path: root/kernel
2015-07-18x86/fpu, sched: Introduce CONFIG_ARCH_WANTS_DYNAMIC_TASK_STRUCT and use it ↵Ingo Molnar
on x86 Don't burden architectures without dynamic task_struct sizing with the overhead of dynamic sizing. Also optimize the x86 code a bit by caching task_struct_size. Acked-and-Tested-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave@sr71.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1437128892-9831-3-git-send-email-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-18x86/fpu, sched: Dynamically allocate 'struct fpu'Dave Hansen
The FPU rewrite removed the dynamic allocations of 'struct fpu'. But, this potentially wastes massive amounts of memory (2k per task on systems that do not have AVX-512 for instance). Instead of having a separate slab, this patch just appends the space that we need to the 'task_struct' which we dynamically allocate already. This saves from doing an extra slab allocation at fork(). The only real downside here is that we have to stick everything and the end of the task_struct. But, I think the BUILD_BUG_ON()s I stuck in there should keep that from being too fragile. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave@sr71.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1437128892-9831-2-git-send-email-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-15Merge tag 'trace-v4.2-rc1-fix' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing fix from Steven Rostedt: "Fengguang Wu discovered a crash that happened to be because of the branch tracer (traces unlikely and likely branches) when enabled with certain debug options. What happened was that various debug options like lockdep and DEBUG_PREEMPT can cause parts of the branch tracer to recurse outside its recursion protection. In fact, part of its recursion protection used these features that caused the lockup. This cleans up the code a little and makes the recursion protection a bit more robust" * tag 'trace-v4.2-rc1-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Have branch tracer use recursive field of task struct
2015-07-12Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Thomas Gleixner: "This update from the timer departement contains: - A series of patches which address a shortcoming in the tick broadcast code. If the broadcast device is not available or an hrtimer emulated broadcast device, some of the original assumptions lead to boot failures. I rather plugged all of the corner cases instead of only addressing the issue reported, so the change got a little larger. Has been extensivly tested on x86 and arm. - Get rid of the last holdouts using do_posix_clock_monotonic_gettime() - A regression fix for the imx clocksource driver - An update to the new state callbacks mechanism for clockevents. This is required to simplify the conversion, which will take place in 4.3" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tick/broadcast: Prevent NULL pointer dereference time: Get rid of do_posix_clock_monotonic_gettime cris: Replace do_posix_clock_monotonic_gettime() tick/broadcast: Unbreak CONFIG_GENERIC_CLOCKEVENTS=n build tick/broadcast: Handle spurious interrupts gracefully tick/broadcast: Check for hrtimer broadcast active early tick/broadcast: Return busy when IPI is pending tick/broadcast: Return busy if periodic mode and hrtimer broadcast tick/broadcast: Move the check for periodic mode inside state handling tick/broadcast: Prevent deep idle if no broadcast device available tick/broadcast: Make idle check independent from mode and config tick/broadcast: Sanity check the shutdown of the local clock_event tick/broadcast: Prevent hrtimer recursion clockevents: Allow set-state callbacks to be optional clocksource/imx: Define clocksource for mx27
2015-07-12Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fix from Thomas Gleixner: "A single fix for a cpu hotplug race vs. interrupt descriptors: Prevent irq setup/teardown across the cpu starting/dying parts of cpu hotplug so that the starting/dying cpu has a stable view of the descriptor space. This has been an issue for all architectures in the cpu dying phase, where interrupts are migrated away from the dying cpu. In the starting phase its mostly a x86 issue vs the vector space update" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: hotplug: Prevent alloc/free of irq descriptors during cpu up/down
2015-07-11tick/broadcast: Prevent NULL pointer dereferenceThomas Gleixner
Dan reported that the recent changes to the broadcast code introduced a potential NULL dereference. Add the proper check. Fixes: e0454311903d "tick/broadcast: Sanity check the shutdown of the local clock_event" Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-09module: Fix load_module() error pathPeter Zijlstra
The load_module() error path frees a module but forgot to take it out of the mod_tree, leaving a dangling entry in the tree, causing havoc. Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Reported-by: Arthur Marsh <arthur.marsh@internode.on.net> Tested-by: Arthur Marsh <arthur.marsh@internode.on.net> Fixes: 93c2e105f6bc ("module: Optimize __module_address() using a latched RB-tree") Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2015-07-08Fix broken audit tests for exec arg lenLinus Torvalds
The "fix" in commit 0b08c5e5944 ("audit: Fix check of return value of strnlen_user()") didn't fix anything, it broke things. As reported by Steven Rostedt: "Yes, strnlen_user() returns 0 on fault, but if you look at what len is set to, than you would notice that on fault len would be -1" because we just subtracted one from the return value. So testing against 0 doesn't test for a fault condition, it tests against a perfectly valid empty string. Also fix up the usual braindamage wrt using WARN_ON() inside a conditional - make it part of the conditional and remove the explicit unlikely() (which is already part of the WARN_ON*() logic, exactly so that you don't have to write unreadable code. Reported-and-tested-by: Steven Rostedt <rostedt@goodmis.org> Cc: Jan Kara <jack@suse.cz> Cc: Paul Moore <pmoore@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-08tracing: Have branch tracer use recursive field of task structSteven Rostedt (Red Hat)
