path: root/kernel
2011-01-31time: Provide xtime_update()Torben Hohn
xtime_update() takes xtime_lock write locked and calls do_timer(). Provided to replace the do_timer() calls in the architecture code. Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: johnstul@us.ibm.com Cc: yong.zhang0@gmail.com Cc: hch@infradead.org LKML-Reference: <20110127145910.23248.21379.stgit@localhost> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-31time: Remove unused __get_wall_to_monotonic()Thomas Gleixner
No users left. Remove it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-31time: Provide get_xtime_and_monotonic_offset()Torben Hohn
The hrtimer code accesses timekeeping variables under xtime_lock. Provide a sensible accessor function and use it. [ tglx: Removed the conditionals, unused variable, fixed codingstyle and massaged changelog ] Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: johnstul@us.ibm.com Cc: yong.zhang0@gmail.com Cc: hch@infradead.org LKML-Reference: <20110127145905.23248.30458.stgit@localhost> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-31time: Move get_jiffies_64 to kernel/time/jiffies.cTorben Hohn
Move the jiffies access functions to the jiffies clocksource code. [ tglx: Add missing include ] Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: johnstul@us.ibm.com Cc: yong.zhang0@gmail.com Cc: hch@infradead.org LKML-Reference: <20110127145900.23248.73352.stgit@localhost> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-31time: Move do_timer() to kernel/time/timekeeping.cTorben Hohn
do_timer() is primary timekeeping related. calc_global_load() is called from do_timer() as well, but that's more for historical reasons. [ tglx: Fixed up the calc_global_load() reject andmassaged changelog ] Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: johnstul@us.ibm.com Cc: yong.zhang0@gmail.com Cc: hch@infradead.org LKML-Reference: <20110127145855.23248.56933.stgit@localhost> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-31Fix prlimit64 for suid/sgid processesKacper Kornet
Since check_prlimit_permission always fails in the case of SUID/GUID processes, such processes are not able to read or set their own limits. This commit changes this by assuming that process can always read/change its own limits. Signed-off-by: Kacper Kornet <kornet@camk.edu.pl> Acked-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-28Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Use rq->clock_task instead of rq->clock for correctly maintaining load averages sched: Fix/remove redundant cfs_rq checks sched: Fix sign under-flows in wake_affine
2011-01-26sched: Use rq->clock_task instead of rq->clock for correctly maintaining ↵Paul Turner
load averages The delta in clock_task is a more fair attribution of how much time a tg has been contributing load to the current cpu. While not really important it also means we're more in sync (by magnitude) with respect to periodic updates (since __update_curr deltas are clock_task based). Signed-off-by: Paul Turner <pjt@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110122044852.007092349@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-26sched: Fix/remove redundant cfs_rq checksPaul Turner
Since updates are against an entity's queuing cfs_rq it's not possible to enter update_cfs_{shares,load} with a NULL cfs_rq. (Indeed, update_cfs_load would crash prior to the check if we did anyway since we load is examined during the initializers). Also, in the update_cfs_load case there's no point in maintaining averages for rq->cfs_rq since we don't perform shares distribution at that level -- NULL check is replaced accordingly. Thanks to Dan Carpenter for pointing out the deference before NULL check. Signed-off-by: Paul Turner <pjt@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110122044851.825284940@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-26sched: Fix sign under-flows in wake_affinePaul Turner
While care is taken around the zero-point in effective_load to not exceed the instantaneous rq->weight, it's still possible (e.g. using wake_idx != 0) for (load + effective_load) to underflow. In this case the comparing the unsigned values can result in incorrect balanced decisions. Signed-off-by: Paul Turner <pjt@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110122044851.734245014@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: wacom - pass touch resolution to clients through input_absinfo Input: wacom - add 2 Bamboo Pen and touch models Input: sysrq - ensure sysrq_enabled and __sysrq_enabled are consistent Input: sparse-keymap - fix KEY_VSW handling in sparse_keymap_setup Input: tegra-kbc - add tegra keyboard driver Input: gpio_keys - switch to using request_any_context_irq Input: serio - allow registered drivers to get status flag Input: ct82710c - return proper error code for ct82c710_open Input: bu21013_ts - added regulator support Input: bu21013_ts - remove duplicate resolution parameters Input: tnetv107x-ts - don't treat NULL clk as an error Input: tnetv107x-keypad - don't treat NULL clk as an error Fix up trivial conflicts in drivers/input/keyboard/Makefile due to additions of tc3589x/Tegra drivers
