path: root/lib
2009-08-26flex_array: convert element_nr formals to unsignedDavid Rientjes
It's problematic to allow signed element_nr's or total's to be passed as part of the flex array API. flex_array_alloc() allows total_nr_elements to be set to a negative quantity, which is obviously erroneous. flex_array_get() and flex_array_put() allows negative array indices in dereferencing an array part, which could address memory mapped before struct flex_array. The fix is to convert all existing element_nr formals to be qualified as unsigned. Existing checks to compare it to total_nr_elements or the max array size based on element_size need not be changed. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-26flex_array: fix flex_array_free_parts commentDavid Rientjes
flex_array_free_parts() does not take `src' or `element_nr' formals, so remove their respective comments. Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-26flex_array: fix get function for elements in base starting at non-zeroDavid Rientjes
If all array elements fit into the base structure and data is copied using flex_array_put() starting at a non-zero index, flex_array_get() will fail to return the data. This fixes the bug by only checking for NULL parts when all elements do not fit in the base structure when flex_array_get() is used. Otherwise, fa_element_to_part_nr() will always be 0 since there are no parts structures needed and such element may never have been put. Thus, it will remain NULL due to the kzalloc() of the base. Additionally, flex_array_put() now only checks for a NULL part when all elements do not fit in the base structure. This is otherwise unnecessary since the base structure is guaranteed to exist (or we would have already hit a NULL pointer). Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-25Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: dma-debug: Fix check_unmap null pointer dereference
2009-08-21Make bitmask 'and' operators return a result codeLinus Torvalds
When 'and'ing two bitmasks (where 'andnot' is a variation on it), some cases want to know whether the result is the empty set or not. In particular, the TLB IPI sending code wants to do cpumask operations and determine if there are any CPU's left in the final set. So this just makes the bitmask (and cpumask) functions return a boolean for whether the result has any bits set. Cc: stable@kernel.org (2.6.30, needed by TLB shootdown fix) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-21dma-debug: Fix check_unmap null pointer dereferenceKyle McMartin
While it's debatable whether or not a NULL device argument to the DMA API functions is valid... since it certainly isn't valid on devices with an IOMMU... dma-debug really shouldn't be dereferencing null pointers either. Guard against that in err_printk and the driver_filter functions. A Fedora rawhide user was seeing this in one of the dvb drivers resulting in an oops on boot. [ A patch has been sent for testing to the driver, but I feel the dma debugging support should be fixed as well. (There's still a pile of legacy garbage in the kernel passing null pointers to dma_{alloc,free}_*. :( ] Signed-off-by: Kyle McMartin <kyle@redhat.com> Cc: mchehab@infradead.org Cc: Joerg Roedel <joerg.roedel@amd.com> LKML-Reference: <20090820011708.GP25206@bombadil.infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-07lib/decompress_*: only include <linux/slab.h> if STATIC is not definedAlbin Tonnerre
These includes were added by 079effb6933f34b9b1b67b08bd4fd7fb672d16ef ("kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_inflate.c") to fix the build when using kmemtrace. However this is not necessary when used to create a compressed kernel, and actually creates issues (brings a lot of things unavailable in the decompression environment), so don't include it if STATIC is defined. Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-07bzip2/lzma: remove nasty uncompressed size hack in pre-boot environmentPhillip Lougher
decompress_bunzip2 and decompress_unlzma have a nasty hack that subtracts 4 from the input length if being called in the pre-boot environment. This is a nasty hack because it relies on the fact that flush = NULL only when called from the pre-boot environment (i.e. arch/x86/boot/compressed/misc.c). initramfs.c/do_mounts_rd.c pass in a flush buffer (flush != NULL). This hack prevents the decompressors from being used with flush = NULL by other callers unless knowledge of the hack is propagated to them. This patch removes the hack by making decompress (called only from the pre-boot environment) a wrapper function that subtracts 4 from the input length before calling the decompressor. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-07bzip2/lzma/gzip: fix comments describing decompressor APIPhillip Lougher
Fix and improve comments in decompress/generic.h that describe the decompressor API. Also remove an unused definition, and rename INBUF_LEN in lib/decompress_inflate.c to conform to bzip2/lzma naming. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-04flex_array: remove unneeded index calculationJonathan Corbet
