path: root/kernel
2010-03-11sched: Remove SYNC_WAKEUPS featureMike Galbraith
Sync wakeups are critical functionality with a long history. Remove it, we don't need the branch or icache footprint. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1268301817.6785.47.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11sched: Remove WAKEUP_SYNC featureMike Galbraith
This feature never earned its keep, remove it. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1268301591.6785.42.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11sched: Remove FAIR_SLEEPERS featureMike Galbraith
Our preemption model relies too heavily on sleeper fairness to disable it without dire consequences. Remove the feature, and save a branch or two. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1268301520.6785.40.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11sched: Remove NORMALIZED_SLEEPERMike Galbraith
This feature hasn't been enabled in a long time, remove effectively dead code. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1268301447.6785.38.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11sched: Fix select_idle_sibling()Mike Galbraith
Don't bother with selection when the current cpu is idle. Recent load balancing changes also make it no longer necessary to check wake_affine() success before returning the selected sibling, so we now always use it. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1268301369.6785.36.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11sched: Tweak sched_latency and min_granularityMike Galbraith
Allow LAST_BUDDY to kick in sooner, improving cache utilization as soon as a second buddy pair arrives on scene. The cost is latency starting to climb sooner, the tbenefit for tbench 8 on my Q6600 box is ~2%. No detrimental effects noted in normal idesktop usage. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1268301285.6785.34.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11sched: Cleanup/optimize clock updatesMike Galbraith
Now that we no longer depend on the clock being updated prior to enqueueing on migratory wakeup, we can clean up a bit, placing calls to update_rq_clock() exactly where they are needed, ie on enqueue, dequeue and schedule events. In the case of a freshly enqueued task immediately preempting, we can skip the update during preemption, as the clock was just updated by the enqueue event. We also save an unneeded call during a migratory wakeup by not updating the previous runqueue, where update_curr() won't be invoked. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1268301199.6785.32.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11sched: Remove avg_overlapMike Galbraith
Both avg_overlap and avg_wakeup had an inherent problem in that their accuracy was detrimentally affected by cross-cpu wakeups, this because we are missing the necessary call to update_curr(). This can't be fixed without increasing overhead in our already too fat fastpath. Additionally, with recent load balancing changes making us prefer to place tasks in an idle cache domain (which is good for compute bound loads), communicating tasks suffer when a sync wakeup, which would enable affine placement, is turned into a non-sync wakeup by SYNC_LESS. With one task on the runqueue, wake_affine() rejects the affine wakeup request, leaving the unfortunate where placed, taking frequent cache misses. Remove it, and recover some fastpath cycles. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1268301121.6785.30.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11sched: Remove avg_wakeupMike Galbraith
Testing the load which led to this heuristic (nfs4 kbuild) shows that it has outlived it's usefullness. With intervening load balancing changes, I cannot see any difference with/without, so recover there fastpath cycles. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1268301062.6785.29.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11sched: Rate-limit nohzMike Galbraith
Entering nohz code on every micro-idle is costing ~10% throughput for netperf TCP_RR when scheduling cross-cpu. Rate limiting entry fixes this, but raises ticks a bit. On my Q6600, an idle box goes from ~85 interrupts/sec to 128. The higher the context switch rate, the more nohz entry costs. With this patch and some cycle recovery patches in my tree, max cross cpu context switch rate is improved by ~16%, a large portion of which of which is this ratelimiting. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1268301003.6785.28.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11sched: Implement group scheduler statistics in one structLucas De Marchi
Put all statistic fields of sched_entity in one struct, sched_statistics, and embed it into sched_entity. This change allows to memset the sched_statistics to 0 when needed (for instance when forking), avoiding bugs of non initialized fields. Signed-off-by: Lucas De Marchi <lucas.de.marchi@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1268275065-18542-1-git-send-email-lucas.de.marchi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11sched: Fix pick_next_highest_task_rt() for cgroupsPeter Zijlstra
Since pick_next_highest_task_rt() already iterates all the cgroups and is really only interested in tasks, skip over the !task entries. Reported-by: Dhaval Giani <dhaval.giani@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Tested-by: Dhaval Giani <dhaval.giani@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11sched: Cleanup: remove unused variable in try_to_wake_up()Dan Carpenter
We haven't used the "orig_rq" variable since 055a00865d "Fix/add missing update_rq_clock() calls" Signed-off-by: Dan Carpenter <error27@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: efault@gmx.de LKML-Reference: <20100306111752.GL4958@bicker> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-01Merge branch 'for-2.6.34' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.34' of git://git.kernel.dk/linux-2.6-block: (38 commits) block: don't access jiffies when initialising io_context cfq: remove 8 bytes of padding from cfq_rb_root on 64 bit builds block: fix for "Consolidate phys_segment and hw_segment limits" cfq-iosched: quantum check tweak blktrace: perform cleanup after setup error blkdev: fix merge_bvec_fn return value checks cfq-iosched: requests "in flight" vs "in driver" clarification cciss: Fix problem with scatter gather elements in the scsi half of the driver cciss: eliminate unnecessary pointer use in cciss scsi code cciss: do not use void pointer for scsi hba data cciss: factor out scatter gather chain block mapping code cciss: fix scatter gather chain block dma direction kludge cciss: simplify scatter gather code cciss: factor out scatter gather chain block allocation and freeing cciss: detect bad alignment of scsi commands at build time cciss: clarify command list padding calculation cfq-iosched: rethink seeky detection for SSDs cfq-iosched: rework seeky detection block: remove padding from io_context on 64bit builds block: Consolidate phys_segment and hw_segment limits ...