2011-01-26console: rename acquire/release_console_sem() to console_lock/unlock()Torben Hohn
The -rt patches change the console_semaphore to console_mutex. As a result, a quite large chunk of the patches changes all acquire/release_console_sem() to acquire/release_console_mutex() This commit makes things use more neutral function names which dont make implications about the underlying lock. The only real change is the return value of console_trylock which is inverted from try_acquire_console_sem() This patch also paves the way to switching console_sem from a semaphore to a mutex. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: make console_trylock return 1 on success, per Geert] Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Thomas Gleixner <tglx@tglx.de> Cc: Greg KH <gregkh@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-25Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf tools: Fix time function double declaration with glibc perf tools: Fix build by checking if extra warnings are supported perf tools: Fix build when using gcc 3.4.6 perf tools: Add missing header, fixes build perf tools: Fix 64 bit integer format strings perf test: Fix build on older glibcs perf: perf_event_exit_task_context: s/rcu_dereference/rcu_dereference_raw/ perf test: Use cpu_map->[cpu] when setting affinity perf symbols: Fix annotation of thumb code perf: Annotate cpuctx->ctx.mutex to avoid a lockdep splat powerpc, perf: Fix frequency calculation for overflowing counters (FSL version) perf: Fix perf_event_init_task()/perf_event_free_task() interaction perf: Fix find_get_context() vs perf_event_exit_task() race
2011-01-25Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: RTC: Remove Kconfig symbol for UIE emulation RTC: Properly handle rtc_read_alarm error propagation and fix bug RTC: Propagate error handling via rtc_timer_enqueue properly acpi_pm: Clear pmtmr_ioport if acpi_pm initialization fails rtc: Cleanup removed UIE emulation declaration hrtimers: Notify hrtimer users of switches to NOHZ mode
2011-01-25Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Fix poor interactivity on UP systems due to group scheduler nice tune bug
2011-01-24Input: sysrq - ensure sysrq_enabled and __sysrq_enabled are consistentAndy Whitcroft
Currently sysrq_enabled and __sysrq_enabled are initialised separately and inconsistently, leading to sysrq being actually enabled by reported as not enabled in sysfs. The first change to the sysfs configurable synchronises these two: static int __read_mostly sysrq_enabled = 1; static int __sysrq_enabled; Add a common define to carry the default for these preventing them becoming out of sync again. Default this to 1 to mirror previous behaviour. Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: stable@kernel.org Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-01-24sched: Fix poor interactivity on UP systems due to group scheduler nice tune bugYong Zhang
Michael Witten and Christian Kujau reported that the autogroup scheduling feature hurts interactivity on their UP systems. It turns out that this is an older bug in the group scheduling code, and the wider appeal provided by the autogroup feature exposed it more prominently. When on UP with FAIR_GROUP_SCHED enabled, tune shares only affect tg->shares, but is not reflected in tg->se->load. The reason is that update_cfs_shares() does nothing on UP. So introduce update_cfs_shares() for UP && FAIR_GROUP_SCHED. This issue was found when enable autogroup scheduling was enabled, but it is an older bug that also exists on cgroup.cpu on UP. Reported-and-Tested-by: Michael Witten <mfwitten@gmail.com> Reported-and-Tested-by: Christian Kujau <christian@nerdbynature.de> Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Pekka Enberg <penberg@kernel.org> Acked-by: Mike Galbraith <efault@gmx.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <20110124073352.GA24186@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-24module: show version information for built-in modules in sysfsDmitry Torokhov
Currently only drivers that are built as modules have their versions shown in /sys/module/<module_name>/version, but this information might also be useful for built-in drivers as well. This especially important for drivers that do not define any parameters - such drivers, if built-in, are completely invisible from userspace. This patch changes MODULE_VERSION() macro so that in case when we are compiling built-in module, version information is stored in a separate section. Kernel then uses this data to create 'version' sysfs attribute in the same fashion it creates attributes for module parameters. Signed-off-by: Dmitry Torokhov <dtor@vmware.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-01-21Merge branch 'fixes-2.6.38' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq * 'fixes-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: note the nested NOT_RUNNING test in worker_clr_flags() isn't a noop workqueue: relax lockdep annotation on flush_work()