flex_array_get() calculates an index value, then drops it on the floor; simply remove it. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-31lib/scatterlist: add a flags to signalize mapping directionSebastian Andrzej Siewior
sg_miter_start() is currently unaware of the direction of the copy process (to or from the scatter list). It is important to know the direction because the page has to be flushed in case the data written is seen on a different mapping in user land on cache incoherent architectures. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Pierre Ossman <pierre@ossman.eu>
2009-07-29lib: flexible array implementationDave Hansen
Once a structure goes over PAGE_SIZE*2, we see occasional allocation failures. Some people have chosen to switch over to things like vmalloc() that will let them keep array-like access to such a large structures. But, vmalloc() has plenty of downsides. Here's an alternative. I think it's what Andrew was suggesting here: http://lkml.org/lkml/2009/7/2/518 I call it a flexible array. It does all of its work in PAGE_SIZE bits, so never does an order>0 allocation. The base level has PAGE_SIZE-2*sizeof(int) bytes of storage for pointers to the second level. So, with a 32-bit arch, you get about 4MB (4183112 bytes) of total storage when the objects pack nicely into a page. It is half that on 64-bit because the pointers are twice the size. There's a table detailing this in the code. There are kerneldocs for the functions, but here's an overview: flex_array_alloc() - dynamically allocate a base structure flex_array_free() - free the array and all of the second-level pages flex_array_free_parts() - free the second-level pages, but not the base (for static bases) flex_array_put() - copy into the array at the given index flex_array_get() - copy out of the array at the given index flex_array_prealloc() - preallocate the second-level pages between the given indexes to guarantee no allocs will occur at put() time. We could also potentially just pass the "element_size" into each of the API functions instead of storing it internally. That would get us one more base pointer on 32-bit. I've been testing this by running it in userspace. The header and patch that I've been using are here, as well as the little script I'm using to generate the size table which goes in the kerneldocs. http://sr71.net/~dave/linux/flexarray/ [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29lib: export generic atomic64_t functionsRoland Dreier
The generic atomic64_t implementation in lib/ did not export the functions it defined, which means that modules that use atomic64_t would not link on platforms (such as 32-bit powerpc). For example, trying to build a kernel with CONFIG_NET_RDS on such a platform would fail with: ERROR: "atomic64_read" [net/rds/rds.ko] undefined! ERROR: "atomic64_set" [net/rds/rds.ko] undefined! Fix this by exporting the atomic64_t functions to modules. (I export the entire API even if it's not all currently used by in-tree modules to avoid having to continue fixing this in dribs and drabs) Signed-off-by: Roland Dreier <rolandd@cisco.com> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-28Dynamic debug: fix typo: -/->Roel Kluin
The member was intended, not the local variable. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Greg Banks <gnb@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-10Merge branch 'core-fixes-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: dma-debug: Fix the overlap() function to be correct and readable oprofile: reset bt_lost_no_mapping with other stats x86/oprofile: rename kernel parameter for architectural perfmon to arch_perfmon signals: declare sys_rt_tgsigqueueinfo in syscalls.h rcu: Mark Hierarchical RCU no longer experimental dma-debug: Put all hash-chain locks into the same lock class dma-debug: fix off-by-one error in overlap function
2009-07-10dma-debug: Fix the overlap() function to be correct and readableIngo Molnar
Linus noticed how unclean and buggy the overlap() function is: - It uses convoluted (and bug-causing) positive checks for range overlap - instead of using a more natural negative check. - Even the positive checks are buggy: a positive intersection check has four natural cases while we checked only for three, missing the (addr < start && addr2 == end) case for example. - The variables are mis-named, making it non-obvious how the check was done. - It needlessly uses u64 instead of unsigned long. Since these are kernel memory pointers and we explicitly exclude highmem ranges anyway we cannot ever overflow 32 bits, even if we could. (and on 64-bit it doesnt matter anyway) All in one, this function needs a total revamp. I used Linus's suggestions minus the paranoid checks (we cannot overflow really because if we get totally bad DMA ranges passed far more things break in the systems than just DMA debugging). I also fixed a few other small details i noticed. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-03Merge branch 'dma-debug/fixes' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/joro/linux-2.6-iommu into core/urgent
