kernel/power/disk.c
Deprecate the old "legacy" PM API, and more importantly default it to "n".
Virtually nothing in-tree uses it any more.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Show the initialization state(live, coming, going) of the module:
$ cat /sys/module/usbcore/initstate
live
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Virtually index, physically tagged cache architectures can get away
without cache flushing when forking. This patch adds a new cache
flushing function flush_cache_dup_mm(struct mm_struct *) which for the
moment I've implemented to do the same thing on all architectures
except on MIPS where it's a no-op.
calc_load() is called by timer interrupt to update avenrun[]. It currently
calls nr_active() at each timer tick (HZ per second), while the update of
avenrun[] is done only once every 5 seconds. (LOAD_FREQ=5 Hz)
nr_active() is quite expensive on SMP machines, since it has to sum up
nr_running and nr_uninterruptible of all online CPUS, bringing foreign
dirty cache lines.
This patch is an optimization of calc_load() so that nr_active() is called
only if we need it.
The use of unlikely() is welcome since the condition is true only once every
5*HZ time.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Acked-by: "Siddha, Suresh B" <suresh.b.siddha@intel.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
All kcalloc() calls of the form "kcalloc(1,...)" are converted to the
equivalent kzalloc() calls, and a few kcalloc() calls with the incorrect
ordering of the first two arguments are fixed.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: Adam Belay <ambx1@neo.rr.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Greg KH <greg@kroah.com>
Cc: Mark Fasheh <mark.fasheh@oracle.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Neil Brown <neilb@suse.de>
Jarek Poplawski noticed that lockdep global state could be accessed in a
racy way if one CPU did a lockdep assert (shutting lockdep down), while the
other CPU would try to do something that changes its global state.
This patch fixes those races and cleans up lockdep's internal locking by
adding a graph_lock()/graph_unlock()/debug_locks_off_graph_unlock helpers.
(Also note that as we all know the Linux kernel is, by definition, bug-free
and perfect, so this code never triggers, so these fixes are highly
theoretical. I wrote this patch for aesthetic reasons alone.)
[akpm@osdl.org: build fix]
[jarkao2@o2.pl: build fix's refix]
Signed-off-by: Jarek Poplawski <jarkao2@o2.pl>
When we print an assert due to scheduling-in-atomic bugs, and if lockdep
is enabled, then the IRQ tracing information of lockdep can be printed
to pinpoint the code location that disabled interrupts. This saved me
quite a bit of debugging time in cases where the backtrace did not
identify the irq-disabling site well enough.
CONFIG_DEBUG_LOCKDEP is unacceptably slow because it does not utilize
the chain-hash. Turn the chain-hash back on in this case too.
Cleanup: the VERY_VERBOSE define was unnecessarily dependent on #ifdef VERBOSE
- while the VERBOSE switch is 0 or 1 (always defined).
Clear all the chains during lockdep_reset(). This fixes some locking-selftest
false positives i saw on -rt. (never saw those on mainline though, but it
could happen.)
Make verbose lockdep messages (off by default) more informative by printing
out the hash chain key. (this patch was what helped me catch the earlier
lockdep hash-collision bug)
Fix typo in the class_filter() function. (filtering is not used by default so
this only affects lockdep-internal debugging cases)
Most distributions enable sysrq support but set it to 0 by default. Add a
sysrq_always_enabled boot option to always-enable sysrq keys. Useful for
debugging - without having to modify the disribution's config files (which
might not be possible if the kernel is on a live CD, etc.).
Also, while at it, clean up the sysrq interfaces.
[bunk@stusta.de: make sysrq_always_enabled_setup() static]
Currently, to tell a task that it should go to the refrigerator, we set the
PF_FREEZE flag for it and send a fake signal to it. Unfortunately there
are two SMP-related problems with this approach. First, a task running on
another CPU may be updating its flags while the freezer attempts to set
PF_FREEZE for it and this may leave the task's flags in an inconsistent
state. Second, there is a potential race between freeze_process() and
refrigerator() in which freeze_process() running on one CPU is reading a
task's PF_FREEZE flag while refrigerator() running on another CPU has just
set PF_FROZEN for the same task and attempts to reset PF_FREEZE for it. If
the refrigerator wins the race, freeze_process() will state that PF_FREEZE
hasn't been set for the task and will set it unnecessarily, so the task
will go to the refrigerator once again after it's been thawed.
To solve first of these problems we need to stop using PF_FREEZE to tell
tasks that they should go to the refrigerator. Instead, we can introduce a
special TIF_*** flag and use it for this purpose, since it is allowed to
change the other tasks' TIF_*** flags and there are special calls for it.
