If the completion of a wb_writeback_work can be waited upon by setting
its ->done to a struct completion and waiting on it; however, for
cgroup writeback support, it's necessary to issue multiple work items
to multiple bdi_writebacks and wait for the completion of all.
This patch implements wb_completion which can wait for multiple work
items and replaces the struct completion with it. It can be defined
using DEFINE_WB_COMPLETION_ONSTACK(), used for multiple work items and
waited for by wb_wait_for_completion().
Nobody currently issues multiple work items and this patch doesn't
introduce any behavior changes.
Cc: Jan Kara <jack@suse.cz>
Signed-off-by: Jens Axboe <axboe@fb.com>
bdi_has_dirty_io() used to only reflect whether the root wb
(bdi_writeback) has dirty inodes. For cgroup writeback support, it
needs to take all active wb's into account. If any wb on the bdi has
dirty inodes, bdi_has_dirty_io() should return true.
To achieve that, as inode_wb_list_{move|del}_locked() now keep track
of the dirty state transition of each wb, the number of dirty wbs can
be counted in the bdi; however, bdi is already aggregating
wb->avg_write_bandwidth which can easily be guaranteed to be > 0 when
there are any dirty inodes by ensuring wb->avg_write_bandwidth can't
dip below 1. bdi_has_dirty_io() can simply test whether
bdi->tot_write_bandwidth is zero or not.
While this bumps the value of wb->avg_write_bandwidth to one when it
used to be zero, this shouldn't cause any meaningful behavior
difference.
bdi_has_dirty_io() is made an inline function which tests whether
->tot_write_bandwidth is non-zero. Also, WARN_ON_ONCE()'s on its
value are added to inode_wb_list_{move|del}_locked().
Currently, wb_has_dirty_io() determines whether a wb (bdi_writeback)
has any dirty inode by testing all three IO lists on each invocation
without actively keeping track. For cgroup writeback support, a
single bdi will host multiple wb's each of which will host dirty
inodes separately and we'll need to make bdi_has_dirty_io(), which
currently only represents the root wb, aggregate has_dirty_io from all
member wb's, which requires tracking transitions in has_dirty_io state
on each wb.
This patch introduces inode_wb_list_{move|del}_locked() to consolidate
IO list operations leaving queue_io() the only other function which
directly manipulates IO lists (via move_expired_inodes()). All three
functions are updated to call wb_io_lists_[de]populated() which keep
track of whether the wb has dirty inodes or not and record it using
the new WB_has_dirty_io flag. inode_wb_list_moved_locked()'s return
value indicates whether the wb had no dirty inodes before.
mark_inode_dirty() is restructured so that the return value of
inode_wb_list_move_locked() can be used for deciding whether to wake
up the wb.
While at it, change {bdi|wb}_has_dirty_io()'s return values to bool.
These functions were returning 0 and 1 before. Also, add a comment
explaining the synchronization of wb_state flags.
v2: Updated to accommodate b_dirty_time.
Currently, all congestion functions take bdi (backing_dev_info) and
always operate on the root wb (bdi->wb) and the congestion state from
the block layer is propagated only for the root blkcg. This patch
introduces {set|clear}_wb_congested() and wb_congested() which take a
bdi_writeback_congested and bdi_writeback respectively. The bdi
counteparts are now wrappers invoking the wb based functions on
@bdi->wb.
While converting clear_bdi_congested() to clear_wb_congested(), the
local variable declaration order between @wqh and @bit is swapped for
cosmetic reason.
This patch just adds the new wb based functions. The following
patches will apply them.
v2: Updated for bdi_writeback_congested.
For the planned cgroup writeback support, on each bdi
(backing_dev_info), each memcg will be served by a separate wb
(bdi_writeback). This patch updates bdi so that a bdi can host
multiple wbs (bdi_writebacks).
On the default hierarchy, blkcg implicitly enables memcg. This allows
using memcg's page ownership for attributing writeback IOs, and every
memcg - blkcg combination can be served by its own wb by assigning a
dedicated wb to each memcg. This means that there may be multiple
wb's of a bdi mapped to the same blkcg. As congested state is per
blkcg - bdi combination, those wb's should share the same congested
state. This is achieved by tracking congested state via
bdi_writeback_congested structs which are keyed by blkcg.
bdi->wb remains unchanged and will keep serving the root cgroup.
cgwb's (cgroup wb's) for non-root cgroups are created on-demand or
looked up while dirtying an inode according to the memcg of the page
being dirtied or current task. Each cgwb is indexed on bdi->cgwb_tree
by its memcg id. Once an inode is associated with its wb, it can be
retrieved using inode_to_wb().
Currently, none of the filesystems has FS_CGROUP_WRITEBACK and all
pages will keep being associated with bdi->wb.
v3: inode_attach_wb() in account_page_dirtied() moved inside
mapping_cap_account_dirty() block where it's known to be !NULL.
Also, an unnecessary NULL check before kfree() removed. Both
detected by the kbuild bot.
v2: Updated so that wb association is per inode and wb is per memcg
rather than blkcg.
Cc: kbuild test robot <fengguang.wu@intel.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Currently, a wb's (bdi_writeback) congestion state is carried in its
->state field; however, cgroup writeback support will require multiple
wb's sharing the same congestion state. This patch separates out
congestion state into its own struct - struct bdi_writeback_congested.
