With CONFIG_COMPACTION enabled, kswapd does not try to free contiguous
free pages, even when it is woken for a higher order request.
This could be bad for eg. jumbo frame network allocations, which are done
from interrupt context and cannot compact memory themselves. Higher than
before allocation failure rates in the network receive path have been
observed in kernels with compaction enabled.
Teach kswapd to defragment the memory zones in a node, but only if
required and compaction is not deferred in a zone.
[akpm@linux-foundation.org: reduce scope of zones_need_compaction]
Signed-off-by: Rik van Riel <riel@redhat.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Hillf Danton <dhillf@gmail.com>
When isolating pages for migration, migration starts at the start of a
zone while the free scanner starts at the end of the zone. Migration
avoids entering a new zone by never going beyond the free scanned.
Unfortunately, in very rare cases nodes can overlap. When this happens,
migration isolates pages without the LRU lock held, corrupting lists
which will trigger errors in reclaim or during page free such as in the
following oops
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffff810f795c>] free_pcppages_bulk+0xcc/0x450
PGD 1dda554067 PUD 1e1cb58067 PMD 0
Oops: 0000 [#1] SMP
CPU 37
Pid: 17088, comm: memcg_process_s Tainted: G X
RIP: free_pcppages_bulk+0xcc/0x450
Process memcg_process_s (pid: 17088, threadinfo ffff881c2926e000, task ffff881c2926c0c0)
Call Trace:
free_hot_cold_page+0x17e/0x1f0
__pagevec_free+0x90/0xb0
release_pages+0x22a/0x260
pagevec_lru_move_fn+0xf3/0x110
putback_lru_page+0x66/0xe0
unmap_and_move+0x156/0x180
migrate_pages+0x9e/0x1b0
compact_zone+0x1f3/0x2f0
compact_zone_order+0xa2/0xe0
try_to_compact_pages+0xdf/0x110
__alloc_pages_direct_compact+0xee/0x1c0
__alloc_pages_slowpath+0x370/0x830
__alloc_pages_nodemask+0x1b1/0x1c0
alloc_pages_vma+0x9b/0x160
do_huge_pmd_anonymous_page+0x160/0x270
do_page_fault+0x207/0x4c0
page_fault+0x25/0x30
The "X" in the taint flag means that external modules were loaded but but
is unrelated to the bug triggering. The real problem was because the PFN
layout looks like this
Zone PFN ranges:
DMA 0x00000010 -> 0x00001000
DMA32 0x00001000 -> 0x00100000
Normal 0x00100000 -> 0x01e80000
Movable zone start PFN for each node
early_node_map[14] active PFN ranges
0: 0x00000010 -> 0x0000009b
0: 0x00000100 -> 0x0007a1ec
0: 0x0007a354 -> 0x0007a379
0: 0x0007f7ff -> 0x0007f800
0: 0x00100000 -> 0x00680000
1: 0x00680000 -> 0x00e80000
0: 0x00e80000 -> 0x01080000
1: 0x01080000 -> 0x01280000
0: 0x01280000 -> 0x01480000
1: 0x01480000 -> 0x01680000
0: 0x01680000 -> 0x01880000
1: 0x01880000 -> 0x01a80000
0: 0x01a80000 -> 0x01c80000
1: 0x01c80000 -> 0x01e80000
The fix is straight-forward. isolate_migratepages() has to make a
similar check to isolate_freepage to ensure that it never isolates pages
from a zone it does not hold the LRU lock for.
This was discovered in a 3.0-based kernel but it affects 3.1.x, 3.2.x
and current mainline.
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Cc: <stable@vger.kernel.org>
during isolation for migration
When isolating for migration, migration starts at the start of a zone
which is not necessarily pageblock aligned. Further, it stops isolating
when COMPACT_CLUSTER_MAX pages are isolated so migrate_pfn is generally
not aligned. This allows isolate_migratepages() to call pfn_to_page() on
an invalid PFN which can result in a crash. This was originally reported
against a 3.0-based kernel with the following trace in a crash dump.
PID: 9902 TASK: d47aecd0 CPU: 0 COMMAND: "memcg_process_s"
#0 [d72d3ad0] crash_kexec at c028cfdb
#1 [d72d3b24] oops_end at c05c5322
#2 [d72d3b38] __bad_area_nosemaphore at c0227e60
#3 [d72d3bec] bad_area at c0227fb6
#4 [d72d3c00] do_page_fault at c05c72ec
#5 [d72d3c80] error_code (via page_fault) at c05c47a4
EAX: 00000000 EBX: 000c0000 ECX: 00000001 EDX: 00000807 EBP: 000c0000
DS: 007b ESI: 00000001 ES: 007b EDI: f3000a80 GS: 6f50
CS: 0060 EIP: c030b15a ERR: ffffffff EFLAGS: 00010002
#6 [d72d3cb4] isolate_migratepages at c030b15a
#7 [d72d3d14] zone_watermark_ok at c02d26cb
#8 [d72d3d2c] compact_zone at c030b8de
#9 [d72d3d68] compact_zone_order at c030bba1
#10 [d72d3db4] try_to_compact_pages at c030bc84
#11 [d72d3ddc] __alloc_pages_direct_compact at c02d61e7
#12 [d72d3e08] __alloc_pages_slowpath at c02d66c7
#13 [d72d3e78] __alloc_pages_nodemask at c02d6a97
#14 [d72d3eb8] alloc_pages_vma at c030a845
#15 [d72d3ed4] do_huge_pmd_anonymous_page at c03178eb
#16 [d72d3f00] handle_mm_fault at c02f36c6
#17 [d72d3f30] do_page_fault at c05c70ed
#18 [d72d3fb0] error_code (via page_fault) at c05c47a4
EAX: b71ff000 EBX: 00000001 ECX: 00001600 EDX: 00000431
DS: 007b ESI: 08048950 ES: 007b EDI: bfaa3788
SS: 007b ESP: bfaa36e0 EBP: bfaa3828 GS: 6f50
CS: 0073 EIP: 080487c8 ERR: ffffffff EFLAGS: 00010202
It was also reported by Herbert van den Bergh against 3.1-based kernel
with the following snippet from the console log.