2011-01-21perf: perf_event_exit_task_context: s/rcu_dereference/rcu_dereference_raw/Oleg Nesterov
In theory, almost every user of task->child->perf_event_ctxp[] is wrong. find_get_context() can install the new context at any moment, we need read_barrier_depends(). dbe08d82ce3967ccdf459f7951d02589cf967300 "perf: Fix find_get_context() vs perf_event_exit_task() race" added rcu_dereference() into perf_event_exit_task_context() to make the precedent, but this makes __rcu_dereference_check() unhappy. Use rcu_dereference_raw() to shut up the warning. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: acme@redhat.com Cc: paulus@samba.org Cc: stern@rowland.harvard.edu Cc: a.p.zijlstra@chello.nl Cc: fweisbec@gmail.com Cc: roland@redhat.com Cc: prasad@linux.vnet.ibm.com Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> LKML-Reference: <20110121174547.GA8796@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-21perf: Annotate cpuctx->ctx.mutex to avoid a lockdep splatPeter Zijlstra
Lockdep spotted: loop_1b_instruc/1899 is trying to acquire lock: (event_mutex){+.+.+.}, at: [<ffffffff810e1908>] perf_trace_init+0x3b/0x2f7 but task is already holding lock: (&ctx->mutex){+.+.+.}, at: [<ffffffff810eb45b>] perf_event_init_context+0xc0/0x218 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #3 (&ctx->mutex){+.+.+.}: -> #2 (cpu_hotplug.lock){+.+.+.}: -> #1 (module_mutex){+.+...}: -> #0 (event_mutex){+.+.+.}: But because the deadlock would be cpuhotplug (cpu-event) vs fork (task-event) it cannot, in fact, happen. We can annotate this by giving the perf_event_context used for the cpuctx a different lock class from those used by tasks. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-21genirq: Remove __do_IRQThomas Gleixner
All architectures are finally converted. Remove the cruft. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Mike Frysinger <vapier@gentoo.org> Cc: David Howells <dhowells@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Michal Simek <monstr@monstr.eu> Acked-by: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jeff Dike <jdike@addtoit.com>
2011-01-20Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: smp: Allow on_each_cpu() to be called while early_boot_irqs_disabled status to init/main.c lockdep: Move early boot local IRQ enable/disable status to init/main.c
2011-01-20Merge branch 'akpm'Linus Torvalds
* akpm: kernel/smp.c: consolidate writes in smp_call_function_interrupt() kernel/smp.c: fix smp_call_function_many() SMP race memcg: correctly order reading PCG_USED and pc->mem_cgroup backlight: fix 88pm860x_bl macro collision drivers/leds/ledtrig-gpio.c: make output match input, tighten input checking MAINTAINERS: update Atmel AT91 entry mm: fix truncate_setsize() comment memcg: fix rmdir, force_empty with THP memcg: fix LRU accounting with THP memcg: fix USED bit handling at uncharge in THP memcg: modify accounting function for supporting THP better fs/direct-io.c: don't try to allocate more than BIO_MAX_PAGES in a bio mm: compaction: prevent division-by-zero during user-requested compaction mm/vmscan.c: remove duplicate include of compaction.h memblock: fix memblock_is_region_memory() thp: keep highpte mapped until it is no longer needed kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERT
2011-01-20kernel/smp.c: consolidate writes in smp_call_function_interrupt()Milton Miller
We have to test the cpu mask in the interrupt handler before checking the refs, otherwise we can start to follow an entry before its deleted and find it partially initailzed for the next trip. Presently we also clear the cpumask bit before executing the called function, which implies getting write access to the line. After the function is called we then decrement refs, and if they go to zero we then unlock the structure. However, this implies getting write access to the call function data before and after another the function is called. If we can assert that no smp_call_function execution function is allowed to enable interrupts, then we can move both writes to after the function is called, hopfully allowing both writes with one cache line bounce. On a 256 thread system with a kernel compiled for 1024 threads, the time to execute testcase in the "smp_call_function_many race" changelog was reduced by about 30-40ms out of about 545 ms. I decided to keep this as WARN because its now a buggy function, even though the stack trace is of no value -- a