A new field wb field, wb_congested, points to its associated congested
struct. The default wb, bdi->wb, always points to bdi->wb_congested.
While this patch adds a layer of indirection, it doesn't introduce any
behavior changes.
wb_init() currently always uses GFP_KERNEL but the planned cgroup
writeback support needs using other allocation masks. Add @gfp to
wb_init().
This patch doesn't introduce any behavior changes.
Now that bdi definitions are moved to backing-dev-defs.h,
backing-dev.h can include blkdev.h and inline inode_to_bdi() without
worrying about introducing circular include dependency. The function
gets called from hot paths and fairly trivial.
This patch makes inode_to_bdi() and sb_is_blkdev_sb() that the
function calls inline. blockdev_superblock and noop_backing_dev_info
are EXPORT_GPL'd to allow the inline functions to be used from
modules.
While at it, make sb_is_blkdev_sb() return bool instead of int.
v2: Fixed typo in description as suggested by Jan.
Reviewed-by: Jens Axboe <axboe@kernel.dk>
Move wb_shutdown(), bdi_register(), bdi_register_dev(),
bdi_prune_sb(), bdi_remove_from_list() and bdi_unregister() so that
init / exit functions are grouped together. This will make updating
init / exit paths for cgroup writeback support easier.
This is pure source file reorganization.
Cc: Wu Fengguang <fengguang.wu@intel.com>
Currently, a bdi (backing_dev_info) embeds single wb (bdi_writeback)
and the role of the separation is unclear. For cgroup support for
writeback IOs, a bdi will be updated to host multiple wb's where each
wb serves writeback IOs of a different cgroup on the bdi. To achieve
that, a wb should carry all states necessary for servicing writeback
IOs for a cgroup independently.
This patch moves bdi->wb_lock and ->worklist into wb.
* The lock protects bdi->worklist and bdi->wb.dwork scheduling. While
moving, rename it to wb->work_lock as wb->wb_lock is confusing.
Also, move wb->dwork downwards so that it's colocated with the new
->work_lock and ->work_list fields.
* bdi_writeback_workfn() -> wb_workfn()
bdi_wakeup_thread_delayed(bdi) -> wb_wakeup_delayed(wb)
bdi_wakeup_thread(bdi) -> wb_wakeup(wb)
bdi_queue_work(bdi, ...) -> wb_queue_work(wb, ...)
__bdi_start_writeback(bdi, ...) -> __wb_start_writeback(wb, ...)
get_next_work_item(bdi) -> get_next_work_item(wb)
* bdi_wb_shutdown() is renamed to wb_shutdown() and now takes @wb.
The function contained parts which belong to the containing bdi
rather than the wb itself - testing cap_writeback_dirty and
bdi_remove_from_list() invocation. Those are moved to
bdi_unregister().
* bdi_wb_{init|exit}() are renamed to wb_{init|exit}().
Initializations of the moved bdi->wb_lock and ->work_list are
relocated from bdi_init() to wb_init().
* As there's still only one bdi_writeback per backing_dev_info, all
uses of bdi->state are mechanically replaced with bdi->wb.state
introducing no behavior changes.
bdi_writeback
This patch moves bandwidth related fields from backing_dev_info into
bdi_writeback.
* The moved fields are: bw_time_stamp, dirtied_stamp, written_stamp,
write_bandwidth, avg_write_bandwidth, dirty_ratelimit,
balanced_dirty_ratelimit, completions and dirty_exceeded.
* writeback_chunk_size() and over_bground_thresh() now take @wb
instead of @bdi.
* bdi_writeout_fraction(bdi, ...) -> wb_writeout_fraction(wb, ...)
bdi_dirty_limit(bdi, ...) -> wb_dirty_limit(wb, ...)
bdi_position_ration(bdi, ...) -> wb_position_ratio(wb, ...)
bdi_update_writebandwidth(bdi, ...) -> wb_update_write_bandwidth(wb, ...)
[__]bdi_update_bandwidth(bdi, ...) -> [__]wb_update_bandwidth(wb, ...)
bdi_{max|min}_pause(bdi, ...) -> wb_{max|min}_pause(wb, ...)
bdi_dirty_limits(bdi, ...) -> wb_dirty_limits(wb, ...)
* Init/exits of the relocated fields are moved to bdi_wb_init/exit()
respectively. Note that explicit zeroing is dropped in the process
as wb's are cleared in entirety anyway.
uses of bdi->stat[] are mechanically replaced with bdi->wb.stat[]
v2: Typo in description fixed as suggested by Jan.
Cc: Jaegeuk Kim <jaegeuk@kernel.org>
Cc: Steven Whitehouse <swhiteho@redhat.com>
This patch moves bdi->bdi_stat[] into wb.
* enum bdi_stat_item is renamed to wb_stat_item and the prefix of all
enums is changed from BDI_ to WB_.
* BDI_STAT_BATCH() -> WB_STAT_BATCH()
* [__]{add|inc|dec|sum}_wb_stat(bdi, ...) -> [__]{add|inc}_wb_stat(wb, ...)
* bdi_stat[_error]() -> wb_stat[_error]()
* bdi_writeout_inc() -> wb_writeout_inc()
* stat init is moved to bdi_wb_init() and bdi_wb_exit() is added and
frees stat.
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Trond Myklebust <trond.myklebust@primarydata.com>
This patch moves bdi->state into wb.