To avoid the freeze_process()-refrigerator() race we can make
freeze_process() to always check the task's PF_FROZEN flag after it's read
its "freeze" flag. We should also make sure that refrigerator() will
always reset the task's "freeze" flag after it's set PF_FROZEN for it.
Acked-by: Pavel Machek <pavel@ucw.cz>
Cc: Andi Kleen <ak@muc.de>
Cc: "Luck, Tony" <tony.luck@intel.com>
Currently, if a task is stopped (ie. it's in the TASK_STOPPED state), it
is considered by the freezer as unfreezeable. However, there may be a race
between the freezer and the delivery of the continuation signal to the task
resulting in the task running after we have finished freezing the other
tasks. This, in turn, may lead to undesirable effects up to and including
data corruption.
To prevent this from happening we first need to make the freezer consider
stopped tasks as freezeable. For this purpose we need to make freezeable()
stop returning 0 for these tasks and we need to force them to enter the
refrigerator. However, if there's no continuation signal in the meantime,
the stopped tasks should remain stopped after all processes have been
thawed, so we need to send an additional SIGSTOP to each of them before
waking it up.
Also, a stopped task that has just been woken up should first check if
there's a freezing request for it and go to the refrigerator if that's the
case.
Elaborate the API for calling cpuset_zone_allowed(), so that users have to
explicitly choose between the two variants:
cpuset_zone_allowed_hardwall()
cpuset_zone_allowed_softwall()
Until now, whether or not you got the hardwall flavor depended solely on
whether or not you or'd in the __GFP_HARDWALL gfp flag to the gfp_mask
argument.
If you didn't specify __GFP_HARDWALL, you implicitly got the softwall
version.
Unfortunately, this meant that users would end up with the softwall version
without thinking about it. Since only the softwall version might sleep,
this led to bugs with possible sleeping in interrupt context on more than
one occassion.
The hardwall version requires that the current tasks mems_allowed allows
the node of the specified zone (or that you're in interrupt or that
__GFP_THISNODE is set or that you're on a one cpuset system.)
The softwall version, depending on the gfp_mask, might allow a node if it
was allowed in the nearest enclusing cpuset marked mem_exclusive (which
requires taking the cpuset lock 'callback_mutex' to evaluate.)
This patch removes the cpuset_zone_allowed() call, and forces the caller to
explicitly choose between the hardwall and the softwall case.
If the caller wants the gfp_mask to determine this choice, they should (1)
be sure they can sleep or that __GFP_HARDWALL is set, and (2) invoke the
cpuset_zone_allowed_softwall() routine.
This adds another 100 or 200 bytes to the kernel text space, due to the few
lines of nearly duplicate code at the top of both cpuset_zone_allowed_*
routines. It should save a few instructions executed for the calls that
turned into calls of cpuset_zone_allowed_hardwall, thanks to not having to
set (before the call) then check (within the call) the __GFP_HARDWALL flag.
For the most critical call, from get_page_from_freelist(), the same
instructions are executed as before -- the old cpuset_zone_allowed()
routine it used to call is the same code as the
cpuset_zone_allowed_softwall() routine that it calls now.
Not a perfect win, but seems worth it, to reduce this chance of hitting a
sleeping with irq off complaint again.
Signed-off-by: Paul Jackson <pj@sgi.com>
This reverts commit 373beb35cd6b625e0ba4ad98baace12310a26aa8.
No one is using this identifier yet. The purpose of this identifier is to
export nsproxy to user space which is wrong. nsproxy is an internal
implementation optimization, which should keep our fork times from getting
slower as we increase the number of global namespaces you don't have to
share.
Adding a global identifier like this is inappropriate because it makes
namespaces inherently non-recursive, greatly limiting what we can do with
them in the future.
Cc: Cedric Le Goater <clg@fr.ibm.com>
Mostly changing alignment. Just some general cleanup.
Signed-off-by: Daniel Walker <dwalker@mvista.com>
Acked-by: John Stultz <johnstul@us.ibm.com>
Simply adds some ifdefs to remove clocksoure sysfs code when CONFIG_SYSFS
isn't turn on.
Introduce a round_jiffies() function as well as a round_jiffies_relative()
function. These functions round a jiffies value to the next whole second.
The primary purpose of this rounding is to cause all "we don't care exactly
when" timers to happen at the same jiffy.
This avoids multiple timers firing within the second for no real reason;
with dynamic ticks these extra timers cause wakeups from deep sleep CPU
sleep states and thus waste power.