simple printk would give us the information needed. Raw data: Without patch: ipi_test startup took 1219366ns complete 539819014ns total 541038380ns ipi_test startup took 1695754ns complete 543439872ns total 545135626ns ipi_test startup took 7513568ns complete 539606362ns total 547119930ns ipi_test startup took 13304064ns complete 533898562ns total 547202626ns ipi_test startup took 8668192ns complete 544264074ns total 552932266ns ipi_test startup took 4977626ns complete 548862684ns total 553840310ns ipi_test startup took 2144486ns complete 541292318ns total 543436804ns ipi_test startup took 21245824ns complete 530280180ns total 551526004ns With patch: ipi_test startup took 5961748ns complete 500859628ns total 506821376ns ipi_test startup took 8975996ns complete 495098924ns total 504074920ns ipi_test startup took 19797750ns complete 492204740ns total 512002490ns ipi_test startup took 14824796ns complete 487495878ns total 502320674ns ipi_test startup took 11514882ns complete 494439372ns total 505954254ns ipi_test startup took 8288084ns complete 502570774ns total 510858858ns ipi_test startup took 6789954ns complete 493388112ns total 500178066ns #include <linux/module.h> #include <linux/init.h> #include <linux/sched.h> /* sched clock */ #define ITERATIONS 100 static void do_nothing_ipi(void *dummy) { } static void do_ipis(struct work_struct *dummy) { int i; for (i = 0; i < ITERATIONS; i++) smp_call_function(do_nothing_ipi, NULL, 1); printk(KERN_DEBUG "cpu %d finished\n", smp_processor_id()); } static struct work_struct work[NR_CPUS]; static int __init testcase_init(void) { int cpu; u64 start, started, done; start = local_clock(); for_each_online_cpu(cpu) { INIT_WORK(&work[cpu], do_ipis); schedule_work_on(cpu, &work[cpu]); } started = local_clock(); for_each_online_cpu(cpu) flush_work(&work[cpu]); done = local_clock(); pr_info("ipi_test startup took %lldns complete %lldns total %lldns\n", started-start, done-started, done-start); return 0; } static void __exit testcase_exit(void) { } module_init(testcase_init) module_exit(testcase_exit) MODULE_LICENSE("GPL"); MODULE_AUTHOR("Anton Blanchard"); Signed-off-by: Milton Miller <miltonm@bga.com> Cc: Anton Blanchard <anton@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-20kernel/smp.c: fix smp_call_function_many() SMP raceAnton Blanchard
I noticed a failure where we hit the following WARN_ON in generic_smp_call_function_interrupt: if (!cpumask_test_and_clear_cpu(cpu, data->cpumask)) continue; data->csd.func(data->csd.info); refs = atomic_dec_return(&data->refs); WARN_ON(refs < 0); <------------------------- We atomically tested and cleared our bit in the cpumask, and yet the number of cpus left (ie refs) was 0. How can this be? It turns out commit 54fdade1c3332391948ec43530c02c4794a38172 ("generic-ipi: make struct call_function_data lockless") is at fault. It removes locking from smp_call_function_many and in doing so creates a rather complicated race. The problem comes about because: - The smp_call_function_many interrupt handler walks call_function.queue without any locking. - We reuse a percpu data structure in smp_call_function_many. - We do not wait for any RCU grace period before starting the next smp_call_function_many. Imagine a scenario where CPU A does two smp_call_functions back to back, and CPU B does an smp_call_function in between. We concentrate on how CPU C handles the calls: CPU A CPU B CPU C CPU D smp_call_function smp_call_function_interrupt walks call_function.queue sees data from CPU A on list smp_call_function smp_call_function_interrupt walks call_function.queue sees (stale) CPU A on list smp_call_function int clears last ref on A list_del_rcu, unlock smp_call_function reuses percpu *data A data->cpumask sees and clears bit in cpumask might be using old or new fn! decrements refs below 0 set data->refs (too late!) The important thing to note is since the interrupt handler walks a potentially stale call_function.queue without any locking, then another cpu can view the percpu *data structure at any time, even when the owner is in the process of initialising it. The following test case hits the WARN_ON 100% of the time on my PowerPC box (having 128 threads does help :) #include <linux/module.h> #include <linux/init.h> #define ITERATIONS 100 static void do_nothing_ipi(void *dummy) { } static void do_ipis(struct work_struct *dummy) { int i; for (i = 0; i < ITERATIONS; i++) smp_call_function(do_nothing_ipi, NULL, 1); printk(KERN_DEBUG "cpu %d finished\n", smp_processor_id()); } static struct work_struct work[NR_CPUS]; static int __init testcase_init(void) { int cpu; for_each_online_cpu(cpu) { INIT_WORK(&work[cpu], do_ipis); schedule_work_on(cpu, &work[cpu]); } return 0; } static void __exit testcase_exit(void) { } module_init(testcase_init) module_exit(testcase_exit) MODULE_LICENSE("GPL"); MODULE_AUTHOR("Anton Blanchard"); I tried to fix it by ordering the read and the write of ->cpumask and ->refs. In doing so I missed a critical case but Paul McKenney was able to spot my bug thankfully :) To ensure we arent viewing previous iterations the interrupt handler needs to read ->refs then ->cpumask then ->refs _again_. Thanks to Milton Miller and Paul McKenney for helping to debug this issue. [miltonm@bga.com: add WARN_ON and BUG_ON, remove extra read of refs before initial read of mask that doesn't help (also noted by Peter Zijlstra), adjust comments, hopefully clarify scenario ] [miltonm@bga.com: remove excess tests] Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Milton Miller <miltonm@bga.