* enum bdi_state is renamed to wb_state and the prefix of all enums is
* Explicit zeroing of bdi->state is removed without adding zeoring of
wb->state as the whole data structure is zeroed on init anyway.
Cc: drbd-dev@lists.linbit.com
Cc: Neil Brown <neilb@suse.de>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Pull lazytime mount option support from Al Viro:
"Lazytime stuff from tytso"
* 'lazytime' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
ext4: add optimization for the lazytime mount option
vfs: add find_inode_nowait() function
vfs: add support for a lazytime mount option
Add a new mount option which enables a new "lazytime" mode. This mode
causes atime, mtime, and ctime updates to only be made to the
in-memory version of the inode. The on-disk times will only get
updated when (a) if the inode needs to be updated for some non-time
related change, (b) if userspace calls fsync(), syncfs() or sync(), or
(c) just before an undeleted inode is evicted from memory.
This is OK according to POSIX because there are no guarantees after a
crash unless userspace explicitly requests via a fsync(2) call.
For workloads which feature a large number of random write to a
preallocated file, the lazytime mount option significantly reduces
writes to the inode table. The repeated 4k writes to a single block
will result in undesirable stress on flash devices and SMR disk
drives. Even on conventional HDD's, the repeated writes to the inode
table block will trigger Adjacent Track Interference (ATI) remediation
latencies, which very negatively impact long tail latencies --- which
is a very big deal for web serving tiers (for example).
Google-Bug-Id: 18297052
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Now that default_backing_dev_info is not used for writeback purposes we can
git rid of it easily:
- instead of using it's name for tracing unregistered bdi we just use
"unknown"
- btrfs and ceph can just assign the default read ahead window themselves
like several other filesystems already do.
- we can assign noop_backing_dev_info as the default one in alloc_super.
All filesystems already either assigned their own or
noop_backing_dev_info.
Reviewed-by: Tejun Heo <tj@kernel.org>
If we have dirty inodes we need to call the filesystem for it, even if the
device has been removed and the filesystem will error out early. The
current code does that by reassining all dirty inodes to the default
backing_dev_info when a bdi is unlinked, but that's pretty pointless given
that the bdi must always outlive the super block.
Instead of stopping writeback at unregister time and moving inodes to the
default bdi just keep the current bdi alive until it is destroyed. The
containing objects of the bdi ensure this doesn't happen until all
writeback has finished by erroring out.
Killed the redundant WARN_ON(), as noticed by Jan.
Now that we never use the backing_dev_info pointer in struct address_space
we can simply remove it and save 4 to 8 bytes in every inode.
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Since "BDI: Provide backing device capability information [try #3]" the
backing_dev_info structure also provides flags for the kind of mmap
operation available in a nommu environment, which is entirely unrelated
to it's original purpose.
Introduce a new nommu-only file operation to provide this information to
the nommu mmap code instead. Splitting this from the backing_dev_info
structure allows to remove lots of backing_dev_info instance that aren't
otherwise needed, and entirely gets rid of the concept of providing a
backing_dev_info for a character device. It also removes the need for
the mtd_inodefs filesystem.
Acked-by: Brian Norris <computersforpeace@gmail.com>
Pull core block layer changes from Jens Axboe:
"This is the core block IO pull request for 3.18. Apart from the new
and improved flush machinery for blk-mq, this is all mostly bug fixes
and cleanups.
- blk-mq timeout updates and fixes from Christoph.
- Removal of REQ_END, also from Christoph. We pass it through the
->queue_rq() hook for blk-mq instead, freeing up one of the request
bits. The space was overly tight on 32-bit, so Martin also killed
REQ_KERNEL since it's no longer used.
- blk integrity updates and fixes from Martin and Gu Zheng.
- Update to the flush machinery for blk-mq from Ming Lei. Now we
have a per hardware context flush request, which both cleans up the
code should scale better for flush intensive workloads on blk-mq.
- Improve the error printing, from Rob Elliott.
- Backing device improvements and cleanups from Tejun.
- Fixup of a misplaced rq_complete() tracepoint from Hannes.
- Make blk_get_request() return error pointers, fixing up issues
where we NULL deref when a device goes bad or missing. From Joe
Lawrence.
- Prep work for drastically reducing the memory consumption of dm
devices from Junichi Nomura. This allows creating clone bio sets
without preallocating a lot of memory.
- Fix a blk-mq hang on certain combinations of queue depths and
hardware queues from me.
- Limit memory consumption for blk-mq devices for crash dump
scenarios and drivers that use crazy high depths (certain SCSI
shared tag setups). We now just use a single queue and limited
depth for that"
* 'for-3.18/core' of git://git.kernel.dk/linux-block: (58 commits)
block: Remove REQ_KERNEL
blk-mq: allocate cpumask on the home node
bio-integrity: remove the needless fail handle of bip_slab creating
block: include func name in __get_request prints
block: make blk_update_request print prefix match ratelimited prefix
blk-merge: don't compute bi_phys_segments from bi_vcnt for cloned bio
block: fix alignment_offset math that assumes io_min is a power-of-2
blk-mq: Make bt_clear_tag() easier to read
blk-mq: fix potential hang if rolling wakeup depth is too high
block: add bioset_create_nobvec()
block: use bio_clone_fast() in blk_rq_prep_clone()
block: misplaced rq_complete tracepoint
sd: Honor block layer integrity handling flags
block: Replace strnicmp with strncasecmp
block: Add T10 Protection Information functions
block: Don't merge requests if integrity flags differ
block: Integrity checksum flag
block: Relocate bio integrity flags
block: Add a disk flag to block integrity profile
block: Add prefix to block integrity profile flags
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull percpu updates from Tejun Heo:
"A lot of activities on percpu front. Notable changes are...
