path: root/lib
2014-08-06lib/cmdline.c: add size unit t/p/e to memparseGui Hecheng
For modern filesystems such as btrfs, t/p/e size level operations are common. add size unit t/p/e parsing to memparse Signed-off-by: Gui Hecheng <guihc.fnst@cn.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Reviewed-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06lib/glob.c: add CONFIG_GLOB_SELFTESTGeorge Spelvin
This was useful during development, and is retained for future regression testing. GCC appears to have no way to place string literals in a particular section; adding __initconst to a char pointer leaves the string itself in the default string section, where it will not be thrown away after module load. Thus all string constants are kept in explicitly declared and named arrays. Sorry this makes printk a bit harder to read. At least the tests are more compact. Signed-off-by: George Spelvin <linux@horizon.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06lib: add lib/glob.cGeorge Spelvin
This is a helper function from drivers/ata/libata_core.c, where it is used to blacklist particular device models. It's being moved to lib/ so other drivers may use it for the same purpose. This implementation in non-recursive, so is safe for the kernel stack. [akpm@linux-foundation.org: fix sparse warning] Signed-off-by: George Spelvin <linux@horizon.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06zlib: clean up some dead codeSergey Senozhatsky
Cleanup unused `if 0'-ed functions, which have been dead since 2006 (commits 87c2ce3b9305 ("lib/zlib*: cleanups") by Adrian Bunk and 4f3865fb57a0 ("zlib_inflate: Upgrade library code to a recent version") by Richard Purdie): - zlib_deflateSetDictionary - zlib_deflateParams - zlib_deflateCopy - zlib_inflateSync - zlib_syncsearch - zlib_inflateSetDictionary - zlib_inflatePrime Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06klist: use same naming scheme as hlist for klist_add_after()Ken Helias
The name was modified from hlist_add_after() to hlist_add_behind() when adjusting the order of arguments to match the one with klist_add_after(). This is necessary to break old code when it would use it the wrong way. Make klist follow this naming scheme for consistency. Signed-off-by: Ken Helias <kenhelias@firemail.de> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Hugh Dickins <hughd@google.com> Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06printk: rename DEFAULT_MESSAGE_LOGLEVELAlex Elder
Commit a8fe19ebfbfd ("kernel/printk: use symbolic defines for console loglevels") makes consistent use of symbolic values for printk() log levels. The naming scheme used is different from the one used for DEFAULT_MESSAGE_LOGLEVEL though. Change that symbol name to be MESSAGE_LOGLEVEL_DEFAULT for consistency. And because the value of that symbol comes from a similarly-named config option, rename CONFIG_DEFAULT_MESSAGE_LOGLEVEL as well. Signed-off-by: Alex Elder <elder@linaro.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: Jan Kara <jack@suse.cz> Cc: John Stultz <john.stultz@linaro.org> Cc: Petr Mladek <pmladek@suse.cz> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights: 1) Steady transitioning of the BPF instructure to a generic spot so all kernel subsystems can make use of it, from Alexei Starovoitov. 2) SFC driver supports busy polling, from Alexandre Rames. 3) Take advantage of hash table in UDP multicast delivery, from David Held. 4) Lighten locking, in particular by getting rid of the LRU lists, in inet frag handling. From Florian Westphal. 5) Add support for various RFC6458 control messages in SCTP, from Geir Ola Vaagland. 6) Allow to filter bridge forwarding database dumps by device, from Jamal Hadi Salim. 7) virtio-net also now supports busy polling, from Jason Wang. 8) Some low level optimization tweaks in pktgen from Jesper Dangaard Brouer. 9) Add support for ipv6 address generation modes, so that userland can have some input into the process. From Jiri Pirko. 10) Consolidate common TCP connection request code in ipv4 and ipv6, from Octavian Purdila. 11) New ARP packet logger in netfilter, from Pablo Neira Ayuso. 12) Generic resizable RCU hash table, with intial users in netlink and nftables. From Thomas Graf. 13) Maintain a name assignment type so that userspace can see where a network device name came from (enumerated by kernel, assigned explicitly by userspace, etc.) From Tom Gundersen. 14) Automatic flow label generation on transmit in ipv6, from Tom Herbert. 15) New packet timestamping facilities from Willem de Bruijn, meant to assist in measuring latencies going into/out-of the packet scheduler, latency from TCP data transmission to ACK, etc" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1536 commits) cxgb4 : Disable recursive mailbox commands when enabling vi net: reduce USB network driver config options. tg3: Modify tg3_tso_bug() to handle multiple TX rings amd-xgbe: Perform phy connect/disconnect at dev open/stop amd-xgbe: Use dma_set_mask_and_coherent to set DMA mask net: sun4i-emac: fix memory leak on bad packet sctp: fix possible seqlock seadlock in sctp_packet_transmit() Revert "net: phy: Set the driver when registering an MDIO bus device" cxgb4vf: Turn off SGE RX/TX Callback Timers and interrupts in PCI shutdown routine team: Simplify return path of team_newlink bridge: Update outdated comment on promiscuous mode net-timestamp: ACK timestamp for bytestreams net-timestamp: TCP timestamping net-timestamp: SCHED timestamp on entering packet scheduler net-timestamp: add key to disambiguate concurrent datagrams net-timestamp: move timestamp flags out of sk_flags net-timestamp: extend SCM_TIMESTAMPING ancillary data struct cxgb4i : Move stray CPL definitions to cxgb4 driver tcp: reduce spurious retransmits due to transient SACK reneging qlcnic: Initialize dcbnl_ops before register_netdev ...
