d_path() is used on a <dentry,vfsmount> pair. Lets use a struct path to
reflect this.
[akpm@linux-foundation.org: fix build in mm/memory.c]
Signed-off-by: Jan Blunck <jblunck@suse.de>
Acked-by: Bryan Wu <bryan.wu@analog.com>
Acked-by: Christoph Hellwig <hch@infradead.org>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Neil Brown <neilb@suse.de>
Cc: Michael Halcrow <mhalcrow@us.ibm.com>
audit_log_d_path() is a d_path() wrapper that is used by the audit code. To
use a struct path in audit_log_d_path() I need to embed it into struct
avc_audit_data.
Cc: Stephen Smalley <sds@tycho.nsa.gov>
* Use struct path in fs_struct.
Signed-off-by: Andreas Gruenbacher <agruen@suse.de>
Acked-by: Christoph Hellwig <hch@lst.de>
* Add path_put() functions for releasing a reference to the dentry and
vfsmount of a struct path in the right order
* Switch from path_release(nd) to path_put(&nd->path)
* Rename dput_path() to path_put_conditional()
[akpm@linux-foundation.org: fix cifs]
Cc: <linux-fsdevel@vger.kernel.org>
Cc: Steven French <sfrench@us.ibm.com>
This is the central patch of a cleanup series. In most cases there is no good
reason why someone would want to use a dentry for itself. This series reflects
that fact and embeds a struct path into nameidata.
Together with the other patches of this series
- it enforced the correct order of getting/releasing the reference count on
<dentry,vfsmount> pairs
- it prepares the VFS for stacking support since it is essential to have a
struct path in every place where the stack can be traversed
- it reduces the overall code size:
without patch series:
5321639 858418 715768 6895825 6938d1 vmlinux
with patch series:
5320026 858418 715768 6894212 693284 vmlinux
This patch:
Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere.
[akpm@linux-foundation.org: fix smack]
Cc: Casey Schaufler <casey@schaufler-ca.com>
This test seems to be unnecessary since we always have rootfs mounted before
calling a usermodehelper.
Acked-by: Greg KH <greg@kroah.com>
RCU style multiple probes support for the Linux Kernel Markers. Common case
(one probe) is still fast and does not require dynamic allocation or a
supplementary pointer dereference on the fast path.
- Move preempt disable from the marker site to the callback.
Since we now have an internal callback, move the preempt disable/enable to the
callback instead of the marker site.
Since the callback change is done asynchronously (passing from a handler that
supports arguments to a handler that does not setup the arguments is no
arguments are passed), we can safely update it even if it is outside the
preempt disable section.
- Move probe arm to probe connection. Now, a connected probe is automatically
armed.
Remove MARK_MAX_FORMAT_LEN, unused.
This patch modifies the Linux Kernel Markers API : it removes the probe
"arm/disarm" and changes the probe function prototype : it now expects a
va_list * instead of a "...".
If we want to have more than one probe connected to a marker at a given
time (LTTng, or blktrace, ssytemtap) then we need this patch. Without it,
connecting a second probe handler to a marker will fail.
It allow us, for instance, to do interesting combinations :
Do standard tracing with LTTng and, eventually, to compute statistics
with SystemTAP, or to have a special trigger on an event that would call
a systemtap script which would stop flight recorder tracing.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Mike Mason <mmlnx@us.ibm.com>
Cc: Dipankar Sarma <dipankar@in.ibm.com>
Cc: David Smith <dsmith@redhat.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
Cc: "Frank Ch. Eigler" <fche@redhat.com>
proc_doulongvec_minmax() calls copy_to_user()/copy_from_user(), so we can't
hold hugetlb_lock over the call. Use a dummy variable to store the sysctl
result, like in hugetlb_sysctl_handler(), then grab the lock to update
nr_overcommit_huge_pages.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Reported-by: Miles Lane <miles.lane@gmail.com>
Cc: Adam Litke <agl@us.ibm.com>
Cc: David Gibson <david@gibson.dropbear.id.au>
fastcall always expands to empty, remove it.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This comment caused some consternation during fastcall removal. Make it
truthful.
