[ Upstream commit 624fa7790f80575a4ec28fbdb2034097dc18d051 ]
In the scsi_transport_srp implementation it cannot be avoided to
iterate over a klist from atomic context when using the legacy block
layer instead of blk-mq. Hence this patch that makes it safe to use
klists in atomic context. This patch avoids that lockdep reports the
following:
WARNING: SOFTIRQ-safe -> SOFTIRQ-unsafe lock order detected
Possible interrupt unsafe locking scenario:
CPU0 CPU1
lock(&(&k->k_lock)->rlock);
local_irq_disable();
lock(&(&q->__queue_lock)->rlock);
<Interrupt>
stack backtrace:
Workqueue: kblockd blk_timeout_work
Call Trace:
dump_stack+0xa4/0xf5
check_usage+0x6e6/0x700
__lock_acquire+0x185d/0x1b50
lock_acquire+0xd2/0x260
_raw_spin_lock+0x32/0x50
klist_next+0x47/0x190
device_for_each_child+0x8e/0x100
srp_timed_out+0xaf/0x1d0 [scsi_transport_srp]
scsi_times_out+0xd4/0x410 [scsi_mod]
blk_rq_timed_out+0x36/0x70
blk_timeout_work+0x1b5/0x220
process_one_work+0x4fe/0xad0
worker_thread+0x63/0x5a0
kthread+0x1c1/0x1e0
ret_from_fork+0x24/0x30
See also commit c9ddf73476ff ("scsi: scsi_transport_srp: Fix shost to
rport translation").
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Cc: James Bottomley <jejb@linux.vnet.ibm.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit 00cd29b799e3449f0c68b1cc77cd4a5f95b42d17 upstream.
The starting node for a klist iteration is often passed in from
somewhere way above the klist infrastructure, meaning there's no
guarantee the node is still on the list. We've seen this in SCSI where
we use bus_find_device() to iterate through a list of devices. In the
face of heavy hotplug activity, the last device returned by
bus_find_device() can be removed before the next call. This leads to
Dec 3 13:22:02 localhost kernel: WARNING: CPU: 2 PID: 28073 at include/linux/kref.h:47 klist_iter_init_node+0x3d/0x50()
Dec 3 13:22:02 localhost kernel: Modules linked in: scsi_debug x86_pkg_temp_thermal kvm_intel kvm irqbypass crc32c_intel joydev iTCO_wdt dcdbas ipmi_devintf acpi_power_meter iTCO_vendor_support ipmi_si imsghandler pcspkr wmi acpi_cpufreq tpm_tis tpm shpchp lpc_ich mfd_core nfsd nfs_acl lockd grace sunrpc tg3 ptp pps_core
Dec 3 13:22:02 localhost kernel: CPU: 2 PID: 28073 Comm: cat Not tainted 4.4.0-rc1+ #2
Dec 3 13:22:02 localhost kernel: Hardware name: Dell Inc. PowerEdge R320/08VT7V, BIOS 2.0.22 11/19/2013
Dec 3 13:22:02 localhost kernel: ffffffff81a20e77 ffff880613acfd18 ffffffff81321eef 0000000000000000
Dec 3 13:22:02 localhost kernel: ffff880613acfd50 ffffffff8107ca52 ffff88061176b198 0000000000000000
Dec 3 13:22:02 localhost kernel: ffffffff814542b0 ffff880610cfb100 ffff88061176b198 ffff880613acfd60
Dec 3 13:22:02 localhost kernel: Call Trace:
Dec 3 13:22:02 localhost kernel: [<ffffffff81321eef>] dump_stack+0x44/0x55
Dec 3 13:22:02 localhost kernel: [<ffffffff8107ca52>] warn_slowpath_common+0x82/0xc0
Dec 3 13:22:02 localhost kernel: [<ffffffff814542b0>] ? proc_scsi_show+0x20/0x20
Dec 3 13:22:02 localhost kernel: [<ffffffff8107cb4a>] warn_slowpath_null+0x1a/0x20
Dec 3 13:22:02 localhost kernel: [<ffffffff8167225d>] klist_iter_init_node+0x3d/0x50
Dec 3 13:22:02 localhost kernel: [<ffffffff81421d41>] bus_find_device+0x51/0xb0
Dec 3 13:22:02 localhost kernel: [<ffffffff814545ad>] scsi_seq_next+0x2d/0x40
And an eventual crash. It can actually occur in any hotplug system
which has a device finder and a starting device.
We can fix this globally by making sure the starting node for
klist_iter_init_node() is actually a member of the list before using it
(and by starting from the beginning if it isn't).
Reported-by: Ewan D. Milne <emilne@redhat.com>
Tested-by: Ewan D. Milne <emilne@redhat.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
klist_prev() gets the previous element in the list. It is useful to traverse
through the list in reverse order, for example, to provide LIFO (last in first
out) variant of access.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
The name was modified from hlist_add_after() to hlist_add_behind() when
adjusting the order of arguments to match the one with
klist_add_after(). This is necessary to break old code when it would
use it the wrong way.