Fengguang Wu's tests triggered a bug in the branch tracer's start up test when CONFIG_DEBUG_PREEMPT set. This was because that config adds some debug logic in the per cpu field, which calls back into the branch tracer. The branch tracer has its own recursive checks, but uses a per cpu variable to implement it. If retrieving the per cpu variable calls back into the branch tracer, you can see how things will break. Instead of using a per cpu variable, use the trace_recursion field of the current task struct. Simply set a bit when entering the branch tracing and clear it when leaving. If the bit is set on entry, just don't do the tracing. There's also the case with lockdep, as the local_irq_save() called before the recursion can also trigger code that can call back into the function. Changing that to a raw_local_irq_save() will protect that as well. This prevents the recursion and the inevitable crash that follows. Link: http://lkml.kernel.org/r/20150630141803.GA28071@wfg-t540p.sh.intel.com Cc: stable@vger.kernel.org # 3.10+ Reported-by: Fengguang Wu <fengguang.wu@intel.com> Tested-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-07-08hotplug: Prevent alloc/free of irq descriptors during cpu up/downThomas Gleixner
When a cpu goes up some architectures (e.g. x86) have to walk the irq space to set up the vector space for the cpu. While this needs extra protection at the architecture level we can avoid a few race conditions by preventing the concurrent allocation/free of irq descriptors and the associated data. When a cpu goes down it moves the interrupts which are targeted to this cpu away by reassigning the affinities. While this happens interrupts can be allocated and freed, which opens a can of race conditions in the code which reassignes the affinities because interrupt descriptors might be freed underneath. Example: CPU1 CPU2 cpu_up/down irq_desc = irq_to_desc(irq); remove_from_radix_tree(desc); raw_spin_lock(&desc->lock); free(desc); We could protect the irq descriptors with RCU, but that would require a full tree change of all accesses to interrupt descriptors. But fortunately these kind of race conditions are rather limited to a few things like cpu hotplug. The normal setup/teardown is very well serialized. So the simpler and obvious solution is: Prevent allocation and freeing of interrupt descriptors accross cpu hotplug. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: xiao jin <jin.xiao@intel.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Borislav Petkov <bp@suse.de> Cc: Yanmin Zhang <yanmin_zhang@linux.intel.com> Link: http://lkml.kernel.org/r/20150705171102.063519515@linutronix.de
2015-07-07tick/broadcast: Handle spurious interrupts gracefullyThomas Gleixner
Andriy reported that on a virtual machine the warning about negative expiry time in the clock events programming code triggered: hpet: hpet0 irq 40 for MSI hpet: hpet1 irq 41 for MSI Switching to clocksource hpet WARNING: at kernel/time/clockevents.c:239 [<ffffffff810ce6eb>] clockevents_program_event+0xdb/0xf0 [<ffffffff810cf211>] tick_handle_periodic_broadcast+0x41/0x50 [<ffffffff81016525>] timer_interrupt+0x15/0x20 When the second hpet is installed as a per cpu timer the broadcast event is not longer required and stopped, which sets the next_evt of the broadcast device to KTIME_MAX. If after that a spurious interrupt happens on the broadcast device, then the current code blindly handles it and tries to reprogram the broadcast device afterwards, which adds the period to next_evt. KTIME_MAX + period results in a negative expiry value causing the WARN_ON in the clockevents code to trigger. Add a proper check for the state of the broadcast device into the interrupt handler and return if the interrupt is spurious. [ Folded in pointer fix from Sudeep ] Reported-by: Andriy Gapon <avg@FreeBSD.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Sudeep Holla <sudeep.holla@arm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/20150705205221.802094647@linutronix.de
2015-07-07tick/broadcast: Check for hrtimer broadcast active earlyThomas Gleixner
If the current cpu is the one which has the hrtimer based broadcast queued then we better return busy immediately instead of going through loops and hoops to figure that out. [ Split out from a larger combo patch ] Tested-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Suzuki Poulose <Suzuki.Poulose@arm.com> Cc: Lorenzo Pieralisi <Lorenzo.Pieralisi@arm.com> Cc: Catalin Marinas <Catalin.Marinas@arm.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1507070929360.3916@nanos
2015-07-07tick/broadcast: Return busy when IPI is pendingThomas Gleixner
Tell the idle code not to go deep if the broadcast IPI is about to arrive. [ Split out from a larger combo patch ] Tested-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Suzuki Poulose <Suzuki.Poulose@arm.com> Cc: Lorenzo Pieralisi <Lorenzo.Pieralisi@arm.com> Cc: Catalin Marinas <Catalin.Marinas@arm.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1507070929360.3916@nanos
2015-07-07tick/broadcast: Return busy if periodic mode and hrtimer broadcastThomas Gleixner
If the system is in periodic mode and the broadcast device is hrtimer based, return busy as we have no proper handling for this. [ Split out from a larger combo patch ] Tested-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Suzuki Poulose <Suzuki.Poulose@arm.com> Cc: Lorenzo Pieralisi <Lorenzo.Pieralisi@arm.com> Cc: Catalin Marinas <Catalin.Marinas@arm.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1507070929360.3916@nanos
