path: root/kernel
2013-02-14stop_machine: Use smpboot threadsThomas Gleixner
Use the smpboot thread infrastructure. Mark the stopper thread selfparking and park it after it has finished the take_cpu_down() work. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Arjan van de Veen <arjan@infradead.org> Cc: Paul Turner <pjt@google.com> Cc: Richard Weinberger <rw@linutronix.de> Cc: Magnus Damm <magnus.damm@gmail.com> Link: http://lkml.kernel.org/r/20130131120741.686315164@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-02-14stop_machine: Store task reference in a separate per cpu variableThomas Gleixner
To allow the stopper thread being managed by the smpboot thread infrastructure separate out the task storage from the stopper data structure. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Arjan van de Veen <arjan@infradead.org> Cc: Paul Turner <pjt@google.com> Cc: Richard Weinberger <rw@linutronix.de> Cc: Magnus Damm <magnus.damm@gmail.com> Link: http://lkml.kernel.org/r/20130131120741.626690384@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-02-14smpboot: Allow selfparking per cpu threadsThomas Gleixner
The stop machine threads are still killed when a cpu goes offline. The reason is that the thread is used to bring the cpu down, so it can't be parked along with the other per cpu threads. Allow a per cpu thread to be excluded from automatic parking, so it can park itself once it's done Add a create callback function as well. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Arjan van de Veen <arjan@infradead.org> Cc: Paul Turner <pjt@google.com> Cc: Richard Weinberger <rw@linutronix.de> Cc: Magnus Damm <magnus.damm@gmail.com> Link: http://lkml.kernel.org/r/20130131120741.553993267@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-02-05Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Three small fixlets" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/debug: Fix format string for 32-bit platforms sched: Fix warning in kernel/sched/fair.c sched/rt: Use root_domain of rt_rq not current processor
2013-02-05Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Three fixlets and two small (and low risk) hw-enablement changes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf: Fix event group context move x86/perf: Add IvyBridge EP support perf/x86: Fix P6 driver section warning arch/x86/tools/insn_sanity.c: Identify source of messages perf/x86: Enable Intel Lincroft/Penwell/Cloverview Atom support
2013-02-05Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull two small RCU fixlets from Ingo Molnar. * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: rcu: Make rcu_nocb_poll an early_param instead of module_param rcu: Prevent soft-lockup complaints about no-CBs CPUs
2013-02-03perf: Fix event group context moveJiri Olsa
When we have group with mixed events (hw/sw) we want to end up with group leader being in hw context. So if group leader is initialy sw event, we move all the events under hw context. The move is done for each event by removing it from its context and adding it back into proper one. As a part of the removal the event is automatically disabled, which is not what we want at this stage of creating groups. The fix is to initialize event state after removal from sw context. This fix resulted from the following discussion: http://thread.gmane.org/gmane.linux.kernel.perf.user/1144 Reported-by: Andreas Hollmann <hollmann@in.tum.de> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Vince Weaver <vince@deater.net> Link: http://lkml.kernel.org/r/1359714225-4231-1-git-send-email-jolsa@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-01-31Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: "This is a collection of miscellaneous fixes, the most important one is the fix for the Samsung laptop bricking issue (auto-blacklisting the samsung-laptop driver); the efi_enabled() changes you see below are prerequisites for that fix. The other issues fixed are booting on OLPC XO-1.5, an UV fix, NMI debugging, and requiring CAP_SYS_RAWIO for MSR references, just as with I/O port references." * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: samsung-laptop: Disable on EFI hardware efi: Make 'efi_enabled' a function to query EFI facilities smp: Fix SMP function call empty cpu mask race x86/msr: Add capabilities check x86/dma-debug: Bump PREALLOC_DMA_DEBUG_ENTRIES x86/olpc: Fix olpc-xo1-sci.c build errors arch/x86/platform/uv: Fix incorrect tlb flush all issue x86-64: Fix unwind annotations in recent NMI changes x86-32: Start out cr0 clean, disable paging before modifying cr3/4
2013-01-31Revert "console: implement lockdep support for console_lock"Dave Airlie