2014-08-06Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "In this release: - PKCS#7 parser for the key management subsystem from David Howells - appoint Kees Cook as seccomp maintainer - bugfixes and general maintenance across the subsystem" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (94 commits) X.509: Need to export x509_request_asymmetric_key() netlabel: shorter names for the NetLabel catmap funcs/structs netlabel: fix the catmap walking functions netlabel: fix the horribly broken catmap functions netlabel: fix a problem when setting bits below the previously lowest bit PKCS#7: X.509 certificate issuer and subject are mandatory fields in the ASN.1 tpm: simplify code by using %*phN specifier tpm: Provide a generic means to override the chip returned timeouts tpm: missing tpm_chip_put in tpm_get_random() tpm: Properly clean sysfs entries in error path tpm: Add missing tpm_do_selftest to ST33 I2C driver PKCS#7: Use x509_request_asymmetric_key() Revert "selinux: fix the default socket labeling in sock_graft()" X.509: x509_request_asymmetric_keys() doesn't need string length arguments PKCS#7: fix sparse non static symbol warning KEYS: revert encrypted key change ima: add support for measuring and appraising firmware firmware_class: perform new LSM checks security: introduce kernel_fw_from_file hook PKCS#7: Missing inclusion of linux/err.h ...
2014-08-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/Makefile net/ipv6/sysctl_net_ipv6.c Two ipv6_table_template[] additions overlap, so the index of the ipv6_table[x] assignments needed to be adjusted. In the drivers/net/Makefile case, we've gotten rid of the garbage whereby we had to list every single USB networking driver in the top-level Makefile, there is just one "USB_NETWORKING" that guards everything. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-05Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer and time updates from Thomas Gleixner: "A rather large update of timers, timekeeping & co - Core timekeeping code is year-2038 safe now for 32bit machines. Now we just need to fix all in kernel users and the gazillion of user space interfaces which rely on timespec/timeval :) - Better cache layout for the timekeeping internal data structures. - Proper nanosecond based interfaces for in kernel users. - Tree wide cleanup of code which wants nanoseconds but does hoops and loops to convert back and forth from timespecs. Some of it definitely belongs into the ugly code museum. - Consolidation of the timekeeping interface zoo. - A fast NMI safe accessor to clock monotonic for tracing. This is a long standing request to support correlated user/kernel space traces. With proper NTP frequency correction it's also suitable for correlation of traces accross separate machines. - Checkpoint/restart support for timerfd. - A few NOHZ[_FULL] improvements in the [hr]timer code. - Code move from kernel to kernel/time of all time* related code. - New clocksource/event drivers from the ARM universe. I'm really impressed that despite an architected timer in the newer chips SoC manufacturers insist on inventing new and differently broken SoC specific timers. [ Ed. "Impressed"? I don't think that word means what you think it means ] - Another round of code move from arch to drivers. Looks like most of the legacy mess in ARM regarding timers is sorted out except for a few obnoxious strongholds. - The usual updates and fixlets all over the place" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (114 commits) timekeeping: Fixup typo in update_vsyscall_old definition clocksource: document some basic timekeeping concepts timekeeping: Use cached ntp_tick_length when accumulating error timekeeping: Rework frequency adjustments to work better w/ nohz timekeeping: Minor fixup for timespec64->timespec assignment ftrace: Provide trace clocks monotonic timekeeping: Provide fast and NMI safe access to CLOCK_MONOTONIC seqcount: Add raw_write_seqcount_latch() seqcount: Provide raw_read_seqcount() timekeeping: Use tk_read_base as argument for timekeeping_get_ns() timekeeping: Create struct tk_read_base and use it in struct timekeeper timekeeping: Restructure the timekeeper some more clocksource: Get rid of cycle_last clocksource: Move cycle_last validation to core code clocksource: Make delta calculation a function wireless: ath9k: Get rid of timespec conversions drm: vmwgfx: Use nsec based interfaces drm: i915: Use nsec based interfaces timekeeping: Provide ktime_get_raw() hangcheck-timer: Use ktime_get_ns() ...
