path: root/kernel
2010-08-05Merge branch 'perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux-2.6 into perf/core
2010-08-05Merge branch 'perf/nmi' into perf/coreIngo Molnar
Conflicts: kernel/Makefile Merge reason: Add the now complete topic, fix the conflict. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-04tracing/kprobes: unregister_trace_probe needs to be called under mutexSrikar Dronamraju
Comment in unregister_trace_probe() says probe_lock will be held when it gets called. However there is a case where it might called without the probe_lock being held. Also since we are traversing the probe_list and deleting an element from the probe_list, probe_lock should be held. This was first pointed in uprobes traceevent review by Frederic Weisbecker here. (http://lkml.org/lkml/2010/5/12/106) Cc: Ingo Molnar <mingo@elte.hu> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20100630084548.GA10325@linux.vnet.ibm.com> Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-02Merge commit 'v2.6.35' into perf/coreIngo Molnar
Conflicts: tools/perf/Makefile tools/perf/util/hist.c Merge reason: Resolve the conflicts and update to latest upstream. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-02perf: Use tracepoint_synchronize_unregister() to flush any pending ↵Frederic Weisbecker
tracepoint call We use synchronize_sched() to ensure a tracepoint won't be called while/after we release the perf buffers it references. But the tracepoint API has its own API for that: tracepoint_synchronize_unregister(). Use it instead as it's self-explanatory and eases maintainance. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Li Zefan <lizf@cn.fujitsu.com>
2010-07-29CRED: Fix get_task_cred() and task_state() to not resurrect dead credentialsDavid Howells
It's possible for get_task_cred() as it currently stands to 'corrupt' a set of credentials by incrementing their usage count after their replacement by the task being accessed. What happens is that get_task_cred() can race with commit_creds(): TASK_1 TASK_2 RCU_CLEANER -->get_task_cred(TASK_2) rcu_read_lock() __cred = __task_cred(TASK_2) -->commit_creds() old_cred = TASK_2->real_cred TASK_2->real_cred = ... put_cred(old_cred) call_rcu(old_cred) [__cred->usage == 0] get_cred(__cred) [__cred->usage == 1] rcu_read_unlock() -->put_cred_rcu() [__cred->usage == 1] panic() However, since a tasks credentials are generally not changed very often, we can reasonably make use of a loop involving reading the creds pointer and using atomic_inc_not_zero() to attempt to increment it if it hasn't already hit zero. If successful, we can safely return the credentials in the knowledge that, even if the task we're accessing has released them, they haven't gone to the RCU cleanup code. We then change task_state() in procfs to use get_task_cred() rather than calling get_cred() on the result of __task_cred(), as that suffers from the same problem. Without this change, a BUG_ON in __put_cred() or in put_cred_rcu() can be tripped when it is noticed that the usage count is not zero as it ought to be, for example: kernel BUG at kernel/cred.c:168! invalid opcode: 0000 [#1] SMP last sysfs file: /sys/kernel/mm/ksm/run CPU 0 Pid: 2436, comm: master Not tainted 2.6.33.3-85.fc13.x86_64 #1 0HR330/OptiPlex 745 RIP: 0010:[<ffffffff81069881>] [<ffffffff81069881>] __put_cred+0xc/0x45 RSP: 0018:ffff88019e7e9eb8 EFLAGS: 00010202 RAX: 0000000000000001 RBX: ffff880161514480 RCX: 00000000ffffffff RDX: 00000000ffffffff RSI: ffff880140c690c0 RDI: ffff880140c690c0 RBP: ffff88019e7e9eb8 R08: 00000000000000d0 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000040 R12: ffff880140c690c0 R13: ffff88019e77aea0 R14: 00007fff336b0a5c R15: 0000000000000001 FS: 00007f12f50d97c0(0000) GS:ffff880007400000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007f8f461bc000 CR3: 00000001b26ce000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process master (pid: 2436, threadinfo ffff88019e7e8000, task ffff88019e77aea0) Stack: ffff88019e7e9ec8 ffffffff810698cd ffff88019e7e9ef8 ffffffff81069b45 <0> ffff880161514180 ffff880161514480 ffff880161514180 0000000000000000 <0> ffff88019e7e9f28 ffffffff8106aace 0000000000000001 0000000000000246 Call Trace: [<ffffffff810698cd>] put_cred+0x13/0x15 [<ffffffff81069b45>] commit_creds+0x16b/0x175 [<ffffffff8106aace>] set_current_groups+0x47/0x4e [<ffffffff8106ac89>] sys_setgroups+0xf6/0x105 [<ffffffff81009b02>] system_call_fastpath+0x16/0x1b Code: 48 8d 71 ff e8 7e 4e 15 00 85 c0 78 0b 8b 75 ec 48 89 df e8 ef 4a 15 00 48 83 c4 18 5b c9 c3 55 8b 07 8b 07 48 89 e5 85 c0 74 04 <0f> 0b eb fe 65 48 8b 04 25 00 cc 00 00 48 3b b8 58 04 00 00 75 RIP [<ffffffff81069881>] __put_cred+0xc/0x45 RSP <ffff88019e7e9eb8> ---[ end trace df391256a100ebdd ]--- Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-27dynamic debug: move ddebug_remove_module() down into free_module()Jason Baron