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: <stable@kernel.org> [2.6.32+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-20Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched, cgroup: Use exit hook to avoid use-after-free crash sched: Fix signed unsigned comparison in check_preempt_tick() sched: Replace rq->bkl_count with rq->rq_sched_info.bkl_count sched, autogroup: Fix CONFIG_RT_GROUP_SCHED sched_setscheduler() failure sched: Display autogroup names in /proc/sched_debug sched: Reinstate group names in /proc/sched_debug sched: Update effective_load() to use global share weights
2011-01-20smp: Allow on_each_cpu() to be called while early_boot_irqs_disabled status ↵Tejun Heo
to init/main.c percpu may end up calling vfree() during early boot which in turn may call on_each_cpu() for TLB flushes. The function of on_each_cpu() can be done safely while IRQ is disabled during early boot but it assumed that the function is always called with local IRQ enabled which ended up enabling local IRQ prematurely during boot and triggering a couple of warnings. This patch updates on_each_cpu() and smp_call_function_many() such on_each_cpu() can be used safely while early_boot_irqs_disabled is set. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <20110120110713.GC6036@htj.dyndns.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Reported-by: Ingo Molnar <mingo@elte.hu>
2011-01-20lockdep: Move early boot local IRQ enable/disable status to init/main.cTejun Heo
During early boot, local IRQ is disabled until IRQ subsystem is properly initialized. During this time, no one should enable local IRQ and some operations which usually are not allowed with IRQ disabled, e.g. operations which might sleep or require communications with other processors, are allowed. lockdep tracked this with early_boot_irqs_off/on() callbacks. As other subsystems need this information too, move it to init/main.c and make it generally available. While at it, toggle the boolean to early_boot_irqs_disabled instead of enabled so that it can be initialized with %false and %true indicates the exceptional condition. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <20110120110635.GB6036@htj.dyndns.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-19hrtimers: Notify hrtimer users of switches to NOHZ modeStephen Boyd
When NOHZ=y and high res timers are disabled (via cmdline or Kconfig) tick_nohz_switch_to_nohz() will notify the user about switching into NOHZ mode. Nothing is printed for the case where HIGH_RES_TIMERS=y. Fix this for the HIGH_RES_TIMERS=y case by duplicating the printk from the low res NOHZ path in the high res NOHZ path. This confused me since I was thinking 'dmesg | grep -i NOHZ' would tell me if NOHZ was enabled, but if I have hrtimers there is nothing. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1295419594-13085-1-git-send-email-sboyd@codeaurora.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-19perf: Fix perf_event_init_task()/perf_event_free_task() interactionOleg Nesterov
perf_event_init_task() should clear child->perf_event_ctxp[] before anything else. Otherwise, if perf_event_init_context(perf_hw_context) fails, perf_event_free_task() can free perf_event_ctxp[perf_sw_context] copied from parent->perf_event_ctxp[] by dup_task_struct(). Also move the initialization of perf_event_mutex and perf_event_list from perf_event_init_context() to perf_event_init_context(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Prasad <prasad@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> LKML-Reference: <20110119182228.GC12183@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-19perf: Fix find_get_context() vs perf_event_exit_task() raceOleg Nesterov