2014-08-04Merge tag 'driver-core-3.17-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here's the big driver-core pull request for 3.17-rc1. Largest thing in here is the dma-buf rework and fence code, that touched many different subsystems so it was agreed it should go through this tree to handle merge issues. There's also some firmware loading updates, as well as tests added, and a few other tiny changes, the changelog has the details. All have been in linux-next for a long time" * tag 'driver-core-3.17-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (32 commits) ARM: imx: Remove references to platform_bus in mxc code firmware loader: Fix _request_firmware_load() return val for fw load abort platform: Remove most references to platform_bus device test: add firmware_class loader test doc: fix minor typos in firmware_class README staging: android: Cleanup style issues Documentation: devres: Sort managed interfaces Documentation: devres: Add devm_kmalloc() et al fs: debugfs: remove trailing whitespace kernfs: kernel-doc warning fix debugfs: Fix corrupted loop in debugfs_remove_recursive stable_kernel_rules: Add pointer to netdev-FAQ for network patches driver core: platform: add device binding path 'driver_override' driver core/platform: remove unused implicit padding in platform_object firmware loader: inform direct failure when udev loader is disabled firmware: replace ALIGN(PAGE_SIZE) by PAGE_ALIGN firmware: read firmware size using i_size_read() firmware loader: allow disabling of udev as firmware loader reservation: add suppport for read-only access using rcu reservation: update api and add some helpers ... Conflicts: drivers/base/platform.c
2014-08-04Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking updates from Ingo Molnar: "The main changes in this cycle are: - big rtmutex and futex cleanup and robustification from Thomas Gleixner - mutex optimizations and refinements from Jason Low - arch_mutex_cpu_relax() removal and related cleanups - smaller lockdep tweaks" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits) arch, locking: Ciao arch_mutex_cpu_relax() locking/lockdep: Only ask for /proc/lock_stat output when available locking/mutexes: Optimize mutex trylock slowpath locking/mutexes: Try to acquire mutex only if it is unlocked locking/mutexes: Delete the MUTEX_SHOW_NO_WAITER macro locking/mutexes: Correct documentation on mutex optimistic spinning rtmutex: Make the rtmutex tester depend on BROKEN futex: Simplify futex_lock_pi_atomic() and make it more robust futex: Split out the first waiter attachment from lookup_pi_state() futex: Split out the waiter check from lookup_pi_state() futex: Use futex_top_waiter() in lookup_pi_state() futex: Make unlock_pi more robust rtmutex: Avoid pointless requeueing in the deadlock detection chain walk rtmutex: Cleanup deadlock detector debug logic rtmutex: Confine deadlock logic to futex rtmutex: Simplify remove_waiter() rtmutex: Document pi chain walk rtmutex: Clarify the boost/deboost part rtmutex: No need to keep task ref for lock owner check rtmutex: Simplify and document try_to_take_rtmutex() ...
2014-08-04Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU changes from Ingo Molar: "The main changes: - torture-test updates - callback-offloading changes - maintainership changes - update RCU documentation - miscellaneous fixes" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (32 commits) rcu: Allow for NULL tick_nohz_full_mask when nohz_full= missing rcu: Fix a sparse warning in rcu_report_unblock_qs_rnp() rcu: Fix a sparse warning in rcu_initiate_boost() rcu: Fix __rcu_reclaim() to use true/false for bool rcu: Remove CONFIG_PROVE_RCU_DELAY rcu: Use __this_cpu_read() instead of per_cpu_ptr() rcu: Don't use NMIs to dump other CPUs' stacks rcu: Bind grace-period kthreads to non-NO_HZ_FULL CPUs rcu: Simplify priority boosting by putting rt_mutex in rcu_node rcu: Check both root and current rcu_node when setting up future grace period rcu: Allow post-unlock reference for rt_mutex rcu: Loosen __call_rcu()'s rcu_head alignment constraint rcu: Eliminate read-modify-write ACCESS_ONCE() calls rcu: Remove redundant ACCESS_ONCE() from tick_do_timer_cpu rcu: Make rcu node arrays static const char * const signal: Explain local_irq_save() call rcu: Handle obsolete references to TINY_PREEMPT_RCU rcu: Document deadlock-avoidance information for rcu_read_unlock() scripts: Teach get_maintainer.pl about the new "R:" tag rcu: Update rcu torture maintainership filename patterns ...
2014-08-04Merge branch 'for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu updates from Tejun Heo: - Major reorganization of percpu header files which I think makes things a lot more readable and logical than before. - percpu-refcount is updated so that it requires explicit destruction and can be reinitialized if necessary. This was pulled into the block tree to replace the custom percpu refcnting implemented in blk-mq. - In the process, percpu and percpu-refcount got cleaned up a bit * 'for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (21 commits) percpu-refcount: implement percpu_ref_reinit() and percpu_ref_is_zero() percpu-refcount: require percpu_ref to be exited explicitly percpu-refcount: use unsigned long for pcpu_count pointer percpu-refcount: add helpers for ->percpu_count accesses percpu-refcount: one bit is enough for REF_STATUS percpu-refcount, aio: use percpu_ref_cancel_init() in ioctx_alloc() workqueue: stronger test in process_one_work() workqueue: clear POOL_DISASSOCIATED in rebind_workers() percpu: Use ALIGN macro instead of hand coding alignment calculation percpu: invoke __verify_pcpu_ptr() from the generic part of accessors and operations percpu: preffity percpu header files percpu: use raw_cpu_*() to define __this_cpu_*() percpu: reorder macros in percpu header files percpu: move {raw|this}_cpu_*() definitions to include/linux/percpu-defs.h percpu: move generic {raw|this}_cpu_*_N() definitions to include/asm-generic/percpu.h percpu: only allow sized arch overrides for {raw|this}_cpu_*() ops percpu: reorganize include/linux/percpu-defs.h percpu: move accessors from include/linux/percpu.h to percpu-defs.h percpu: include/asm-generic/percpu.h should contain only arch-overridable parts percpu: introduce arch_raw_cpu_ptr() ...
