There is a piece of sanity checks code in the put_unbound_pool().
The meaning of this code is "if it is not an unbound pool, it will complain
and return" IIUC. But the code uses "pool->flags & POOL_DISASSOCIATED"
imprecisely due to a non-unbound pool may also have this flags.
We should use "pool->cpu < 0" to stand for an unbound pool, so we covert the
code to it.
There is no strictly wrong if we still keep "pool->flags & POOL_DISASSOCIATED"
here, but it is just a noise if we keep it:
1) we focus on "unbound" here, not "[dis]association".
2) "pool->cpu < 0" already implies "pool->flags & POOL_DISASSOCIATED".
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Pull workqueue updates from Tejun Heo:
"Lai simplified worker destruction path and internal workqueue locking
and there are some other minor changes.
Except for the removal of some long-deprecated interfaces which
haven't had any in-kernel user for quite a while, there shouldn't be
any difference to workqueue users"
* 'for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
kernel/workqueue.c: pr_warning/pr_warn & printk/pr_info
workqueue: remove the confusing POOL_FREEZING
workqueue: rename first_worker() to first_idle_worker()
workqueue: remove unused work_clear_pending()
workqueue: remove unused WORK_CPU_END
workqueue: declare system_highpri_wq
workqueue: use generic attach/detach routine for rescuers
workqueue: separate pool-attaching code out from create_worker()
workqueue: rename manager_mutex to attach_mutex
workqueue: narrow the protection range of manager_mutex
workqueue: convert worker_idr to worker_ida
workqueue: separate iteration role from worker_idr
workqueue: destroy worker directly in the idle timeout handler
workqueue: async worker destruction
workqueue: destroy_worker() should destroy idle workers only
workqueue: use manager lock only to protect worker_idr
workqueue: Remove deprecated system_nrt[_freezable]_wq
workqueue: Remove deprecated flush[_delayed]_work_sync()
workqueue: simplify wq_update_unbound_numa() by jumping to use_dfl_pwq if the target cpumask equals wq's
This commit did an incorrect printk->pr_info conversion. If we were
converting to pr_info() we should lose the log_level parameter. The problem is
that this is called (indirectly) by show_regs_print_info(), which is called
with various log_levels (from _INFO clear to _EMERG). So we leave it as
a printk() call so the desired log_level is applied.
Not a full revert, as the other half of the patch is correct.
Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Currently, the global freezing state is propagated to worker_pools via
POOL_FREEZING and then to each workqueue; however, the middle step -
propagation through worker_pools - can be skipped as long as one or
more max_active adjustments happens for each workqueue after the
update to the global state is visible. The global workqueue freezing
state and the max_active adjustments during workqueue creation and
[un]freezing are serialized with wq_pool_mutex, so it's trivial to
guarantee that max_actives stay in sync with global freezing state.
POOL_FREEZING is unnecessary and makes the code more confusing and
complicates freeze_workqueues_begin() and thaw_workqueues() by
requiring them to walk through all pools.
Remove POOL_FREEZING and use workqueue_freezing directly instead.
tj: Description and comment updates.
first_worker() actually returns the first idle workers, the name
first_idle_worker() which is self-commnet will be better.
All the callers of first_worker() expect it returns an idle worker,
the name first_idle_worker() with "idle" notation makes reviewers happier.
There are several problems with the code that rescuers use to bind
themselve to the target pool's cpumask.
1) It is very different from how the normal workers bind to cpumask,
increasing code complexity and maintenance overhead.
2) The code of cpu-binding for rescuers is complicated.
3) If one or more cpu hotplugs happen while a rescuer is processing
its scheduled work items, the rescuer may not stay bound to the
cpumask of the pool. This is an allowed behavior, but is still
hairy. It will be better if the cpumask of the rescuer is always
kept synchronized with the pool across cpu hotplugs.
Using generic attach/detach routine will solve the above problems and
results in much simpler code.
tj: Minor description updates.