This reverts commit daee779718a319ff9f83e1ba3339334ac650bb22. I'll requeue this after the console locking fixes, so lockdep is useful again for people until fbcon is fixed. Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-01-28smp: Fix SMP function call empty cpu mask raceWang YanQing
I get the following warning every day with v3.7, once or twice a day: [ 2235.186027] WARNING: at /mnt/sda7/kernel/linux/arch/x86/kernel/apic/ipi.c:109 default_send_IPI_mask_logical+0x2f/0xb8() As explained by Linus as well: | | Once we've done the "list_add_rcu()" to add it to the | queue, we can have (another) IPI to the target CPU that can | now see it and clear the mask. | | So by the time we get to actually send the IPI, the mask might | have been cleared by another IPI. | This patch also fixes a system hang problem, if the data->cpumask gets cleared after passing this point: if (WARN_ONCE(!mask, "empty IPI mask")) return; then the problem in commit 83d349f35e1a ("x86: don't send an IPI to the empty set of CPU's") will happen again. Signed-off-by: Wang YanQing <udknight@gmail.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Jan Beulich <jbeulich@suse.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: peterz@infradead.org Cc: mina86@mina86.org Cc: srivatsa.bhat@linux.vnet.ibm.com Cc: <stable@kernel.org> Link: http://lkml.kernel.org/r/20130126075357.GA3205@udknight [ Tidied up the changelog and the comment in the code. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-01-25sched/debug: Fix format string for 32-bit platformsArnd Bergmann
The type returned from atomic64_t can be either unsigned long or unsigned long long, depending on the architecture. Using a cast to unsigned long long lets us use the same format string for all architectures. Without this patch, building with scheduler debugging enabled results in: kernel/sched/debug.c: In function 'print_cfs_rq': kernel/sched/debug.c:225:2: warning: format '%ld' expects argument of type 'long int', but argument 4 has type 'long long int' [-Wformat] kernel/sched/debug.c:225:2: warning: format '%ld' expects argument of type 'long int', but argument 3 has type 'long long int' [-Wformat] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Turner <pjt@google.com> Cc: linux-arm-kernel@list.infradead.org Link: http://lkml.kernel.org/r/1359123276-15833-7-git-send-email-arnd@arndb.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-01-25sched: Fix warning in kernel/sched/fair.cArnd Bergmann
a4c96ae319 "sched: Unthrottle rt runqueues in __disable_runtime()" turned the unthrottle_offline_cfs_rqs function into a static symbol, which now triggers a warning about it being potentially unused: kernel/sched/fair.c:2055:13: warning: 'unthrottle_offline_cfs_rqs' defined but not used [-Wunused-function] Marking it __maybe_unused shuts up the gcc warning and lets the compiler safely drop the function body when it's not being used. To reproduce, build the ARM bcm2835_defconfig. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Peter Boonstoppel <pboonstoppel@nvidia.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Turner <pjt@google.com> Cc: linux-arm-kernel@list.infradead.org Link: http://lkml.kernel.org/r/1359123276-15833-6-git-send-email-arnd@arndb.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-01-25sched/rt: Use root_domain of rt_rq not current processorShawn Bohrer
When the system has multiple domains do_sched_rt_period_timer() can run on any CPU and may iterate over all rt_rq in cpu_online_mask. This means when balance_runtime() is run for a given rt_rq that rt_rq may be in a different rd than the current processor. Thus if we use smp_processor_id() to get rd in do_balance_runtime() we may borrow runtime from a rt_rq that is not part of our rd. This changes do_balance_runtime to get the rd from the passed in rt_rq ensuring that we borrow runtime only from the correct rd for the given rt_rq. This fixes a BUG at kernel/sched/rt.c:687! in __disable_runtime when we try reclaim runtime lent to other rt_rq but runtime has been lent to a rt_rq in another rd. Signed-off-by: Shawn Bohrer <sbohrer@rgmadvisors.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Mike Galbraith <bitbucket@online.de> Cc: peterz@infradead.org Cc: <stable@kernel.org> Link: http://lkml.kernel.org/r/1358186131-29494-1-git-send-email-sbohrer@rgmadvisors.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-01-24Merge branch 'rcu/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/urgent Pull RCU fixes from Paul E. McKenney. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-01-22async: fix __lowest_in_progress()Tejun Heo