The command echo "file ec.c +p" >/sys/kernel/debug/dynamic_debug/control causes an oops. Move the call to ddebug_remove_module() down into free_module(). In this way it should be called from all error paths. Currently, we are missing the remove if the module init routine fails. Signed-off-by: Jason Baron <jbaron@redhat.com> Reported-by: Thomas Renninger <trenn@suse.de> Tested-by: Thomas Renninger <trenn@suse.de> Cc: <stable@kernel.org> [2.6.32+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-23Merge branch 'tip/perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
2010-07-22trace: strlen() return doesn't account for the NULLDan Carpenter
We need to add one to the strlen() return because of the NULL character. The type->name here generally comes from the kernel and I don't think any of them come close to being MAX_TRACER_SIZE (100) characters long so this is basically a cleanup. Signed-off-by: Dan Carpenter <error27@gmail.com> LKML-Reference: <20100710100644.GV19184@bicker> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-07-21sysrq,kdb: Use __handle_sysrq() for kdb's sysrq functionJason Wessel
The kdb code should not toggle the sysrq state in case an end user wants to try and resume the normal kernel execution. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2010-07-21debug_core,kdb: fix kgdb_connected bit set in the wrong placeJason Wessel
Immediately following an exit from the kdb shell the kgdb_connected variable should be set to zero, unless there are breakpoints planted. If the kgdb_connected variable is not zeroed out with kdb, it is impossible to turn off kdb. This patch is merely a work around for now, the real fix will check for the breakpoints. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-07-21Fix merge regression from external kdb to upstream kdbJason Wessel
In the process of merging kdb to the mainline, the kdb lsmod command stopped printing the base load address of kernel modules. This is needed for using kdb in conjunction with external tools such as gdb. Simply restore the functionality by adding a kdb_printf for the base load address of the kernel modules. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-07-21repair gdbstub to match the gdbserial protocol specificationJason Wessel
The gdbserial protocol handler should return an empty packet instead of an error string when ever it responds to a command it does not implement. The problem cases come from a debugger client sending qTBuffer, qTStatus, qSearch, qSupported. The incorrect response from the gdbstub leads the debugger clients to not function correctly. Recent versions of gdb will not detach correctly as a result of this behavior. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Dongdong Deng <dongdong.deng@windriver.com>
2010-07-21kdb: break out of kdb_ll() when command is terminatedMartin Hicks
Without this patch the "ll" linked-list traversal command won't terminate when you hit q/Q. Signed-off-by: Martin Hicks <mort@sgi.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-07-21Merge branch 'perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into perf/core
2010-07-21Merge branch 'linus' into perf/coreIngo Molnar
Merge reason: Pick up the latest perf fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-07-21tracing: Shrink max latency ringbuffer if unnecessaryKOSAKI Motohiro
Documentation/trace/ftrace.txt says buffer_size_kb: This sets or displays the number of kilobytes each CPU buffer can hold. The tracer buffers are the same size for each CPU. The displayed number is the size of the CPU buffer and not total size of all buffers. The trace buffers are allocated in pages (blocks of memory that the kernel uses for allocation, usually 4 KB in size). If the last page allocated has room for more bytes than requested, the rest of the page will be used, making the actual allocation bigger than requested. ( Note, the size may not be a multiple of the page size due to buffer management overhead. ) This can only be updated when the current_tracer is set to "nop". But it's incorrect. currently total memory consumption is 'buffer_size_kb x CPUs x 2'. Why two times difference is there? because ftrace implicitly allocate the buffer for max latency too. That makes sad result when admin want to use large buffer. (If admin want full logging and makes detail analysis). example, If admin have 24 CPUs machine and write 200MB to buffer_size_kb, the system consume ~10GB memory (200MB x 24 x 2). umm.. 5GB memory waste is usually unacceptable. Fortunatelly, almost all users don't use max latency feature. The max latency buffer can be disabled easily. This patch shrink buffer size of the max latency buffer if unnecessary. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> LKML-Reference: <20100701104554.DA2D.A69D9226@jp.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-07-20tracing: Reduce latency and remove percpu trace_seqLai Jiangshan
__print_flags() and __print_symbolic() use percpu trace_seq: 1) Its memory is allocated at compile time, it wastes memory if we don't use tracing. 2) It is percpu data and it wastes more memory for multi-cpus system. 3) It disables preemption when it executes its core routine "trace_seq_printf(s, "%s: ", #call);" and introduces latency. So we move this trace_seq to struct trace_iterator. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <4C078350.7090106@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-07-20trace: Reorder struct ring_buffer_per_cpu to remove padding on 64bitRichard Kennedy
Reorder structure to remove 8 bytes of padding on 64 bit builds. This shrinks the size to 128 bytes so allowing allocation from a smaller slab & needed one fewer cache lines. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> LKML-Reference: <1269516456.2054.8.camel@localhost> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-07-20tracing: Allow to disable cmdline recordingLi Zefan
We found that even enabling a single trace event that will rarely be triggered can add big overhead to context switch. (lmbench context switch test) ------------------------------------------------- 2p/0K 2p/16K 2p/64K 8p/16K 8p/64K 16p/16K 16p/64K ctxsw ctxsw ctxsw ctxsw ctxsw ctxsw ctxsw ------ ------ ------ ------ ------ ------- ------- 2.19 2.3 2.21 2.56 2.13 2.54 2.07 2.39 2.51 2.35 2.75 2.27 2.81 2.24 The overhead is 6% ~ 11%. It's because when a trace event is enabled 3 tracepoints (sched_switch, sched_wakeup, sched_wakeup_new) will be activated to map pid to cmdname. We'd like to avoid this overhead, so add a trace option '(no)record-cmd' to allow to disable cmdline recording. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4C2D57F4.2050204@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-07-20tracing: Use generic_file_llseek for debugfsArnd Bergmann
The default for llseek will change to no_llseek, so the tracing debugfs files need to add explicit .llseek assignments. Since we're dealing with regular files from a VFS perspective, use generic_file_llseek. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: John Kacur <jkacur@redhat.com> Cc: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <1278538820-1392-10-git-send-email-arnd@arndb.de> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2010-07-20tracing: Remove special tracesFrederic Weisbecker
Special traces type was only used by sysprof. Lets remove it now that sysprof ftrace plugin has been dropped. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Soeren Sandmann <sandmann@daimi.au.dk> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Li Zefan <lizf@cn.fujitsu.com>
2010-07-20tracing: Remove sysprof ftrace pluginFrederic Weisbecker
The sysprof ftrace plugin doesn't seem to be seriously used somewhere. There is a branch in the sysprof tree that makes an interface to it, but the real sysprof tool uses either its own module or perf events. Drop the sysprof ftrace plugin then, as it's mostly useless. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Soeren Sandmann <sandmann@daimi.au.dk> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Li Zefan <lizf@cn.fujitsu.com>
2010-07-19kmemleak: Add support for NO_BOOTMEM configurationsCatalin Marinas
With commits 08677214 and 59be5a8e, alloc_bootmem()/free_bootmem() and friends use the early_res functions for memory management when NO_BOOTMEM is enabled. This patch adds the kmemleak calls in the corresponding code paths for bootmem allocations. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Yinghai Lu <yinghai@kernel.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: stable@kernel.org
2010-07-15tracing: Remove ksym tracerFrederic Weisbecker