2010-03-01Merge branches 'futexes-for-linus', 'irq-core-for-linus' and ↵Linus Torvalds
'bkl-drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'futexes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: futex: Protect pid lookup in compat code with RCU * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Fix documentation of default chip disable() * 'bkl-drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: nvram: Drop the BKL from nvram_open()
2010-03-01Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: posix-timers.c: Don't export local functions clocksource: start CMT at clocksource resume clocksource: add suspend callback clocksource: add argument to resume callback ntp: Cleanup xtime references in ntp.c ntp: Make time_esterror and time_maxerror static
2010-02-28Merge branch 'x86-ptrace-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-ptrace-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, ptrace: Remove set_stopped_child_used_math() in [x]fpregs_set x86, ptrace: Simplify xstateregs_get() ptrace: Fix ptrace_regset() comments and diagnose errors specifically parisc: Disable CONFIG_HAVE_ARCH_TRACEHOOK ptrace: Add support for generic PTRACE_GETREGSET/PTRACE_SETREGSET x86, ptrace: regset extensions to support xstate
2010-02-28blktrace: perform cleanup after setup errorDmitry Monakhov
Currently even if BLKTRACESETUP ioctl has failed user must call BLKTRACETEARDOWN to be shure what all staff was cleaned, which is contr-intuitive. Let's setup ioctl make necessery cleanup by it self. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-28Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, mm: Unify kernel_physical_mapping_init() API x86, mm: Allow highmem user page tables to be disabled at boot time x86: Do not reserve brk for DMI if it's not going to be used x86: Convert tlbstate_lock to raw_spinlock x86: Use the generic page_is_ram() x86: Remove BIOS data range from e820 Move page_is_ram() declaration to mm.h Generic page_is_ram: use __weak resources: introduce generic page_is_ram()
2010-02-28Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits) sched: Fix SCHED_MC regression caused by change in sched cpu_power sched: Don't use possibly stale sched_class kthread, sched: Remove reference to kthread_create_on_cpu sched: cpuacct: Use bigger percpu counter batch values for stats counters percpu_counter: Make __percpu_counter_add an inline function on UP sched: Remove member rt_se from struct rt_rq sched: Change usage of rt_rq->rt_se to rt_rq->tg->rt_se[cpu] sched: Remove unused update_shares_locked() sched: Use for_each_bit sched: Queue a deboosted task to the head of the RT prio queue sched: Implement head queueing for sched_rt sched: Extend enqueue_task to allow head queueing sched: Remove USER_SCHED sched: Fix the place where group powers are updated sched: Assume *balance is valid sched: Remove load_balance_newidle() sched: Unify load_balance{,_newidle}() sched: Add a lock break for PREEMPT=y sched: Remove from fwd decls sched: Remove rq_iterator from move_one_task ... Fix up trivial conflicts in kernel/sched.c
2010-02-28Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Fix race between ttwu() and task_rq_lock() sched: Fix SMT scheduler regression in find_busiest_queue() sched: Fix sched_mv_power_savings for !SMT kernel/sched.c: Suppress unused var warning
