commit 62635ea8c18f0f62df4cc58379e4f1d33afd5801 upstream.
show_workqueue_state() can print out a lot of messages while being in
atomic context, e.g. sysrq-t -> show_workqueue_state(). If the console
device is slow it may end up triggering NMI hard lockup watchdog.
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
commit 1ebe1eaf2f02784921759992ae1fde1a9bec8fd0 upstream.
Since enums do not get converted by the TRACE_EVENT macro into their values,
the event format displaces the enum name and not the value. This breaks
tools like perf and trace-cmd that need to interpret the raw binary data. To
solve this, an enum map was created to convert these enums into their actual
numbers on boot up. This is done by TRACE_EVENTS() adding a
TRACE_DEFINE_ENUM() macro.
Some enums were not being converted. This was caused by an optization that
had a bug in it.
All calls get checked against this enum map to see if it should be converted
or not, and it compares the call's system to the system that the enum map
was created under. If they match, then they call is processed.
To cut down on the number of iterations needed to find the maps with a
matching system, since calls and maps are grouped by system, when a match is
made, the index into the map array is saved, so that the next call, if it
belongs to the same system as the previous call, could start right at that
array index and not have to scan all the previous arrays.
The problem was, the saved index was used as the variable to know if this is
a call in a new system or not. If the index was zero, it was assumed that
the call is in a new system and would keep incrementing the saved index
until it found a matching system. The issue arises when the first matching
system was at index zero. The next map, if it belonged to the same system,
would then think it was the first match and increment the index to one. If
the next call belong to the same system, it would begin its search of the
maps off by one, and miss the first enum that should be converted. This left
a single enum not converted properly.
Also add a comment to describe exactly what that index was for. It took me a
bit too long to figure out what I was thinking when debugging this issue.
Link: http://lkml.kernel.org/r/717BE572-2070-4C1E-9902-9F2E0FEDA4F8@oracle.com
Fixes: 0c564a538aa93 ("tracing: Add TRACE_DEFINE_ENUM() macro to map enums to their values")
Reported-by: Chuck Lever <chuck.lever@oracle.com>
Teste-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit ae83b56a56f8d9643dedbee86b457fa1c5d42f59 upstream.
When a contrained task is throttled by dl_check_constrained_dl(),
it may carry the remaining positive runtime, as a result when
dl_task_timer() fires and calls replenish_dl_entity(), it will
not be replenished correctly due to the positive dl_se->runtime.
This patch assigns its runtime to 0 if positive after throttling.
Signed-off-by: Xunlei Pang <xlpang@redhat.com>
Acked-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Cc: Juri Lelli <juri.lelli@arm.com>
Cc: Luca Abeni <luca.abeni@santannapisa.it>
Fixes: df8eac8cafce ("sched/deadline: Throttle a constrained deadline task activated after the deadline)
Link: http://lkml.kernel.org/r/1494421417-27550-1-git-send-email-xlpang@redhat.com
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit ed4bbf7910b28ce3c691aef28d245585eaabda06 upstream.
When the timer base is checked for expired timers then the deferrable base
must be checked as well. This was missed when making the deferrable base
independent of base::nohz_active.
Fixes: ced6d5c11d3e ("timers: Use deferrable base independent of base::nohz_active")
Cc: Anna-Maria Gleixner <anna-maria@linutronix.de>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: rt@linutronix.de
commit fbe0e839d1e22d88810f3ee3e2f1479be4c0aa4a upstream.
UBSAN reports signed integer overflow in kernel/futex.c:
UBSAN: Undefined behaviour in kernel/futex.c:2041:18
signed integer overflow:
0 - -2147483648 cannot be represented in type 'int'
Add a sanity check to catch negative values of nr_wake and nr_requeue.
Signed-off-by: Li Jinyue <lijinyue@huawei.com>
Cc: peterz@infradead.org
Cc: dvhart@infradead.org
Link: https://lkml.kernel.org/r/1513242294-31786-1-git-send-email-lijinyue@huawei.com
commit bbeb6e4323dad9b5e0ee9f60c223dd532e2403b1 upstream.
syzkaller tried to alloc a map with 0xfffffffd entries out of a userns,
and thus unprivileged. With the recently added logic in b2157399cc98
("bpf: prevent out-of-bounds speculation") we round this up to the next
power of two value for max_entries for unprivileged such that we can
apply proper masking into potentially zeroed out map slots.
However, this will generate an index_mask of 0xffffffff, and therefore
a + 1 will let this overflow into new max_entries of 0. This will pass
allocation, etc, and later on map access we still enforce on the original
attr->max_entries value which was 0xfffffffd, therefore triggering GPF
all over the place. Thus bail out on overflow in such case.
Moreover, on 32 bit archs roundup_pow_of_two() can also not be used,
since fls_long(max_entries - 1) can result in 32 and 1UL << 32 in 32 bit
space is undefined. Therefore, do this by hand in a 64 bit variable.
This fixes all the issues triggered by syzkaller's reproducers.
Fixes: b2157399cc98 ("bpf: prevent out-of-bounds speculation")
Reported-by: syzbot+b0efb8e572d01bce1ae0@syzkaller.appspotmail.com
Reported-by: syzbot+6c15e9744f75f2364773@syzkaller.appspotmail.com
Reported-by: syzbot+d2f5524fb46fd3b312ee@syzkaller.appspotmail.com
Reported-by: syzbot+61d23c95395cc90dbc2b@syzkaller.appspotmail.com
Reported-by: syzbot+0d363c942452cca68c01@syzkaller.appspotmail.com
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
commit b2157399cc9898260d6031c5bfe45fe137c1fbe7 upstream.
Under speculation, CPUs may mis-predict branches in bounds checks. Thus,
memory accesses under a bounds check may be speculated even if the
bounds check fails, providing a primitive for building a side channel.
To avoid leaking kernel data round up array-based maps and mask the index
after bounds check, so speculated load with out of bounds index will load
either valid value from the array or zero from the padded area.
Unconditionally mask index for all array types even when max_entries
are not rounded to power of 2 for root user.
When map is created by unpriv user generate a sequence of bpf insns
that includes AND operation to make sure that JITed code includes
the same 'index & index_mask' operation.
If prog_array map is created by unpriv user replace
bpf_tail_call(ctx, map, index);
with
if (index >= max_entries) {
index &= map->index_mask;
(along with roundup to power 2) to prevent out-of-bounds speculation.
There is secondary redundant 'if (index >= max_entries)' in the interpreter
and in all JITs, but they can be optimized later if necessary.
Other array-like maps (cpumap, devmap, sockmap, perf_event_array, cgroup_array)
cannot be used by unpriv, so no changes there.
That fixes bpf side of "Variant 1: bounds check bypass (CVE-2017-5753)" on
all architectures with and without JIT.
v2->v3:
Daniel noticed that attack potentially can be crafted via syscall commands
without loading the program, so add masking to those paths as well.
Acked-by: John Fastabend <john.fastabend@gmail.com>
Cc: Jiri Slaby <jslaby@suse.cz>
[ Backported to 4.9 - gregkh ]
commit 79741b3bdec01a8628368fbcfccc7d189ed606cb upstream.
reduce indent and make it iterate over instructions similar to
convert_ctx_accesses(). Also convert hard BUG_ON into soft verifier error.