find_get_context() must not install the new perf_event_context if the task has already passed perf_event_exit_task(). If nothing else, this means the memory leak. Initially ctx->refcount == 2, it is supposed that perf_event_exit_task_context() should participate and do the necessary put_ctx(). find_lively_task_by_vpid() checks PF_EXITING but this buys nothing, by the time we call find_get_context() this task can be already dead. To the point, cmpxchg() can succeed when the task has already done the last schedule(). Change find_get_context() to populate task->perf_event_ctxp[] under task->perf_event_mutex, this way we can trust PF_EXITING because perf_event_exit_task() takes the same mutex. Also, change perf_event_exit_task_context() to use rcu_dereference(). Probably this is not strictly needed, but with or without this change find_get_context() can race with setup_new_exec()->perf_event_exit_task(), rcu_dereference() looks better. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Prasad <prasad@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> LKML-Reference: <20110119182207.GB12183@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-19sched, cgroup: Use exit hook to avoid use-after-free crashPeter Zijlstra
By not notifying the controller of the on-exit move back to init_css_set, we fail to move the task out of the previous cgroup's cfs_rq. This leads to an opportunity for a cgroup-destroy to come in and free the cgroup (there are no active tasks left in it after all) to which the not-quite dead task is still enqueued. Reported-by: Miklos Vajna <vmiklos@frugalware.org> Fixed-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@kernel.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1293206353.29444.205.camel@laptop>
2011-01-18Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf: Validate cpu early in perf_event_alloc() perf: Find_get_context: fix the per-cpu-counter check perf: Fix contexted inheritance
2011-01-18perf: Validate cpu early in perf_event_alloc()Oleg Nesterov
Starting from perf_event_alloc()->perf_init_event(), the kernel assumes that event->cpu is either -1 or the valid CPU number. Change perf_event_alloc() to validate this argument early. This also means we can remove the similar check in find_get_context(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Prasad <prasad@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> Cc: gregkh@suse.de Cc: stable@kernel.org LKML-Reference: <20110118161032.GC693@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-18perf: Find_get_context: fix the per-cpu-counter checkOleg Nesterov
If task == NULL, find_get_context() should always check that cpu is correct. Afaics, the bug was introduced by 38a81da2 "perf events: Clean up pid passing", but even before that commit "&& cpu != -1" was not exactly right, -ESRCH from find_task_by_vpid() is not accurate. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Prasad <prasad@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> Cc: gregkh@suse.de Cc: stable@kernel.org LKML-Reference: <20110118161008.GB693@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-18perf: Fix contexted inheritancePeter Zijlstra
Linus reported that the RCU lockdep annotation bits triggered for this rcu_dereference() because we're not holding rcu_read_lock(). Going over the code I cannot convince myself its correct: - holding a ref on the parent_ctx, doesn't avoid it being uncloned concurrently (as the comment says), so we can race with a free. - holding parent_ctx->mutex doesn't avoid the above free from taking place either, it would at best avoid parent_ctx from being freed. I.e. the warning is correct. To fix the bug, serialize against the unclone_ctx() call by extending the reach of the parent_ctx->lock. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-18sched: Fix signed unsigned comparison in check_preempt_tick()Mike Galbraith
Signed unsigned comparison may lead to superfluous resched if leftmost is right of the current task, wasting a few cycles, and inadvertently _lengthening_ the current task's slice. Reported-by: Venkatesh Pallipadi <venki@google.com> Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1294202477.9384.5.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-18sched: Replace rq->bkl_count with rq->rq_sched_info.bkl_countYong Zhang
Now rq->rq_sched_info.bkl_count is not used for rq, scroll rq->bkl_count into it. Thus we can save some space for rq. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1294991859-13246-1-git-send-email-yong.zhang0@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-18sched, autogroup: Fix CONFIG_RT_GROUP_SCHED sched_setscheduler() failureMike Galbraith
If CONFIG_RT_GROUP_SCHED is set, __sched_setscheduler() fails due to autogroup not allocating rt_runtime. Free unused/unusable rt_se and rt_rq, redirect RT tasks to the root task group, and tell __sched_setscheduler() that it's ok. Reported-and-tested-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1294890890.8089.39.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-18sched: Display autogroup names in /proc/sched_debugBharata B Rao
Add autogroup name to cfs_rq and tasks information to /proc/sched_debug. Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110111101257.GF4772@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-18sched: Reinstate group names in /proc/sched_debugBharata B Rao
