Pull ACPI and power management updates from Rafael Wysocki:
- Rework of the ACPI namespace scanning code from Rafael J. Wysocki
with contributions from Bjorn Helgaas, Jiang Liu, Mika Westerberg,
Toshi Kani, and Yinghai Lu.
- ACPI power resources handling and ACPI device PM update from Rafael
J Wysocki.
- ACPICA update to version 20130117 from Bob Moore and Lv Zheng with
contributions from Aaron Lu, Chao Guan, Jesper Juhl, and Tim Gardner.
- Support for Intel Lynxpoint LPSS from Mika Westerberg.
- cpuidle update from Len Brown including Intel Haswell support, C1
state for intel_idle, removal of global pm_idle.
- cpuidle fixes and cleanups from Daniel Lezcano.
- cpufreq fixes and cleanups from Viresh Kumar and Fabio Baltieri with
contributions from Stratos Karafotis and Rickard Andersson.
- Intel P-states driver for Sandy Bridge processors from Dirk
Brandewie.
- cpufreq driver for Marvell Kirkwood SoCs from Andrew Lunn.
- cpufreq fixes related to ordering issues between acpi-cpufreq and
powernow-k8 from Borislav Petkov and Matthew Garrett.
- cpufreq support for Calxeda Highbank processors from Mark Langsdorf
and Rob Herring.
- cpufreq driver for the Freescale i.MX6Q SoC and cpufreq-cpu0 update
from Shawn Guo.
- cpufreq Exynos fixes and cleanups from Jonghwan Choi, Sachin Kamat,
and Inderpal Singh.
- Support for "lightweight suspend" from Zhang Rui.
- Removal of the deprecated power trace API from Paul Gortmaker.
- Assorted updates from Andreas Fleig, Colin Ian King, Davidlohr Bueso,
Joseph Salisbury, Kees Cook, Li Fei, Nishanth Menon, ShuoX Liu,
Srinivas Pandruvada, Tejun Heo, Thomas Renninger, and Yasuaki
Ishimatsu.
* tag 'pm+acpi-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (267 commits)
PM idle: remove global declaration of pm_idle
unicore32 idle: delete stray pm_idle comment
openrisc idle: delete pm_idle
mn10300 idle: delete pm_idle
microblaze idle: delete pm_idle
m32r idle: delete pm_idle, and other dead idle code
ia64 idle: delete pm_idle
cris idle: delete idle and pm_idle
ARM64 idle: delete pm_idle
ARM idle: delete pm_idle
blackfin idle: delete pm_idle
sparc idle: rename pm_idle to sparc_idle
sh idle: rename global pm_idle to static sh_idle
x86 idle: rename global pm_idle to static x86_idle
APM idle: register apm_cpu_idle via cpuidle
cpufreq / intel_pstate: Add kernel command line option disable intel_pstate.
cpufreq / intel_pstate: Change to disallow module build
tools/power turbostat: display SMI count by default
intel_idle: export both C1 and C1E
ACPI / hotplug: Fix concurrency issues and memory leaks
Pull scheduler changes from Ingo Molnar:
"Main changes:
- scheduler side full-dynticks (user-space execution is undisturbed
and receives no timer IRQs) preparation changes that convert the
cputime accounting code to be full-dynticks ready, from Frederic
Weisbecker.
- Initial sched.h split-up changes, by Clark Williams
- select_idle_sibling() performance improvement by Mike Galbraith:
" 1 tbench pair (worst case) in a 10 core + SMT package:
pre 15.22 MB/sec 1 procs
post 252.01 MB/sec 1 procs "
- sched_rr_get_interval() ABI fix/change. We think this detail is not
used by apps (so it's not an ABI in practice), but lets keep it
under observation.
- misc RT scheduling cleanups, optimizations"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits)
sched/rt: Add <linux/sched/rt.h> header to <linux/init_task.h>
cputime: Remove irqsave from seqlock readers
sched, powerpc: Fix sched.h split-up build failure
cputime: Restore CPU_ACCOUNTING config defaults for PPC64
sched/rt: Move rt specific bits into new header file
sched/rt: Add a tuning knob to allow changing SCHED_RR timeslice
sched: Move sched.h sysctl bits into separate header
sched: Fix signedness bug in yield_to()
sched: Fix select_idle_sibling() bouncing cow syndrome
sched/rt: Further simplify pick_rt_task()
sched/rt: Do not account zero delta_exec in update_curr_rt()
cputime: Safely read cputime of full dynticks CPUs
kvm: Prepare to add generic guest entry/exit callbacks
cputime: Use accessors to read task cputime stats
cputime: Allow dynamic switch between tick/virtual based cputime accounting
cputime: Generic on-demand virtual cputime accounting
cputime: Move default nsecs_to_cputime() to jiffies based cputime file
cputime: Librarize per nsecs resolution cputime definitions
cputime: Avoid multiplication overflow on utime scaling
context_tracking: Export context state for generic vtime
Fix up conflict in kernel/context_tracking.c due to comment additions.