Commit 083b804c4d3e ("async: use workqueue for worker pool") made it possible that async jobs are moved from pending to running out-of-order. While pending async jobs will be queued and dispatched for execution in the same order, nothing guarantees they'll enter "1) move self to the running queue" of async_run_entry_fn() in the same order. Before the conversion, async implemented its own worker pool. An async worker, upon being woken up, fetches the first item from the pending list, which kept the executing lists sorted. The conversion to workqueue was done by adding work_struct to each async_entry and async just schedules the work item. The queueing and dispatching of such work items are still in order but now each worker thread is associated with a specific async_entry and moves that specific async_entry to the executing list. So, depending on which worker reaches that point earlier, which is non-deterministic, we may end up moving an async_entry with larger cookie before one with smaller one. This broke __lowest_in_progress(). running->domain may not be properly sorted and is not guaranteed to contain lower cookies than pending list when not empty. Fix it by ensuring sort-inserting to the running list and always looking at both pending and running when trying to determine the lowest cookie. Over time, the async synchronization implementation became quite messy. We better restructure it such that each async_entry is linked to two lists - one global and one per domain - and not move it when execution starts. There's no reason to distinguish pending and running. They behave the same for synchronization purposes. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-22Merge tag 'trace-3.8-rc4-fix' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull ftrace fix from Steven Rostedt: "Kprobes now uses the function tracer if it can. That is, if a probe is placed on a function mcount/nop location, and the arch supports it, instead of adding a breakpoint, kprobes will register a function callback as that is much more efficient. The function tracer requires to update modules before they run, and uses the module notifier to do so. But if something else in the module notifiers registers a kprobe at one of these locations, before ftrace can get to it, then the system could fail. The function tracer must be initialized early, otherwise module notifiers that probe will only work by chance." * tag 'trace-3.8-rc4-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: ftrace: Be first to run code modification on modules
2013-01-22wake_up_process() should be never used to wakeup a TASK_STOPPED/TRACED taskOleg Nesterov
wake_up_process() should never wakeup a TASK_STOPPED/TRACED task. Change it to use TASK_NORMAL and add the WARN_ON(). TASK_ALL has no other users, probably can be killed. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-22ptrace: ensure arch_ptrace/ptrace_request can never race with SIGKILLOleg Nesterov
putreg() assumes that the tracee is not running and pt_regs_access() can safely play with its stack. However a killed tracee can return from ptrace_stop() to the low-level asm code and do RESTORE_REST, this means that debugger can actually read/modify the kernel stack until the tracee does SAVE_REST again. set_task_blockstep() can race with SIGKILL too and in some sense this race is even worse, the very fact the tracee can be woken up breaks the logic. As Linus suggested we can clear TASK_WAKEKILL around the arch_ptrace() call, this ensures that nobody can ever wakeup the tracee while the debugger looks at it. Not only this fixes the mentioned problems, we can do some cleanups/simplifications in arch_ptrace() paths. Probably ptrace_unfreeze_traced() needs more callers, for example it makes sense to make the tracee killable for oom-killer before access_process_vm(). While at it, add the comment into may_ptrace_stop() to explain why ptrace_stop() still can't rely on SIGKILL and signal_pending_state(). Reported-by: Salman Qazi <sqazi@google.com> Reported-by: Suleiman Souhlal <suleiman@google.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-22ptrace: introduce signal_wake_up_state() and ptrace_signal_wake_up()Oleg Nesterov
Cleanup and preparation for the next change. signal_wake_up(resume => true) is overused. None of ptrace/jctl callers actually want to wakeup a TASK_WAKEKILL task, but they can't specify the necessary mask. Turn signal_wake_up() into signal_wake_up_state(state), reintroduce signal_wake_up() as a trivial helper, and add ptrace_signal_wake_up() which adds __TASK_TRACED. This way ptrace_signal_wake_up() can work "inside" ptrace_request() even if the tracee doesn't have the TASK_WAKEKILL bit set. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-21ftrace: Be first to run code modification on modulesSteven Rostedt