2009-06-25kmemleak: Allow the early log buffer to be configurable.Catalin Marinas
(feature suggested by Sergey Senozhatsky) Kmemleak needs to track all the memory allocations but some of these happen before kmemleak is initialised. These are stored in an internal buffer which may be exceeded in some kernel configurations. This patch adds a configuration option with a default value of 400 and also removes the stack dump when the early log buffer is exceeded. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Sergey Senozhatsky <sergey.senozhatsky@mail.by>
2009-06-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: asm-generic: add dummy pgprot_noncached() lib/checksum.c: fix endianess bug asm-generic: hook up new system calls asm-generic: list Arnd as asm-generic maintainer asm-generic: drop HARDIRQ_BITS definition from hardirq.h asm-generic: uaccess: fix up local access_ok() usage asm-generic: uaccess: add missing access_ok() check to strnlen_user()
2009-06-23kmemleak: Do not force the slab debugging Kconfig optionsCatalin Marinas
Selecting DEBUG_SLAB or SLUB_DEBUG by the KMEMLEAK menu entry may cause issues with other dependencies (KMEMCHECK). These configuration options aren't strictly needed by kmemleak but they may increase the chances of finding leaks. This patch also updates the KMEMLEAK config entry help text. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-06-21Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: lockdep: Select frame pointers on x86 dma-debug: be more careful when building reference entries dma-debug: check for sg_call_ents in best-fit algorithm too
2009-06-21lockdep: Select frame pointers on x86Peter Zijlstra
x86 stack traces are a piece of crap without frame pointers, and its not like the 'performance gain' of not having stack pointers matters when you selected lockdep. Reported-by: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <new-submission> Cc: <stable@kernel.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-19lib/checksum.c: fix endianess bugArnd Bergmann
The new generic checksum code has a small dependency on endianess and worked only on big-endian systems. I could not find a nice efficient way to express this, so I added an #ifdef. Using 'result += le16_to_cpu(*buff);' would have worked as well, but would be slightly less efficient on big-endian systems and IMHO would not be clearer. Also fix a bug that prevents this from working on 64-bit machines. If you have a 64-bit CPU and want to use the generic checksum code, you should probably do some more optimizations anyway, but at least the code should not break. Reported-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-18lib: add lib/gcd.cFlorian Fainelli
This patch adds lib/gcd.c which contains a greatest common divider implementation taken from sound/core/pcm_timer.c Several usages of this new library function will be sent to subsystem maintainers. [akpm@linux-foundation.org: use swap() (pointed out by Joe)] [akpm@linux-foundation.org: just add gcd.o to obj-y, remove Kconfig changes] Signed-off-by: Florian Fainelli <florian@openwrt.org> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Simon Horman <horms@verge.net.au> Cc: Julius Volz <juliusv@google.com> Cc: David S. Miller <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-17dma-debug: Put all hash-chain locks into the same lock classIngo Molnar
Alan Cox reported that lockdep runs out of its stack-trace entries with certain configs: BUG: MAX_STACK_TRACE_ENTRIES too low This happens because there are 1024 hash buckets, each with a separate lock. Lockdep puts each lock into a separate lock class and tracks them independently. But in reality we never take more than one of the buckets, so they really belong into a single lock-class. Annotate the has bucket lock init accordingly. [ Impact: reduce the lockdep footprint of dma-debug ] Reported-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-06-16Merge branch 'akpm'Linus Torvalds
* akpm: (182 commits) fbdev: bf54x-lq043fb: use kzalloc over kmalloc/memset fbdev: *bfin*: fix __dev{init,exit} markings fbdev: *bfin*: drop unnecessary calls to memset fbdev: bfin-t350mcqb-fb: drop unused local variables fbdev: blackfin has __raw I/O accessors, so use them in fb.h fbdev: s1d13xxxfb: add accelerated bitblt functions tcx: use standard fields for framebuffer physical address and length fbdev: add support for handoff from firmware to hw framebuffers intelfb: fix a bug when changing video timing fbdev: use framebuffer_release() for freeing fb_info structures radeon: P2G2CLK_ALWAYS_ONb tested twice, should 2nd be P2G2CLK_DAC_ALWAYS_ONb? s3c-fb: CPUFREQ frequency scaling support s3c-fb: fix resource releasing on error during probing carminefb: fix possible access beyond end of carmine_modedb[] acornfb: remove fb_mmap function mb862xxfb: use CONFIG_OF instead of CONFIG_PPC_OF mb862xxfb: restrict compliation of platform driver to PPC Samsung SoC Framebuffer driver: add Alpha Channel support atmel-lcdc: fix pixclock upper bound detection offb: use framebuffer_alloc() to allocate fb_info struct ... Manually fix up conflicts due to kmemcheck in mm/slab.c