Cc: Harvey Harrison <harvey.harrison@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched:
sched: rt-group: refure unrunnable tasks
sched: rt-group: clean up the ifdeffery
sched: rt-group: make rt groups scheduling configurable
sched: rt-group: interface
sched: rt-group: deal with PI
sched: fix incorrect irq lock usage in normalize_rt_tasks()
sched: fair-group: separate tg->shares from task_group_lock
hrtimer: more hrtimer_init_sleeper() fallout.
Refuse to accept or create RT tasks in groups that can't run them.
Clean up some of the excessive ifdeffery introduces in the last patch.
Make the rt group scheduler compile time configurable.
Keep it experimental for now.
Change the rt_ratio interface to rt_runtime_us, to match rt_period_us.
This avoids picking a granularity for the ratio.
Extend the /sys/kernel/uids/<uid>/ interface to allow setting
the group's rt_runtime.
Steven mentioned the fun case where a lock holding task will be throttled.
Simple fix: allow groups that have boosted tasks to run anyway.
If a runnable task in a throttled group gets boosted the dequeue/enqueue
done by rt_mutex_setprio() is enough to unthrottle the group.
This is ofcourse not quite correct. Two possible ways forward are:
- second prio array for boosted tasks
- boost to a prio ceiling (this would also work for deadline scheduling)
lockdep spotted this bogus irq locking. normalize_rt_tasks() can be called
from hardirq context through sysrq-n
On Mon, 2008-02-11 at 15:09 +0300, Denis V. Lunev wrote:
> BUG: sleeping function called from invalid context
> at /home/den/src/linux-netns26/kernel/mutex.c:209
> in_atomic():1, irqs_disabled():0
> no locks held by swapper/0.
> Pid: 0, comm: swapper Not tainted 2.6.24 #304
> Call Trace:
> <IRQ> [<ffffffff80252d1e>] ? __debug_show_held_locks+0x15/0x27
> [<ffffffff8022c2a8>] __might_sleep+0xc0/0xdf
> [<ffffffff8049f1df>] mutex_lock_nested+0x28/0x2a9
> [<ffffffff80231294>] sched_destroy_group+0x18/0xea
> [<ffffffff8023e835>] sched_destroy_user+0xd/0xf
> [<ffffffff8023e8c1>] free_uid+0x8a/0xab
> [<ffffffff80233e24>] __put_task_struct+0x3f/0xd3
> [<ffffffff80236708>] delayed_put_task_struct+0x23/0x25
> [<ffffffff8026fda7>] __rcu_process_callbacks+0x8d/0x215
> [<ffffffff8026ff52>] rcu_process_callbacks+0x23/0x44
> [<ffffffff8023a2ae>] __do_softirq+0x79/0xf8
> [<ffffffff8020f8c3>] ? profile_pc+0x2a/0x67
> [<ffffffff8020d38c>] call_softirq+0x1c/0x30
> [<ffffffff8020f689>] do_softirq+0x61/0x9c
> [<ffffffff8023a233>] irq_exit+0x51/0x53
> [<ffffffff8021bd1a>] smp_apic_timer_interrupt+0x77/0xad
> [<ffffffff8020ce3b>] apic_timer_interrupt+0x6b/0x70
> <EOI> [<ffffffff8020b0dd>] ? default_idle+0x43/0x76
> [<ffffffff8020b0db>] ? default_idle+0x41/0x76
> [<ffffffff8020b09a>] ? default_idle+0x0/0x76
> [<ffffffff8020b186>] ? cpu_idle+0x76/0x98
separate the tg->shares protection from the task_group lock.
Reported-by: Denis V. Lunev <den@openvz.org>
Tested-by: Denis V. Lunev <den@openvz.org>
Missed an instance...
futex_lock_pi()
rt_mutex_timed_lock()
rt_mutex_timed_fastlock()
rt_mutex_slowlock()
hrtimer_start()
The USEC_TO_HZ and HZ_TO_USEC constant sets were mislabelled, with
seriously incorrect results. This among other things manifested
itself as cpufreq not working when a tickless kernel was configured.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Tested-by: Carlos R. Mafra <crmafra@ift.unesp.br>
hrtimer_nanosleep_restart() clears/restores restart_block->fn. This is
pointless and complicates its usage. Note that if sys_restart_syscall()
doesn't actually happen, we have a bogus "pending" restart->fn anyway,
this is harmless.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Alexey Dobriyan <adobriyan@sw.ru>
Cc: Pavel Emelyanov <xemul@sw.ru>
Cc: Toyo Abe <toyoa@mvista.com>
Spotted by Pavel Emelyanov and Alexey Dobriyan.
compat_sys_nanosleep() implicitly uses hrtimer_nanosleep_restart(), this can't
work. Make a suitable compat_nanosleep_restart() helper.