Pull perf changes from Ingo Molnar:
"There are lots of improvements, the biggest changes are:
Main kernel side changes:
- Improve uprobes performance by adding 'pre-filtering' support, by
Oleg Nesterov.
- Make some POWER7 events available in sysfs, equivalent to what was
done on x86, from Sukadev Bhattiprolu.
- tracing updates by Steve Rostedt - mostly misc fixes and smaller
improvements.
- Use perf/event tracing to report PCI Express advanced errors, by
Tony Luck.
- Enable northbridge performance counters on AMD family 15h, by Jacob
Shin.
- This tracing commit:
tracing: Remove the extra 4 bytes of padding in events
changes the ABI. All involved parties (PowerTop in particular)
seem to agree that it's safe to do now with the introduction of
libtraceevent, but the devil is in the details ...
Main tooling side changes:
- Add 'event group view', from Namyung Kim:
To use it, 'perf record' should group events when recording. And
then perf report parses the saved group relation from file header
and prints them together if --group option is provided. You can
use the 'perf evlist' command to see event group information:
$ perf record -e '{ref-cycles,cycles}' noploop 1
[ perf record: Woken up 2 times to write data ]
[ perf record: Captured and wrote 0.385 MB perf.data (~16807 samples) ]
$ perf evlist --group
{ref-cycles,cycles}
With this example, default perf report will show you each event
separately.
You can use --group option to enable event group view:
$ perf report --group
# group: {ref-cycles,cycles}
# Samples: 7K of event 'anon group { ref-cycles, cycles }'
# Event count (approx.): 6876107743
# Overhead Command Shared Object Symbol
99.84% 99.76% noploop noploop [.] main
0.07% 0.00% noploop ld-2.15.so [.] strcmp
0.03% 0.00% noploop [kernel.kallsyms] [k] timerqueue_del
0.03% 0.03% noploop [kernel.kallsyms] [k] sched_clock_cpu
0.02% 0.00% noploop [kernel.kallsyms] [k] account_user_time
0.01% 0.00% noploop [kernel.kallsyms] [k] __alloc_pages_nodemask
0.00% 0.00% noploop [kernel.kallsyms] [k] native_write_msr_safe
0.00% 0.11% noploop [kernel.kallsyms] [k] _raw_spin_lock
0.00% 0.06% noploop [kernel.kallsyms] [k] find_get_page
0.00% 0.02% noploop [kernel.kallsyms] [k] rcu_check_callbacks
0.00% 0.02% noploop [kernel.kallsyms] [k] __current_kernel_time
As you can see the Overhead column now contains both of ref-cycles
and cycles and header line shows group information also - 'anon
group { ref-cycles, cycles }'. The output is sorted by period of
group leader first.
- Initial GTK+ annotate browser, from Namhyung Kim.
- Add option for runtime switching perf data file in perf report,
just press 's' and a menu with the valid files found in the current
directory will be presented, from Feng Tang.
- Add support to display whole group data for raw columns, from Jiri
Olsa.
- Add per processor socket count aggregation in perf stat, from
Stephane Eranian.
- Add interval printing in 'perf stat', from Stephane Eranian.
- 'perf test' improvements
- Add support for wildcards in tracepoint system name, from Jiri
Olsa.
- Add anonymous huge page recognition, from Joshua Zhu.
- perf build-id cache now can show DSOs present in a perf.data file
that are not in the cache, to integrate with build-id servers being
put in place by organizations such as Fedora.
- perf top now shares more of the evsel config/creation routines with
'record', paving the way for further integration like 'top'
snapshots, etc.
- perf top now supports DWARF callchains.
- Fix mmap limitations on 32-bit, fix from David Miller.
- 'perf bench numa mem' NUMA performance measurement suite
- ... and lots of fixes, performance improvements, cleanups and other
improvements I failed to list - see the shortlog and git log for
details."
