we'll see. Other than that there's some smaller fixes and cleanups, mainly related to the THP-specific hacks. I've tested this with stress-highalloc in GFP_KERNEL order-4 and THP-like order-9 scenarios. There's some improvement for compaction stats for the order-4, which is likely due to the better watermarks handling. In the previous version I reported mostly noise wrt compaction stats, and decreased direct reclaim - now the reclaim is without difference. I believe this is due to the less aggressive compaction priority increase in patch 6. "before" is a mmotm tree prior to 4.7 release plus the first part of the series that was sent and merged separately before after order-4: Compaction stalls 27216 30759 Compaction success 19598 25475 Compaction failures 7617 5283 Page migrate success 370510 464919 Page migrate failure 25712 27987 Compaction pages isolated 849601 1041581 Compaction migrate scanned 143146541 101084990 Compaction free scanned 208355124 144863510 Compaction cost 1403 1210 order-9: Compaction stalls 7311 7401 Compaction success 1634 1683 Compaction failures 5677 5718 Page migrate success 194657 183988 Page migrate failure 4753 4170 Compaction pages isolated 498790 456130 Compaction migrate scanned 565371 524174 Compaction free scanned 4230296 4250744 Compaction cost 215 203 [1] https://lwn.net/Articles/684611/ This patch (of 11): A recent patch has added whole_zone flag that compaction sets when scanning starts from the zone boundary, in order to report that zone has been fully scanned in one attempt. For allocations that want to try really hard or cannot fail, we will want to introduce a mode where scanning whole zone is guaranteed regardless of the cached positions. This patch reuses the whole_zone flag in a way that if it's already passed true to compaction, the cached scanner positions are ignored. Employing this flag during reclaim/compaction loop will be done in the next patch. This patch however converts compaction invoked from userspace via procfs to use this flag. Before this patch, the cached positions were first reset to zone boundaries and then read back from struct zone, so there was a window where a parallel compaction could replace the reset values, making the manual compaction less effective. Using the flag instead of performing reset is more robust. [akpm@linux-foundation.org: coding-style fixes] Link: http://lkml.kernel.org/r/20160810091226.6709-2-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Tested-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, compaction: simplify contended compaction handlingVlastimil Babka
Async compaction detects contention either due to failing trylock on zone->lock or lru_lock, or by need_resched(). Since 1f9efdef4f3f ("mm, compaction: khugepaged should not give up due to need_resched()") the code got quite complicated to distinguish these two up to the __alloc_pages_slowpath() level, so different decisions could be taken for khugepaged allocations. After the recent changes, khugepaged allocations don't check for contended compaction anymore, so we again don't need to distinguish lock and sched contention, and simplify the current convoluted code a lot. However, I believe it's also possible to simplify even more and completely remove the check for contended compaction after the initial async compaction for costly orders, which was originally aimed at THP page fault allocations. There are several reasons why this can be done now: - with the new defaults, THP page faults no longer do reclaim/compaction at all, unless the system admin has overridden the default, or application has indicated via madvise that it can benefit from THP's. In both cases, it means that the potential extra latency is expected and worth the benefits. - even if reclaim/compaction proceeds after this patch where it previously wouldn't, the second compaction attempt is still async and will detect the contention and back off, if the contention persists - there are still heuristics like deferred compaction and pageblock skip bits in place that prevent excessive THP page fault latencies Link: http://lkml.kernel.org/r/20160721073614.24395-9-vbabka@suse.cz Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, page_alloc: remove fair zone allocation policyMel Gorman
The fair zone allocation policy interleaves allocation requests between zones to avoid an age inversion problem whereby new pages are reclaimed to balance a zone. Reclaim is now node-based so this should no longer be an issue and the fair zone allocation policy is not free. This patch removes it. Link: http://lkml.kernel.org/r/1467970510-21195-30-git-send-email-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@surriel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm: convert zone_reclaim to node_reclaimMel Gorman
As reclaim is now per-node based, convert zone_reclaim to be node_reclaim. It is possible that a node will be reclaimed multiple times if it has multiple zones but this is unavoidable without caching all nodes traversed so far. The documentation and interface to userspace is the same from a configuration perspective and will will be similar in behaviour unless the node-local allocation requests were also limited to lower zones. Link: http://lkml.kernel.org/r/1467970510-21195-24-git-send-email-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@surriel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-28mm, vmscan: move LRU lists to nodeMel Gorman
This moves the LRU lists from the zone to the node and related data such as counters, tracing, congestion tracking and writeback tracking. Unfortunately, due to reclaim and compaction retry logic, it is necessary to account for the number of LRU pages on both zone and node logic. Most reclaim logic is based on the node counters but the retry logic uses the zone counters which do not distinguish inactive and active sizes. It would be possible to leave the LRU counters on a per-zone basis but it's a heavier calculation across multiple cache lines that is much more frequent than the retry checks. Other than the LRU counters, this is mostly a mechanical patch but note that it introduces a number of anomalies. For example, the scans are per-zone but using per-node counters. We also mark a node as congested when a zone is congested. This causes weird problems that are fixed later but is easier to review. In the event that there is excessive overhead on 32-bit systems due to the nodes being on LRU then there are two potential solutions 1. Long-term isolation of highmem pages when reclaim is lowmem When pages are skipped, they are immediately added back onto the LRU list. If lowmem reclaim persisted for long periods of time, the same highmem pages get continually scanned. The idea would be that lowmem keeps those pages on a separate list until a reclaim for highmem pages arrives that splices the highmem pages back onto the LRU. It potentially could be implemented similar to the UNEVICTABLE list. That would reduce the skip rate with the potential corner case is that highmem pages have to be scanned and reclaimed to free lowmem slab pages. 2. Linear scan lowmem pages if the initial LRU shrink fails This will break LRU ordering but may be preferable and faster during memory pressure than skipping LRU pages. Link: http://lkml.kernel.org/r/1467970510-21195-4-git-send-email-mgorman@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@surriel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm: introduce fault_envKirill A. Shutemov
The idea borrowed from Peter's patch from patchset on speculative page faults[1]: Instead of passing around the endless list of function arguments, replace the lot with a single structure so we can change context without endless function signature changes. The changes are mostly mechanical with exception of faultaround code: filemap_map_pages() got reworked a bit. This patch is preparation for the next one. [1] http://lkml.kernel.org/r/20141020222841.302891540@infradead.org Link: http://lkml.kernel.org/r/1466021202-61880-9-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm: make swapin readahead to improve thp collapse rateEbru Akagunduz