BUG: unable to handle kernel paging request at 01c00008
IP: [<c0522399>] isolate_migratepages+0x119/0x390
*pdpt = 000000002f7ce001 *pde = 0000000000000000
It is expected that it also affects 3.2.x and current mainline.
The problem is that pfn_valid is only called on the first PFN being
checked and that PFN is not necessarily aligned. Lets say we have a case
like this
H = MAX_ORDER_NR_PAGES boundary
| = pageblock boundary
m = cc->migrate_pfn
f = cc->free_pfn
o = memory hole
H------|------H------|----m-Hoooooo|ooooooH-f----|------H
The migrate_pfn is just below a memory hole and the free scanner is beyond
the hole. When isolate_migratepages started, it scans from migrate_pfn to
migrate_pfn+pageblock_nr_pages which is now in a memory hole. It checks
pfn_valid() on the first PFN but then scans into the hole where there are
not necessarily valid struct pages.
This patch ensures that isolate_migratepages calls pfn_valid when
necessary.
Reported-by: Herbert van den Bergh <herbert.van.den.bergh@oracle.com>
Tested-by: Herbert van den Bergh <herbert.van.den.bergh@oracle.com>
This patch adds a lightweight sync migrate operation MIGRATE_SYNC_LIGHT
mode that avoids writing back pages to backing storage. Async compaction
maps to MIGRATE_ASYNC while sync compaction maps to MIGRATE_SYNC_LIGHT.
For other migrate_pages users such as memory hotplug, MIGRATE_SYNC is
used.
This avoids sync compaction stalling for an excessive length of time,
particularly when copying files to a USB stick where there might be a
large number of dirty pages backed by a filesystem that does not support
->writepages.
[aarcange@redhat.com: This patch is heavily based on Andrea's work]
[akpm@linux-foundation.org: fix fs/nfs/write.c build]
[akpm@linux-foundation.org: fix fs/btrfs/disk-io.c build]
Cc: Dave Jones <davej@redhat.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Andy Isaacson <adi@hexapodia.org>
Cc: Nai Xia <nai.xia@gmail.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Commit 39deaf85 ("mm: compaction: make isolate_lru_page() filter-aware")
noted that compaction does not migrate dirty or writeback pages and that
is was meaningless to pick the page and re-add it to the LRU list. This
had to be partially reverted because some dirty pages can be migrated by
compaction without blocking.
This patch updates "mm: compaction: make isolate_lru_page" by skipping
over pages that migration has no possibility of migrating to minimise LRU
disruption.
Reviewed-by: Rik van Riel<riel@redhat.com>
Reviewed-by: Minchan Kim <minchan@kernel.org>
When asynchronous compaction was introduced, the
/proc/sys/vm/compact_memory handler should have been updated to always use
synchronous compaction. This did not happen so this patch addresses it.
The assumption is if a user writes to /proc/sys/vm/compact_memory, they
are willing for that process to stall.
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Short summary: There are severe stalls when a USB stick using VFAT is
used with THP enabled that are reduced by this series. If you are
experiencing this problem, please test and report back and considering I
have seen complaints from openSUSE and Fedora users on this as well as a
few private mails, I'm guessing it's a widespread issue. This is a new
type of USB-related stall because it is due to synchronous compaction
writing where as in the past the big problem was dirty pages reaching
the end of the LRU and being written by reclaim.
Am cc'ing Andrew this time and this series would replace
mm-do-not-stall-in-synchronous-compaction-for-thp-allocations.patch.
I'm also cc'ing Dave Jones as he might have merged that patch to Fedora
for wider testing and ideally it would be reverted and replaced by this
series.
That said, the later patches could really do with some review. If this
series is not the answer then a new direction needs to be discussed
because as it is, the stalls are unacceptable as the results in this
leader show.
For testers that try backporting this to 3.1, it won't work because
there is a non-obvious dependency on not writing back pages in direct
reclaim so you need those patches too.
Changelog since V5
o Rebase to 3.2-rc5
o Tidy up the changelogs a bit
Changelog since V4
o Added reviewed-bys, credited Andrea properly for sync-light
o Allow dirty pages without mappings to be considered for migration
o Bound the number of pages freed for compaction
o Isolate PageReclaim pages on their own LRU list
This is against 3.2-rc5 and follows on from discussions on "mm: Do
not stall in synchronous compaction for THP allocations" and "[RFC
PATCH 0/5] Reduce compaction-related stalls". Initially, the proposed
patch eliminated stalls due to compaction which sometimes resulted in
user-visible interactivity problems on browsers by simply never using
sync compaction. The downside was that THP success allocation rates
were lower because dirty pages were not being migrated as reported by
Andrea. His approach at fixing this was nacked on the grounds that
it reverted fixes from Rik merged that reduced the amount of pages
reclaimed as it severely impacted his workloads performance.
This series attempts to reconcile the requirements of maximising THP
usage, without stalling in a user-visible fashion due to compaction
or cheating by reclaiming an excessive number of pages.
Patch 1 partially reverts commit 39deaf85 to allow migration to isolate
dirty pages. This is because migration can move some dirty
pages without blocking.
Patch 2 notes that the /proc/sys/vm/compact_memory handler is not using
synchronous compaction when it should be. This is unrelated
to the reported stalls but is worth fixing.