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (270 commits)
perf/x86/amd: Enable northbridge performance counters on AMD family 15h
perf/hwbp: Fix cleanup in case of kzalloc failure
perf tools: Fix build with bison 2.3 and older.
perf tools: Limit unwind support to x86 archs
perf annotate: Make it to be able to skip unannotatable symbols
perf gtk/annotate: Fail early if it can't annotate
perf gtk/annotate: Show source lines with gray color
perf gtk/annotate: Support multiple event annotation
perf ui/gtk: Implement basic GTK2 annotation browser
perf annotate: Fix warning message on a missing vmlinux
perf buildid-cache: Add --update option
uprobes/perf: Avoid uprobe_apply() whenever possible
uprobes/perf: Teach trace_uprobe/perf code to use UPROBE_HANDLER_REMOVE
uprobes/perf: Teach trace_uprobe/perf code to pre-filter
uprobes/perf: Teach trace_uprobe/perf code to track the active perf_event's
uprobes: Introduce uprobe_apply()
perf: Introduce hw_perf_event->tp_target and ->tp_list
uprobes/perf: Always increment trace_uprobe->nhit
uprobes/tracing: Kill uprobe_trace_consumer, embed uprobe_consumer into trace_uprobe
uprobes/tracing: Introduce is_trace_uprobe_enabled()
uprobe_perf_open/close call the costly uprobe_apply() every time,
we can avoid it if:
- "nr_systemwide != 0" is not changed.
- There is another process/thread with the same ->mm.
- copy_proccess() does inherit_event(). dup_mmap() preserves the
inserted breakpoints.
- event->attr.enable_on_exec == T, we can rely on uprobe_mmap()
called by exec/mmap paths.
- tp_target is exiting. Only _close() checks PF_EXITING, I don't
think TRACE_REG_PERF_OPEN can hit the dying task too often.
Change uprobe_trace_func() and uprobe_perf_func() to return "int". Change
uprobe_dispatcher() to return "trace_ret | perf_ret" although this is not
needed, currently TP_FLAG_TRACE/TP_FLAG_PROFILE are mutually exclusive.
The only functional change is that uprobe_perf_func() checks the filtering
too and returns UPROBE_HANDLER_REMOVE if nobody wants to trace current.
Testing:
# perf probe -x /lib/libc.so.6 syscall
# perf record -e probe_libc:syscall -i perl -e 'fork; syscall -1 for 1..10; wait'
# perf report --show-total-period
100.00% 10 perl libc-2.8.so [.] syscall
Before this patch:
# cat /sys/kernel/debug/tracing/uprobe_profile
/lib/libc.so.6 syscall 20
A child process doesn't have a counter, but still it hits this breakoint
"copied" by dup_mmap().
After the patch:
/lib/libc.so.6 syscall 11
The child process hits this int3 only once and does unapply_uprobe().
Finally implement uprobe_perf_filter() which checks ->nr_systemwide or
->perf_events to figure out whether we need to insert the breakpoint.
uprobe_perf_open/close are changed to do uprobe_apply(true/false) when
the new perf event comes or goes away.
Note that currently this is very suboptimal:
- uprobe_register() called by TRACE_REG_PERF_REGISTER becomes a
heavy nop, consumer->filter() always returns F at this stage.
As it was already discussed we need uprobe_register_only() to
avoid the costly register_for_each_vma() when possible.
- uprobe_apply() is oftenly overkill. Unless "nr_systemwide != 0"
changes we need uprobe_apply_mm(), unapply_uprobe() is almost
what we need.
- uprobe_apply() can be simply avoided sometimes, see the next
changes.
Testing:
# perl -e 'syscall -1 while 1' &
[1] 530
# perf record -e probe_libc:syscall perl -e 'syscall -1 for 1..10; sleep 1'
Before this patch:
/lib/libc.so.6 syscall 79291
A huge ->nrhit == 79291 reflects the fact that the background process
530 constantly hits this breakpoint too, even if doesn't contribute to
the output.
After the patch:
/lib/libc.so.6 syscall 10
This shows that only the target process was punished by int3.
Introduce "struct trace_uprobe_filter" which records the "active"
perf_event's attached to ftrace_event_call. For the start we simply
use list_head, we can optimize this later if needed. For example, we
do not really need to record an event with ->parent != NULL, we can
rely on parent->child_list. And we can certainly do some optimizations
for the case when 2 events have the same ->tp_target or tp_target->mm.
Change trace_uprobe_register() to process TRACE_REG_PERF_OPEN/CLOSE
and add/del this perf_event to the list.
We can probably avoid any locking, but lets start with the "obvioulsy
correct" trace_uprobe_filter->rwlock which protects everything.
Move tu->nhit++ from uprobe_trace_func() to uprobe_dispatcher().
->nhit counts how many time we hit the breakpoint inserted by this
uprobe, we do not want to loose this info if uprobe was enabled by
sys_perf_event_open().
