path: root/kernel
2018-03-20genirq: Cleanup top of file commentsThomas Gleixner
Remove pointless references to the file name itself and condense the information so it wastes less space. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Cc: Kate Stewart <kstewart@linuxfoundation.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Philippe Ombredanne <pombredanne@nexb.com> Link: https://lkml.kernel.org/r/20180314212030.412095827@linutronix.de
2018-03-20genirq: Pass desc to __irq_free instead of irq numberUwe Kleine König
Given that irq_to_desc() is a radix_tree_lookup and the reverse operation is only a pointer dereference and that all callers of __free_irq already have the desc, pass the desc instead of the irq number. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: kernel@pengutronix.de Link: https://lkml.kernel.org/r/20180319105202.9794-1-u.kleine-koenig@pengutronix.de
2018-03-14genirq: Add CONFIG_GENERIC_IRQ_MULTI_HANDLERPalmer Dabbelt
The arm multi irq handler registration mechanism has been copied into a handful of architectures, including arm64 and openrisc. RISC-V needs the same mechanism. Instead of adding yet another copy for RISC-V copy the arm implementation into the core code depending on a new Kconfig symbol: CONFIG_GENERIC_MULTI_IRQ_HANDLER. Subsequent patches will convert the various architectures. Signed-off-by: Palmer Dabbelt <palmer@sifive.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: jonas@southpole.se Cc: catalin.marinas@arm.com Cc: Will Deacon <will.deacon@arm.com> Cc: linux@armlinux.org.uk Cc: stefan.kristiansson@saunalahti.fi Cc: openrisc@lists.librecores.org Cc: shorne@gmail.com Cc: linux-riscv@lists.infradead.org Cc: linux-arm-kernel@lists.infradead.org Link: https://lkml.kernel.org/r/20180307235731.22627-2-palmer@sifive.com
2018-03-14Merge branch 'linus' into irq/core to pick up dependencies.Thomas Gleixner
2018-03-11Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Thomas Gleixner: "Another set of perf updates: - Fix a Skylake Uncore event format declaration - Prevent perf pipe mode from crahsing which was caused by a missing buffer allocation - Make the perf top popup message which tells the user that it uses fallback mode on older kernels a debug message. - Make perf context rescheduling work correcctly - Robustify the jump error drawing in perf browser mode so it does not try to create references to NULL initialized offset entries - Make trigger_on() robust so it does not enable the trigger before everything is set up correctly to handle it - Make perf auxtrace respect the --no-itrace option so it does not try to queue AUX data for decoding. - Prevent having different number of field separators in CVS output lines when a counter is not supported. - Make the perf kallsyms man page usage behave like it does for all other perf commands. - Synchronize the kernel headers" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/core: Fix ctx_event_type in ctx_resched() perf tools: Fix trigger class trigger_on() perf auxtrace: Prevent decoding when --no-itrace perf stat: Fix CVS output format for non-supported counters tools headers: Sync x86's cpufeatures.h tools headers: Sync copy of kvm UAPI headers perf record: Fix crash in pipe mode perf annotate browser: Be more robust when drawing jump arrows perf top: Fix annoying fallback message on older kernels perf kallsyms: Fix the usage on the man page perf/x86/intel/uncore: Fix Skylake UPI event format
2018-03-11Merge branch 'locking-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking fix from Thomas Gleixner: "rt_mutex_futex_unlock() grew a new irq-off call site, but the function assumes that its always called from irq enabled context. Use (un)lock_irqsafe() to handle the new call site correctly" * 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: rtmutex: Make rt_mutex_futex_unlock() safe for irq-off callsites
2018-03-09bug: use %pB in BUG and stack protector failureKees Cook
The BUG and stack protector reports were still using a raw %p. This changes it to %pB for more meaningful output. Link: http://lkml.kernel.org/r/20180301225704.GA34198@beast Fixes: ad67b74d2469 ("printk: hash addresses printed with %p") Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Richard Weinberger <richard.weinberger@gmail.com>, Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-03-09softirq: Consolidate common code in tasklet_[hi]_action()Ingo Molnar
tasklet_action() + tasklet_hi_action() are almost identical. Move the common code from both function into __tasklet_action_common() and let both functions invoke it with different arguments. [ bigeasy: Splitted out from RT's "tasklet: Prevent tasklets from going into infinite spin in RT" and added commit message] Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Julia Cartwright <juliac@eso.teric.us> Link: https://lkml.kernel.org/r/20180227164808.10093-3-bigeasy@linutronix.de
2018-03-09softirq: Consolidate common code in __tasklet_[hi]_schedule()Ingo Molnar
__tasklet_schedule() and __tasklet_hi_schedule() are almost identical. Move the common code from both function into __tasklet_schedule_common() and let both functions invoke it with different arguments. [ bigeasy: Splitted out from RT's "tasklet: Prevent tasklets from going into infinite spin in RT" and added commit message. Use this_cpu_ptr(headp) in __tasklet_schedule_common() as suggested by Julia Cartwright ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Julia Cartwright <juliac@eso.teric.us> Link: https://lkml.kernel.org/r/20180227164808.10093-2-bigeasy@linutronix.de
2018-03-09genirq/irq_sim: Return the base of the irq range from irq_sim_init()Bartosz Golaszewski
Returning the base of the allocated interrupt range from irq_sim_init() and devm_irq_sim_init() allows users to handle the logic of associating irq numbers with any other driver-specific resources without having to use irq_sim_irqnum(). Signed-off-by: Bartosz Golaszewski <brgl@bgdev.pl> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/20180304121018.640-4-brgl@bgdev.pl
2018-03-09genirq/irq_sim: Check the return value of irq_sim_init() for error codesBartosz Golaszewski
As discussed with Marc Zyngier: irq_sim_init() and its devres variant should return the base of the allocated interrupt range on success rather than 0. Make devm_irq_sim_init() check for an error code. This is a preparatory change for modifying irq_sim_init() itself. Signed-off-by: Bartosz Golaszewski <brgl@bgdev.pl> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/20180304121018.640-3-brgl@bgdev.pl
2018-03-09genirq/irq_sim: Explicitly include slab.hBartosz Golaszewski
kfree() is used in the irq_sim code but slab.h is pulled in indirectly via irq.h. Include it explicitly. Signed-off-by: Bartosz Golaszewski <brgl@bgdev.pl> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/20180304121018.640-2-brgl@bgdev.pl
