path: root/kernel
2009-01-14[CVE-2009-0029] System call wrappers part 09Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 08Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 07Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 06Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 05Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 04Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 03Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 02Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 01Heiko Carstens
2009-01-14[CVE-2009-0029] Make sys_syslog a conditional system callHeiko Carstens
Remove the -ENOSYS implementation for !CONFIG_PRINTK and use the cond_syscall infrastructure instead. Acked-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-14[CVE-2009-0029] Convert all system calls to return a longHeiko Carstens
Convert all system calls to return a long. This should be a NOP since all converted types should have the same size anyway. With the exception of sys_exit_group which returned void. But that doesn't matter since the system call doesn't return. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-13Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: smp_call_function_single(): be slightly less stupid, fix #2 lockdep, mm: fix might_fault() annotation
2009-01-12async: fix __lowest_in_progress()Arjan van de Ven
At 37000 feet somewhere near Greenland I woke up from a half-sleep with the realisation that __lowest_in_progress() is buggy. After landing I checked and there were indeed 2 problems with it; this patch fixes both: * The order of the list checks was wrong * The locking was not correct. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-12Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: kernel/sched.c: add missing forward declaration for 'double_rq_lock' sched: partly revert "sched debug: remove NULL checking in print_cfs_rt_rq()" cpumask: fix CONFIG_NUMA=y sched.c
2009-01-12smp_call_function_single(): be slightly less stupid, fix #2Ingo Molnar
fix m68k build failure: tip/kernel/up.c: In function 'smp_call_function_single': tip/kernel/up.c:16: error: dereferencing pointer to incomplete type make[2]: *** [kernel/up.o] Error 1 Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-11kernel/sched.c: add missing forward declaration for 'double_rq_lock'Steven Noonan
Impact: build fix on certain configs Added 'double_rq_lock' forward declaration, allowing double_rq_lock to be used in _double_lock_balance(). Signed-off-by: Steven Noonan <steven@uplinklabs.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-11smp_call_function_single(): be slightly less stupid, fixIngo Molnar
Impact: build fix on Alpha kernel/up.c: In function 'smp_call_function_single': kernel/up.c:12: error: 'cpuid' undeclared (first use in this function) kernel/up.c:12: error: (Each undeclared identifier is reported only once kernel/up.c:12: error: for each function it appears in.) The typo didnt show up on x86 because 'cpuid' happens to be a function address as well ... Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-11smp_call_function_single(): be slightly less stupidAndrew Morton
If you do smp_call_function_single(expression-with-side-effects, ...) then expression-with-side-effects never gets evaluated on UP builds. As always, implementing it in C is the correct thing to do. While we're there, uninline it for size and possible header dependency reasons. And create a new kernel/up.c, as a place in which to put uniprocessor-specific code and storage. It should mirror kernel/smp.c. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-11Merge commit 'v2.6.29-rc1' into core/urgentIngo Molnar
2009-01-11sched: partly revert "sched debug: remove NULL checking in print_cfs_rt_rq()"Li Zefan
Impact: avoid accessing NULL tg.css->cgroup In commit 0a0db8f5c9d4bbb9bbfcc2b6cb6bce2d0ef4d73d, I removed checking NULL tg.css->cgroup, but I realized I was wrong when I found reading /proc/sched_debug can race with cgroup_create(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-11cpumask: fix CONFIG_NUMA=y sched.cRusty Russell
Impact: fix panic on ia64 with NR_CPUS=1024 struct sched_domain is now a dangling structure; where we really want static ones, we need to use static_sched_domain. (As the FIXME in this file says, cpumask_var_t would be better, but this code is hairy enough without trying to add initialization code to the right places). Reported-by: Mike Travis <travis@sgi.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/arjan/linux-2.6-async-2Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/arjan/linux-2.6-async-2: async: make async a command line option for now partial revert of asynchronous inode delete