If some other kernel subsystem has a module notifier, and adds a kprobe to a ftrace mcount point (now that kprobes work on ftrace points), when the ftrace notifier runs it will fail and disable ftrace, as well as kprobes that are attached to ftrace points. Here's the error: WARNING: at kernel/trace/ftrace.c:1618 ftrace_bug+0x239/0x280() Hardware name: Bochs Modules linked in: fat(+) stap_56d28a51b3fe546293ca0700b10bcb29__8059(F) nfsv4 auth_rpcgss nfs dns_resolver fscache xt_nat iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack lockd sunrpc ppdev parport_pc parport microcode virtio_net i2c_piix4 drm_kms_helper ttm drm i2c_core [last unloaded: bid_shared] Pid: 8068, comm: modprobe Tainted: GF 3.7.0-0.rc8.git0.1.fc19.x86_64 #1 Call Trace: [<ffffffff8105e70f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff81134106>] ? __probe_kernel_read+0x46/0x70 [<ffffffffa0180000>] ? 0xffffffffa017ffff [<ffffffffa0180000>] ? 0xffffffffa017ffff [<ffffffff8105e76a>] warn_slowpath_null+0x1a/0x20 [<ffffffff810fd189>] ftrace_bug+0x239/0x280 [<ffffffff810fd626>] ftrace_process_locs+0x376/0x520 [<ffffffff810fefb7>] ftrace_module_notify+0x47/0x50 [<ffffffff8163912d>] notifier_call_chain+0x4d/0x70 [<ffffffff810882f8>] __blocking_notifier_call_chain+0x58/0x80 [<ffffffff81088336>] blocking_notifier_call_chain+0x16/0x20 [<ffffffff810c2a23>] sys_init_module+0x73/0x220 [<ffffffff8163d719>] system_call_fastpath+0x16/0x1b ---[ end trace 9ef46351e53bbf80 ]--- ftrace failed to modify [<ffffffffa0180000>] init_once+0x0/0x20 [fat] actual: cc:bb:d2:4b:e1 A kprobe was added to the init_once() function in the fat module on load. But this happened before ftrace could have touched the code. As ftrace didn't run yet, the kprobe system had no idea it was a ftrace point and simply added a breakpoint to the code (0xcc in the cc:bb:d2:4b:e1). Then when ftrace went to modify the location from a call to mcount/fentry into a nop, it didn't see a call op, but instead it saw the breakpoint op and not knowing what to do with it, ftrace shut itself down. The solution is to simply give the ftrace module notifier the max priority. This should have been done regardless, as the core code ftrace modification also happens very early on in boot up. This makes the module modification closer to core modification. Link: http://lkml.kernel.org/r/20130107140333.593683061@goodmis.org Cc: stable@vger.kernel.org Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Reported-by: Frank Ch. Eigler <fche@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-01-20module: fix missing module_mutex unlockLinus Torvalds
Commit 1fb9341ac348 ("module: put modules in list much earlier") moved some of the module initialization code around, and in the process changed the exit paths too. But for the duplicate export symbol error case the change made the ddebug_cleanup path jump to after the module mutex unlock, even though it happens with the mutex held. Rusty has some patches to split this function up into some helper functions, hopefully the mess of complex goto targets will go away eventually. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-20Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module fixes and a virtio block fix from Rusty Russell: "Various minor fixes, but a slightly more complex one to fix the per-cpu overload problem introduced recently by kvm id changes." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: module: put modules in list much earlier. module: add new state MODULE_STATE_UNFORMED. module: prevent warning when finit_module a 0 sized file virtio-blk: Don't free ida when disk is in use
2013-01-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull misc syscall fixes from Al Viro: - compat syscall fixes (discussed back in December) - a couple of "make life easier for sigaltstack stuff by reducing inter-tree dependencies" - fix up compiler/asmlinkage calling convention disagreement of sys_clone() - misc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: sys_clone() needs asmlinkage_protect make sure that /linuxrc has std{in,out,err} x32: fix sigtimedwait x32: fix waitid() switch compat_sys_wait4() and compat_sys_waitid() to COMPAT_SYSCALL_DEFINE switch compat_sys_sigaltstack() to COMPAT_SYSCALL_DEFINE CONFIG_GENERIC_SIGALTSTACK build breakage with asm-generic/syscalls.h Ensure that kernel_init_freeable() is not inlined into non __init code
2013-01-20ia64: kill thread_matches(), unexport ptrace_check_attach()Oleg Nesterov