Currently, the code to attach a new worker to its pool is embedded in
create_worker(). Separating this code out will make the codes clearer
and will allow rescuers to share the code path later.
manager_mutex is only used to protect the attaching for the pool
and the pool->workers list. It protects the pool->workers and operations
based on this list, such as:
cpu-binding for the workers in the pool->workers
the operations to set/clear WORKER_UNBOUND
So let's rename manager_mutex to attach_mutex to better reflect its
role. This patch is a pure rename.
tj: Minor command and description updates.
In create_worker(), as pool->worker_ida now uses
ida_simple_get()/ida_simple_put() and doesn't require external
synchronization, it doesn't need manager_mutex.
struct worker allocation and kthread allocation are not visible by any
one before attached, so they don't need manager_mutex either.
The above operations are before the attaching operation which attaches
the worker to the pool. Between attaching and starting the worker, the
worker is already attached to the pool, so the cpu hotplug will handle
cpu-binding for the worker correctly and we don't need the
manager_mutex after attaching.
The conclusion is that only the attaching operation needs manager_mutex,
so we narrow the protection section of manager_mutex in create_worker().
Some comments about manager_mutex are removed, because we will rename
it to attach_mutex and add worker_attach_to_pool() later which will be
self-explanatory.
We no longer iterate workers via worker_idr and worker_idr is used
only for allocating/freeing ID, so we can convert it to worker_ida.
By using ida_simple_get/remove(), worker_ida doesn't require external
synchronization, so we don't need manager_mutex to protect it and the
ID-removal code is allowed to be moved out from
worker_detach_from_pool().
In a later patch, worker_detach_from_pool() will be used in rescuers
which don't have IDs, so we move the ID-removal code out from
worker_detach_from_pool() into worker_thread().
worker_idr has the iteration (iterating for attached workers) and
worker ID duties. These two duties don't have to be tied together. We
can separate them and use a list for tracking attached workers and
iteration.
Before this separation, it wasn't possible to add rescuer workers to
worker_idr due to rescuer workers couldn't allocate ID dynamically
because ID-allocation depends on memory-allocation, which rescuer
can't depend on.
After separation, we can easily add the rescuer workers to the list for
iteration without any memory-allocation. It is required when we attach
the rescuer worker to the pool in later patch.
Since destroy_worker() doesn't need to sleep nor require manager_mutex,
destroy_worker() can be directly called in the idle timeout
handler, it helps us remove POOL_MANAGE_WORKERS and
maybe_destroy_worker() and simplify the manage_workers()
After POOL_MANAGE_WORKERS is removed, worker_thread() doesn't
need to test whether it needs to manage after processed works.
So we can remove the test branch.
worker destruction includes these parts of code:
adjust pool's stats
remove the worker from idle list
detach the worker from the pool
kthread_stop() to wait for the worker's task exit
free the worker struct
We can find out that there is no essential work to do after
kthread_stop(), which means destroy_worker() doesn't need to wait for
the worker's task exit, so we can remove kthread_stop() and free the
worker struct in the worker exiting path.
However, put_unbound_pool() still needs to sync the all the workers'
destruction before destroying the pool; otherwise, the workers may
access to the invalid pool when they are exiting.
So we also move the code of "detach the worker" to the exiting
path and let put_unbound_pool() to sync with this code via
detach_completion.
The code of "detach the worker" is wrapped in a new function
"worker_detach_from_pool()" although worker_detach_from_pool() is only
called once (in worker_thread()) after this patch, but we need to wrap
it for these reasons:
1) The code of "detach the worker" is not short enough to unfold them
in worker_thread().
2) the name of "worker_detach_from_pool()" is self-comment, and we add
some comments above the function.
3) it will be shared by rescuer in later patch which allows rescuer
and normal thread use the same attach/detach frameworks.
The worker id is freed when detaching which happens before the worker
is fully dead, but this id of the dying worker may be re-used for a
new worker, so the dying worker's task name is changed to
"worker/dying" to avoid two or several workers having the same name.