2018-03-09rtmutex: Make rt_mutex_futex_unlock() safe for irq-off callsitesBoqun Feng
When running rcutorture with TREE03 config, CONFIG_PROVE_LOCKING=y, and kernel cmdline argument "rcutorture.gp_exp=1", lockdep reports a HARDIRQ-safe->HARDIRQ-unsafe deadlock: ================================ WARNING: inconsistent lock state 4.16.0-rc4+ #1 Not tainted -------------------------------- inconsistent {IN-HARDIRQ-W} -> {HARDIRQ-ON-W} usage. takes: __schedule+0xbe/0xaf0 {IN-HARDIRQ-W} state was registered at: _raw_spin_lock+0x2a/0x40 scheduler_tick+0x47/0xf0 ... other info that might help us debug this: Possible unsafe locking scenario: CPU0 ---- lock(&rq->lock); <Interrupt> lock(&rq->lock); *** DEADLOCK *** 1 lock held by rcu_torture_rea/724: rcu_torture_read_lock+0x0/0x70 stack backtrace: CPU: 2 PID: 724 Comm: rcu_torture_rea Not tainted 4.16.0-rc4+ #1 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.11.0-20171110_100015-anatol 04/01/2014 Call Trace: lock_acquire+0x90/0x200 ? __schedule+0xbe/0xaf0 _raw_spin_lock+0x2a/0x40 ? __schedule+0xbe/0xaf0 __schedule+0xbe/0xaf0 preempt_schedule_irq+0x2f/0x60 retint_kernel+0x1b/0x2d RIP: 0010:rcu_read_unlock_special+0x0/0x680 ? rcu_torture_read_unlock+0x60/0x60 __rcu_read_unlock+0x64/0x70 rcu_torture_read_unlock+0x17/0x60 rcu_torture_reader+0x275/0x450 ? rcutorture_booster_init+0x110/0x110 ? rcu_torture_stall+0x230/0x230 ? kthread+0x10e/0x130 kthread+0x10e/0x130 ? kthread_create_worker_on_cpu+0x70/0x70 ? call_usermodehelper_exec_async+0x11a/0x150 ret_from_fork+0x3a/0x50 This happens with the following even sequence: preempt_schedule_irq(); local_irq_enable(); __schedule(): local_irq_disable(); // irq off ... rcu_note_context_switch(): rcu_note_preempt_context_switch(): rcu_read_unlock_special(): local_irq_save(flags); ... raw_spin_unlock_irqrestore(...,flags); // irq remains off rt_mutex_futex_unlock(): raw_spin_lock_irq(); ... raw_spin_unlock_irq(); // accidentally set irq on <return to __schedule()> rq_lock(): raw_spin_lock(); // acquiring rq->lock with irq on which means rq->lock becomes a HARDIRQ-unsafe lock, which can cause deadlocks in scheduler code. This problem was introduced by commit 02a7c234e540 ("rcu: Suppress lockdep false-positive ->boost_mtx complaints"). That brought the user of rt_mutex_futex_unlock() with irq off. To fix this, replace the *lock_irq() in rt_mutex_futex_unlock() with *lock_irq{save,restore}() to make it safe to call rt_mutex_futex_unlock() with irq off. Fixes: 02a7c234e540 ("rcu: Suppress lockdep false-positive ->boost_mtx complaints") Signed-off-by: Boqun Feng <boqun.feng@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Lai Jiangshan <jiangshanlai@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com> Link: https://lkml.kernel.org/r/20180309065630.8283-1-boqun.feng@gmail.com
2018-03-09perf/core: Fix ctx_event_type in ctx_resched()Song Liu
In ctx_resched(), EVENT_FLEXIBLE should be sched_out when EVENT_PINNED is added. However, ctx_resched() calculates ctx_event_type before checking this condition. As a result, pinned events will NOT get higher priority than flexible events. The following shows this issue on an Intel CPU (where ref-cycles can only use one hardware counter). 1. First start: perf stat -C 0 -e ref-cycles -I 1000 2. Then, in the second console, run: perf stat -C 0 -e ref-cycles:D -I 1000 The second perf uses pinned events, which is expected to have higher priority. However, because it failed in ctx_resched(). It is never run. This patch fixes this by calculating ctx_event_type after re-evaluating event_type. Reported-by: Ephraim Park <ephiepark@fb.com> Signed-off-by: Song Liu <songliubraving@fb.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: <jolsa@redhat.com> Cc: <kernel-team@fb.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Fixes: 487f05e18aa4 ("perf/core: Optimize event rescheduling on active contexts") Link: http://lkml.kernel.org/r/20180306055504.3283731-1-songliubraving@fb.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2018-03-08Merge tag 'mips_fixes_4.16_4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/mips Pull MIPS fixes from James Hogan: "A miscellaneous pile of MIPS fixes for 4.16: - move put_compat_sigset() to evade hardened usercopy warnings (4.16) - select ARCH_HAVE_PC_{SERIO,PARPORT} for Loongson64 platforms (4.16) - fix kzalloc() failure handling in ath25 (3.19) and Octeon (4.0) - fix disabling of IPIs during BMIPS suspend (3.19)" * tag 'mips_fixes_4.16_4' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/mips: MIPS: BMIPS: Do not mask IPIs during suspend MIPS: Loongson64: Select ARCH_MIGHT_HAVE_PC_SERIO MIPS: Loongson64: Select ARCH_MIGHT_HAVE_PC_PARPORT signals: Move put_compat_sigset to compat.h to silence hardened usercopy MIPS: OCTEON: irq: Check for null return on kzalloc allocation MIPS: ath25: Check for kzalloc allocation failure
2018-03-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Use an appropriate TSQ pacing shift in mac80211, from Toke Høiland-Jørgensen. 2) Just like ipv4's ip_route_me_harder(), we have to use skb_to_full_sk in ip6_route_me_harder, from Eric Dumazet. 3) Fix several shutdown races and similar other problems in l2tp, from James Chapman. 4) Handle missing XDP flush properly in tuntap, for real this time. From Jason Wang. 5) Out-of-bounds access in powerpc ebpf tailcalls, from Daniel Borkmann. 6) Fix phy_resume() locking, from Andrew Lunn. 7) IFLA_MTU values are ignored on newlink for some tunnel types, fix from Xin Long. 8) Revert F-RTO middle box workarounds, they only handle one dimension of the problem. From Yuchung Cheng. 9) Fix socket refcounting in RDS, from Ka-Cheong Poon. 10) Don't allow ppp unit registration to an unregistered channel, from Guillaume Nault. 11) Various hv_netvsc fixes from Stephen Hemminger. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (98 commits) hv_netvsc: propagate rx filters to VF hv_netvsc: filter multicast/broadcast hv_netvsc: defer queue selection to VF hv_netvsc: use napi_schedule_irqoff hv_netvsc: fix race in napi poll when rescheduling hv_netvsc: cancel subchannel setup before halting device hv_netvsc: fix error unwind handling if vmbus_open fails hv_netvsc: only wake transmit queue if link is up hv_netvsc: avoid retry on send during shutdown virtio-net: re enable XDP_REDIRECT for mergeable buffer ppp: prevent unregistered channels from connecting to PPP units tc-testing: skbmod: fix match value of ethertype mlxsw: spectrum_switchdev: Check success of FDB add operation net: make skb_gso_*_seglen functions private net: xfrm: use skb_gso_validate_network_len() to check gso sizes net: sched: tbf: handle GSO_BY_FRAGS case in enqueue net: rename skb_gso_validate_mtu -> skb_gso_validate_network_len rds: Incorrect reference counting in TCP socket creation net: ethtool: don't ignore return from driver get_fecparam method vrf: check forwarding on the original netdevice when generating ICMP dest unreachable ...