2010-02-28Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (172 commits) perf_event, amd: Fix spinlock initialization perf_event: Fix preempt warning in perf_clock() perf tools: Flush maps on COMM events perf_events, x86: Split PMU definitions into separate files perf annotate: Handle samples not at objdump output addr boundaries perf_events, x86: Remove superflous MSR writes perf_events: Simplify code by removing cpu argument to hw_perf_group_sched_in() perf_events, x86: AMD event scheduling perf_events: Add new start/stop PMU callbacks perf_events: Report the MMAP pgoff value in bytes perf annotate: Defer allocating sym_priv->hist array perf symbols: Improve debugging information about symtab origins perf top: Use a macro instead of a constant variable perf symbols: Check the right return variable perf/scripts: Tag syscall_name helper as not yet available perf/scripts: Add perf-trace-python Documentation perf/scripts: Remove unnecessary PyTuple resizes perf/scripts: Add syscall tracing scripts perf/scripts: Add Python scripting engine perf/scripts: Remove check-perf-trace from listed scripts ... Fix trivial conflict in tools/perf/util/probe-event.c
2010-02-28Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits) ftrace: Add function names to dangling } in function graph tracer tracing: Simplify memory recycle of trace_define_field tracing: Remove unnecessary variable in print_graph_return tracing: Fix typo of info text in trace_kprobe.c tracing: Fix typo in prof_sysexit_enable() tracing: Remove CONFIG_TRACE_POWER from kernel config tracing: Fix ftrace_event_call alignment for use with gcc 4.5 ftrace: Remove memory barriers from NMI code when not needed tracing/kprobes: Add short documentation for HAVE_REGS_AND_STACK_ACCESS_API s390: Add pt_regs register and stack access API tracing/kprobes: Make Kconfig dependencies generic tracing: Unify arch_syscall_addr() implementations tracing: Add notrace to TRACE_EVENT implementation functions ftrace: Allow to remove a single function from function graph filter tracing: Add correct/incorrect to sort keys for branch annotation output tracing: Simplify test for function_graph tracing start point tracing: Drop the tr check from the graph tracing path tracing: Add stack dump to trace_printk if stacktrace option is set tracing: Use appropriate perl constructs in recordmcount.pl tracing: optimize recordmcount.pl for offsets-handling ...
2010-02-28Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (44 commits) rcu: Fix accelerated GPs for last non-dynticked CPU rcu: Make non-RCU_PROVE_LOCKING rcu_read_lock_sched_held() understand boot rcu: Fix accelerated grace periods for last non-dynticked CPU rcu: Export rcu_scheduler_active rcu: Make rcu_read_lock_sched_held() take boot time into account rcu: Make lockdep_rcu_dereference() message less alarmist sched, cgroups: Fix module export rcu: Add RCU_CPU_STALL_VERBOSE to dump detailed per-task information rcu: Fix rcutorture mod_timer argument to delay one jiffy rcu: Fix deadlock in TREE_PREEMPT_RCU CPU stall detection rcu: Convert to raw_spinlocks rcu: Stop overflowing signed integers rcu: Use canonical URL for Mathieu's dissertation rcu: Accelerate grace period if last non-dynticked CPU rcu: Fix citation of Mathieu's dissertation rcu: Documentation update for CONFIG_PROVE_RCU security: Apply lockdep-based checking to rcu_dereference() uses idr: Apply lockdep-based diagnostics to rcu_dereference() uses radix-tree: Disable RCU lockdep checking in radix tree vfs: Abstract rcu_dereference_check for files-fdtable use ...