Since "detach the worker" is moved out from destroy_worker(),
destroy_worker() doesn't require manager_mutex, so the
"lockdep_assert_held(&pool->manager_mutex)" in destroy_worker() is
removed, and destroy_worker() is not protected by manager_mutex in
put_unbound_pool().
We used to have the CPU online failure path where a worker is created
and then destroyed without being started. A worker was created for
the CPU coming online and if the online operation failed the created worker
was shut down without being started. But this behavior was changed.
The first worker is created and started at the same time for the CPU coming
online.
It means that we had already ensured in the code that destroy_worker()
destroys only idle workers and we don't want to allow it to destroy
any non-idle worker in the future. Otherwise, it may be buggy and it
may be extremely hard to check. We should force destroy_worker() to
destroy only idle workers explicitly.
Since destroy_worker() destroys only idle workers, this patch does not
change any functionality. We just need to update the comments and the
sanity check code.
In the sanity check code, we will refuse to destroy the worker
if !(worker->flags & WORKER_IDLE).
If the worker entered idle which means it is already started,
so we remove the check of "worker->flags & WORKER_STARTED",
after this removal, WORKER_STARTED is totally unneeded,
so we remove WORKER_STARTED too.
In the comments for create_worker(), "Create a new worker which is bound..."
is changed to "... which is attached..." due to we change the name of this
behavior to attaching.
tj: Minor description / comment updates.
worker_idr is highly bound to managers and is always/only accessed in manager
lock context. So we don't need pool->lock for it.
tj: Refreshed on top of wq/for-3.16.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
wq_update_unbound_numa(), when it's decided that the newly updated
cpumask equals the default, looks at whether the current pwq is
already the default one and skips setting pwq to the default one.
This extra step is unnecessary and we can always jump to use_dfl_pwq
instead. Simplify the code by removing the conditional.
This doesn't make any functional difference.
Signed-off-by: Daeseok Youn <daeseok.youn@gmail.com>
There is a race condition between rescuer_thread() and
pwq_unbound_release_workfn().
Even after a pwq is scheduled for rescue, the associated work items
may be consumed by any worker. If all of them are consumed before the
rescuer gets to them and the pwq's base ref was put due to attribute
change, the pwq may be released while still being linked on
@wq->maydays list making the rescuer dereference already freed pwq
later.
Make send_mayday() pin the target pwq until the rescuer is done with
it.
tj: Updated comment and patch description.
Cc: stable@vger.kernel.org # v3.10+
After a @pwq is scheduled for emergency execution, other workers may
consume the affectd work items before the rescuer gets to them. This
means that a workqueue many have pwqs queued on @wq->maydays list
while not having any work item pending or in-flight. If
destroy_workqueue() executes in such condition, the rescuer may exit
without emptying @wq->maydays.
This currently doesn't cause any actual harm. destroy_workqueue() can
safely destroy all the involved data structures whether @wq->maydays
is populated or not as nobody access the list once the rescuer exits.
However, this is nasty and makes future development difficult. Let's
update rescuer_thread() so that it empties @wq->maydays after seeing
should_stop to guarantee that the list is empty on rescuer exit.
Replace various -20/+19 hardcoded nice values with MIN_NICE/MAX_NICE.
Signed-off-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com>
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/ff13819fd09b7a5dba5ab5ae797f2e7019bdfa17.1394532288.git.yangds.fnst@cn.fujitsu.com
Cc: devel@driverdev.osuosl.org
Cc: devicetree@vger.kernel.org
Cc: fcoe-devel@open-fcoe.org
Cc: linux390@de.ibm.com
Cc: linux-mm@kvack.org
Cc: linux-s390@vger.kernel.org
Cc: linux-scsi@vger.kernel.org
Cc: nbd-general@lists.sourceforge.net
Cc: ocfs2-devel@oss.oracle.com
Cc: openipmi-developer@lists.sourceforge.net
Cc: qla2xxx-upstream@qlogic.com
[ Consolidated the patches, twiddled the changelog. ]
wq_update_unbound_numa() failure path has the following two bugs.