2018-03-04Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Thomas Gleixner: "A small set of fixes from the timer departement: - Add a missing timer wheel clock forward when migrating timers off a unplugged CPU to prevent operating on a stale clock base and missing timer deadlines. - Use the proper shift count to extract data from a register value to prevent evaluating unrelated bits - Make the error return check in the FSL timer driver work correctly. Checking an unsigned variable for less than zero does not really work well. - Clarify the confusing comments in the ARC timer code" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: timers: Forward timer base before migrating timers clocksource/drivers/arc_timer: Update some comments clocksource/drivers/mips-gic-timer: Use correct shift count to extract data clocksource/drivers/fsl_ftm_timer: Fix error return checking
2018-03-03Merge branch 'libnvdimm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm fixes from Dan Williams: "A 4.16 regression fix, three fixes for -stable, and a cleanup fix: - During the merge window support for the new ACPI NVDIMM Platform Capabilities structure disabled support for "deep flush", a force-unit- access like mechanism for persistent memory. Restore that mechanism. - VFIO like RDMA is yet one more memory registration / pinning interface that is incompatible with Filesystem-DAX. Disable long term pins of Filesystem-DAX mappings via VFIO. - The Filesystem-DAX detection to prevent long terms pins mistakenly also disabled Device-DAX pins which are not subject to the same block- map collision concerns. - Similar to the setup path, softlockup warnings can trigger in the shutdown path for large persistent memory namespaces. Teach for_each_device_pfn() to perform cond_resched() in all cases. - Boaz noticed that the might_sleep() in dax_direct_access() is stale as of the v4.15 kernel. These have received a build success notification from the 0day robot, and the longterm pin fixes have appeared in -next. However, I recently rebased the tree to remove some other fixes that need to be reworked after review feedback. * 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: memremap: fix softlockup reports at teardown libnvdimm: re-enable deep flush for pmem devices via fsync() vfio: disable filesystem-dax page pinning dax: fix vma_is_fsdax() helper dax: ->direct_access does not sleep anymore
2018-03-02memremap: fix softlockup reports at teardownDan Williams
The cond_resched() currently in the setup path needs to be duplicated in the teardown path. Rather than require each instance of for_each_device_pfn() to open code the same sequence, embed it in the helper. Link: https://github.com/intel/ixpdimm_sw/issues/11 Cc: "Jérôme Glisse" <jglisse@redhat.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Christoph Hellwig <hch@lst.de> Cc: <stable@vger.kernel.org> Fixes: 71389703839e ("mm, zone_device: Replace {get, put}_zone_device_page()...") Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2018-03-02signals: Move put_compat_sigset to compat.h to silence hardened usercopyMatt Redfearn
Since commit afcc90f8621e ("usercopy: WARN() on slab cache usercopy region violations"), MIPS systems booting with a compat root filesystem emit a warning when copying compat siginfo to userspace: WARNING: CPU: 0 PID: 953 at mm/usercopy.c:81 usercopy_warn+0x98/0xe8 Bad or missing usercopy whitelist? Kernel memory exposure attempt detected from SLAB object 'task_struct' (offset 1432, size 16)! Modules linked in: CPU: 0 PID: 953 Comm: S01logging Not tainted 4.16.0-rc2 #10 Stack : ffffffff808c0000 0000000000000000 0000000000000001 65ac85163f3bdc4a 65ac85163f3bdc4a 0000000000000000 90000000ff667ab8 ffffffff808c0000 00000000000003f8 ffffffff808d0000 00000000000000d1 0000000000000000 000000000000003c 0000000000000000 ffffffff808c8ca8 ffffffff808d0000 ffffffff808d0000 ffffffff80810000 fffffc0000000000 ffffffff80785c30 0000000000000009 0000000000000051 90000000ff667eb0 90000000ff667db0 000000007fe0d938 0000000000000018 ffffffff80449958 0000000020052798 ffffffff808c0000 90000000ff664000 90000000ff667ab0 00000000100c0000 ffffffff80698810 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ffffffff8010d02c 65ac85163f3bdc4a ... Call Trace: [<ffffffff8010d02c>] show_stack+0x9c/0x130 [<ffffffff80698810>] dump_stack+0x90/0xd0 [<ffffffff80137b78>] __warn+0x100/0x118 [<ffffffff80137bdc>] warn_slowpath_fmt+0x4c/0x70 [<ffffffff8021e4a8>] usercopy_warn+0x98/0xe8 [<ffffffff8021e68c>] __check_object_size+0xfc/0x250 [<ffffffff801bbfb8>] put_compat_sigset+0x30/0x88 [<ffffffff8011af24>] setup_rt_frame_n32+0xc4/0x160 [<ffffffff8010b8b4>] do_signal+0x19c/0x230 [<ffffffff8010c408>] do_notify_resume+0x60/0x78 [<ffffffff80106f50>] work_notifysig+0x10/0x18 ---[ end trace 88fffbf69147f48a ]--- Commit 5905429ad856 ("fork: Provide usercopy whitelisting for task_struct") noted that: "While the blocked and saved_sigmask fields of task_struct are copied to userspace (via sigmask_to_save() and setup_rt_frame()), it is always copied with a static length (i.e. sizeof(sigset_t))." However, this is not true in the case of compat signals, whose sigset is copied by put_compat_sigset and receives size as an argument. At most call sites, put_compat_sigset is copying a sigset from the current task_struct. This triggers a warning when CONFIG_HARDENED_USERCOPY is active. However, by marking this function as static inline, the warning can be avoided because in all of these cases the size is constant at compile time, which is allowed. The only site where this is not the case is handling the rt_sigpending syscall, but there the copy is being made from a stack local variable so does not trigger the warning. Move put_compat_sigset to compat.h, and mark it static inline. This fixes the WARN on MIPS. Fixes: afcc90f8621e ("usercopy: WARN() on slab cache usercopy region violations") Signed-off-by: Matt Redfearn <matt.redfearn@mips.com> Acked-by: Kees Cook <keescook@chromium.org> Cc: "Dmitry V . Levin" <ldv@altlinux.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: kernel-hardening@lists.openwall.com Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/18639/ Signed-off-by: James Hogan <jhogan@kernel.org>
2018-03-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/bpf/bpfDavid S. Miller
Daniel Borkmann says: ==================== pull-request: bpf 2018-02-28 The following pull-request contains BPF updates for your *net* tree. The main changes are: 1) Add schedule points and reduce the number of loop iterations the test_bpf kernel module is performing in order to not hog the CPU for too long, from Eric. 2) Fix an out of bounds access in tail calls in the ppc64 BPF JIT compiler, from Daniel. 3) Fix a crash on arm64 on unaligned BPF xadd operations that could be triggered via interpreter and JIT, from Daniel. Please not that once you merge net into net-next at some point, there is a minor merge conflict in test_verifier.c since test cases had been added at the end in both trees. Resolution is trivial: keep all the test cases from both trees. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2018-03-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk Pull printk fix from Petr Mladek: "Make sure that we wake up userspace loggers. This fixes a race introduced by the console waiter logic during this merge window" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk: printk: Wake klogd when passing console_lock owner