Patch 3 checks if we isolated a compound page during lumpy scan and
account for it properly. For the most part, this affects
tracing so it's unrelated to the stalls but worth fixing.
Patch 4 notes that it is possible to abort reclaim early for compaction
and return 0 to the page allocator potentially entering the
"may oom" path. This has not been observed in practice but
the rest of the series potentially makes it easier to happen.
Patch 5 adds a sync parameter to the migratepage callback and gives
the callback responsibility for migrating the page without
blocking if sync==false. For example, fallback_migrate_page
will not call writepage if sync==false. This increases the
number of pages that can be handled by asynchronous compaction
thereby reducing stalls.
Patch 6 restores filter-awareness to isolate_lru_page for migration.
In practice, it means that pages under writeback and pages
without a ->migratepage callback will not be isolated
for migration.
Patch 7 avoids calling direct reclaim if compaction is deferred but
makes sure that compaction is only deferred if sync
compaction was used.
Patch 8 introduces a sync-light migration mechanism that sync compaction
uses. The objective is to allow some stalls but to not call
->writepage which can lead to significant user-visible stalls.
Patch 9 notes that while we want to abort reclaim ASAP to allow
compation to go ahead that we leave a very small window of
opportunity for compaction to run. This patch allows more pages
to be freed by reclaim but bounds the number to a reasonable
level based on the high watermark on each zone.
Patch 10 allows slabs to be shrunk even after compaction_ready() is
true for one zone. This is to avoid a problem whereby a single
small zone can abort reclaim even though no pages have been
reclaimed and no suitably large zone is in a usable state.
Patch 11 fixes a problem with the rate of page scanning. As reclaim is
rarely stalling on pages under writeback it means that scan
rates are very high. This is particularly true for direct
reclaim which is not calling writepage. The vmstat figures
implied that much of this was busy work with PageReclaim pages
marked for immediate reclaim. This patch is a prototype that
moves these pages to their own LRU list.
This has been tested and other than 2 USB keys getting trashed,
nothing horrible fell out. That said, I am a bit unhappy with the
rescue logic in patch 11 but did not find a better way around it. It
does significantly reduce scan rates and System CPU time indicating
it is the right direction to take.
What is of critical importance is that stalls due to compaction
are massively reduced even though sync compaction was still
allowed. Testing from people complaining about stalls copying to USBs
with THP enabled are particularly welcome.
The following tests all involve THP usage and USB keys in some
way. Each test follows this type of pattern
1. Read from some fast fast storage, be it raw device or file. Each time
the copy finishes, start again until the test ends
2. Write a large file to a filesystem on a USB stick. Each time the copy
3. When memory is low, start an alloc process that creates a mapping
the size of physical memory to stress THP allocation. This is the
"real" part of the test and the part that is meant to trigger
stalls when THP is enabled. Copying continues in the background.
4. Record the CPU usage and time to execute of the alloc process
5. Record the number of THP allocs and fallbacks as well as the number of THP
pages in use a the end of the test just before alloc exited
6. Run the test 5 times to get an idea of variability
7. Between each run, sync is run and caches dropped and the test
waits until nr_dirty is a small number to avoid interference
or caching between iterations that would skew the figures.
The individual tests were then
writebackCPDeviceBasevfat
Disable THP, read from a raw device (sda), vfat on USB stick
writebackCPDeviceBaseext4
Disable THP, read from a raw device (sda), ext4 on USB stick
writebackCPDevicevfat
THP enabled, read from a raw device (sda), vfat on USB stick
writebackCPDeviceext4
THP enabled, read from a raw device (sda), ext4 on USB stick
writebackCPFilevfat
THP enabled, read from a file on fast storage and USB, both vfat
writebackCPFileext4
THP enabled, read from a file on fast storage and USB, both ext4
The kernels tested were
3.1 3.1
vanilla 3.2-rc5
freemore Patches 1-10
immediate Patches 1-11
andrea The 8 patches Andrea posted as a basis of comparison
The results are very long unfortunately. I'll start with the case
where we are not using THP at all
3.1.0-vanilla rc5-vanilla freemore-v6r1 isolate-v6r1 andrea-v2r1
System Time 1.28 ( 0.00%) 54.49 (-4143.46%) 48.63 (-3687.69%) 4.69 ( -265.11%) 51.88 (-3940.81%)
+/- 0.06 ( 0.00%) 2.45 (-4305.55%) 4.75 (-8430.57%) 7.46 (-13282.76%) 4.76 (-8440.70%)
User Time 0.09 ( 0.00%) 0.05 ( 40.91%) 0.06 ( 29.55%) 0.07 ( 15.91%) 0.06 ( 27.27%)
+/- 0.02 ( 0.00%) 0.01 ( 45.39%) 0.02 ( 25.07%) 0.00 ( 77.06%) 0.01 ( 52.24%)
Elapsed Time 110.27 ( 0.00%) 56.38 ( 48.87%) 49.95 ( 54.70%) 11.77 ( 89.33%) 53.43 ( 51.54%)
+/- 7.33 ( 0.00%) 3.77 ( 48.61%) 4.94 ( 32.63%) 6.71 ( 8.50%) 4.76 ( 35.03%)
THP Active 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%)
+/- 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%)
Fault Alloc 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%)
Fault Fallback 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%)
The THP figures are obviously all 0 because THP was enabled. The
main thing to watch is the elapsed times and how they compare to
times when THP is enabled later. It's also important to note that
elapsed time is improved by this series as System CPu time is much
reduced.