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommuLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-nommu: NOMMU: Support XIP on initramfs NOMMU: Teach kobjsize() about VMA regions. FLAT: Don't attempt to expand the userspace stack to fill the space allocated FDPIC: Don't attempt to expand the userspace stack to fill the space allocated NOMMU: Improve procfs output using per-MM VMAs NOMMU: Make mmap allocation page trimming behaviour configurable. NOMMU: Make VMAs per MM as for MMU-mode linux NOMMU: Delete askedalloc and realalloc variables NOMMU: Rename ARM's struct vm_region NOMMU: Fix cleanup handling in ramfs_nommu_get_umapped_area()
2009-01-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: CRED: Fix commit_creds() on a process that has no mm
2009-01-09async: make async a command line option for nowArjan van de Ven
... and have it default off. This does allow people to work with it for testing. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile: (31 commits) powerpc/oprofile: fix whitespaces in op_model_cell.c powerpc/oprofile: IBM CELL: add SPU event profiling support powerpc/oprofile: fix cell/pr_util.h powerpc/oprofile: IBM CELL: cleanup and restructuring oprofile: make new cpu buffer functions part of the api oprofile: remove #ifdef CONFIG_OPROFILE_IBS in non-ibs code ring_buffer: fix ring_buffer_event_length() oprofile: use new data sample format for ibs oprofile: add op_cpu_buffer_get_data() oprofile: add op_cpu_buffer_add_data() oprofile: rework implementation of cpu buffer events oprofile: modify op_cpu_buffer_read_entry() oprofile: add op_cpu_buffer_write_reserve() oprofile: rename variables in add_ibs_begin() oprofile: rename add_sample() in cpu_buffer.c oprofile: rename variable ibs_allowed to has_ibs in op_model_amd.c oprofile: making add_sample_entry() inline oprofile: remove backtrace code for ibs oprofile: remove unused ibs macro oprofile: remove unused components in struct oprofile_cpu_buffer ...
2009-01-09Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (94 commits) ACPICA: hide private headers ACPICA: create acpica/ directory ACPI: fix build warning ACPI : Use RSDT instead of XSDT by adding boot option of "acpi=rsdt" ACPI: Avoid array address overflow when _CST MWAIT hint bits are set fujitsu-laptop: Simplify SBLL/SBL2 backlight handling fujitsu-laptop: Add BL power, LED control and radio state information ACPICA: delete utcache.c ACPICA: delete acdisasm.h ACPICA: Update version to 20081204. ACPICA: FADT: Update error msgs for consistency ACPICA: FADT: set acpi_gbl_use_default_register_widths to TRUE by default ACPICA: FADT parsing changes and fixes ACPICA: Add ACPI_MUTEX_TYPE configuration option ACPICA: Fixes for various ACPI data tables ACPICA: Restructure includes into public/private ACPI: remove private acpica headers from driver files ACPI: reboot.c: use new acpi_reset interface ACPICA: New: acpi_reset interface - write to reset register ACPICA: Move all public H/W interfaces to new hwxface ...
2009-01-09CRED: Must initialise the new creds in prepare_kernel_cred()David Howells
The newly allocated creds in prepare_kernel_cred() must be initialised before get_uid() and get_group_info() can access them. They should be copied from the old credentials. Reported-by: Steve Dickson <steved@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-09CRED: Missing put_cred() in prepare_kernel_cred()David Howells
Missing put_cred() in the error handling path of prepare_kernel_cred(). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-09Merge branch 'linus' into releaseLen Brown
2009-01-09Merge branch 'suspend' into releaseLen Brown
2009-01-08async: make async_synchronize_full() more serializingArjan van de Ven
turns out that there are real problems with allowing async tasks that are scheduled from async tasks to run after the async_synchronize_full() returns. This patch makes the _full more strict and a complete synchronization. Later I might need to add back a lighter form of synchronization for other uses.. but not right now. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08generic swap(): sched: remove local swap() macroWu Fengguang
Use the new generic implementation. Signed-off-by: Wu Fengguang <wfg@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08pid: generalize task_active_pid_nsEric W. Biederman
Currently task_active_pid_ns is not safe to call after a task becomes a zombie and exit_task_namespaces is called, as nsproxy becomes NULL. By reading the pid namespace from the pid of the task we can trivially solve this problem at the cost of one extra memory read in what should be the same cacheline as we read the namespace from. When moving things around I have made task_active_pid_ns out of line because keeping it in pid_namespace.h would require adding includes of pid.h and sched.h that I don't think we want. This change does make task_active_pid_ns unsafe to call during copy_process until we attach a pid on the task_struct which seems to be a reasonable trade off. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Bastian Blank <bastian@waldi.eu.org> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Nadia Derbey <Nadia.Derbey@bull.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cpuset: remove remaining pointers to cpumask_tLi Zefan
