path: root/kernel/trace/trace_events.c
2013-01-21tracing: Remove the extra 4 bytes of padding in eventsSteven Rostedt
Due to a userspace issue with PowerTop v2beta, which hardcoded the offset of event fields that it was using, it broke when we removed the Big Kernel Lock counter from the event header. (commit e6e1e2593 "tracing: Remove lock_depth from event entry") Because this broke userspace, it was determined that we must keep those 4 bytes around. (commit a3a4a5acd "Regression: partial revert "tracing: Remove lock_depth from event entry"") This unfortunately wastes space in the ring buffer. 4 bytes per event, where a lot of events are just 24 bytes. That's 16% of the buffer wasted. A million events will add 4 megs of white space into the buffer. It was later noticed that PowerTop v2beta could not work on systems where the kernel was 64 bit but the userspace was 32 bits. The reason was because the offsets are different between the two and the hard coded offset of one would not work with the other. With PowerTop v2 final, it implemented the same interface that both perf and trace-cmd use. That is, it reads the format file of the event to find the offsets of the fields it needs. This fixes the problem with running powertop on a 32 bit userspace running on a 64 bit kernel. It also no longer requires the 4 byte padding. As PowerTop v2 has been out for a while, and is included in all major distributions, it is time that we can safely remove the 4 bytes of padding. Users of PowerTop v2beta should upgrade to PowerTop v2 final. Cc: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-11-02tracing: Use irq_work for wake ups and remove *_nowake_*() functionsSteven Rostedt
Have the ring buffer commit function use the irq_work infrastructure to wake up any waiters waiting on the ring buffer for new data. The irq_work was created for such a purpose, where doing the actual wake up at the time of adding data is too dangerous, as an event or function trace may be in the midst of the work queue locks and cause deadlocks. The irq_work will either delay the action to the next timer interrupt, or trigger an IPI to itself forcing an interrupt to do the work (in a safe location). With irq_work, all ring buffer commits can safely do wakeups, removing the need for the ring buffer commit "nowake" variants, which were used by events and function tracing. All commits can now safely use the normal commit, and the "nowake" variants can be removed. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-11-02tracing: Separate open function from set_event and available_eventsSteven Rostedt
The open function used by available_events is the same as set_event even though it uses different seq functions. This causes a side effect of writing into available_events clearing all events, even though available_events is suppose to be read only. There's no reason to keep a single function for just the open and have both use different functions for everything else. It is a little confusing and causes strange behavior. Just have each have their own function. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-10-31tracing: Enable comm recording if trace_printk() is usedSteven Rostedt
If comm recording is not enabled when trace_printk() is used then you just get this type of output: [ adding trace_printk("hello! %d", irq); in do_IRQ ] <...>-2843 [001] d.h. 80.812300: do_IRQ: hello! 14 <...>-2734 [002] d.h2 80.824664: do_IRQ: hello! 14 <...>-2713 [003] d.h. 80.829971: do_IRQ: hello! 14 <...>-2814 [000] d.h. 80.833026: do_IRQ: hello! 14 By enabling the comm recorder when trace_printk is enabled: hackbench-6715 [001] d.h. 193.233776: do_IRQ: hello! 21 sshd-2659 [001] d.h. 193.665862: do_IRQ: hello! 21 <idle>-0 [001] d.h1 193.665996: do_IRQ: hello! 21 Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-09-24trace: Move trace event enable from fs_initcall to core_initcallEzequiel Garcia
This patch splits trace event initialization in two stages: * ftrace enable * sysfs event entry creation This allows to capture trace events from an earlier point by using 'trace_event' kernel parameter and is important to trace boot-up allocations. Note that, in order to enable events at core_initcall, it's necessary to move init_ftrace_syscalls() from core_initcall to early_initcall. Link: http://lkml.kernel.org/r/1347461277-25302-1-git-send-email-elezegarcia@gmail.com Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-09-13tracing: Skip printing "OK" if failed to disable eventYuanhan Liu
No acutal case found. But logically, we should skip "OK" in case any error met. Link: http://lkml.kernel.org/r/1346051625-25231-1-git-send-email-yuanhan.liu@linux.intel.com Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-31ftrace: Add default recursion protection for function tracingSteven Rostedt