Acked-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
trace_uprobe
trace_uprobe->consumer and "struct uprobe_trace_consumer" add the
unnecessary indirection and complicate the code for no reason.
This patch simply embeds uprobe_consumer into "struct trace_uprobe",
all other changes only fix the compilation errors.
probe_event_enable/disable() check tu->consumer != NULL to avoid the
wrong uprobe_register/unregister().
We are going to kill this pointer and "struct uprobe_trace_consumer",
so we add the new helper, is_trace_uprobe_enabled(), which can rely
on TP_FLAG_TRACE/TP_FLAG_PROFILE instead.
Note: the current logic doesn't look optimal, it is not clear why
TP_FLAG_TRACE/TP_FLAG_PROFILE are mutually exclusive, we will probably
change this later.
Also kill the unused TP_FLAG_UPROBE.
probe_event_enable/disable() check tu->inode != NULL at the start.
This is ugly, if igrab() can fail create_trace_uprobe() should not
succeed and "postpone" the failure.
And S_ISREG(inode->i_mode) check added by d24d7dbf is not safe.
Note: alloc_uprobe() should probably check igrab() != NULL as well.
probe_event_enable() does uprobe_register() and only after that sets
utc->tu and tu->consumer/flags. This can race with uprobe_dispatcher()
which can miss these assignments or see them out of order. Nothing
really bad can happen, but this doesn't look clean/safe.
And this does not allow to use uprobe_consumer->filter() we are going
to add, it is called by uprobe_register() and it needs utc->tu.
Change this code to initialize everything before uprobe_register(), and
reset tu->consumer/flags if it fails. We can't race with event_disable(),
the caller holds event_mutex, and if we could the code would be wrong
anyway.
In fact I think uprobe_trace_consumer should die, it buys nothing but
complicates the code. We can simply add uprobe_consumer into trace_uprobe.
create_trace_uprobe() does kern_path() to find ->d_inode, but forgets
to do path_put(). We can do this right after igrab().
Change handle_swbp() to set regs->ip = bp_vaddr in advance, this is
what consumer->handler() needs but uprobe_get_swbp_addr() is not
exported.
This also simplifies the code and makes it more consistent across
the supported architectures. handle_swbp() becomes the only caller
of uprobe_get_swbp_addr().
Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
uprobe_consumer->filter() is pointless in its current form, kill it.
We will add it back, but with the different signature/semantics. Perhaps
we will even re-introduce the callsite in handler_chain(), but not to
just skip uc->handler().
Move rt scheduler definitions out of include/linux/sched.h into
new file include/linux/sched/rt.h
Signed-off-by: Clark Williams <williams@redhat.com>
Link: http://lkml.kernel.org/r/20130207094707.7b9f825f@riff.lan
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu
Pull RCU updates from Paul E. McKenney:
1. Changes to rcutorture and to RCU documentation. Posted to LKML at
https://lkml.org/lkml/2013/1/26/188.
2. Enhancements to uniprocessor handling in tiny RCU. Posted to LKML
at https://lkml.org/lkml/2013/1/27/2.
3. Tag RCU callbacks with grace-period number to simplify callback
advancement. Posted to LKML at https://lkml.org/lkml/2013/1/26/203.
4. Miscellaneous fixes. Posted to LKML at https://lkml.org/lkml/2013/1/26/204.
On early boot up, when the ftrace ring buffer is initialized, the
static variable current_trace is initialized to &nop_trace.
Before this initialization, current_trace is NULL and will never
become NULL again. It is always reassigned to a ftrace tracer.
Several places check if current_trace is NULL before it uses
it, and this check is frivolous, because at the point in time
when the checks are made the only way current_trace could be
NULL is if ftrace failed its allocations at boot up, and the
paths to these locations would probably not be possible.
By initializing current_trace to &nop_trace where it is declared,
current_trace will never be NULL, and we can remove all these
checks of current_trace being NULL which never needed to be
checked in the first place.
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Hiraku Toyooka <hiraku.toyooka.gu@hitachi.com>
Ftrace has a snapshot feature available from kernel space and
latency tracers (e.g. irqsoff) are using it. This patch enables
user applictions to take a snapshot via debugfs.
Add "snapshot" debugfs file in "tracing" directory.
snapshot:
This is used to take a snapshot and to read the output of the
snapshot.
# echo 1 > snapshot
This will allocate the spare buffer for snapshot (if it is
not allocated), and take a snapshot.
# cat snapshot
This will show contents of the snapshot.
# echo 0 > snapshot
This will free the snapshot if it is allocated.