2010-02-28Merge branches 'core-ipi-for-linus', 'core-locking-for-linus', ↵Linus Torvalds
'tracing-fixes-for-linus', 'x86-debug-for-linus', 'x86-doc-for-linus', 'x86-gpu-for-linus' and 'x86-rlimit-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-ipi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: generic-ipi: Optimize accesses by using DEFINE_PER_CPU_SHARED_ALIGNED for IPI data * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: plist: Fix grammar mistake, and c-style mistake * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: kprobes: Add mcount to the kprobes blacklist * 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86_64: Print modules like i386 does * 'x86-doc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Put 'nopat' in kernel-parameters * 'x86-gpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86-64: Allow fbdev primary video code * 'x86-rlimit-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Use helpers for rlimits
2010-02-27Merge branch 'tip/tracing/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into tracing/core
2010-02-27Merge branch 'tracing/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into tracing/core
2010-02-27rcu: Fix accelerated GPs for last non-dynticked CPUPaul E. McKenney
This patch disables irqs across the call to rcu_needs_cpu(). It also enforces a hold-off period so that the idle loop doesn't softirq itself to death when there are lots of RCU callbacks in flight on the last non-dynticked CPU. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1267231138-27856-3-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-27rcu: Fix accelerated grace periods for last non-dynticked CPUPaul E. McKenney
It is invalid to invoke __rcu_process_callbacks() with irqs disabled, so do it indirectly via raise_softirq(). This requires a state-machine implementation to cycle through the grace-period machinery the required number of times. Located-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1267231138-27856-1-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM / Hibernate: Fix preallocating of memory PM / Hibernate: Remove swsusp.c finally PM / Hibernate: Remove trailing space in message PM: Allow SCSI devices to suspend/resume asynchronously PM: Allow USB devices to suspend/resume asynchronously USB: implement non-tree resume ordering constraints for PCI host controllers PM: Allow PCI devices to suspend/resume asynchronously PM / Hibernate: Swap, remove useless check from swsusp_read() PM / Hibernate: Really deprecate deprecated user ioctls PM: Allow device drivers to use dpm_wait() PM: Start asynchronous resume threads upfront PM: Add facility for advanced testing of async suspend/resume PM: Add a switch for disabling/enabling asynchronous suspend/resume PM: Asynchronous suspend and resume of devices PM: Add parent information to timing messages PM: Document device power attributes in sysfs PM / Runtime: Add sysfs switch for disabling device run-time PM
2010-02-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (31 commits) crypto: aes_generic - Fix checkpatch errors crypto: fcrypt - Fix checkpatch errors crypto: ecb - Fix checkpatch errors crypto: des_generic - Fix checkpatch errors crypto: deflate - Fix checkpatch errors crypto: crypto_null - Fix checkpatch errors crypto: cipher - Fix checkpatch errors crypto: crc32 - Fix checkpatch errors crypto: compress - Fix checkpatch errors crypto: cast6 - Fix checkpatch errors crypto: cast5 - Fix checkpatch errors crypto: camellia - Fix checkpatch errors crypto: authenc - Fix checkpatch errors crypto: api - Fix checkpatch errors crypto: anubis - Fix checkpatch errors crypto: algapi - Fix checkpatch errors crypto: blowfish - Fix checkpatch errors crypto: aead - Fix checkpatch errors crypto: ablkcipher - Fix checkpatch errors crypto: pcrypt - call the complete function on error ...
2010-02-26ftrace: Add function names to dangling } in function graph tracerSteven Rostedt
The function graph tracer is currently the most invasive tracer in the ftrace family. It can easily overflow the buffer even with 10megs per CPU. This means that events can often be lost. On start up, or after events are lost, if the function return is recorded but the function enter was lost, all we get to see is the exiting '}'. Here is how a typical trace output starts: [tracing] cat trace # tracer: function_graph # # CPU DURATION FUNCTION CALLS # | | | | | | | 0) + 91.897 us | } 0) ! 567.961 us | } 0) <========== | 0) ! 579.083 us | _raw_spin_lock_irqsave(); 0) 4.694 us | _raw_spin_unlock_irqrestore(); 0) ! 594.862 us | } 0) ! 603.361 us | } 0) ! 613.574 us | } 0) ! 