The exact wakeup moment is skewed by the cpu number, to avoid all cpus from
waking up at the exact same time (and hitting the same lock/cachelines
there)
[akpm@osdl.org: fix variable type]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
An fdtable can either be embedded inside a files_struct or standalone (after
being expanded). When an fdtable is being discarded after all RCU references
to it have expired, we must either free it directly, in the standalone case,
or free the files_struct it is contained within, in the embedded case.
Currently the free_files field controls this behavior, but we can get rid of
it entirely, as all the necessary information is already recorded. We can
distinguish embedded and standalone fdtables using max_fds, and if it is
embedded we can divine the relevant files_struct using container_of().
Signed-off-by: Vadim Lobanov <vlobanov@speakeasy.net>
Cc: Dipankar Sarma <dipankar@in.ibm.com>
Currently, each fdtable supports three dynamically-sized arrays of data: the
fdarray and two fdsets. The code allows the number of fds supported by the
fdarray (fdtable->max_fds) to differ from the number of fds supported by each
of the fdsets (fdtable->max_fdset).
In practice, it is wasteful for these two sizes to differ: whenever we hit a
limit on the smaller-capacity structure, we will reallocate the entire fdtable
and all the dynamic arrays within it, so any delta in the memory used by the
larger-capacity structure will never be touched at all.
Rather than hogging this excess, we shouldn't even allocate it in the first
place, and keep the capacities of the fdarray and the fdsets equal. This
patch removes fdtable->max_fdset. As an added bonus, most of the supporting
code becomes simpler.
The dup_fd() function creates a new files_struct and fdtable embedded inside
that files_struct, and then possibly expands the fdtable using expand_files().
The out_release error path is invoked when expand_files() returns an error
code. However, when this attempt to expand fails, the fdtable is left in its
original embedded form, so it is pointless to try to free the associated
fdarray and fdsets.
[akpm@osdl.org: additional cleanups]
Signed-off-by: Miguel Ojeda Sandonis <maxextreme@gmail.com>
RT task does not participate in interactiveness priority and thus shouldn't
be bothered with timestamp and p->sleep_type manipulation when task is
being put on run queue. Bypass all of the them with a single if (rt_task)
test.
Signed-off-by: Ken Chen <kenneth.w.chen@intel.com>
Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com>
Remove scheduler stats lb_stopbalance counter. This counter can be
calculated by: lb_balanced - lb_nobusyg - lb_nobusyq. There is no need to
create gazillion counters while we can derive the value.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Currently at a particular domain, each cpu in the sched group will do a
load balance at the frequency of balance_interval. More the cores and
threads, more the cpus will be in each sched group at SMP and NUMA domain.
And we endup spending quite a bit of time doing load balancing in those
domains.
Fix this by making only one cpu(first idle cpu or first cpu in the group if
all the cpus are busy) in the sched group do the load balance at that
particular sched domain and this load will slowly percolate down to the
other cpus with in that group(when they do load balancing at lower
domains).
Cc: Christoph Lameter <clameter@engr.sgi.com>
Co-opt rq->timestamp_last_tick to maintain a cache_hot_time evaluation
reference timestamp at both tick and sched times to prevent said reference,
formerly rq->timestamp_last_tick, from being behind task->last_ran at
evaluation time, and to move said reference closer to current time on the
remote processor, intent being to improve cache hot evaluation and
timestamp adjustment accuracy for task migration.
Fix minor sched_time double accounting error which occurs when a task
passing through schedule() does not schedule off, and takes the next timer
tick.
[kenneth.w.chen@intel.com: cleanup]
Signed-off-by: Mike Galbraith <efault@gmx.de>
Acked-by: Ken Chen <kenneth.w.chen@intel.com>
Cc: Don Mullis <dwm@meer.net>
Large sched domains can be very expensive to scan. Add an option SD_SERIALIZE
to the sched domain flags. If that flag is set then we make sure that no
other such domain is being balanced.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Cc: Peter Williams <pwil3058@bigpond.net.au>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: "Chen, Kenneth W" <kenneth.w.chen@intel.com>
Trigger softirq less frequently
We trigger the softirq before this patch using offset of sd->interval.
However, if the queue is busy then it is sufficient to schedule the softirq
with sd->interval * busy_factor.
So we modify the calculation of the next time to balance by taking
the interval added to last_balance again. This is only the
right value if the idle/busy situation continues as is.
There are two potential trouble spots:
- If the queue was idle and now gets busy then we call rebalance
early. However, that is not a problem because we will then use
the longer interval for the next period.