The ksym (breakpoint) ftrace plugin has been superseded by perf tools that are much more poweful to use the cpu breakpoints. This tracer doesn't bring more feature. It has been deprecated for a while now, lets remove it. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Prasad <prasad@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu>
2010-07-07kernel/watchdog: Initialize 'result'Kulikov Vasiliy
Variable on the stack is not initialized to zero, do it explicitly. This bug was found by a compiler warning: kernel/watchdog.c:463: warning: 'result' may be used uninitialized in this function Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Acked-by: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1278316854-28442-1-git-send-email-segooon@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-07-06Merge branch 'perf/core' of ↵Ingo Molnar
2010-07-05tracing/kprobes: Support "string" typeMasami Hiramatsu
Support string type tracing and printing in kprobe-tracer. This allows user to trace string data in kernel including __user data. Note that sometimes __user data may not be accessed if it is paged-out (sorry, but kprobes operation should be done in atomic, we can not wait for page-in). Commiter note: Fixed up conflicts with b7e2ece. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20100519195724.2885.18788.stgit@localhost6.localdomain6> Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-07-05Merge commit 'v2.6.35-rc4' into perf/coreIngo Molnar
Merge reason: Pick up the latest perf fixes Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-07-04module: initialize module dynamic debug laterYehuda Sadeh
We should initialize the module dynamic debug datastructures only after determining that the module is not loaded yet. This fixes a bug that introduced in 2.6.35-rc2, where when a trying to load a module twice, we also load it's dynamic printing data twice which causes all sorts of nasty issues. Also handle the dynamic debug cleanup later on failure. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (removed a #ifdef) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-02Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Cure nr_iowait_cpu() users init: Fix comment init, sched: Fix race between init and kthreadd
2010-07-01sched: Cure nr_iowait_cpu() usersPeter Zijlstra
Commit 0224cf4c5e (sched: Intoduce get_cpu_iowait_time_us()) broke things by not making sure preemption was indeed disabled by the callers of nr_iowait_cpu() which took the iowait value of the current cpu. This resulted in a heap of preempt warnings. Cure this by making nr_iowait_cpu() take a cpu number and fix up the callers to pass in the right number. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Jiri Slaby <jslaby@suse.cz> Cc: linux-pm@lists.linux-foundation.org LKML-Reference: <1277968037.1868.120.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-30futex: futex_find_get_task remove credentails checkMichal Hocko
futex_find_get_task is currently used (through lookup_pi_state) from two contexts, futex_requeue and futex_lock_pi_atomic. None of the paths looks it needs the credentials check, though. Different (e)uids shouldn't matter at all because the only thing that is important for shared futex is the accessibility of the shared memory. The credentail check results in glibc assert failure or process hang (if glibc is compiled without assert support) for shared robust pthread mutex with priority inheritance if a process tries to lock already held lock owned by a process with a different euid: pthread_mutex_lock.c:312: __pthread_mutex_lock_full: Assertion `(-(e)) != 3 || !robust' failed. The problem is that futex_lock_pi_atomic which is called when we try to lock already held lock checks the current holder (tid is stored in the futex value) to get the PI state. It uses lookup_pi_state which in turn gets task struct from futex_find_get_task. ESRCH is returned either when the task is not found or if credentials check fails. futex_lock_pi_atomic simply returns if it gets ESRCH. glibc code, however, doesn't expect that robust lock returns with ESRCH because it should get either success or owner died. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Darren Hart <dvhltc@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Nick Piggin <npiggin@suse.de> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-29kexec: fix Oops in crash_shrink_memory()Pavan Naregundi