2014-08-02lib: Resizable, Scalable, Concurrent Hash TableThomas Graf
Generic implementation of a resizable, scalable, concurrent hash table based on [0]. The implementation supports both, fixed size keys specified via an offset and length, or arbitrary keys via own hash and compare functions. Lookups are lockless and protected as RCU read side critical sections. Automatic growing/shrinking based on user configurable watermarks is available while allowing concurrent lookups to take place. Objects to be hashed must include a struct rhash_head. The reason for not using the existing struct hlist_head is that the expansion and shrinking will have two buckets point to a single entry which would lead in obscure reverse chaining behaviour. Code includes a boot selftest if CONFIG_TEST_RHASHTABLE is defined. [0] https://www.usenix.org/legacy/event/atc11/tech/final_files/Triplett.pdf Signed-off-by: Thomas Graf <tgraf@suug.ch> Reviewed-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-02iovec: make sure the caller actually wants anything in memcpy_fromiovecendSasha Levin
Check for cases when the caller requests 0 bytes instead of running off and dereferencing potentially invalid iovecs. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-02net: filter: split 'struct sk_filter' into socket and bpf partsAlexei Starovoitov
clean up names related to socket filtering and bpf in the following way: - everything that deals with sockets keeps 'sk_*' prefix - everything that is pure BPF is changed to 'bpf_*' prefix split 'struct sk_filter' into struct sk_filter { atomic_t refcnt; struct rcu_head rcu; struct bpf_prog *prog; }; and struct bpf_prog { u32 jited:1, len:31; struct sock_fprog_kern *orig_prog; unsigned int (*bpf_func)(const struct sk_buff *skb, const struct bpf_insn *filter); union { struct sock_filter insns[0]; struct bpf_insn insnsi[0]; struct work_struct work; }; }; so that 'struct bpf_prog' can be used independent of sockets and cleans up 'unattached' bpf use cases split SK_RUN_FILTER macro into: SK_RUN_FILTER to be used with 'struct sk_filter *' and BPF_PROG_RUN to be used with 'struct bpf_prog *' __sk_filter_release(struct sk_filter *) gains __bpf_prog_release(struct bpf_prog *) helper function also perform related renames for the functions that work with 'struct bpf_prog *', since they're on the same lines: sk_filter_size -> bpf_prog_size sk_filter_select_runtime -> bpf_prog_select_runtime sk_filter_free -> bpf_prog_free sk_unattached_filter_create -> bpf_prog_create sk_unattached_filter_destroy -> bpf_prog_destroy sk_store_orig_filter -> bpf_prog_store_orig_filter sk_release_orig_filter -> bpf_release_orig_filter __sk_migrate_filter -> bpf_migrate_filter __sk_prepare_filter -> bpf_prepare_filter API for attaching classic BPF to a socket stays the same: sk_attach_filter(prog, struct sock *)/sk_detach_filter(struct sock *) and SK_RUN_FILTER(struct sk_filter *, ctx) to execute a program which is used by sockets, tun, af_packet API for 'unattached' BPF programs becomes: bpf_prog_create(struct bpf_prog **)/bpf_prog_destroy(struct bpf_prog *) and BPF_PROG_RUN(struct bpf_prog *, ctx) to execute a program which is used by isdn, ppp, team, seccomp, ptp, xt_bpf, cls_bpf, test_bpf Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-30random32: mix in entropy from core to late initcallHannes Frederic Sowa
Currently, we have a 3-stage seeding process in prandom(): Phase 1 is from the early actual initialization of prandom() subsystem which happens during core_initcall() and remains most likely until the beginning of late_initcall() phase. Here, the system might not have enough entropy available for seeding with strong randomness from the random driver. That means, we currently have a 32bit weak LCG() seeding the PRNG status register 1 and mixing that successively into the other 3 registers just to get it up and running. Phase 2 starts with late_initcall() phase resp. when the random driver has initialized its non-blocking pool with enough entropy. At that time, we throw away *all* inner state from its 4 registers and do a full reseed with strong randomness. Phase 3 starts right after that and does a periodic reseed with random slack of status register 1 by a strong random source again. A problem in phase 1 is that during bootup data structures can be initialized, e.g. on module load time, and thus access a weakly seeded prandom and are never changed for the rest of their live-time, thus carrying along the results from a week seed. Lets make sure that current but also future users access a possibly better early seeded prandom. This patch therefore improves phase 1 by trying to make it more 'unpredictable' through mixing in seed from a possible hardware source. Now, the mix-in xors inner state with the outcome of either of the two functions arch_get_random_{,seed}_int(), preferably arch_get_random_seed_int() as it likely represents a non-deterministic random bit generator in hw rather than a cryptographically secure PRNG in hw. However, not all might have the first one, so we use the PRNG as a fallback if available. As we xor the seed into the current state, the worst case would be that a hardware source could be unverifiable compromised or backdoored. In that case nevertheless it would be as good as our original early seeding function prandom_seed_very_weak() since we mix through xor which is entropy preserving. Joint work with Daniel Borkmann. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-24net: filter: rename 'struct sock_filter_int' into 'struct bpf_insn'Alexei Starovoitov