- If the queue was busy and becomes idle then we potentially
wait too long before rebalancing. However, when the task
goes idle then idle_balance is called. We add another calculation
of the next balance time based on sd->interval in idle_balance
so that we will rebalance soon.
V2->V3:
- Calculate rebalance time based on current jiffies and not
based on the jiffies at the last time we load balanced.
We no longer rely on staggering and therefore we can
affort to do this now.
V3->V4:
- Use functions to do jiffy comparisons.
Call rebalance_tick (renamed to run_rebalance_domains) from a newly introduced
softirq.
We calculate the earliest time for each layer of sched domains to be rescanned
(this is the rescan time for idle) and use the earliest of those to schedule
the softirq via a new field "next_balance" added to struct rq.
Perform the idle state determination in rebalance_tick.
If we separate balancing from sched_tick then we also need to determine the
idle state in rebalance_tick.
V2->V3
Remove useless idlle != 0 check. Checking nr_running seems
to be sufficient. Thanks Suresh.
A load calculation is always done in rebalance_tick() in addition to the real
load balancing activities that only take place when certain jiffie counts have
been reached. Move that processing into a separate function and call it
directly from scheduler_tick().
Also extract the time slice handling from scheduler_tick and put it into a
separate function. Then we can clean up scheduler_tick significantly. It
will no longer have any gotos.
Interrupts must be disabled for request queue locks if we want to run
load_balance() with interrupts enabled.
Timer interrupts already are staggered. We do not need an additional layer of
time staggering for short load balancing actions that take a reasonably small
portion of the time slice.
For load balancing on large sched_domains we will add a serialization later
that avoids concurrent load balance operations and thus has the same effect as
load staggering.
Avoid taking the request queue lock in wake_priority_sleeper if there are no
running processes.
move_task_off_dead_cpu() requires interrupts to be disabled, while
migrate_dead() calls it with enabled interrupts. Added appropriate
comments to functions and added BUG_ON(!irqs_disabled()) into
double_rq_lock() and double_lock_balance() which are the origin sources of
such bugs.
Signed-off-by: Kirill Korotaev <dev@openvz.org>
Move the sched group allocations to percpu area. This will minimize cross
node memory references and also cleans up the sched groups allocation for
allnodes sched domain.
Acked-by: Christoph Lameter <clameter@sgi.com>
Deliver IO accounting via taskstats.
Cc: Jay Lan <jlan@sgi.com>
Cc: Shailabh Nagar <nagar@watson.ibm.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Chris Sturtivant <csturtiv@sgi.com>
Cc: Tony Ernst <tee@sgi.com>
Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net>
Cc: David Wright <daw@sgi.com>
The present per-task IO accounting isn't very useful. It simply counts the
number of bytes passed into read() and write(). So if a process reads 1MB
from an already-cached file, it is accused of having performed 1MB of I/O,
which is wrong.
(David Wright had some comments on the applicability of the present logical IO accounting:
For billing purposes it is useless but for workload analysis it is very
useful
read_bytes/read_calls average read request size
write_bytes/write_calls average write request size
read_bytes/read_blocks ie logical/physical can indicate hit rate or thrashing
write_bytes/write_blocks ie logical/physical guess since pdflush writes can
be missed
I often look for logical larger than physical to see filesystem cache
problems. And the bytes/cpusec can help find applications that are
dominating the cache and causing slow interactive response from page cache
contention.
I want to find the IO intensive applications and make sure they are doing
efficient IO. Thus the acctcms(sysV) or csacms command would give the high
IO commands).
This patchset adds new accounting which tries to be more accurate. We account
for three things:
reads:
attempt to count the number of bytes which this process really did cause
to be fetched from the storage layer. Done at the submit_bio() level, so it
is accurate for block-backed filesystems. I also attempt to wire up NFS and
CIFS.
writes:
attempt to count the number of bytes which this process caused to be sent
to the storage layer. This is done at page-dirtying time.
The big inaccuracy here is truncate. If a process writes 1MB to a file
and then deletes the file, it will in fact perform no writeout. But it will
have been accounted as having caused 1MB of write.
So...
cancelled_writes:
account the number of bytes which this process caused to not happen, by
truncating pagecache.
We _could_ just subtract this from the process's `write' accounting. But
that means that some processes would be reported to have done negative
amounts of write IO, which is silly.
So we just report the raw number and punt this decision up to userspace.
Now, we _could_ account for writes at the physical I/O level. But
- This would require that we track memory-dirtying tasks at the per-page
level (would require a new pointer in struct page).