- alloc_unbound_pwq() is called without holding wq->mutex; however, if
the allocation fails, it jumps to out_unlock which tries to unlock
wq->mutex.
- The function should switch to dfl_pwq on failure but didn't do so
after alloc_unbound_pwq() failure.
Fix it by regrabbing wq->mutex and jumping to use_dfl_pwq on
Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Fixes: 4c16bd327c74 ("workqueue: implement NUMA affinity for unbound workqueues")
Pull timer changes from Thomas Gleixner:
"This assorted collection provides:
- A new timer based timer broadcast feature for systems which do not
provide a global accessible timer device. That allows those
systems to put CPUs into deep idle states where the per cpu timer
device stops.
- A few NOHZ_FULL related improvements to the timer wheel
- The usual updates to timer devices found in ARM SoCs
- Small improvements and updates all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (44 commits)
tick: Remove code duplication in tick_handle_periodic()
tick: Fix spelling mistake in tick_handle_periodic()
x86: hpet: Use proper destructor for delayed work
workqueue: Provide destroy_delayed_work_on_stack()
clocksource: CMT, MTU2, TMU and STI should depend on GENERIC_CLOCKEVENTS
timer: Remove code redundancy while calling get_nohz_timer_target()
hrtimer: Rearrange comments in the order struct members are declared
timer: Use variable head instead of &work_list in __run_timers()
clocksource: exynos_mct: silence a static checker warning
arm: zynq: Add support for cpufreq
arm: zynq: Don't use arm_global_timer with cpufreq
clocksource/cadence_ttc: Overhaul clocksource frequency adjustment
clocksource/cadence_ttc: Call clockevents_update_freq() with IRQs enabled
clocksource: Add Kconfig entries for CMT, MTU2, TMU and STI
sh: Remove Kconfig entries for TMU, CMT and MTU2
ARM: shmobile: Remove CMT, TMU and STI Kconfig entries
clocksource: armada-370-xp: Use atomic access for shared registers
clocksource: orion: Use atomic access for shared registers
clocksource: timer-keystone: Delete unnecessary variable
clocksource: timer-keystone: introduce clocksource driver for Keystone
If a delayed or deferrable work is on stack we need to tell debug
objects that we are destroying the timer and the work. Otherwise we
leak the tracking object.
Cc: Vince Weaver <vincent.weaver@maine.edu>
Link: http://lkml.kernel.org/r/20140323141939.911487677@linutronix.de
Link: http://lkml.kernel.org/r/6d85138180c00ce86975addab6e34b24b84f00a5.1392103744.git.yangds.fnst@cn.fujitsu.com
When a kworker should die, the kworkre is notified through WORKER_DIE
flag instead of kthread_should_stop(). This, IIRC, is primarily to
keep the test synchronized inside worker_pool lock. WORKER_DIE is
first set while holding pool->lock, the lock is dropped and
kthread_stop() is called.
Unfortunately, this means that there's a slight chance that the target
kworker may see WORKER_DIE before kthread_stop() finishes and exits
and frees the target task before or during kthread_stop().
Fix it by pinning the target task before setting WORKER_DIE and
putting it after kthread_stop() is done.
tj: Improved patch description and comment. Moved pinning above
WORKER_DIE for better signify what it's protecting.
CC: stable@vger.kernel.org
Pull workqueue update from Tejun Heo:
"Just one patch to add destroy_work_on_stack() annotations to help
debugobj debugging"
* 'for-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: Calling destroy_work_on_stack() to pair with INIT_WORK_ONSTACK()
In case CONFIG_DEBUG_OBJECTS_WORK is defined, it is needed to
call destroy_work_on_stack() which frees the debug object to pair
with INIT_WORK_ONSTACK().