The ia64 function "thread_matches()" has no users since commit e868a55c2a8c ("[IA64] remove find_thread_for_addr()"). Remove it. This allows us to make ptrace_check_attach() static to kernel/ptrace.c, which is good since we'll need to change the semantics of it and fix up all the callers. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-19sys_clone() needs asmlinkage_protectAl Viro
Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-01-16module, async: async_synchronize_full() on module init iff async is usedTejun Heo
If the default iosched is built as module, the kernel may deadlock while trying to load the iosched module on device probe if the probing was running off async. This is because async_synchronize_full() at the end of module init ends up waiting for the async job which initiated the module loading. async A modprobe 1. finds a device 2. registers the block device 3. request_module(default iosched) 4. modprobe in userland 5. load and init module 6. async_synchronize_full() Async A waits for modprobe to finish in request_module() and modprobe waits for async A to finish in async_synchronize_full(). Because there's no easy to track dependency once control goes out to userland, implementing properly nested flushing is difficult. For now, make module init perform async_synchronize_full() iff module init has queued async jobs as suggested by Linus. This avoids the described deadlock because iosched module doesn't use async and thus wouldn't invoke async_synchronize_full(). This is hacky and incomplete. It will deadlock if async module loading nests; however, this works around the known problem case and seems to be the best of bad options. For more details, please refer to the following thread. http://thread.gmane.org/gmane.linux.kernel/1420814 Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Alex Riesen <raa.lkml@gmail.com> Tested-by: Ming Lei <ming.lei@canonical.com> Tested-by: Alex Riesen <raa.lkml@gmail.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-14Merge tag 'trace-3.8-rc3-regression-fix' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing regression fixes from Steven Rostedt: "The clean up patch commit 0fb9656d957d "tracing: Make tracing_enabled be equal to tracing_on" caused two regressions. 1) The irqs off latency tracer no longer starts if tracing_on is off when the tracer is set, and then tracing_on is enabled. The tracing_on file needs the hook that tracing_enabled had to enable tracers if they request it (call the tracer's start() method). 2) That commit had a separate change that really should have been a separate patch, but it must have been added accidently with the -a option of git commit. But as the change is still related to the commit it wasn't noticed in review. That change, changed the way blocking is done by the trace_pipe file with respect to the tracing_on settings. I've been told that this change breaks current userspace, and this specific change is being reverted." * tag 'trace-3.8-rc3-regression-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Fix regression of trace_pipe tracing: Fix regression with irqsoff tracer and tracing_on file
2013-01-14tracing: Fix regression of trace_pipeLiu Bo
Commit 0fb9656d "tracing: Make tracing_enabled be equal to tracing_on" changes the behaviour of trace_pipe, ie. it makes trace_pipe return if we've read something and tracing is enabled, and this means that we have to 'cat trace_pipe' again and again while running tests. IMO the right way is if tracing is enabled, we always block and wait for ring buffer, or we may lose what we want since ring buffer's size is limited. Link: http://lkml.kernel.org/r/1358132051-5410-1-git-send-email-bo.li.liu@oracle.com Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-01-12module: put modules in list much earlier.Rusty Russell
Prarit's excellent bug report: > In recent Fedora releases (F17 & F18) some users have reported seeing > messages similar to > > [ 15.478160] kvm: Could not allocate 304 bytes percpu data > [ 15.478174] PERCPU: allocation failed, size=304 align=32, alloc from > reserved chunk failed > > during system boot. In some cases, users have also reported seeing this > message along with a failed load of other modules. > > What is happening is systemd is loading an instance of the kvm module for > each cpu found (see commit e9bda3b). When the module load occurs the kernel > currently allocates the modules percpu data area prior to checking to see > if the module is already loaded or is in the process of being loaded. If > the module is already loaded, or finishes load, the module loading code > releases the current instance's module's percpu data. Now we have a new state MODULE_STATE_UNFORMED, we can insert the module into the list (and thus guarantee its uniqueness) before we allocate the per-cpu region. Reported-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Tested-by: Prarit Bhargava <prarit@redhat.com>