2015-07-07tick/broadcast: Move the check for periodic mode inside state handlingThomas Gleixner
We need to check more than the periodic mode for proper operation in all runtime combinations. To avoid code duplication move the check into the enter state handling. No functional change. [ Split out from a larger combo patch ] Reported-and-tested-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Suzuki Poulose <Suzuki.Poulose@arm.com> Cc: Lorenzo Pieralisi <Lorenzo.Pieralisi@arm.com> Cc: Catalin Marinas <Catalin.Marinas@arm.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1507070929360.3916@nanos
2015-07-07tick/broadcast: Prevent deep idle if no broadcast device availableThomas Gleixner
Add a check for a installed broadcast device to the oneshot control function and return busy if not. [ Split out from a larger combo patch ] Reported-and-tested-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Suzuki Poulose <Suzuki.Poulose@arm.com> Cc: Lorenzo Pieralisi <Lorenzo.Pieralisi@arm.com> Cc: Catalin Marinas <Catalin.Marinas@arm.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1507070929360.3916@nanos
2015-07-07tick/broadcast: Make idle check independent from mode and configThomas Gleixner
Currently the broadcast busy check, which prevents the idle code from going into deep idle, works only in one shot mode. If NOHZ and HIGHRES are off (config or command line) there is no sanity check at all, so under certain conditions cpus are allowed to go into deep idle, where the local timer stops, and are not woken up again because there is no broadcast timer installed or a hrtimer based broadcast device is not evaluated. Move tick_broadcast_oneshot_control() into the common code and provide proper subfunctions for the various config combinations. The common check in tick_broadcast_oneshot_control() is for the C3STOP misfeature flag of the local clock event device. If its not set, idle can proceed. If set, further checks are necessary. Provide checks for the trivial cases: - If broadcast is disabled in the config, then return busy - If oneshot mode (NOHZ/HIGHES) is disabled in the config, return busy if the broadcast device is hrtimer based. - If oneshot mode is enabled in the config call the original tick_broadcast_oneshot_control() function. That function needs extra checks which will be implemented in seperate patches. [ Split out from a larger combo patch ] Reported-and-tested-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Suzuki Poulose <Suzuki.Poulose@arm.com> Cc: Lorenzo Pieralisi <Lorenzo.Pieralisi@arm.com> Cc: Catalin Marinas <Catalin.Marinas@arm.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1507070929360.3916@nanos
2015-07-07tick/broadcast: Sanity check the shutdown of the local clock_eventThomas Gleixner
The broadcast code shuts down the local clock event unconditionally even if no broadcast device is installed or if the broadcast device is hrtimer based. Add proper sanity checks. [ Split out from a larger combo patch ] Reported-and-tested-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Suzuki Poulose <Suzuki.Poulose@arm.com> Cc: Lorenzo Pieralisi <Lorenzo.Pieralisi@arm.com> Cc: Catalin Marinas <Catalin.Marinas@arm.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1507070929360.3916@nanos
2015-07-07tick/broadcast: Prevent hrtimer recursionThomas Gleixner
The hrtimer based broadcast vehicle can cause a hrtimer recursion which went unnoticed until we changed the hrtimer expiry code to keep track of the currently running timer. local_timer_interrupt() local_handler() hrtimer_interrupt() expire_hrtimers() broadcast_hrtimer() send_ipis() local_handler() hrtimer_interrupt() .... Solution is simple: Prevent the local handler call from the broadcast code when the broadcast 'device' is hrtimer based. [ Split out from a larger combo patch ] Tested-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Suzuki Poulose <Suzuki.Poulose@arm.com> Cc: Lorenzo Pieralisi <Lorenzo.Pieralisi@arm.com> Cc: Catalin Marinas <Catalin.Marinas@arm.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1507070929360.3916@nanos
2015-07-07clockevents: Allow set-state callbacks to be optionalViresh Kumar
Its mandatory for the drivers to provide set_state_{oneshot|periodic}() (only if related modes are supported) and set_state_shutdown() callbacks today, if they are implementing the new set-state interface. But this leads to unnecessary noop callbacks for drivers which don't want to implement them. Over that, it will lead to a full function call for nothing really useful. Lets make all set-state callbacks optional. Suggested-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Link: http://lkml.kernel.org/r/1436256875-15562-1-git-send-email-daniel.lezcano@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-06perf: Fix AUX buffer refcountingPeter Zijlstra
