path: root/lib/digsig.c
2013-02-01digsig: Fix memory leakage in digsig_verify_rsa()YOSHIFUJI Hideaki
digsig_verify_rsa() does not free kmalloc'ed buffer returned by mpi_get_buffer(). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Cc: stable@vger.kernel.org Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-09-13digsig: add hash size comparision on signature verificationDmitry Kasatkin
When pkcs_1_v1_5_decode_emsa() returns without error and hash sizes do not match, hash comparision is not done and digsig_verify_rsa() returns no error. This is a bug and this patch fixes it. The bug was introduced in v3.3 by commit b35e286a640f ("lib/digsig: pkcs_1_v1_5_decode_emsa cleanup"). Cc: stable@vger.kernel.org Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-02lib/digsig: checks for NULL return valueDmitry Kasatkin
mpi_read_from_buffer() return value must not be NULL. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Reviewed-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2012-02-02lib/digsig: pkcs_1_v1_5_decode_emsa cleanupDmitry Kasatkin
Removed useless 'is_valid' variable in pkcs_1_v1_5_decode_emsa(), which was inhereted from original code. Client now uses return value to check for an error. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Reviewed-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2012-02-02lib/digsig: additional sanity checks against badly formated key payloadDmitry Kasatkin
Added sanity checks for possible wrongly formatted key payload data: - minimum key payload size - zero modulus length - corrected upper key payload boundary. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Reviewed-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2011-11-09crypto: digital signature verification supportDmitry Kasatkin
This patch implements RSA digital signature verification using GnuPG library. The format of the signature and the public key is defined by their respective headers. The signature header contains version information, algorithm, and keyid, which was used to generate the signature. The key header contains version and algorythim type. The payload of the signature and the key are multi-precision integers. The signing and key management utilities evm-utils provide functionality to generate signatures and load keys into the kernel keyring. When the key is added to the kernel keyring, the keyid defines the name of the key. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Acked-by: Mimi Zohar <zohar@us.ibm.com>