When crashkernel is not enabled, "echo 0 > /sys/kernel/kexec_crash_size" OOPSes the kernel in crash_shrink_memory. This happens when crash_shrink_memory tries to release the 'crashk_res' resource which are not reserved. Also value of "/sys/kernel/kexec_crash_size" shows as 1, which should be 0. This patch fixes the OOPS in crash_shrink_memory and shows "/sys/kernel/kexec_crash_size" as 0 when crash kernel memory is not reserved. Signed-off-by: Pavan Naregundi <pavan@linux.vnet.ibm.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Simon Horman <horms@verge.net.au> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-28tracing: Use class->reg() for all registering of eventsSteven Rostedt
Because kprobes and syscalls need special processing to register events, the class->reg() method was created to handle the differences. But instead of creating a default ->reg for perf and ftrace events, the code was scattered with: if (class->reg) class->reg(); else default_reg(); This is messy and can also lead to bugs. This patch cleans up this code and creates a default reg() entry for the events allowing for the code to directly call the class->reg() without the condition. Reported-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-06-28tracing/function-graph: Use correct string size for snprintfChase Douglas
The nsecs_str string is a local variable defined as: char nsecs_str[5]; It is possible for the snprintf call to use a size value larger than the size of the string. This should not cause a buffer overrun as it is written now due to the value for the string format "%03lu" can not be larger than 1000. However, this change makes it correct. By making the size correct we guard against potential future changes that could actually cause a buffer overrun. Signed-off-by: Chase Douglas <chase.douglas@canonical.com> LKML-Reference: <1276619355-18116-1-git-send-email-chase.douglas@canonical.com> [ added 'UL' to number 8 to fix gcc warning comparing it to sizeof() ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-06-28tracing: Remove open-coded __trace_add_event_call()Li Zefan
Let trace_module_add_events() and event_trace_init() call __trace_add_event_call(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4BFA37E9.1020106@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-06-28tracing: Remove redundant raw_init callbacksLi Zefan
raw_init callback is optional. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4BFA37D4.7070500@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-06-28tracing: Remove test of NULL define_fields callbackLi Zefan
Every event (or event class) has it's define_fields callback, so the test is redundant. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4BFA37BC.8080707@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-06-28tracing: Don't allocate common fields for every trace eventsLi Zefan
Every event has the same common fields, so it's a big waste of memory to have a copy of those fields for every event. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4BFA3759.30105@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-06-28tracing: Use a global field list for all syscall exit eventsLi Zefan
All syscall exit events have the same fields. The kernel size drops 2.5K: text data bss dec hex filename 7018612 2034376 7251132 16304120 f8c7f8 vmlinux.o.orig 7018612 2031888 7251132 16301632 f8be40 vmlinux.o Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4BFA3746.8070100@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-06-28Merge branch 'linus' into perf/coreThomas Gleixner
Reason: Further changes conflict with upstream fixes Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-06-28Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing: Fix undeclared ENOSYS in include/linux/tracepoint.h perf record: prevent kill(0, SIGTERM); perf session: Remove threads from tree on PERF_RECORD_EXIT perf/tracing: Fix regression of perf losing kprobe events perf_events: Fix Intel Westmere event constraints perf record: Don't call newt functions when not initialized
2010-06-28Merge branch 'irq-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Deal with desc->set_type() changing desc->chip
2010-06-28Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Prevent compiler from optimising the sched_avg_update() loop sched: Fix over-scheduling bug sched: Fix PROVE_RCU vs cpu_cgroup
2010-06-28Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: nohz: Fix nohz ratelimit
2010-06-28Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: silence PROVE_RCU in sched_fork() idr: fix RCU lockdep splat in idr_get_next() rcu: apply RCU protection to wake_affine()