2018-02-28timers: Forward timer base before migrating timersLingutla Chandrasekhar
On CPU hotunplug the enqueued timers of the unplugged CPU are migrated to a live CPU. This happens from the control thread which initiated the unplug. If the CPU on which the control thread runs came out from a longer idle period then the base clock of that CPU might be stale because the control thread runs prior to any event which forwards the clock. In such a case the timers from the unplugged CPU are queued on the live CPU based on the stale clock which can cause large delays due to increased granularity of the outer timer wheels which are far away from base:;clock. But there is a worse problem than that. The following sequence of events illustrates it: - CPU0 timer1 is queued expires = 59969 and base->clk = 59131. The timer is queued at wheel level 2, with resulting expiry time = 60032 (due to level granularity). - CPU1 enters idle @60007, with next timer expiry @60020. - CPU0 is hotplugged at @60009 - CPU1 exits idle and runs the control thread which migrates the timers from CPU0 timer1 is now queued in level 0 for immediate handling in the next softirq because the requested expiry time 59969 is before CPU1 base->clk 60007 - CPU1 runs code which forwards the base clock which succeeds because the next expiring timer. which was collected at idle entry time is still set to 60020. So it forwards beyond 60007 and therefore misses to expire the migrated timer1. That timer gets expired when the wheel wraps around again, which takes between 63 and 630ms depending on the HZ setting. Address both problems by invoking forward_timer_base() for the control CPUs timer base. All other places, which might run into a similar problem (mod_timer()/add_timer_on()) already invoke forward_timer_base() to avoid that. [ tglx: Massaged comment and changelog ] Fixes: a683f390b93f ("timers: Forward the wheel clock whenever possible") Co-developed-by: Neeraj Upadhyay <neeraju@codeaurora.org> Signed-off-by: Neeraj Upadhyay <neeraju@codeaurora.org> Signed-off-by: Lingutla Chandrasekhar <clingutla@codeaurora.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Anna-Maria Gleixner <anna-maria@linutronix.de> Cc: linux-arm-msm@vger.kernel.org Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20180118115022.6368-1-clingutla@codeaurora.org
2018-02-28genirq: Add wakeup sysfs node to show IRQ wakeup stateAndy Shevchenko
Surprisingly there is no simple way to see if the IRQ line in question is wakeup source or not. Note that wakeup might be an OOB (out-of-band) source like GPIO line which makes things slightly more complicated. Add a sysfs node to cover this case. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Tony Lindgren <tony@atomide.com> Cc: Grygorii Strashko <grygorii.strashko@ti.com> Cc: "Rafael J . Wysocki" <rafael.j.wysocki@intel.com> Link: https://lkml.kernel.org/r/20180226155043.67937-1-andriy.shevchenko@linux.intel.com
2018-02-27printk: Wake klogd when passing console_lock ownerPetr Mladek
wake_klogd is a local variable in console_unlock(). The information is lost when the console_lock owner using the busy wait added by the commit dbdda842fe96f8932 ("printk: Add console owner and waiter logic to load balance console writes"). The following race is possible: CPU0 CPU1 console_unlock() for (;;) /* calling console for last message */ printk() log_store() log_next_seq++; /* see new message */ if (seen_seq != log_next_seq) { wake_klogd = true; seen_seq = log_next_seq; } console_lock_spinning_enable(); if (console_trylock_spinning()) /* spinning */ if (console_lock_spinning_disable_and_check()) { printk_safe_exit_irqrestore(flags); return; console_unlock() if (seen_seq != log_next_seq) { /* already seen */ /* nothing to do */ Result: Nobody would wakeup klogd. One solution would be to make a global variable from wake_klogd. But then we would need to manipulate it under a lock or so. This patch wakes klogd also when console_lock is passed to the spinning waiter. It looks like the right way to go. Also userspace should have a chance to see and store any "flood" of messages. Note that the very late klogd wake up was a historic solution. It made sense on single CPU systems or when sys_syslog() operations were synchronized using the big kernel lock like in v2.1.113. But it is questionable these days. Fixes: dbdda842fe96f8932 ("printk: Add console owner and waiter logic to load balance console writes") Link: http://lkml.kernel.org/r/20180226155734.dzwg3aovqnwtvkoy@pathway.suse.cz Cc: Steven Rostedt <rostedt@goodmis.org> Cc: linux-kernel@vger.kernel.org Cc: Tejun Heo <tj@kernel.org> Suggested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com>
2018-02-26Merge branch 'x86-pti-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Thomas Gleixner: "Yet another pile of melted spectrum related changes: - sanitize the array_index_nospec protection mechanism: Remove the overengineered array_index_nospec_mask_check() magic and allow const-qualified types as index to avoid temporary storage in a non-const local variable. - make the microcode loader more robust by properly propagating error codes. Provide information about new feature bits after micro code was updated so administrators can act upon. - optimizations of the entry ASM code which reduce code footprint and make the code simpler and faster. - fix the {pmd,pud}_{set,clear}_flags() implementations to work properly on paravirt kernels by removing the address translation operations. - revert the harmful vmexit_fill_RSB() optimization - use IBRS around firmware calls - teach objtool about retpolines and add annotations for indirect jumps and calls. - explicitly disable jumplabel patching in __init code and handle patching failures properly instead of silently ignoring them. - remove indirect paravirt calls for writing the speculation control MSR as these calls are obviously proving the same attack vector which is tried to be mitigated. - a few small fixes which address build issues with recent compiler and assembler versions" * 'x86-pti-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (38 commits) KVM/VMX: Optimize vmx_vcpu_run() and svm_vcpu_run() by marking the RDMSR path as unlikely() KVM/x86: Remove indirect MSR op calls from SPEC_CTRL objtool, retpolines: Integrate objtool with retpoline support more closely x86/entry/64: Simplify ENCODE_FRAME_POINTER extable: Make init_kernel_text() global jump_label: Warn on failed jump_label patching attempt jump_label: Explicitly disable jump labels in __init code x86/entry/64: Open-code switch_to_thread_stack() x86/entry/64: Move ASM_CLAC to interrupt_entry() x86/entry/64: Remove 'interrupt' macro x86/entry/64: Move the switch_to_thread_stack() call to interrupt_entry() x86/entry/64: Move ENTER_IRQ_STACK from interrupt macro to interrupt_entry x86/entry/64: Move PUSH_AND_CLEAR_REGS from interrupt macro to helper function x86/speculation: Move firmware_restrict_branch_speculation_*() from C to CPP objtool: Add module specific retpoline rules objtool: Add retpoline validation objtool: Use existing global variables for options x86/mm/sme, objtool: Annotate indirect call in sme_encrypt_execute() x86/boot, objtool: Annotate indirect jump in secondary_startup_64() x86/paravirt, objtool: Annotate indirect calls ...