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
[Backported to 4.9.y - gregkh]
commit e245c5c6a5656e4d61aa7bb08e9694fd6e5b2b9d upstream.
no functional change.
move fixup_bpf_calls() to verifier.c
it's being refactored in the next patch
[backported to 4.9 - gregkh]
complete_signal()
commit 426915796ccaf9c2bd9bb06dc5702225957bc2e5 upstream.
complete_signal() checks SIGNAL_UNKILLABLE before it starts to destroy
the thread group, today this is wrong in many ways.
If nothing else, fatal_signal_pending() should always imply that the
whole thread group (except ->group_exit_task if it is not NULL) is
killed, this check breaks the rule.
After the previous changes we can rely on sig_task_ignored();
sig_fatal(sig) && SIGNAL_UNKILLABLE can only be true if we actually want
to kill this task and sig == SIGKILL OR it is traced and debugger can
intercept the signal.
This should hopefully fix the problem reported by Dmitry. This
test-case
static int init(void *arg)
for (;;)
pause();
int main(void)
char stack[16 * 1024];
for (;;) {
int pid = clone(init, stack + sizeof(stack)/2,
CLONE_NEWPID | SIGCHLD, NULL);
assert(pid > 0);
assert(ptrace(PTRACE_ATTACH, pid, 0, 0) == 0);
assert(waitpid(-1, NULL, WSTOPPED) == pid);
assert(ptrace(PTRACE_DETACH, pid, 0, SIGSTOP) == 0);
assert(syscall(__NR_tkill, pid, SIGKILL) == 0);
assert(pid == wait(NULL));
triggers the WARN_ON_ONCE(!(task->jobctl & JOBCTL_STOP_PENDING)) in
task_participate_group_stop(). do_signal_stop()->signal_group_exit()
checks SIGNAL_GROUP_EXIT and return false, but task_set_jobctl_pending()
checks fatal_signal_pending() and does not set JOBCTL_STOP_PENDING.
And his should fix the minor security problem reported by Kyle,
SECCOMP_RET_TRACE can miss fatal_signal_pending() the same way if the
task is the root of a pid namespace.
Link: http://lkml.kernel.org/r/20171103184246.GD21036@redhat.com
Reported-by: Kyle Huey <me@kylehuey.com>
Tested-by: Kyle Huey <me@kylehuey.com>
signals
commit ac25385089f673560867eb5179228a44ade0cfc1 upstream.
Change sig_task_ignored() to drop the SIG_DFL && !sig_kernel_only()
signals even if force == T. This simplifies the next change and this
matches the same check in get_signal() which will drop these signals
anyway.
Link: http://lkml.kernel.org/r/20171103184227.GC21036@redhat.com
commit 628c1bcba204052d19b686b5bac149a644cdb72e upstream.
The comment in sig_ignored() says "Tracers may want to know about even
ignored signals" but SIGKILL can not be reported to debugger and it is
just wrong to return 0 in this case: SIGKILL should only kill the
SIGNAL_UNKILLABLE task if it comes from the parent ns.
Change sig_ignored() to ignore ->ptrace if sig == SIGKILL and rely on
sig_task_ignored().
SISGTOP coming from within the namespace is not really right too but at
least debugger can intercept it, and we can't drop it here because this
will break "gdb -p 1": ptrace_attach() won't work. Perhaps we will add
another ->ptrace check later, we will see.
Link: http://lkml.kernel.org/r/20171103184206.GB21036@redhat.com
commit bdcf0a423ea1c40bbb40e7ee483b50fc8aa3d758 upstream.
In testing, we found that nfsd threads may call set_groups in parallel
for the same entry cached in auth.unix.gid, racing in the call of
groups_sort, corrupting the groups for that entry and leading to
permission denials for the client.
This patch:
- Make groups_sort globally visible.
- Move the call to groups_sort to the modifiers of group_info
- Remove the call to groups_sort from set_groups
Link: http://lkml.kernel.org/r/20171211151420.18655-1-thiago.becker@gmail.com
Signed-off-by: Thiago Rafael Becker <thiago.becker@gmail.com>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
Reviewed-by: NeilBrown <neilb@suse.com>
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
commit 4d9570158b6260f449e317a5f9ed030c2504a615 upstream.
As Tsukada explains, the time_is_before_jiffies(acct->needcheck) check
is very wrong, we need time_is_after_jiffies() to make sys_acct() work.
Ignoring the overflows, the code should "goto out" if needcheck >
jiffies, while currently it checks "needcheck < jiffies" and thus in the
likely case check_free_space() does nothing until jiffies overflow.
In particular this means that sys_acct() is simply broken, acct_on()
sets acct->needcheck = jiffies and expects that check_free_space()
should set acct->active = 1 after the free-space check, but this won't
happen if jiffies increments in between.
This was broken by commit 32dc73086015 ("get rid of timer in
kern/acct.c") in 2011, then another (correct) commit 795a2f22a8ea
("acct() should honour the limits from the very beginning") made the
problem more visible.
Link: http://lkml.kernel.org/r/20171213133940.GA6554@redhat.com
Fixes: 32dc73086015 ("get rid of timer in kern/acct.c")
Reported-by: TSUKADA Koutaro <tsukada@ascade.co.jp>
Suggested-by: TSUKADA Koutaro <tsukada@ascade.co.jp>
Kaiser only needs to map one page of the stack; and
kernel/fork.c did not build on powerpc (no __PAGE_KERNEL).
It's all cleaner if linux/kaiser.h provides kaiser_map_thread_stack()
and kaiser_unmap_thread_stack() wrappers around asm/kaiser.h's
kaiser_add_mapping() and kaiser_remove_mapping(). And use
linux/kaiser.h in init/main.c to avoid the #ifdefs there.
Merged fixes and cleanups, rebased to 4.9.51 tree (no 5-level paging).
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
This patch introduces our implementation of KAISER (Kernel Address Isolation to
have Side-channels Efficiently Removed), a kernel isolation technique to close
hardware side channels on kernel address information.
More information about the patch can be found on:
https://github.com/IAIK/KAISER
From: Richard Fellner <richard.fellner@student.tugraz.at>
Subject: [RFC, PATCH] x86_64: KAISER - do not map kernel in user mode
Date: Thu, 4 May 2017 14:26:50 +0200
Link: http://marc.info/?l=linux-kernel&m=149390087310405&w=2
Kaiser-4.10-SHA1: c4b1831d44c6144d3762ccc72f0c4e71a0c713e5
To: <linux-kernel@vger.kernel.org>
To: <kernel-hardening@lists.openwall.com>
Cc: <clementine.maurice@iaik.tugraz.at>
Cc: <moritz.lipp@iaik.tugraz.at>
Cc: Michael Schwarz <michael.schwarz@iaik.tugraz.at>
Cc: Richard Fellner <richard.fellner@student.tugraz.at>
Cc: <kirill.shutemov@linux.intel.com>
Cc: <anders.fogh@gdata-adan.de>
After several recent works [1,2,3] KASLR on x86_64 was basically
considered dead by many researchers. We have been working on an
efficient but effective fix for this problem and found that not mapping
the kernel space when running in user mode is the solution to this
problem [4] (the corresponding paper [5] will be presented at ESSoS17).