This patch makes swapin readahead to improve thp collapse rate. When khugepaged scanned pages, there can be a few of the pages in swap area. With the patch THP can collapse 4kB pages into a THP when there are up to max_ptes_swap swap ptes in a 2MB range. The patch was tested with a test program that allocates 400B of memory, writes to it, and then sleeps. I force the system to swap out all. Afterwards, the test program touches the area by writing, it skips a page in each 20 pages of the area. Without the patch, system did not swap in readahead. THP rate was %65 of the program of the memory, it did not change over time. With this patch, after 10 minutes of waiting khugepaged had collapsed %99 of the program's memory. [kirill.shutemov@linux.intel.com: trivial cleanup of exit path of the function] [kirill.shutemov@linux.intel.com: __collapse_huge_page_swapin(): drop unused 'pte' parameter] [kirill.shutemov@linux.intel.com: do not hold anon_vma lock during swap in] Signed-off-by: Ebru Akagunduz <ebru.akagunduz@gmail.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Xie XiuQi <xiexiuqi@huawei.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: David Rientjes <rientjes@google.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-26mm/page_alloc: introduce post allocation processing on page allocatorJoonsoo Kim
This patch is motivated from Hugh and Vlastimil's concern [1]. There are two ways to get freepage from the allocator. One is using normal memory allocation API and the other is __isolate_free_page() which is internally used for compaction and pageblock isolation. Later usage is rather tricky since it doesn't do whole post allocation processing done by normal API. One problematic thing I already know is that poisoned page would not be checked if it is allocated by __isolate_free_page(). Perhaps, there would be more. We could add more debug logic for allocated page in the future and this separation would cause more problem. I'd like to fix this situation at this time. Solution is simple. This patch commonize some logic for newly allocated page and uses it on all sites. This will solve the problem. [1] http://marc.info/?i=alpine.LSU.2.11.1604270029350.7066%40eggly.anvils%3E [iamjoonsoo.kim@lge.com: mm-page_alloc-introduce-post-allocation-processing-on-page-allocator-v3] Link: http://lkml.kernel.org/r/1464230275-25791-7-git-send-email-iamjoonsoo.kim@lge.com Link: http://lkml.kernel.org/r/1466150259-27727-9-git-send-email-iamjoonsoo.kim@lge.com Link: http://lkml.kernel.org/r/1464230275-25791-7-git-send-email-iamjoonsoo.kim@lge.com Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Minchan Kim <minchan@kernel.org> Cc: Alexander Potapenko <glider@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Michal Hocko <mhocko@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-24mm, sl[au]b: add __GFP_ATOMIC to the GFP reclaim maskMel Gorman
Commit d0164adc89f6 ("mm, page_alloc: distinguish between being unable to sleep, unwilling to sleep and avoiding waking kswapd") modified __GFP_WAIT to explicitly identify the difference between atomic callers and those that were unwilling to sleep. Later the definition was removed entirely. The GFP_RECLAIM_MASK is the set of flags that affect watermark checking and reclaim behaviour but __GFP_ATOMIC was never added. Without it, atomic users of the slab allocator strip the __GFP_ATOMIC flag and cannot access the page allocator atomic reserves. This patch addresses the problem. The user-visible impact depends on the workload but potentially atomic allocations unnecessarily fail without this path. Link: http://lkml.kernel.org/r/20160610093832.GK2527@techsingularity.net Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Reported-by: Marcin Wojtas <mw@semihalf.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Cc: <stable@vger.kernel.org> [4.4+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23mm: make vm_mmap killableMichal Hocko
All the callers of vm_mmap seem to check for the failure already and bail out in one way or another on the error which means that we can change it to use killable version of vm_mmap_pgoff and return -EINTR if the current task gets killed while waiting for mmap_sem. This also means that vm_mmap_pgoff can be killable by default and drop the additional parameter. This will help in the OOM conditions when the oom victim might be stuck waiting for the mmap_sem for write which in turn can block oom_reaper which relies on the mmap_sem for read to make a forward progress and reclaim the address space of the victim. Please note that load_elf_binary is ignoring vm_mmap error for current->personality & MMAP_PAGE_ZERO case but that shouldn't be a problem because the address is not used anywhere and we never return to the userspace if we got killed. Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23mm: make mmap_sem for write waits killable for mm syscallsMichal Hocko
This is a follow up work for oom_reaper [1]. As the async OOM killing depends on oom_sem for read we would really appreciate if a holder for write didn't stood in the way. This patchset is changing many of down_write calls to be killable to help those cases when the writer is blocked and waiting for readers to release the lock and so help __oom_reap_task to process the oom victim. Most of the patches are really trivial because the lock is help from a shallow syscall paths where we can return EINTR trivially and allow the current task to die (note that EINTR will never get to the userspace as the task has fatal signal pending). Others seem to be easy as well as the callers are already handling fatal errors and bail and return to userspace which should be sufficient to handle the failure gracefully. I am not familiar with all those code paths so a deeper review is really appreciated. As this work is touching more areas which are not directly connected I have tried to keep the CC list as small as possible and people who I believed would be familiar are CCed only to the specific patches (all should have received the cover though). This patchset is based on linux-next and it depends on down_write_killable for rw_semaphores which got merged into tip locking/rwsem branch and it is merged into this next tree. I guess it would be easiest to route these patches via mmotm because of the dependency on the tip tree but if respective maintainers prefer other way I have no objections. I haven't covered all the mmap_write(mm->mmap_sem) instances here $ git grep "down_write(.*\<mmap_sem\>)" next/master | wc -l 98 $ git grep "down_write(.*\<mmap_sem\>)" | wc -l 62 I have tried to cover those which should be relatively easy to review in this series because this alone should be a nice improvement. Other places can be changed on top. [0] http://lkml.kernel.org/r/1456752417-9626-1-git-send-email-mhocko@kernel.org [1] http://lkml.kernel.org/r/1452094975-551-1-git-send-email-mhocko@kernel.org [2] http://lkml.kernel.org/r/1456750705-7141-1-git-send-email-mhocko@kernel.org This patch (of 18): This is the first step in making mmap_sem write waiters killable. It focuses on the trivial ones which are taking the lock early after entering the syscall and they are not changing state before. Therefore it is very easy to change them to use down_write_killable and immediately return with -EINTR. This will allow the waiter to pass away without blocking the mmap_sem which might be required to make a forward progress. E.g. the oom reaper will need the lock for reading to dismantle the OOM victim address space. The only tricky function in this patch is vm_mmap_pgoff which has many call sites via vm_mmap. To reduce the risk keep vm_mmap with the original non-killable semantic for now. vm_munmap callers do not bother checking the return value so open code it into the munmap syscall path for now for simplicity. Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Hugh Dickins <hughd@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20mm, compaction: distinguish between full and partial COMPACT_COMPLETEMichal Hocko
COMPACT_COMPLETE now means that compaction and free scanner met. This is not very useful information if somebody just wants to use this feedback and make any decisions based on that. The current caller might be a poor guy who just happened to scan tiny portion of the zone and that could be the reason no suitable pages were compacted. Make sure we distinguish the full and partial zone walks. Consumers should treat COMPACT_PARTIAL_SKIPPED as a potential success and be optimistic in retrying. The existing users of COMPACT_COMPLETE are conservatively changed to use COMPACT_PARTIAL_SKIPPED as well but some of them should be probably reconsidered and only defer the compaction only for COMPACT_COMPLETE with the new semantic. This patch shouldn't introduce any functional changes. Signed-off-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Hillf Danton <hillf.zj@alibaba-inc.com> Cc: David Rientjes <rientjes@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Vladimir Davydov <vdavydov@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19mm, page_alloc: remove field from alloc_contextMel Gorman
