path: root/kernel
2008-01-24fix struct user_info export's sysfs interactionKay Sievers
Clean up the use of ksets and kobjects. Kobjects are instances of objects (like struct user_info), ksets are collections of objects of a similar type (like the uids directory containing the user_info directories). So, use kobjects for the user_info directories, and a kset for the "uids" directory. On object cleanup, the final kobject_put() was missing. Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Driver Core: switch all dynamic ksets to kobj_sysfs_opsKay Sievers
Switch all dynamically created ksets, that export simple attributes, to kobj_attribute from subsys_attribute. Struct subsys_attribute will be removed. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Mike Halcrow <mhalcrow@us.ibm.com> Cc: Phillip Hellewell <phillip@hellewell.homeip.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert /sys/power to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. We also rename power_subsys to power_kset to catch all users of the variable and we properly export it so that people don't have to guess that it really is present in the system. The pseries code is wierd, why is it createing /sys/power if CONFIG_PM is disabled? Oh well, stupid big boxes ignoring config options... Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert /sys/module to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. We also rename module_subsys to module_kset to catch all users of the variable. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert kernel_subsys to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. We also rename kernel_subsys to kernel_kset to catch all users of this symbol with a build error instead of an easy-to-ignore build warning. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: get rid of kobject_add_dirGreg Kroah-Hartman
kobject_create_and_add is the same as kobject_add_dir, so drop kobject_add_dir. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: remove struct kobj_type from struct ksetGreg Kroah-Hartman
We don't need a "default" ktype for a kset. We should set this explicitly every time for each kset. This change is needed so that we can make ksets dynamic, and cleans up one of the odd, undocumented assumption that the kset/kobject/ktype model has. This patch is based on a lot of help from Kay Sievers. Nasty bug in the block code was found by Dave Young <hidave.darkstar@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24lockdep: fix kernel crash on module unloadArjan van de Ven
Michael Wu noticed in his lkml post at http://marc.info/?l=linux-kernel&m=119396182726091&w=2 that certain wireless drivers ended up having their name in module memory, which would then crash the kernel on module unload. The patch he proposed was a bit clumsy in that it increased the size of a lockdep entry significantly; the patch below tries another approach, it checks, on module teardown, if the name of a class is in module space and then zaps the class. This is very similar to what we already do with keys that are in module space. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-schedLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched: sched: group scheduler, set uid share fix
2008-01-22rcu: fix section mismatchRandy Dunlap
rcu_online_cpu() should be __cpuinit instead of __devinit. WARNING: vmlinux.o(.text+0x4b6d5): Section mismatch: reference to .init.text: (between 'rcu_cpu_notify' and 'wakeme_after_rcu') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-22sched: group scheduler, set uid share fixIngo Molnar
setting cpu share to 1 causes hangs, as reported in: http://bugzilla.kernel.org/show_bug.cgi?id=9779 as the default share is 1024, the values of 0 and 1 can indeed cause problems. Limit it to 2 or higher values. These values can only be set by the root user - but still it makes sense to protect against nonsensical values. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-21timer: fix section mismatchRandy Dunlap
The caller is __cpuinit. Also, this code block and its caller are inside #ifdef CONFIG_HOTPLUG_CPU blocks, so this code should reflect that config symbol's usage. WARNING: vmlinux.o(.text+0x4252f): Section mismatch: reference to .init.text: (between 'timer_cpu_notify' and 'msleep') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@akpm@linux-foundation.org>
2008-01-21hrtimer: fix section mismatchRandy Dunlap
Fix section mismatch in hrtimer.c: WARNING: vmlinux.o(.text+0x50c61): Section mismatch: reference to .init.text: (between 'hrtimer_cpu_notify' and 'down_read_trylock') Noticed by Johannes Berg and confirmed by Sam Ravnborg. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@akpm@linux-foundation.org>
