path: root/kernel/workqueue.c
2007-05-09unify queue_delayed_work() and queue_delayed_work_on()Oleg Nesterov
Change queue_delayed_work() to use queue_delayed_work_on() to avoid the code duplication (saves 133 bytes). Q: queue_delayed_work() enqueues &dwork->work directly when delay == 0, why? [jirislaby@gmail.com: oops fix] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09make queue_delayed_work() friendly to flush_fork()Oleg Nesterov
Currently typeof(delayed_work->work.data) is "struct workqueue_struct" when the timer is pending "struct cpu_workqueue_struct" whe the work is queued This makes impossible to use flush_fork(delayed_work->work) in addition to cancel_delayed_work/cancel_rearming_delayed_work, not good. Change queue_delayed_work/delayed_work_timer_fn to use cwq, not wq. This complicates (and uglifies) these functions a little bit, but alows us to use flush_fork(dwork) and imho makes the whole code more consistent. Also, document the fact that cancel_rearming_delayed_work() doesn't garantee the completion of work->func() upon return. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueues: shift kthread_bind() from CPU_UP_PREPARE to CPU_ONLINEOleg Nesterov
CPU_UP_PREPARE binds cwq->thread to the new CPU. So CPU_UP_CANCELED tries to wake up the task which is bound to the failed CPU. With this patch we don't bind cwq->thread until CPU becomes online. The first wake_up() after kthread_create() is a bit special, make a simple helper for that. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: make init_workqueues() __initOleg Nesterov
The only caller of init_workqueues() is do_basic_setup(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: introduce workqueue_struct->singlethreadOleg Nesterov
Add explicit workqueue_struct->singlethread flag. This lessens .text a little, but most importantly this allows us to manipulate wq->list without changine the meaning of is_single_threaded(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: introduce cpu_singlethread_mapOleg Nesterov
The code like if (is_single_threaded(wq)) do_something(singlethread_cpu); else { for_each_cpu_mask(cpu, cpu_populated_map) do_something(cpu); } looks very annoying. We can add "static cpumask_t cpu_singlethread_map" and simplify the code. Lessens .text a bit, and imho makes the code more readable. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: make cancel_rearming_delayed_workqueue() work on idle dworkOleg Nesterov
cancel_rearming_delayed_workqueue(dwork) will hang forever if dwork was not scheduled, because in that case cancel_delayed_work()->del_timer_sync() never returns true. I don't know if there are any callers which may have problems, but this is not so convenient, and the fix is very simple. Q: looks like we don't need "struct workqueue_struct *wq" parameter. If the timer was aborted successfully, get_wq_data() == wq. Is it worth to add the new function? Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: don't save interrupts in run_workqueue()Oleg Nesterov
work->func() may sleep, it's a bug to call run_workqueue() with irqs disabled. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: kill run_scheduled_work()Oleg Nesterov
Because it has no callers. Actually, I think the whole idea of run_scheduled_work() was not right, not good to mix "unqueue this work and execute its ->func()" in one function. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: don't migrate pending works from the dead CPUOleg Nesterov
Currently CPU_DEAD uses kthread_stop() to stop cwq->thread and then transfers cwq->worklist to another CPU. However, it is very unlikely that worker_thread() will notice kthread_should_stop() before flushing cwq->worklist. It is only possible if worker_thread() was preempted after run_workqueue(cwq), a new work_struct was added, and CPU_DEAD happened before cwq->thread has a chance to run. This means that take_over_work() mostly adds unneeded complications. Note also that kthread_stop() is not good per se, wake_up_process() may confuse work->func() if it sleeps waiting for some event. Remove take_over_work() and migrate_sequence complications. CPU_DEAD sets the cwq->should_stop flag (introduced by this patch) and waits for cwq->thread to flush cwq->worklist and exit. Because the dead CPU is not on cpu_online_map, no more works can be added to that cwq. cpu_populated_map was introduced to optimize for_each_possible_cpu(), it is not strictly needed, and it is more a documentation in fact. Saves 418 bytes. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: "Pallipadi, Venkatesh" <venkatesh.pallipadi@intel.com> Cc: Gautham shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: don't clear cwq->thread until it exitsOleg Nesterov