- percpu allocator now can take @gfp. If @gfp doesn't contain
GFP_KERNEL, it tries to allocate from what's already available to
the allocator and a work item tries to keep the reserve around
certain level so that these atomic allocations usually succeed.
This will replace the ad-hoc percpu memory pool used by
blk-throttle and also be used by the planned blkcg support for
writeback IOs.
Please note that I noticed a bug in how @gfp is interpreted while
preparing this pull request and applied the fix 6ae833c7fe0c
("percpu: fix how @gfp is interpreted by the percpu allocator")
just now.
- percpu_ref now uses longs for percpu and global counters instead of
ints. It leads to more sparse packing of the percpu counters on
64bit machines but the overhead should be negligible and this
allows using percpu_ref for refcnting pages and in-memory objects
directly.
- The switching between percpu and single counter modes of a
percpu_ref is made independent of putting the base ref and a
percpu_ref can now optionally be initialized in single or killed
mode. This allows avoiding percpu shutdown latency for cases where
the refcounted objects may be synchronously created and destroyed
in rapid succession with only a fraction of them reaching fully
operational status (SCSI probing does this when combined with
blk-mq support). It's also planned to be used to implement forced
single mode to detect underflow more timely for debugging.
There's a separate branch percpu/for-3.18-consistent-ops which cleans
up the duplicate percpu accessors. That branch causes a number of
conflicts with s390 and other trees. I'll send a separate pull
request w/ resolutions once other branches are merged"
* 'for-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (33 commits)
blk-mq, percpu_ref: start q->mq_usage_counter in atomic mode
percpu_ref: make INIT_ATOMIC and switch_to_atomic() sticky
percpu_ref: add PERCPU_REF_INIT_* flags
percpu_ref: decouple switching to percpu mode and reinit
percpu_ref: decouple switching to atomic mode and killing
percpu_ref: add PCPU_REF_DEAD
percpu_ref: rename things to prepare for decoupling percpu/atomic mode switch
percpu_ref: replace pcpu_ prefix with percpu_
percpu_ref: minor code and comment updates
percpu_ref: relocate percpu_ref_reinit()
Revert "blk-mq, percpu_ref: implement a kludge for SCSI blk-mq stall during probe"
Revert "percpu: free percpu allocation info for uniprocessor system"
percpu-refcount: make percpu_ref based on longs instead of ints
percpu-refcount: improve WARN messages
percpu: fix locking regression in the failure path of pcpu_alloc()
percpu-refcount: add @gfp to percpu_ref_init()
proportions: add @gfp to init functions
percpu_counter: add @gfp to percpu_counter_init()
percpu_counter: make percpu_counters_lock irq-safe
Page reclaim tests zone_is_reclaim_dirty(), but the site that actually
sets this state does zone_set_flag(zone, ZONE_TAIL_LRU_DIRTY), sending the
reader through layers indirection just to track down a simple bit.
Remove all zone flag wrappers and just use bitops against zone->flags
directly. It's just as readable and the lines are barely any longer.
Also rename ZONE_TAIL_LRU_DIRTY to ZONE_DIRTY to match ZONE_WRITEBACK, and
remove the zone_flags_t typedef.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Acked-by: David Rientjes <rientjes@google.com>
A block_device may be attached to different gendisks and thus
different bdis over time. bdev_inode_switch_bdi() is used to switch
the associated bdi. The function assumes that the inode could be
dirty and transfers it between bdis if so. This is a bit nasty in
that it reaches into bdi internals.
This patch reimplements the function so that it writes out the inode
if dirty. This is a lot simpler and can be implemented without
exposing bdi internals.
bdi_destroy() has code to transfer the remaining dirty inodes to the
default_backing_dev_info; however, given the shutdown sequence, it
isn't clear how such condition would happen. Also, it isn't a full
solution as the transferred inodes stlil point to the bdi which is
being destroyed. Operations on those inodes can end up accessing
already released fields such as the percpu stat fields.
Digging through the history, it seems that the code was added as a
quick workaround for a bug report without fully root-causing the
issue. We probably want to remove the code in time but for now let's
add a comment noting that it is a quick workaround.
Canceling of bdi->wb.dwork is currently a bit mushy.
bdi_wb_shutdown() performs cancel_delayed_work_sync() at the end after
shutting down and flushing the delayed_work and bdi_destroy() tries
yet again after bdi_unregister().
bdi->wb.dwork is queued only after checking BDI_registered while
holding bdi->wb_lock and bdi_wb_shutdown() clears the flag while
holding the same lock and then flushes the delayed_work. There's no
way the delayed_work can be queued again after that.
Replace the two unnecessary cancel_delayed_work_sync() invocations
with WARNs on pending. This simplifies and clarifies the code a bit
and will help future changes in further isolating bdi_writeback
handling.
The only places where NULL test on bdi->dev is used are
bdi_[un]register(). The functions can't be called in parallel anyway
and there's no point in protecting bdi->dev clearing with a lock.