System Time 1.22 ( 0.00%) 13.89 (-1040.72%) 46.40 (-3709.20%) 4.44 ( -264.37%) 47.37 (-3789.33%)
+/- 0.06 ( 0.00%) 22.82 (-37635.56%) 3.84 (-6249.44%) 6.48 (-10618.92%) 6.60
(-10818.53%)
User Time 0.06 ( 0.00%) 0.06 ( -6.90%) 0.05 ( 17.24%) 0.05 ( 13.79%) 0.04 ( 31.03%)
+/- 0.01 ( 0.00%) 0.01 ( 33.33%) 0.01 ( 33.33%) 0.01 ( 39.14%) 0.01 ( 25.46%)
Elapsed Time 10445.54 ( 0.00%) 2249.92 ( 78.46%) 70.06 ( 99.33%) 16.59 ( 99.84%) 472.43 (
95.48%)
+/- 643.98 ( 0.00%) 811.62 ( -26.03%) 10.02 ( 98.44%) 7.03 ( 98.91%) 59.99 ( 90.68%)
THP Active 15.60 ( 0.00%) 35.20 ( 225.64%) 65.00 ( 416.67%) 70.80 ( 453.85%) 62.20 ( 398.72%)
+/- 18.48 ( 0.00%) 51.29 ( 277.59%) 15.99 ( 86.52%) 37.91 ( 205.18%) 22.02 ( 119.18%)
Fault Alloc 121.80 ( 0.00%) 76.60 ( 62.89%) 155.40 ( 127.59%) 181.20 ( 148.77%) 286.60 ( 235.30%)
+/- 73.51 ( 0.00%) 61.11 ( 83.12%) 34.89 ( 47.46%) 31.88 ( 43.36%) 68.13 ( 92.68%)
Fault Fallback 881.20 ( 0.00%) 926.60 ( -5.15%) 847.60 ( 3.81%) 822.00 ( 6.72%) 716.60 ( 18.68%)
+/- 73.51 ( 0.00%) 61.26 ( 16.67%) 34.89 ( 52.54%) 31.65 ( 56.94%) 67.75 ( 7.84%)
MMTests Statistics: duration
User/Sys Time Running Test (seconds) 3540.88 1945.37 716.04 64.97 1937.03
Total Elapsed Time (seconds) 52417.33 11425.90 501.02 230.95 2520.28
The first thing to note is the "Elapsed Time" for the vanilla kernels
of 2249 seconds versus 56 with THP disabled which might explain the
reports of USB stalls with THP enabled. Applying the patches brings
performance in line with THP-disabled performance while isolating
pages for immediate reclaim from the LRU cuts down System CPU time.
The "Fault Alloc" success rate figures are also improved. The vanilla
kernel only managed to allocate 76.6 pages on average over the course
of 5 iterations where as applying the series allocated 181.20 on
average albeit it is well within variance. It's worth noting that
applies the series at least descreases the amount of variance which
implies an improvement.
Andrea's series had a higher success rate for THP allocations but
at a severe cost to elapsed time which is still better than vanilla
but still much worse than disabling THP altogether. One can bring my
series close to Andrea's by removing this check
* If compaction is deferred for high-order allocations, it is because
* sync compaction recently failed. In this is the case and the caller
* has requested the system not be heavily disrupted, fail the
* allocation now instead of entering direct reclaim
if (deferred_compaction && (gfp_mask & __GFP_NO_KSWAPD))
goto nopage;
I didn't include a patch that removed the above check because hurting
overall performance to improve the THP figure is not what the average
user wants. It's something to consider though if someone really wants
to maximise THP usage no matter what it does to the workload initially.
This is summary of vmstat figures from the same test.
Page Ins 3257266139 1111844061 17263623 10901575 161423219
Page Outs 81054922 30364312 3626530 3657687 8753730
Swap Ins 3294 2851 6560 4964 4592
Swap Outs 390073 528094 620197 790912 698285
Direct pages scanned 1077581700 3024951463 1764930052 115140570 5901188831
Kswapd pages scanned 34826043 7112868 2131265 1686942 1893966
Kswapd pages reclaimed 28950067 4911036 1246044 966475 1497726
Direct pages reclaimed 805148398 280167837 3623473 2215044 40809360
Kswapd efficiency 83% 69% 58% 57% 79%
Kswapd velocity 664.399 622.521 4253.852 7304.360 751.490
Direct efficiency 74% 9% 0% 1% 0%
Direct velocity 20557.737 264745.137 3522673.849 498551.938 2341481.435
Percentage direct scans 96% 99% 99% 98% 99%
Page writes by reclaim 722646 529174 620319 791018 699198
Page writes file 332573 1080 122 106 913
Page writes anon 390073 528094 620197 790912 698285
Page reclaim immediate 0 2552514720 1635858848 111281140 5478375032
Page rescued immediate 0 0 0 87848 0
Slabs scanned 23552 23552 9216 8192 9216
Direct inode steals 231 0 0 0 0
Kswapd inode steals 0 0 0 0 0
Kswapd skipped wait 28076 786 0 61 6
THP fault alloc 609 383 753 906 1433
THP collapse alloc 12 6 0 0 6
THP splits 536 211 456 593 1136
THP fault fallback 4406 4633 4263 4110 3583
THP collapse fail 120 127 0 0 4
Compaction stalls 1810 728 623 779 3200
Compaction success 196 53 60 80 123
Compaction failures 1614 675 563 699 3077
Compaction pages moved 193158 53545 243185 333457 226688
Compaction move failure 9952 9396 16424 23676 45070
The main things to look at are
1. Page In/out figures are much reduced by the series.
2. Direct page scanning is incredibly high (264745.137 pages scanned
per second on the vanilla kernel) but isolating PageReclaim pages
on their own list reduces the number of pages scanned significantly.
3. The fact that "Page rescued immediate" is a positive number implies
that we sometimes race removing pages from the LRU_IMMEDIATE list
that need to be put back on a normal LRU but it happens only for
0.07% of the pages marked for immediate reclaim.