eBPF is used by socket filtering, seccomp and soon by tracing and exposed to userspace, therefore 'sock_filter_int' name is not accurate. Rename it to 'bpf_insn' Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-23kernel: time: Add udelay_test module to validate udelayDavid Riley
Create a module that allows udelay() to be executed to ensure that it is delaying at least as long as requested (with a little bit of error allowed). There are some configurations which don't have reliably udelay due to using a loop delay with cpufreq changes which should use a counter time based delay instead. This test aims to identify those configurations where timing is unreliable. Signed-off-by: David Riley <davidriley@chromium.org> Signed-off-by: John Stultz <john.stultz@linaro.org>
2014-07-23of: Provide a function to request and map memoryMatthias Brugger
A call to of_iomap does not request the memory region. This patch adds the function of_io_request_and_map which requests the memory region before mapping it. Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com> Suggested-by: Thomas Gleixner <tglx@linutronix.de> Suggested-by: Rob Herring <robh@kernel.org> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2014-07-21Merge 3.16-rc6 into driver-core-nextGreg Kroah-Hartman
We want the platform changes in here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-20net: print net_device reg_state in netdev_* unless it's registeredVeaceslav Falico
This way we'll always know in what status the device is, unless it's running normally (i.e. NETDEV_REGISTERED). Also, emit a warning once in case of a bad reg_state. CC: "David S. Miller" <davem@davemloft.net> CC: Jason Baron <jbaron@akamai.com> CC: Eric Dumazet <edumazet@google.com> CC: Vlad Yasevich <vyasevic@redhat.com> CC: stephen hemminger <stephen@networkplumber.org> CC: Jerry Chu <hkchu@google.com> CC: Ben Hutchings <bhutchings@solarflare.com> CC: Joe Perches <joe@perches.com> Signed-off-by: Veaceslav Falico <vfalico@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-17test: add firmware_class loader testKees Cook
This provides a simple interface to trigger the firmware_class loader to test built-in, filesystem, and user helper modes. Additionally adds tests via the new interface to the selftests tree. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-17digsig: make crypto builtin if digsig selected as builtinDmitry Kasatkin
When SIGNATURE=y but depends on CRYPTO=m, it selects MPILIB as module producing build break. This patch makes digsig to select crypto for correcting dependency. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: David Howells <dhowells@redhat.com>
2014-07-17arch, locking: Ciao arch_mutex_cpu_relax()Davidlohr Bueso
The arch_mutex_cpu_relax() function, introduced by 34b133f, is hacky and ugly. It was added a few years ago to address the fact that common cpu_relax() calls include yielding on s390, and thus impact the optimistic spinning functionality of mutexes. Nowadays we use this function well beyond mutexes: rwsem, qrwlock, mcs and lockref. Since the macro that defines the call is in the mutex header, any users must include mutex.h and the naming is misleading as well. This patch (i) renames the call to cpu_relax_lowlatency ("relax, but only if you can do it with very low latency") and (ii) defines it in each arch's asm/processor.h local header, just like for regular cpu_relax functions. On all archs, except s390, cpu_relax_lowlatency is simply cpu_relax, and thus we can take it out of mutex.h. While this can seem redundant, I believe it is a good choice as it allows us to move out arch specific logic from generic locking primitives and enables future(?) archs to transparently define it, similarly to System Z. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Anton Blanchard <anton@samba.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Bharat Bhushan <r65777@freescale.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Howells <dhowells@redhat.com> Cc: David S. Miller <davem@davemloft.net> Cc: Deepthi Dharwar <deepthi@linux.vnet.ibm.com> Cc: Dominik Dingel <dingel@linux.vnet.ibm.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jason Wang <jasowang@redhat.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Joe Perches <joe@perches.