2013-01-12module: add new state MODULE_STATE_UNFORMED.Rusty Russell
You should never look at such a module, so it's excised from all paths which traverse the modules list. We add the state at the end, to avoid gratuitous ABI break (ksplice). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-01-11kernel/audit.c: avoid negative sleep durationsAndrew Morton
audit_log_start() performs the same jiffies comparison in two places. If sufficient time has elapsed between the two comparisons, the second one produces a negative sleep duration: schedule_timeout: wrong timeout value fffffffffffffff0 Pid: 6606, comm: trinity-child1 Not tainted 3.8.0-rc1+ #43 Call Trace: schedule_timeout+0x305/0x340 audit_log_start+0x311/0x470 audit_log_exit+0x4b/0xfb0 __audit_syscall_exit+0x25f/0x2c0 sysret_audit+0x17/0x21 Fix it by performing the comparison a single time. Reported-by: Dave Jones <davej@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Paris <eparis@redhat.com> Reviewed-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-11audit: catch possible NULL audit buffersKees Cook
It's possible for audit_log_start() to return NULL. Handle it in the various callers. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Paris <eparis@redhat.com> Cc: Jeff Layton <jlayton@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Julien Tinnes <jln@google.com> Cc: Will Drewry <wad@google.com> Cc: Steve Grubb <sgrubb@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-11audit: create explicit AUDIT_SECCOMP event typeKees Cook
The seccomp path was using AUDIT_ANOM_ABEND from when seccomp mode 1 could only kill a process. While we still want to make sure an audit record is forced on a kill, this should use a separate record type since seccomp mode 2 introduces other behaviors. In the case of "handled" behaviors (process wasn't killed), only emit a record if the process is under inspection. This change also fixes userspace examination of seccomp audit events, since it was considered malformed due to missing fields of the AUDIT_ANOM_ABEND event type. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Paris <eparis@redhat.com> Cc: Jeff Layton <jlayton@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Julien Tinnes <jln@google.com> Acked-by: Will Drewry <wad@chromium.org> Acked-by: Steve Grubb <sgrubb@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-11lockdep, rwsem: provide down_write_nest_lock()Jiri Kosina
down_write_nest_lock() provides a means to annotate locking scenario where an outer lock is guaranteed to serialize the order nested locks are being acquired. This is analogoue to already existing mutex_lock_nest_lock() and spin_lock_nest_lock(). Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mel Gorman <mel@csn.ul.ie> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-11tracing: Fix regression with irqsoff tracer and tracing_on fileSteven Rostedt
Commit 02404baf1b47 "tracing: Remove deprecated tracing_enabled file" removed the tracing_enabled file as it never worked properly and the tracing_on file should be used instead. But the tracing_on file didn't call into the tracers start/stop routines like the tracing_enabled file did. This caused trace-cmd to break when it enabled the irqsoff tracer. If you just did "echo irqsoff > current_tracer" then it would work properly. But the tool trace-cmd disables tracing first by writing "0" into the tracing_on file. Then it writes "irqsoff" into current_tracer and then writes "1" into tracing_on. Unfortunately, the above commit changed the irqsoff tracer to check the tracing_on status instead of the tracing_enabled status. If it's disabled then it does not start the tracer internals. The problem is that writing "1" into tracing_on does not call the tracers "start" routine like writing "1" into tracing_enabled did. This makes the irqsoff tracer not start when using the trace-cmd tool, and is a regression for userspace. Simple fix is to have the tracing_on file call the tracers start() method when being enabled (and the stop() method when disabled). Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-01-10audit: fix auditfilter.c kernel-doc warningsRandy Dunlap