Introduced by commit c70878b4e0b6cf8d2f1e46319e48e821ef4a8aba
hrtimer: hook compat_sys_nanosleep up to high res timer code
Also, set ->addr_limit = KERNEL_DS before doing hrtimer_nanosleep(), this func
was changed by the previous patch and now takes the "__user *" parameter.
Thanks to Ingo Molnar for fixing the bug in this patch.
hrtimer_nanosleep() sets restart_block->arg1 = rmtp, but this rmtp points to
the local variable which lives in the caller's stack frame. This means that
if sys_restart_syscall() actually happens and it is interrupted as well, we
don't update the user-space variable, but write into the already dead stack
frame.
Introduced by commit 04c227140fed77587432667a574b14736a06dd7f
hrtimer: Rework hrtimer_nanosleep to make sys_compat_nanosleep easier
Change the callers to pass "__user *rmtp" to hrtimer_nanosleep(), and change
hrtimer_nanosleep() to use copy_to_user() to actually update *rmtp.
Small problem remains. man 2 nanosleep states that *rtmp should be written if
nanosleep() was interrupted (it says nothing whether it is OK to update *rmtp
if nanosleep returns 0), but (with or without this patch) we can dirty *rem
even if nanosleep() returns 0.
NOTE: this patch doesn't change compat_sys_nanosleep(), because it has other
bugs. Fixed by the next patch.
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
include/linux/hrtimer.h | 2 -
kernel/hrtimer.c | 51 +++++++++++++++++++++++++-----------------------
kernel/posix-timers.c | 14 +------------
3 files changed, 30 insertions(+), 37 deletions(-)
clocksource initialization and error accumulation. This corrects a 280ppm
drift seen on some systems using acpi_pm, and affects other clocksources as
well (likely to a lesser degree).
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Signed-off-by: S.Çağlar Onur <caglar@pardus.org.tr>
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'for-2.6.25' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
[POWERPC] Add arch-specific walk_memory_remove() for 64-bit powerpc
[POWERPC] Enable hotplug memory remove for 64-bit powerpc
[POWERPC] Add remove_memory() for 64-bit powerpc
[POWERPC] Make cell IOMMU fixed mapping printk more useful
[POWERPC] Fix potential cell IOMMU bug when switching back to default DMA ops
[POWERPC] Don't enable cell IOMMU fixed mapping if there are no dma-ranges
[POWERPC] Fix cell IOMMU null pointer explosion on old firmwares
[POWERPC] spufs: Fix timing dependent false return from spufs_run_spu
[POWERPC] spufs: No need to have a runnable SPU for libassist update
[POWERPC] spufs: Update SPU_Status[CISHP] in backing runcntl write
[POWERPC] spufs: Fix state_mutex leaks
[POWERPC] Disable G5 NAP mode during SMU commands on U3
Probing non-ISA interrupts using the handle_percpu_irq as their handle_irq
method may crash the system because handle_percpu_irq does not check
IRQ_WAITING. This for example hits the MIPS Qemu configuration.
This patch provides two helper functions set_irq_noprobe and set_irq_probe to
set rsp. clear the IRQ_NOPROBE flag. The only current caller is MIPS code
but this really belongs into generic code.
As an aside, interrupt probing these days has become a mostly obsolete if not
dangerous art. I think Linux interrupts should be changed to default to
non-probing but that's subject of this patch.
Acked-and-tested-by: Rob Landley <rob@landley.net>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Currently, for every sysfs node, the callers will be responsible for
implementing store operation, so many many callers are doing duplicate
things to validate input, they have the same mistakes because they are
calling simple_strtol/ul/ll/uul, especially for module params, they are
just numeric, but you can echo such values as 0x1234xxx, 07777888 and
1234aaa, for these cases, module params store operation just ignores
succesive invalid char and converts prefix part to a numeric although input
is acctually invalid.