Pointed out by Srivatsa Vaddagiri. cleanup_workqueue_thread() sets cwq->thread = NULL and does kthread_stop(). This breaks the "if (cwq->thread == current)" logic in flush_cpu_workqueue() and leads to deadlock. Kill the thead first, then clear cwq->thread. workqueue_mutex protects us from create_workqueue_thread() so we don't need cwq->lock. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: "Pallipadi, Venkatesh" <venkatesh.pallipadi@intel.com> Cc: Gautham shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: fix flush_workqueue() vs CPU_DEAD raceOleg Nesterov
Many thanks to Srivatsa Vaddagiri for the helpful discussion and for spotting the bug in my previous attempt. work->func() (and thus flush_workqueue()) must not use workqueue_mutex, this leads to deadlock when CPU_DEAD does kthread_stop(). However without this mutex held we can't detect CPU_DEAD in progress, which can move pending works to another CPU while the dead one is not on cpu_online_map. Change flush_workqueue() to use for_each_possible_cpu(). This means that flush_cpu_workqueue() may hit CPU which is already dead. However in that case !list_empty(&cwq->worklist) || cwq->current_work != NULL means that CPU_DEAD in progress, it will do kthread_stop() + take_over_work() so we can proceed and insert a barrier. We hold cwq->lock, so we are safe. Also, add migrate_sequence incremented by take_over_work() under cwq->lock. If take_over_work() happened before we checked this CPU, we should see the new value after spin_unlock(). Further possible changes: remove CPU_DEAD handling (along with take_over_work, migrate_sequence) from workqueue.c. CPU_DEAD just sets cwq->please_exit_after_flush flag. CPU_UP_PREPARE->create_workqueue_thread() clears this flag, and creates the new thread if cwq->thread == NULL. This way the workqueue/cpu-hotplug interaction is almost zero, workqueue_mutex just protects "workqueues" list, CPU_LOCK_ACQUIRE/CPU_LOCK_RELEASE go away. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: "Pallipadi, Venkatesh" <venkatesh.pallipadi@intel.com> Cc: Gautham shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09workqueue: fix freezeable workqueues implementationOleg Nesterov
Currently ->freezeable is per-cpu, this is wrong. CPU_UP_PREPARE creates cwq->thread which is not freezeable. Move ->freezeable to workqueue_struct. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: "Pallipadi, Venkatesh" <venkatesh.pallipadi@intel.com> Cc: Gautham shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09flush_cpu_workqueue: don't flush an empty ->worklistOleg Nesterov
Now when we have ->current_work we can avoid adding a barrier and waiting for its completition when cwq's queue is empty. Note: this change is also useful if we change flush_workqueue() to also check the dead CPUs. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Gautham Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09flush_workqueue(): use preempt_disable to hold off cpu hotplugAndrew Morton
Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Gautham Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09implement flush_work()Oleg Nesterov
A basic problem with flush_scheduled_work() is that it blocks behind _all_ presently-queued works, rather than just the work whcih the caller wants to flush. If the caller holds some lock, and if one of the queued work happens to want that lock as well then accidental deadlocks can occur. One example of this is the phy layer: it wants to flush work while holding rtnl_lock(). But if a linkwatch event happens to be queued, the phy code will deadlock because the linkwatch callback function takes rtnl_lock. So we implement a new function which will flush a *single* work - just the one which the caller wants to free up. Thus we avoid the accidental deadlocks which can arise from unrelated subsystems' callbacks taking shared locks. flush_work() non-blockingly dequeues the work_struct which we want to kill, then it waits for its handler to complete on all CPUs. Add ->current_work to the "struct cpu_workqueue_struct", it points to currently running "struct work_struct". When flush_work(work) detects ->current_work == work, it inserts a barrier at the _head_ of ->worklist (and thus right _after_ that work) and waits for completition. This means that