Its currently possible to drop the last refcount to the aux buffer from NMI context, which results in the expected fireworks. The refcounting needs a bigger overhaul, but to cure the immediate problem, delay the freeing by using an irq_work. Reviewed-and-tested-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Reported-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20150618103249.GK19282@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted VFS fixes and related cleanups (IMO the most interesting in that part are f_path-related things and Eric's descriptor-related stuff). UFS regression fixes (it got broken last cycle). 9P fixes. fs-cache series, DAX patches, Jan's file_remove_suid() work" [ I'd say this is much more than "fixes and related cleanups". The file_table locking rule change by Eric Dumazet is a rather big and fundamental update even if the patch isn't huge. - Linus ] * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits) 9p: cope with bogus responses from server in p9_client_{read,write} p9_client_write(): avoid double p9_free_req() 9p: forgetting to cancel request on interrupted zero-copy RPC dax: bdev_direct_access() may sleep block: Add support for DAX reads/writes to block devices dax: Use copy_from_iter_nocache dax: Add block size note to documentation fs/file.c: __fget() and dup2() atomicity rules fs/file.c: don't acquire files->file_lock in fd_install() fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation vfs: avoid creation of inode number 0 in get_next_ino namei: make set_root_rcu() return void make simple_positive() public ufs: use dir_pages instead of ufs_dir_pages() pagemap.h: move dir_pages() over there remove the pointless include of lglock.h fs: cleanup slight list_entry abuse xfs: Correctly lock inode when removing suid and file capabilities fs: Call security_ops->inode_killpriv on truncate fs: Provide function telling whether file_remove_privs() will do anything ...
2015-07-04Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm fixes from Paolo Bonzini: "Except for the preempt notifiers fix, these are all small bugfixes that could have been waited for -rc2. Sending them now since I was taking care of Peter's patch anyway" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: kvm: add hyper-v crash msrs values KVM: x86: remove data variable from kvm_get_msr_common KVM: s390: virtio-ccw: don't overwrite config space values KVM: x86: keep track of LVT0 changes under APICv KVM: x86: properly restore LVT0 KVM: x86: make vapics_in_nmi_mode atomic sched, preempt_notifier: separate notifier registration from static_key inc/dec
2015-07-04Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Debug info and other statistics fixes and related enhancements" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/numa: Fix numa balancing stats in /proc/pid/sched sched/numa: Show numa_group ID in /proc/sched_debug task listings sched/debug: Move print_cfs_rq() declaration to kernel/sched/sched.h sched/stat: Expose /proc/pid/schedstat if CONFIG_SCHED_INFO=y sched/stat: Simplify the sched_info accounting dependency
2015-07-04sched/numa: Fix numa balancing stats in /proc/pid/schedSrikar Dronamraju
Commit 44dba3d5d6a1 ("sched: Refactor task_struct to use numa_faults instead of numa_* pointers") modified the way tsk->numa_faults stats are accounted. However that commit never touched show_numa_stats() that is displayed in /proc/pid/sched and thus the numbers displayed in /proc/pid/sched don't match the actual numbers. Fix it by making sure that /proc/pid/sched reflects the task fault numbers. Also add group fault stats too. Also couple of more modifications are added here: 1. Format changes: - Previously we would list two entries per node, one for private and one for shared. Also the home node info was listed in each entry. - Now preferred node, total_faults and current node are displayed separately. - Now there is one entry per node, that lists private,shared task and group faults. 2. Unit changes: - p->numa_pages_migrated was getting reset after every read of /proc/pid/sched. It's more useful to have absolute numbers since differential migrations between two accesses can be more easily calculated. Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Iulia Manda <iulia.manda21@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1435252903-1081-4-git-send-email-srikar@linux.vnet.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-04sched/numa: Show numa_group ID in /proc/sched_debug task listingsSrikar Dronamraju
Having the numa group ID in /proc/sched_debug helps to see how the numa groups have spread across the system. Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Iulia Manda <iulia.manda21@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1435252903-1081-3-git-send-email-srikar@linux.vnet.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-04sched/debug: Move print_cfs_rq() declaration to kernel/sched/sched.hSrikar Dronamraju
Currently print_cfs_rq() is declared in include/linux/sched.h. However it's not used outside kernel/sched. Hence move the declaration to kernel/sched/sched.h Also some functions are only available for CONFIG_SCHED_DEBUG=y. Hence move the declarations to within the #ifdef. Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Iulia Manda <iulia.manda21@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1435252903-1081-2-git-send-email-srikar@linux.vnet.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-04sched/stat: Simplify the sched_info accounting dependencyNaveen N. Rao
Both CONFIG_SCHEDSTATS=y and CONFIG_TASK_DELAY_ACCT=y track task sched_info, which results in ugly #if clauses. Simplify the code by introducing a synthethic CONFIG_SCHED_INFO switch, selected by both. Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: a.p.zijlstra@chello.nl Cc: ricklind@us.ibm.com Link: http://lkml.kernel.org/r/8d19eef800811a94b0f91bcbeb27430a884d7433.1435255405.git.naveen.n.rao@linux.vnet.