With this RFC patch we allow anybody to configure their kernel with the
flag CONFIG_KAISER to add our defense mechanism.
If there are any questions we would love to answer them.
We also appreciate any comments!
Cheers,
Daniel (+ the KAISER team from Graz University of Technology)
[1] http://www.ieee-security.org/TC/SP2013/papers/4977a191.pdf
[2] https://www.blackhat.com/docs/us-16/materials/us-16-Fogh-Using-Undocumented-CPU-Behaviour-To-See-Into-Kernel-Mode-And-Break-KASLR-In-The-Process.pdf
[3] https://www.blackhat.com/docs/us-16/materials/us-16-Jang-Breaking-Kernel-Address-Space-Layout-Randomization-KASLR-With-Intel-TSX.pdf
[4] https://github.com/IAIK/KAISER
[5] https://gruss.cc/files/kaiser.pdf
[patch based also on
https://raw.githubusercontent.com/IAIK/KAISER/master/KAISER/0001-KAISER-Kernel-Address-Isolation.patch]
Signed-off-by: Richard Fellner <richard.fellner@student.tugraz.at>
Signed-off-by: Moritz Lipp <moritz.lipp@iaik.tugraz.at>
Signed-off-by: Daniel Gruss <daniel.gruss@iaik.tugraz.at>
Signed-off-by: Michael Schwarz <michael.schwarz@iaik.tugraz.at>
Acked-by: Jiri Kosina <jkosina@suse.cz>
commit 5d62c183f9e9df1deeea0906d099a94e8a43047a upstream.
The conditions in irq_exit() to invoke tick_nohz_irq_exit() which
subsequently invokes tick_nohz_stop_sched_tick() are:
if ((idle_cpu(cpu) && !need_resched()) || tick_nohz_full_cpu(cpu))
If need_resched() is not set, but a timer softirq is pending then this is
an indication that the softirq code punted and delegated the execution to
softirqd. need_resched() is not true because the current interrupted task
takes precedence over softirqd.
Invoking tick_nohz_irq_exit() in this case can cause an endless loop of
timer interrupts because the timer wheel contains an expired timer, but
softirqs are not yet executed. So it returns an immediate expiry request,
which causes the timer to fire immediately again. Lather, rinse and
repeat....
Prevent that by adding a check for a pending timer soft interrupt to the
conditions in tick_nohz_stop_sched_tick() which avoid calling
get_next_timer_interrupt(). That keeps the tick sched timer on the tick and
prevents a repetitive programming of an already expired timer.
Reported-by: Sebastian Siewior <bigeasy@linutronix.d>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1712272156050.2431@nanos
commit 26456f87aca7157c057de65c9414b37f1ab881d1 upstream.
The timer wheel bases are not (re)initialized on CPU hotplug. That leaves
them with a potentially stale clk and next_expiry valuem, which can cause
trouble then the CPU is plugged.
Add a prepare callback which forwards the clock, sets next_expiry to far in
the future and reset the control flags to a known state.
Set base->must_forward_clk so the first timer which is queued will try to
forward the clock to current jiffies.
Fixes: 500462a9de65 ("timers: Switch to a non-cascading wheel")
Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1712272152200.2431@nanos
commit fd45bb77ad682be728d1002431d77b8c73342836 upstream.
The timer start debug function is called before the proper timer base is
set. As a consequence the trace data contains the stale CPU and flags
values.
Call the debug function after setting the new base and flags.
Link: https://lkml.kernel.org/r/20171222145337.792907137@linutronix.de
commit ced6d5c11d3e7b342f1a80f908e6756ebd4b8ddd upstream.
During boot and before base::nohz_active is set in the timer bases, deferrable
timers are enqueued into the standard timer base. This works correctly as
long as base::nohz_active is false.
Once it base::nohz_active is set and a timer which was enqueued before that
is accessed the lock selector code choses the lock of the deferred
base. This causes unlocked access to the standard base and in case the
timer is removed it does not clear the pending flag in the standard base
bitmap which causes get_next_timer_interrupt() to return bogus values.
To prevent that, the deferrable timers must be enqueued in the deferrable
base, even when base::nohz_active is not set. Those deferrable timers also
need to be expired unconditional.
Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de>
Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com>
Link: https://lkml.kernel.org/r/20171222145337.633328378@linutronix.de
commit 45d8b80c2ac5d21cd1e2954431fb676bc2b1e099 upstream.
Two info bits were added to the "commit" part of the ring buffer data page
when returned to be consumed. This was to inform the user space readers that
events have been missed, and that the count may be stored at the end of the
page.
What wasn't handled, was the splice code that actually called a function to
return the length of the data in order to zero out the rest of the page
before sending it up to user space. These data bits were returned with the
length making the value negative, and that negative value was not checked.
It was compared to PAGE_SIZE, and only used if the size was less than
PAGE_SIZE. Luckily PAGE_SIZE is unsigned long which made the compare an
unsigned compare, meaning the negative size value did not end up causing a
large portion of memory to be randomly zeroed out.
Fixes: 66a8cb95ed040 ("ring-buffer: Add place holder recording of dropped events")
commit 24f2aaf952ee0b59f31c3a18b8b36c9e3d3c2cf5 upstream.
Double free of the ring buffer happens when it fails to alloc new
ring buffer instance for max_buffer if TRACER_MAX_TRACE is configured.
The root cause is that the pointer is not set to NULL after the buffer
is freed in allocate_trace_buffers(), and the freeing of the ring
buffer is invoked again later if the pointer is not equal to Null,
as:
instance_mkdir()
|-allocate_trace_buffers()
|-allocate_trace_buffer(tr, &tr->trace_buffer...)
|-allocate_trace_buffer(tr, &tr->max_buffer...)
// allocate fail(-ENOMEM),first free
// and the buffer pointer is not set to null
|-ring_buffer_free(tr->trace_buffer.buffer)
// out_free_tr
|-free_trace_buffers()
|-free_trace_buffer(&tr->trace_buffer);
//if trace_buffer is not null, free again
|-ring_buffer_free(buf->buffer)
|-rb_free_cpu_buffer(buffer->buffers[cpu])
// ring_buffer_per_cpu is null, and
// crash in ring_buffer_per_cpu->pages
Link: http://lkml.kernel.org/r/20171226071253.8968-1-chunyan.zhang@spreadtrum.com
Fixes: 737223fbca3b1 ("tracing: Consolidate buffer allocation code")
Signed-off-by: Jing Xia <jing.xia@spreadtrum.com>
Signed-off-by: Chunyan Zhang <chunyan.zhang@spreadtrum.com>
commit 4397f04575c44e1440ec2e49b6302785c95fd2f8 upstream.
Jing Xia and Chunyan Zhang reported that on failing to allocate part of the
tracing buffer, memory is freed, but the pointers that point to them are not
initialized back to NULL, and later paths may try to free the freed memory
again. Jing and Chunyan fixed one of the locations that does this, but
missed a spot.
Reported-by: Jing Xia <jing.xia@spreadtrum.com>
Reported-by: Chunyan Zhang <chunyan.zhang@spreadtrum.com>
commit 6b7e633fe9c24682df550e5311f47fb524701586 upstream.