As more users of the function tracer utility are being added, they do not always add the necessary recursion protection. To protect from function recursion due to tracing, if the callback ftrace_ops does not specifically specify that it protects against recursion (by setting the FTRACE_OPS_FL_RECURSION_SAFE flag), the list operation will be called by the mcount trampoline which adds recursion protection. If the flag is set, then the function will be called directly with no extra protection. Note, the list operation is called if more than one function callback is registered, or if the arch does not support all of the function tracer features. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-19ftrace: Return pt_regs to function trace callbackSteven Rostedt
Return as the 4th paramater to the function tracer callback the pt_regs. Later patches that implement regs passing for the architectures will require having the ftrace_ops set the SAVE_REGS flag, which will tell the arch to take the time to pass a full set of pt_regs to the ftrace_ops callback function. If the arch does not support it then it should pass NULL. If an arch can pass full regs, then it should define: ARCH_SUPPORTS_FTRACE_SAVE_REGS to 1 Link: http://lkml.kernel.org/r/20120702201821.019966811@goodmis.org Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-07-19ftrace: Pass ftrace_ops as third parameter to function trace callbackSteven Rostedt
Currently the function trace callback receives only the ip and parent_ip of the function that it traced. It would be more powerful to also return the ops that registered the function as well. This allows the same function to act differently depending on what ftrace_ops registered it. Link: http://lkml.kernel.org/r/20120612225424.267254552@goodmis.org Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-05-10tracing: Do not enable function event with enableSteven Rostedt
With the adding of function tracing event to perf, it caused a side effect that produces the following warning when enabling all events in ftrace: # echo 1 > /sys/kernel/debug/tracing/events/enable [console] event trace: Could not enable event function This is because when enabling all events via the debugfs system it ignores events that do not have a ->reg() function assigned. This was to skip over the ftrace internal events (as they are not TRACE_EVENTs). But as the ftrace function event now has a ->reg() function attached to it for use with perf, it is no longer ignored. Worse yet, this ->reg() function is being called when it should not be. It returns an error and causes the above warning to be printed. By adding a new event_call flag (TRACE_EVENT_FL_IGNORE_ENABLE) and have all ftrace internel event structures have it set, setting the events/enable will no longe try to incorrectly enable the function event and does not warn. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-02-21ftrace, perf: Add add/del tracepoint perf registration actionsJiri Olsa
Adding TRACE_REG_PERF_ADD and TRACE_REG_PERF_DEL to handle perf event schedule in/out actions. The add action is invoked for when the perf event is scheduled in, while the del action is invoked when the event is scheduled out. Link: http://lkml.kernel.org/r/1329317514-8131-4-git-send-email-jolsa@redhat.com Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-02-21ftrace, perf: Add open/close tracepoint perf registration actionsJiri Olsa
Adding TRACE_REG_PERF_OPEN and TRACE_REG_PERF_CLOSE to differentiate register/unregister from open/close actions. The register/unregister actions are invoked for the first/last tracepoint user when opening/closing the event. The open/close actions are invoked for each tracepoint user when opening/closing the event. Link: http://lkml.kernel.org/r/1329317514-8131-3-git-send-email-jolsa@redhat.com Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-12-05tracing: fix event_subsystem ref countingIlya Dryomov
Fix a bug introduced by e9dbfae5, which prevents event_subsystem from ever being released. Ref_count was added to keep track of subsystem users, not for counting events. Subsystem is created with ref_count = 1, so there is no need to increment it for every event, we have nr_events for that. Fix this by touching ref_count only when we actually have a new user - subsystem_open(). Cc: stable@vger.kernel.org Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Link: http://lkml.kernel.org/r/1320052062-7846-1-git-send-email-idryomov@gmail.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-21Merge branch 'perf/urgent' into perf/coreIngo Molnar
Merge reason: pick up the latest fixes - they won't make v3.0. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-07tracing: Have "enable" file use refcounts like the "filter" fileSteven Rostedt