System Time 1.51 ( 0.00%) 1.77 ( -17.66%) 1.46 ( 2.92%) 1.15 ( 23.77%) 1.89 ( -25.63%)
+/- 0.27 ( 0.00%) 0.67 ( -148.52%) 0.33 ( -22.76%) 0.30 ( -11.15%) 0.19 ( 30.16%)
User Time 0.03 ( 0.00%) 0.04 ( -37.50%) 0.05 ( -62.50%) 0.07 ( -112.50%) 0.04 ( -18.75%)
+/- 0.01 ( 0.00%) 0.02 ( -146.64%) 0.02 ( -97.91%) 0.02 ( -75.59%) 0.02 ( -63.30%)
Elapsed Time 124.93 ( 0.00%) 114.49 ( 8.36%) 96.77 ( 22.55%) 27.48 ( 78.00%) 205.70 ( -64.65%)
+/- 20.20 ( 0.00%) 74.39 ( -268.34%) 59.88 ( -196.48%) 7.72 ( 61.79%) 25.03 ( -23.95%)
THP Active 161.80 ( 0.00%) 83.60 ( 51.67%) 141.20 ( 87.27%) 84.60 ( 52.29%) 82.60 ( 51.05%)
+/- 71.95 ( 0.00%) 43.80 ( 60.88%) 26.91 ( 37.40%) 59.02 ( 82.03%) 52.13 ( 72.45%)
Fault Alloc 471.40 ( 0.00%) 228.60 ( 48.49%) 282.20 ( 59.86%) 225.20 ( 47.77%) 388.40 ( 82.39%)
+/- 88.07 ( 0.00%) 87.42 ( 99.26%) 73.79 ( 83.78%) 109.62 ( 124.47%) 82.62 ( 93.81%)
Fault Fallback 531.60 ( 0.00%) 774.60 ( -45.71%) 720.80 ( -35.59%) 777.80 ( -46.31%) 614.80 ( -15.65%)
+/- 88.07 ( 0.00%) 87.26 ( 0.92%) 73.79 ( 16.22%) 109.62 ( -24.47%) 82.29 ( 6.56%)
User/Sys Time Running Test (seconds) 50.22 33.76 30.65 24.14 128.45
Total Elapsed Time (seconds) 1113.73 1132.19 1029.45 759.49 1707.26
Similar test but the USB stick is using ext4 instead of vfat. As
ext4 does not use writepage for migration, the large stalls due to
compaction when THP is enabled are not observed. Still, isolating
PageReclaim pages on their own list helped completion time largely
by reducing the number of pages scanned by direct reclaim although
time spend in congestion_wait could also be a factor.
Again, Andrea's series had far higher success rates for THP allocation
at the cost of elapsed time. I didn't look too closely but a quick
look at the vmstat figures tells me kswapd reclaimed 8 times more pages
than the patch series and direct reclaim reclaimed roughly three times
as many pages. It follows that if memory is aggressively reclaimed,
there will be more available for THP.
writebackCPFilevfat
System Time 1.76 ( 0.00%) 29.10 (-1555.52%) 46.01 (-2517.18%) 4.79 ( -172.35%) 54.89 (-3022.53%)
+/- 0.14 ( 0.00%) 25.61 (-18185.17%) 2.15 (-1434.83%) 6.60 (-4610.03%) 9.75
(-6863.76%)
User Time 0.05 ( 0.00%) 0.07 ( -45.83%) 0.05 ( -4.17%) 0.06 ( -29.17%) 0.06 ( -16.67%)
+/- 0.02 ( 0.00%) 0.02 ( 20.11%) 0.02 ( -3.14%) 0.01 ( 31.58%) 0.01 ( 47.41%)
Elapsed Time 22520.79 ( 0.00%) 1082.85 ( 95.19%) 73.30 ( 99.67%) 32.43 ( 99.86%) 291.84 ( 98.70%)
+/- 7277.23 ( 0.00%) 706.29 ( 90.29%) 19.05 ( 99.74%) 17.05 ( 99.77%) 125.55 ( 98.27%)
THP Active 83.80 ( 0.00%) 12.80 ( 15.27%) 15.60 ( 18.62%) 13.00 ( 15.51%) 0.80 ( 0.95%)
+/- 66.81 ( 0.00%) 20.19 ( 30.22%) 5.92 ( 8.86%) 15.06 ( 22.54%) 1.17 ( 1.75%)
Fault Alloc 171.00 ( 0.00%) 67.80 ( 39.65%) 97.40 ( 56.96%) 125.60 ( 73.45%) 133.00 ( 77.78%)
+/- 82.91 ( 0.00%) 30.69 ( 37.02%) 53.91 ( 65.02%) 55.05 ( 66.40%) 21.19 ( 25.56%)
Fault Fallback 832.00 ( 0.00%) 935.20 ( -12.40%) 906.00 ( -8.89%) 877.40 ( -5.46%) 870.20 ( -4.59%)
+/- 82.91 ( 0.00%) 30.69 ( 62.98%) 54.01 ( 34.86%) 55.05 ( 33.60%) 20.91 ( 74.78%)
User/Sys Time Running Test (seconds) 7229.81 928.42 704.52 80.68 1330.76
Total Elapsed Time (seconds) 112849.04 5618.69 571.11 360.54 1664.28
In this case, the test is reading/writing only from filesystems but as
it's vfat, it's slow due to calling writepage during compaction. Little
to observe really - the time to complete the test goes way down
with the series applied and THP allocation success rates go up in
comparison to 3.2-rc5. The success rates are lower than 3.1.0 but
the elapsed time for that kernel is abysmal so it is not really a
sensible comparison.
As before, Andrea's series allocates more THPs at the cost of overall
performance.
writebackCPFileext4
Same type of story - elapsed times go down. In this case, allocation
success rates are roughtly the same. As before, Andrea's has higher
success rates but takes a lot longer.