Impact: cleanups, use new cpumask API Final trivial cleanups: mainly s/cpumask_t/struct cpumask Note there is a FIXME in generate_sched_domains(). A future patch will change struct cpumask *doms to struct cpumask *doms[]. (I suppose Rusty will do this.) Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Mike Travis <travis@sgi.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cpuset: convert cpuset->cpus_allowed to cpumask_var_tLi Zefan
Impact: use new cpumask API This patch mainly does the following things: - change cs->cpus_allowed from cpumask_t to cpumask_var_t - call alloc_bootmem_cpumask_var() for top_cpuset in cpuset_init_early() - call alloc_cpumask_var() for other cpusets - replace cpus_xxx() to cpumask_xxx() Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Mike Travis <travis@sgi.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cpuset: don't allocate trial cpuset on stackLi Zefan
Impact: cleanups, reduce stack usage This patch prepares for the next patch. When we convert cpuset.cpus_allowed to cpumask_var_t, (trialcs = *cs) no longer works. Another result of this patch is reducing stack usage of trialcs. sizeof(*cs) can be as large as 148 bytes on x86_64, so it's really not good to have it on stack. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Mike Travis <travis@sgi.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cpuset: convert cpuset_attach() to use cpumask_var_tLi Zefan
Impact: reduce stack usage Allocate a global cpumask_var_t at boot, and use it in cpuset_attach(), so we won't fail cpuset_attach(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Mike Travis <travis@sgi.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cpuset: remove on stack cpumask_t in cpuset_can_attach()Li Zefan
Impact: reduce stack usage Just use cs->cpus_allowed, and no need to allocate a cpumask_var_t. Signed-off-by: Li Zefan <lizf@cn.fujistu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Mike Travis <travis@sgi.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cpuset: remove on stack cpumask_t in cpuset_sprintf_cpulist()Li Zefan
This patchset converts cpuset to use new cpumask API, and thus remove on stack cpumask_t to reduce stack usage. Before: # cat kernel/cpuset.c include/linux/cpuset.h | grep -c cpumask_t 21 After: # cat kernel/cpuset.c include/linux/cpuset.h | grep -c cpumask_t 0 This patch: Impact: reduce stack usage It's safe to call cpulist_scnprintf inside callback_mutex, and thus we can just remove the cpumask_t and no need to allocate a cpumask_var_t. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Mike Travis <travis@sgi.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cpusets: set task's cpu_allowed to cpu_possible_map when attaching it into ↵Miao Xie
top cpuset I found a bug on my dual-cpu box. I created a sub cpuset in top cpuset and assign 1 to its cpus. And then we attach some tasks into this sub cpuset. After this, we offline CPU1. Now, the tasks in this new cpuset are moved into top cpuset automatically because there is no cpu in sub cpuset. Then we online CPU1, we find all the tasks which doesn't belong to top cpuset originally just run on CPU0. We fix this bug by setting task's cpu_allowed to cpu_possible_map when attaching it into top cpuset. This method needn't modify the current behavior of cpusets on CPU hotplug, and all of tasks in top cpuset use cpu_possible_map to initialize their cpu_allowed. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cpuset: rcu_read_lock() to protect task_cs()Lai Jiangshan
task_cs() calls task_subsys_state(). We must use rcu_read_lock() to protect cgroup_subsys_state(). It's correct that top_cpuset is never freed, but cgroup_subsys_state() accesses css_set, this css_set maybe freed when task_cs() called. We use use rcu_read_lock() to protect it. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: add css_tryget()Paul Menage
Add css_tryget(), that obtains a counted reference on a CSS. It is used in situations where the caller has a "weak" reference to the CSS, i.e. one that does not protect the cgroup from removal via a reference count, but would instead be cleaned up by a destroy() callback. css_tryget() will return true on success, or false if the cgroup is being removed. This is similar to Kamezawa Hiroyuki's patch from a week or two ago, but with the difference that in the event of css_tryget() racing with a cgroup_rmdir(), css_tryget() will only return false if the cgroup really does get removed. This implementation is done by biasing css->refcnt, so that a refcnt of 1 means "releasable" and 0 means "released or releasing". In the event of a race, css_tryget() distinguishes between "released" and "releasing" by checking for the CSS_REMOVED flag in css->flags. Signed-off-by: Paul Menage <menage@google.com> Tested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: add a per-subsystem hierarchy_mutexPaul Menage
