worker_thread() can miss freeze_process()->signal_wake_up() if it happens
between try_to_freeze() and prepare_to_wait(). We should check freezing()
before entering schedule().
This race was introduced by me in
[PATCH 1/1] workqueue: don't migrate pending works from the dead CPU
Looks like mm/vmscan.c:kswapd() has the same race.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
worker_thread() doesn't need to "Block and flush all signals", this was
already done by its caller, kthread().
We don't have any users, and it is not so trivial to use NOAUTOREL works
correctly. It is better to simplify API.
Delete NOAUTOREL support and rename work_release to work_clear_pending to
avoid a confusion.
cancel_rearming_delayed_workqueue(wq, dwork) doesn't need the first
parameter. We don't hang on un-queued dwork any longer, and work->data
doesn't change its type. This means we can always figure out "wq" from
dwork when it is needed.
Remove this parameter, and rename the function to
cancel_rearming_delayed_work(). Re-create an inline "obsolete"
cancel_rearming_delayed_workqueue(wq) which just calls
Cleanup. A number of per_cpu_ptr(wq->cpu_wq, cpu) users have to check that
cpu is valid for this wq. Make a simple helper.
Change queue_delayed_work() to use queue_delayed_work_on() to avoid the code
duplication (saves 133 bytes).
Q: queue_delayed_work() enqueues &dwork->work directly when delay == 0, why?
[jirislaby@gmail.com: oops fix]
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Currently typeof(delayed_work->work.data) is
"struct workqueue_struct" when the timer is pending
"struct cpu_workqueue_struct" whe the work is queued
This makes impossible to use flush_fork(delayed_work->work) in addition
to cancel_delayed_work/cancel_rearming_delayed_work, not good.
Change queue_delayed_work/delayed_work_timer_fn to use cwq, not wq. This
complicates (and uglifies) these functions a little bit, but alows us to
use flush_fork(dwork) and imho makes the whole code more consistent.
Also, document the fact that cancel_rearming_delayed_work() doesn't garantee
the completion of work->func() upon return.
CPU_UP_PREPARE binds cwq->thread to the new CPU. So CPU_UP_CANCELED tries to
wake up the task which is bound to the failed CPU.
With this patch we don't bind cwq->thread until CPU becomes online. The first
wake_up() after kthread_create() is a bit special, make a simple helper for
that.
Cc: Gautham R Shenoy <ego@in.ibm.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
The only caller of init_workqueues() is do_basic_setup().
Add explicit workqueue_struct->singlethread flag. This lessens .text a
little, but most importantly this allows us to manipulate wq->list without
changine the meaning of is_single_threaded().
The code like
if (is_single_threaded(wq))
do_something(singlethread_cpu);
else {
for_each_cpu_mask(cpu, cpu_populated_map)
do_something(cpu);
looks very annoying. We can add "static cpumask_t cpu_singlethread_map" and
simplify the code. Lessens .text a bit, and imho makes the code more readable.
cancel_rearming_delayed_workqueue(dwork) will hang forever if dwork was not
scheduled, because in that case cancel_delayed_work()->del_timer_sync() never
returns true.
I don't know if there are any callers which may have problems, but this is not
so convenient, and the fix is very simple.
Q: looks like we don't need "struct workqueue_struct *wq" parameter. If the
timer was aborted successfully, get_wq_data() == wq. Is it worth to add the
new function?
work->func() may sleep, it's a bug to call run_workqueue() with irqs disabled.
Because it has no callers.
Actually, I think the whole idea of run_scheduled_work() was not right, not
good to mix "unqueue this work and execute its ->func()" in one function.
Currently CPU_DEAD uses kthread_stop() to stop cwq->thread and then
transfers cwq->worklist to another CPU. However, it is very unlikely that
worker_thread() will notice kthread_should_stop() before flushing
cwq->worklist. It is only possible if worker_thread() was preempted after
run_workqueue(cwq), a new work_struct was added, and CPU_DEAD happened
before cwq->thread has a chance to run.
This means that take_over_work() mostly adds unneeded complications. Note
also that kthread_stop() is not good per se, wake_up_process() may confuse
work->func() if it sleeps waiting for some event.