Overall the series does reduce latencies and while the tests are
inherency racy as alloc competes with the cp processes, the variability
was included. The THP allocation rates are not as high as they could
be but that is because we would have to be more aggressive about
reclaim and compaction impacting overall performance.
This patch:
What was missed during review is that asynchronous migration moves dirty
pages if their ->migratepage callback is migrate_page() because these can
be moved without blocking. This potentially impacted hugepage allocation
success rates by a factor depending on how many dirty pages are in the
system.
This patch partially reverts 39deaf85 to allow migration to isolate dirty
pages again. This increases how much compaction disrupts the LRU but that
is addressed later in the series.
After isolated the current pfn will no longer be scanned and isolated if
the next round is necessary, so push the isolate_migratepages search base
of the given compact_control one step ahead.
Signed-off-by: Hillf Danton <dhillf@gmail.com>
This moves the 'memory sysdev_class' over to a regular 'memory' subsystem
and converts the devices to regular devices. The sysdev drivers are
implemented as subsystem interfaces now.
After all sysdev classes are ported to regular driver core entities, the
sysdev implementation will be entirely removed from the kernel.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
There's no compact_zone_order() user outside file scope, so make it static.
Acked-by: David Rientjes <rientjes@google.com>
In async mode, compaction doesn't migrate dirty or writeback pages. So,
it's meaningless to pick the page and re-add it to lru list.
Of course, when we isolate the page in compaction, the page might be dirty
or writeback but when we try to migrate the page, the page would be not
dirty, writeback. So it could be migrated. But it's very unlikely as
isolate and migration cycle is much faster than writeout.
So, this patch helps cpu overhead and prevent unnecessary LRU churning.
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Change ISOLATE_XXX macro with bitwise isolate_mode_t type. Normally,
macro isn't recommended as it's type-unsafe and making debugging harder as
symbol cannot be passed throught to the debugger.
Quote from Johannes
" Hmm, it would probably be cleaner to fully convert the isolation mode
into independent flags. INACTIVE, ACTIVE, BOTH is currently a
tri-state among flags, which is a bit ugly."
This patch moves isolate mode from swap.h to mmzone.h by memcontrol.h
acct_isolated of compaction uses page_lru_base_type which returns only
base type of LRU list so it never returns LRU_ACTIVE_ANON or
LRU_ACTIVE_FILE. In addtion, cc->nr_[anon|file] is used in only
acct_isolated so it doesn't have fields in conpact_control.
This patch removes fields from compact_control and makes clear function of
acct_issolated which counts the number of anon|file pages isolated.
is asynchronous V2
Asynchronous compaction is used when promoting to huge pages. This is all
very nice but if there are a number of processes in compacting memory, a
large number of pages can be isolated. An "asynchronous" process can
stall for long periods of time as a result with a user reporting that
firefox can stall for 10s of seconds. This patch aborts asynchronous
compaction if too many pages are isolated as it's better to fail a
hugepage promotion than stall a process.
[minchan.kim@gmail.com: return COMPACT_PARTIAL for abort]
Reported-and-tested-by: Ury Stankevich <urykhy@gmail.com>
next zone
Compaction works with two scanners, a migration and a free scanner. When
the scanners crossover, migration within the zone is complete. The
location of the scanner is recorded on each cycle to avoid excesive
scanning.
When a zone is small and mostly reserved, it's very easy for the migration
scanner to be close to the end of the zone. Then the following situation
can occurs
o migration scanner isolates some pages near the end of the zone
o free scanner starts at the end of the zone but finds that the
migration scanner is already there
o free scanner gets reinitialised for the next cycle as
cc->migrate_pfn + pageblock_nr_pages
moving the free scanner into the next zone
o migration scanner moves into the next zone
When this happens, NR_ISOLATED accounting goes haywire because some of the
accounting happens against the wrong zone. One zones counter remains
positive while the other goes negative even though the overall global
count is accurate. This was reported on X86-32 with !SMP because !SMP
allows the negative counters to be visible. The fact that it is the bug
should theoritically be possible there.
fragmentation_index() returns -1000 when the allocation might succeed
This doesn't match the comment and code in compaction_suitable(). I
thought compaction_suitable should return COMPACT_PARTIAL in -1000
case, because in this case allocation could succeed depending on
watermarks.
The impact of this is that compaction starts and compact_finished() is
called which rechecks the watermarks and the free lists. It should have
the same result in that compaction should not start but is more expensive.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Commit 56de7263fcf3 ("mm: compaction: direct compact when a high-order
allocation fails") introduced a check for cc->order == -1 in
compact_finished. We should continue compacting in that case because
the request came from userspace and there is no particular order to
compact for. Similar check has been added by 82478fb7 (mm: compaction:
prevent division-by-zero during user-requested compaction) for
compaction_suitable.
The check is, however, done after zone_watermark_ok which uses order as a
right hand argument for shifts. Not only watermark check is pointless if
we can break out without it but it also uses 1 << -1 which is not well
defined (at least from C standard). Let's move the -1 check above
zone_watermark_ok.
[minchan.kim@gmail.com> - caught compaction_suitable]
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hioryu@jp.fujitsu.com>
for migration
compaction_alloc() isolates pages for migration in isolate_migratepages.