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace updates from Eric Biederman: "Long ago and far away when user namespaces where young it was realized that allowing fresh mounts of proc and sysfs with only user namespace permissions could violate the basic rule that only root gets to decide if proc or sysfs should be mounted at all. Some hacks were put in place to reduce the worst of the damage could be done, and the common sense rule was adopted that fresh mounts of proc and sysfs should allow no more than bind mounts of proc and sysfs. Unfortunately that rule has not been fully enforced. There are two kinds of gaps in that enforcement. Only filesystems mounted on empty directories of proc and sysfs should be ignored but the test for empty directories was insufficient. So in my tree directories on proc, sysctl and sysfs that will always be empty are created specially. Every other technique is imperfect as an ordinary directory can have entries added even after a readdir returns and shows that the directory is empty. Special creation of directories for mount points makes the code in the kernel a smidge clearer about it's purpose. I asked container developers from the various container projects to help test this and no holes were found in the set of mount points on proc and sysfs that are created specially. This set of changes also starts enforcing the mount flags of fresh mounts of proc and sysfs are consistent with the existing mount of proc and sysfs. I expected this to be the boring part of the work but unfortunately unprivileged userspace winds up mounting fresh copies of proc and sysfs with noexec and nosuid clear when root set those flags on the previous mount of proc and sysfs. So for now only the atime, read-only and nodev attributes which userspace happens to keep consistent are enforced. Dealing with the noexec and nosuid attributes remains for another time. This set of changes also addresses an issue with how open file descriptors from /proc/<pid>/ns/* are displayed. Recently readlink of /proc/<pid>/fd has been triggering a WARN_ON that has not been meaningful since it was added (as all of the code in the kernel was converted) and is not now actively wrong. There is also a short list of issues that have not been fixed yet that I will mention briefly. It is possible to rename a directory from below to above a bind mount. At which point any directory pointers below the renamed directory can be walked up to the root directory of the filesystem. With user namespaces enabled a bind mount of the bind mount can be created allowing the user to pick a directory whose children they can rename to outside of the bind mount. This is challenging to fix and doubly so because all obvious solutions must touch code that is in the performance part of pathname resolution. As mentioned above there is also a question of how to ensure that developers by accident or with purpose do not introduce exectuable files on sysfs and proc and in doing so introduce security regressions in the current userspace that will not be immediately obvious and as such are likely to require breaking userspace in painful ways once they are recognized" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: vfs: Remove incorrect debugging WARN in prepend_path mnt: Update fs_fully_visible to test for permanently empty directories sysfs: Create mountpoints with sysfs_create_mount_point sysfs: Add support for permanently empty directories to serve as mount points. kernfs: Add support for always empty directories. proc: Allow creating permanently empty directories that serve as mount points sysctl: Allow creating permanently empty directories that serve as mountpoints. fs: Add helper functions for permanently empty directories. vfs: Ignore unlocked mounts in fs_fully_visible mnt: Modify fs_fully_visible to deal with locked ro nodev and atime mnt: Refactor the logic for mounting sysfs and proc in a user namespace
2015-07-03sched, preempt_notifier: separate notifier registration from static_key inc/decPeter Zijlstra
Commit 1cde2930e154 ("sched/preempt: Add static_key() to preempt_notifiers") had two problems. First, the preempt-notifier API needs to sleep with the addition of the static_key, we do however need to hold off preemption while modifying the preempt notifier list, otherwise a preemption could observe an inconsistent list state. KVM correctly registers and unregisters preempt notifiers with preemption disabled, so the sleep caused dmesg splats. Second, KVM registers and unregisters preemption notifiers very often (in vcpu_load/vcpu_put). With a single uniprocessor guest the static key would move between 0 and 1 continuously, hitting the slow path on every userspace exit. To fix this, wrap the static_key inc/dec in a new API, and call it from KVM. Fixes: 1cde2930e154 ("sched/preempt: Add static_key() to preempt_notifiers") Reported-by: Pontus Fuchs <pontus.fuchs@gmail.com> Reported-by: Takashi Iwai <tiwai@suse.de> Tested-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-07-02make certificate list change message more usefulLinus Torvalds
It's a bug in our Makefile rules, make it show what the changing certificate list was, and make it a warning so that people actually see it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-01Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patchbomb from Andrew Morton: - the rest of MM - scripts/gdb updates - ipc/ updates - lib/ updates - MAINTAINERS updates - various other misc things * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (67 commits) genalloc: rename of_get_named_gen_pool() to of_gen_pool_get() genalloc: rename dev_get_gen_pool() to gen_pool_get() x86: opt into HAVE_COPY_THREAD_TLS, for both 32-bit and 64-bit MAINTAINERS: add zpool MAINTAINERS: BCACHE: Kent Overstreet has changed email address MAINTAINERS: move Jens Osterkamp to CREDITS MAINTAINERS: remove unused nbd.h pattern MAINTAINERS: update brcm gpio filename pattern MAINTAINERS: update brcm dts pattern MAINTAINERS: update sound soc intel patterns MAINTAINERS: remove website for paride MAINTAINERS: update Emulex ocrdma email addresses bcache: use kvfree() in various places libcxgbi: use kvfree() in cxgbi_free_big_mem() target: use kvfree() in session alloc and free IB/ehca: use kvfree() in ipz_queue_{cd}tor() drm/nouveau/gem: use kvfree() in u_free() drm: use kvfree() in drm_free_large() cxgb4: use kvfree() in t4_free_mem() cxgb3: use kvfree() in cxgb_free_mem() ...