Remove take_over_work() and migrate_sequence complications. CPU_DEAD sets
the cwq->should_stop flag (introduced by this patch) and waits for
cwq->thread to flush cwq->worklist and exit. Because the dead CPU is not
on cpu_online_map, no more works can be added to that cwq.
cpu_populated_map was introduced to optimize for_each_possible_cpu(), it is
not strictly needed, and it is more a documentation in fact.
Saves 418 bytes.
Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com>
Cc: "Pallipadi, Venkatesh" <venkatesh.pallipadi@intel.com>
Cc: Gautham shenoy <ego@in.ibm.com>
Pointed out by Srivatsa Vaddagiri.
cleanup_workqueue_thread() sets cwq->thread = NULL and does kthread_stop().
This breaks the "if (cwq->thread == current)" logic in flush_cpu_workqueue()
and leads to deadlock.
Kill the thead first, then clear cwq->thread. workqueue_mutex protects us
from create_workqueue_thread() so we don't need cwq->lock.
Many thanks to Srivatsa Vaddagiri for the helpful discussion and for spotting
the bug in my previous attempt.
work->func() (and thus flush_workqueue()) must not use workqueue_mutex,
this leads to deadlock when CPU_DEAD does kthread_stop(). However without
this mutex held we can't detect CPU_DEAD in progress, which can move pending
works to another CPU while the dead one is not on cpu_online_map.
Change flush_workqueue() to use for_each_possible_cpu(). This means that
flush_cpu_workqueue() may hit CPU which is already dead. However in that
case
!list_empty(&cwq->worklist) || cwq->current_work != NULL
means that CPU_DEAD in progress, it will do kthread_stop() + take_over_work()
so we can proceed and insert a barrier. We hold cwq->lock, so we are safe.
Also, add migrate_sequence incremented by take_over_work() under cwq->lock.
If take_over_work() happened before we checked this CPU, we should see the
new value after spin_unlock().
Further possible changes:
remove CPU_DEAD handling (along with take_over_work, migrate_sequence)
from workqueue.c. CPU_DEAD just sets cwq->please_exit_after_flush flag.
CPU_UP_PREPARE->create_workqueue_thread() clears this flag, and creates
the new thread if cwq->thread == NULL.
This way the workqueue/cpu-hotplug interaction is almost zero, workqueue_mutex
just protects "workqueues" list, CPU_LOCK_ACQUIRE/CPU_LOCK_RELEASE go away.
Currently ->freezeable is per-cpu, this is wrong. CPU_UP_PREPARE creates
cwq->thread which is not freezeable. Move ->freezeable to workqueue_struct.
Now when we have ->current_work we can avoid adding a barrier and waiting
for its completition when cwq's queue is empty.
Note: this change is also useful if we change flush_workqueue() to also
check the dead CPUs.
Cc: Gautham Shenoy <ego@in.ibm.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
A basic problem with flush_scheduled_work() is that it blocks behind _all_
presently-queued works, rather than just the work whcih the caller wants to
flush. If the caller holds some lock, and if one of the queued work happens
to want that lock as well then accidental deadlocks can occur.
One example of this is the phy layer: it wants to flush work while holding
rtnl_lock(). But if a linkwatch event happens to be queued, the phy code will
deadlock because the linkwatch callback function takes rtnl_lock.
So we implement a new function which will flush a *single* work - just the one
which the caller wants to free up. Thus we avoid the accidental deadlocks
which can arise from unrelated subsystems' callbacks taking shared locks.
flush_work() non-blockingly dequeues the work_struct which we want to kill,
then it waits for its handler to complete on all CPUs.
Add ->current_work to the "struct cpu_workqueue_struct", it points to
currently running "struct work_struct". When flush_work(work) detects
->current_work == work, it inserts a barrier at the _head_ of ->worklist
(and thus right _after_ that work) and waits for completition. This means
that the next work fired on that CPU will be this barrier, or another
barrier queued by concurrent flush_work(), so the caller of flush_work()
will be woken before any "regular" work has a chance to run.