While it's scanning, IRQs are disabled on the mistaken assumption the
scanning should be short. Tests show this to be true for the most part
but contention times on the LRU lock can be increased. Before this patch,
the IRQ disabled times for a simple test looked like
Total sampled time IRQs off (not real total time): 5493
Event shrink_inactive_list..shrink_zone 1596 us count 1
Event shrink_inactive_list..shrink_zone 1530 us count 1
Event shrink_inactive_list..shrink_zone 956 us count 1
Event shrink_inactive_list..shrink_zone 541 us count 1
Event shrink_inactive_list..shrink_zone 531 us count 1
Event split_huge_page..add_to_swap 232 us count 1
Event save_args..call_softirq 36 us count 1
Event save_args..call_softirq 35 us count 2
Event __wake_up..__wake_up 1 us count 1
This patch reduces the worst-case IRQs-disabled latencies by releasing the
lock every SWAP_CLUSTER_MAX pages that are scanned and releasing the CPU if
necessary. The cost of this is that the processing performing compaction will
be slower but IRQs being disabled for too long a time has worse consequences
as the following report shows;
Total sampled time IRQs off (not real total time): 4367
Event shrink_inactive_list..shrink_zone 881 us count 1
Event shrink_inactive_list..shrink_zone 875 us count 1
Event shrink_inactive_list..shrink_zone 868 us count 1
Event shrink_inactive_list..shrink_zone 555 us count 1
Event split_huge_page..add_to_swap 495 us count 1
Event compact_zone..compact_zone_order 269 us count 1
Event split_huge_page..add_to_swap 266 us count 1
Event shrink_inactive_list..shrink_zone 85 us count 1
Event save_args..call_softirq 36 us count 2
[akpm@linux-foundation.org: simplify with s/unlocked/locked/]
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Arthur Marsh <arthur.marsh@internode.on.net>
Cc: Clemens Ladisch <cladisch@googlemail.com>
compaction_alloc() isolates free pages to be used as migration targets.
While its scanning, IRQs are disabled on the mistaken assumption the
scanning should be short. Analysis showed that IRQs were in fact being
disabled for substantial time. A simple test was run using large
anonymous mappings with transparent hugepage support enabled to trigger
frequent compactions. A monitor sampled what the worst IRQ-off latencies
were and a post-processing tool found the following;
Total sampled time IRQs off (not real total time): 22355
Event compaction_alloc..compaction_alloc 8409 us count 1
Event compaction_alloc..compaction_alloc 7341 us count 1
Event compaction_alloc..compaction_alloc 2463 us count 1
Event compaction_alloc..compaction_alloc 2054 us count 1
Event shrink_inactive_list..shrink_zone 1864 us count 1
Event shrink_inactive_list..shrink_zone 88 us count 1
Event __make_request..__blk_run_queue 24 us count 1
Event __alloc_pages_nodemask..__alloc_pages_nodemask 6 us count 1
i.e. compaction is disabled IRQs for a prolonged period of time - 8ms in
one instance. The full report generated by the tool can be found at
http://www.csn.ul.ie/~mel/postings/minfree-20110225/irqsoff-vanilla-micro.report
This patch reduces the time IRQs are disabled by simply disabling IRQs at
the last possible minute. An updated IRQs-off summary report then looks
like;
A full report is again available at
http://www.csn.ul.ie/~mel/postings/minfree-20110225/irqsoff-minimiseirq-free-v1r4-micro.report
As should be obvious, IRQ disabled latencies due to compaction are
almost elimimnated for this particular test.
[aarcange@redhat.com: Fix initialisation of isolated]
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujisu.com>
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
Many migrate_page's caller check return value instead of list_empy by
cf608ac19c ("mm: compaction: fix COMPACTPAGEFAILED counting"). This patch
makes compaction's migrate_pages consistent with others. This patch
should not change old behavior.
Cc: Christoph Lameter <cl@linux.com>
This patch reverts 5a03b051 ("thp: use compaction in kswapd for GFP_ATOMIC
order > 0") due to reports stating that kswapd CPU usage was higher and
IRQs were being disabled more frequently. This was reported at
http://www.spinics.net/linux/fedora/alsa-user/msg09885.html.
Without this patch applied, CPU usage by kswapd hovers around the 20% mark
according to the tester (Arthur Marsh:
http://www.spinics.net/linux/fedora/alsa-user/msg09899.html). With this
patch applied, it's around 2%.
The problem is not related to THP which specifies __GFP_NO_KSWAPD but is
triggered by high-order allocations hitting the low watermark for their
order and waking kswapd on kernels with CONFIG_COMPACTION set. The most
common trigger for this is network cards configured for jumbo frames but
it's also possible it'll be triggered by fork-heavy workloads (order-1)
and some wireless cards which depend on order-1 allocations.
The symptoms for the user will be high CPU usage by kswapd in low-memory
situations which could be confused with another writeback problem. While
a patch like 5a03b051 may be reintroduced in the future, this patch plays
it safe for now and reverts it.
[mel@csn.ul.ie: Beefed up the changelog]
Reported-by: Arthur Marsh <arthur.marsh@internode.on.net>
Tested-by: Arthur Marsh <arthur.marsh@internode.on.net>
Cc: <stable@kernel.org> [2.6.38.1]
Up until 3e7d344 ("mm: vmscan: reclaim order-0 and use compaction instead
of lumpy reclaim"), compaction skipped calculating the fragmentation index
of a zone when compaction was explicitely requested through the procfs
knob.
However, when compaction_suitable was introduced, it did not come with an
extra check for order == -1, set on explicit compaction requests, and
passed this order on to the fragmentation index calculation, where it
overshifts the number of requested pages, leading to a division by zero.
This patch makes sure that order == -1 is recognized as the flag it is
rather than passing it along as valid order parameter.
[akpm@linux-foundation.org: add comment, per Mel]
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Mel Gorman <mel@csn.ul.ie>
It makes no sense not to enable compaction for small order pages as we
don't want to end up with bad order 2 allocations and good and graceful
order 9 allocations.
This takes advantage of memory compaction to properly generate pages of
order > 0 if regular page reclaim fails and priority level becomes more
severe and we don't reach the proper watermarks.