The "enable" file for the event system can be removed when a module is unloaded and the event system only has events from that module. As the event system nr_events count goes to zero, it may be freed if its ref_count is also set to zero. Like the "filter" file, the "enable" file may be opened by a task and referenced later, after a module has been unloaded and the events for that event system have been removed. Although the "filter" file referenced the event system structure, the "enable" file only references a pointer to the event system name. Since the name is freed when the event system is removed, it is possible that an access to the "enable" file may reference a freed pointer. Update the "enable" file to use the subsystem_open() routine that the "filter" file uses, to keep a reference to the event system structure while the "enable" file is opened. Cc: <stable@kernel.org> Reported-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-07tracing: Fix bug when reading system filters on module removalSteven Rostedt
The event system is freed when its nr_events is set to zero. This happens when a module created an event system and then later the module is removed. Modules may share systems, so the system is allocated when it is created and freed when the modules are unloaded and all the events under the system are removed (nr_events set to zero). The problem arises when a task opened the "filter" file for the system. If the module is unloaded and it removed the last event for that system, the system structure is freed. If the task that opened the filter file accesses the "filter" file after the system has been freed, the system will access an invalid pointer. By adding a ref_count, and using it to keep track of what is using the event system, we can free it after all users are finished with the event system. Cc: <stable@kernel.org> Reported-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-14tracing: Convert to kstrtoul_from_userPeter Huewe
This patch replaces the code for getting an unsigned long from a userspace buffer by a simple call to kstroul_from_user. This makes it easier to read and less error prone. Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Link: http://lkml.kernel.org/r/1307476707-14762-1-git-send-email-peterhuewe@gmx.de Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25tracing: Have event with function tracer check error returnSteven Rostedt
The self tests for event tracer does not check if the function tracing was successfully activated. It needs to before it continues the tests, otherwise the wrong errors may be reported. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-06Regression: partial revert "tracing: Remove lock_depth from event entry"Arjan van de Ven
This partially reverts commit e6e1e2593592a8f6f6380496655d8c6f67431266. That commit changed the structure layout of the trace structure, which in turn broke PowerTOP (1.9x generation) quite badly. I appreciate not wanting to expose the variable in question, and PowerTOP was not using it, so I've replaced the variable with just a padding field - that way if in the future a new field is needed it can just use this padding field. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-10tracing: Export trace_set_clr_event()Yuanhan Liu
Trace events belonging to a module only exists when the module is loaded. Well, we can use trace_set_clr_event funtion to enable some trace event at the module init routine, so that we will not miss something while loading then module. So, Export the trace_set_clr_event function so that module can use it. Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com> LKML-Reference: <1289196312-25323-1-git-send-email-yuanhan.liu@linux.intel.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-03-10tracing: Remove lock_depth from event entrySteven Rostedt
The lock_depth field in the event headers was added as a temporary data point for help in removing the BKL. Now that the BKL is pretty much been removed, we can remove this field. This in turn changes the header from 12 bytes to 8 bytes, removing the 4 byte buffer that gcc would insert if the first field in the data load was 8 bytes in size. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-02-02tracing: Replace trace_event struct array with pointer arraySteven Rostedt
Currently the trace_event structures are placed in the _ftrace_events section, and at link time, the linker makes one large array of all the trace_event structures. On boot up, this array is read (much like the initcall sections) and the events are processed. The problem is that there is no guarantee that gcc will place complex structures nicely together in an array format. Two structures in the same file may be placed awkwardly, because gcc has no clue that they are suppose to be in an array. A hack was used previous to force the alignment to 4, to pack the structures together. But this caused alignment issues with other architectures (sparc). Instead of packing the structures into an array, the structures' addresses are now put into the _ftrace_event section. As pointers are always the natural alignment, gcc should always pack them tightly together (otherwise initcall, extable, etc would also fail). By having the pointers to the structures in the section, we can still iterate the trace_events without causing unnecessary alignment problems with other architectures, or depending on the current behaviour of gcc that will likely change in the future just to tick us kernel developers off a little more. The _ftrace_event section is also moved into the .init.data section as it is now only needed at boot up. Suggested-by: David Miller <davem@davemloft.net> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-11-19tracing/events: Show real number in array fieldsSteven Rostedt