Remove bdi->wb_lock grabbing around bdi->dev clearing and move it
after device_unregister() call so that bdi->dev doesn't have to be
cached in a local variable.
This patch shouldn't introduce any behavior difference.
Percpu allocator now supports allocation mask. Add @gfp to
[flex_]proportions init functions so that !GFP_KERNEL allocation masks
can be used with them too.
This patch doesn't make any functional difference.
percpu_counter_init() so that !GFP_KERNEL allocation masks can be used
with percpu_counters too.
We could have left percpu_counter_init() alone and added
percpu_counter_init_gfp(); however, the number of users isn't that
high and introducing _gfp variants to all percpu data structures would
be quite ugly, so let's just do the conversion. This is the one with
the most users. Other percpu data structures are a lot easier to
convert.
Acked-by: Jan Kara <jack@suse.cz>
Acked-by: "David S. Miller" <davem@davemloft.net>
Cc: x86@kernel.org
Cc: "Theodore Ts'o" <tytso@mit.edu>
Mostly scripted conversion of the smp_mb__* barriers.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-55dhyhocezdw1dg7u19hmh1u@git.kernel.org
After commit 839a8e8660b6 ("writeback: replace custom worker pool
implementation with unbound workqueue") when device is removed while we
are writing to it we crash in bdi_writeback_workfn() ->
set_worker_desc() because bdi->dev is NULL.
This can happen because even though bdi_unregister() cancels all pending
flushing work, nothing really prevents new ones from being queued from
balance_dirty_pages() or other places.
Fix the problem by clearing BDI_registered bit in bdi_unregister() and
checking it before scheduling of any flushing work.
Fixes: 839a8e8660b6777e7fe4e80af1a048aebe2b5977
Cc: Derek Basehore <dbasehore@chromium.org>
Cc: <stable@vger.kernel.org>
bdi_wakeup_thread_delayed() used the mod_delayed_work() function to
schedule work to writeback dirty inodes. The problem with this is that
it can delay work that is scheduled for immediate execution, such as the
work from sync_inodes_sb(). This can happen since mod_delayed_work()
can now steal work from a work_queue. This fixes the problem by using
queue_delayed_work() instead. This is a regression caused by commit
839a8e8660b6 ("writeback: replace custom worker pool implementation with
unbound workqueue").
The reason that this causes a problem is that laptop-mode will change
the delay, dirty_writeback_centisecs, to 60000 (10 minutes) by default.
In the case that bdi_wakeup_thread_delayed() races with
sync_inodes_sb(), sync will be stopped for 10 minutes and trigger a hung
task. Even if dirty_writeback_centisecs is not long enough to cause a
hung task, we still don't want to delay sync for that long.
We fix the problem by using queue_delayed_work() when we want to
schedule writeback sometime in future. This function doesn't change the
timer if it is already armed.
For the same reason, we also change bdi_writeback_workfn() to
immediately queue the work again in the case that the work_list is not
empty. The same problem can happen if the sync work is run on the
rescue worker.
[jack@suse.cz: update changelog, add comment, use bdi_wakeup_thread_delayed()]
Signed-off-by: Derek Basehore <dbasehore@chromium.org>
Cc: Alexander Viro <viro@zento.linux.org.uk>
Cc: "Darrick J. Wong" <darrick.wong@oracle.com>
Cc: Benson Leung <bleung@chromium.org>
Cc: Sonny Rao <sonnyrao@chromium.org>
Cc: Luigi Semenzato <semenzato@chromium.org>
related user buffer
'*lenp' may be less than "sizeof(kbuf)" so we must check this before the
next copy_to_user().
pdflush_proc_obsolete() is called by sysctl which 'procname' is
"nr_pdflush_threads", if the user passes buffer length less than
"sizeof(kbuf)", it will cause issue.
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Jeff Moyer <jmoyer@redhat.com>
The dev_attrs field of struct class is going away soon, dev_groups
should be used instead. This converts the backing device class code to
use the correct field.
A number of parts of the kernel created their own version of this, might
as well have the sysfs core provide it instead.
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Calling dev_set_name with a single paramter causes it to be handled as a
format string. Many callers are passing potentially dynamic string
content, so use "%s" in those cases to avoid any potential accidents,
including wrappers like device_create*() and bdi_register().
There are cases where userland wants to tweak the priority and
affinity of writeback flushers. Expose bdi_wq to userland by setting
WQ_SYSFS. It appears under /sys/bus/workqueue/devices/writeback/ and
allows adjusting maximum concurrency level, cpumask and nice level.
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Writeback implements its own worker pool - each bdi can be associated
with a worker thread which is created and destroyed dynamically. The
worker thread for the default bdi is always present and serves as the
"forker" thread which forks off worker threads for other bdis.
there's no reason for writeback to implement its own worker pool when
using unbound workqueue instead is much simpler and more efficient.
This patch replaces custom worker pool implementation in writeback
with an unbound workqueue.
The conversion isn't too complicated but the followings are worth
mentioning.
* bdi_writeback->last_active, task and wakeup_timer are removed.
delayed_work ->dwork is added instead. Explicit timer handling is
no longer necessary. Everything works by either queueing / modding
/ flushing / canceling the delayed_work item.