Signed-off-by: Liu, Chuansheng <chuansheng.liu@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"PCI device hotplug
- Move device_del() from pci_stop_dev() to pci_destroy_dev() (Rafael
Wysocki)
Host bridge drivers
- Update maintainers for DesignWare, i.MX6, Armada, R-Car (Bjorn
Helgaas)
- mvebu: Return 'unsupported' for Interrupt Line and Interrupt Pin
(Jason Gunthorpe)
Miscellaneous
- Avoid unnecessary CPU switch when calling .probe() (Alexander
Duyck)
- Revert "workqueue: allow work_on_cpu() to be called recursively"
(Bjorn Helgaas)
- Disable Bus Master only on kexec reboot (Khalid Aziz)
- Omit PCI ID macro strings to shorten quirk names for LTO (Michal
Marek)"
* tag 'pci-v3.13-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
MAINTAINERS: Add DesignWare, i.MX6, Armada, R-Car PCI host maintainers
PCI: Disable Bus Master only on kexec reboot
PCI: mvebu: Return 'unsupported' for Interrupt Line and Interrupt Pin
PCI: Omit PCI ID macro strings to shorten quirk names
PCI: Move device_del() from pci_stop_dev() to pci_destroy_dev()
PCI: Avoid unnecessary CPU switch when calling driver .probe() method
This reverts commit c2fda509667b0fda4372a237f5a59ea4570b1627.
c2fda509667b removed lockdep annotation from work_on_cpu() to work around
the PCI path that calls work_on_cpu() from within a work_on_cpu() work item
(PF driver .probe() method -> pci_enable_sriov() -> add VFs -> VF driver
.probe method).
961da7fb6b22 ("PCI: Avoid unnecessary CPU switch when calling driver
.probe() method) avoids that recursive work_on_cpu() use in a different
way, so this revert restores the work_on_cpu() lockdep annotation.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
init_workqueues
When one work starts execution, the high bits of work's data contain
pool ID. It can represent a maximum of WORK_OFFQ_POOL_NONE. Pool ID
is assigned WORK_OFFQ_POOL_NONE when the work being initialized
indicating that no pool is associated and get_work_pool() uses it to
check the associated pool. So if worker_pool_assign_id() assigns a
ID greater than or equal WORK_OFFQ_POOL_NONE to a pool, it triggers
leakage, and it may break the non-reentrance guarantee.
This patch fix this issue by modifying the worker_pool_assign_id()
function calling idr_alloc() by setting @end param WORK_OFFQ_POOL_NONE.
Furthermore, in the current implementation, the BUILD_BUG_ON() in
init_workqueues makes no sense. The number of worker pools needed
cannot be determined at compile time, because the number of backing
pools for UNBOUND workqueues is dynamic based on the assigned custom
attributes. So remove it.
tj: Minor comment and indentation updates.
Signed-off-by: Li Bin <huawei.libin@huawei.com>
It seems the "dying" should be "draining" here.
An ordered workqueue implements execution ordering by using single
pool_workqueue with max_active == 1. On a given pool_workqueue, work
items are processed in FIFO order and limiting max_active to 1
enforces the queued work items to be processed one by one.
Unfortunately, 4c16bd327c ("workqueue: implement NUMA affinity for
unbound workqueues") accidentally broke this guarantee by applying
NUMA affinity to ordered workqueues too. On NUMA setups, an ordered
workqueue would end up with separate pool_workqueues for different
nodes. Each pool_workqueue still limits max_active to 1 but multiple
work items may be executed concurrently and out of order depending on
which node they are queued to.
Fix it by using dedicated ordered_wq_attrs[] when creating ordered
workqueues. The new attrs match the unbound ones except that no_numa
is always set thus forcing all NUMA nodes to share the default
pool_workqueue.
While at it, add sanity check in workqueue creation path which
verifies that an ordered workqueues has only the default
pool_workqueue.
Reported-by: Libin <huawei.libin@huawei.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Move the setting of PF_NO_SETAFFINITY up before set_cpus_allowed()
in create_worker(). Otherwise userland can change ->cpus_allowed
in between.