These patches introduce new locking/refcount support for cgroups to reduce the need for subsystems to call cgroup_lock(). This will ultimately allow the atomicity of cgroup_rmdir() (which was removed recently) to be restored. These three patches give: 1/3 - introduce a per-subsystem hierarchy_mutex which a subsystem can use to prevent changes to its own cgroup tree 2/3 - use hierarchy_mutex in place of calling cgroup_lock() in the memory controller 3/3 - introduce a css_tryget() function similar to the one recently proposed by Kamezawa, but avoiding spurious refcount failures in the event of a race between a css_tryget() and an unsuccessful cgroup_rmdir() Future patches will likely involve: - using hierarchy mutex in place of cgroup_lock() in more subsystems where appropriate - restoring the atomicity of cgroup_rmdir() with respect to cgroup_create() This patch: Add a hierarchy_mutex to the cgroup_subsys object that protects changes to the hierarchy observed by that subsystem. It is taken by the cgroup subsystem (in addition to cgroup_mutex) for the following operations: - linking a cgroup into that subsystem's cgroup tree - unlinking a cgroup from that subsystem's cgroup tree - moving the subsystem to/from a hierarchy (including across the bind() callback) Thus if the subsystem holds its own hierarchy_mutex, it can safely traverse its own hierarchy. Signed-off-by: Paul Menage <menage@google.com> Tested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08memcg: memory cgroup resource counters for hierarchyBalbir Singh
Add support for building hierarchies in resource counters. Cgroups allows us to build a deep hierarchy, but we currently don't link the resource counters belonging to the memory controller control groups, in the same fashion as the corresponding cgroup entries in the cgroup hierarchy. This patch provides the infrastructure for resource counters that have the same hiearchy as their cgroup counter parts. These set of patches are based on the resource counter hiearchy patches posted by Pavel Emelianov. NOTE: Building hiearchies is expensive, deeper hierarchies imply charging the all the way up to the root. It is known that hiearchies are expensive, so the user needs to be careful and aware of the trade-offs before creating very deep ones. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: make cgroup_path() RCU-safePaul Menage
Fix races between /proc/sched_debug by freeing cgroup objects via an RCU callback. Thus any cgroup reference obtained from an RCU-safe source will remain valid during the RCU section. Since dentries are also RCU-safe, this allows us to traverse up the tree safely. Additionally, make cgroup_path() check for a NULL cgrp->dentry to avoid trying to report a path for a partially-created cgroup. [lizf@cn.fujitsu.com: call deactive_super() in cgroup_diput()] Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Tested-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: skip processes from other namespaces when listing a cgroupGowrishankar M
Once tasks are populated from system namespace inside cgroup, container replaces other namespace task with 0 while listing tasks, inside container. Though this is expected behaviour from container end, there is no use of showing unwanted 0s. In this patch, we check if a process is in same namespace before loading into pid array. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Gowrishankar M <gowrishankar.m@in.ibm.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: introduce link_css_set() to remove duplicate codeLi Zefan
Add a common function link_css_set() to link a css_set to a cgroup. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: add inactive subsystems to rootnode.subsys_listLi Zefan
Though for an inactive hierarchy, we have subsys->root == &rootnode, but rootnode's subsys_list is always empty. This conflicts with the code in find_css_set(): for (i = 0; i < CGROUP_SUBSYS_COUNT; i++) { ... if (ss->root->subsys_list.next == &ss->sibling) { ... } } if (list_empty(&rootnode.subsys_list)) { ... } The above code assumes rootnode.subsys_list links all inactive hierarchies. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08cgroups: make root_list contains active hierarchies onlyLi Zefan
Don't link rootnode to the root list, so root_list contains active hierarchies only as the comment indicates. And rename for_each_root() to for_each_active_root(). Also remove redundant check in cgroup_kill_sb(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