2018-02-25Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Thomas Gleixner: "A small set of fixes: - UAPI data type correction for hyperv - correct the cpu cores field in /proc/cpuinfo on CPU hotplug - return proper error code in the resctrl file system failure path to avoid silent subsequent failures - correct a subtle accounting issue in the new vector allocation code which went unnoticed for a while and caused suspend/resume failures" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/topology: Update the 'cpu cores' field in /proc/cpuinfo correctly across CPU hotplug operations x86/topology: Fix function name in documentation x86/intel_rdt: Fix incorrect returned value when creating rdgroup sub-directory in resctrl file system x86/apic/vector: Handle vector release on CPU unplug correctly genirq/matrix: Handle CPU offlining proper x86/headers/UAPI: Use __u64 instead of u64 in <uapi/asm/hyperv.h>
2018-02-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix TTL offset calculation in mac80211 mesh code, from Peter Oh. 2) Fix races with procfs in ipt_CLUSTERIP, from Cong Wang. 3) Memory leak fix in lpm_trie BPF map code, from Yonghong Song. 4) Need to use GFP_ATOMIC in BPF cpumap allocations, from Jason Wang. 5) Fix potential deadlocks in netfilter getsockopt() code paths, from Paolo Abeni. 6) Netfilter stackpointer size checks really are needed to validate user input, from Florian Westphal. 7) Missing timer init in x_tables, from Paolo Abeni. 8) Don't use WQ_MEM_RECLAIM in mac80211 hwsim, from Johannes Berg. 9) When an ibmvnic device is brought down then back up again, it can be sent queue entries from a previous session, handle this properly instead of crashing. From Thomas Falcon. 10) Fix TCP checksum on LRO buffers in mlx5e, from Gal Pressman. 11) When we are dumping filters in cls_api, the output SKB is empty, and the filter we are dumping is too large for the space in the SKB, we should return -EMSGSIZE like other netlink dump operations do. Otherwise userland has no signal that is needs to increase the size of its read buffer. From Roman Kapl. 12) Several XDP fixes for virtio_net, from Jesper Dangaard Brouer. 13) Module refcount leak in netlink when a dump start fails, from Jason Donenfeld. 14) Handle sub-optimal GSO sizes better in TCP BBR congestion control, from Eric Dumazet. 15) Releasing bpf per-cpu arraymaps can take a long time, add a condtional scheduling point. From Eric Dumazet. 16) Implement retpolines for tail calls in x64 and arm64 bpf JITs. From Daniel Borkmann. 17) Fix page leak in gianfar driver, from Andy Spencer. 18) Missed clearing of estimator scratch buffer, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (76 commits) net_sched: gen_estimator: fix broken estimators based on percpu stats gianfar: simplify FCS handling and fix memory leak ipv6 sit: work around bogus gcc-8 -Wrestrict warning macvlan: fix use-after-free in macvlan_common_newlink() bpf, arm64: fix out of bounds access in tail call bpf, x64: implement retpoline for tail call rxrpc: Fix send in rxrpc_send_data_packet() net: aquantia: Fix error handling in aq_pci_probe() bpf: fix rcu lockdep warning for lpm_trie map_free callback bpf: add schedule points in percpu arrays management regulatory: add NUL to request alpha2 ibmvnic: Fix early release of login buffer net/smc9194: Remove bogus CONFIG_MAC reference net: ipv4: Set addr_type in hash_keys for forwarded case tcp_bbr: better deal with suboptimal GSO smsc75xx: fix smsc75xx_set_features() netlink: put module reference if dump start fails selftests/bpf/test_maps: exit child process without error in ENOMEM case selftests/bpf: update gitignore with test_libbpf_open selftests/bpf: tcpbpf_kern: use in6_* macros from glibc ..
2018-02-23Merge branch 'fixes-v4.16-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem fixes from James Morris: - keys fixes via David Howells: "A collection of fixes for Linux keyrings, mostly thanks to Eric Biggers: - Fix some PKCS#7 verification issues. - Fix handling of unsupported crypto in X.509. - Fix too-large allocation in big_key" - Seccomp updates via Kees Cook: "These are fixes for the get_metadata interface that landed during -rc1. While the new selftest is strictly not a bug fix, I think it's in the same spirit of avoiding bugs" - an IMA build fix from Randy Dunlap * 'fixes-v4.16-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: integrity/security: fix digsig.c build error with header file KEYS: Use individual pages in big_key for crypto buffers X.509: fix NULL dereference when restricting key with unsupported_sig X.509: fix BUG_ON() when hash algorithm is unsupported PKCS#7: fix direct verification of SignerInfo signature PKCS#7: fix certificate blacklisting PKCS#7: fix certificate chain verification seccomp: add a selftest for get_metadata ptrace, seccomp: tweak get_metadata behavior slightly seccomp, ptrace: switch get_metadata types to arch independent
2018-02-23bpf: allow xadd only on aligned memoryDaniel Borkmann