Pull trivial tree from Jiri Kosina:
"The usual trivial updates all over the tree -- mostly typo fixes and
documentation updates"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits)
doc: Documentation/cputopology.txt fix typo
treewide: Convert retrun typos to return
Fix comment typo for init_cma_reserved_pageblock
Documentation/trace: Correcting and extending tracepoint documentation
mm/hotplug: fix a typo in Documentation/memory-hotplug.txt
power: Documentation: Update s2ram link
doc: fix a typo in Documentation/00-INDEX
Documentation/printk-formats.txt: No casts needed for u64/s64
doc: Fix typo "is is" in Documentations
treewide: Fix printks with 0x%#
zram: doc fixes
Documentation/kmemcheck: update kmemcheck documentation
doc: documentation/hwspinlock.txt fix typo
PM / Hibernate: add section for resume options
doc: filesystems : Fix typo in Documentations/filesystems
scsi/megaraid fixed several typos in comments
ppc: init_32: Fix error typo "CONFIG_START_KERNEL"
treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks
page_isolation: Fix a comment typo in test_pages_isolated()
doc: fix a typo about irq affinity
"Nothing interesting. All are doc / comment updates"
* 'for-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: Correct/Drop references to gcwq in Documentation
workqueue: Fix manage_workers() RETURNS description
workqueue: Comment correction in file header
workqueue: mark WQ_NON_REENTRANT deprecated
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core patches from Greg KH:
"Here's the big driver core pull request for 3.12-rc1.
Lots of tiny changes here fixing up the way sysfs attributes are
created, to try to make drivers simpler, and fix a whole class race
conditions with creations of device attributes after the device was
announced to userspace.
All the various pieces are acked by the different subsystem
maintainers"
* tag 'driver-core-3.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (119 commits)
firmware loader: fix pending_fw_head list corruption
drivers/base/memory.c: introduce help macro to_memory_block
dynamic debug: line queries failing due to uninitialized local variable
sysfs: sysfs_create_groups returns a value.
debugfs: provide debugfs_create_x64() when disabled
rbd: convert bus code to use bus_groups
firmware: dcdbas: use binary attribute groups
sysfs: add sysfs_create/remove_groups for when SYSFS is not enabled
driver core: add #include <linux/sysfs.h> to core files.
HID: convert bus code to use dev_groups
Input: serio: convert bus code to use drv_groups
Input: gameport: convert bus code to use drv_groups
driver core: firmware: use __ATTR_RW()
driver core: core: use DEVICE_ATTR_RO
driver core: bus: use DRIVER_ATTR_WO()
driver core: create write-only attribute macros for devices and drivers
sysfs: create __ATTR_WO()
driver-core: platform: convert bus code to use dev_groups
workqueue: convert bus code to use dev_groups
MEI: convert bus code to use dev_groups
If !PREEMPT, a kworker running work items back to back can hog CPU.
This becomes dangerous when a self-requeueing work item which is
waiting for something to happen races against stop_machine. Such
self-requeueing work item would requeue itself indefinitely hogging
the kworker and CPU it's running on while stop_machine would wait for
that CPU to enter stop_machine while preventing anything else from
happening on all other CPUs. The two would deadlock.
Jamie Liu reports that this deadlock scenario exists around
scsi_requeue_run_queue() and libata port multiplier support, where one
port may exclude command processing from other ports. With the right
timing, scsi_requeue_run_queue() can end up requeueing itself trying
to execute an IO which is asked to be retried while another device has
an exclusive access, which in turn can't make forward progress due to
stop_machine.
Fix it by invoking cond_resched() after executing each work item.
Reported-by: Jamie Liu <jamieliu@google.com>
References: http://thread.gmane.org/gmane.linux.kernel/1552567
kernel/workqueue.c | 9 +++++++++
1 file changed, 9 insertions(+)
The dev_attrs field of struct bus_type is going away soon, dev_groups
should be used instead. This converts the workqueue bus code to use
the correct field.
No functional change. The comment of function manage_workers()
RETURNS description is obvious wrong, same as the CONTEXT.