Currently we have in something like the sched_switch event: field:char prev_comm[TASK_COMM_LEN]; offset:12; size:16; signed:1; When a userspace tool such as perf tries to parse this, the TASK_COMM_LEN is meaningless. This is done because the TRACE_EVENT() macro simply uses a #len to show the string of the length. When the length is an enum, we get a string that means nothing for tools. By adding a static buffer and a mutex to protect it, we can store the string into that buffer with snprintf and show the actual number. Now we get: field:char prev_comm[16]; offset:12; size:16; signed:1; Something much more useful. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-18tracing: Clean up seqfile code for format fileLi Zefan
Remove the nasty hack that marks a pointer's LSB to distinguish common fields from event fields. Replace it with a more sane approach. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4C6A23C2.9020606@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-08-16Merge branch 'tip/perf/urgent-3' of ↵Steven Rostedt
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into trace/tip/perf/urgent-4 Conflicts: kernel/trace/trace_events.c Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-08-12tracing/events: Convert format output to seq_fileSteven Rostedt
Two new events were added that broke the current format output. Both from the SCSI system: scsi_dispatch_cmd_done and scsi_dispatch_cmd_timeout The reason is that their print_fmt exceeded a page size. Since the output of the format used simple_read_from_buffer and trace_seq, it was limited to a page size in output. This patch converts the printing of the format of an event into seq_file, which allows greater than a page size to be shown. I diffed all event formats comparing the output with and without this patch. All matched except for the above two, which showed just: FORMAT TOO BIG without this patch, but now properly displays the output with this patch. v2: Remove updating *pos in seq start function. [ Thanks to Li Zefan for pointing that out ] Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Martin K. Petersen <martin.petersen@oracle.com> Cc: Kei Tokunaga <tokunaga.keiich@jp.fujitsu.com> Cc: James Bottomley <James.Bottomley@suse.de> Cc: Tomohiro Kusumi <kusumi.tomohiro@jp.fujitsu.com> Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-07-20tracing: Allow to disable cmdline recordingLi Zefan
We found that even enabling a single trace event that will rarely be triggered can add big overhead to context switch. (lmbench context switch test) ------------------------------------------------- 2p/0K 2p/16K 2p/64K 8p/16K 8p/64K 16p/16K 16p/64K ctxsw ctxsw ctxsw ctxsw ctxsw ctxsw ctxsw ------ ------ ------ ------ ------ ------- ------- 2.19 2.3 2.21 2.56 2.13 2.54 2.07 2.39 2.51 2.35 2.75 2.27 2.81 2.24 The overhead is 6% ~ 11%. It's because when a trace event is enabled 3 tracepoints (sched_switch, sched_wakeup, sched_wakeup_new) will be activated to map pid to cmdname. We'd like to avoid this overhead, so add a trace option '(no)record-cmd' to allow to disable cmdline recording. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4C2D57F4.2050204@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-06-28tracing: Use class->reg() for all registering of eventsSteven Rostedt
Because kprobes and syscalls need special processing to register events, the class->reg() method was created to handle the differences. But instead of creating a default ->reg for perf and ftrace events, the code was scattered with: if (class->reg) class->reg(); else default_reg(); This is messy and can also lead to bugs. This patch cleans up this code and creates a default reg() entry for the events allowing for the code to directly call the class->reg() without the condition. Reported-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-06-28tracing: Remove open-coded __trace_add_event_call()Li Zefan
Let trace_module_add_events() and event_trace_init() call __trace_add_event_call(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4BFA37E9.1020106@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-06-28tracing: Remove test of NULL define_fields callbackLi Zefan
Every event (or event class) has it's define_fields callback, so the test is redundant. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4BFA37BC.8080707@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-06-28tracing: Don't allocate common fields for every trace eventsLi Zefan