The requirements around atomic_add() / atomic64_add() resp. their JIT implementations differ across architectures. E.g. while x86_64 seems just fine with BPF's xadd on unaligned memory, on arm64 it triggers via interpreter but also JIT the following crash: [ 830.864985] Unable to handle kernel paging request at virtual address ffff8097d7ed6703 [...] [ 830.916161] Internal error: Oops: 96000021 [#1] SMP [ 830.984755] CPU: 37 PID: 2788 Comm: test_verifier Not tainted 4.16.0-rc2+ #8 [ 830.991790] Hardware name: Huawei TaiShan 2280 /BC11SPCD, BIOS 1.29 07/17/2017 [ 830.998998] pstate: 80400005 (Nzcv daif +PAN -UAO) [ 831.003793] pc : __ll_sc_atomic_add+0x4/0x18 [ 831.008055] lr : ___bpf_prog_run+0x1198/0x1588 [ 831.012485] sp : ffff00001ccabc20 [ 831.015786] x29: ffff00001ccabc20 x28: ffff8017d56a0f00 [ 831.021087] x27: 0000000000000001 x26: 0000000000000000 [ 831.026387] x25: 000000c168d9db98 x24: 0000000000000000 [ 831.031686] x23: ffff000008203878 x22: ffff000009488000 [ 831.036986] x21: ffff000008b14e28 x20: ffff00001ccabcb0 [ 831.042286] x19: ffff0000097b5080 x18: 0000000000000a03 [ 831.047585] x17: 0000000000000000 x16: 0000000000000000 [ 831.052885] x15: 0000ffffaeca8000 x14: 0000000000000000 [ 831.058184] x13: 0000000000000000 x12: 0000000000000000 [ 831.063484] x11: 0000000000000001 x10: 0000000000000000 [ 831.068783] x9 : 0000000000000000 x8 : 0000000000000000 [ 831.074083] x7 : 0000000000000000 x6 : 000580d428000000 [ 831.079383] x5 : 0000000000000018 x4 : 0000000000000000 [ 831.084682] x3 : ffff00001ccabcb0 x2 : 0000000000000001 [ 831.089982] x1 : ffff8097d7ed6703 x0 : 0000000000000001 [ 831.095282] Process test_verifier (pid: 2788, stack limit = 0x0000000018370044) [ 831.102577] Call trace: [ 831.105012] __ll_sc_atomic_add+0x4/0x18 [ 831.108923] __bpf_prog_run32+0x4c/0x70 [ 831.112748] bpf_test_run+0x78/0xf8 [ 831.116224] bpf_prog_test_run_xdp+0xb4/0x120 [ 831.120567] SyS_bpf+0x77c/0x1110 [ 831.123873] el0_svc_naked+0x30/0x34 [ 831.127437] Code: 97fffe97 17ffffec 00000000 f9800031 (885f7c31) Reason for this is because memory is required to be aligned. In case of BPF, we always enforce alignment in terms of stack access, but not when accessing map values or packet data when the underlying arch (e.g. arm64) has CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS set. xadd on packet data that is local to us anyway is just wrong, so forbid this case entirely. The only place where xadd makes sense in fact are map values; xadd on stack is wrong as well, but it's been around for much longer. Specifically enforce strict alignment in case of xadd, so that we handle this case generically and avoid such crashes in the first place. Fixes: 17a5267067f3 ("bpf: verifier (add verifier core)") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Alexei Starovoitov <ast@kernel.org>
2018-02-23Merge tag 'drm-fixes-for-v4.16-rc3' of ↵Linus Torvalds
git://people.freedesktop.org/~airlied/linux Pull drm fixes from Dave Airlie: "A bunch of fixes for rc3: Exynos: - fixes for using monotonic timestamps - register definitions - removal of unused file ipu-v3L - minor changes - make some register arrays const+static - fix some leaks meson: - fix for vsync atomic: - fix for memory leak EDID parser: - add quirks for some more non-desktop devices - 6-bit panel fix. drm_mm: - fix a bug in the core drm mm hole handling cirrus: - fix lut loading regression Lastly there is a deadlock fix around runtime suspend for secondary GPUs. There was a deadlock between one thread trying to wait for a workqueue job to finish in the runtime suspend path, and the workqueue job it was waiting for in turn waiting for a runtime_get_sync to return. The fixes avoids it by not doing the runtime sync in the workqueue as then we always wait for all those tasks to complete before we runtime suspend" * tag 'drm-fixes-for-v4.16-rc3' of git://people.freedesktop.org/~airlied/linux: (25 commits) drm/tve200: fix kernel-doc documentation comment include drm/edid: quirk Sony PlayStation VR headset as non-desktop drm/edid: quirk Windows Mixed Reality headsets as non-desktop drm/edid: quirk Oculus Rift headsets as non-desktop drm/meson: fix vsync buffer update drm: Handle unexpected holes in color-eviction drm: exynos: Use proper macro definition for HDMI_I2S_PIN_SEL_1 drm/exynos: remove exynos_drm_rotator.h drm/exynos: g2d: Delete an error message for a failed memory allocation in two functions drm/exynos: fix comparison to bitshift when dealing with a mask drm/exynos: g2d: use monotonic timestamps drm/edid: Add 6 bpc quirk for CPT panel in Asus UX303LA gpu: ipu-csi: add 10/12-bit grayscale support to mbus_code_to_bus_cfg gpu: ipu-cpmem: add 16-bit grayscale support to ipu_cpmem_set_image gpu: ipu-v3: prg: fix device node leak in ipu_prg_lookup_by_phandle gpu: ipu-v3: pre: fix device node leak in ipu_pre_lookup_by_phandle drm/amdgpu: Fix deadlock on runtime suspend drm/radeon: Fix deadlock on runtime suspend drm/nouveau: Fix deadlock on runtime suspend drm: Allow determining if current task is output poll worker ...