2008-01-17Fix unbalanced helper_lock in kernel/kmod.cNigel Cunningham
call_usermodehelper_exec() has an exit path that can leave the helper_lock() call at the top of the routine unbalanced. The attached patch fixes this issue. Signed-off-by: Nigel Cunningham <nigel@tuxonice.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-16lockdep: fix workqueue creation API lockdep interactionJohannes Berg
Dave Young reported warnings from lockdep that the workqueue API can sometimes try to register lockdep classes with the same key but different names. This is not permitted in lockdep. Unfortunately, I was unaware of that restriction when I wrote the code to debug workqueue problems with lockdep and used the workqueue name as the lockdep class name. This can obviously lead to the problem if the workqueue name is dynamic. This patch solves the problem by always using a constant name for the workqueue's lockdep class, namely either the constant name that was passed in or a string consisting of the variable name. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
2008-01-16lockdep: fix internal double unlock during self-testNick Piggin
Lockdep, during self-test (when it was simulating double unlocks) was sometimes unconditionally unlocking a spinlock when it had not been locked. This won't work for ticket locks. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
2008-01-14modules: de-mutex more symbol lookup paths in the module codeRusty Russell
Kyle McMartin reports sysrq_timer_list_show() can hit the module mutex from hard interrupt context. These paths don't need to though, since we long ago changed all the module list manipulation to occur via stop_machine(). Disabling preemption is enough. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu> Cc: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-13Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: pnpacpi: print resource shortage message only once PM: ACPI and APM must not be enabled at the same time ACPI: apply quirk_ich6_lpc_acpi to more ICH8 and ICH9 ACPICA: fix acpi_serialize hang regression ACPI : Not register gsi for PCI IDE controller in legacy mode ACPI: Reintroduce run time configurable max_cstate for !CPU_IDLE case ACPI: Make sysfs interface in ACPI power optional. ACPI: EC: Enable boot EC before bus_scan increase PNP_MAX_PORT to 40 from 24
2008-01-13remove task_ppid_nr_nsRoland McGrath
task_ppid_nr_ns is called in three places. One of these should never have called it. In the other two, using it broke the existing semantics. This was presumably accidental. If the function had not been there, it would have been much more obvious to the eye that those patches were changing the behavior. We don't need this function. In task_state, the pid of the ptracer is not the ppid of the ptracer. In do_task_stat, ppid is the tgid of the real_parent, not its pid. I also moved the call outside of lock_task_sighand, since it doesn't need it. In sys_getppid, ppid is the tgid of the real_parent, not its pid. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-11Pull bugzilla-9194 into release branchLen Brown
2008-01-11PM: ACPI and APM must not be enabled at the same timeLen Brown
ACPI and APM used "pm_active" to guarantee that they would not be simultaneously active. But pm_active was recently moved under CONFIG_PM_LEGACY, so that without CONFIG_PM_LEGACY, pm_active became a NOP -- allowing ACPI and APM to both be simultaneously enabled. This caused unpredictable results, including boot hangs. Further, the code under CONFIG_PM_LEGACY is scheduled for removal. So replace pm_active with pm_flags. pm_flags depends only on CONFIG_PM, which is present for both CONFIG_APM and CONFIG_ACPI. http://bugzilla.kernel.org/show_bug.cgi?id=9194 Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2008-01-09show_task: real_parentRoland McGrath
The show_task function invoked by sysrq-t et al displays the pid and parent's pid of each task. It seems more useful to show the actual process hierarchy here than who is using ptrace on each process. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-08futex: Prevent stale futex owner when interrupted/timeoutThomas Gleixner