Every event has the same common fields, so it's a big waste of memory to have a copy of those fields for every event. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4BFA3759.30105@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-06-03tracing: Remove ftrace_preempt_disable/enableSteven Rostedt
The ftrace_preempt_disable/enable functions were to address a recursive race caused by the function tracer. The function tracer traces all functions which makes it easily susceptible to recursion. One area was preempt_enable(). This would call the scheduler and the schedulre would call the function tracer and loop. (So was it thought). The ftrace_preempt_disable/enable was made to protect against recursion inside the scheduler by storing the NEED_RESCHED flag. If it was set before the ftrace_preempt_disable() it would not call schedule on ftrace_preempt_enable(), thinking that if it was set before then it would have already scheduled unless it was already in the scheduler. This worked fine except in the case of SMP, where another task would set the NEED_RESCHED flag for a task on another CPU, and then kick off an IPI to trigger it. This could cause the NEED_RESCHED to be saved at ftrace_preempt_disable() but the IPI to arrive in the the preempt disabled section. The ftrace_preempt_enable() would not call the scheduler because the flag was already set before entring the section. This bug would cause a missed preemption check and cause lower latencies. Investigating further, I found that the recusion caused by the function tracer was not due to schedule(), but due to preempt_schedule(). Now that preempt_schedule is completely annotated with notrace, the recusion no longer is an issue. Reported-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Combine event filter_active and enable into single flags fieldSteven Rostedt
The filter_active and enable both use an int (4 bytes each) to set a single flag. We can save 4 bytes per event by combining the two into a single integer. text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4894944 1018052 861512 6774508 675eec vmlinux.id 4894871 1012292 861512 6768675 674823 vmlinux.flags This gives us another 5K in savings. The modification of both the enable and filter fields are done under the event_mutex, so it is still safe to combine the two. Note: Although Mathieu gave his Acked-by, he would like it documented that the reads of flags are not protected by the mutex. The way the code works, these reads will not break anything, but will have a residual effect. Since this behavior is the same even before this patch, describing this situation is left to another patch, as this patch does not change the behavior, but just brought it to Mathieu's attention. v2: Updated the event trace self test to for this change. Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Remove duplicate id information in event structureSteven Rostedt
Now that the trace_event structure is embedded in the ftrace_event_call structure, there is no need for the ftrace_event_call id field. The id field is the same as the trace_event type field. Removing the id and re-arranging the structure brings down the tracepoint footprint by another 5K. text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4895024 1023812 861512 6780348 6775bc vmlinux.print 4894944 1018052 861512 6774508 675eec vmlinux.id Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Move print functions into event classSteven Rostedt
Currently, every event has its own trace_event structure. This is fine since the structure is needed anyway. But the print function structure (trace_event_functions) is now separate. Since the output of the trace event is done by the class (with the exception of events defined by DEFINE_EVENT_PRINT), it makes sense to have the class define the print functions that all events in the class can use. This makes a bigger deal with the syscall events since all syscall events use the same class. The savings here is another 30K. text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4900382 1048964 861512 6810858 67ecea vmlinux.init 4900446 1049028 861512 6810986 67ed6a vmlinux.preprint 4895024 1023812 861512 6780348 6775bc vmlinux.print To accomplish this, and to let the class know what event is being printed, the event structure is embedded in the ftrace_event_call structure. This should not be an issues since the event structure was created for each event anyway. Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Move raw_init from events to classSteven Rostedt