2009-06-16rb_tree: remove redundant if()-condition in rb_erase()Wolfram Strepp
Furthermore, notice that the initial checks: if (!node->rb_left) child = node->rb_right; else if (!node->rb_right) child = node->rb_left; else { ... } guarantee that old->rb_right is set in the final else branch, therefore we can omit checking that again. Signed-off-by: Wolfram Strepp <wstrepp@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16rb_tree: make clear distinction between two different cases in rb_erase()Wolfram Strepp
There are two cases when a node, having 2 childs, is erased: 'normal case': the successor is not the right-hand-child of the node to be erased 'special case': the successor is the right-hand child of the node to be erased Here some ascii-art, with following symbols (referring to the code): O: node to be deleted N: the successor of O P: parent of N C: child of N L: some other node normal case: O N / \ / \ / \ / \ L \ L \ / \ P ----> / \ P / \ / \ / / N C \ / \ \ C / \ special case: O|P N / \ / \ / \ / \ L \ L \ / \ N ----> / C \ / \ \ C / \ Notice that for the special case we don't have to reconnect C to N. Signed-off-by: Wolfram Strepp <wstrepp@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16rb_tree: reorganize code in rb_erase() for additional changesWolfram Strepp
First, move some code around in order to make the next change more obvious. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Wolfram Strepp <wstrepp@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16lib/genalloc.c: remove unmatched write_lock() in gen_pool_destroyZygo Blaxell
There is a call to write_lock() in gen_pool_destroy which is not balanced by any corresponding write_unlock(). This causes problems with preemption because the preemption-disable counter is incremented in the write_lock() call, but never decremented by any call to write_unlock(). This bug is gen_pool_destroy, and one of them is non-x86 arch-specific code. Signed-off-by: Zygo Blaxell <zygo.blaxell@xandros.com> Cc: Jiri Kosina <trivial@kernel.org> Cc: Steve Wise <swise@opengridcomputing.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16hexdump: remove the trailing spaceLi Zefan
For example: hex_dump_to_buffer("AB", 2, 16, 1, buf, 100, 0); pr_info("[%s]\n", buf); I'd expect the output to be "[41 42]", but actually it's "[41 42 ]" This patch also makes the required buf to be minimum. To print the hex format of "AB", a buf with size 6 should be sufficient, but hex_dump_to_buffer() required at least 8. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16lib: do code optimization for radix_tree_lookup() and radix_tree_lookup_slot()Huang Shijie
radix_tree_lookup() and radix_tree_lookup_slot() have much the same code except for the return value. Introduce radix_tree_lookup_element() to do the real work. /* * is_slot == 1 : search for the slot. * is_slot == 0 : search for the node. */ static void * radix_tree_lookup_element(struct radix_tree_root *root, unsigned long index, int is_slot); Signed-off-by: Huang Shijie <shijie8@gmail.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16atomic: only take lock when the counter drops to zero on UP as wellJan Blunck
_atomic_dec_and_lock() should not unconditionally take the lock before calling atomic_dec_and_test() in the UP case. For consistency reasons it should behave exactly like in the SMP case. Besides that this works around the problem that with CONFIG_DEBUG_SPINLOCK this spins in __spin_lock_debug() if the lock is already taken even if the counter doesn't drop to 0. Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Nick Piggin <npiggin@suse.de> Cc: Valerie Aurora <vaurora@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16radix-tree: add radix_tree_prev_hole()Wu Fengguang
The counterpart of radix_tree_next_hole(). To be used by context readahead. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Vladislav Bolkhovitin <vst@vlnb.net> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vegard/kmemcheck * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/vegard/kmemcheck: (39 commits) signal: fix __send_signal() false positive kmemcheck warning fs: fix do_mount_root() false positive kmemcheck warning fs: introduce __getname_gfp() trace: annotate bitfields in struct ring_buffer_event net: annotate struct sock bitfield c2port: annotate bitfield for kmemcheck net: annotate inet_timewait_sock bitfields ieee1394/csr1212: fix false positive kmemcheck report ieee1394: annotate bitfield net: annotate bitfields in struct inet_sock net: use kmemcheck bitfields API for skbuff kmemcheck: introduce bitfield API kmemcheck: add opcode self-testing at boot x86: unify pte_hidden x86: make _PAGE_HIDDEN conditional kmemcheck: make kconfig accessible for other architectures kmemcheck: enable in the x86 Kconfig kmemcheck: add hooks for the page allocator kmemcheck: add hooks for page- and sg-dma-mappings kmemcheck: don't track page tables ...