* bdi_writeback_thread() becomes bdi_writeback_workfn() which runs off
bdi_writeback->dwork. On each execution, it processes
bdi->work_list and reschedules itself if there are more things to
do.
The function also handles low-mem condition, which used to be
handled by the forker thread. If the function is running off a
rescuer thread, it only writes out limited number of pages so that
the rescuer can serve other bdis too. This preserves the flusher
creation failure behavior of the forker thread.
* INIT_LIST_HEAD(&bdi->bdi_list) is used to tell
bdi_writeback_workfn() about on-going bdi unregistration so that it
always drains work_list even if it's running off the rescuer. Note
that the original code was broken in this regard. Under memory
pressure, a bdi could finish unregistration with non-empty
work_list.
* The default bdi is no longer special. It now is treated the same as
any other bdi and bdi_cap_flush_forker() is removed.
* BDI_pending is no longer used. Removed.
* Some tracepoints become non-applicable. The following TPs are
removed - writeback_nothread, writeback_wake_thread,
writeback_wake_forker_thread, writeback_thread_start,
writeback_thread_stop.
Everything, including devices coming and going away and rescuer
operation under simulated memory pressure, seems to work fine in my
test setup.
There's no user left. Remove it.
This patchset ("stable page writes, part 2") makes some key
modifications to the original 'stable page writes' patchset. First, it
provides creators (devices and filesystems) of a backing_dev_info a flag
that declares whether or not it is necessary to ensure that page
contents cannot change during writeout. It is no longer assumed that
this is true of all devices (which was never true anyway). Second, the
flag is used to relaxed the wait_on_page_writeback calls so that wait
only occurs if the device needs it. Third, it fixes up the remaining
disk-backed filesystems to use this improved conditional-wait logic to
provide stable page writes on those filesystems.
It is hoped that (for people not using checksumming devices, anyway)
this patchset will give back unnecessary performance decreases since the
original stable page write patchset went into 3.0. Sorry about not
fixing it sooner.
Complaints were registered by several people about the long write
latencies introduced by the original stable page write patchset.
Generally speaking, the kernel ought to allocate as little extra memory
as possible to facilitate writeout, but for people who simply cannot
wait, a second page stability strategy is (re)introduced: snapshotting
page contents. The waiting behavior is still the default strategy; to
enable page snapshotting, a superblock flag (MS_SNAP_STABLE) must be
set. This flag is used to bandaid^Henable stable page writeback on
ext3[1], and is not used anywhere else.
Given that there are already a few storage devices and network FSes that
have rolled their own page stability wait/page snapshot code, it would
be nice to move towards consolidating all of these. It seems possible
that iscsi and raid5 may wish to use the new stable page write support
to enable zero-copy writeout.
Thank you to Jan Kara for helping fix a couple more filesystems.
Per Andrew Morton's request, here are the result of using dbench to measure
latencies on ext2:
3.8.0-rc3:
Operation Count AvgLat MaxLat
WriteX 109347 0.028 59.817
ReadX 347180 0.004 3.391
Flush 15514 29.828 287.283
Throughput 57.429 MB/sec 4 clients 4 procs max_latency=287.290 ms
3.8.0-rc3 + patches:
WriteX 105556 0.029 4.273
ReadX 335004 0.005 4.112
Flush 14982 30.540 298.634
Throughput 55.4496 MB/sec 4 clients 4 procs max_latency=298.650 ms
As you can see, for ext2 the maximum write latency decreases from ~60ms
on a laptop hard disk to ~4ms. I'm not sure why the flush latencies
increase, though I suspect that being able to dirty pages faster gives
the flusher more work to do.
On ext4, the average write latency decreases as well as all the maximum
latencies:
3.8.0-rc3:
WriteX 85624 0.152 33.078
ReadX 272090 0.010 61.210
Flush 12129 36.219 168.260
Throughput 44.8618 MB/sec 4 clients 4 procs max_latency=168.276 ms
WriteX 86082 0.141 30.928
ReadX 273358 0.010 36.124
Flush 12214 34.800 165.689
Throughput 44.9941 MB/sec 4 clients 4 procs max_latency=165.722 ms
XFS seems to exhibit similar latency improvements as ext2:
3.8.0-rc3:
WriteX 125739 0.028 104.343
ReadX 399070 0.005 4.115
Flush 17851 25.004 131.390
Throughput 66.0024 MB/sec 4 clients 4 procs max_latency=131.406 ms
WriteX 123529 0.028 6.299
ReadX 392434 0.005 4.287
Flush 17549 25.120 188.687
Throughput 64.9113 MB/sec 4 clients 4 procs max_latency=188.704 ms
...and btrfs, just to round things out, also shows some latency
decreases:
3.8.0-rc3:
WriteX 67122 0.083 82.355
ReadX 212719 0.005 2.828
Flush 9547 47.561 147.418
Throughput 35.3391 MB/sec 4 clients 4 procs max_latency=147.433 ms
WriteX 64898 0.101 71.631
ReadX 206673 0.005 7.123
Flush 9190 47.963 219.034
Throughput 34.0795 MB/sec 4 clients 4 procs max_latency=219.044 ms
Before this patchset, all filesystems would block, regardless of whether
or not it was necessary. ext3 would wait, but still generate occasional
checksum errors. The network filesystems were left to do their own
thing, so they'd wait too.