Any other positive values will clear the snapshot contents if
the snapshot is allocated, or return EINVAL if it is not allocated.
Link: http://lkml.kernel.org/r/20121226025300.3252.86850.stgit@liselsia
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: David Sharp <dhsharp@google.com>
Signed-off-by: Hiraku Toyooka <hiraku.toyooka.gu@hitachi.com>
Fixed irqsoff selftest and also a conflict with a change
that fixes the update_max_tr.
Currently the trace buffer read functions use a static variable
"old_tracer" for detecting if the current tracer changes. This
was suitable for a single trace file ("trace"), but to add a
snapshot feature that will use the same function for its file,
a check against a static variable is not sufficient.
To use the output functions for two different files, instead of
storing the current tracer in a static variable, as the trace
iterator descriptor contains a pointer to the original current
tracer's name, that pointer can now be used to check if the
current tracer has changed between different reads of the trace
file.
Link: http://lkml.kernel.org/r/20121226025252.3252.9276.stgit@liselsia
For systems with an unstable sched_clock, all cpu_clock() does is enable/
disable local irq during the call to sched_clock_cpu(). And for stable
systems they are same.
trace_clock_global() already disables interrupts, so it can call
sched_clock_cpu() directly.
Link: http://lkml.kernel.org/r/1356576585-28782-2-git-send-email-namhyung@kernel.org
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Add a stat about the number of events read from the ring buffer:
# cat /debug/tracing/per_cpu/cpu0/stats
entries: 39869
overrun: 870512
commit overrun: 0
bytes: 1449912
oldest event ts: 6561.368690
now ts: 6565.246426
dropped events: 0
read events: 112 <-- Added
While debugging the virtual cputime with the function graph tracer
with a max_depth of 1 (most common use of the max_depth so far),
I found that I was missing kernel execution because of a race condition.
The code for the return side of the function has a slight race:
ftrace_pop_return_trace(&trace, &ret, frame_pointer);
trace.rettime = trace_clock_local();
ftrace_graph_return(&trace);
barrier();
current->curr_ret_stack--;
The ftrace_pop_return_trace() initializes the trace structure for
the callback. The ftrace_graph_return() uses the trace structure
for its own use as that structure is on the stack and is local
to this function. Then the curr_ret_stack is decremented which
is what the trace.depth is set to.
If an interrupt comes in after the ftrace_graph_return() but
before the curr_ret_stack, then the called function will get
a depth of 2. If max_depth is set to 1 this function will be
ignored.
The problem is that the trace has already been called, and the
timestamp for that trace will not reflect the time the function
was about to re-enter userspace. Calls to the interrupt will not
be traced because the max_depth has prevented this.
To solve this issue, the ftrace_graph_return() can safely be
moved after the current->curr_ret_stack has been updated.
This way the timestamp for the return callback will reflect
the actual time.
If an interrupt comes in after the curr_ret_stack update and
ftrace_graph_return(), it will be traced. It may look a little
confusing to see it within the other function, but at least
it will not be lost.
The trace iterator is already initialized by trace_init_global_iter(),
so there is no need to initialize it again.
Link: http://lkml.kernel.org/r/CACV3sb+G1YnO6168JhY3dEadmJi58pA5-2cSZT8E0WVHJNFt9Q@mail.gmail.com
Signed-off-by: Jovi Zhang <bookjovi@gmail.com>
__this_cpu_inc_return() or __this_cpu_dec generates a single instruction,
which is faster than __get_cpu_var operation.
Link: http://lkml.kernel.org/r/50A9C1BD.1060308@gmail.com
Reviewed-by: Christoph Lameter <cl@linux.com>
Signed-off-by: Shan Wei <davidshan@tencent.com>
The text in Documentation said it would be removed in 2.6.41;
the text in the Kconfig said removal in the 3.1 release. Either
way you look at it, we are well past both, so push it off a cliff.
Note that the POWER_CSTATE and the POWER_PSTATE are part of the
legacy tracing API. Remove all tracepoints which use these flags.
As can be seen from context, most already have a trace entry via
trace_cpu_idle anyways.
Also, the cpufreq/cpufreq.c PSTATE one is actually unpaired, as
compared to the CSTATE ones which all have a clear start/stop.
As part of this, the trace_power_frequency also becomes orphaned,
so it too is deleted.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Nothing outside of kernel/trace/trace.c references tracing_dentry_percpu().
Link: http://lkml.kernel.org/r/1353302917-13995-7-git-send-email-josh@joshtriplett.org
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Dan's smatch found a compare bug with the result of the
trace_test_and_set_recursion() and comparing to less than
zero. If the function fails, it returns -1, but was saved in
an unsigned int, which will never be less than zero and will
ignore the result of the test if a recursion did happen.