The ring_buffer_read_page() takes care of zeroing out any extra data in the
page that it returns. There's no need to zero it out again from the
consumer. It was removed from one consumer of this function, but
read_buffers_splice_read() did not remove it, and worse, it contained a
nasty bug because of it.
Fixes: 2711ca237a084 ("ring-buffer: Move zeroing out excess in page to ring buffer code")
An UNKNOWN_VALUE is not supposed to be derived from a pointer, unless
pointer leaks are allowed. Therefore, states_equal() must not treat
a state with a pointer in a register as "equal" to a state with an
UNKNOWN_VALUE in that register.
This was fixed differently upstream, but the code around here was
largely rewritten in 4.14 by commit f1174f77b50c "bpf/verifier: rework
value tracking". The bug can be detected by the bpf/verifier sub-test
"pointer/scalar confusion in state equality check (way 1)".
Cc: Edward Cree <ecree@solarflare.com>
Cc: Jann Horn <jannh@google.com>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 95a762e2c8c942780948091f8f2a4f32fce1ac6f ]
Distinguish between
BPF_ALU64|BPF_MOV|BPF_K (load 32-bit immediate, sign-extended to 64-bit)
and BPF_ALU|BPF_MOV|BPF_K (load 32-bit immediate, zero-padded to 64-bit);
only perform sign extension in the first case.
Starting with v4.14, this is exploitable by unprivileged users as long as
the unprivileged_bpf_disabled sysctl isn't set.
Debian assigned CVE-2017-16995 for this issue.
v3:
- add CVE number (Ben Hutchings)
Fixes: 484611357c19 ("bpf: allow access into map value arrays")
Signed-off-by: Jann Horn <jannh@google.com>
Acked-by: Edward Cree <ecree@solarflare.com>
Reject programs that compute wildly out-of-bounds stack pointers.
Otherwise, pointers can be computed with an offset that doesn't fit into an
`int`, causing security issues in the stack memory access check (as well as
signed integer overflow during offset addition).
This is a fix specifically for the v4.9 stable tree because the mainline
code looks very different at this point.
Fixes: 7bca0a9702edf ("bpf: enhance verifier to understand stack pointer arithmetic")
[ Upstream commit c131187db2d3fa2f8bf32fdf4e9a4ef805168467 ]
when the verifier detects that register contains a runtime constant
and it's compared with another constant it will prune exploration
of the branch that is guaranteed not to be taken at runtime.
This is all correct, but malicious program may be constructed
in such a way that it always has a constant comparison and
the other branch is never taken under any conditions.
In this case such path through the program will not be explored
by the verifier. It won't be taken at run-time either, but since
all instructions are JITed the malicious program may cause JITs
to complain about using reserved fields, etc.
To fix the issue we have to track the instructions explored by
the verifier and sanitize instructions that are dead at run time
with NOPs. We cannot reject such dead code, since llvm generates
it for valid C code, since it doesn't do as much data flow
analysis as the verifier does.
Fixes: 17a5267067f3 ("bpf: verifier (add verifier core)")
[ Upstream commit 8041902dae5299c1f194ba42d14383f734631009 ]
convert_ctx_accesses() replaces single bpf instruction with a set of
instructions. Adjust corresponding insn_aux_data while patching.
It's needed to make sure subsequent 'for(all insn)' loops
have matching insn and insn_aux_data.
[ Upstream commit a15f7fc20389a8827d5859907568b201234d4b79 ]
There are a small number of 'generic fields' (comm/COMM/cpu/CPU) that
are found by trace_find_event_field() but are only meant for
filtering. Specifically, they unlike normal fields, they have a size
of 0 and thus wreak havoc when used as a histogram key.
Exclude these (return -EINVAL) when used as histogram keys.
Link: http://lkml.kernel.org/r/956154cbc3e8a4f0633d619b886c97f0f0edf7b4.1506105045.git.tom.zanussi@linux.intel.com
Signed-off-by: Tom Zanussi <tom.zanussi@linux.intel.com>
[ Upstream commit 2317d5f1c34913bac5971d93d69fb6c31bb74670 ]
I was testing Daniel's changes with his test case, and tweaked it a
little. Instead of having the runtime equal to the deadline, I
increased the deadline ten fold.
Daniel's test case had:
attr.sched_runtime = 2 * 1000 * 1000; /* 2 ms */
attr.sched_deadline = 2 * 1000 * 1000; /* 2 ms */
attr.sched_period = 2 * 1000 * 1000 * 1000; /* 2 s */
To make it more interesting, I changed it to:
attr.sched_deadline = 20 * 1000 * 1000; /* 20 ms */
The results were rather surprising. The behavior that Daniel's patch
was fixing came back. The task started using much more than .1% of the
CPU. More like 20%.
Looking into this I found that it was due to the dl_entity_overflow()
constantly returning true. That's because it uses the relative period
against relative runtime vs the absolute deadline against absolute
runtime.
runtime / (deadline - t) > dl_runtime / dl_period
There's even a comment mentioning this, and saying that when relative
deadline equals relative period, that the equation is the same as using
deadline instead of period. That comment is backwards! What we really
want is:
runtime / (deadline - t) > dl_runtime / dl_deadline
We care about if the runtime can make its deadline, not its period. And
then we can say "when the deadline equals the period, the equation is
the same as using dl_period instead of dl_deadline".
After correcting this, now when the task gets enqueued, it can throttle
correctly, and Daniel's fix to the throttling of sleeping deadline
tasks works even when the runtime and deadline are not the same.
Reviewed-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Cc: Romulo Silva de Oliveira <romulo.deoliveira@ufsc.br>
Cc: Tommaso Cucinotta <tommaso.cucinotta@sssup.it>
Link: http://lkml.kernel.org/r/02135a27f1ae3fe5fd032568a5a2f370e190e8d7.1488392936.git.bristot@redhat.com
deadline
[ Upstream commit df8eac8cafce7d086be3bd5cf5a838fa37594dfb ]
During the activation, CBS checks if it can reuse the current task's
runtime and period. If the deadline of the task is in the past, CBS
cannot use the runtime, and so it replenishes the task. This rule
works fine for implicit deadline tasks (deadline == period), and the
CBS was designed for implicit deadline tasks. However, a task with
constrained deadline (deadine < period) might be awakened after the
deadline, but before the next period. In this case, replenishing the
task would allow it to run for runtime / deadline. As in this case
deadline < period, CBS enables a task to run for more than the
runtime / period. In a very loaded system, this can cause a domino
effect, making other tasks miss their deadlines.
To avoid this problem, in the activation of a constrained deadline
task after the deadline but before the next period, throttle the
task and set the replenishing timer to the begin of the next period,
unless it is boosted.
Reproducer:
int main (int argc, char **argv)
int ret;
int flags = 0;
unsigned long l = 0;
struct timespec ts;
struct sched_attr attr;
memset(&attr, 0, sizeof(attr));
attr.size = sizeof(attr);
attr.sched_policy = SCHED_DEADLINE;
ts.tv_sec = 0;
ts.tv_nsec = 2000 * 1000; /* 2 ms */
ret = sched_setattr(0, &attr, flags);
if (ret < 0) {
perror("sched_setattr");
exit(-1);
for(;;) {
/* XXX: you may need to adjust the loop */
for (l = 0; l < 150000; l++);
* The ideia is to go to sleep right before the deadline
* and then wake up before the next period to receive
* a new replenishment.
nanosleep(&ts, NULL);
exit(0);
On my box, this reproducer uses almost 50% of the CPU time, which is
obviously wrong for a task with 2/2000 reservation.
