path: root/lib/rwsem-spinlock.c
2009-12-15rwsem: fix rwsem_is_locked() bugsAmerigo Wang
rwsem_is_locked() tests ->activity without locks, so we should always keep ->activity consistent. However, the code in __rwsem_do_wake() breaks this rule, it updates ->activity after _all_ readers waken up, this may give some reader a wrong ->activity value, thus cause rwsem_is_locked() behaves wrong. Quote from Andrew: " - we have one or more processes sleeping in down_read(), waiting for access. - we wake one or more processes up without altering ->activity - they start to run and they do rwsem_is_locked(). This incorrectly returns "false", because the waker process is still crunching away in __rwsem_do_wake(). - the waker now alters ->activity, but it was too late. " So we need get a spinlock to protect this. And rwsem_is_locked() should not block, thus we use spin_trylock_irqsave(). [akpm@linux-foundation.org: simplify code] Reported-by: Brian Behlendorf <behlendorf1@llnl.gov> Cc: Ben Woodard <bwoodard@llnl.gov> Cc: David Howells <dhowells@redhat.com> Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15rwsem-spinlock: remove useless function exportsAmerigo Wang
These functions need not to be exported, since no drivers should use them. __init_rwsem() is an exception, because init_rwsem(), which is a macro, is used. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08lib: remove fastcall from lib/*Harvey Harrison
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-11Lockdep: add lockdep_set_class_and_subclass() and lockdep_set_subclass()Peter Zijlstra
This annotation makes it possible to assign a subclass on lock init. This annotation is meant to reduce the _nested() annotations by assigning a default subclass. One could do without this annotation and rely on lockdep_set_class() exclusively, but that would require a manual stack of struct lock_class_key objects. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-07-03[PATCH] lockdep: prove rwsem locking correctnessIngo Molnar
Use the lock validator framework to prove rwsem locking correctness. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: clean up rwsemsIngo Molnar
Clean up rwsems. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] use smp_mb/wmb/rmb where possibleakpm@osdl.org
Replace a number of memory barriers with smp_ variants. This means we won't take the unnecessary hit on UP machines. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