the next work fired on that CPU will be this barrier, or another barrier queued by concurrent flush_work(), so the caller of flush_work() will be woken before any "regular" work has a chance to run. When wait_on_work() unlocks workqueue_mutex (or whatever we choose to protect against CPU hotplug), CPU may go away. But in that case take_over_work() will move a barrier we queued to another CPU, it will be fired sometime, and wait_on_work() will be woken. Actually, we are doing cleanup_workqueue_thread()->kthread_stop() before take_over_work(), so cwq->thread should complete its ->worklist (and thus the barrier), because currently we don't check kthread_should_stop() in run_workqueue(). But even if we did, everything should be ok. [akpm@osdl.org: cleanup] [akpm@osdl.org: add flush_work_keventd() wrapper] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09reimplement flush_workqueue()Oleg Nesterov
Remove ->remove_sequence, ->insert_sequence, and ->work_done from struct cpu_workqueue_struct. To implement flush_workqueue() we can queue a barrier work on each CPU and wait for its completition. The barrier is queued under workqueue_mutex to ensure that per cpu wq->cpu_wq is alive, we drop this mutex before going to sleep. If CPU goes down while we are waiting for completition, take_over_work() will move the barrier on another CPU, and the handler will wake up us eventually. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09schedule_on_each_cpu(): use preempt_disable()Andrew Morton
We take workqueue_mutex in there to keep CPU hotplug away. But preempt_disable() will suffice for that. Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] Add debugging feature /proc/timer_statIngo Molnar
Add /proc/timer_stats support: debugging feature to profile timer expiration. Both the starting site, process/PID and the expiration function is captured. This allows the quick identification of timer event sources in a system. Sample output: # echo 1 > /proc/timer_stats # cat /proc/timer_stats Timer Stats Version: v0.1 Sample period: 4.010 s 24, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick) 11, 0 swapper sk_reset_timer (tcp_delack_timer) 6, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick) 2, 1 swapper queue_delayed_work_on (delayed_work_timer_fn) 17, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick) 2, 1 swapper queue_delayed_work_on (delayed_work_timer_fn) 4, 2050 pcscd do_nanosleep (hrtimer_wakeup) 5, 4179 sshd sk_reset_timer (tcp_write_timer) 4, 2248 yum-updatesd schedule_timeout (process_timeout) 18, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick) 3, 0 swapper sk_reset_timer (tcp_delack_timer) 1, 1 swapper neigh_table_init_no_netlink (neigh_periodic_timer) 2, 1 swapper e1000_up (e1000_watchdog) 1, 1 init schedule_timeout (process_timeout) 100 total events, 25.24 events/sec [ cleanups and hrtimers support from Thomas Gleixner <tglx@linutronix.de> ] [bunk@stusta.de: nr_entries can become static] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-22[PATCH] fix kernel-doc warnings in 2.6.20-rc1Randy Dunlap
Fix kernel-doc warnings in 2.6.20-rc1. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-21[PATCH] workqueue: fix schedule_on_each_cpu()Ingo Molnar
fix the schedule_on_each_cpu() implementation: __queue_work() is now stricter, hence set the work-pending bit before passing in the new work. (found in the -rt tree, using Peter Zijlstra's files-lock scalability patchset) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-16Make workqueue bit operations work on "atomic_long_t"Linus Torvalds
On architectures where the atomicity of the bit operations is handled by external means (ie a separate spinlock to protect concurrent accesses), just doing a direct assignment on the workqueue data field (as done by commit 4594bf159f1962cec3b727954b7c598b07e2e737) can cause the assignment to be lost due to lack of serialization with the bitops on the same word. So we need to serialize the assignment with the locks on those architectures (notably older ARM chips, PA-RISC and sparc32). So rather than using an "unsigned long", let's use "atomic_long_t", which already has a safe assignment operation (atomic_long_set()) on such architectures. This requires that the atomic operations use the same atomicity locks as the bit operations do, but that is largely the case anyway. Sparc32 will probably need fixing. Architectures (including modern ARM with LL/SC) that implement sane atomic operations for SMP won't see any of this matter. Cc: Russell King <rmk+lkml@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: David Miller <davem@davemloft.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Linux Arch Maintainers <linux-arch@vger.kernel.org> Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-09[PATCH] WorkStruct: Use direct assignment rather than cmpxchg()David Howells