When wait_on_work() unlocks workqueue_mutex (or whatever we choose to protect
against CPU hotplug), CPU may go away. But in that case take_over_work() will
move a barrier we queued to another CPU, it will be fired sometime, and
wait_on_work() will be woken.
Actually, we are doing cleanup_workqueue_thread()->kthread_stop() before
take_over_work(), so cwq->thread should complete its ->worklist (and thus
the barrier), because currently we don't check kthread_should_stop() in
run_workqueue(). But even if we did, everything should be ok.
[akpm@osdl.org: cleanup]
[akpm@osdl.org: add flush_work_keventd() wrapper]
Remove ->remove_sequence, ->insert_sequence, and ->work_done from struct
cpu_workqueue_struct. To implement flush_workqueue() we can queue a
barrier work on each CPU and wait for its completition.
The barrier is queued under workqueue_mutex to ensure that per cpu
wq->cpu_wq is alive, we drop this mutex before going to sleep. If CPU goes
down while we are waiting for completition, take_over_work() will move the
barrier on another CPU, and the handler will wake up us eventually.
We take workqueue_mutex in there to keep CPU hotplug away. But
preempt_disable() will suffice for that.
Add /proc/timer_stats support: debugging feature to profile timer expiration.
Both the starting site, process/PID and the expiration function is captured.
This allows the quick identification of timer event sources in a system.
Sample output:
# echo 1 > /proc/timer_stats
# cat /proc/timer_stats
Timer Stats Version: v0.1
Sample period: 4.010 s
24, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick)
11, 0 swapper sk_reset_timer (tcp_delack_timer)
6, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick)
2, 1 swapper queue_delayed_work_on (delayed_work_timer_fn)
17, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick)
4, 2050 pcscd do_nanosleep (hrtimer_wakeup)
5, 4179 sshd sk_reset_timer (tcp_write_timer)
4, 2248 yum-updatesd schedule_timeout (process_timeout)
18, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick)
3, 0 swapper sk_reset_timer (tcp_delack_timer)
1, 1 swapper neigh_table_init_no_netlink (neigh_periodic_timer)
2, 1 swapper e1000_up (e1000_watchdog)
1, 1 init schedule_timeout (process_timeout)
100 total events, 25.24 events/sec
[ cleanups and hrtimers support from Thomas Gleixner <tglx@linutronix.de> ]
[bunk@stusta.de: nr_entries can become static]
Cc: john stultz <johnstul@us.ibm.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Andi Kleen <ak@suse.de>
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in
source files, including:
* make multi-line initial descriptions single line
* denote some function names, constants and structs as such
* change erroneous opening '/*' to '/**' in a few places
* reword some text for clarity
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
Fix kernel-doc warnings in 2.6.20-rc1.
fix the schedule_on_each_cpu() implementation: __queue_work() is now
stricter, hence set the work-pending bit before passing in the new work.
(found in the -rt tree, using Peter Zijlstra's files-lock scalability
patchset)
On architectures where the atomicity of the bit operations is handled by
external means (ie a separate spinlock to protect concurrent accesses),
just doing a direct assignment on the workqueue data field (as done by
commit 4594bf159f1962cec3b727954b7c598b07e2e737) can cause the
assignment to be lost due to lack of serialization with the bitops on
the same word.
So we need to serialize the assignment with the locks on those
architectures (notably older ARM chips, PA-RISC and sparc32).
So rather than using an "unsigned long", let's use "atomic_long_t",
which already has a safe assignment operation (atomic_long_set()) on
such architectures.
This requires that the atomic operations use the same atomicity locks as
the bit operations do, but that is largely the case anyway. Sparc32
will probably need fixing.
Architectures (including modern ARM with LL/SC) that implement sane
atomic operations for SMP won't see any of this matter.
Cc: Russell King <rmk+lkml@arm.linux.org.uk>
Cc: David Miller <davem@davemloft.com>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Linux Arch Maintainers <linux-arch@vger.kernel.org>
Cc: Andrew Morton <akpm@osdl.org>
Use direct assignment rather than cmpxchg() as the latter is unavailable
and unimplementable on some platforms and is actually unnecessary.