Fix new kernel-doc warning in auditfilter.c: Warning(kernel/auditfilter.c:1157): Excess function parameter 'uid' description in 'audit_receive_filter' Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Paris <eparis@redhat.com> Cc: linux-audit@redhat.com (subscribers-only) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-10Merge tag 'trace-3.8-rc2-regression-fix' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing regression fix from Steven Rostedt: "A change that came in this merge window broke the writing to the trace_options file. It causes garbage to be read during the compare of option names, and breaks setting options via the trace_options file, although options can still be set via the options/<option> files." * tag 'trace-3.8-rc2-regression-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Fix regression of trace_options file setting
2013-01-09tracing: Fix regression of trace_options file settingSteven Rostedt
The latest change to allow trace options to be set on the command line also broke the trace_options file. The zeroing of the last byte of the option name that is echoed into the trace_option file was removed with the consolidation of some of the code. The compare between the option and what was written to the trace_options file fails because the string holding the data written doesn't terminate with a null character. A zero needs to be added to the end of the string copied from user space. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-01-08rcu: Make rcu_nocb_poll an early_param instead of module_paramPaul Gortmaker
The as-documented rcu_nocb_poll will fail to enable this feature for two reasons. (1) there is an extra "s" in the documented name which is not in the code, and (2) since it uses module_param, it really is expecting a prefix, akin to "rcutree.fanout_leaf" and the prefix isn't documented. However, there are several reasons why we might not want to simply fix the typo and add the prefix: 1) we'd end up with rcutree.rcu_nocb_poll, and rather probably make a change to rcutree.nocb_poll 2) if we did #1, then the prefix wouldn't be consistent with the rcu_nocbs=<cpumap> parameter (i.e. one with, one without prefix) 3) the use of module_param in a header file is less than desired, since it isn't immediately obvious that it will get processed via rcutree.c and get the prefix from that (although use of module_param_named() could clarify that.) 4) the implied export of /sys/module/rcutree/parameters/rcu_nocb_poll data to userspace via module_param() doesn't really buy us anything, as it is read-only and we can tell if it is enabled already without it, since there is a printk at early boot telling us so. In light of all that, just change it from a module_param() to an early_setup() call, and worry about adding it to /sys later on if we decide to allow a dynamic setting of it. Also change the variable to be tagged as read_mostly, since it will only ever be fiddled with at most, once at boot. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2013-01-08rcu: Prevent soft-lockup complaints about no-CBs CPUsPaul Gortmaker
The wait_event() at the head of the rcu_nocb_kthread() can result in soft-lockup complaints if the CPU in question does not register RCU callbacks for an extended period. This commit therefore changes the wait_event() to a wait_event_interruptible(). Reported-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2013-01-07Merge branch 'akpm' (fixes from Andrew)Linus Torvalds
Merge emailed fixes from Andrew Morton: "Bunch of fixes: - delayed IPC updates. I held back on this because of some possible outstanding bug reports, but they appear to have been addressed in later versions - A bunch of MAINTAINERS updates - Yet Another RTC driver. I'd held this back while a couple of little issues were being worked out. I'm expecting an intrusive-but-simple patchset from Joe Perches which splits up printk.c into kernel/printk/*. That will be a pig to maintain for two months so if it passes testing I'd like to get it upstream after a week or so." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (35 commits) printk: fix incorrect length from print_time() when seconds > 99999 drivers/rtc/rtc-vt8500.c: fix handling of data passed in struct rtc_time drivers/rtc/rtc-vt8500.c: correct handling of CR_24H bitfield rtc: add RTC driver for TPS6586x MAINTAINERS: fix drivers/staging/sm7xx/ MAINTAINERS: remove include/linux/of_pwm.h MAINTAINERS: remove arch/*/lib/perf_event*.c MAINTAINERS: remove drivers/mmc/host/imxmmc.* MAINTAINERS: fix Documentation/mei/ MAINTAINERS: remove arch/x86/platform/mrst/pmu.* MAINTAINERS: remove firmware/isci/ MAINTAINERS: fix drivers/ieee802154/ MAINTAINERS: fix .../plat-mxc/include/mach/imxfb.h MAINTAINERS: remove drivers/video/epson1355fb.c MAINTAINERS: fix drivers/media/usb/dvb-usb/cxusb* MAINTAINERS: adjust for UAPI MAINTAINERS: fix drivers/media/platform/atmel-isi.c MAINTAINERS: fix arch/arm/mach-at91/include/mach/at_hdmac.h MAINTAINERS: fix drivers/rtc/rtc-vt8500.c MAINTAINERS: remove arch/arm/plat-s5p/ ...