Fix it.
Signed-off-by: Libin <huawei.libin@huawei.com>
No functional change. There are two worker pools for each cpu in
current implementation (one for normal work items and the other for
high priority ones).
tj: Whitespace adjustments.
When building the htmldocs (in verbose mode), scripts/kernel-doc reports the
following type of warnings:
Warning(kernel/workqueue.c:653): No description found for return value of
'get_work_pool'
Fix them by:
- Using "Return:" sections to introduce descriptions of return values
- Adding some missing descriptions
Signed-off-by: Yacine Belkadi <yacine.belkadi.1@gmail.com>
Pull two workqueue fixes from Tejun Heo:
"A lockdep notation update so that nested work_on_cpu() invocations
don't lead to spurious lockdep warnings and fix for an unbound attr
bug which made what's shown in sysfs deviate from the actual ones.
Both patches have pretty limited scope"
* 'for-3.11-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: copy workqueue_attrs with all fields
$echo '0' > /sys/bus/workqueue/devices/xxx/numa
$cat /sys/bus/workqueue/devices/xxx/numa
I got 1. It should be 0, the reason is copy_workqueue_attrs() called
in apply_workqueue_attrs() doesn't copy no_numa field.
Fix it by making copy_workqueue_attrs() copy ->no_numa too. This
would also make get_unbound_pool() set a pool's ->no_numa attribute
according to the workqueue attributes used when the pool was created.
While harmelss, as ->no_numa isn't a pool attribute, this is a bit
confusing. Clear it explicitly.
tj: Updated description and comments a bit.
Signed-off-by: Shaohua Li <shli@fusionio.com>
If the @fn call work_on_cpu() again, the lockdep will complain:
> [ INFO: possible recursive locking detected ]
> 3.11.0-rc1-lockdep-fix-a #6 Not tainted
> kworker/0:1/142 is trying to acquire lock:
> ((&wfc.work)){+.+.+.}, at: [<ffffffff81077100>] flush_work+0x0/0xb0
> but task is already holding lock:
> ((&wfc.work)){+.+.+.}, at: [<ffffffff81075dd9>] process_one_work+0x169/0x610
> other info that might help us debug this:
> Possible unsafe locking scenario:
> CPU0
> lock((&wfc.work));
> lock((&wfc.work));
> *** DEADLOCK ***
It is false-positive lockdep report. In this sutiation,
the two "wfc"s of the two work_on_cpu() are different,
they are both on stack. flush_work() can't be deadlock.
To fix this, we need to avoid the lockdep checking in this case,
thus we instroduce a internal __flush_work() which skip the lockdep.
tj: Minor comment adjustment.
Reported-by: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com>
Reported-by: Alexander Duyck <alexander.h.duyck@intel.com>
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
This removes all the uses of the __cpuinit macros from C files in
the core kernel directories (kernel, init, lib, mm, and include)
that don't really have a specific maintainer.
[1] https://lkml.org/lkml/2013/5/20/589
Pull workqueue changes from Tejun Heo:
"Surprisingly, Lai and I didn't break too many things implementing
custom pools and stuff last time around and there aren't any follow-up
changes necessary at this point.
The only change in this pull request is Viresh's patches to make some
per-cpu workqueues to behave as unbound workqueues dependent on a boot
param whose default can be configured via a config option. This leads
to higher processing overhead / lower bandwidth as more work items are
bounced across CPUs; however, it can lead to noticeable powersave in
certain configurations - ~10% w/ idlish constant workload on a
big.LITTLE configuration according to Viresh.
This is because per-cpu workqueues interfere with how the scheduler
perceives whether or not each CPU is idle by forcing pinned tasks on
them, which makes the scheduler's power-aware scheduling decisions
less effective.
Its effectiveness is likely less pronounced on homogenous
configurations and this type of optimization can probably be made
automatic; however, the changes are pretty minimal and the affected
workqueues are clearly marked, so it's an easy gain for some
configurations for the time being with pretty unintrusive changes."