Signed-off-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Link: http://lkml.kernel.org/r/edf58354e01db46bf42df8d2dd32418833f68c89.1488392936.git.bristot@redhat.com
[ Upstream commit 5ac69d37784b237707a7b15d199cdb6c6fdb6780 ]
Currently, the replenishment timer is set to fire at the deadline
of a task. Although that works for implicit deadline tasks because the
deadline is equals to the begin of the next period, that is not correct
for constrained deadline tasks (deadline < period).
For instance:
f.c:
int main (void)
for(;;);
# gcc -o f f.c
# trace-cmd record -e sched:sched_switch \
-e syscalls:sys_exit_sched_setattr \
chrt -d --sched-runtime 490000000 \
--sched-deadline 500000000 \
--sched-period 1000000000 0 ./f
# trace-cmd report | grep "{pid of ./f}"
After setting parameters, the task is replenished and continue running
until being throttled:
f-11295 [003] 13322.113776: sys_exit_sched_setattr: 0x0
The task is throttled after running 492318 ms, as expected:
f-11295 [003] 13322.606094: sched_switch: f:11295 [-1] R ==> watchdog/3:32 [0]
But then, the task is replenished 500719 ms after the first
replenishment:
<idle>-0 [003] 13322.614495: sched_switch: swapper/3:0 [120] R ==> f:11295 [-1]
Running for 490277 ms:
f-11295 [003] 13323.104772: sched_switch: f:11295 [-1] R ==> swapper/3:0 [120]
Hence, in the first period, the task runs 2 * runtime, and that is a bug.
During the first replenishment, the next deadline is set one period away.
So the runtime / period starts to be respected. However, as the second
replenishment took place in the wrong instant, the next replenishment
will also be held in a wrong instant of time. Rather than occurring in
the nth period away from the first activation, it is taking place
in the (nth period - relative deadline).
Reviewed-by: Luca Abeni <luca.abeni@santannapisa.it>
Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Reviewed-by: Juri Lelli <juri.lelli@arm.com>
Link: http://lkml.kernel.org/r/ac50d89887c25285b47465638354b63362f8adff.1488392936.git.bristot@redhat.com
[ Upstream commit dcc3b5ffe1b32771c9a22e2c916fb94c4fcf5b79 ]
The following warning can be triggered by hot-unplugging the CPU
on which an active SCHED_DEADLINE task is running on:
WARNING: CPU: 7 PID: 0 at kernel/sched/sched.h:833 replenish_dl_entity+0x71e/0xc40
rq->clock_update_flags < RQCF_ACT_SKIP
CPU: 7 PID: 0 Comm: swapper/7 Tainted: G B 4.11.0-rc1+ #24
Hardware name: LENOVO ThinkCentre M8500t-N000/SHARKBAY, BIOS FBKTC1AUS 02/16/2016
Call Trace:
<IRQ>
dump_stack+0x85/0xc4
__warn+0x172/0x1b0
warn_slowpath_fmt+0xb4/0xf0
? __warn+0x1b0/0x1b0
? debug_check_no_locks_freed+0x2c0/0x2c0
? cpudl_set+0x3d/0x2b0
enqueue_task_dl+0x2ea/0x12e0
? dl_task_timer+0x777/0x990
? __hrtimer_run_queues+0x270/0xa50
dl_task_timer+0x316/0x990
? enqueue_task_dl+0x12e0/0x12e0
? hrtimer_cancel+0x20/0x20
? hrtimer_interrupt+0x119/0x600
hrtimer_interrupt+0x19c/0x600
? trace_hardirqs_off+0xd/0x10
local_apic_timer_interrupt+0x74/0xe0
smp_apic_timer_interrupt+0x76/0xa0
apic_timer_interrupt+0x93/0xa0
The DL task will be migrated to a suitable later deadline rq once the DL
timer fires and currnet rq is offline. The rq clock of the new rq should
be updated. This patch fixes it by updating the rq clock after holding
the new rq's rq lock.
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk>
Link: http://lkml.kernel.org/r/1488865888-15894-1-git-send-email-wanpeng.li@hotmail.com
commit f73c52a5bcd1710994e53fbccc378c42b97a06b6 upstream.
Daniel Wagner reported a crash on the BeagleBone Black SoC.
This is a single CPU architecture, and does not have a functional
arch_send_call_function_single_ipi() implementation which can crash
the kernel if that is called.
As it only has one CPU, it shouldn't be called, but if the kernel is
compiled for SMP, the push/pull RT scheduling logic now calls it for
irq_work if the one CPU is overloaded, it can use that function to call
itself and crash the kernel.
Ideally, we should disable the SCHED_FEAT(RT_PUSH_IPI) if the system
only has a single CPU. But SCHED_FEAT is a constant if sched debugging
is turned off. Another fix can also be used, and this should also help
with normal SMP machines. That is, do not initiate the pull code if
there's only one RT overloaded CPU, and that CPU happens to be the
current CPU that is scheduling in a lower priority task.
Even on a system with many CPUs, if there's many RT tasks waiting to
run on a single CPU, and that CPU schedules in another RT task of lower
priority, it will initiate the PULL logic in case there's a higher
priority RT task on another CPU that is waiting to run. But if there is
no other CPU with waiting RT tasks, it will initiate the RT pull logic
on itself (as it still has RT tasks waiting to run). This is a wasted
effort.
Not only does this help with SMP code where the current CPU is the only
one with RT overloaded tasks, it should also solve the issue that
Daniel encountered, because it will prevent the PULL logic from
executing, as there's only one CPU on the system, and the check added
here will cause it to exit the RT pull code.
Reported-by: Daniel Wagner <wagi@monom.org>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: linux-rt-users <linux-rt-users@vger.kernel.org>
Fixes: 4bdced5c9 ("sched/rt: Simplify the IPI based RT balancing logic")
Link: http://lkml.kernel.org/r/20171202130454.4cbbfe8d@vmware.local.home
commit 90e406f96f630c07d631a021fd4af10aac913e77 upstream.
The default NR_CPUS can be very large, but actual possible nr_cpu_ids
usually is very small. For my x86 distribution, the NR_CPUS is 8192 and
nr_cpu_ids is 4. About 2 pages are wasted.
Most machines don't have so many CPUs, so define a array with NR_CPUS
just wastes memory. So let's allocate the buffer dynamically when need.
With this change, the mutext tracing_cpumask_update_lock also can be
removed now, which was used to protect mask_str.
Link: http://lkml.kernel.org/r/1512013183-19107-1-git-send-email-changbin.du@intel.com
Fixes: 36dfe9252bd4c ("ftrace: make use of tracing_cpumask")
Signed-off-by: Changbin Du <changbin.du@intel.com>
[ Upstream commit 173743dd99a49c956b124a74c8aacb0384739a4c ]
Prior to this patch we enabled audit in audit_init(), which is too
late for PID 1 as the standard initcalls are run after the PID 1 task
is forked. This means that we never allocate an audit_context (see
audit_alloc()) for PID 1 and therefore miss a lot of audit events
generated by PID 1.
