The ftrace_preempt_disable/enable functions were to address a
recursive race caused by the function tracer. The function tracer
traces all functions which makes it easily susceptible to recursion.
One area was preempt_enable(). This would call the scheduler and
the schedulre would call the function tracer and loop.
(So was it thought).
The ftrace_preempt_disable/enable was made to protect against recursion
inside the scheduler by storing the NEED_RESCHED flag. If it was
set before the ftrace_preempt_disable() it would not call schedule
on ftrace_preempt_enable(), thinking that if it was set before then
it would have already scheduled unless it was already in the scheduler.
This worked fine except in the case of SMP, where another task would set
the NEED_RESCHED flag for a task on another CPU, and then kick off an
IPI to trigger it. This could cause the NEED_RESCHED to be saved at
ftrace_preempt_disable() but the IPI to arrive in the the preempt
disabled section. The ftrace_preempt_enable() would not call the scheduler
because the flag was already set before entring the section.
This bug would cause a missed preemption check and cause lower latencies.
Investigating further, I found that the recusion caused by the function
tracer was not due to schedule(), but due to preempt_schedule(). Now
that preempt_schedule is completely annotated with notrace, the recusion
no longer is an issue.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
# echo 1 > events/enable
# echo global > trace_clock
WARNING: at kernel/lockdep.c:3162 check_flags+0xb2/0x190()
---[ end trace 3f86734a89416623 ]---
possible reason: unannotated irqs-on.
There's no reason to use the raw_local_irq_save() in trace_clock_global.
The local_irq_save() version is fine, and does not cause the bug in lockdep.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <4BA97FA1.7030606@cn.fujitsu.com>
trace_clock.c includes spinlock.h, which ends up including
asm/system.h, which in turn includes linux/irqflags.h in x86.
So the definition of raw_local_irq_save is luckily covered there,
but this is not the case in parisc:
tip/kernel/trace/trace_clock.c:86: error: implicit declaration of function 'raw_local_irq_save'
tip/kernel/trace/trace_clock.c:112: error: implicit declaration of function 'raw_local_irq_restore'
We need to include linux/irqflags.h directly from trace_clock.c
to avoid such build error.
Cc: Robert Richter <robert.richter@amd.com>
Name space cleanup. No functional change.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Further name space cleanup. No functional change
The raw_spin* namespace was taken by lockdep for the architecture
specific implementations. raw_spin_* would be the ideal name space for
the spinlocks which are not converted to sleeping locks in preempt-rt.
Linus suggested to convert the raw_ to arch_ locks and cleanup the
name space instead of using an artifical name like core_spin,
atomic_spin or whatever
Disabling interrupts in trace_clock_local takes quite a performance
hit to the recording of traces. Using perf top we see:
PerfTop: 244 irqs/sec kernel:100.0% [1000Hz cpu-clock-msecs], (all, 4 CPUs)
samples pcnt kernel function
_______ _____ _______________
2842.00 - 40.4% : trace_clock_local
1043.00 - 14.8% : rb_reserve_next_event
784.00 - 11.1% : ring_buffer_lock_reserve
600.00 - 8.5% : __rb_reserve_next
579.00 - 8.2% : rb_end_commit
440.00 - 6.3% : ring_buffer_unlock_commit
290.00 - 4.1% : ring_buffer_producer_thread [ring_buffer_benchmark]
155.00 - 2.2% : debug_smp_processor_id
117.00 - 1.7% : trace_recursive_unlock
103.00 - 1.5% : ring_buffer_event_data
28.00 - 0.4% : do_gettimeofday
22.00 - 0.3% : _spin_unlock_irq
14.00 - 0.2% : native_read_tsc
11.00 - 0.2% : getnstimeofday
Where trace_clock_local is 40% of the tracing, and the time for recording
a trace according to ring_buffer_benchmark is 210ns. After converting
the interrupts to preemption disabling we have from perf top:
PerfTop: 1084 irqs/sec kernel:99.9% [1000Hz cpu-clock-msecs], (all, 4 CPUs)
1277.00 - 16.8% : native_read_tsc
1148.00 - 15.1% : rb_reserve_next_event
896.00 - 11.8% : ring_buffer_lock_reserve
688.00 - 9.1% : __rb_reserve_next
664.00 - 8.8% : rb_end_commit
563.00 - 7.4% : ring_buffer_unlock_commit
508.00 - 6.7% : _spin_unlock_irq
365.00 - 4.8% : debug_smp_processor_id
321.00 - 4.2% : trace_clock_local
303.00 - 4.0% : ring_buffer_producer_thread [ring_buffer_benchmark]
273.00 - 3.6% : native_sched_clock
122.00 - 1.6% : trace_recursive_unlock
113.00 - 1.5% : sched_clock
101.00 - 1.3% : ring_buffer_event_data
53.00 - 0.7% : tick_nohz_stop_sched_tick
Where trace_clock_local drops from 40% to only taking 4% of the total time.
The trace time also goes from 210ns down to 179ns (31ns).
I talked with Peter Zijlstra about the impact that sched_clock may have
without having interrupts disabled, and he told me that if a timer interrupt
comes in, sched_clock may report a wrong time.
Balancing a seldom incorrect timestamp with a 15% performance boost, I'll
take the performance boost.
The prev_trace_clock_time is only read or written to when the
trace_clock_lock is taken. For better perfomance, they
should share the same cache line.
Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Impact: cleanup.
This patch fixes the following sparse warnings:
kernel/trace/trace.c:385:9: warning: symbol 'trace_seq_to_buffer' was
not declared. Should it be static?
kernel/trace/trace_clock.c:29:13: warning: symbol 'trace_clock_local'
was not declared. Should it be static?
kernel/trace/trace_clock.c:54:13: warning: symbol 'trace_clock' was not
kernel/trace/trace_clock.c:74:13: warning: symbol 'trace_clock_global'
Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com>
LKML-Reference: <1237741871-5827-4-git-send-email-dmitri.vorobiev@movial.com>
Using the function_graph tracer in recent kernels generates a spew of
preemption BUGs. Fix this by not requiring trace_clock_local() users
to disable preemption themselves.
Impact: implement new tracing timestamp APIs
Add three trace clock variants, with differing scalability/precision
tradeoffs:
- local: CPU-local trace clock
- medium: scalable global clock with some jitter
- global: globally monotonic, serialized clock
Make the ring-buffer use the local trace clock internally.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