The classzone_idx can be inferred from preferred_zoneref so remove the unnecessary field and save stack space. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19mm, page_alloc: avoid looking up the first zone in a zonelist twiceMel Gorman
The allocator fast path looks up the first usable zone in a zonelist and then get_page_from_freelist does the same job in the zonelist iterator. This patch preserves the necessary information. 4.6.0-rc2 4.6.0-rc2 fastmark-v1r20 initonce-v1r20 Min alloc-odr0-1 364.00 ( 0.00%) 359.00 ( 1.37%) Min alloc-odr0-2 262.00 ( 0.00%) 260.00 ( 0.76%) Min alloc-odr0-4 214.00 ( 0.00%) 214.00 ( 0.00%) Min alloc-odr0-8 186.00 ( 0.00%) 186.00 ( 0.00%) Min alloc-odr0-16 173.00 ( 0.00%) 173.00 ( 0.00%) Min alloc-odr0-32 165.00 ( 0.00%) 165.00 ( 0.00%) Min alloc-odr0-64 161.00 ( 0.00%) 162.00 ( -0.62%) Min alloc-odr0-128 159.00 ( 0.00%) 161.00 ( -1.26%) Min alloc-odr0-256 168.00 ( 0.00%) 170.00 ( -1.19%) Min alloc-odr0-512 180.00 ( 0.00%) 181.00 ( -0.56%) Min alloc-odr0-1024 190.00 ( 0.00%) 190.00 ( 0.00%) Min alloc-odr0-2048 196.00 ( 0.00%) 196.00 ( 0.00%) Min alloc-odr0-4096 202.00 ( 0.00%) 202.00 ( 0.00%) Min alloc-odr0-8192 206.00 ( 0.00%) 205.00 ( 0.49%) Min alloc-odr0-16384 206.00 ( 0.00%) 205.00 ( 0.49%) The benefit is negligible and the results are within the noise but each cycle counts. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19mm, page_alloc: convert alloc_flags to unsignedMel Gorman
alloc_flags is a bitmask of flags but it is signed which does not necessarily generate the best code depending on the compiler. Even without an impact, it makes more sense that this be unsigned. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19mm: rename _count, field of the struct page, to _refcountJoonsoo Kim
Many developers already know that field for reference count of the struct page is _count and atomic type. They would try to handle it directly and this could break the purpose of page reference count tracepoint. To prevent direct _count modification, this patch rename it to _refcount and add warning message on the code. After that, developer who need to handle reference count will find that field should not be accessed directly. [akpm@linux-foundation.org: fix comments, per Vlastimil] [akpm@linux-foundation.org: Documentation/vm/transhuge.txt too] [sfr@canb.auug.org.au: sync ethernet driver changes] Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Sunil Goutham <sgoutham@cavium.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Manish Chopra <manish.chopra@qlogic.com> Cc: Yuval Mintz <yuval.mintz@qlogic.com> Cc: Tariq Toukan <tariqt@mellanox.com> Cc: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-25mm, oom: introduce oom reaperMichal Hocko
This patch (of 5): This is based on the idea from Mel Gorman discussed during LSFMM 2015 and independently brought up by Oleg Nesterov. The OOM killer currently allows to kill only a single task in a good hope that the task will terminate in a reasonable time and frees up its memory. Such a task (oom victim) will get an access to memory reserves via mark_oom_victim to allow a forward progress should there be a need for additional memory during exit path. It has been shown (e.g. by Tetsuo Handa) that it is not that hard to construct workloads which break the core assumption mentioned above and the OOM victim might take unbounded amount of time to exit because it might be blocked in the uninterruptible state waiting for an event (e.g. lock) which is blocked by another task looping in the page allocator. This patch reduces the probability of such a lockup by introducing a specialized kernel thread (oom_reaper) which tries to reclaim additional memory by preemptively reaping the anonymous or swapped out memory owned by the oom victim under an assumption that such a memory won't be needed when its owner is killed and kicked from the userspace anyway. There is one notable exception to this, though, if the OOM victim was in the process of coredumping the result would be incomplete. This is considered a reasonable constrain because the overall system health is more important than debugability of a particular application. A kernel thread has been chosen because we need a reliable way of invocation so workqueue context is not appropriate because all the workers might be busy (e.g. allocating memory). Kswapd which sounds like another good fit is not appropriate as well because it might get blocked on locks during reclaim as well. oom_reaper has to take mmap_sem on the target task for reading so the solution is not 100% because the semaphore might be held or blocked for write but the probability is reduced considerably wrt. basically any lock blocking forward progress as described above. In order to prevent from blocking on the lock without any forward progress we are using only a trylock and retry 10 times with a short sleep in between. Users of mmap_sem which need it for write should be carefully reviewed to use _killable waiting as much as possible and reduce allocations requests done with the lock held to absolute minimum to reduce the risk even further. The API between oom killer and oom reaper is quite trivial. wake_oom_reaper updates mm_to_reap with cmpxchg to guarantee only NULL->mm transition and oom_reaper clear this atomically once it is done with the work. This means that only a single mm_struct can be reaped at the time. As the operation is potentially disruptive we are trying to limit it to the ncessary minimum and the reaper blocks any updates while it operates on an mm. mm_struct is pinned by mm_count to allow parallel exit_mmap and a race is detected by atomic_inc_not_zero(mm_users). Signed-off-by: Michal Hocko <mhocko@suse.com> Suggested-by: Oleg Nesterov <oleg@redhat.com> Suggested-by: Mel Gorman <mgorman@suse.de> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Andrea Argangeli <andrea@kernel.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17mm: convert printk(KERN_<LEVEL> to pr_<level>Joe Perches
Most of the mm subsystem uses pr_<level> so make it consistent. Miscellanea: - Realign arguments - Add missing newline to format - kmemleak-test.c has a "kmemleak: " prefix added to the "Kmemleak testing" logging message via pr_fmt Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Tejun Heo <tj@kernel.org> [percpu] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17mm: introduce page reference manipulation functionsJoonsoo Kim
The success of CMA allocation largely depends on the success of migration and key factor of it is page reference count. Until now, page reference is manipulated by direct calling atomic functions so we cannot follow up who and where manipulate it. Then, it is hard to find actual reason of CMA allocation failure. CMA allocation should be guaranteed to succeed so finding offending place is really important. In this patch, call sites where page reference is manipulated are converted to introduced wrapper function. This is preparation step to add tracepoint to each page reference manipulation function. With this facility, we can easily find reason of CMA allocation failure. There is no functional change in this patch. In addition, this patch also converts reference read sites. It will help a second step that renames page._count to something else and prevents later attempt to direct access to it (Suggested by Andrew). Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Minchan Kim <minchan@kernel.org> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17mm, kswapd: replace kswapd compaction with waking up kcompactdVlastimil Babka