Use direct assignment rather than cmpxchg() as the latter is unavailable and unimplementable on some platforms and is actually unnecessary. The use of cmpxchg() was to guard against two possibilities, neither of which can actually occur: (1) The pending flag may have been unset or may be cleared. However, given where it's called, the pending flag is _always_ set. I don't think it can be unset whilst we're in set_wq_data(). Once the work is enqueued to be actually run, the only way off the queue is for it to be actually run. If it's a delayed work item, then the bit can't be cleared by the timer because we haven't started the timer yet. Also, the pending bit can't be cleared by cancelling the delayed work _until_ the work item has had its timer started. (2) The workqueue pointer might change. This can only happen in two cases: (a) The work item has just been queued to actually run, and so we're protected by the appropriate workqueue spinlock. (b) A delayed work item is being queued, and so the timer hasn't been started yet, and so no one else knows about the work item or can access it (the pending bit protects us). Besides, set_wq_data() _sets_ the workqueue pointer unconditionally, so it can be assigned instead. So, replacing the set_wq_data() with a straight assignment would be okay in most cases. The problem is where we end up tangling with test_and_set_bit() emulated using spinlocks, and even then it's not a problem _provided_ test_and_set_bit() doesn't attempt to modify the word if the bit was set. If that's a problem, then a bitops-proofed assignment will be required - equivalent to atomic_set() vs other atomic_xxx() ops. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Add "run_scheduled_work()" workqueue functionLinus Torvalds
This allows workqueue users to run just their own pending work, rather than wait for the whole workqueue to finish running. This solves the deadlock with networking libphy that was due to other workqueue entries possibly needing a lock that was held by the routine that wanted to flush its own work. It's not wonderful: if you absolutely need to synchronize with the work function having been executed, any user strictly speaking should have its own completion tracking logic, since when we run things explicitly by hand, the generic workqueue layer can no longer help us synchronize. Also, this is strictly only usable for work that has been scheduled without any delayed timers. You can not mix the new interface with schedule_delayed_work(). But it's better than what we had currently. Acked-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] hotplug CPU: clean up hotcpu_notifier() useIngo Molnar
There was lots of #ifdef noise in the kernel due to hotcpu_notifier(fn, prio) not correctly marking 'fn' as used in the !HOTPLUG_CPU case, and thus generating compiler warnings of unused symbols, hence forcing people to add #ifdefs. the compiler can skip truly unused functions just fine: text data bss dec hex filename 1624412 728710 3674856 6027978 5bfaca vmlinux.before 1624412 728710 3674856 6027978 5bfaca vmlinux.after [akpm@osdl.org: topology.c fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] debug: workqueue locking sanityPeter Zijlstra
Workqueue functions should not leak locks, assert so, printing the last function ran. Use macros in lockdep.h to avoid include dependency pains. [akpm@osdl.org: build fix] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Support for freezeable workqueuesRafael J. Wysocki
Make it possible to create a workqueue the worker thread of which will be frozen during suspend, along with other kernel threads. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@suspend2.net> Cc: David Chinner <dgc@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-22WorkStruct: Pass the work_struct pointer instead of context dataDavid Howells