2009-06-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (64 commits) debugfs: use specified mode to possibly mark files read/write only debugfs: Fix terminology inconsistency of dir name to mount debugfs filesystem. xen: remove driver_data direct access of struct device from more drivers usb: gadget: at91_udc: remove driver_data direct access of struct device uml: remove driver_data direct access of struct device block/ps3: remove driver_data direct access of struct device s390: remove driver_data direct access of struct device parport: remove driver_data direct access of struct device parisc: remove driver_data direct access of struct device of_serial: remove driver_data direct access of struct device mips: remove driver_data direct access of struct device ipmi: remove driver_data direct access of struct device infiniband: ehca: remove driver_data direct access of struct device ibmvscsi: gadget: at91_udc: remove driver_data direct access of struct device hvcs: remove driver_data direct access of struct device xen block: remove driver_data direct access of struct device thermal: remove driver_data direct access of struct device scsi: remove driver_data direct access of struct device pcmcia: remove driver_data direct access of struct device PCIE: remove driver_data direct access of struct device ... Manually fix up trivial conflicts due to different direct driver_data direct access fixups in drivers/block/{ps3disk.c,ps3vram.c}
2009-06-16dma-debug: fix off-by-one error in overlap functionJoerg Roedel
This patch fixes a bug in the overlap function which returned true if one region ends exactly before the second region begins. This is no overlap but the function returned true in that case. Cc: stable@kernel.org Reported-by: Andrew Randrianasulu <randrik@mail.ru> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-06-15kobject: make kset_create check kobject_set_name return valueDave Young
kset_create should check the kobject_set_name return value. Add the return value checking code. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15Merge commit 'linus/master' into HEADVegard Nossum
Conflicts: MAINTAINERS Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2009-06-15kmemcheck: make kconfig accessible for other architecturesPekka Enberg
The Kconfig options of kmemcheck are hidden under arch/x86 which makes porting to other architectures harder. To fix that, move the Kconfig bits to lib/Kconfig.kmemcheck and introduce a CONFIG_HAVE_ARCH_KMEMCHECK config option that architectures can define. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> [rebased for mainline inclusion] Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2009-06-15kmemcheck: enable in the x86 KconfigVegard Nossum
let it rip! Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu> [rebased for mainline inclusion] Signed-off-by: Vegard Nossum <vegardno@ifi.uio.no>
2009-06-15dma-debug: be more careful when building reference entriesJoerg Roedel
The current code is not very careful when it builds reference dma_debug_entries which get passed to hash_bucket_find(). But since this function changed to a best-fit algorithm these entries have to be more acurate. This patch adds this higher level of accuracy. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-06-15dma-debug: check for sg_call_ents in best-fit algorithm tooJoerg Roedel
If we don't check for sg_call_ents the hash_bucket_find function might still return the wrong dma_debug_entry for sg mappings. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-06-15lib: Provide generic atomic64_t implementationPaul Mackerras