Luckily this is the last of the recursion tests, as the
infrastructure of ftrace would catch recursions before it
got here, except for some few exceptions.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
ring_buffer.c use to require declarations from trace.h, but
these have moved to the generic header files. There's nothing
in trace.h that ring_buffer.c requires.
There's some headers that trace.h included that ring_buffer.c
needs, but it's best that it includes them directly, and not
include trace.h.
Also, some things may use ring_buffer.c without having tracing
configured. This removes the dependency that may come in the
future.
Using context bit recursion checking, we can help increase the
performance of the ring buffer.
Before this patch:
# echo function > /debug/tracing/current_tracer
# for i in `seq 10`; do ./hackbench 50; done
Time: 10.285
Time: 10.407
Time: 10.243
Time: 10.372
Time: 10.380
Time: 10.198
Time: 10.272
Time: 10.354
Time: 10.248
Time: 10.253
(average: 10.3012)
Now we have:
Time: 9.712
Time: 9.824
Time: 9.861
Time: 9.827
Time: 9.962
Time: 9.905
Time: 9.886
Time: 10.088
Time: 9.861
Time: 9.834
(average: 9.876)
a 4% savings!
The function tracer had two different versions of function tracing.
The disabling of irqs version and the preempt disable version.
As function tracing in very intrusive and can cause nasty recursion
issues, it has its own recursion protection. But the old method to
do this was a flat layer. If it detected that a recursion was happening
then it would just return without recording.
This made the preempt version (much faster than the irq disabling one)
not very useful, because if an interrupt were to occur after the
recursion flag was set, the interrupt would not be traced at all,
because every function that was traced would think it recursed on
itself (due to the context it preempted setting the recursive flag).
Now that we have a recursion flag for every context level, we
no longer need to worry about that. We can disable preemption,
set the current context recursion check bit, and go on. If an
interrupt were to come along, it would check its own context bit
and happily continue to trace.
As the preempt version is faster than the irq disable version,
there's no more reason to keep the preempt version around.
And the irq disable version still had an issue with missing
out on tracing NMI code.
Remove the irq disable function tracer version and have the
preempt disable version be the default (and only version).
Before this patch we had from running:
Time: 12.028
Time: 11.945
Time: 11.925
Time: 11.964
Time: 12.002
Time: 11.910
Time: 11.944
Time: 11.929
Time: 11.941
Time: 11.924
(average: 11.9512)
Now we have:
Time: 10.285
Time: 10.407
Time: 10.243
Time: 10.372
Time: 10.380
Time: 10.198
Time: 10.272
Time: 10.354
Time: 10.248
Time: 10.253
(average: 10.3012)
a 13.8% savings!
When function tracing occurs, the following steps are made:
If arch does not support a ftrace feature:
call internal function (uses INTERNAL bits) which calls...
If callback is registered to the "global" list, the list
function is called and recursion checks the GLOBAL bits.
then this function calls...
The function callback, which can use the FTRACE bits to
check for recursion.
Now if the arch does not suppport a feature, and it calls
the global list function which calls the ftrace callback
all three of these steps will do a recursion protection.
There's no reason to do one if the previous caller already
did. The recursion that we are protecting against will
go through the same steps again.
To prevent the multiple recursion checks, if a recursion
bit is set that is higher than the MAX bit of the current
check, then we know that the check was made by the previous
caller, and we can skip the current check.
Convert the bits into enums which makes the code a little easier
to maintain.
Currently for recursion checking in the function tracer, ftrace
tests a task_struct bit to determine if the function tracer had
recursed or not. If it has, then it will will return without going
further.
But this leads to races. If an interrupt came in after the bit
was set, the functions being traced would see that bit set and
think that the function tracer recursed on itself, and would return.
Instead add a bit for each context (normal, softirq, irq and nmi).
A check of which context the task is in is made before testing the
associated bit. Now if an interrupt preempts the function tracer
after the previous context has been set, the interrupt functions
can still be traced.
There is lots of places that perform:
op = rcu_dereference_raw(ftrace_control_list);
while (op != &ftrace_list_end) {
Add a helper macro to do this, and also optimize for a single
entity. That is, gcc will optimize a loop for either no iterations
or more than one iteration. But usually only a single callback
is registered to the function tracer, thus the optimized case
should be a single pass. to do this we now do:
op = rcu_dereference_raw(list);
do {
} while (likely(op = rcu_dereference_raw((op)->next)) &&
unlikely((op) != &ftrace_list_end));
An op is always registered (ftrace_list_end when no callbacks is
registered), thus when a single callback is registered, the link
list looks like:
top => callback => ftrace_list_end => NULL.