Roland Westrelin did a great analysis of a long standing thinko in the return path of futex_lock_pi. While we fixed the lock steal case long ago, which was easy to trigger, we never had a test case which exposed this problem and stupidly never thought about the reverse lock stealing scenario and the return to user space with a stale state. When a blocked tasks returns from rt_mutex_timed_locked without holding the rt_mutex (due to a signal or timeout) and at the same time the task holding the futex is releasing the futex and assigning the ownership of the futex to the returning task, then it might happen that a third task acquires the rt_mutex before the final rt_mutex_trylock() of the returning task happens under the futex hash bucket lock. The returning task returns to user space with ETIMEOUT or EINTR, but the user space futex value is assigned to this task. The task which acquired the rt_mutex fixes the user space futex value right after the hash bucket lock has been released by the returning task, but for a short period of time the user space value is wrong. Detailed description is available at: https://bugzilla.redhat.com/show_bug.cgi?id=400541 The fix for this is the same as we do when the rt_mutex was acquired by a higher priority task via lock stealing from the designated new owner. In that case we already fix the user space value and the internal pi_state up before we return. This mechanism can be used to fixup the above corner case as well. When the returning task, which failed to acquire the rt_mutex, notices that it is the designated owner of the futex, then it fixes up the stale user space value and the pi_state, before returning to user space. This happens with the futex hash bucket lock held, so the task which acquired the rt_mutex is guaranteed to be blocked on the hash bucket lock. We can access the rt_mutex owner, which gives us the pid of the new owner, safely here as the owner is not able to modify (release) it while waiting on the hash bucket lock. Rename the "curr" argument of fixup_pi_state_owner() to "newowner" to avoid confusion with current and add the check for the stale state into the failure path of rt_mutex_trylock() in the return path of unlock_futex_pi(). If the situation is detected use fixup_pi_state_owner() to assign everything to the owner of the rt_mutex. Pointed-out-and-tested-by: Roland Westrelin <roland.westrelin@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-08vmcoreinfo: add the array length of "free_list" for filtering free pagesKen'ichi Ohmichi
This patch adds the array length of "free_area.free_list" to the vmcoreinfo data so that makedumpfile (dump filtering command) can exclude all free pages in linux-2.6.24. makedumpfile creates a small dumpfile by excluding unnecessary pages for the analysis. To distinguish unnecessary pages, makedumpfile gets the vmcoreinfo data which has the minimum debugging information only for dump filtering. In 2.6.24-rc1 or later, the free_area.free_list is an array which has one list for each migrate types instead of a single list. makedumpfile needs the array length of "free_area.free_list" and the vmcoreinfo data should contain it. Signed-off-by: Huang Ying <ying.huang@intel.com> Tested-by: Ken'ichi Ohmichi <oomichi@mxs.nes.nec.co.jp> Acked-by: Simon Horman <horms@verge.net.au> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-07acct: real_parent ppidRoland McGrath
The ac_ppid field reported in process accounting records should match what getppid() would have returned to that process, regardless of whether a debugger is attached. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-schedLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched: sched: fix gcc warnings
2008-01-02Fix kernel/ptrace.c compile problem (missing "may_attach()")Linus Torvalds
The previous commit missed one use of "may_attach()" that had been renamed to __ptrace_may_attach(). Tssk, tssk, Al. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-02restrict reading from /proc/<pid>/maps to those who share ->mm or can ptrace pidAl Viro
Contents of /proc/*/maps is sensitive and may become sensitive after open() (e.g. if target originally shares our ->mm and later does exec on suid-root binary). Check at read() (actually, ->start() of iterator) time that mm_struct we'd grabbed and locked is - still the ->mm of target - equal to reader's ->mm or the target is ptracable by reader. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-30sched: fix gcc warningsIngo Molnar
Meelis Roos reported these warnings on sparc64: CC kernel/sched.o In file included from kernel/sched.c:879: kernel/sched_debug.c: In function 'nsec_high': kernel/sched_debug.c:38: warning: comparison of distinct pointer types lacks a cast the debug check in do_div() is over-eager here, because the long long is always positive in these places. Mark this by casting them to unsigned long long. no change in code output: text data bss dec hex filename 51471 6582 376 58429 e43d sched.o.before 51471 6582 376 58429 e43d sched.o.after md5: 7f7729c111f185bf3ccea4d542abc049 sched.o.before.asm 7f7729c111f185bf3ccea4d542abc049 sched.o.after.asm Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-12-29[SERIAL]: Fix section mismatches in Sun serial console drivers.David S. Miller