Similarly to direct reclaim/compaction, kswapd attempts to combine reclaim and compaction to attempt making memory allocation of given order available. The details differ from direct reclaim e.g. in having high watermark as a goal. The code involved in kswapd's reclaim/compaction decisions has evolved to be quite complex. Testing reveals that it doesn't actually work in at least one scenario, and closer inspection suggests that it could be greatly simplified without compromising on the goal (make high-order page available) or efficiency (don't reclaim too much). The simplification relieas of doing all compaction in kcompactd, which is simply woken up when high watermarks are reached by kswapd's reclaim. The scenario where kswapd compaction doesn't work was found with mmtests test stress-highalloc configured to attempt order-9 allocations without direct reclaim, just waking up kswapd. There was no compaction attempt from kswapd during the whole test. Some added instrumentation shows what happens: - balance_pgdat() sets end_zone to Normal, as it's not balanced - reclaim is attempted on DMA zone, which sets nr_attempted to 99, but it cannot reclaim anything, so sc.nr_reclaimed is 0 - for zones DMA32 and Normal, kswapd_shrink_zone uses testorder=0, so it merely checks if high watermarks were reached for base pages. This is true, so no reclaim is attempted. For DMA, testorder=0 wasn't used, as compaction_suitable() returned COMPACT_SKIPPED - even though the pgdat_needs_compaction flag wasn't set to false, no compaction happens due to the condition sc.nr_reclaimed > nr_attempted being false (as 0 < 99) - priority-- due to nr_reclaimed being 0, repeat until priority reaches 0 pgdat_balanced() is false as only the small zone DMA appears balanced (curiously in that check, watermark appears OK and compaction_suitable() returns COMPACT_PARTIAL, because a lower classzone_idx is used there) Now, even if it was decided that reclaim shouldn't be attempted on the DMA zone, the scenario would be the same, as (sc.nr_reclaimed=0 > nr_attempted=0) is also false. The condition really should use >= as the comment suggests. Then there is a mismatch in the check for setting pgdat_needs_compaction to false using low watermark, while the rest uses high watermark, and who knows what other subtlety. Hopefully this demonstrates that this is unsustainable. Luckily we can simplify this a lot. The reclaim/compaction decisions make sense for direct reclaim scenario, but in kswapd, our primary goal is to reach high watermark in order-0 pages. Afterwards we can attempt compaction just once. Unlike direct reclaim, we don't reclaim extra pages (over the high watermark), the current code already disallows it for good reasons. After this patch, we simply wake up kcompactd to process the pgdat, after we have either succeeded or failed to reach the high watermarks in kswapd, which goes to sleep. We pass kswapd's order and classzone_idx, so kcompactd can apply the same criteria to determine which zones are worth compacting. Note that we use the classzone_idx from wakeup_kswapd(), not balanced_classzone_idx which can include higher zones that kswapd tried to balance too, but didn't consider them in pgdat_balanced(). Since kswapd now cannot create high-order pages itself, we need to adjust how it determines the zones to be balanced. The key element here is adding a "highorder" parameter to zone_balanced, which, when set to false, makes it consider only order-0 watermark instead of the desired higher order (this was done previously by kswapd_shrink_zone(), but not elsewhere). This false is passed for example in pgdat_balanced(). Importantly, wakeup_kswapd() uses true to make sure kswapd and thus kcompactd are woken up for a high-order allocation failure. The last thing is to decide what to do with pageblock_skip bitmap handling. Compaction maintains a pageblock_skip bitmap to record pageblocks where isolation recently failed. This bitmap can be reset by three ways: 1) direct compaction is restarting after going through the full deferred cycle 2) kswapd goes to sleep, and some other direct compaction has previously finished scanning the whole zone and set zone->compact_blockskip_flush. Note that a successful direct compaction clears this flag. 3) compaction was invoked manually via trigger in /proc The case 2) is somewhat fuzzy to begin with, but after introducing kcompactd we should update it. The check for direct compaction in 1), and to set the flush flag in 2) use current_is_kswapd(), which doesn't work for kcompactd. Thus, this patch adds bool direct_compaction to compact_control to use in 2). For the case 1) we remove the check completely - unlike the former kswapd compaction, kcompactd does use the deferred compaction functionality, so flushing tied to restarting from deferred compaction makes sense here. Note that when kswapd goes to sleep, kcompactd is woken up, so it will see the flushed pageblock_skip bits. This is different from when the former kswapd compaction observed the bits and I believe it makes more sense. Kcompactd can afford to be more thorough than a direct compaction trying to limit allocation latency, or kswapd whose primary goal is to reclaim. For testing, I used stress-highalloc configured to do order-9 allocations with GFP_NOWAIT|__GFP_HIGH|__GFP_COMP, so they relied just on kswapd/kcompactd reclaim/compaction (the interfering kernel builds in phases 1 and 2 work as usual): stress-highalloc 4.5-rc1+before 4.5-rc1+after -nodirect -nodirect Success 1 Min 1.00 ( 0.00%) 5.00 (-66.67%) Success 1 Mean 1.40 ( 0.00%) 6.20 (-55.00%) Success 1 Max 2.00 ( 0.00%) 7.00 (-16.67%) Success 2 Min 1.00 ( 0.00%) 5.00 (-66.67%) Success 2 Mean 1.80 ( 0.00%) 6.40 (-52.38%) Success 2 Max 3.00 ( 0.00%) 7.00 (-16.67%) Success 3 Min 34.00 ( 0.00%) 62.00 ( 1.59%) Success 3 Mean 41.80 ( 0.00%) 63.80 ( 1.24%) Success 3 Max 53.00 ( 0.00%) 65.00 ( 2.99%) User 3166.67 3181.09 System 1153.37 1158.25 Elapsed 1768.53 1799.37 4.5-rc1+before 4.5-rc1+after -nodirect -nodirect Direct pages scanned 32938 32797 Kswapd pages scanned 2183166 2202613 Kswapd pages reclaimed 2152359 2143524 Direct pages reclaimed 32735 32545 Percentage direct scans 1% 1% THP fault alloc 579 612 THP collapse alloc 304 316 THP splits 0 0 THP fault fallback 793 778 THP collapse fail 11 16 Compaction stalls 1013 1007 Compaction success 92 67 Compaction failures 920 939 Page migrate success 238457 721374 Page migrate failure 23021 23469 Compaction pages isolated 504695 1479924 Compaction migrate scanned 661390 8812554 Compaction free scanned 13476658 84327916 Compaction cost 262 838 After this patch we see improvements in allocation success rate (especially for phase 3) along with increased compaction activity. The compaction stalls (direct compaction) in the interfering kernel builds (probably THP's) also decreased somewhat thanks to kcompactd activity, yet THP alloc successes improved a bit. Note that elapsed and user time isn't so useful for this benchmark, because of the background interference being unpredictable. It's just to quickly spot some major unexpected differences. System time is somewhat more useful and that didn't increase. Also (after adjusting mmtests' ftrace monitor): Time kswapd awake 2547781 2269241 Time kcompactd awake 0 119253 Time direct compacting 939937 557649 Time kswapd compacting 0 0 Time kcompactd compacting 0 119099 The decrease of overal time spent compacting appears to not match the increased compaction stats. I suspect the tasks get rescheduled and since the ftrace monitor doesn't see that, the reported time is wall time, not CPU time. But arguably direct compactors care about overall latency anyway, whether busy compacting or waiting for CPU doesn't matter. And that latency seems to almost halved. It's also interesting how much time kswapd spent awake just going through all the priorities and failing to even try compacting, over and over. We can also configure stress-highalloc to perform both direct reclaim/compaction and wakeup kswapd/kcompactd, by using GFP_KERNEL|__GFP_HIGH|__GFP_COMP: stress-highalloc 4.5-rc1+before 4.5-rc1+after -direct -direct Success 1 Min 4.00 ( 0.00%) 9.00 (-50.00%) Success 1 Mean 8.00 ( 0.00%) 10.00 (-19.05%) Success 1 Max 12.00 ( 0.00%) 11.00 ( 15.38%) Success 2 Min 4.00 ( 0.00%) 9.00 (-50.00%) Success 2 Mean 8.20 ( 0.00%) 10.00 (-16.28%) Success 2 Max 13.00 ( 0.00%) 11.00 ( 8.33%) Success 3 Min 75.00 ( 0.00%) 74.00 ( 1.33%) Success 3 Mean 75.60 ( 0.00%) 75.20 ( 0.53%) Success 3 Max 77.00 ( 0.00%) 76.00 ( 0.00%) User 3344.73 3246.04 System 1194.24 1172.29 Elapsed 1838.04 1836.76 4.5-rc1+before 4.5-rc1+after -direct -direct Direct pages scanned 125146 120966 Kswapd pages scanned 2119757 2135012 Kswapd pages reclaimed 2073183 2108388 Direct pages reclaimed 124909 120577 Percentage direct scans 5% 5% THP fault alloc 599 652 THP collapse alloc 323 354 THP splits 0 0 THP fault fallback 806 793 THP collapse fail 17 16 Compaction stalls 2457 2025 Compaction success 906 518 Compaction failures 1551 1507 Page migrate success 2031423 2360608 Page migrate failure 32845 40852 Compaction pages isolated 4129761 4802025 Compaction migrate scanned 11996712 21750613 Compaction free scanned 214970969 344372001 Compaction cost 2271 2694 In this scenario, this patch doesn't change the overall success rate as direct compaction already tries all it can. There's however significant reduction in direct compaction stalls (that is, the number of allocations that went into direct compaction). The number of successes (i.e. direct compaction stalls that ended up with successful allocation) is reduced by the same number. This means the offload to kcompactd is working as expected, and direct compaction is reduced either due to detecting contention, or compaction deferred by kcompactd. In the previous version of this patchset there was some apparent reduction of success rate, but the changes in this version (such as using sync compaction only), new baseline kernel, and/or averaging results from 5 executions (my bet), made this go away. Ftrace-based stats seem to roughly agree: Time kswapd awake 2532984 2326824 Time kcompactd awake 0 257916 Time direct compacting 864839 735130 Time kswapd compacting 0 0 Time kcompactd compacting 0 257585 Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: David Rientjes <rientjes@google.