It's not worth migrating transparent hugepages during compaction. Those
hugepages don't create fragmentation.
try_to_compact_pages() is initially called to only migrate pages
asychronously and kswapd always compacts asynchronously. Both are being
optimistic so it is important to complete the work as quickly as possible
to minimise stalls.
This patch alters the scanner when asynchronous to only consider
MIGRATE_MOVABLE pageblocks as migration candidates. This reduces stalls
when allocating huge pages while not impairing allocation success rates as
a full scan will be performed if necessary after direct reclaim.
Cc: Andy Whitcroft <apw@shadowen.org>
sync
With the introduction of the boolean sync parameter, the API looks a
little inconsistent as offlining is still an int. Convert offlining to a
bool for the sake of being tidy.
synchronous compaction in the faster path
Migration synchronously waits for writeback if the initial passes fails.
Callers of memory compaction do not necessarily want this behaviour if the
caller is latency sensitive or expects that synchronous migration is not
going to have a significantly better success rate.
This patch adds a sync parameter to migrate_pages() allowing the caller to
indicate if wait_on_page_writeback() is allowed within migration or not.
For reclaim/compaction, try_to_compact_pages() is first called
asynchronously, direct reclaim runs and then try_to_compact_pages() is
called synchronously as there is a greater expectation that it'll succeed.
[akpm@linux-foundation.org: build/merge fix]
Lumpy reclaim is disruptive. It reclaims a large number of pages and
ignores the age of the pages it reclaims. This can incur significant
stalls and potentially increase the number of major faults.
Compaction has reached the point where it is considered reasonably stable
(meaning it has passed a lot of testing) and is a potential candidate for
displacing lumpy reclaim. This patch introduces an alternative to lumpy
reclaim whe compaction is available called reclaim/compaction. The basic
operation is very simple - instead of selecting a contiguous range of
pages to reclaim, a number of order-0 pages are reclaimed and then
compaction is later by either kswapd (compact_zone_order()) or direct
compaction (__alloc_pages_direct_compact()).
[akpm@linux-foundation.org: fix build]
[akpm@linux-foundation.org: use conventional task_struct naming]
In preparation for a patches promoting the use of memory compaction over
lumpy reclaim, this patch adds trace points for memory compaction
activity. Using them, we can monitor the scanning activity of the
migration and free page scanners as well as the number and success rates
of pages passed to page migration.
del_page_from_lru_list() already called mem_cgroup_del_lru(). So we must
not call it again. It adds unnecessary overhead.
It was not a runtime bug because the TestClearPageCgroupAcctLRU() early in
mem_cgroup_del_lru_list() will prevent any double-deletion, etc.
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Iram reported that compaction's too_many_isolated() loops forever.
(http://www.spinics.net/lists/linux-mm/msg08123.html)
The meminfo when the situation happened was inactive anon is zero. That's
because the system has no memory pressure until then. While all anon
pages were in the active lru, compaction could select active lru as well
as inactive lru. That's a different thing from vmscan's isolated. So we
has been two too_many_isolated.
While compaction can isolate pages in both active and inactive, current
implementation of too_many_isolated only considers inactive. It made
Iram's problem.
This patch handles active and inactive fairly. That's because we can't
expect where from and how many compaction would isolated pages.
This patch changes (nr_isolated > nr_inactive) with
nr_isolated > (nr_active + nr_inactive) / 2.
Reported-by: Iram Shahzad <iram.shahzad@jp.fujitsu.com>
Acked-by: Wu Fengguang <fengguang.wu@intel.com>
and when it should be reclaimed
The kernel applies some heuristics when deciding if memory should be
compacted or reclaimed to satisfy a high-order allocation. One of these
is based on the fragmentation. If the index is below 500, memory will not
be compacted. This choice is arbitrary and not based on data. To help
optimise the system and set a sensible default for this value, this patch
adds a sysctl extfrag_threshold. The kernel will only compact memory if
the fragmentation index is above the extfrag_threshold.
[randy.dunlap@oracle.com: Fix build errors when proc fs is not configured]
Ordinarily when a high-order allocation fails, direct reclaim is entered
to free pages to satisfy the allocation. With this patch, it is
determined if an allocation failed due to external fragmentation instead
of low memory and if so, the calling process will compact until a suitable
page is freed. Compaction by moving pages in memory is considerably
cheaper than paging out to disk and works where there are locked pages or
no swap. If compaction fails to free a page of a suitable size, then
reclaim will still occur.
Direct compaction returns as soon as possible. As each block is
compacted, it is checked if a suitable page has been freed and if so, it
returns.
[akpm@linux-foundation.org: Fix build errors]
[aarcange@redhat.com: fix count_vm_event preempt in memory compaction direct reclaim]
Add a per-node sysfs file called compact. When the file is written to,
each zone in that node is compacted. The intention that this would be
used by something like a job scheduler in a batch system before a job
starts so that the job can allocate the maximum number of hugepages
without significant start-up cost.
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Add a proc file /proc/sys/vm/compact_memory. When an arbitrary value is
written to the file, all zones are compacted. The expected user of such a
trigger is a job scheduler that prepares the system before the target
application runs.
This patch is the core of a mechanism which compacts memory in a zone by
relocating movable pages towards the end of the zone.
A single compaction run involves a migration scanner and a free scanner.
Both scanners operate on pageblock-sized areas in the zone. The migration
scanner starts at the bottom of the zone and searches for all movable
pages within each area, isolating them onto a private list called
migratelist. The free scanner starts at the top of the zone and searches
for suitable areas and consumes the free pages within making them
available for the migration scanner. The pages isolated for migration are
then migrated to the newly isolated free pages.
[aarcange@redhat.com: Fix unsafe optimisation]
[mel@csn.ul.ie: do not schedule work on other CPUs for compaction]