This patch enables audit as early as possible to help ensure that when
PID 1 is forked it can allocate an audit_context if required.
Reviewed-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 92ee46efeb505ead3ab06d3c5ce695637ed5f152 ]
Fengguang Wu reported that running the rcuperf test during boot can cause
the jump_label_test() to hit a WARN_ON(). The issue is that the core jump
label code relies on kernel_text_address() to detect when it can no longer
update branches that may be contained in __init sections. The
kernel_text_address() in turn assumes that if the system_state variable is
greter than or equal to SYSTEM_RUNNING then __init sections are no longer
valid (since the assumption is that they have been freed). However, when
rcuperf is setup to run in early boot it can call kernel_power_off() which
sets the system_state to SYSTEM_POWER_OFF.
Since rcuperf initialization is invoked via a module_init(), we can make
the dependency of jump_label_test() needing to complete before rcuperf
explicit by calling it via early_initcall().
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Jason Baron <jbaron@akamai.com>
Link: http://lkml.kernel.org/r/1510609727-2238-1-git-send-email-jbaron@akamai.com
[ Upstream commit 89ad2fa3f043a1e8daae193bcb5fe34d5f8caf28 ]
pcpu_freelist_pop() needs the same lockdep awareness than
pcpu_freelist_populate() to avoid a false positive.
[ INFO: SOFTIRQ-safe -> SOFTIRQ-unsafe lock order detected ]
switchto-defaul/12508 [HC0[0]:SC0[6]:HE0:SE0] is trying to acquire:
(&htab->buckets[i].lock){......}, at: [<ffffffff9dc099cb>] __htab_percpu_map_update_elem+0x1cb/0x300
and this task is already holding:
(dev_queue->dev->qdisc_class ?: &qdisc_tx_lock#2){+.-...}, at: [<ffffffff9e135848>] __dev_queue_xmit+0
x868/0x1240
which would create a new lock dependency:
(dev_queue->dev->qdisc_class ?: &qdisc_tx_lock#2){+.-...} -> (&htab->buckets[i].lock){......}
but this new dependency connects a SOFTIRQ-irq-safe lock:
... which became SOFTIRQ-irq-safe at:
[<ffffffff9db5931b>] __lock_acquire+0x42b/0x1f10
[<ffffffff9db5b32c>] lock_acquire+0xbc/0x1b0
[<ffffffff9da05e38>] _raw_spin_lock+0x38/0x50
[<ffffffff9e135848>] __dev_queue_xmit+0x868/0x1240
[<ffffffff9e136240>] dev_queue_xmit+0x10/0x20
[<ffffffff9e1965d9>] ip_finish_output2+0x439/0x590
[<ffffffff9e197410>] ip_finish_output+0x150/0x2f0
[<ffffffff9e19886d>] ip_output+0x7d/0x260
[<ffffffff9e19789e>] ip_local_out+0x5e/0xe0
[<ffffffff9e197b25>] ip_queue_xmit+0x205/0x620
[<ffffffff9e1b8398>] tcp_transmit_skb+0x5a8/0xcb0
[<ffffffff9e1ba152>] tcp_write_xmit+0x242/0x1070
[<ffffffff9e1baffc>] __tcp_push_pending_frames+0x3c/0xf0
[<ffffffff9e1b3472>] tcp_rcv_established+0x312/0x700
[<ffffffff9e1c1acc>] tcp_v4_do_rcv+0x11c/0x200
[<ffffffff9e1c3dc2>] tcp_v4_rcv+0xaa2/0xc30
[<ffffffff9e191107>] ip_local_deliver_finish+0xa7/0x240
[<ffffffff9e191a36>] ip_local_deliver+0x66/0x200
[<ffffffff9e19137d>] ip_rcv_finish+0xdd/0x560
[<ffffffff9e191e65>] ip_rcv+0x295/0x510
[<ffffffff9e12ff88>] __netif_receive_skb_core+0x988/0x1020
[<ffffffff9e130641>] __netif_receive_skb+0x21/0x70
[<ffffffff9e1306ff>] process_backlog+0x6f/0x230
[<ffffffff9e132129>] net_rx_action+0x229/0x420
[<ffffffff9da07ee8>] __do_softirq+0xd8/0x43d
[<ffffffff9e282bcc>] do_softirq_own_stack+0x1c/0x30
[<ffffffff9dafc2f5>] do_softirq+0x55/0x60
[<ffffffff9dafc3a8>] __local_bh_enable_ip+0xa8/0xb0
[<ffffffff9db4c727>] cpu_startup_entry+0x1c7/0x500
[<ffffffff9daab333>] start_secondary+0x113/0x140
to a SOFTIRQ-irq-unsafe lock:
(&head->lock){+.+...}
... which became SOFTIRQ-irq-unsafe at:
... [<ffffffff9db5971f>] __lock_acquire+0x82f/0x1f10
[<ffffffff9dc0b7fa>] pcpu_freelist_pop+0x7a/0xb0
[<ffffffff9dc08b2c>] htab_map_alloc+0x50c/0x5f0
[<ffffffff9dc00dc5>] SyS_bpf+0x265/0x1200
[<ffffffff9e28195f>] entry_SYSCALL_64_fastpath+0x12/0x17
Chain exists of:
dev_queue->dev->qdisc_class ?: &qdisc_tx_lock#2 --> &htab->buckets[i].lock --> &head->lock
Possible interrupt unsafe locking scenario:
CPU0 CPU1
lock(&head->lock);
local_irq_disable();
lock(dev_queue->dev->qdisc_class ?: &qdisc_tx_lock#2);
lock(&htab->buckets[i].lock);
<Interrupt>
*** DEADLOCK ***
Fixes: e19494edab82 ("bpf: introduce percpu_freelist")
[ Upstream commit 637fdbae60d6cb9f6e963c1079d7e0445c86ff7d ]
If queue_delayed_work() gets called with NULL @wq, the kernel will
oops asynchronuosly on timer expiration which isn't too helpful in
tracking down the offender. This actually happened with smc.
__queue_delayed_work() already does several input sanity checks
synchronously. Add NULL @wq check.
Reported-by: Dave Jones <davej@codemonkey.org.uk>
Link: http://lkml.kernel.org/r/20170227171439.jshx3qplflyrgcv7@codemonkey.org.uk
[ Upstream commit 4c77b18cf8b7ab37c7d5737b4609010d2ceec5f0 ]
Kitsunyan reported desktop latency issues on his Celeron 887 because
of commit:
1b568f0aabf2 ("sched/core: Optimize SCHED_SMT")
... even though his CPU doesn't do SMT.
The effect of running the SMT code on a !SMT part is basically a more
aggressive select_idle_cpu(). Removing the avg condition fixed things
for him.
I also know FB likes this test gone, even though other workloads like
having it.
For now, take it out by default, until we get a better idea.