2015-07-01Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Thomas Gleixner: "This contains: - a build regression fix introduced by the timeconst move - a hotplug regression fix introduced by the timer wheel diet - a cpu hotplug bug fix for the exynos clocksource driver" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: time: Remove development rules from Kbuild/Makefile timer: Fix hotplug regression clocksource: exynos_mct: Avoid blocking calls in the cpu hotplug notifier
2015-07-01Merge tag 'pm+acpi-4.2-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI fixes from Rafael Wysocki: "These are fixes that didn't make it to the previous PM+ACPI pull request or are fixing issues introduced by it. Specifics: - Fix a recently added memory leak in an error path in the ACPI resources management code (Dan Carpenter) - Fix a build warning triggered by an ACPI video header function that should be static inline (Borislav Petkov) - Change names of helper function converting struct fwnode_handle pointers to either struct device_node or struct acpi_device pointers so they don't conflict with local variable names (Alexander Sverdlin) - Make the hibernate core re-enable nonboot CPUs on failures to disable them as expected (Vitaly Kuznetsov) - Increase the default timeout of the device suspend watchdog to prevent it from triggering too early on some systems (Takashi Iwai) - Prevent the cpuidle powernv driver from registering idle states with CPUIDLE_FLAG_TIMER_STOP set if CONFIG_TICK_ONESHOT is unset which leads to boot hangs (Preeti U Murthy)" * tag 'pm+acpi-4.2-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: tick/idle/powerpc: Do not register idle states with CPUIDLE_FLAG_TIMER_STOP set in periodic mode PM / sleep: Increase default DPM watchdog timeout to 60 PM / hibernate: re-enable nonboot cpus on disable_nonboot_cpus() failure ACPI / OF: Rename of_node() and acpi_node() to to_of_node() and to_acpi_node() ACPI / video: Inline acpi_video_set_dmi_backlight_type ACPI / resources: free memory on error in add_region_before()
2015-07-01Merge tag 'for-linus-4.2-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen updates from David Vrabel: "Xen features and cleanups for 4.2-rc0: - add "make xenconfig" to assist in generating configs for Xen guests - preparatory cleanups necessary for supporting 64 KiB pages in ARM guests - automatically use hvc0 as the default console in ARM guests" * tag 'for-linus-4.2-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: block/xen-blkback: s/nr_pages/nr_segs/ block/xen-blkfront: Remove invalid comment block/xen-blkfront: Remove unused macro MAXIMUM_OUTSTANDING_BLOCK_REQS arm/xen: Drop duplicate define mfn_to_virt xen/grant-table: Remove unused macro SPP xen/xenbus: client: Fix call of virt_to_mfn in xenbus_grant_ring xen: Include xen/page.h rather than asm/xen/page.h kconfig: add xenconfig defconfig helper kconfig: clarify kvmconfig is for kvm xen/pcifront: Remove usage of struct timeval xen/tmem: use BUILD_BUG_ON() in favor of BUG_ON() hvc_xen: avoid uninitialized variable warning xenbus: avoid uninitialized variable warning xen/arm: allow console=hvc0 to be omitted for guests arm,arm64/xen: move Xen initialization earlier arm/xen: Correctly check if the event channel interrupt is present
2015-07-01Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Main excitement here is Peter Zijlstra's lockless rbtree optimization to speed module address lookup. He found some abusers of the module lock doing that too. A little bit of parameter work here too; including Dan Streetman's breaking up the big param mutex so writing a parameter can load another module (yeah, really). Unfortunately that broke the usual suspects, !CONFIG_MODULES and !CONFIG_SYSFS, so those fixes were appended too" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (26 commits) modules: only use mod->param_lock if CONFIG_MODULES param: fix module param locks when !CONFIG_SYSFS. rcu: merge fix for Convert ACCESS_ONCE() to READ_ONCE() and WRITE_ONCE() module: add per-module param_lock module: make perm const params: suppress unused variable error, warn once just in case code changes. modules: clarify CONFIG_MODULE_COMPRESS help, suggest 'N'. kernel/module.c: avoid ifdefs for sig_enforce declaration kernel/workqueue.c: remove ifdefs over wq_power_efficient kernel/params.c: export param_ops_bool_enable_only kernel/params.c: generalize bool_enable_only kernel/module.c: use generic module param operaters for sig_enforce kernel/params: constify struct kernel_param_ops uses sysfs: tightened sysfs permission checks module: Rework module_addr_{min,max} module: Use __module_address() for module_address_lookup() module: Make the mod_tree stuff conditional on PERF_EVENTS || TRACING module: Optimize __module_address() using a latched RB-tree rbtree: Implement generic latch_tree seqlock: Introduce raw_read_seqcount_latch() ...