The raw_init function pointer in the event is used to initialize various kinds of events. The type of initialization needed is usually classed to the kind of event it is. Two events with the same class will always have the same initialization function, so it makes sense to move this to the class structure. Perhaps even making a special system structure would work since the initialization is the same for all events within a system. But since there's no system structure (yet), this will just move it to the class. text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4900375 1053380 861512 6815267 67fe23 vmlinux.fields 4900382 1048964 861512 6810858 67ecea vmlinux.init The text grew very slightly, but this is a constant growth that happened with the changing of the C files that call the init code. The bigger savings is the data which will be saved the more events share a class. Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Move fields from event to class structureSteven Rostedt
Move the defined fields from the event to the class structure. Since the fields of the event are defined by the class they belong to, it makes sense to have the class hold the information instead of the individual events. The events of the same class would just hold duplicate information. After this change the size of the kernel dropped another 3K: text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4900252 1057412 861512 6819176 680d68 vmlinux.regs 4900375 1053380 861512 6815267 67fe23 vmlinux.fields Although the text increased, this was mainly due to the C files having to adapt to the change. This is a constant increase, where new tracepoints will not increase the Text. But the big drop is in the data size (as well as needed allocations to hold the fields). This will give even more savings as more tracepoints are created. Note, if just TRACE_EVENT()s are used and not DECLARE_EVENT_CLASS() with several DEFINE_EVENT()s, then the savings will be lost. But we are pushing developers to consolidate events with DEFINE_EVENT() so this should not be an issue. The kprobes define a unique class to every new event, but are dynamic so it should not be a issue. The syscalls however have a single class but the fields for the individual events are different. The syscalls use a metadata to define the fields. I moved the fields list from the event to the metadata and added a "get_fields()" function to the class. This function is used to find the fields. For normal events and kprobes, get_fields() just returns a pointer to the fields list_head in the class. For syscall events, it returns the fields list_head in the metadata for the event. v2: Fixed the syscall fields. The syscall metadata needs a list of fields for both enter and exit. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Remove per event trace registeringSteven Rostedt
This patch removes the register functions of TRACE_EVENT() to enable and disable tracepoints. The registering of a event is now down directly in the trace_events.c file. The tracepoint_probe_register() is now called directly. The prototypes are no longer type checked, but this should not be an issue since the tracepoints are created automatically by the macros. If a prototype is incorrect in the TRACE_EVENT() macro, then other macros will catch it. The trace_event_class structure now holds the probes to be called by the callbacks. This removes needing to have each event have a separate pointer for the probe. To handle kprobes and syscalls, since they register probes in a different manner, a "reg" field is added to the ftrace_event_class structure. If the "reg" field is assigned, then it will be called for enabling and disabling of the probe for either ftrace or perf. To let the reg function know what is happening, a new enum (trace_reg) is created that has the type of control that is needed. With this new rework, the 82 kernel events and 618 syscall events has their footprint dramatically lowered: text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4914025 1088868 861512 6864405 68be15 vmlinux.class 4918492 1084612 861512 6864616 68bee8 vmlinux.tracepoint 4900252 1057412 861512 6819176 680d68 vmlinux.regs The size went from 6863829 to 6819176, that's a total of 44K in savings. With tracepoints being continuously added, this is critical that the footprint becomes minimal. v5: Added #ifdef CONFIG_PERF_EVENTS around a reference to perf specific structure in trace_events.c. v4: Fixed trace self tests to check probe because regfunc no longer exists. v3: Updated to handle void *data in beginning of probe parameters. Also added the tracepoint: check_trace_callback_type_##call(). v2: Changed the callback probes to pass void * and typecast the value within the function. Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Create class struct for eventsSteven Rostedt