We're exporting an __init function, oops :-) The core issue here is that add_preferred_console() is marked as __init, this makes it impossible to invoke this thing from a driver probe routine which is what the Sparc serial drivers need to do. There is no harm in dropping the __init marker. This code will actually work properly when invoked from a modular driver, except that init will probably not pick up the console change without some other support code. Then we can drop the __init from sunserial_console_match() and we're no longer exporting an __init function to modules. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-22Modules: fix memory leak of module namesGreg Kroah-Hartman
Due to the change in kobject name handling, the module kobject needs to have a null release function to ensure that the name it previously set will be properly cleaned up. All of this wierdness goes away in 2.6.25 with the rework of the kobject name and cleanup logic, but this is required for 2.6.24. Thanks to Alexey Dobriyan for finding the problem, and to Kay Sievers for pointing out the simple way to fix it after I tried many complex ways. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-12-20debug: add end-of-oops markerArjan van de Ven
Right now it's nearly impossible for parsers that collect kernel crashes from logs or emails (such as www.kerneloops.org) to detect the end-of-oops condition. In addition, it's not currently possible to detect whether or not 2 oopses that look alike are actually the same oops reported twice, or are truly two unique oopses. This patch adds an end-of-oops marker, and makes the end marker include a very simple 64-bit random ID to be able to detect duplicate reports. Normally, this ID is calculated as a late_initcall() (in the hope that at that time there is enough entropy to get a unique enough ID); however for early oopses the oops_exit() function needs to generate the ID on the fly. We do this all at the _end_ of an oops printout, so this does not impact our ability to get the most important portions of a crash out to the console first. [ Sidenote: the already existing oopses-since-bootup counter we print during crashes serves as the differentiator between multiple oopses that trigger during the same bootup. ] Tested on 32-bit and 64-bit x86. Artificially injected very early crashes as well, as expected they result in this constant ID after multiple bootups: ---[ end trace ca143223eefdc828 ]--- ---[ end trace ca143223eefdc828 ]--- because the random pools are still all zero. But it all still works fine and causes no additional problems (which is the main goal of instrumentation code). Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-12-20sched: rt: account the cpu time during the tickPeter Zijlstra
Realtime tasks would not account their runtime during ticks. Which would lead to: struct sched_param param = { .sched_priority = 10 }; pthread_setschedparam(pthread_self(), SCHED_FIFO, &param); while (1) ; Not showing up in top. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-12-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: x86: fix "Kernel panic - not syncing: IO-APIC + timer doesn't work!" genirq: revert lazy irq disable for simple irqs x86: also define AT_VECTOR_SIZE_ARCH x86: kprobes bugfix x86: jprobe bugfix timer: kernel/timer.c section fixes genirq: add unlocked version of set_irq_handler() clockevents: fix reprogramming decision in oneshot broadcast oprofile: op_model_athlon.c support for AMD family 10h barcelona performance counters
2007-12-18genirq: revert lazy irq disable for simple irqsSteven Rostedt
In commit 76d2160147f43f982dfe881404cfde9fd0a9da21 lazy irq disabling was implemented, and the simple irq handler had a masking set to it. Remy Bohmer discovered that some devices in the ARM architecture would trigger the mask, but never unmask it. His patch to do the unmasking was questioned by Russell King about masking simple irqs to begin with. Looking further, it was discovered that the problems Remy was seeing was due to improper use of the simple handler by devices, and he later submitted patches to fix those. But the issue that was uncovered was that the simple handler should never mask. This patch reverts the masking in the simple handler. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-12-18timer: kernel/timer.c section fixesAdrian Bunk
This patch fixes the following section mismatches with CONFIG_HOTPLUG=n, CONFIG_HOTPLUG_CPU=y: ... WARNING: vmlinux.o(.text+0x41cd3): Section mismatch: reference to .init.data:tvec_base_done.22610 (between 'timer_cpu_notify' and 'run_timer_softirq') WARNING: vmlinux.o(.text+0x41d67): Section mismatch: reference to .init.data:tvec_base_done.22610 (between 'timer_cpu_notify' and 'run_timer_softirq') ... Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-12-18clockevents: fix reprogramming decision in oneshot broadcastThomas Gleixner