2015-07-01sysfs: Create mountpoints with sysfs_create_mount_pointEric W. Biederman
This allows for better documentation in the code and it allows for a simpler and fully correct version of fs_fully_visible to be written. The mount points converted and their filesystems are: /sys/hypervisor/s390/ s390_hypfs /sys/kernel/config/ configfs /sys/kernel/debug/ debugfs /sys/firmware/efi/efivars/ efivarfs /sys/fs/fuse/connections/ fusectl /sys/fs/pstore/ pstore /sys/kernel/tracing/ tracefs /sys/fs/cgroup/ cgroup /sys/kernel/security/ securityfs /sys/fs/selinux/ selinuxfs /sys/fs/smackfs/ smackfs Cc: stable@vger.kernel.org Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2015-07-01sysctl: Allow creating permanently empty directories that serve as mountpoints.Eric W. Biederman
Add a magic sysctl table sysctl_mount_point that when used to create a directory forces that directory to be permanently empty. Update the code to use make_empty_dir_inode when accessing permanently empty directories. Update the code to not allow adding to permanently empty directories. Update /proc/sys/fs/binfmt_misc to be a permanently empty directory. Cc: stable@vger.kernel.org Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2015-07-01time: Remove development rules from Kbuild/MakefileThomas Gleixner
time.o gets rebuilt unconditionally due to a leftover Makefile rule which was placed there for development purposes. Remove it along with the commented out always rule in the toplevel Kbuild file. Fixes: 0a227985d4a9 'time: Move timeconst.h into include/generated' Reported-by; Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Nicholas Mc Guire <der.herr@hofr.at>
2015-06-30kernel/relay.c: use kvfree() in relay_free_page_array()Pekka Enberg
Use kvfree() instead of open-coding it. Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30printk: improve the description of /dev/kmsg line formatAntonio Ospite
The comment about /dev/kmsg does not mention the additional values which may actually be exported, fix that. Also move up the part of the comment instructing the users to ignore these additional values, this way the reading is more fluent and logically compact. Signed-off-by: Antonio Ospite <ao2@ao2.it> Cc: Joe Perches <joe@perches.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30gcov: add support for GCC 5.1Lorenzo Stoakes
Fix kernel gcov support for GCC 5.1. Similar to commit a992bf836f9 ("gcov: add support for GCC 4.9"), this patch takes into account the existence of a new gcov counter (see gcc's gcc/gcov-counter.def.) Firstly, it increments GCOV_COUNTERS (to 10), which makes the data structure struct gcov_info compatible with GCC 5.1. Secondly, a corresponding counter function __gcov_merge_icall_topn (Top N value tracking for indirect calls) is included in base.c with the other gcov counters unused for kernel profiling. Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com> Cc: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Yuan Pengfei <coolypf@qq.com> Tested-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30kernel/panic/kexec: fix "crash_kexec_post_notifiers" option issue in oops pathHATAYAMA Daisuke
Commit f06e5153f4ae2e ("kernel/panic.c: add "crash_kexec_post_notifiers" option for kdump after panic_notifers") introduced "crash_kexec_post_notifiers" kernel boot option, which toggles wheather panic() calls crash_kexec() before panic_notifiers and dump kmsg or after. The problem is that the commit overlooks panic_on_oops kernel boot option. If it is enabled, crash_kexec() is called directly without going through panic() in oops path. To fix this issue, this patch adds a check to "crash_kexec_post_notifiers" in the condition of kexec_should_crash(). Also, put a comment in kexec_should_crash() to explain not obvious things on this patch. Signed-off-by: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Acked-by: Baoquan He <bhe@redhat.com> Tested-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Baoquan He <bhe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30kernel/panic: call the 2nd crash_kexec() only if crash_kexec_post_notifiers ↵HATAYAMA Daisuke
is enabled For compatibility with the behaviour before the commit f06e5153f4ae2e ("kernel/panic.c: add "crash_kexec_post_notifiers" option for kdump after panic_notifers"), the 2nd crash_kexec() should be called only if crash_kexec_post_notifiers is enabled. Note that crash_kexec() returns immediately if kdump crash kernel is not loaded, so in this case, this patch makes no functionality change, but the point is to make it explicit, from the caller panic() side, that the 2nd crash_kexec() does nothing. Signed-off-by: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Suggested-by: Ingo Molnar <mingo@kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Baoquan He <bhe@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-28modules: only use mod->param_lock if CONFIG_MODULESStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2015-06-28param: fix module param locks when !CONFIG_SYSFS.Rusty Russell