623.554 us | } 0) 3.653 us | fget_light(); 0) | sock_poll() { There are a series of '}' with no matching "func() {". There's no information to what functions these ending brackets belong to. This patch adds a stack on the per cpu structure used in outputting the function graph tracer to keep track of what function was outputted. Then on a function exit event, it checks the depth to see if the function exit has a matching entry event. If it does, then it only prints the '}', otherwise it adds the function name after the '}'. This allows function exit events to show what function they belong to at trace output startup, when the entry was lost due to ring buffer overflow, or even after a new task is scheduled in. Here is what the above trace will look like after this patch: [tracing] cat trace # tracer: function_graph # # CPU DURATION FUNCTION CALLS # | | | | | | | 0) + 91.897 us | } (irq_exit) 0) ! 567.961 us | } (smp_apic_timer_interrupt) 0) <========== | 0) ! 579.083 us | _raw_spin_lock_irqsave(); 0) 4.694 us | _raw_spin_unlock_irqrestore(); 0) ! 594.862 us | } (add_wait_queue) 0) ! 603.361 us | } (__pollwait) 0) ! 613.574 us | } (tcp_poll) 0) ! 623.554 us | } (sock_poll) 0) 3.653 us | fget_light(); 0) | sock_poll() { Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-02-26PM / Hibernate: Fix preallocating of memoryRafael J. Wysocki
The hibernate memory preallocation code allocates memory to push some user space data out of physical RAM, so that the hibernation image is not too large. It allocates more memory than necessary for creating the image, so it has to release some pages to make room for allocations made while suspending devices and disabling nonboot CPUs, or the system will hang due to the lack of free pages to allocate from. Unfortunately, the function used for freeing these pages, free_unnecessary_pages(), contains a bug that prevents it from doing the job on all systems without highmem. Fix this problem, which is a regression from the 2.6.30 kernel, by using the right condition for the termination of the loop in free_unnecessary_pages(). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Alan Jenkins <sourcejedi.lkml@googlemail.com> Cc: stable@kernel.org
2010-02-26PM / Hibernate: Remove swsusp.c finallyJiri Slaby
Its contents and entry in Makefile were already removed in 8e60c6a1348e17e68ad73589a52a03876e7059be (Shift remaining code from swsusp.c to hibernate.c) but somehow it remained in-place (rjw: which most likely was my mistake). Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Nigel Cunningham <nigel@tuxonice.net> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-02-26PM / Hibernate: Remove trailing space in messageFrans Pop
Remove a trailing space from a message in swsusp_save(). Signed-off-by: Frans Pop <elendil@planet.nl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-02-26PM / Hibernate: Swap, remove useless check from swsusp_read()Jiri Slaby
It will never reach here if the sws_resume_bdev is erratic. swsusp_read() is called only from software_resume(), but after swsusp_check() which would catch the error state. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-02-26PM / Hibernate: Really deprecate deprecated user ioctlsJiri Slaby
They were deprecated and removed from exported headers more than 2 years ago. Inform users about their removal in the future now. (Switch cases needed to be reorderded for an easy fall through.) And add an entry to feature-removal-schedule. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-02-26PM: Add facility for advanced testing of async suspend/resumeRafael J. Wysocki
Add configuration switch CONFIG_PM_ADVANCED_DEBUG for compiling in extra PM debugging/testing code allowing one to access some PM-related attributes of devices from the user space via sysfs. If CONFIG_PM_ADVANCED_DEBUG is set, add sysfs attribute power/async for every device allowing the user space to access the device's power.async_suspend flag and modify it, if desired. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-02-26PM: Add a switch for disabling/enabling asynchronous suspend/resumeRafael J. Wysocki
Add sysfs attribute /sys/power/pm_async allowing the user space to disable/enable asynchronous suspend/resume of devices. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-02-26Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (48 commits) x86/PCI: Prevent mmconfig memory corruption ACPI: Use GPE reference counting to support shared GPEs x86/PCI: use host bridge _CRS info by default on 2008 and newer machines PCI: augment bus resource table with a list PCI: add pci_bus_for_each_resource(), remove direct bus->resource[] refs PCI: read bridge windows before filling in subtractive decode resources PCI: split up pci_read_bridge_bases() PCIe PME: use pci_pcie_cap() PCI PM: Run-time callbacks for PCI bus type PCIe PME: use pci_is_pcie() PCI / ACPI / PM: Platform support for PCI PME wake-up ACPI / ACPICA: Multiple system notify handlers per device ACPI / PM: Add more run-time wake-up fields ACPI: Use GPE reference counting to support shared GPEs PCI PM: Make it possible to force using INTx for PCIe PME signaling PCI PM: PCIe PME root port service driver PCI PM: Add function for checking PME status of devices PCI: mark is_pcie obsolete PCI: set PCI_PREF_RANGE_TYPE_64 in pci_bridge_check_ranges PCI: pciehp: second try to get big range for pcie devices ...