Many processor architectures have no 64-bit atomic instructions, but we need atomic64_t in order to support the perf_counter subsystem. This adds an implementation of 64-bit atomic operations using hashed spinlocks to provide atomicity. For each atomic operation, the address of the atomic64_t variable is hashed to an index into an array of 16 spinlocks. That spinlock is taken (with interrupts disabled) around the operation, which can then be coded non-atomically within the lock. On UP, all the spinlock manipulation goes away and we simply disable interrupts around each operation. In fact gcc eliminates the whole atomic64_lock variable as well. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: add generic lib/checksum.c asm-generic: add a generic uaccess.h asm-generic: add generic NOMMU versions of some headers asm-generic: add generic atomic.h and io.h asm-generic: add legacy I/O header files asm-generic: add generic versions of common headers asm-generic: make bitops.h usable asm-generic: make pci.h usable directly asm-generic: make get_rtc_time overridable asm-generic: rename page.h and uaccess.h asm-generic: rename atomic.h to atomic-long.h asm-generic: add a generic unistd.h asm-generic: add generic ABI headers asm-generic: add generic sysv ipc headers asm-generic: introduce asm/bitsperlong.h asm-generic: rename termios.h, signal.h and mman.h
2009-06-12module: trim exception table on init free.Rusty Russell
It's theoretically possible that there are exception table entries which point into the (freed) init text of modules. These could cause future problems if other modules get loaded into that memory and cause an exception as we'd see the wrong fixup. The only case I know of is kvm-intel.ko (when CONFIG_CC_OPTIMIZE_FOR_SIZE=n). Amerigo fixed this long-standing FIXME in the x86 version, but this patch is more general. This implements trim_init_extable(); most archs are simple since they use the standard lib/extable.c sort code. Alpha and IA64 use relative addresses in their fixups, so thier trimming is a slight variation. Sparc32 is unique; it doesn't seem to define ARCH_HAS_SORT_EXTABLE, yet it defines its own sort_extable() which overrides the one in lib. It doesn't sort, so we have to mark deleted entries instead of actually trimming them. Inspired-by: Amerigo Wang <amwang@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: linux-alpha@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: linux-ia64@vger.kernel.org
2009-06-12asm-generic: merge branch 'master' of torvalds/linux-2.6Arnd Bergmann
Fixes a merge conflict against the x86 tree caused by a fix to atomic.h which I renamed to atomic_long.h. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-06-11Merge branch 'for-linus' of git://linux-arm.org/linux-2.6Linus Torvalds
* 'for-linus' of git://linux-arm.org/linux-2.6: kmemleak: Add the corresponding MAINTAINERS entry kmemleak: Simple testing module for kmemleak kmemleak: Enable the building of the memory leak detector kmemleak: Remove some of the kmemleak false positives kmemleak: Add modules support kmemleak: Add kmemleak_alloc callback from alloc_large_system_hash kmemleak: Add the vmalloc memory allocation/freeing hooks kmemleak: Add the slub memory allocation/freeing hooks kmemleak: Add the slob memory allocation/freeing hooks kmemleak: Add the slab memory allocation/freeing hooks kmemleak: Add documentation on the memory leak detector kmemleak: Add the base support Manual conflict resolution (with the slab/earlyboot changes) in: drivers/char/vt.c init/main.c mm/slab.c
2009-06-11Merge branch 'topic/slab/earlyboot' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'topic/slab/earlyboot' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: vgacon: use slab allocator instead of the bootmem allocator irq: use kcalloc() instead of the bootmem allocator sched: use slab in cpupri_init() sched: use alloc_cpumask_var() instead of alloc_bootmem_cpumask_var() memcg: don't use bootmem allocator in setup code irq/cpumask: make memoryless node zero happy x86: remove some alloc_bootmem_cpumask_var calling vt: use kzalloc() instead of the bootmem allocator sched: use kzalloc() instead of the bootmem allocator init: introduce mm_init() vmalloc: use kzalloc() instead of alloc_bootmem() slab: setup allocators earlier in the boot sequence bootmem: fix slab fallback on numa bootmem: use slab if bootmem is no longer available
2009-06-11add generic lib/checksum.cArnd Bergmann
Add a generic (unoptimized) implementation of checksum.c in pure C for use by all architectures that cannot be bother with implementing their own version. Based on microblaze code by Michal Simek <monstr@monstr.eu> Cc: Michal Simek <monstr@monstr.eu> Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