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: Joseph Myers <joseph@codesourcery.com> Cc: Kees Cook <keescook@chromium.org> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Michael Neuling <mikey@neuling.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Mikael Starvik <starvik@axis.com> Cc: Nicolas Pitre <nico@linaro.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Qais Yousef <qais.yousef@imgtec.com> Cc: Qiaowei Ren <qiaowei.ren@intel.com> Cc: Rafael Wysocki <rafael.j.wysocki@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Steven Miao <realmz6@gmail.com> Cc: Steven Rostedt <srostedt@redhat.com> Cc: Stratos Karafotis <stratosk@semaphore.gr> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Vasily Kulikov <segoon@openwall.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com> Cc: Waiman Long <Waiman.Long@hp.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Wolfram Sang <wsa@the-dreams.de> Cc: adi-buildroot-devel@lists.sourceforge.net Cc: linux390@de.ibm.com Cc: linux-alpha@vger.kernel.org Cc: linux-am33-list@redhat.com Cc: linux-arm-kernel@lists.infradead.org Cc: linux-c6x-dev@linux-c6x.org Cc: linux-cris-kernel@axis.com Cc: linux-hexagon@vger.kernel.org Cc: linux-ia64@vger.kernel.org Cc: linux@lists.openrisc.net Cc: linux-m32r-ja@ml.linux-m32r.org Cc: linux-m32r@ml.linux-m32r.org Cc: linux-m68k@lists.linux-m68k.org Cc: linux-metag@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-parisc@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-s390@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-xtensa@linux-xtensa.org Cc: sparclinux@vger.kernel.org Link: http://lkml.kernel.org/r/1404079773.2619.4.camel@buesod1.americas.hpqcorp.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-07-17Merge branch 'locking/urgent' into locking/core, before applying larger ↵Ingo Molnar
changes and to refresh the branch with fixes Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-07-17Merge branch 'rcu/next' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu Pull RCU updates from Paul E. McKenney: * Update RCU documentation. * Miscellaneous fixes. * Maintainership changes. * Torture-test updates. * Callback-offloading changes. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-07-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2014-07-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Bluetooth pairing fixes from Johan Hedberg. 2) ieee80211_send_auth() doesn't allocate enough tail room for the SKB, from Max Stepanov. 3) New iwlwifi chip IDs, from Oren Givon. 4) bnx2x driver reads wrong PCI config space MSI register, from Yijing Wang. 5) IPV6 MLD Query validation isn't strong enough, from Hangbin Liu. 6) Fix double SKB free in openvswitch, from Andy Zhou. 7) Fix sk_dst_set() being racey with UDP sockets, leading to strange crashes, from Eric Dumazet. 8) Interpret the NAPI budget correctly in the new systemport driver, from Florian Fainelli. 9) VLAN code frees percpu stats in the wrong place, leading to crashes in the get stats handler. From Eric Dumazet. 10) TCP sockets doing a repair can crash with a divide by zero, because we invoke tcp_push() with an MSS value of zero. Just skip that part of the sendmsg paths in repair mode. From Christoph Paasch. 11) IRQ affinity bug fixes in mlx4 driver from Amir Vadai. 12) Don't ignore path MTU icmp messages with a zero mtu, machines out there still spit them out, and all of our per-protocol handlers for PMTU can cope with it just fine. From Edward Allcutt. 13) Some NETDEV_CHANGE notifier invocations were not passing in the correct kind of cookie as the argument, from Loic Prylli. 14) Fix crashes in long multicast/broadcast reassembly, from Jon Paul Maloy. 15) ip_tunnel_lookup() doesn't interpret wildcard keys correctly, fix from Dmitry Popov. 16) Fix skb->sk assigned without taking a reference to 'sk' in appletalk, from Andrey Utkin. 17) Fix some info leaks in ULP event signalling to userspace in SCTP, from Daniel Borkmann. 18) Fix deadlocks in HSO driver, from Olivier Sobrie. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (93 commits) hso: fix deadlock when receiving bursts of data hso: remove unused workqueue net: ppp: don't call sk_chk_filter twice mlx4: mark napi id for gro_skb bonding: fix ad_select module param check net: pppoe: use correct channel MTU when using Multilink PPP neigh: sysctl - simplify address calculation of gc_* variables net: sctp: fix information leaks in ulpevent layer MAINTAINERS: update r8169 maintainer net: bcmgenet: fix RGMII_MODE_EN bit tipc: clear 'next'-pointer of message fragments before reassembly r8152: fix r8152_csum_workaround function be2net: set EQ DB clear-intr bit in be_open() GRE: enable offloads for GRE farsync: fix invalid memory accesses in fst_add_one() and fst_init_card() igb: do a reset on SR-IOV re-init if device is down igb: Workaround for i210 Errata 25: Slow System Clock usbnet: smsc95xx: add reset_resume function with reset operation dp83640: Always decode received status frames r8169: disable L23 ...