After this patchset, all the disk filesystems except ext3 and btrfs will
wait only if the hardware requires it. ext3 (if necessary) snapshots
pages instead of blocking, and btrfs provides its own bdi so the mm will
never wait. Network filesystems haven't been touched, so either they
provide their own wait code, or they don't block at all. The blocking
behavior is back to what it was before 3.0 if you don't have a disk
requiring stable page writes.
This patchset has been tested on 3.8.0-rc3 on x64 with ext3, ext4, and
xfs. I've spot-checked 3.8.0-rc4 and seem to be getting the same
results as -rc3.
[1] The alternative fixes to ext3 include fixing the locking order and
page bit handling like we did for ext4 (but then why not just use
ext4?), or setting PG_writeback so early that ext3 becomes extremely
slow. I tried that, but the number of write()s I could initiate dropped
by nearly an order of magnitude. That was a bit much even for the
author of the stable page series! :)
This patch:
Creates a per-backing-device flag that tracks whether or not pages must
be held immutable during writeout. Eventually it will be used to waive
wait_for_page_writeback() if nothing requires stable pages.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
This reverts commit 8fa72d234da9b6b473bbb1f74d533663e4996e6b.
People disagree about how this should be done, so let's revert this for
now so that nobody starts using the new tuning interface. Tejun is
thinking about a more generic interface for thread pool affinity.
Requested-by: Tejun Heo <tj@kernel.org>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Jens Axboe <axboe@kernel.dk>
In realtime environments, it may be desirable to keep the per-bdi
flusher threads from running on certain cpus. This patch adds a
cpu_list file to /sys/class/bdi/* to enable this. The default is to tie
the flusher threads to the same numa node as the backing device (though
I could be convinced to make it a mask of all cpus to avoid a change in
behaviour).
Thanks to Jeremy Eder for the original idea.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Fix checkpatch warnings:
WARNING: consider using kstrto* in preference to simple_strtoul
for the below sys entry parsers:
/sys/block/<block device>/bdi/read_ahead_kb
/sys/block/<block device>/bdi/max_ratio
/sys/block/<block device>/bdi/min_ratio
Signed-off-by: Namjae Jeon <linkinjeon@gmail.com>
Signed-off-by: Vivek Trivedi <vtrivedi018@gmail.com>
Finally we can kill the 'sync_supers' kernel thread along with the
'->write_super()' superblock operation because all the users are gone.
Now every file-system is supposed to self-manage own superblock and
its dirty state.
The nice thing about killing this thread is that it improves power management.
Indeed, 'sync_supers' is a source of monotonic system wake-ups - it woke up
every 5 seconds no matter what - even if there were no dirty superblocks and
even if there were no file-systems using this service (e.g., btrfs and
journalled ext4 do not need it). So it was wasting power most of the time. And
because the thread was in the core of the kernel, all systems had to have it.
So I am quite happy to make it go away.
Interestingly, this thread is a left-over from the pdflush kernel thread which
was a self-forking kernel thread responsible for all the write-back in old
Linux kernels. It was turned into per-block device BDI threads, and
'sync_supers' was a left-over. Thus, R.I.P, pdflush as well.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Since per-BDI flusher threads were introduced in 2.6, the pdflush
mechanism is not used any more. But the old interface exported through
/proc/sys/vm/nr_pdflush_threads still exists and is obviously useless.
For back-compatibility, printk warning information and return 2 to notify
the users that the interface is removed.
Signed-off-by: Wanpeng Li <liwp@linux.vnet.ibm.com>
Convert calculations of proportion of writeback each bdi does to new flexible
proportion code. That allows us to use aging period of fixed wallclock time
which gives better proportion estimates given the hugely varying throughput of
different devices.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
While 7a401a972df8e18 ("backing-dev: ensure wakeup_timer is deleted")
addressed the problem of the bdi being freed with a queued wakeup
timer, there are other races that could happen if the wakeup timer
expires after/during bdi_unregister(), before bdi_destroy() is called.
wakeup_timer_fn() could attempt to wakeup a task which has already has
been freed, or could access a NULL bdi->dev via the wake_forker_thread
tracepoint.
Cc: <stable@kernel.org>
Reported-by: Chanho Min <chanho.min@lge.com>
Reviewed-by: Namjae Jeon <linkinjeon@gmail.com>
Signed-off-by: Rabin Vincent <rabin@rab.in>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Writeback and thinkpad_acpi have been using thaw_process() to prevent
deadlock between the freezer and kthread_stop(); unfortunately, this
is inherently racy - nothing prevents freezing from happening between
thaw_process() and kthread_stop().
This patch implements kthread_freezable_should_stop() which enters
refrigerator if necessary but is guaranteed to return if
kthread_stop() is invoked. Both thaw_process() users are converted to
use the new function.
Note that this deadlock condition exists for many of freezable
kthreads. They need to be converted to use the new should_stop or
freezable workqueue.
Tested with synthetic test case.
Acked-by: Henrique de Moraes Holschuh <ibm-acpi@hmh.eng.br>
bdi_prune_sb() in bdi_unregister() attempts to removes the bdi links
from all super_blocks and then del_timer_sync() the writeback timer.
However, this can race with __mark_inode_dirty(), leading to
bdi_wakeup_thread_delayed() rearming the writeback timer on the bdi
we're unregistering, after we've called del_timer_sync().