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17/proc/kpageflags: return KPF_BUDDY for "tail" buddy pagesNaoya Horiguchi
Currently /proc/kpageflags returns nothing for "tail" buddy pages, which is inconvenient when grasping how free pages are distributed. This patch sets KPF_BUDDY for such pages. With this patch: $ grep MemFree /proc/meminfo ; tools/vm/page-types -b buddy MemFree: 3134992 kB flags page-count MB symbolic-flags long-symbolic-flags 0x0000000000000400 779272 3044 __________B_______________________________ buddy 0x0000000000000c00 4385 17 __________BM______________________________ buddy,mmap total 783657 3061 783657 pages is 3134628 kB (roughly consistent with the global counter,) so it's OK. [akpm@linux-foundation.org: update comment, per Naoya] Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com>> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15mm/compaction: speed up pageblock_pfn_to_page() when zone is contiguousJoonsoo Kim
There is a performance drop report due to hugepage allocation and in there half of cpu time are spent on pageblock_pfn_to_page() in compaction [1]. In that workload, compaction is triggered to make hugepage but most of pageblocks are un-available for compaction due to pageblock type and skip bit so compaction usually fails. Most costly operations in this case is to find valid pageblock while scanning whole zone range. To check if pageblock is valid to compact, valid pfn within pageblock is required and we can obtain it by calling pageblock_pfn_to_page(). This function checks whether pageblock is in a single zone and return valid pfn if possible. Problem is that we need to check it every time before scanning pageblock even if we re-visit it and this turns out to be very expensive in this workload. Although we have no way to skip this pageblock check in the system where hole exists at arbitrary position, we can use cached value for zone continuity and just do pfn_to_page() in the system where hole doesn't exist. This optimization considerably speeds up in above workload. Before vs After Max: 1096 MB/s vs 1325 MB/s Min: 635 MB/s 1015 MB/s Avg: 899 MB/s 1194 MB/s Avg is improved by roughly 30% [2]. [1]: http://www.spinics.net/lists/linux-mm/msg97378.html [2]: https://lkml.org/lkml/2015/12/9/23 [akpm@linux-foundation.org: don't forget to restore zone->contiguous on error path, per Vlastimil] Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reported-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Tested-by: Aaron Lu <aaron.lu@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15mm, printk: introduce new format string for flagsVlastimil Babka
In mm we use several kinds of flags bitfields that are sometimes printed for debugging purposes, or exported to userspace via sysfs. To make them easier to interpret independently on kernel version and config, we want to dump also the symbolic flag names. So far this has been done with repeated calls to pr_cont(), which is unreliable on SMP, and not usable for e.g. sysfs export. To get a more reliable and universal solution, this patch extends printk() format string for pointers to handle the page flags (%pGp), gfp_flags (%pGg) and vma flags (%pGv). Existing users of dump_flag_names() are converted and simplified. It would be possible to pass flags by value instead of pointer, but the %p format string for pointers already has extensions for various kernel structures, so it's a good fit, and the extra indirection in a non-critical path is negligible. [linux@rasmusvillemoes.dk: lots of good implementation suggestions] Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-02-03mm: polish virtual memory accountingKonstantin Khlebnikov
* add VM_STACK as alias for VM_GROWSUP/DOWN depending on architecture * always account VMAs with flag VM_STACK as stack (as it was before) * cleanup classifying helpers * update comments and documentation Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Tested-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-02-03mm: warn about VmData over RLIMIT_DATAKonstantin Khlebnikov
This patch provides a way of working around a slight regression introduced by commit 84638335900f ("mm: rework virtual memory accounting"). Before that commit RLIMIT_DATA have control only over size of the brk region. But that change have caused problems with all existing versions of valgrind, because it set RLIMIT_DATA to zero. This patch fixes rlimit check (limit actually in bytes, not pages) and by default turns it into warning which prints at first VmData misuse: "mmap: top (795): VmData 516096 exceed data ulimit 512000. Will be forbidden soon." Behavior is controlled by boot param ignore_rlimit_data=y/n and by sysfs /sys/module/kernel/parameters/ignore_rlimit_data. For now it set to "y". [akpm@linux-foundation.org: tweak kernel-parameters.txt text[ Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Link: http://lkml.kernel.org/r/20151228211015.GL2194@uranus Reported-by: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Vladimir Davydov <vdavydov@virtuozzo.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Kees Cook <keescook@google.com> Cc: Willy Tarreau <w@1wt.eu> Cc: Pavel Emelyanov <xemul@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-15thp: reintroduce split_huge_page()Kirill A. Shutemov
This patch adds implementation of split_huge_page() for new refcountings. Unlike previous implementation, new split_huge_page() can fail if somebody holds GUP pin on the page. It also means that pin on page would prevent it from bening split under you. It makes situation in many places much cleaner. The basic scheme of split_huge_page(): - Check that sum of mapcounts of all subpage is equal to page_count() plus one (caller pin). Foll off with -EBUSY. This way we can avoid useless PMD-splits. - Freeze the page counters by splitting all PMD and setup migration PTEs. - Re-check sum of mapcounts against page_count(). Page's counts are stable now. -EBUSY if page is pinned. - Split compound page. - Unfreeze the page by removing migration entries. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Jerome Marchand <jmarchan@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Steve Capper <steve.capper@linaro.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-15mm: drop tail page refcountingKirill A. Shutemov
Tail page refcounting is utterly complicated and painful to support. It uses ->_mapcount on tail pages to store how many times this page is pinned. get_page() bumps ->_mapcount on tail page in addition to ->_count on head. This information is required by split_huge_page() to be able to distribute pins from head of compound page to tails during the split. We will need ->_mapcount to account PTE mappings of subpages of the compound page. We eliminate need in current meaning of ->_mapcount in tail pages by forbidding split entirely if the page is pinned. The only user of tail page refcounting is THP which is marked BROKEN for now. Let's drop all this mess. It makes get_page() and put_page() much simpler. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Tested-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Jerome Marchand <jmarchan@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Steve Capper <steve.capper@linaro.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm: use 'unsigned int' for page orderKirill A. Shutemov