The use of cmpxchg() was to guard against two possibilities, neither of
which can actually occur:
(1) The pending flag may have been unset or may be cleared. However, given
where it's called, the pending flag is _always_ set. I don't think it
can be unset whilst we're in set_wq_data().
Once the work is enqueued to be actually run, the only way off the queue
is for it to be actually run.
If it's a delayed work item, then the bit can't be cleared by the timer
because we haven't started the timer yet. Also, the pending bit can't be
cleared by cancelling the delayed work _until_ the work item has had its
timer started.
(2) The workqueue pointer might change. This can only happen in two cases:
(a) The work item has just been queued to actually run, and so we're
protected by the appropriate workqueue spinlock.
(b) A delayed work item is being queued, and so the timer hasn't been
started yet, and so no one else knows about the work item or can
access it (the pending bit protects us).
Besides, set_wq_data() _sets_ the workqueue pointer unconditionally, so
it can be assigned instead.
So, replacing the set_wq_data() with a straight assignment would be okay
in most cases.
The problem is where we end up tangling with test_and_set_bit() emulated
using spinlocks, and even then it's not a problem _provided_
test_and_set_bit() doesn't attempt to modify the word if the bit was
set.
If that's a problem, then a bitops-proofed assignment will be required -
equivalent to atomic_set() vs other atomic_xxx() ops.
This allows workqueue users to run just their own pending work, rather
than wait for the whole workqueue to finish running. This solves the
deadlock with networking libphy that was due to other workqueue entries
possibly needing a lock that was held by the routine that wanted to
flush its own work.
It's not wonderful: if you absolutely need to synchronize with the work
function having been executed, any user strictly speaking should have
its own completion tracking logic, since when we run things explicitly
by hand, the generic workqueue layer can no longer help us synchronize.
Also, this is strictly only usable for work that has been scheduled
without any delayed timers. You can not mix the new interface with
schedule_delayed_work().
But it's better than what we had currently.
Acked-by: Maciej W. Rozycki <macro@linux-mips.org>
There was lots of #ifdef noise in the kernel due to hotcpu_notifier(fn,
prio) not correctly marking 'fn' as used in the !HOTPLUG_CPU case, and thus
generating compiler warnings of unused symbols, hence forcing people to add
#ifdefs.
the compiler can skip truly unused functions just fine:
1624412 728710 3674856 6027978 5bfaca vmlinux.before
1624412 728710 3674856 6027978 5bfaca vmlinux.after
[akpm@osdl.org: topology.c fix]
Workqueue functions should not leak locks, assert so, printing the
last function ran.
Use macros in lockdep.h to avoid include dependency pains.
[akpm@osdl.org: build fix]
Make it possible to create a workqueue the worker thread of which will be
frozen during suspend, along with other kernel threads.
Acked-by: Pavel Machek <pavel@ucw.cz>
Cc: Nigel Cunningham <nigel@suspend2.net>
Cc: David Chinner <dgc@sgi.com>
Pass the work_struct pointer to the work function rather than context data.
The work function can use container_of() to work out the data.
For the cases where the container of the work_struct may go away the moment the
pending bit is cleared, it is made possible to defer the release of the
structure by deferring the clearing of the pending bit.
To make this work, an extra flag is introduced into the management side of the
work_struct. This governs auto-release of the structure upon execution.
Ordinarily, the work queue executor would release the work_struct for further
scheduling or deallocation by clearing the pending bit prior to jumping to the
work function. This means that, unless the driver makes some guarantee itself
that the work_struct won't go away, the work function may not access anything
else in the work_struct or its container lest they be deallocated.. This is a
problem if the auxiliary data is taken away (as done by the last patch).
However, if the pending bit is *not* cleared before jumping to the work
function, then the work function *may* access the work_struct and its container
with no problems. But then the work function must itself release the
work_struct by calling work_release().
In most cases, automatic release is fine, so this is the default. Special
initiators exist for the non-auto-release case (ending in _NAR).
Signed-Off-By: David Howells <dhowells@redhat.com>
Reclaim a word from the size of the work_struct by folding the pending bit and
the wq_data pointer together. This shouldn't cause misalignment problems as
all pointers should be at least 4-byte aligned.