This patch tries to fix the aforementioned issues and implements
strict_strtox serial functions, kernel/params.c uses them to strictly
validate input, so module params will reject such values as 0x1234xxxx and
returns an error:
write error: Invalid argument
Any modules which export numeric sysfs node can use strict_strtox instead of
simple_strtox to reject any invalid input.
Here are some test results:
Before applying this patch:
[root@yangyi-dev /]# cat /sys/module/e1000/parameters/copybreak
4096
[root@yangyi-dev /]# echo 0x1000 > /sys/module/e1000/parameters/copybreak
4096
[root@yangyi-dev /]# echo 0x1000g > /sys/module/e1000/parameters/copybreak
4096
[root@yangyi-dev /]# echo 0x1000gggggggg > /sys/module/e1000/parameters/copybreak
4096
[root@yangyi-dev /]# echo 010000 > /sys/module/e1000/parameters/copybreak
4096
[root@yangyi-dev /]# echo 0100008 > /sys/module/e1000/parameters/copybreak
4096
[root@yangyi-dev /]# echo 010000aaaaa > /sys/module/e1000/parameters/copybreak
4096
After applying this patch:
4096
4096
-bash: echo: write error: Invalid argument
4096
4096
[root@yangyi-dev /]# echo -n 4096 > /sys/module/e1000/parameters/copybreak
4096
[akpm@linux-foundation.org: fix compiler warnings]
[akpm@linux-foundation.org: fix off-by-one found by tiwai@suse.de]
Signed-off-by: Yi Yang <yi.y.yang@intel.com>
Cc: Greg KH <greg@kroah.com>
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Hugh Dickins <hugh@veritas.com>
Fix following warning:
WARNING: o-x86_64/kernel/built-in.o(.text+0x36d8b): Section mismatch in reference from the function enable_nonboot_cpus() to the function .cpuinit.text:_cpu_up()
enable_nonboot_cpus() are used solely from CONFIG_CONFIG_PM_SLEEP_SMP=y
and PM_SLEEP_SMP imply HOTPLUG_CPU therefore the reference
to _cpu_up() is valid.
Annotate enable_nonboot_cpus() with __ref to silence modpost.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Cc: Gautham R Shenoy <ego@in.ibm.com>
The proper behavior to store task's pid and get this task later is to get the
struct pid pointer and get the task with the pid_task() call.
Make it for rt_mutex_waiter->deadlock_task_pid field.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
All the functions that need to lookup a task by pid in posix timers obtain
this pid from a user space, and thus this value refers to a task in the same
namespace, as the current task lives in.
So the proper behavior is to call find_task_by_vpid() here.
When the conversion factor between jiffies and milli- or microseconds is
not a single multiply or divide, as for the case of HZ == 300, we currently
do a multiply followed by a divide. The intervening result, however, is
subject to overflows, especially since the fraction is not simplified (for
HZ == 300, we multiply by 300 and divide by 1000).
This is exposed to the user when passing a large timeout to poll(), for
example.
This patch replaces the multiply-divide with a reciprocal multiplication on
32-bit platforms. When the input is an unsigned long, there is no portable
way to do this on 64-bit platforms there is no portable way to do this
since it requires a 128-bit intermediate result (which gcc does support on
64-bit platforms but may generate libgcc calls, e.g. on 64-bit s390), but
since the output is a 32-bit integer in the cases affected, just simplify
the multiply-divide (*3/10 instead of *300/1000).
The reciprocal multiply used can have off-by-one errors in the upper half
of the valid output range. This could be avoided at the expense of having
to deal with a potential 65-bit intermediate result. Since the intent is
to avoid overflow problems and most of the other time conversions are only
semiexact, the off-by-one errors were considered an acceptable tradeoff.
At Ralf Baechle's suggestion, this version uses a Perl script to compute
the necessary constants. We already have dependencies on Perl for kernel
compiles. This does, however, require the Perl module Math::BigInt, which
is included in the standard Perl distribution starting with version 5.8.0.
In order to support older versions of Perl, include a table of canned
constants in the script itself, and structure the script so that
Math::BigInt isn't required if pulling values from said table.