Make klist follow this naming scheme for consistency.
Signed-off-by: Ken Helias <kenhelias@firemail.de>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
There is a race between klist_remove and klist_release. klist_remove
uses a local var waiter saved on stack. When klist_release calls
wake_up_process(waiter->process) to wake up the waiter, waiter might run
immediately and reuse the stack. Then, klist_release calls
list_del(&waiter->list) to change previous
wait data and cause prior waiter thread corrupt.
The patch fixes it against kernel 3.9.
Signed-off-by: wang, biao <biao.wang@intel.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map
them onto including export.h -- or if the file isn't even
using those, then just delete the include. Fix up any implicit
include dependencies that were being masked by module.h along
the way.
Removing the completion from klist_node reduces its size from 64 bytes
to 28 on x86-64. To maintain the semantics of klist_remove(), we add
a single list of klist nodes which are pending deletion and scan them.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
A klist entry is kept on the list till all its current iterations are
finished; however, a new iteration after deletion also iterates over
deleted entries as long as their reference count stays above zero.
This causes problems for cases where there are users which iterate
over the list while synchronized against list manipulations and
natuarally expect already deleted entries to not show up during
iteration.
This patch implements dead flag which gets set on deletion so that
iteration can skip already deleted entries. The dead flag piggy backs
on the lowest bit of knode->n_klist and only visible to klist
implementation proper.
While at it, drop klist_iter->i_head as it's redundant and doesn't
offer anything in semantics or performance wise as klist_iter->i_klist
is dereferenced on every iteration anyway.
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Jens Axboe <jens.axboe@oracle.com>
Finally clean up the odd spacing in these files.
Add klist_add_after() and klist_add_before() which puts a new node
after and before an existing node, respectively. This is useful for
callers which need to keep klist ordered. Note that synchronizing
between simultaneous additions for ordering is the caller's
responsibility.
Signed-off-by: Tejun Heo <htejun@gmail.com>
The klist utility routines currently call _put methods while holding a
spinlock. This is of course illegal; a put routine could try to
unregister a device and hence need to sleep.
No problems have arisen until now because in many cases klist removals
were done synchronously, so the _put methods were never actually used.
In other cases we may simply have been lucky.
This patch (as784) reworks the klist routines so that _put methods are
called only _after_ the klist's spinlock has been released.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
The klist reference counting in the find functions that use
klist_iter_init_node is broken. If the function (for example
driver_find_device) is called with a NULL start object then everything is
fine, the first call to next_device()/klist_next increases the ref-count of
the first node on the list and does nothing for the start object which is
NULL.
If they are called with a valid start object then klist_next will decrement
the ref-count for the start object but nobody has incremented it. Logical
place to fix this would be klist_iter_init_node because the function puts a
reference of the object into the klist_iter struct.
Signed-off-by: Frank Pavlic <pavlic@de.ibm.com>
Cc: Patrick Mochel <mochel@digitalimplant.org>
The problem is that klists claim to provide semantics for safe traversal of
lists which are being modified. The failure case is when traversal of a
list causes element removal (a fairly common case). The issue is that
although the list node is refcounted, if it is embedded in an object (which
is universally the case), then the object will be freed regardless of the
klist refcount leading to slab corruption because the klist iterator refers
to the prior element to get the next.
The solution is to make the klist take and release references to the
embedding object meaning that the embedding object won't be released until
the list relinquishes the reference to it.
(akpm: fast-track this because it's needed for the 2.6.13 scsi merge)
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
at the moment, the list_head semantics are
list_add(node, head)
whereas current klist semantics are
klist_add(head, node)
This is bound to cause confusion, and since klist is the newcomer, it
should follow the list_head semantics.
I also added missing include guards to klist.h
Signed-off-by: Patrick Mochel <mochel@digitalimplant.org>
diff -Nru a/lib/klist.c b/lib/klist.c
diff -Nru a/include/linux/klist.h b/include/linux/klist.h
This klist interface provides a couple of structures that wrap around
struct list_head to provide explicit list "head" (struct klist) and
list "node" (struct klist_node) objects. For struct klist, a spinlock
is included that protects access to the actual list itself. struct
klist_node provides a pointer to the klist that owns it and a kref
reference count that indicates the number of current users of that node
in the list.
The entire point is to provide an interface for iterating over a list
that is safe and allows for modification of the list during the
iteration (e.g. insertion and removal), including modification of the
current node on the list.
It works using a 3rd object type - struct klist_iter - that is declared
and initialized before an iteration. klist_next() is used to acquire the
next element in the list. It returns NULL if there are no more items.
in the list.
Internally, that routine takes the klist's lock, decrements the reference
count of the previous klist_node and increments the count of the next
klist_node. It then drops the lock and returns.
There are primitives for adding and removing nodes to/from a klist.
When deleting, klist_del() will simply decrement the reference count.
Only when the count goes to 0 is the node removed from the list.
klist_remove() will try to delete the node from the list and block
until it is actually removed. This is useful for objects (like devices)
that have been removed from the system and must be freed (but must wait
until all accessors have finished).