2014-07-09rcu: Remove CONFIG_PROVE_RCU_DELAYPaul E. McKenney
The CONFIG_PROVE_RCU_DELAY Kconfig parameter doesn't appear to be very effective at finding race conditions, so this commit removes it. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Andi Kleen <ak@linux.intel.com> [ paulmck: Remove definition and uses as noted by Paul Bolle. ]
2014-07-07Merge 3.16-rc4 into driver-core-nextGreg Kroah-Hartman
We want the lz* fixes here to do more work with them. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-03lz4: add overrun checks to lz4_uncompress_unknownoutputsize()Greg Kroah-Hartman
Jan points out that I forgot to make the needed fixes to the lz4_uncompress_unknownoutputsize() function to mirror the changes done in lz4_decompress() with regards to potential pointer overflows. The only in-kernel user of this function is the zram code, which only takes data from a valid compressed buffer that it made itself, so it's not a big issue. But due to external kernel modules using this function, it's better to be safe here. Reported-by: Jan Beulich <JBeulich@suse.com> Cc: "Don A. Bailey" <donb@securitymouse.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-03Merge branch 'component-for-driver' of ↵Greg Kroah-Hartman
git://ftp.arm.linux.org.uk/~rmk/linux-arm into driver-core-next Russell writes: These updates fix one bug in the component helper where the matched components are not properly cleaned up when the master fails to bind. I'll provide a version of this for stable trees if it's deemed that we need to backport it. The second patch causes the component helper to ignore duplicate matches when adding components - this is something that was originally needed for imx-drm, but since that has now been updated, we no longer need to skip over a component which has already been matched. The final patch starts the process of updating the component helper API to achieve two goals: to allow the API to be more efficient when deferred probing occurs, and to allow for future improvements to the component helper without having a major impact on the users. This represents groundwork for some other changes; once this has been merged, I will then send two further pull requests (one for the staging tree, and one for the DRM tree) to update the drivers to the new API. This will result in these three commits being shared with those trees.
2014-07-02lib/cpumask: cpumask_set_cpu_local_first to use all cores when numa node is ↵Amir Vadai
not defined When device is non numa aware (numa_node == -1), use all online cpu's. Signed-off-by: Amir Vadai <amirv@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pendingLinus Torvalds
Pull SCSI target fixes from Nicholas Bellinger: "Mostly minor fixes this time around. The highlights include: - iscsi-target CHAP authentication fixes to enforce explicit key values (Tejas Vaykole + rahul.rane) - fix a long-standing OOPs in target-core when a alua configfs attribute is accessed after port symlink has been removed. (Sebastian Herbszt) - fix a v3.10.y iscsi-target regression causing the login reject status class/detail to be ignored (Christoph Vu-Brugier) - fix a v3.10.y iscsi-target regression to avoid rejecting an existing ITT during Data-Out when data-direction is wrong (Santosh Kulkarni + Arshad Hussain) - fix a iscsi-target related shutdown deadlock on UP kernels (Mikulas Patocka) - fix a v3.16-rc1 build issue with vhost-scsi + !CONFIG_NET (MST)" * git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: iscsi-target: fix iscsit_del_np deadlock on unload iovec: move memcpy_from/toiovecend to lib/iovec.c iscsi-target: Avoid rejecting incorrect ITT for Data-Out tcm_loop: Fix memory leak in tcm_loop_submission_work error path iscsi-target: Explicily clear login response PDU in exception path target: Fix left-over se_lun->lun_sep pointer OOPs iscsi-target; Enforce 1024 byte maximum for CHAP_C key value iscsi-target: Convert chap_server_compute_md5 to use kstrtoul
2014-06-28percpu-refcount: implement percpu_ref_reinit() and percpu_ref_is_zero()Tejun Heo
Now that explicit invocation of percpu_ref_exit() is necessary to free the percpu counter, we can implement percpu_ref_reinit() which reinitializes a released percpu_ref. This can be used implement scalable gating switch which can be drained and then re-opened without worrying about memory allocation failures. percpu_ref_is_zero() is added to be used in a sanity check in percpu_ref_exit(). As this function will be useful for other purposes too, make it a public interface. v2: Use smp_read_barrier_depends() instead of smp_load_acquire(). We only need data dep barrier and smp_load_acquire() is stronger and heavier on some archs. Spotted by Lai Jiangshan. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kent Overstreet <kmo@daterainc.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
2014-06-28percpu-refcount: require percpu_ref to be exited explicitlyTejun Heo
Currently, a percpu_ref undoes percpu_ref_init() automatically by freeing the allocated percpu area when the percpu_ref is killed. While seemingly convenient, this has the following niggles. * It's impossible to re-init a released reference counter without going through re-allocation. * In the similar vein, it's impossible to initialize a percpu_ref count with static percpu variables. * We need and have an explicit destructor anyway for failure paths - percpu_ref_cancel_init(). This patch removes the automatic percpu counter freeing in percpu_ref_kill_rcu() and repurposes percpu_ref_cancel_init() into a generic destructor now named percpu_ref_exit(). percpu_ref_destroy() is considered but it gets confusing with percpu_ref_kill() while "exit" clearly indicates that it's the counterpart of percpu_ref_init(). All percpu_ref_cancel_init() users are updated to invoke percpu_ref_exit() instead and explicit percpu_ref_exit() calls are added to the destruction path of all percpu_ref users. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Benjamin LaHaise <bcrl@kvack.org> Cc: Kent Overstreet <kmo@daterainc.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: Nicholas A. Bellinger <nab@linux-iscsi.org> Cc: Li Zefan <lizefan@huawei.com>