Displaying of group names in /proc/sched_debug was dropped in autogroup patches. Add group names while displaying cfs_rq and tasks information. Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110111101153.GE4772@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-18sched: Update effective_load() to use global share weightsPaul Turner
Previously effective_load would approximate the global load weight present on a group taking advantage of: entity_weight = tg->shares ( lw / global_lw ), where entity_weight was provided by tg_shares_up. This worked (approximately) for an 'empty' (at tg level) cpu since we would place boost load representative of what a newly woken task would receive. However, now that load is instantaneously updated this assumption is no longer true and the load calculation is rather incorrect in this case. Fix this (and improve the general case) by re-writing effective_load to take advantage of the new shares distribution code. Signed-off-by: Paul Turner <pjt@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110115015817.069769529@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-15Merge branches 'core-fixes-for-linus', 'x86-fixes-for-linus', ↵Linus Torvalds
'timers-fixes-for-linus' and 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: avoid pointless blocked-task warnings rcu: demote SRCU_SYNCHRONIZE_DELAY from kernel-parameter status rtmutex: Fix comment about why new_owner can be NULL in wake_futex_pi() * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, olpc: Add missing Kconfig dependencies x86, mrst: Set correct APB timer IRQ affinity for secondary cpu x86: tsc: Fix calibration refinement conditionals to avoid divide by zero x86, ia64, acpi: Clean up x86-ism in drivers/acpi/numa.c * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: timekeeping: Make local variables static time: Rename misnamed minsec argument of clocks_calc_mult_shift() * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing: Remove syscall_exit_fields tracing: Only process module tracepoints once perf record: Add "nodelay" mode, disabled by default perf sched: Fix list of events, dropping unsupported ':r' modifier Revert "perf tools: Emit clearer message for sys_perf_event_open ENOENT return" perf top: Fix annotate segv perf evsel: Fix order of event list deletion
2011-01-14tracing: Remove syscall_exit_fieldsLai Jiangshan
There is no need for syscall_exit_fields as the syscall exit event class can already host the fields in its structure, like most other trace events do by default. Use that default behavior instead. Following this scheme, we don't need anymore to override the get_fields() callback of the syscall exit event class either. Hence both syscall_exit_fields and syscall_get_exit_fields() can be removed. Also changed some indentation to keep the following under 80 characters: ".fields = LIST_HEAD_INIT(event_class_syscall_exit.fields)," Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <4D301C0E.8090408@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-01-14Merge branch 'vfs-scale-working' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin * 'vfs-scale-working' of git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin: kernel: fix hlist_bl again cgroups: Fix a lockdep warning at cgroup removal fs: namei fix ->put_link on wrong inode in do_filp_open
2011-01-14cgroup_fs: fix cgroup use of simple_lookup()Al Viro
cgroup can't use simple_lookup(), since that'd override its desired ->d_op. Tested-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-14Merge branch 'rcu/next' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/urgent
2011-01-14rcu: avoid pointless blocked-task warningsPaul E. McKenney
If the RCU callback-processing kthread has nothing to do, it parks in a wait_event(). If RCU remains idle for more than two minutes, the kernel complains about this. This commit changes from wait_event() to wait_event_interruptible() to prevent the kernel from complaining just because RCU is idle. Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Thomas Weber <weber@corscience.de> Tested-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-14rcu: demote SRCU_SYNCHRONIZE_DELAY from kernel-parameter statusPaul E. McKenney
Because the adaptive synchronize_srcu_expedited() approach has worked very well in testing, remove the kernel parameter and replace it by a C-preprocessor macro. If someone finds problems with this approach, a more complex and aggressively adaptive approach might be required. Longer term, SRCU will be merged with the other RCU implementations, at which point synchronize_srcu_expedited() will be event driven, just as synchronize_sched_expedited() currently is. At that point, there will be no need for this adaptive approach. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