2018-02-22genirq/matrix: Handle CPU offlining properThomas Gleixner
At CPU hotunplug the corresponding per cpu matrix allocator is shut down and the allocated interrupt bits are discarded under the assumption that all allocated bits have been either migrated away or shut down through the managed interrupts mechanism. This is not true because interrupts which are not started up might have a vector allocated on the outgoing CPU. When the interrupt is started up later or completely shutdown and freed then the allocated vector is handed back, triggering warnings or causing accounting issues which result in suspend failures and other issues. Change the CPU hotplug mechanism of the matrix allocator so that the remaining allocations at unplug time are preserved and global accounting at hotplug is correctly readjusted to take the dormant vectors into account. Fixes: 2f75d9e1c905 ("genirq: Implement bitmap matrix allocator") Reported-by: Yuriy Vostrikov <delamonpansie@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Yuriy Vostrikov <delamonpansie@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20180222112316.849980972@linutronix.de
2018-02-22bpf: fix rcu lockdep warning for lpm_trie map_free callbackYonghong Song
Commit 9a3efb6b661f ("bpf: fix memory leak in lpm_trie map_free callback function") fixed a memory leak and removed unnecessary locks in map_free callback function. Unfortrunately, it introduced a lockdep warning. When lockdep checking is turned on, running tools/testing/selftests/bpf/test_lpm_map will have: [ 98.294321] ============================= [ 98.294807] WARNING: suspicious RCU usage [ 98.295359] 4.16.0-rc2+ #193 Not tainted [ 98.295907] ----------------------------- [ 98.296486] /home/yhs/work/bpf/kernel/bpf/lpm_trie.c:572 suspicious rcu_dereference_check() usage! [ 98.297657] [ 98.297657] other info that might help us debug this: [ 98.297657] [ 98.298663] [ 98.298663] rcu_scheduler_active = 2, debug_locks = 1 [ 98.299536] 2 locks held by kworker/2:1/54: [ 98.300152] #0: ((wq_completion)"events"){+.+.}, at: [<00000000196bc1f0>] process_one_work+0x157/0x5c0 [ 98.301381] #1: ((work_completion)(&map->work)){+.+.}, at: [<00000000196bc1f0>] process_one_work+0x157/0x5c0 Since actual trie tree removal happens only after no other accesses to the tree are possible, replacing rcu_dereference_protected(*slot, lockdep_is_held(&trie->lock)) with rcu_dereference_protected(*slot, 1) fixed the issue. Fixes: 9a3efb6b661f ("bpf: fix memory leak in lpm_trie map_free callback function") Reported-by: Eric Dumazet <edumazet@google.com> Suggested-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Yonghong Song <yhs@fb.com> Reviewed-by: Eric Dumazet <edumazet@google.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
2018-02-22bpf: add schedule points in percpu arrays managementEric Dumazet
syszbot managed to trigger RCU detected stalls in bpf_array_free_percpu() It takes time to allocate a huge percpu map, but even more time to free it. Since we run in process context, use cond_resched() to yield cpu if needed. Fixes: a10423b87a7e ("bpf: introduce BPF_MAP_TYPE_PERCPU_ARRAY map") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
2018-02-22Merge tag 'seccomp-v4.16-rc3' of ↵James Morris
https://git.kernel.org/pub/scm/linux/kernel/git/kees/linux into fixes-v4.16-rc3 - Fix seccomp GET_METADATA to deal with field sizes correctly (Tycho Andersen) - Add selftest to make sure GET_METADATA doesn't regress (Tycho Andersen)
2018-02-22Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: "16 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: mm: don't defer struct page initialization for Xen pv guests lib/Kconfig.debug: enable RUNTIME_TESTING_MENU vmalloc: fix __GFP_HIGHMEM usage for vmalloc_32 on 32b systems selftests/memfd: add run_fuse_test.sh to TEST_FILES bug.h: work around GCC PR82365 in BUG() mm/swap.c: make functions and their kernel-doc agree (again) mm/zpool.c: zpool_evictable: fix mismatch in parameter name and kernel-doc ida: do zeroing in ida_pre_get() mm, swap, frontswap: fix THP swap if frontswap enabled certs/blacklist_nohashes.c: fix const confusion in certs blacklist kernel/relay.c: limit kmalloc size to KMALLOC_MAX_SIZE mm, mlock, vmscan: no more skipping pagevecs mm: memcontrol: fix NR_WRITEBACK leak in memcg and system stats Kbuild: always define endianess in kconfig.h include/linux/sched/mm.h: re-inline mmdrop() tools: fix cross-compile var clobbering
2018-02-22efivarfs: Limit the rate for non-root to read filesLuck, Tony
Each read from a file in efivarfs results in two calls to EFI (one to get the file size, another to get the actual data). On X86 these EFI calls result in broadcast system management interrupts (SMI) which affect performance of the whole system. A malicious user can loop performing reads from efivarfs bringing the system to its knees. Linus suggested per-user rate limit to solve this. So we add a ratelimit structure to "user_struct" and initialize it for the root user for no limit. When allocating user_struct for other users we set the limit to 100 per second. This could be used for other places that want to limit the rate of some detrimental user action. In efivarfs if the limit is exceeded when reading, we take an interruptible nap for 50ms and check the rate limit again. Signed-off-by: Tony Luck <tony.luck@intel.com> Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-02-21ptrace, seccomp: tweak get_metadata behavior slightlyTycho Andersen
Previously if users passed a small size for the input structure size, they would get get odd behavior. It doesn't make sense to pass a structure smaller than at least filter_off size, so let's just give -EINVAL in this case. This changes userspace visible behavior, but was only introduced in commit 26500475ac1b ("ptrace, seccomp: add support for retrieving seccomp metadata") in 4.16-rc2, so should be safe to change if merged before then. Reported-by: Eugene Syromiatnikov <esyr@redhat.com> Signed-off-by: Tycho Andersen <tycho@tycho.ws> CC: Kees Cook <keescook@chromium.org> CC: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Kees Cook <keescook@chromium.org>
2018-02-21kernel/relay.c: limit kmalloc size to KMALLOC_MAX_SIZEDavid Rientjes
chan->n_subbufs is set by the user and relay_create_buf() does a kmalloc() of chan->n_subbufs * sizeof(size_t *). kmalloc_slab() will generate a warning when this fails if chan->subbufs * sizeof(size_t *) > KMALLOC_MAX_SIZE. Limit chan->n_subbufs to the maximum allowed kmalloc() size. Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1802061216100.122576@chino.kir.corp.google.com Fixes: f6302f1bcd75 ("relay: prevent integer overflow in relay_open()") Signed-off-by: David Rientjes <rientjes@google.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Dave Jiang <dave.jiang@intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-02-21include/linux/sched/mm.h: re-inline mmdrop()Andrew Morton
As Peter points out, Doing a CALL+RET for just the decrement is a bit silly. Fixes: d70f2a14b72a4bc ("include/linux/sched/mm.h: uninline mmdrop_async(), etc") Acked-by: Peter Zijlstra (Intel) <peterz@infraded.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-02-22Merge tag 'drm-misc-fixes-2018-02-21' of ↵Dave Airlie
git://anongit.freedesktop.org/drm/drm-misc into drm-fixes Fixes for 4.16. I contains fixes for deadlock on runtime suspend on few drivers, a memory leak on non-blocking commits, a crash on color-eviction. The is also meson and edid fixes, plus a fix for a doc warning. * tag 'drm-misc-fixes-2018-02-21' of git://anongit.freedesktop.org/drm/drm-misc: drm/tve200: fix kernel-doc documentation comment include drm/meson: fix vsync buffer update drm: Handle unexpected holes in color-eviction drm/edid: Add 6 bpc quirk for CPT panel in Asus UX303LA drm/amdgpu: Fix deadlock on runtime suspend drm/radeon: Fix deadlock on runtime suspend drm/nouveau: Fix deadlock on runtime suspend drm: Allow determining if current task is output poll worker workqueue: Allow retrieval of current task's work struct drm/atomic: Fix memleak on ERESTARTSYS during non-blocking commits
2018-02-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/bpf/bpfDavid S. Miller