Running the script requires that the HZ value is available from the
Makefile. Thus, this patch also adds the Kconfig variable CONFIG_HZ to the
architectures which didn't already have it (alpha, cris, frv, h8300, m32r,
m68k, m68knommu, sparc, v850, and xtensa.) It does *not* touch the sh or
sh64 architectures, since Paul Mundt has dealt with those separately in the
sh tree.
Cc: Ralf Baechle <ralf@linux-mips.org>,
Cc: Sam Ravnborg <sam@ravnborg.org>,
Cc: Paul Mundt <lethal@linux-sh.org>,
Cc: Richard Henderson <rth@twiddle.net>,
Cc: Michael Starvik <starvik@axis.com>,
Cc: David Howells <dhowells@redhat.com>,
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>,
Cc: Hirokazu Takata <takata@linux-m32r.org>,
Cc: Geert Uytterhoeven <geert@linux-m68k.org>,
Cc: Roman Zippel <zippel@linux-m68k.org>,
Cc: William L. Irwin <sparclinux@vger.kernel.org>,
Cc: Chris Zankel <chris@zankel.net>,
Cc: H. Peter Anvin <hpa@zytor.com>,
Cc: Jan Engelhardt <jengelh@computergmbh.de>
Makes an embedded image a bit smaller.
delayed_work_timer_fn() is a timer function, make it static.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
The scheduled removal of the 'time' option.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Don't include linux/security.h twice in kernel/sysctl.c
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Remove duplicate inclusion of linux/profile.h from kernel/profile.c
Remove the duplicate inclusion of linux/jiffies.h from kernel/printk.c
Remains the question whether it is intended that many, perhaps even large,
tables are compiled in without ever having a chance to get used, i.e.
whether there shouldn't #ifdef CONFIG_xxx get added.
[akpm@linux-foundation.org: fix cut-n-paste error]
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
Fix typo in comments.
BTW: I have to fix coding style in arch/ia64/kernel/time.c also, otherwise
checkpatch.pl will be complaining.
Cc: john stultz <johnstul@us.ibm.com>
Function timekeeping_is_continuous() no longer checks flag
CLOCK_IS_CONTINUOUS, and it checks CLOCK_SOURCE_VALID_FOR_HRES now. So rename
the function accordingly.
list_for_each_safe() suffices here.
Flag CLOCK_SOURCE_WATCHDOG is cleared twice. Note clocksource_change_rating()
won't do anyting with the cs flag.
There's only one caller left - the kill_pgrp one - so merge these two
functions and forget the kill_pgrp_info one.
Reviewed-by: Oleg Nesterov <oleg@tv-sign.ru>
This is the first step (of two) in removing the kill_pgrp_info.
All the users of this function are in kernel/signal.c, but all they need is to
call __kill_pgrp_info() with the tasklist_lock read-locked.
Fortunately, one of its users is the kill_something_info(), which already
needs this lock in one of its branches, so clean these branches up and call
the __kill_pgrp_info() directly.
Based on Oleg's view of how this function should look.
Some time ago the xxx_vnr() calls (e.g. pid_vnr or find_task_by_vpid) were
_all_ converted to operate on the current pid namespace. After this each call
like xxx_nr_ns(foo, current->nsproxy->pid_ns) is nothing but a xxx_vnr(foo)
one.
Switch all the xxx_nr_ns() callers to use the xxx_vnr() calls where
appropriate.
Cc: Balbir Singh <balbir@in.ibm.com>
signal_struct->tsk points to the ->group_leader and thus we have the nasty
code in de_thread() which has to change it and restart ->real_timer if the
leader is changed.
Use "struct pid *leader_pid" instead. This also allows us to kill now
unneeded send_group_sig_info().
Cc: Davide Libenzi <davidel@xmailserver.org>
Cc: Pavel Emelyanov <xemul@openvz.org>
Acked-by: Roland McGrath <roland@redhat.com>
kill_pid_info()->pid_task() could be the old leader of the execing process.
In that case it is possible that the leader will be released before we take
siglock. This means that kill_pid_info() (and thus sys_kill()) can return a
false -ESRCH.
Change the code to retry when lock_task_sighand() fails. The endless loop is
not possible, __exit_signal() both clears ->sighand and does detach_pid().
Cc: Roland McGrath <roland@redhat.com>
With the new semantics of find_vpid() we don't need to play with ->nsproxy
explicitely, _vxx() do the right things.
Also s/tasklist/rcu/.