2013-01-05signals: set_current_blocked() can use __set_current_blocked()Oleg Nesterov
Cleanup. And I think we need more cleanups, in particular __set_current_blocked() and sigprocmask() should die. Nobody should ever block SIGKILL or SIGSTOP. - Change set_current_blocked() to use __set_current_blocked() - Change sys_sigprocmask() to use set_current_blocked(), this way it should not worry about SIGKILL/SIGSTOP. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-05signals: sys_ssetmask() uses uninitialized newmaskOleg Nesterov
Commit 77097ae503b1 ("most of set_current_blocked() callers want SIGKILL/SIGSTOP removed from set") removed the initialization of newmask by accident, causing ltp to complain like this: ssetmask01 1 TFAIL : sgetmask() failed: TEST_ERRNO=???(0): Success Restore the proper initialization. Reported-and-tested-by: CAI Qian <caiqian@redhat.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: stable@kernel.org # v3.5+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04printk: fix incorrect length from print_time() when seconds > 99999Roland Dreier
print_prefix() passes a NULL buf to print_time() to get the length of the time prefix; when printk times are enabled, the current code just returns the constant 15, which matches the format "[%5lu.%06lu] " used to print the time value. However, this is obviously incorrect when the whole seconds part of the time gets beyond 5 digits (100000 seconds is a bit more than a day of uptime). The simple fix is to use snprintf(NULL, 0, ...) to calculate the actual length of the time prefix. This could be micro-optimized but it seems better to have simpler, more readable code here. The bug leads to the syslog system call miscomputing which messages fit into the userspace buffer. If there are enough messages to fill log_buf_len and some have a timestamp >= 100000, dmesg may fail with: # dmesg klogctl: Bad address When this happens, strace shows that the failure is indeed EFAULT due to the kernel mistakenly accessing past the end of dmesg's buffer, since dmesg asks the kernel how big a buffer it needs, allocates a bit more, and then gets an error when it asks the kernel to fill it: syslog(0xa, 0, 0) = 1048576 mmap(NULL, 1052672, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fa4d25d2000 syslog(0x3, 0x7fa4d25d2010, 0x100008) = -1 EFAULT (Bad address) As far as I can see, the bug has been there as long as print_time(), which comes from commit 084681d14e42 ("printk: flush continuation lines immediately to console") in 3.5-rc5. Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Joe Perches <joe@perches.com> Cc: Sylvain Munaut <s.munaut@whatever-company.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-03module: prevent warning when finit_module a 0 sized fileSasha Levin
If we try to finit_module on a file sized 0 bytes vmalloc will scream and spit out a warning. Since modules have to be bigger than 0 bytes anyways we can just check that beforehand and avoid the warning. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-12-26x32: fix sigtimedwaitAl Viro
It needs 64bit timespec. As it is, we end up truncating the timeout to whole seconds; usually it doesn't matter, but for having all sub-second timeouts truncated to one jiffy is visibly wrong. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-26x32: fix waitid()Al Viro
It needs 64bit rusage and 32bit siginfo. glibc never calls it with non-NULL rusage pointer, or we would've seen breakage already... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-26switch compat_sys_wait4() and compat_sys_waitid() to COMPAT_SYSCALL_DEFINEAl Viro
Strictly speaking, ppc64 needs it for C ABI compliance. Realistically I would be very surprised if e.g. passing 0xffffffff as 'options' argument to waitid() from 32bit task would cause problems, but yes, it puts us into undefined behaviour territory. ppc64 expects int argument to be passed in 64bit register with bits 31..63 containing the same value. SYSCALL_DEFINE on ppc provides a wrapper that normalizes the value passed from userland; so does COMPAT_SYSCALL_DEFINE. Plain declaration of compat_sys_something() with an int argument obviously doesn't. Again, for wait4 and waitid I would be extremely surprised if gcc started to produce code depending on that value having been properly sign-extended - the argument(s) in question end up passed blindly to sys_wait4 and sys_waitid resp. and normalization for native syscalls takes care of their use there. Still, better to use COMPAT_SYSCALL_DEFINE here than worry about nasal daemons... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-26switch compat_sys_sigaltstack() to COMPAT_SYSCALL_DEFINEAl Viro
Makes sigaltstack conversion easier to split into per-architecture parts. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-25pidns: Stop pid allocation when init diesEric W. Biederman
Oleg pointed out that in a pid namespace the sequence. - pid 1 becomes a zombie - setns(thepidns), fork,... - reaping pid 1. - The injected processes exiting. Can lead to processes attempting access their child reaper and instead following a stale pointer. That waitpid for init can return before all of the processes in the pid namespace have exited is also unfortunate. Avoid these problems by disabling the allocation of new pids in a pid namespace when init dies, instead of when the last process in a pid namespace is reaped. Pointed-out-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