Resolve the following regression of a choppy, almost unusable laptop: http://lkml.org/lkml/2007/12/7/299 http://bugzilla.kernel.org/show_bug.cgi?id=9525 A previous version of the code did the reprogramming of the broadcast device in the return from idle code. This was removed, but the logic in tick_handle_oneshot_broadcast() was kept the same. When a broadcast interrupt happens we signal the expiry to all CPUs which have an expired event. If none of the CPUs has an expired event, which can happen in dyntick mode, then we reprogram the broadcast device. We do not reprogram otherwise, but this is only correct if all CPUs, which are in the idle broadcast state have been woken up. The code ignores, that there might be pending not yet expired events on other CPUs, which are in the idle broadcast state. So the delivery of those events can be delayed for quite a time. Change the tick_handle_oneshot_broadcast() function to check for CPUs, which are in broadcast state and are not woken up by the current event, and enforce the rearming of the broadcast device for those CPUs. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-12-18sched: do not hurt SCHED_BATCH on wakeupIngo Molnar
measurements by Yanmin Zhang have shown that SCHED_BATCH tasks benefit if they run the same place_entity() logic as SCHED_OTHER tasks - so uniformize behavior in this area. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-12-18sched: touch softlockup watchdog after idlingIngo Molnar
touch softlockup watchdog after idling. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-12-18sched: sysctl, proc_dointvec_minmax() expects int values forEric Dumazet
min_sched_granularity_ns, max_sched_granularity_ns, min_wakeup_granularity_ns and max_wakeup_granularity_ns are declared "unsigned long". This is incorrect since proc_dointvec_minmax() expects plain "int" guard values. This bug only triggers on big endian 64 bit arches. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-12-18sched: mark rwsem functions as __sched for wchan/profilingLivio Soares
This following commit http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=fdf8cb0909b531f9ae8f9b9d7e4eb35ba3505f07 un-inlined a low-level rwsem function, but did not mark it as __sched. The result is that it now shows up as thread wchan (which also affects /proc/profile stats). The following simple patch fixes this by properly marking rwsem_down_failed_common() as a __sched function. Also in this patch, which is up for discussion, marks down_read() and down_write() proper as __sched. For profiling, it is pretty much useless to know that a semaphore is beig help - it is necessary to know _which_ one. By going up another frame on the stack, the information becomes much more useful. In summary, the below change to lib/rwsem.c should be applied; the changes to kernel/rwsem.c could be applied if other kernel hackers agree with my proposal that down_read()/down_write() in the profile is not enough. [ akpm@linux-foundation.org: build fix ] Signed-off-by: Livio Soares <livio@eecg.toronto.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-12-18sched: fix crash on ia64, introduce task_current()Dmitry Adamushko
Some services (e.g. sched_setscheduler(), rt_mutex_setprio() and sched_move_task()) must handle a given task differently in case it's the 'rq->curr' task on its run-queue. The task_running() interface is not suitable for determining such tasks for platforms with one of the following options: #define __ARCH_WANT_UNLOCKED_CTXSW #define __ARCH_WANT_INTERRUPTS_ON_CTXSW Due to the fact that it makes use of 'p->oncpu == 1' as a criterion but such a task is not necessarily 'rq->curr'. The detailed explanation is available here: https://lists.linux-foundation.org/pipermail/containers/2007-December/009262.html Signed-off-by: Dmitry Adamushko <dmitry.adamushko@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Tested-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Tested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
2007-12-17sysctl: fix ax25 checksEric W. Biederman
Fix: sysctl table check failed: /net/ax25/ax0/ax25_default_mode .3.9.1.2 Unknown sysctl binary path Pid: 2936, comm: kissattach Not tainted 2.6.24-rc5 #1 [<c012ca6a>] set_fail+0x3b/0x43 [<c012ce7a>] sysctl_check_table+0x408/0x456 [<c012ce8e>] sysctl_check_table+0x41c/0x456 [<c012ce8e>] sysctl_check_table+0x41c/0x456 ... Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Bernard Pidoux <pidoux@ccr.jussieu.fr> Cc: "David S. Miller" <davem@davemloft.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-17Revert "hugetlb: Add hugetlb_dynamic_pool sysctl"Nishanth Aravamudan