This patch creates a ftrace_event_class struct that event structs point to. This class struct will be made to hold information to modify the events. Currently the class struct only holds the events system name. This patch slightly increases the size, but this change lays the ground work of other changes to make the footprint of tracepoints smaller. With 82 standard tracepoints, and 618 system call tracepoints (two tracepoints per syscall: enter and exit): text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4914025 1088868 861512 6864405 68be15 vmlinux.class This patch also cleans up some stale comments in ftrace.h. v2: Fixed missing semi-colon in macro. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-10perf: Drop the obsolete profile naming for trace eventsFrederic Weisbecker
Drop the obsolete "profile" naming used by perf for trace events. Perf can now do more than simple events counting, so generalize the API naming. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Jason Baron <jbaron@redhat.com>
2010-02-25tracing: Simplify memory recycle of trace_define_fieldWenji Huang
Discard freeing field->type since it is not necessary. Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Wenji Huang <wenji.huang@oracle.com> LKML-Reference: <1266997226-6833-5-git-send-email-wenji.huang@oracle.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-01-06tracing: Remove show_format and related macros from TRACE_EVENTLai Jiangshan
The previous patches added the use of print_fmt string and changes the trace_define_field() function to also create the fields and format output for the event format files. text data bss dec hex filename 5857201 1355780 9336808 16549789 fc879d vmlinux 5884589 1351684 9337896 16574169 fce6d9 vmlinux-orig The above shows the size of the vmlinux after this patch set compared to the vmlinux-orig which is before the patch set. This saves us 27k on text, 1k on bss and adds just 4k of data. The total savings of 24k in size. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <4B273D4D.40604@cn.fujitsu.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-01-06tracing: Use defined fields and print_fmt to print formatsLai Jiangshan
The calls ftrace_format_##call() and ftrace_define_fields_##call() are almost duplicate in functionality. With the addition of the print_fmt in previous patches, these two functions can be merged into one. The trace_define_field() defines the fields and links them into the struct ftrace_event_call. The previous patches introduced the print_fmt field and this can now be used with the trace_define_field() to create the event format file fields and print_fmt field. The struct ftrace_event_call->fields are used to print the fields The struct ftrace_event_call->print_fmt is used to print the "print fmt: XXXXXXXXXXX" line. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <4B273D49.5000006@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-12-13tracing: Move a printk out of ftrace_raw_reg_event_foo()Li Zefan
Move the printk from each ftrace_raw_reg_event_foo() to its caller ftrace_event_enable_disable(). This avoids each regfunc trace event callbacks to handle a same error report that can be carried from the caller. See how much space this saves: text data bss dec hex filename 5345151 1961864 7103260 14410275 dbe223 vmlinux.o.old 5331487 1961864 7103260 14396611 dbacc3 vmlinux.o Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Jason Baron <jbaron@redhat.com> LKML-Reference: <4B1DC4AC.802@cn.fujitsu.com> [start cmdline record before calling regfunc to avoid lost window of pid to comm resolution] Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-12-13tracing: Pull up calls to trace_define_common_fields()Li Zefan
Call trace_define_common_fields() in event_create_dir() only. This avoids trace events to handle it from their define_fields callbacks and shrinks the kernel code size: text data bss dec hex filename 5346802 1961864 7103260 14411926 dbe896 vmlinux.o.old 5345151 1961864 7103260 14410275 dbe223 vmlinux.o Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jason Baron <jbaron@redhat.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> LKML-Reference: <4B1DC49C.8000107@cn.fujitsu.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-12-13tracing: Extract duplicate ftrace_raw_init_event_foo()Li Zefan
Use a generic trace_event_raw_init() function for all event's raw_init callbacks (but kprobes) instead of defining the same version for each of these. This shrinks the kernel code: text data bss dec hex filename 5355293 1961928 7103260 14420481 dc0a01 vmlinux.o.old 5346802 1961864 7103260 14411926 dbe896 vmlinux.o raw_init can't be removed, because ftrace events and kprobe events use different raw_init callbacks. Though it's possible to totally remove raw_init, I choose to leave it as it is for now. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Jason Baron <jbaron@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <4B1DC48C.7080603@cn.fujitsu.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-10-23Merge branch 'perf/core' into perf/probesIngo Molnar
Conflicts: tools/perf/Makefile Merge reason: - fix the conflict - pick up the pr_*() infrastructure to queue up dependent patch Signed-off-by: Ingo Molnar <mingo@elte.hu>