Let's try to be consistent about data type of page order. [sfr@canb.auug.org.au: fix build (type of pageblock_order)] [hughd@google.com: some configs end up with MAX_ORDER and pageblock_order having different types] Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm: make compound_head() robustKirill A. Shutemov
Hugh has pointed that compound_head() call can be unsafe in some context. There's one example: CPU0 CPU1 isolate_migratepages_block() page_count() compound_head() !!PageTail() == true put_page() tail->first_page = NULL head = tail->first_page alloc_pages(__GFP_COMP) prep_compound_page() tail->first_page = head __SetPageTail(p); !!PageTail() == true <head == NULL dereferencing> The race is pure theoretical. I don't it's possible to trigger it in practice. But who knows. We can fix the race by changing how encode PageTail() and compound_head() within struct page to be able to update them in one shot. The patch introduces page->compound_head into third double word block in front of compound_dtor and compound_order. Bit 0 encodes PageTail() and the rest bits are pointer to head page if bit zero is set. The patch moves page->pmd_huge_pte out of word, just in case if an architecture defines pgtable_t into something what can have the bit 0 set. hugetlb_cgroup uses page->lru.next in the second tail page to store pointer struct hugetlb_cgroup. The patch switch it to use page->private in the second tail page instead. The space is free since ->first_page is removed from the union. The patch also opens possibility to remove HUGETLB_CGROUP_MIN_ORDER limitation, since there's now space in first tail page to store struct hugetlb_cgroup pointer. But that's out of scope of the patch. That means page->compound_head shares storage space with: - page->lru.next; - page->next; - page->rcu_head.next; That's too long list to be absolutely sure, but looks like nobody uses bit 0 of the word. page->rcu_head.next guaranteed[1] to have bit 0 clean as long as we use call_rcu(), call_rcu_bh(), call_rcu_sched(), or call_srcu(). But future call_rcu_lazy() is not allowed as it makes use of the bit and we can get false positive PageTail(). [1] http://lkml.kernel.org/g/20150827163634.GD4029@linux.vnet.ibm.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Vlastimil Babka <vbabka@suse.cz> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm: page_alloc: hide some GFP internals and document the bits and flag ↵Mel Gorman
combinations Andrew stated the following We have quite a history of remote parts of the kernel using weird/wrong/inexplicable combinations of __GFP_ flags. I tend to think that this is because we didn't adequately explain the interface. And I don't think that gfp.h really improved much in this area as a result of this patchset. Could you go through it some time and decide if we've adequately documented all this stuff? This patches first moves some GFP flag combinations that are part of the MM internals to mm/internal.h. The rest of the patch documents the __GFP_FOO bits under various headings and then documents the flag combinations. It will not help callers that are brain damaged but the clarity might motivate some fixes and avoid future mistakes. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Rik van Riel <riel@redhat.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06mm, page_alloc: remove unnecessary recalculations for dirty zone balancingMel Gorman
File-backed pages that will be immediately written are balanced between zones. This heuristic tries to avoid having a single zone filled with recently dirtied pages but the checks are unnecessarily expensive. Move consider_zone_balanced into the alloc_context instead of checking bitmaps multiple times. The patch also gives the parameter a more meaningful name. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Lameter <cl@linux.com> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05mm: page migration fix PageMlocked on migrated pagesHugh Dickins
Commit e6c509f85455 ("mm: use clear_page_mlock() in page_remove_rmap()") in v3.7 inadvertently made mlock_migrate_page() impotent: page migration unmaps the page from userspace before migrating, and that commit clears PageMlocked on the final unmap, leaving mlock_migrate_page() with nothing to do. Not a serious bug, the next attempt at reclaiming the page would fix it up; but a betrayal of page migration's intent - the new page ought to emerge as PageMlocked. I don't see how to fix it for mlock_migrate_page() itself; but easily fixed in remove_migration_pte(), by calling mlock_vma_page() when the vma is VM_LOCKED - under pte lock as in try_to_unmap_one(). Delete mlock_migrate_page()? Not quite, it does still serve a purpose for migrate_misplaced_transhuge_page(): where we could replace it by a test, clear_page_mlock(), mlock_vma_page() sequence; but would that be an improvement? mlock_migrate_page() is fairly lean, and let's make it leaner by skipping the irq save/restore now clearly not needed. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Rik van Riel <riel@redhat.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08mm/compaction: correct to flush migrated pages if pageblock skip happensJoonsoo Kim
We cache isolate_start_pfn before entering isolate_migratepages(). If pageblock is skipped in isolate_migratepages() due to whatever reason, cc->migrate_pfn can be far from isolate_start_pfn hence we flush pages that were freed. For example, the following scenario can be possible: - assume order-9 compaction, pageblock order is 9 - start_isolate_pfn is 0x200 - isolate_migratepages() - skip a number of pageblocks - start to isolate from pfn 0x600 - cc->migrate_pfn = 0x620 - return - last_migrated_pfn is set to 0x200 - check flushing condition - current_block_start is set to 0x600 - last_migrated_pfn < current_block_start then do useless flush This wrong flush would not help the performance and success rate so this patch tries to fix it. One simple way to know the exact position where we start to isolate migratable pages is that we cache it in isolate_migratepages() before entering actual isolation. This patch implements that and fixes the problem. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04mm: defer flush of writable TLB entriesMel Gorman
If a PTE is unmapped and it's dirty then it was writable recently. Due to deferred TLB flushing, it's best to assume a writable TLB cache entry exists. With that assumption, the TLB must be flushed before any IO can start or the page is freed to avoid lost writes or data corruption. This patch defers flushing of potentially writable TLBs as long as possible. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Dave Hansen <dave.hansen@intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04mm: send one IPI per CPU to TLB flush all entries after unmapping pagesMel Gorman
An IPI is sent to flush remote TLBs when a page is unmapped that was potentially accesssed by other CPUs. There are many circumstances where this happens but the obvious one is kswapd reclaiming pages belonging to a running process as kswapd and the task are likely running on separate CPUs. On small machines, this is not a significant problem but as machine gets larger with more cores and more memory, the cost of these IPIs can be high. This patch uses a simple structure that tracks CPUs that potentially have TLB entries for pages being unmapped. When the unmapping is complete, the full TLB is flushed on the assumption that a refill cost is lower than flushing individual entries. Architectures wishing to do this must give the following guarantee. If a clean page is unmapped and not immediately flushed, the architecture must guarantee that a write to that linear address from a CPU with a cached TLB entry will trap a page fault. This is essentially what the kernel already depends on but the window is much larger with this patch applied and is worth highlighting. The architecture should consider whether the cost of the full TLB flush is higher than sending an IPI to flush each individual entry. An additional architecture helper called flush_tlb_local is required. It's a trivial wrapper with some accounting in the x86 case. The impact of this patch depends on the workload as measuring any benefit requires both mapped pages co-located on the LRU and memory pressure. The case with the biggest impact is multiple processes reading mapped pages taken from the vm-scalability test suite. The test case uses NR_CPU readers of mapped files that consume 10*RAM. Linear mapped reader on a 4-node machine with 64G RAM and 48 CPUs 4.2.0-rc1 4.2.0-rc1 vanilla flushfull-v7 Ops lru-file-mmap-read-elapsed 159.62 ( 0.00%) 120.68 ( 24.40%) Ops lru-file-mmap-read-time_range 30.59 ( 0.00%) 2.80 ( 90.85%) Ops lru-file-mmap-read-time_stddv 6.70 ( 0.00%) 0.64 ( 90.38%) 4.2.0-rc1 4.2.0-rc1 vanilla flushfull-v7 User 581.00 611.43 System 5804.93 4111.76 Elapsed 161.03 122.12 This is showing that the readers completed 24.40% faster with 29% less system CPU time. From vmstats, it is known that the vanilla kernel was interrupted roughly 900K times per second during the steady phase of the test and the patched kernel was interrupts 180K times per second. The impact is lower on a single socket machine. 