2014-06-28percpu-refcount: use unsigned long for pcpu_count pointerTejun Heo
percpu_ref->pcpu_count is a percpu pointer with a status flag in its lowest bit. As such, it always goes through arithmetic operations which is very cumbersome to do on a pointer. It has to be first casted to unsigned long and then back. Let's just make the field unsigned long so that we can skip the first casts. While at it, rename it to pcpu_counter_ptr to clarify that it's a pointer value. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kent Overstreet <kmo@daterainc.com> Cc: Christoph Lameter <cl@linux-foundation.org>
2014-06-28percpu-refcount: add helpers for ->percpu_count accessesTejun Heo
* All four percpu_ref_*() operations implemented in the header file perform the same operation to determine whether the percpu_ref is alive and extract the percpu pointer. Factor out the common logic into __pcpu_ref_alive(). This doesn't change the generated code. * There are a couple places in percpu-refcount.c which masks out PCPU_REF_DEAD to obtain the percpu pointer. Factor it out into pcpu_count_ptr(). * The above changes make the WARN_ON_ONCE() conditional at the top of percpu_ref_kill_and_confirm() the only user of REF_STATUS(). Test PCPU_REF_DEAD directly and remove REF_STATUS(). This patch doesn't introduce any functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kent Overstreet <kmo@daterainc.com> Cc: Christoph Lameter <cl@linux-foundation.org>
2014-06-28percpu-refcount: one bit is enough for REF_STATUSTejun Heo
percpu-refcount currently reserves two lowest bits of its percpu pointer to indicate its state; however, only one bit is used for PCPU_REF_DEAD. Simplify it by removing PCPU_STATUS_BITS/MASK and testing PCPU_REF_DEAD directly. This also allows the compiler to choose a more efficient instruction depending on the architecture. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kent Overstreet <kmo@daterainc.com> Cc: Christoph Lameter <cl@linux-foundation.org>
2014-06-27Merge tag 'compress-3.16-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull compress bugfix from Greg KH: "Here is another lz4 bugfix for 3.16-rc3 that resolves a reported issue with that compression algorithm" * tag 'compress-3.16-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: lz4: fix another possible overrun
2014-06-27Merge tag 'stable/for-linus-3.16-rc1-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb Pull swiotlb bugfix from Konrad Rzeszutek Wilk: "One bug-fix that had been in tree for quite some time. We had assumed that the physical address zero was invalid and would fail it. But that is not true and on some architectures it is not reserved and valid. This fixes it" * tag 'stable/for-linus-3.16-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/swiotlb: swiotlb: don't assume PA 0 is invalid
2014-06-27iovec: move memcpy_from/toiovecend to lib/iovec.cMichael S. Tsirkin
ERROR: "memcpy_fromiovecend" [drivers/vhost/vhost_scsi.ko] undefined! commit 9f977ef7b671f6169eca78bf40f230fe84b7c7e5 vhost-scsi: Include prot_bytes into expected data transfer length in target-pending makes drivers/vhost/scsi.c call memcpy_fromiovecend(). This function is not available when CONFIG_NET is not enabled. socket.h already includes uio.h, so no callers need updating. Reported-by: Randy Dunlap <rdunlap@infradead.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2014-06-27lz4: fix another possible overrunGreg Kroah-Hartman
There is one other possible overrun in the lz4 code as implemented by Linux at this point in time (which differs from the upstream lz4 codebase, but will get synced at in a future kernel release.) As pointed out by Don, we also need to check the overflow in the data itself. While we are at it, replace the odd error return value with just a "simple" -1 value as the return value is never used for anything other than a basic "did this work or not" check. Reported-by: "Don A. Bailey" <donb@securitymouse.com> Reported-by: Willy Tarreau <w@1wt.eu> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2014-06-25mac_pton: Use bool not int returnJoe Perches
Use bool instead of int as the return type. All uses are tested with !. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-25lib: crc32: Add some additional __pure annotationsGeorge Spelvin
In case they help the compiler. Signed-off-by: George Spelvin <linux@horizon.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-25lib: crc32: Mark test data __initconstGeorge Spelvin
So it gets discarded after the selftest. Signed-off-by: George Spelvin <linux@horizon.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-25lib: crc32: Greatly shrink CRC combining codeGeorge Spelvin
There's no need for a full 32x32 matrix, when rows before the last are just shifted copies of the rows after them. There's still room for improvement (especially on X86 processors with CRC32 and PCLMUL instructions), but this is a large step in the right direction [which is in particular useful for its current user, namely SCTP checksumming over multiple skb frags[] entries, i.e. in IPVS balancing when other CRC32 offloads are not available]. The internal primitive is now called crc32_generic_shift and takes one less argument; the XOR with crc2 is done in inline wrappers. Signed-off-by: George Spelvin <linux@horizon.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