Define a type for the work function prototype. It's not only kept in the
work_struct struct, it's also passed as an argument to several functions.
This makes it easier to change it.
Separate delayable work items from non-delayable work items be splitting them
into a separate structure (delayed_work), which incorporates a work_struct and
the timer_list removed from work_struct.
The work_struct struct is huge, and this limits it's usefulness. On a 64-bit
architecture it's nearly 100 bytes in size. This reduces that by half for the
non-delayable type of event.
This patch (as812) changes the kerneldoc comments explaining the return
values from queue_work(), queue_delayed_work(), and
queue_delayed_work_on(). The updated comments explain more accurately the
meaning of the return code and avoid suggesting that a 0 value means the
routine was unsuccessful.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Switch the memory policy of the kevent threads to MPOL_DEFAULT while
leaving the kzalloc of the workqueue structure on interleave. This means
that all code executed in the context of the kevent thread is allocating
node local.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: Alok Kataria <alok.kataria@calsoftinc.com>
Cc: <pj@sgi.com>
Cc: <shai@scalex86.org>
s/until until/until/
Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de>
Use a private lock instead. It protects all per-cpu data structures in
workqueue.c, including the workqueues list.
Fix a bug in schedule_on_each_cpu(): it was forgetting to lock down the
per-cpu resources.
Unfixed long-standing bug: if someone unplugs the CPU identified by
`singlethread_cpu' the kernel will get very sick.
Cc: Dave Jones <davej@codemonkey.org.uk>
kernel/workqueue.c was omitted from generating kernel documentation. This
adds a new section "Workqueues and Kevents" and adds documentation for some
of the functions.
Some functions in this file already had DocBook-style comments, now they
finally become visible.
* master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreq:
Move workqueue exports to where the functions are defined.
[CPUFREQ] Misc cleanups in ondemand.
[CPUFREQ] Make ondemand sampling per CPU and remove the mutex usage in sampling path.
[CPUFREQ] Add queue_delayed_work_on() interface for workqueues.
[CPUFREQ] Remove slowdown from ondemand sampling path.
cleanup: remove task_t and convert all the uses to struct task_struct. I
introduced it for the scheduler anno and it was a mistake.
Conversion was mostly scripted, the result was reviewed and all
secondary whitespace and style impact (if any) was fixed up by hand.
Signed-off-by: Dave Jones <davej@redhat.com>
Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
In 2.6.17, there was a problem with cpu_notifiers and XFS. I provided a
band-aid solution to solve that problem. In the process, i undid all the
changes you both were making to ensure that these notifiers were available
only at init time (unless CONFIG_HOTPLUG_CPU is defined).
We deferred the real fix to 2.6.18. Here is a set of patches that fixes the
XFS problem cleanly and makes the cpu notifiers available only at init time
If CONFIG_HOTPLUG_CPU is defined then cpu notifiers are available at run
time.
This patch reverts the notifier_call changes made in 2.6.17
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Cc: Ashok Raj <ashok.raj@intel.com>
If a cpu hotplug callback fails on CPU_UP_PREPARE, all callbacks will be
called with CPU_UP_CANCELED. A few of these callbacks assume that on
CPU_UP_PREPARE a pointer to task has been stored in a percpu array. This
assumption is not true if CPU_UP_PREPARE fails and the following calls to
kthread_bind() in CPU_UP_CANCELED will cause an addressing exception
because of passing a NULL pointer.
schedule_on_each_cpu() presently does a large kmalloc - 96 kbytes on 1024 CPU
64-bit.
Rework it so that we do one 8192-byte allocation and then a pile of tiny ones,
via alloc_percpu(). This has a much higher chance of success (100% in the
current VM).
This also has the effect of reducing the memory requirements from NR_CPUS*n to
num_possible_cpus()*n.
Cc: Christoph Lameter <clameter@engr.sgi.com>
Cc: Andi Kleen <ak@muc.de>
list_splice_init(list, head) does unneeded job if it is known that
list_empty(head) == 1. We can use list_replace_init() instead.