Reported-by: kitsunyan <kitsunyan@inbox.ru>
Cc: Chris Mason <clm@fb.com>
Cc: Mike Galbraith <umgwanakikbuti@gmail.com>
commit c07d35338081d107e57cf37572d8cc931a8e32e2 upstream.
kallsyms_symbol_next() returns a boolean (true on success). Currently
kdb_read() tests the return value with an inequality that
unconditionally evaluates to true.
This is fixed in the obvious way and, since the conditional branch is
supposed to be unreachable, we also add a WARN_ON().
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
commit 46febd37f9c758b05cd25feae8512f22584742fe upstream.
Commit 31487f8328f2 ("smp/cfd: Convert core to hotplug state machine")
accidently put this step on the wrong place. The step should be at the
cpuhp_ap_states[] rather than the cpuhp_bp_states[].
grep smpcfd /sys/devices/system/cpu/hotplug/states
40: smpcfd:prepare
129: smpcfd:dying
"smpcfd:dying" was missing before.
So was the invocation of the function smpcfd_dying_cpu().
Fixes: 31487f8328f2 ("smp/cfd: Convert core to hotplug state machine")
Signed-off-by: Lai Jiangshan <jiangshanlai@gmail.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Link: https://lkml.kernel.org/r/20171128131954.81229-1-jiangshanlai@gmail.com
[ Upstream commit 475113d937adfd150eb82b5e2c5507125a68e7af ]
It's possible to set up PEBS events to get only errors and not
any data, like on SNB-X (model 45) and IVB-EP (model 62)
via 2 perf commands running simultaneously:
taskset -c 1 ./perf record -c 4 -e branches:pp -j any -C 10
This leads to a soft lock up, because the error path of the
intel_pmu_drain_pebs_nhm() does not account event->hw.interrupt
for error PEBS interrupts, so in case you're getting ONLY
errors you don't have a way to stop the event when it's over
the max_samples_per_tick limit:
NMI watchdog: BUG: soft lockup - CPU#22 stuck for 22s! [perf_fuzzer:5816]
RIP: 0010:[<ffffffff81159232>] [<ffffffff81159232>] smp_call_function_single+0xe2/0x140
Call Trace:
? trace_hardirqs_on_caller+0xf5/0x1b0
? perf_cgroup_attach+0x70/0x70
perf_install_in_context+0x199/0x1b0
? ctx_resched+0x90/0x90
SYSC_perf_event_open+0x641/0xf90
SyS_perf_event_open+0x9/0x10
do_syscall_64+0x6c/0x1f0
entry_SYSCALL64_slow_path+0x25/0x25
Add perf_event_account_interrupt() which does the interrupt
and frequency checks and call it from intel_pmu_drain_pebs_nhm()'s
error path.
We keep the pending_kill and pending_wakeup logic only in the
__perf_event_overflow() path, because they make sense only if
there's any data to deliver.
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vince@deater.net>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Link: http://lkml.kernel.org/r/1482931866-6018-2-git-send-email-jolsa@kernel.org
commit 4bdced5c9a2922521e325896a7bbbf0132c94e56 upstream.
When a CPU lowers its priority (schedules out a high priority task for a
lower priority one), a check is made to see if any other CPU has overloaded
RT tasks (more than one). It checks the rto_mask to determine this and if so
it will request to pull one of those tasks to itself if the non running RT
task is of higher priority than the new priority of the next task to run on
the current CPU.
When we deal with large number of CPUs, the original pull logic suffered
from large lock contention on a single CPU run queue, which caused a huge
latency across all CPUs. This was caused by only having one CPU having
overloaded RT tasks and a bunch of other CPUs lowering their priority. To
solve this issue, commit:
b6366f048e0c ("sched/rt: Use IPI to trigger RT task push migration instead of pulling")
changed the way to request a pull. Instead of grabbing the lock of the
overloaded CPU's runqueue, it simply sent an IPI to that CPU to do the work.
Although the IPI logic worked very well in removing the large latency build
up, it still could suffer from a large number of IPIs being sent to a single
CPU. On a 80 CPU box, I measured over 200us of processing IPIs. Worse yet,
when I tested this on a 120 CPU box, with a stress test that had lots of
RT tasks scheduling on all CPUs, it actually triggered the hard lockup
detector! One CPU had so many IPIs sent to it, and due to the restart
mechanism that is triggered when the source run queue has a priority status
change, the CPU spent minutes! processing the IPIs.
Thinking about this further, I realized there's no reason for each run queue
to send its own IPI. As all CPUs with overloaded tasks must be scanned
regardless if there's one or many CPUs lowering their priority, because
there's no current way to find the CPU with the highest priority task that
can schedule to one of these CPUs, there really only needs to be one IPI
being sent around at a time.
This greatly simplifies the code!
The new approach is to have each root domain have its own irq work, as the
rto_mask is per root domain. The root domain has the following fields
attached to it:
rto_push_work - the irq work to process each CPU set in rto_mask
rto_lock - the lock to protect some of the other rto fields
rto_loop_start - an atomic that keeps contention down on rto_lock
the first CPU scheduling in a lower priority task
is the one to kick off the process.
rto_loop_next - an atomic that gets incremented for each CPU that
schedules in a lower priority task.
rto_loop - a variable protected by rto_lock that is used to
compare against rto_loop_next
rto_cpu - The cpu to send the next IPI to, also protected by
the rto_lock.
When a CPU schedules in a lower priority task and wants to make sure
overloaded CPUs know about it. It increments the rto_loop_next. Then it
atomically sets rto_loop_start with a cmpxchg. If the old value is not "0",
then it is done, as another CPU is kicking off the IPI loop. If the old
value is "0", then it will take the rto_lock to synchronize with a possible
IPI being sent around to the overloaded CPUs.
If rto_cpu is greater than or equal to nr_cpu_ids, then there's either no
IPI being sent around, or one is about to finish. Then rto_cpu is set to the
first CPU in rto_mask and an IPI is sent to that CPU. If there's no CPUs set
in rto_mask, then there's nothing to be done.
When the CPU receives the IPI, it will first try to push any RT tasks that is
queued on the CPU but can't run because a higher priority RT task is
currently running on that CPU.
Then it takes the rto_lock and looks for the next CPU in the rto_mask. If it
finds one, it simply sends an IPI to that CPU and the process continues.
If there's no more CPUs in the rto_mask, then rto_loop is compared with
rto_loop_next. If they match, everything is done and the process is over. If
they do not match, then a CPU scheduled in a lower priority task as the IPI
was being passed around, and the process needs to start again. The first CPU
in rto_mask is sent the IPI.
This change removes this duplication of work in the IPI logic, and greatly
lowers the latency caused by the IPIs. This removed the lockup happening on
the 120 CPU machine. It also simplifies the code tremendously. What else
could anyone ask for?
Thanks to Peter Zijlstra for simplifying the rto_loop_start atomic logic and
supplying me with the rto_start_trylock() and rto_start_unlock() helper
functions.
Cc: Clark Williams <williams@redhat.com>
Cc: Daniel Bristot de Oliveira <bristot@redhat.com>
Cc: John Kacur <jkacur@redhat.com>
Cc: Scott Wood <swood@redhat.com>
Link: http://lkml.kernel.org/r/20170424114732.1aac6dc4@gandalf.local.home
commit 7c2102e56a3f7d85b5d8f33efbd7aecc1f36fdd8 upstream.