2010-06-25sched: Prevent compiler from optimising the sched_avg_update() loopWill Deacon
GCC 4.4.1 on ARM has been observed to replace the while loop in sched_avg_update with a call to uldivmod, resulting in the following build failure at link-time: kernel/built-in.o: In function `sched_avg_update': kernel/sched.c:1261: undefined reference to `__aeabi_uldivmod' kernel/sched.c:1261: undefined reference to `__aeabi_uldivmod' make: *** [.tmp_vmlinux1] Error 1 This patch introduces a fake data hazard to the loop body to prevent the compiler optimising the loop away. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-24hw_breakpoints: Fix per task breakpoint trackingFrederic Weisbecker
Freeing a perf event can happen in several ways. A task calls perf_event_exit_task() right before exiting. This helper will detach all the events from the task context and queue their removal through free_event() if they are child tasks. The task also loses its context reference there. Releasing the breakpoint slot from the constraint table is made from free_event() that calls release_bp_slot(). We count the number of breakpoints this task is running by looking at the task's perf_event_ctxp and iterating through its attached events. But at this time, the reference to this context has been cleaned up already. So looking at the event->ctx instead of task->perf_event_ctxp to count the remaining breakpoints should solve the problem. At least it would for child breakpoints, but not for parent ones. If the parent exits before the child, it will remove all its events from the context but free_event() will be called later, on fd release time. And checking the number of breakpoints the task has attached to its context at this time is unreliable as all events have been removed from the context. To solve this, we keep track of the list of per task breakpoints. On top of it, we maintain our array of numbers of breakpoints used by the tasks. We use the context address as a task id. So, instead of looking at the number of events attached to a context, we walk through our list of per task breakpoints and count the number of breakpoints that use the same ctx than the one to be reserved or released from the constraint table, and update the count on top of this result. In the meantime it solves a bad refcounting, it also solves a warning, reported by Paul. Badness at /home/paulus/kernel/perf/kernel/hw_breakpoint.c:114 NIP: c0000000000cb470 LR: c0000000000cb46c CTR: c00000000032d9b8 REGS: c000000118e7b570 TRAP: 0700 Not tainted (2.6.35-rc3-perf-00008-g76b0f13 ) MSR: 9000000000029032 <EE,ME,CE,IR,DR> CR: 44004424 XER: 000fffff TASK = c0000001187dcad0[3143] 'perf' THREAD: c000000118e78000 CPU: 1 GPR00: c0000000000cb46c c000000118e7b7f0 c0000000009866a0 0000000000000020 GPR04: 0000000000000000 000000000000001d 0000000000000000 0000000000000001 GPR08: c0000000009bed68 c00000000086dff8 c000000000a5bf10 0000000000000001 GPR12: 0000000024004422 c00000000ffff200 0000000000000000 0000000000000000 GPR16: 0000000000000000 0000000000000000 0000000000000018 00000000101150f4 GPR20: 0000000010206b40 0000000000000000 0000000000000000 00000000101150f4 GPR24: c0000001199090c0 0000000000000001 0000000000000000 0000000000000001 GPR28: 0000000000000000 0000000000000000 c0000000008ec290 0000000000000000 NIP [c0000000000cb470] .task_bp_pinned+0x5c/0x12c LR [c0000000000cb46c] .task_bp_pinned+0x58/0x12c Call Trace: [c000000118e7b7f0] [c0000000000cb46c] .task_bp_pinned+0x58/0x12c (unreliable) [c000000118e7b8a0] [c0000000000cb584] .toggle_bp_task_slot+0x44/0xe4 [c000000118e7b940] [c0000000000cb6c8] .toggle_bp_slot+0xa4/0x164 [c000000118e7b9f0] [c0000000000cbafc] .release_bp_slot+0x44/0x6c [c000000118e7ba80] [c0000000000c4178] .bp_perf_event_destroy+0x10/0x24 [c000000118e7bb00] [c0000000000c4aec] .free_event+0x180/0x1bc [c000000118e7bbc0] [c0000000000c54c4] .perf_event_release_kernel+0x14c/0x170 Reported-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Prasad <prasad@linux.vnet.ibm.com> Cc: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Jason Wessel <jason.wessel@windriver.com>
2010-06-23sched: silence PROVE_RCU in sched_fork()Peter Zijlstra
Because cgroup_fork() is ran before sched_fork() [ from copy_process() ] and the child's pid is not yet visible the child is pinned to its cgroup. Therefore we can silence this warning. A nicer solution would be moving cgroup_fork() to right after dup_task_struct() and exclude PF_STARTING from task_subsys_state(). Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