- It would mean that IO statistics for a process are usually only available
long after that process has exitted. Which means that we probably cannot
communicate this info via taskstats.
This patch:
Wire up the kernel-private data structures and the accessor functions to
manipulate them.
Cc: Andi Kleen <ak@suse.de>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
kernel.cap-bound uses only OP_SET and OP_AND
Cc: Chris Wright <chrisw@sous-sol.org>
When CONFIG_PROC_FS=n and CONFIG_PROC_SYSCTL=n but CONFIG_SYSVIPC=y, we get
this build error:
kernel/built-in.o:(.data+0xc38): undefined reference to `proc_ipc_doulongvec_minmax'
kernel/built-in.o:(.data+0xc88): undefined reference to `proc_ipc_doulongvec_minmax'
kernel/built-in.o:(.data+0xcd8): undefined reference to `proc_ipc_dointvec'
kernel/built-in.o:(.data+0xd28): undefined reference to `proc_ipc_dointvec'
kernel/built-in.o:(.data+0xd78): undefined reference to `proc_ipc_dointvec'
kernel/built-in.o:(.data+0xdc8): undefined reference to `proc_ipc_dointvec'
kernel/built-in.o:(.data+0xe18): undefined reference to `proc_ipc_dointvec'
make: *** [vmlinux] Error 1
Acked-by: Eric Biederman <ebiederm@xmission.com>
Use direct assignment rather than cmpxchg() as the latter is unavailable
and unimplementable on some platforms and is actually unnecessary.
The use of cmpxchg() was to guard against two possibilities, neither of
which can actually occur:
(1) The pending flag may have been unset or may be cleared. However, given
where it's called, the pending flag is _always_ set. I don't think it
can be unset whilst we're in set_wq_data().
Once the work is enqueued to be actually run, the only way off the queue
is for it to be actually run.
If it's a delayed work item, then the bit can't be cleared by the timer
because we haven't started the timer yet. Also, the pending bit can't be
cleared by cancelling the delayed work _until_ the work item has had its
timer started.
(2) The workqueue pointer might change. This can only happen in two cases:
(a) The work item has just been queued to actually run, and so we're
protected by the appropriate workqueue spinlock.
(b) A delayed work item is being queued, and so the timer hasn't been
started yet, and so no one else knows about the work item or can
access it (the pending bit protects us).
Besides, set_wq_data() _sets_ the workqueue pointer unconditionally, so
it can be assigned instead.
So, replacing the set_wq_data() with a straight assignment would be okay
in most cases.
The problem is where we end up tangling with test_and_set_bit() emulated
using spinlocks, and even then it's not a problem _provided_
test_and_set_bit() doesn't attempt to modify the word if the bit was
set.
If that's a problem, then a bitops-proofed assignment will be required -
equivalent to atomic_set() vs other atomic_xxx() ops.
Currently there is a regression and the ipc sysctls don't show up in the
binary sysctl namespace.
This patch adds sysctl_ipc_data to read data/write from the appropriate
namespace and deliver it in the expected manner.
[akpm@osdl.org: warning fix]
Refactor the ipc sysctl support so that it is simpler, more readable, and
prepares for fixing the bug with the wrong values being returned in the
sys_sysctl interface.
The function proc_do_ipc_string() was misnamed as it never handled strings.
It's magic of when to work with strings and when to work with longs belonged
in the sysctl table. I couldn't tell if the code would work if you disabled
the ipc namespace but it certainly looked like it would have problems.
The problem: When using sys_sysctl we don't read the proper values for the
variables exported from the uts namespace, nor do we do the proper locking.
This patch introduces sysctl_uts_string which properly fetches the values and
does the proper locking.
The binary interface to the namespace sysctls was never implemented resulting
in some really weird things if you attempted to use sys_sysctl to read your
hostname for example.
This patch series simples the code a little and implements the binary sysctl
interface.
In testing this patch series I discovered that our 32bit compatibility for the
binary sysctl interface is imperfect. In particular KERN_SHMMAX and
KERN_SMMALL are size_t sized quantities and are returned as 8 bytes on to
32bit binaries using a x86_64 kernel. However this has existing for a long
time so it is not a new regression with the namespace work.
Gads the whole sysctl thing needs work before it stops being easy to shoot
yourself in the foot.
Looking forward a little bit we need a better way to handle sysctls and
namespaces as our current technique will not work for the network namespace.
I think something based on the current overlapping sysctl trees will work but
the proc side needs to be redone before we can use it.
This patch:
Introduce get_uts() and put_uts() (used later) and remove most of the special
cases for when UTS namespace is compiled in.