The current implementation of synchronize_sched_expedited() incorrectly
assumes that resched_cpu() is unconditional, which it is not. This means
that synchronize_sched_expedited() can hang when resched_cpu()'s trylock
fails as follows (analysis by Neeraj Upadhyay):
o CPU1 is waiting for expedited wait to complete:
sync_rcu_exp_select_cpus
rdp->exp_dynticks_snap & 0x1 // returns 1 for CPU5
IPI sent to CPU5
synchronize_sched_expedited_wait
ret = swait_event_timeout(rsp->expedited_wq,
sync_rcu_preempt_exp_done(rnp_root),
jiffies_stall);
expmask = 0x20, CPU 5 in idle path (in cpuidle_enter())
o CPU5 handles IPI and fails to acquire rq lock.
Handles IPI
sync_sched_exp_handler
resched_cpu
returns while failing to try lock acquire rq->lock
need_resched is not set
o CPU5 calls rcu_idle_enter() and as need_resched is not set, goes to
idle (schedule() is not called).
o CPU 1 reports RCU stall.
Given that resched_cpu() is now used only by RCU, this commit fixes the
assumption by making resched_cpu() unconditional.
Reported-by: Neeraj Upadhyay <neeraju@codeaurora.org>
Suggested-by: Neeraj Upadhyay <neeraju@codeaurora.org>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
commit cef572ad9bd7f85035ba8272e5352040e8be0152 upstream.
When queue_work() is used in irq (not in task context), there is
a potential case that trigger NULL pointer dereference.
worker_thread()
|-spin_lock_irq()
|-process_one_work()
|-worker->current_pwq = pwq
|-spin_unlock_irq()
|-worker->current_func(work)
|-spin_lock_irq()
|-worker->current_pwq = NULL
|-spin_unlock_irq()
//interrupt here
|-irq_handler
|-__queue_work()
//assuming that the wq is draining
|-is_chained_work(wq)
|-current_wq_worker()
//Here, 'current' is the interrupted worker!
|-current->current_pwq is NULL here!
|-schedule()
Avoid it by checking for task context in current_wq_worker(), and
if not in task context, we shouldn't use the 'current' to check the
condition.
Reported-by: Xiaofei Tan <tanxiaofei@huawei.com>
Signed-off-by: Li Bin <huawei.libin@huawei.com>
Reviewed-by: Lai Jiangshan <jiangshanlai@gmail.com>
Fixes: 8d03ecfe4718 ("workqueue: reimplement is_chained_work() using current_wq_worker()")
[ Upstream commit 1b1d62254df0fe42a711eb71948f915918987790 ]
Bug was noticed via this warning:
WARNING: CPU: 6 PID: 1 at kernel/sched/sched.h:804 detach_task_cfs_rq+0x8e8/0xb80
Modules linked in:
CPU: 6 PID: 1 Comm: systemd Not tainted 4.10.0-rc5-00140-g0874170baf55-dirty #1
Hardware name: Supermicro SYS-4048B-TRFT/X10QBi, BIOS 1.0 04/11/2014
Call Trace:
dump_stack+0x4d/0x65
__warn+0xcb/0xf0
warn_slowpath_fmt+0x5f/0x80
? allocate_cgrp_cset_links+0x59/0x80
task_change_group_fair+0x27/0x150
sched_change_group+0x48/0xf0
sched_move_task+0x53/0x150
cpu_cgroup_attach+0x36/0x70
cgroup_taskset_migrate+0x175/0x300
cgroup_migrate+0xab/0xd0
cgroup_attach_task+0xf0/0x190
__cgroup_procs_write+0x1ed/0x2f0
cgroup_procs_write+0x14/0x20
cgroup_file_write+0x3f/0x100
kernfs_fop_write+0x104/0x180
__vfs_write+0x37/0x140
vfs_write+0xb8/0x1b0
SyS_write+0x55/0xc0
do_syscall_64+0x61/0x170
Reported-by: Ingo Molnar <mingo@kernel.org>
Reported-by: Borislav Petkov <bp@alien8.de>
commit 692b48258dda7c302e777d7d5f4217244478f1f6 upstream.
Josef reported a HARDIRQ-safe -> HARDIRQ-unsafe lock order detected by
lockdep:
[ 1270.472259] WARNING: HARDIRQ-safe -> HARDIRQ-unsafe lock order detected
[ 1270.472783] 4.14.0-rc1-xfstests-12888-g76833e8 #110 Not tainted
[ 1270.473240] -----------------------------------------------------
[ 1270.473710] kworker/u5:2/5157 [HC0[0]:SC0[0]:HE0:SE1] is trying to acquire:
[ 1270.474239] (&(&lock->wait_lock)->rlock){+.+.}, at: [<ffffffff8da253d2>] __mutex_unlock_slowpath+0xa2/0x280
[ 1270.474994]
[ 1270.474994] and this task is already holding:
[ 1270.475440] (&pool->lock/1){-.-.}, at: [<ffffffff8d2992f6>] worker_thread+0x366/0x3c0
[ 1270.476046] which would create a new lock dependency:
[ 1270.476436] (&pool->lock/1){-.-.} -> (&(&lock->wait_lock)->rlock){+.+.}
[ 1270.476949]
[ 1270.476949] but this new dependency connects a HARDIRQ-irq-safe lock:
[ 1270.477553] (&pool->lock/1){-.-.}
[ 1270.488900] to a HARDIRQ-irq-unsafe lock:
[ 1270.489327] (&(&lock->wait_lock)->rlock){+.+.}
[ 1270.494735] Possible interrupt unsafe locking scenario:
[ 1270.494735]
[ 1270.495250] CPU0 CPU1
[ 1270.495600] ---- ----
[ 1270.495947] lock(&(&lock->wait_lock)->rlock);
[ 1270.496295] local_irq_disable();
[ 1270.496753] lock(&pool->lock/1);
[ 1270.497205] lock(&(&lock->wait_lock)->rlock);
[ 1270.497744] <Interrupt>
[ 1270.497948] lock(&pool->lock/1);
, which will cause a irq inversion deadlock if the above lock scenario
happens.
The root cause of this safe -> unsafe lock order is the
mutex_unlock(pool->manager_arb) in manage_workers() with pool->lock
held.
Unlocking mutex while holding an irq spinlock was never safe and this
problem has been around forever but it never got noticed because the
only time the mutex is usually trylocked while holding irqlock making
actual failures very unlikely and lockdep annotation missed the
condition until the recent b9c16a0e1f73 ("locking/mutex: Fix
lockdep_assert_held() fail").
Using mutex for pool->manager_arb has always been a bit of stretch.
It primarily is an mechanism to arbitrate managership between workers
which can easily be done with a pool flag. The only reason it became
a mutex is that pool destruction path wants to exclude parallel
managing operations.
This patch replaces the mutex with a new pool flag POOL_MANAGER_ACTIVE
and make the destruction path wait for the current manager on a wait
queue.
v2: Drop unnecessary flag clearing before pool destruction as
suggested by Boqun.
Reported-by: Josef Bacik <josef@toxicpanda.com>
Cc: Boqun Feng <boqun.feng@gmail.com>