Daniel Borkmann says: ==================== pull-request: bpf 2018-02-20 The following pull-request contains BPF updates for your *net* tree. The main changes are: 1) Fix a memory leak in LPM trie's map_free() callback function, where the trie structure itself was not freed since initial implementation. Also a synchronize_rcu() was needed in order to wait for outstanding programs accessing the trie to complete, from Yonghong. 2) Fix sock_map_alloc()'s error path in order to correctly propagate the -EINVAL error in case of too large allocation requests. This was just recently introduced when fixing close hooks via ULP layer, fix from Eric. 3) Do not use GFP_ATOMIC in __cpu_map_entry_alloc(). Reason is that this will not work with the recent __ptr_ring_init_queue_alloc() conversion to kvmalloc_array(), where in case of fallback to vmalloc() that GFP flag is invalid, from Jason. 4) Fix two recent syzkaller warnings: i) fix bpf_prog_array_copy_to_user() when a prog query with a big number of ids was performed where we'd otherwise trigger a warning from allocator side, ii) fix a missing mlock precharge on arraymaps, from Daniel. 5) Two fixes for bpftool in order to avoid breaking JSON output when used in batch mode, from Quentin. 6) Move a pr_debug() in libbpf in order to avoid having an otherwise uninitialized variable in bpf_program__reloc_text(), from Jeremy. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2018-02-21extable: Make init_kernel_text() globalJosh Poimboeuf
Convert init_kernel_text() to a global function and use it in a few places instead of manually comparing _sinittext and _einittext. Note that kallsyms.h has a very similar function called is_kernel_inittext(), but its end check is inclusive. I'm not sure whether that's intentional behavior, so I didn't touch it. Suggested-by: Jason Baron <jbaron@akamai.com> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Cc: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/4335d02be8d45ca7d265d2f174251d0b7ee6c5fd.1519051220.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2018-02-21jump_label: Warn on failed jump_label patching attemptJosh Poimboeuf
Currently when the jump label code encounters an address which isn't recognized by kernel_text_address(), it just silently fails. This can be dangerous because jump labels are used in a variety of places, and are generally expected to work. Convert the silent failure to a warning. This won't warn about attempted writes to tracepoints in __init code after initmem has been freed, as those are already guarded by the entry->code check. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@suse.de> Cc: Jason Baron <jbaron@akamai.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/de3a271c93807adb7ed48f4e946b4f9156617680.1519051220.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2018-02-21jump_label: Explicitly disable jump labels in __init codeJosh Poimboeuf
After initmem has been freed, any jump labels in __init code are prevented from being written to by the kernel_text_address() check in __jump_label_update(). However, this check is quite broad. If kernel_text_address() were to return false for any other reason, the jump label write would fail silently with no warning. For jump labels in module init code, entry->code is set to zero to indicate that the entry is disabled. Do the same thing for core kernel init code. This makes the behavior more consistent, and will also make it more straightforward to detect non-init jump label write failures in the next patch. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@suse.de> Cc: Jason Baron <jbaron@akamai.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/c52825c73f3a174e8398b6898284ec20d4deb126.1519051220.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2018-02-18Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Thomas Gleixner: "Perf tool updates and kprobe fixes: - perf_mmap overwrite mode fixes/overhaul, prep work to get 'perf top' using it, making it bearable to use it in large core count systems such as Knights Landing/Mill Intel systems (Kan Liang) - s/390 now uses syscall.tbl, just like x86-64 to generate the syscall table id -> string tables used by 'perf trace' (Hendrik Brueckner) - Use strtoull() instead of home grown function (Andy Shevchenko) - Synchronize kernel ABI headers, v4.16-rc1 (Ingo Molnar) - Document missing 'perf data --force' option (Sangwon Hong) - Add perf vendor JSON metrics for ARM Cortex-A53 Processor (William Cohen) - Improve error handling and error propagation of ftrace based kprobes so failures when installing kprobes are not silently ignored and create disfunctional tracepoints" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits) kprobes: Propagate error from disarm_kprobe_ftrace() kprobes: Propagate error from arm_kprobe_ftrace() Revert "tools include s390: Grab a copy of arch/s390/include/uapi/asm/unistd.h" perf s390: Rework system call table creation by using syscall.tbl perf s390: Grab a copy of arch/s390/kernel/syscall/syscall.tbl tools/headers: Synchronize kernel ABI headers, v4.16-rc1 perf test: Fix test trace+probe_libc_inet_pton.sh for s390x perf data: Document missing --force option perf tools: Substitute yet another strtoull() perf top: Check the latency of perf_top__mmap_read() perf top: Switch default mode to overwrite mode perf top: Remove lost events checking perf hists browser: Add parameter to disable lost event warning perf top: Add overwrite fall back perf evsel: Expose the perf_missing_features struct perf top: Check per-event overwrite term perf mmap: Discard legacy interface for mmap read perf test: Update mmap read functions for backward-ring-buffer test perf mmap: Introduce perf_mmap__read_event() perf mmap: Introduce perf_mmap__read_done() ...
2018-02-18Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "A small set of updates mostly for irq chip drivers: - MIPS GIC fix for spurious, masked interrupts - fix for a subtle IPI bug in GICv3 - do not probe GICv3 ITSs that are marked as disabled - multi-MSI support for GICv2m - various small cleanups" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqdomain: Re-use DEFINE_SHOW_ATTRIBUTE() macro irqchip/bcm: Remove hashed address printing irqchip/gic-v2m: Add PCI Multi-MSI support irqchip/gic-v3: Ignore disabled ITS nodes irqchip/gic-v3: Use wmb() instead of smb_wmb() in gic_raise_softirq() irqchip/gic-v3: Change pr_debug message to pr_devel irqchip/mips-gic: Avoid spuriously handling masked interrupts
2018-02-16workqueue: Allow retrieval of current task's work structLukas Wunner
Introduce a helper to retrieve the current task's work struct if it is a workqueue worker. This allows us to fix a long-standing deadlock in several DRM drivers wherein the ->runtime_suspend callback waits for a specific worker to finish and that worker in turn calls a function which waits for runtime suspend to finish. That function is invoked from multiple call sites and waiting for runtime suspend to finish is the correct thing to do except if it's executing in the context of the worker. Cc: Lai Jiangshan <jiangshanlai@gmail.com> Cc: Dave Airlie <airlied@redhat.com> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Alex Deucher <alexander.deucher@amd.com> Acked-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lyude Paul <lyude@redhat.com> Signed-off-by: Lukas Wunner <lukas@wunner.de> Link: https://patchwork.freedesktop.org/patch/msgid/2d8f603074131eb87e588d2b803a71765bd3a2fd.1518338788.git.lukas@wunner.de
2018-02-16genirq: Let irq thread follow the effective hard irq affinityThomas Gleixner
In case of threaded interrupts the thread follows the affinity setting of the hard interrupt. The related function uses the affinity mask which was set by either from user space or via one of the kernel mechanisms. This mask can be wider than the resulting effective affinity of the hard interrupt. As a consequence the thread might become affine to a completely different CPU. Use the effective interrupt affinity if the architecture supports it, so the hard interrupt and the thread stay on the same CPU. Reported-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
2018-02-16irqdomain: Re-use DEFINE_SHOW_ATTRIBUTE() macroAndy Shevchenko
...instead of open coding file operations followed by custom ->open() callbacks per each attribute. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