4.2.0-rc1 4.2.0-rc1 vanilla flushfull-v7 Ops lru-file-mmap-read-elapsed 25.33 ( 0.00%) 20.38 ( 19.54%) Ops lru-file-mmap-read-time_range 0.91 ( 0.00%) 1.44 (-58.24%) Ops lru-file-mmap-read-time_stddv 0.28 ( 0.00%) 0.47 (-65.34%) 4.2.0-rc1 4.2.0-rc1 vanilla flushfull-v7 User 58.09 57.64 System 111.82 76.56 Elapsed 27.29 22.55 It's still a noticeable improvement with vmstat showing interrupts went from roughly 500K per second to 45K per second. The patch will have no impact on workloads with no memory pressure or have relatively few mapped pages. It will have an unpredictable impact on the workload running on the CPU being flushed as it'll depend on how many TLB entries need to be refilled and how long that takes. Worst case, the TLB will be completely cleared of active entries when the target PFNs were not resident at all. [sasha.levin@oracle.com: trace tlb flush after disabling preemption in try_to_unmap_flush] Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Dave Hansen <dave.hansen@intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: finish initialisation of struct pages before basic setupMel Gorman
Waiman Long reported that 24TB machines hit OOM during basic setup when struct page initialisation was deferred. One approach is to initialise memory on demand but it interferes with page allocator paths. This patch creates dedicated threads to initialise memory before basic setup. It then blocks on a rw_semaphore until completion as a wait_queue and counter is overkill. This may be slower to boot but it's simplier overall and also gets rid of a section mangling which existed so kswapd could do the initialisation. [akpm@linux-foundation.org: include rwsem.h, use DECLARE_RWSEM, fix comment, remove unneeded cast] Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Waiman Long <waiman.long@hp.com Cc: Nathan Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Scott Norton <scott.norton@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: remove mminit_verify_page_linksMel Gorman
mminit_verify_page_links() is an extremely paranoid check that was introduced when memory initialisation was being heavily reworked. Profiles indicated that up to 10% of parallel memory initialisation was spent on checking this for every page. The cost could be reduced but in practice this check only found problems very early during the initialisation rewrite and has found nothing since. This patch removes an expensive unnecessary check. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: initialise remaining struct pages in parallel with kswapdMel Gorman
Only a subset of struct pages are initialised at the moment. When this patch is applied kswapd initialise the remaining struct pages in parallel. This should boot faster by spreading the work to multiple CPUs and initialising data that is local to the CPU. The user-visible effect on large machines is that free memory will appear to rapidly increase early in the lifetime of the system until kswapd reports that all memory is initialised in the kernel log. Once initialised there should be no other user-visibile effects. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: meminit: initialise a subset of struct pages if ↵Mel Gorman
CONFIG_DEFERRED_STRUCT_PAGE_INIT is set This patch initalises all low memory struct pages and 2G of the highest zone on each node during memory initialisation if CONFIG_DEFERRED_STRUCT_PAGE_INIT is set. That config option cannot be set but will be available in a later patch. Parallel initialisation of struct page depends on some features from memory hotplug and it is necessary to alter alter section annotations. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30mm: page_alloc: pass PFN to __free_pages_bootmemMel Gorman
__free_pages_bootmem prepares a page for release to the buddy allocator and assumes that the struct page is initialised. Parallel initialisation of struct pages defers initialisation and __free_pages_bootmem can be called for struct pages that cannot yet map struct page to PFN. This patch passes PFN to __free_pages_bootmem with no other functional change. Signed-off-by: Mel Gorman <mgorman@suse.de> Tested-by: Nate Zimmer <nzimmer@sgi.com> Tested-by: Waiman Long <waiman.long@hp.com> Tested-by: Daniel J Blueman <daniel@numascale.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Robin Holt <robinmholt@gmail.com> Cc: Nate Zimmer <nzimmer@sgi.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Waiman Long <waiman.long@hp.com> Cc: Scott Norton <scott.norton@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15mm: remove rest of ACCESS_ONCE() usagesJason Low
We converted some of the usages of ACCESS_ONCE to READ_ONCE in the mm/ tree since it doesn't work reliably on non-scalar types. This patch removes the rest of the usages of ACCESS_ONCE, and use the new READ_ONCE API for the read accesses. This makes things cleaner, instead of using separate/multiple sets of APIs. Signed-off-by: Jason Low <jason.low2@hp.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Davidlohr Bueso <dave@stgolabs.net> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14mm/compaction: enhance compaction finish conditionJoonsoo Kim
Compaction has anti fragmentation algorithm. It is that freepage should be more than pageblock order to finish the compaction if we don't find any freepage in requested migratetype buddy list. This is for mitigating fragmentation, but, there is a lack of migratetype consideration and it is too excessive compared to page allocator's anti fragmentation algorithm. Not considering migratetype would cause premature finish of compaction. For example, if allocation request is for unmovable migratetype, freepage with CMA migratetype doesn't help that allocation and compaction should not be stopped. But, current logic regards this situation as compaction is no longer needed, so finish the compaction. Secondly, condition is too excessive compared to page allocator's logic. We can steal freepage from other migratetype and change pageblock migratetype on more relaxed conditions in page allocator. This is designed to prevent fragmentation and we can use it here. Imposing hard constraint only to the compaction doesn't help much in this case since page allocator would cause fragmentation again. To solve these problems, this patch borrows anti fragmentation logic from page allocator. It will reduce premature compaction finish in some cases and reduce excessive compaction work. stress-highalloc test in mmtests with non movable order 7 allocation shows considerable increase of compaction success rate. Compaction success rate (Compaction success * 100 / Compaction stalls, %) 31.82 : 42.20 I tested it on non-reboot 5 runs stress-highalloc benchmark and found that there is no more degradation on allocation success rate than before. That roughly means that this patch doesn't result in more fragmentations. Vlastimil suggests additional idea that we only test for fallbacks when migration scanner has scanned a whole pageblock. It looked good for fragmentation because chance of stealing increase due to making more free pages in certain pageblock. So, I tested it, but, it results in decreased compaction success rate, roughly 38.00. I guess the reason that if system is low memory condition, watermark check could be failed due to not enough order 0 free page and so, sometimes, we can't reach a fallback check although migrate_pfn is aligned to pageblock_nr_pages. I can insert code to cope with this situation but it makes code more complicated so I don't include his idea at this patch. [akpm@linux-foundation.org: fix CONFIG_CMA=n build] Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14mm: rename __mlock_vma_pages_range() to populate_vma_page_range()Kirill A. Shutemov