Pass the work_struct pointer to the work function rather than context data. The work function can use container_of() to work out the data. For the cases where the container of the work_struct may go away the moment the pending bit is cleared, it is made possible to defer the release of the structure by deferring the clearing of the pending bit. To make this work, an extra flag is introduced into the management side of the work_struct. This governs auto-release of the structure upon execution. Ordinarily, the work queue executor would release the work_struct for further scheduling or deallocation by clearing the pending bit prior to jumping to the work function. This means that, unless the driver makes some guarantee itself that the work_struct won't go away, the work function may not access anything else in the work_struct or its container lest they be deallocated.. This is a problem if the auxiliary data is taken away (as done by the last patch). However, if the pending bit is *not* cleared before jumping to the work function, then the work function *may* access the work_struct and its container with no problems. But then the work function must itself release the work_struct by calling work_release(). In most cases, automatic release is fine, so this is the default. Special initiators exist for the non-auto-release case (ending in _NAR). Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-22WorkStruct: Merge the pending bit into the wq_data pointerDavid Howells
Reclaim a word from the size of the work_struct by folding the pending bit and the wq_data pointer together. This shouldn't cause misalignment problems as all pointers should be at least 4-byte aligned. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-22WorkStruct: Typedef the work function prototypeDavid Howells
Define a type for the work function prototype. It's not only kept in the work_struct struct, it's also passed as an argument to several functions. This makes it easier to change it. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-22WorkStruct: Separate delayable and non-delayable events.David Howells
Separate delayable work items from non-delayable work items be splitting them into a separate structure (delayed_work), which incorporates a work_struct and the timer_list removed from work_struct. The work_struct struct is huge, and this limits it's usefulness. On a 64-bit architecture it's nearly 100 bytes in size. This reduces that by half for the non-delayable type of event. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-28[PATCH] workqueue: update kerneldocAlan Stern
This patch (as812) changes the kerneldoc comments explaining the return values from queue_work(), queue_delayed_work(), and queue_delayed_work_on(). The updated comments explain more accurately the meaning of the return code and avoid suggesting that a 0 value means the routine was unsuccessful. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] mm: kevent threads: use MPOL_DEFAULTChristoph Lameter
Switch the memory policy of the kevent threads to MPOL_DEFAULT while leaving the kzalloc of the workqueue structure on interleave. This means that all code executed in the context of the kevent thread is allocating node local. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Alok Kataria <alok.kataria@calsoftinc.com> Cc: Andi Kleen <ak@suse.de> Cc: <pj@sgi.com> Cc: <shai@scalex86.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03remove duplicate "until" from kernel/workqueue.cRolf Eike Beer
s/until until/until/ Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-08-14[PATCH] workqueue: remove lock_cpu_hotplug()Andrew Morton
Use a private lock instead. It protects all per-cpu data structures in workqueue.c, including the workqueues list. Fix a bug in schedule_on_each_cpu(): it was forgetting to lock down the per-cpu resources. Unfixed long-standing bug: if someone unplugs the CPU identified by `singlethread_cpu' the kernel will get very sick. Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-31[PATCH] Add DocBook documentation for workqueue functionsRolf Eike Beer
kernel/workqueue.c was omitted from generating kernel documentation. This adds a new section "Workqueues and Kevents" and adds documentation for some of the functions. Some functions in this file already had DocBook-style comments, now they finally become visible. Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-04Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreqLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreq: Move workqueue exports to where the functions are defined. [CPUFREQ] Misc cleanups in ondemand. [CPUFREQ] Make ondemand sampling per CPU and remove the mutex usage in sampling path. [CPUFREQ] Add queue_delayed_work_on() interface for workqueues. [CPUFREQ] Remove slowdown from ondemand sampling path.