* 'for-3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
fbcon: queue work on power efficient wq
block: queue work on power efficient wq
PHYLIB: queue work on system_power_efficient_wq
workqueue: Add system wide power_efficient workqueues
workqueues: Introduce new flag WQ_POWER_EFFICIENT for power oriented workqueues
wq_numa_init()
wq_numa_init() builds per-node cpumasks which are later used to make
unbound workqueues NUMA-aware. The cpumasks are allocated using
alloc_cpumask_var_node() for all possible nodes. Unfortunately, on
machines with off-line nodes, this leads to NUMA-aware allocations on
existing bug offline nodes, which in turn triggers BUG in the memory
allocation code.
Fix it by using NUMA_NO_NODE for cpumask allocations for offline
nodes.
kernel BUG at include/linux/gfp.h:323!
invalid opcode: 0000 [#1] SMP
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0+ #1
Hardware name: ProLiant BL465c G7, BIOS A19 12/10/2011
task: ffff880234608000 ti: ffff880234602000 task.ti: ffff880234602000
RIP: 0010:[<ffffffff8117495d>] [<ffffffff8117495d>] new_slab+0x2ad/0x340
RSP: 0000:ffff880234603bf8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff880237404b40 RCX: 00000000000000d0
RDX: 0000000000000001 RSI: 0000000000000003 RDI: 00000000002052d0
RBP: ffff880234603c28 R08: 0000000000000000 R09: 0000000000000001
R10: 0000000000000001 R11: ffffffff812e3aa8 R12: 0000000000000001
R13: ffff8802378161c0 R14: 0000000000030027 R15: 00000000000040d0
FS: 0000000000000000(0000) GS:ffff880237800000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff88043fdff000 CR3: 00000000018d5000 CR4: 00000000000007f0
Stack:
ffff880234603c28 0000000000000001 00000000000000d0 ffff8802378161c0
ffff880237404b40 ffff880237404b40 ffff880234603d28 ffffffff815edba1
ffff880237816140 0000000000000000 ffff88023740e1c0
Call Trace:
[<ffffffff815edba1>] __slab_alloc+0x330/0x4f2
[<ffffffff81174b25>] kmem_cache_alloc_node_trace+0xa5/0x200
[<ffffffff812e3aa8>] alloc_cpumask_var_node+0x28/0x90
[<ffffffff81a0bdb3>] wq_numa_init+0x10d/0x1be
[<ffffffff81a0bec8>] init_workqueues+0x64/0x341
[<ffffffff810002ea>] do_one_initcall+0xea/0x1a0
[<ffffffff819f1f31>] kernel_init_freeable+0xb7/0x1ec
[<ffffffff815d50de>] kernel_init+0xe/0xf0
[<ffffffff815ff89c>] ret_from_fork+0x7c/0xb0
Code: 45 84 ac 00 00 00 f0 41 80 4d 00 40 e9 f6 fe ff ff 66 0f 1f 84 00 00 00 00 00 e8 eb 4b ff ff 49 89 c5 e9 05 fe ff ff <0f> 0b 4c 8b 73 38 44 89 ff 81 cf 00 00 20 00 4c 89 f6 48 c1 ee
Reported-and-Tested-by: Lingzhu Xiang <lxiang@redhat.com>
Commit 8425e3d5bdbe ("workqueue: inline trivial wrappers") changed
schedule_work() and schedule_delayed_work() to inline wrappers,
but these rely on some symbols that are EXPORT_SYMBOL_GPL, while
the original functions were EXPORT_SYMBOL. This has the effect of
changing the licensing requirement for these functions and making
them unavailable to non GPL modules.
Make them available again by removing the restriction on the
required symbols.
Signed-off-by: Marc Dionne <marc.dionne@your-file-system.com>
When we fail to mutex_trylock(), we release the pool spin_lock and do
mutex_lock(). After that, we should regrab the pool spin_lock, but,
regrabbing is missed in current code. So correct it.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