__mlock_vma_pages_range() doesn't necessarily mlock pages. It depends on vma flags. The same codepath is used for MAP_POPULATE. Let's rename __mlock_vma_pages_range() to populate_vma_page_range(). This patch also drops mlock_vma_pages_range() references from documentation. It has gone in cea10a19b797 ("mm: directly use __mlock_vma_pages_range() in find_extend_vma()"). Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: David Rientjes <rientjes@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12mm/internal.h: don't split printk call in twoRasmus Villemoes
All users of mminit_dprintk pass a compile-time constant as level, so this just makes gcc emit a single printk call instead of two. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Rik van Riel <riel@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Vishnu Pratap Singh <vishnu.ps@samsung.com> Cc: Pintu Kumar <pintu.k@samsung.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Li Zefan <lizefan@huawei.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-11mm: reduce try_to_compact_pages parametersVlastimil Babka
Expand the usage of the struct alloc_context introduced in the previous patch also for calling try_to_compact_pages(), to reduce the number of its parameters. Since the function is in different compilation unit, we need to move alloc_context definition in the shared mm/internal.h header. With this change we get simpler code and small savings of code size and stack usage: add/remove: 0/0 grow/shrink: 0/1 up/down: 0/-27 (-27) function old new delta __alloc_pages_direct_compact 283 256 -27 add/remove: 0/0 grow/shrink: 0/1 up/down: 0/-13 (-13) function old new delta try_to_compact_pages 582 569 -13 Stack usage of __alloc_pages_direct_compact goes from 24 to none (per scripts/checkstack.pl). Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Minchan Kim <minchan@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-10mm, compaction: always update cached scanner positionsVlastimil Babka
Compaction caches the migration and free scanner positions between compaction invocations, so that the whole zone gets eventually scanned and there is no bias towards the initial scanner positions at the beginning/end of the zone. The cached positions are continuously updated as scanners progress and the updating stops as soon as a page is successfully isolated. The reasoning behind this is that a pageblock where isolation succeeded is likely to succeed again in near future and it should be worth revisiting it. However, the downside is that potentially many pages are rescanned without successful isolation. At worst, there might be a page where isolation from LRU succeeds but migration fails (potentially always). So upon encountering this page, cached position would always stop being updated for no good reason. It might have been useful to let such page be rescanned with sync compaction after async one failed, but this is now handled by caching scanner position for async and sync mode separately since commit 35979ef33931 ("mm, compaction: add per-zone migration pfn cache for async compaction"). After this patch, cached positions are updated unconditionally. In stress-highalloc benchmark, this has decreased the numbers of scanned pages by few percent, without affecting allocation success rates. To prevent free scanner from leaving free pages behind after they are returned due to page migration failure, the cached scanner pfn is changed to point to the pageblock of the returned free page with the highest pfn, before leaving compact_zone(). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Cc: Minchan Kim <minchan@kernel.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Christoph Lameter <cl@linux.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-10mm, compaction: pass classzone_idx and alloc_flags to watermark checkingVlastimil Babka
Compaction relies on zone watermark checks for decisions such as if it's worth to start compacting in compaction_suitable() or whether compaction should stop in compact_finished(). The watermark checks take classzone_idx and alloc_flags parameters, which are related to the memory allocation request. But from the context of compaction they are currently passed as 0, including the direct compaction which is invoked to satisfy the allocation request, and could therefore know the proper values. The lack of proper values can lead to mismatch between decisions taken during compaction and decisions related to the allocation request. Lack of proper classzone_idx value means that lowmem_reserve is not taken into account. This has manifested (during recent changes to deferred compaction) when DMA zone was used as fallback for preferred Normal zone. compaction_suitable() without proper classzone_idx would think that the watermarks are already satisfied, but watermark check in get_page_from_freelist() would fail. Because of this problem, deferring compaction has extra complexity that can be removed in the following patch. The issue (not confirmed in practice) with missing alloc_flags is opposite in nature. For allocations that include ALLOC_HIGH, ALLOC_HIGHER or ALLOC_CMA in alloc_flags (the last includes all MOVABLE allocations on CMA-enabled systems) the watermark checking in compaction with 0 passed will be stricter than in get_page_from_freelist(). In these cases compaction might be running for a longer time than is really needed. Another issue compaction_suitable() is that the check for "does the zone need compaction at all?" comes only after the check "does the zone have enough free free pages to succeed compaction". The latter considers extra pages for migration and can therefore in some situations fail and return COMPACT_SKIPPED, although the high-order allocation would succeed and we should return COMPACT_PARTIAL. This patch fixes these problems by adding alloc_flags and classzone_idx to struct compact_control and related functions involved in direct compaction and watermark checking. Where possible, all other callers of compaction_suitable() pass proper values where those are known. This is currently limited to classzone_idx, which is sometimes known in kswapd context. However, the direct reclaim callers should_continue_reclaim() and compaction_ready() do not currently know the proper values, so the coordination between reclaim and compaction may still not be as accurate as it could. This can be fixed later, if it's shown to be an issue. Additionaly the checks in compact_suitable() are reordered to address the second issue described above. The effect of this patch should be slightly better high-order allocation success rates and/or less compaction overhead, depending on the type of allocations and presence of CMA. It allows simplifying deferred compaction code in a followup patch. When testing with stress-highalloc, there was some slight improvement (which might be just due to variance) in success rates of non-THP-like allocations. Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Cc: Minchan Kim <minchan@kernel.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Christoph Lameter <cl@linux.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm/page_alloc: restrict max order of merging on isolated pageblockJoonsoo Kim
Current pageblock isolation logic could isolate each pageblock individually. This causes freepage accounting problem if freepage with pageblock order on isolate pageblock is merged with other freepage on normal pageblock. We can prevent merging by restricting max order of merging to pageblock order if freepage is on isolate pageblock. A side-effect of this change is that there could be non-merged buddy freepage even if finishing pageblock isolation, because undoing pageblock isolation is just to move freepage from isolate buddy list to normal buddy list rather than to consider merging. So, the patch also makes undoing pageblock isolation consider freepage merge. When un-isolation, freepage with more than pageblock order and it's buddy are checked. If they are on normal pageblock, instead of just moving, we isolate the freepage and free it in order to get merged. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Heesub Shin <heesub.shin@samsung.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Ritesh Harjani <ritesh.list@gmail.com> Cc: Gioh Kim <gioh.kim@lge.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