As Dan Streetman points out, the entire point of locking for is to stop sysfs accesses, so they're elided entirely in the !SYSFS case. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2015-06-27Merge branch 'upstream' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit updates from Paul Moore: "Four small audit patches for v4.2, all bug fixes. Only 10 lines of change this time so very unremarkable, the patch subject lines pretty much tell the whole story" * 'upstream' of git://git.infradead.org/users/pcmoore/audit: audit: Fix check of return value of strnlen_user() audit: obsolete audit_context check is removed in audit_filter_rules() audit: fix for typo in comment to function audit_log_link_denied() lsm: rename duplicate labels in LSM_AUDIT_DATA_TASK audit message type
2015-06-27Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "The main change in this kernel is Casey's generalized LSM stacking work, which removes the hard-coding of Capabilities and Yama stacking, allowing multiple arbitrary "small" LSMs to be stacked with a default monolithic module (e.g. SELinux, Smack, AppArmor). See https://lwn.net/Articles/636056/ This will allow smaller, simpler LSMs to be incorporated into the mainline kernel and arbitrarily stacked by users. Also, this is a useful cleanup of the LSM code in its own right" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits) tpm, tpm_crb: fix le64_to_cpu conversions in crb_acpi_add() vTPM: set virtual device before passing to ibmvtpm_reset_crq tpm_ibmvtpm: remove unneccessary message level. ima: update builtin policies ima: extend "mask" policy matching support ima: add support for new "euid" policy condition ima: fix ima_show_template_data_ascii() Smack: freeing an error pointer in smk_write_revoke_subj() selinux: fix setting of security labels on NFS selinux: Remove unused permission definitions selinux: enable genfscon labeling for sysfs and pstore files selinux: enable per-file labeling for debugfs files. selinux: update netlink socket classes signals: don't abuse __flush_signals() in selinux_bprm_committed_creds() selinux: Print 'sclass' as string when unrecognized netlink message occurs Smack: allow multiple labels in onlycap Smack: fix seq operations in smackfs ima: pass iint to ima_add_violation() ima: wrap event related data to the new ima_event_data structure integrity: add validity checks for 'path' parameter ...
2015-06-26Merge branch 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue updates from Tejun Heo: "Most of the changes are around implementing and fixing fallouts from sysfs and internal interface to limit the CPUs available to all unbound workqueues to help isolating CPUs. It needs more work as ordered workqueues can roam unrestricted but still is a significant improvement" * 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix typos in comments workqueue: move flush_scheduled_work() to workqueue.h workqueue: remove the lock from wq_sysfs_prep_attrs() workqueue: remove the declaration of copy_workqueue_attrs() workqueue: ensure attrs changes are properly synchronized workqueue: separate out and refactor the locking of applying attrs workqueue: simplify wq_update_unbound_numa() workqueue: wq_pool_mutex protects the attrs-installation workqueue: fix a typo workqueue: function name in the comment differs from the real function name workqueue: fix trivial typo in Documentation/workqueue.txt workqueue: Allow modifying low level unbound workqueue cpumask workqueue: Create low-level unbound workqueues cpumask workqueue: split apply_workqueue_attrs() into 3 stages
2015-06-26Merge branch 'for-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: - threadgroup_lock got reorganized so that its users can pick the actual locking mechanism to use. Its only user - cgroups - is updated to use a percpu_rwsem instead of per-process rwsem. This makes things a bit lighter on hot paths and allows cgroups to perform and fail multi-task (a process) migrations atomically. Multi-task migrations are used in several places including the unified hierarchy. - Delegation rule and documentation added to unified hierarchy. This will likely be the last interface update from the cgroup core side for unified hierarchy before lifting the devel mask. - Some groundwork for the pids controller which is scheduled to be merged in the coming devel cycle. * 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: add delegation section to unified hierarchy documentation cgroup: require write perm on common ancestor when moving processes on the default hierarchy cgroup: separate out cgroup_procs_write_permission() from __cgroup_procs_write() kernfs: make kernfs_get_inode() public MAINTAINERS: add a cgroup core co-maintainer cgroup: fix uninitialised iterator in for_each_subsys_which cgroup: replace explicit ss_mask checking with for_each_subsys_which cgroup: use bitmask to filter for_each_subsys cgroup: add seq_file forward declaration for struct cftype cgroup: simplify threadgroup locking sched, cgroup: replace signal_struct->group_rwsem with a global percpu_rwsem sched, cgroup: reorganize threadgroup locking cgroup: switch to unsigned long for bitmasks cgroup: reorganize include/linux/cgroup.h cgroup: separate out include/linux/cgroup-defs.h cgroup: fix some comment typos