The likely(op = op->next) still must be performed due to the race
of removing the callback, where the first op assignment could
equal ftrace_list_end. In that case, the op->next would be NULL.
But this is unlikely (only happens in a race condition when
removing the callback).
But it is very likely that the next op would be ftrace_list_end,
unless more than one callback has been registered. This tells
gcc what the most common case is and makes the fast path with
the least amount of branches.
The function tracing recursion self test should not crash
the machine if the resursion test fails. If it detects that
the function tracing is recursing when it should not be, then
bail, don't go into an infinite recursive loop.
If one of the function tracers set by the global ops is not recursion
safe, it can still be called directly without the added recursion
supplied by the ftrace infrastructure.
The test that checks function recursion does things differently
if the arch does not support all ftrace features. But that really
doesn't make a difference with how the test runs, and either way
the count variable should be 2 at the end.
Currently the test wrongly fails for archs that don't support all
the ftrace features.
There's a race condition between the setting of a new tracer and
the update of the max trace buffers (the swap). When a new tracer
is added, it sets current_trace to nop_trace before disabling
the old tracer. At this moment, if the old tracer uses update_max_tr(),
the update may trigger the warning against !current_trace->use_max-tr,
as nop_trace doesn't have that set.
As update_max_tr() requires that interrupts be disabled, we can
add a check to see if current_trace == nop_trace and bail if it
does. Then when disabling the current_trace, set it to nop_trace
and run synchronize_sched(). This will make sure all calls to
update_max_tr() have completed (it was called with interrupts disabled).
As a clean up, this commit also removes shrinking and recreating
the max_tr buffer if the old and new tracers both have use_max_tr set.
The old way use to always shrink the buffer, and then expand it
for the next tracer. This is a waste of time.
As trace_clock is used by other things besides tracing, and it
does not require anything from trace.h, it is best not to include
the header file in trace_clock.c.
Due to a userspace issue with PowerTop v2beta, which hardcoded
the offset of event fields that it was using, it broke when
we removed the Big Kernel Lock counter from the event header.
(commit e6e1e2593 "tracing: Remove lock_depth from event entry")
Because this broke userspace, it was determined that we must
keep those 4 bytes around.
(commit a3a4a5acd "Regression: partial revert "tracing: Remove lock_depth from event entry"")
This unfortunately wastes space in the ring buffer. 4 bytes per
event, where a lot of events are just 24 bytes. That's 16% of the
buffer wasted. A million events will add 4 megs of white space
into the buffer.
It was later noticed that PowerTop v2beta could not work on systems
where the kernel was 64 bit but the userspace was 32 bits.
The reason was because the offsets are different between the
two and the hard coded offset of one would not work with the other.
With PowerTop v2 final, it implemented the same interface that both
perf and trace-cmd use. That is, it reads the format file of
the event to find the offsets of the fields it needs. This fixes
the problem with running powertop on a 32 bit userspace running
on a 64 bit kernel. It also no longer requires the 4 byte padding.
As PowerTop v2 has been out for a while, and is included in all
major distributions, it is time that we can safely remove the
4 bytes of padding. Users of PowerTop v2beta should upgrade to
PowerTop v2 final.
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
Move SAVE_REGS support flag into Kconfig and rename
it to CONFIG_DYNAMIC_FTRACE_WITH_REGS. This also introduces
CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS which indicates
the architecture depending part of ftrace has a code
that saves full registers.
On the other hand, CONFIG_DYNAMIC_FTRACE_WITH_REGS indicates
the code is enabled.
Link: http://lkml.kernel.org/r/20120928081516.3560.72534.stgit@ltc138.sdl.hitachi.co.jp
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Add the file max_graph_depth to the debug tracing directory that lets
the user define the depth of the function graph.
A very useful operation is to set the depth to 1. Then it traces only
the first function that is called when entering the kernel. This can
be used to determine what system operations interrupt a process.
For example, to work on NOHZ processes (single tasks running without
a timer tick), if any interrupt goes off and preempts that task, this
code will show it happening.
# cd /sys/kernel/debug/tracing
# echo 1 > max_graph_depth
# echo function_graph > current_tracer
# cat per_cpu/cpu/<cpu-of-process>/trace
There's now a check in tracing_reset_online_cpus() if the buffer is
allocated or NULL. No need to do a check before calling it with max_tr.
max_tr->buffer could be NULL in the tracing_reset{_online_cpus}. In this
case, a NULL pointer dereference happens, so we should return immediately
from these functions.