This can end up with the bdi being freed with an active timer inside it,
as in the case of the following dump after the removal of an SD card.
Fix this by redoing the del_timer_sync() in bdi_destory().
WARNING: at /home/rabin/kernel/arm/lib/debugobjects.c:262 debug_print_object+0x9c/0xc8()
ODEBUG: free active (active state 0) object type: timer_list hint: wakeup_timer_fn+0x0/0x180
Modules linked in:
Backtrace:
[<c00109dc>] (dump_backtrace+0x0/0x110) from [<c0236e4c>] (dump_stack+0x18/0x1c)
r6:c02bc638 r5:00000106 r4:c79f5d18 r3:00000000
[<c0236e34>] (dump_stack+0x0/0x1c) from [<c0025e6c>] (warn_slowpath_common+0x54/0x6c)
[<c0025e18>] (warn_slowpath_common+0x0/0x6c) from [<c0025f28>] (warn_slowpath_fmt+0x38/0x40)
r8:20000013 r7:c780c6f0 r6:c031613c r5:c780c6f0 r4:c02b1b29
r3:00000009
[<c0025ef0>] (warn_slowpath_fmt+0x0/0x40) from [<c015eb4c>] (debug_print_object+0x9c/0xc8)
r3:c02b1b29 r2:c02bc662
[<c015eab0>] (debug_print_object+0x0/0xc8) from [<c015f574>] (debug_check_no_obj_freed+0xac/0x1dc)
r6:c7964000 r5:00000001 r4:c7964000
[<c015f4c8>] (debug_check_no_obj_freed+0x0/0x1dc) from [<c00a9e38>] (kmem_cache_free+0x88/0x1f8)
[<c00a9db0>] (kmem_cache_free+0x0/0x1f8) from [<c014286c>] (blk_release_queue+0x70/0x78)
[<c01427fc>] (blk_release_queue+0x0/0x78) from [<c015290c>] (kobject_release+0x70/0x84)
r5:c79641f0 r4:c796420c
[<c015289c>] (kobject_release+0x0/0x84) from [<c0153ce4>] (kref_put+0x68/0x80)
r7:00000083 r6:c74083d0 r5:c015289c r4:c796420c
[<c0153c7c>] (kref_put+0x0/0x80) from [<c01527d0>] (kobject_put+0x48/0x5c)
r5:c79643b4 r4:c79641f0
[<c0152788>] (kobject_put+0x0/0x5c) from [<c013ddd8>] (blk_cleanup_queue+0x68/0x74)
r4:c7964000
[<c013dd70>] (blk_cleanup_queue+0x0/0x74) from [<c01a6370>] (mmc_blk_put+0x78/0xe8)
r5:00000000 r4:c794c400
[<c01a62f8>] (mmc_blk_put+0x0/0xe8) from [<c01a64b4>] (mmc_blk_release+0x24/0x38)
r5:c794c400 r4:c0322824
[<c01a6490>] (mmc_blk_release+0x0/0x38) from [<c00de11c>] (__blkdev_put+0xe8/0x170)
r5:c78d5e00 r4:c74083c0
[<c00de034>] (__blkdev_put+0x0/0x170) from [<c00de2c0>] (blkdev_put+0x11c/0x12c)
r8:c79f5f70 r7:00000001 r6:c74083d0 r5:00000083 r4:c74083c0
r3:00000000
[<c00de1a4>] (blkdev_put+0x0/0x12c) from [<c00b0724>] (kill_block_super+0x60/0x6c)
r7:c7942300 r6:c79f4000 r5:00000083 r4:c74083c0
[<c00b06c4>] (kill_block_super+0x0/0x6c) from [<c00b0a94>] (deactivate_locked_super+0x44/0x70)
r6:c79f4000 r5:c031af64 r4:c794dc00 r3:c00b06c4
[<c00b0a50>] (deactivate_locked_super+0x0/0x70) from [<c00b1358>] (deactivate_super+0x6c/0x70)
r5:c794dc00 r4:c794dc00
[<c00b12ec>] (deactivate_super+0x0/0x70) from [<c00c88b0>] (mntput_no_expire+0x188/0x194)
r5:c794dc00 r4:c7942300
[<c00c8728>] (mntput_no_expire+0x0/0x194) from [<c00c95e0>] (sys_umount+0x2e4/0x310)
r6:c7942300 r5:00000000 r4:00000000 r3:00000000
[<c00c92fc>] (sys_umount+0x0/0x310) from [<c000d940>] (ret_fast_syscall+0x0/0x30)
---[ end trace e5c83c92ada51c76 ]---
Cc: stable@kernel.org
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux
* 'writeback-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux:
writeback: Add a 'reason' to wb_writeback_work
writeback: send work item to queue_io, move_expired_inodes
writeback: trace event balance_dirty_pages
writeback: trace event bdi_dirty_ratelimit
writeback: fix ppc compile warnings on do_div(long long, unsigned long)
writeback: per-bdi background threshold
writeback: dirty position control - bdi reserve area
writeback: control dirty pause time
writeback: limit max dirty pause time
writeback: IO-less balance_dirty_pages()
writeback: per task dirty rate limit
writeback: stabilize bdi->dirty_ratelimit
writeback: dirty rate control
writeback: add bg_threshold parameter to __bdi_update_bandwidth()
writeback: account per-bdi accumulated dirtied pages
fiddle wording