2006-07-03[PATCH] sched: cleanup, remove task_t, convert to struct task_structIngo Molnar
cleanup: remove task_t and convert all the uses to struct task_struct. I introduced it for the scheduler anno and it was a mistake. Conversion was mostly scripted, the result was reviewed and all secondary whitespace and style impact (if any) was fixed up by hand. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30Move workqueue exports to where the functions are defined.Dave Jones
Signed-off-by: Dave Jones <davej@redhat.com>
2006-06-30[CPUFREQ] Add queue_delayed_work_on() interface for workqueues.Venkatesh Pallipadi
Add queue_delayed_work_on() interface for workqueues. Signed-off-by: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-06-27[PATCH] cpu hotplug: revert init patch submitted for 2.6.17Chandra Seetharaman
In 2.6.17, there was a problem with cpu_notifiers and XFS. I provided a band-aid solution to solve that problem. In the process, i undid all the changes you both were making to ensure that these notifiers were available only at init time (unless CONFIG_HOTPLUG_CPU is defined). We deferred the real fix to 2.6.18. Here is a set of patches that fixes the XFS problem cleanly and makes the cpu notifiers available only at init time (unless CONFIG_HOTPLUG_CPU is defined). If CONFIG_HOTPLUG_CPU is defined then cpu notifiers are available at run time. This patch reverts the notifier_call changes made in 2.6.17 Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] cpu hotplug: fix CPU_UP_CANCEL handlingHeiko Carstens
If a cpu hotplug callback fails on CPU_UP_PREPARE, all callbacks will be called with CPU_UP_CANCELED. A few of these callbacks assume that on CPU_UP_PREPARE a pointer to task has been stored in a percpu array. This assumption is not true if CPU_UP_PREPARE fails and the following calls to kthread_bind() in CPU_UP_CANCELED will cause an addressing exception because of passing a NULL pointer. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] schedule_on_each_cpu(): reduce kmalloc() sizeAndrew Morton
schedule_on_each_cpu() presently does a large kmalloc - 96 kbytes on 1024 CPU 64-bit. Rework it so that we do one 8192-byte allocation and then a pile of tiny ones, via alloc_percpu(). This has a much higher chance of success (100% in the current VM). This also has the effect of reducing the memory requirements from NR_CPUS*n to num_possible_cpus()*n. Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] list: use list_replace_init() instead of list_splice_init()Oleg Nesterov
list_splice_init(list, head) does unneeded job if it is known that list_empty(head) == 1. We can use list_replace_init() instead. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26[PATCH] Remove __devinit and __cpuinit from notifier_call definitionsChandra Seetharaman
Few of the notifier_chain_register() callers use __init in the definition of notifier_call. It is incorrect as the function definition should be available after the initializations (they do not unregister them during initializations). This patch fixes all such usages to _not_ have the notifier_call __init section. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-27[SCSI] add execute_in_process_context() APIJames Bottomley
We have several points in the SCSI stack (primarily for our device functions) where we need to guarantee process context, but (given the place where the last reference was released) we cannot guarantee this. This API gets around the issue by executing the function directly if the caller has process context, but scheduling a workqueue to execute in process context if the caller doesn't have it. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] fix workqueue oops during cpu offlineNathan Lynch
Use first_cpu(cpu_possible_map) for the single-thread workqueue case. We used to hardcode 0, but that broke on systems where !cpu_possible(0) when workqueue_struct->cpu_workqueue_struct was changed from a static array to alloc_percpu. Commit id bce61dd49d6ba7799be2de17c772e4c701558f14 ("Fix hardcoded cpu=0 in workqueue for per_cpu_ptr() calls") fixed that for Ben's funky sparc64 system, but it regressed my Power5. Offlining cpu 0 oopses upon the next call to queue_work for a single-thread workqueue, because now we try to manipulate per_cpu_ptr(wq->cpu_wq, 1), which is uninitialized. So we need to establish an unchanging "slot" for single-thread workqueues which will have a valid percpu allocation. Since alloc_percpu keys off of cpu_possible_map, which must not change after initialization, make this slot == first_cpu(cpu_possible_map). Signed-off-by: Nathan Lynch <ntl@pobox.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Unchecked alloc_percpu() return in __create_workqueue()Ben Collins
__create_workqueue() not checking return of alloc_percpu() NULL dereference was possible. Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