Note, the current code does not call tracing_reset*() with max_tr when
its buffer is NULL, but future code will. This patch is needed to prevent
the future code from crashing.
Link: http://lkml.kernel.org/r/20121219070234.31200.93863.stgit@liselsia
Some functions in the syscall tracing is used only locally to
the file, but they are labeled global. Convert them to static functions.
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Without this patch, we can register a uprobe event for a directory.
Enabling such a uprobe event would anyway fail.
Example:
$ echo 'p /bin:0x4245c0' > /sys/kernel/debug/tracing/uprobe_events
However dirctories cannot be valid targets for uprobe.
Hence verify if the target is a regular file during the probe
registration.
Link: http://lkml.kernel.org/r/20130103004212.690763002@goodmis.org
Cc: Namhyung Kim <namhyung@kernel.org>
[ cleaned up whitespace and removed redundant IS_DIR() check ]
typeof(&buffer) is a pointer to array of 1024 char, or char (*)[1024].
But, typeof(&buffer[0]) is a pointer to char which match the return type of get_trace_buf().
As well-known, the value of &buffer is equal to &buffer[0].
so return this_cpu_ptr(&percpu_buffer->buffer[0]) can avoid type cast.
Link: http://lkml.kernel.org/r/50A1A800.3020102@gmail.com
The original ring-buffer code had special checks at the start
of rb_advance_iter() and instead of repeating them again at the
end of the function if a certain condition existed, I just did
a recursive call to rb_advance_iter() because the special condition
would cause rb_advance_iter() to return early (after the checks).
But as things have changed, the special checks no longer exist
and the only thing done for the special_condition is to call
rb_inc_iter() and return. Instead of doing a confusing recursive call,
just call rb_inc_iter instead.
If some other kernel subsystem has a module notifier, and adds a kprobe
to a ftrace mcount point (now that kprobes work on ftrace points),
when the ftrace notifier runs it will fail and disable ftrace, as well
as kprobes that are attached to ftrace points.
Here's the error:
WARNING: at kernel/trace/ftrace.c:1618 ftrace_bug+0x239/0x280()
Hardware name: Bochs
Modules linked in: fat(+) stap_56d28a51b3fe546293ca0700b10bcb29__8059(F) nfsv4 auth_rpcgss nfs dns_resolver fscache xt_nat iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack lockd sunrpc ppdev parport_pc parport microcode virtio_net i2c_piix4 drm_kms_helper ttm drm i2c_core [last unloaded: bid_shared]
Pid: 8068, comm: modprobe Tainted: GF 3.7.0-0.rc8.git0.1.fc19.x86_64 #1
Call Trace:
[<ffffffff8105e70f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff81134106>] ? __probe_kernel_read+0x46/0x70
[<ffffffffa0180000>] ? 0xffffffffa017ffff
[<ffffffff8105e76a>] warn_slowpath_null+0x1a/0x20
[<ffffffff810fd189>] ftrace_bug+0x239/0x280
[<ffffffff810fd626>] ftrace_process_locs+0x376/0x520
[<ffffffff810fefb7>] ftrace_module_notify+0x47/0x50
[<ffffffff8163912d>] notifier_call_chain+0x4d/0x70
[<ffffffff810882f8>] __blocking_notifier_call_chain+0x58/0x80
[<ffffffff81088336>] blocking_notifier_call_chain+0x16/0x20
[<ffffffff810c2a23>] sys_init_module+0x73/0x220
[<ffffffff8163d719>] system_call_fastpath+0x16/0x1b
---[ end trace 9ef46351e53bbf80 ]---
ftrace failed to modify [<ffffffffa0180000>] init_once+0x0/0x20 [fat]
actual: cc:bb:d2:4b:e1
A kprobe was added to the init_once() function in the fat module on load.
But this happened before ftrace could have touched the code. As ftrace
didn't run yet, the kprobe system had no idea it was a ftrace point and
simply added a breakpoint to the code (0xcc in the cc:bb:d2:4b:e1).
Then when ftrace went to modify the location from a call to mcount/fentry
into a nop, it didn't see a call op, but instead it saw the breakpoint op
and not knowing what to do with it, ftrace shut itself down.
The solution is to simply give the ftrace module notifier the max priority.
This should have been done regardless, as the core code ftrace modification
also happens very early on in boot up. This makes the module modification
closer to core modification.
Link: http://lkml.kernel.org/r/20130107140333.593683061@goodmis.org
Cc: stable@vger.kernel.org
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Reported-by: Frank Ch. Eigler <fche@redhat.com>