2010-02-26perf_event: Fix preempt warning in perf_clock()Peter Zijlstra
A recent commit introduced a preemption warning for perf_clock(), use raw_smp_processor_id() to avoid this, it really doesn't matter which cpu we use here. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1267198583.22519.684.camel@laptop> Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-26sched: Fix SCHED_MC regression caused by change in sched cpu_powerSuresh Siddha
On platforms like dual socket quad-core platform, the scheduler load balancer is not detecting the load imbalances in certain scenarios. This is leading to scenarios like where one socket is completely busy (with all the 4 cores running with 4 tasks) and leaving another socket completely idle. This causes performance issues as those 4 tasks share the memory controller, last-level cache bandwidth etc. Also we won't be taking advantage of turbo-mode as much as we would like, etc. Some of the comparisons in the scheduler load balancing code are comparing the "weighted cpu load that is scaled wrt sched_group's cpu_power" with the "weighted average load per task that is not scaled wrt sched_group's cpu_power". While this has probably been broken for a longer time (for multi socket numa nodes etc), the problem got aggrevated via this recent change: | | commit f93e65c186ab3c05ce2068733ca10e34fd00125e | Author: Peter Zijlstra <a.p.zijlstra@chello.nl> | Date: Tue Sep 1 10:34:32 2009 +0200 | | sched: Restore __cpu_power to a straight sum of power | Also with this change, the sched group cpu power alone no longer reflects the group capacity that is needed to implement MC, MT performance (default) and power-savings (user-selectable) policies. We need to use the computed group capacity (sgs.group_capacity, that is computed using the SD_PREFER_SIBLING logic in update_sd_lb_stats()) to find out if the group with the max load is above its capacity and how much load to move etc. Reported-by: Ma Ling <ling.ma@intel.com> Initial-Analysis-by: Zhang, Yanmin <yanmin_zhang@linux.intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> [ -v2: build fix ] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@kernel.org> # [2.6.32.x, 2.6.33.x] LKML-Reference: <1266970432.11588.22.camel@sbs-t61.sc.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-26perf_events: Simplify code by removing cpu argument to hw_perf_group_sched_in()Peter Zijlstra
Since the cpu argument to hw_perf_group_sched_in() is always smp_processor_id(), simplify the code a little by removing this argument and using the current cpu where needed. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1265890918.5396.3.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-26perf_events, x86: AMD event schedulingStephane Eranian
This patch adds correct AMD NorthBridge event scheduling. NB events are events measuring L3 cache, Hypertransport traffic. They are identified by an event code >= 0xe0. They measure events on the Northbride which is shared by all cores on a package. NB events are counted on a shared set of counters. When a NB event is programmed in a counter, the data actually comes from a shared counter. Thus, access to those counters needs to be synchronized. We implement the synchronization such that no two cores can be measuring NB events using the same counters. Thus, we maintain a per-NB allocation table. The available slot is propagated using the event_constraint structure. Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <4b703957.0702d00a.6bf2.7b7d@mx.google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-26perf_events: Add new start/stop PMU callbacksStephane Eranian
In certain situations, the kernel may need to stop and start the same event rapidly. The current PMU callbacks do not distinguish between stop and release (i.e., stop + free the resource). Thus, a counter may be released, then it will be immediately re-acquired. Event scheduling will again take place with no guarantee to assign the same counter. On some processors, this may event yield to failure to assign the event back due to competion between cores. This patch is adding a new pair of callback to stop and restart a counter without actually release the underlying counter resource. On stop, the counter is stopped, its values saved and that's it. On start, the value is reloaded and counter is restarted (on x86, actual restart is delayed until perf_enable()). Signed-off-by: Stephane Eranian <eranian@google.com> [ added fallback to ->enable/->disable for all other PMUs fixed x86_pmu_start() to call x86_pmu.enable() merged __x86_pmu_disable into x86_pmu_stop() ] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <4b703875.0a04d00a.7896.ffffb824@mx.google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-26perf_events: Report the MMAP pgoff value in bytesPeter Zijlstra
DaveM reported that currently perf interprets the pgoff value reported by the MMAP events as a byte range, but the kernel reports it as a page offset. Since its broken (and unusable) anyway, change the kernel behaviour (ABI) to report bytes indeed, avoiding the need for userspace to deal with PAGE_SIZE things. Reported-by: David Miller <davem@davemloft.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-26Merge branch 'tip/tracing/core' of ↵Ingo Molnar
2010-02-26Merge commit 'v2.6.33' into tracing/coreIngo Molnar
Conflicts: scripts/recordmcount.pl Merge reason: Merge up to v2.6.33. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-26rcu: Export rcu_scheduler_activePaul E. McKenney
Kernel modules using rcu_read_lock_sched_held() must now have access to rcu_scheduler_active, so it must be exported. This should fix the fix for the boot-time RCU-lockdep splat. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <20100226030230.GA7743@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-26rcu: Make rcu_read_lock_sched_held() take boot time into accountPaul E. McKenney
Before the scheduler starts, all tasks are non-preemptible by definition. So, during that time, rcu_read_lock_sched_held() needs to always return "true". This patch makes that be so. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1267135607-7056-2-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