This reverts commit 54f9f80d6543fb7b157d3b11e2e7911dc1379790 ("hugetlb: Add hugetlb_dynamic_pool sysctl") Given the new sysctl nr_overcommit_hugepages, the boolean dynamic pool sysctl is not needed, as its semantics can be expressed by 0 in the overcommit sysctl (no dynamic pool) and non-0 in the overcommit sysctl (pool enabled). (Needed in 2.6.24 since it reverts a post-2.6.23 userspace-visible change) Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Acked-by: Adam Litke <agl@us.ibm.com> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-17hugetlb: introduce nr_overcommit_hugepages sysctlNishanth Aravamudan
hugetlb: introduce nr_overcommit_hugepages sysctl While examining the code to support /proc/sys/vm/hugetlb_dynamic_pool, I became convinced that having a boolean sysctl was insufficient: 1) To support per-node control of hugepages, I have previously submitted patches to add a sysfs attribute related to nr_hugepages. However, with a boolean global value and per-mount quota enforcement constraining the dynamic pool, adding corresponding control of the dynamic pool on a per-node basis seems inconsistent to me. 2) Administration of the hugetlb dynamic pool with multiple hugetlbfs mount points is, arguably, more arduous than it needs to be. Each quota would need to be set separately, and the sum would need to be monitored. To ease the administration, and to help make the way for per-node control of the static & dynamic hugepage pool, I added a separate sysctl, nr_overcommit_hugepages. This value serves as a high watermark for the overall hugepage pool, while nr_hugepages serves as a low watermark. The boolean sysctl can then be removed, as the condition nr_overcommit_hugepages > 0 indicates the same administrative setting as hugetlb_dynamic_pool == 1 Quotas still serve as local enforcement of the size of the pool on a per-mount basis. A few caveats: 1) There is a race whereby the global surplus huge page counter is incremented before a hugepage has allocated. Another process could then try grow the pool, and fail to convert a surplus huge page to a normal huge page and instead allocate a fresh huge page. I believe this is benign, as no memory is leaked (the actual pages are still tracked correctly) and the counters won't go out of sync. 2) Shrinking the static pool while a surplus is in effect will allow the number of surplus huge pages to exceed the overcommit value. As long as this condition holds, however, no more surplus huge pages will be allowed on the system until one of the two sysctls are increased sufficiently, or the surplus huge pages go out of use and are freed. Successfully tested on x86_64 with the current libhugetlbfs snapshot, modified to use the new sysctl. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Acked-by: Adam Litke <agl@us.ibm.com> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: ACPI: move timer broadcast before busmaster disable clockevents: warn once when program_event() is called with negative expiry hrtimers: avoid overflow for large relative timeouts
2007-12-07clockevents: warn once when program_event() is called with negative expiryThomas Gleixner
The hrtimer problem with large relative timeouts resulting in a negative expiry time went unnoticed as there is no check in the clockevents_program_event() code. Put a check there with a WARN_ONCE to avoid such problems in the future. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-12-07hrtimers: avoid overflow for large relative timeoutsThomas Gleixner
Relative hrtimers with a large timeout value might end up as negative timer values, when the current time is added in hrtimer_start(). This in turn is causing the clockevents_set_next() function to set an huge timeout and sleep for quite a long time when we have a clock source which is capable of long sleeps like HPET. With PIT this almost goes unnoticed as the maximum delta is ~27ms. The non-hrt/nohz code sorts this out in the next timer interrupt, so we never noticed that problem which has been there since the first day of hrtimers. This bug became more apparent in 2.6.24 which activates HPET on more hardware. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-12-07sched: enable early use of sched_clock()Ingo Molnar
some platforms have sched_clock() implementations that cannot be called very early during wakeup. If it's called it might hang or crash in hard to debug ways. So only call update_rq_clock() [which calls sched_clock()] if sched_init() has already been called. (rq->idle is NULL before the scheduler is initialized.) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-12-07lockdep: make cli/sti annotation warnings clearerIngo Molnar
make cli/sti annotation warnings easier to interpret. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
