path: root/kernel/trace/ring_buffer.c
2015-11-25ring-buffer: Process commits whenever moving to a new page.Steven Rostedt (Red Hat)
When crossing over to a new page, commit the current work. This will allow readers to get data with less latency, and also simplifies the work to get timestamps working for interrupted events. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-11-24ring-buffer: Remove redundant update of page timestampSteven Rostedt (Red Hat)
The first commit of a buffer page updates the timestamp of that page. No need to have the update to the next page add the timestamp too. It will only be replaced by the first commit on that page anyway. Only update to a page if it contains an event. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-11-24ring-buffer: Use READ_ONCE() for most tail_page accessSteven Rostedt (Red Hat)
As cpu_buffer->tail_page may be modified by interrupts at almost any time, the flow of logic is very important. Do not let gcc get smart with re-reading cpu_buffer->tail_page by adding READ_ONCE() around most of its accesses. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-11-24ring-buffer: Put back the length if crossed page with add_timestampSteven Rostedt (Red Hat)
Commit fcc742eaad7c "ring-buffer: Add event descriptor to simplify passing data" added a descriptor that holds various data instead of passing around several variables through parameters. The problem was that one of the parameters was modified in a function and the code was designed not to have an effect on that modified parameter. Now that the parameter is a descriptor and any modifications to it are non-volatile, the size of the data could be unnecessarily expanded. Remove the extra space added if a timestamp was added and the event went across the page. Cc: stable@vger.kernel.org # 4.3+ Fixes: fcc742eaad7c "ring-buffer: Add event descriptor to simplify passing data" Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-11-24ring-buffer: Update read stamp with first real commit on pageSteven Rostedt (Red Hat)
Do not update the read stamp after swapping out the reader page from the write buffer. If the reader page is swapped out of the buffer before an event is written to it, then the read_stamp may get an out of date timestamp, as the page timestamp is updated on the first commit to that page. rb_get_reader_page() only returns a page if it has an event on it, otherwise it will return NULL. At that point, check if the page being returned has events and has not been read yet. Then at that point update the read_stamp to match the time stamp of the reader page. Cc: stable@vger.kernel.org # 2.6.30+ Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-11-02ring-buffer: rb_event_is_commit() can return booleanYaowei Bai
Make rb_event_is_commit() return bool to improve readability due to this particular function only using either one or zero as its return value. No functional change. Link: http://lkml.kernel.org/r/1443537816-5788-7-git-send-email-bywxiaobai@163.com Signed-off-by: Yaowei Bai <bywxiaobai@163.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-11-02ring-buffer: rb_per_cpu_empty() can return booleanYaowei Bai
Makes rb_per_cpu_empty() return bool to improve readability. No functional change. Link: http://lkml.kernel.org/r/1443537816-5788-6-git-send-email-bywxiaobai@163.com Signed-off-by: Yaowei Bai <bywxiaobai@163.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-11-02ring_buffer: ring_buffer_empty{cpu}() can return booleanYaowei Bai
Make ring_buffer_empty() and ring_buffer_empty_cpu() return bool. No functional change. Link: http://lkml.kernel.org/r/1443537816-5788-5-git-send-email-bywxiaobai@163.com Signed-off-by: Yaowei Bai <bywxiaobai@163.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-11-02ring-buffer: rb_is_reader_page() can return booleanYaowei Bai
Make rb_is_reader_page() return bool to improve readability due to this particular function only using either true or false as its return value. No functional change. Link: http://lkml.kernel.org/r/1443537816-5788-4-git-send-email-bywxiaobai@163.com Signed-off-by: Yaowei Bai <bywxiaobai@163.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-09-03ring-buffer: Revert "ring-buffer: Get timestamp after event is allocated"Steven Rostedt (Red Hat)
The commit a4543a2fa9ef31 "ring-buffer: Get timestamp after event is allocated" is needed for some future work. But after adding it, there is a race somewhere that causes the saved timestamp to have a slight shift, and get ahead of the actual timestamp and make it look like time goes backwards. I'm still looking into why this happens, but in the mean time, this is holding up other work to get in. I'm reverting the change for now (which makes the problem go away), and will add it back after I know what is wrong and fix it. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-07-20ring-buffer: Reorganize function locationsSteven Rostedt (Red Hat)
Functions in ring-buffer.c have gotten interleaved between different use cases. Move the functions around to get like functions closer together. This may or may not help gcc keep cache locality, but it makes it a little easier to work with the code. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-07-20ring-buffer: Make sure event has enough room for extend and paddingSteven Rostedt (Red Hat)
Now that events only add time extends after it is committed, in case an event comes in before it can discard the allocated event, the time extend needs to be stored within the event. If the event is bigger than then size needed for the time extend, padding must be added. The minimum padding size is 8 bytes. Thus if the event is 12 bytes (size of time extend + 4), there will not be enough room to add both the time extend and padding. Make sure all events are either 8 bytes or 16 or more bytes. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-07-20ring-buffer: Get timestamp after event is allocatedSteven Rostedt (Red Hat)
Move the capturing of the timestamp to after an event is allocated. If the event is not a commit (where it is an event that preempted another event), then no timestamp is needed, because the delta of nested events is always zero. If the event starts on a new page, no delta needs to be calculated as the full timestamp will be added to the page header, and the event will have a delta of zero. Now if the event requires a time extend (the delta does not fit in the 27 bit delta slot in the header), then the event is discarded, the length is extended to hold the TIME_EXTEND event that allows for a 59 bit delta, and the commit is tried again. If the event can't be discarded (another event came in after it), then the TIME_EXTEND is added directly to the allocated event and the rest of the event is given padding. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-07-20ring-buffer: Move the adding of the extended timestamp out of lineSteven Rostedt (Red Hat)
Requiring a extended time stamp is an uncommon occurrence, and it is best to do it out of line when needed. Add a noinline function that handles the extended timestamp and have it called with an unlikely to completely move it out of the fast path. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-07-20ring-buffer: Add event descriptor to simplify passing dataSteven Rostedt (Red Hat)
Add rb_event_info descriptor to pass event info to functions a bit easier than using a bunch of parameters. This will also allow for changing the code around a bit to find better fast paths. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-05-29ring-buffer: Add enum names for the context levelsSteven Rostedt (Red Hat)
Instead of having hard coded numbers for the context levels, use enums to describe them more. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-05-28ring-buffer: Remove useless unused tracing_off_permanent()Steven Rostedt (Red Hat)
The tracing_off_permanent() call is a way to disable all ring_buffers. Nothing uses it and nothing should use it, as tracing_off() and friends are better, as they disable the ring buffers related to tracing. The tracing_off_permanent() even disabled non tracing ring buffers. This is a bit drastic, and was added to handle NMIs doing outputs that could corrupt the ring buffer when only tracing used them. It is now obsolete and adds a little overhead, it should be removed. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-05-28ring-buffer: Give NMIs a chance to lock the reader_lockSteven Rostedt (Red Hat)
Currently, if an NMI does a dump of a ring buffer, it disables all ring buffers from ever doing any writes again. This is because it wont take the locks for the cpu_buffer and this can cause corruption if it preempted a read, or a read happens on another CPU for the current cpu buffer. This is a bit overkill. First, it should at least try to take the lock, and if it fails then disable it. Also, there's no need to disable all ring buffers, even those that are unrelated to what is being read. Only disable the per cpu ring buffer that is being read if it can not get the lock for it. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-05-27ring-buffer: Add trace_recursive checks to ring_buffer_write()Steven Rostedt (Red Hat)
The ring_buffer_write() function isn't protected by the trace recursive writes. Luckily, this function is not used as much and is unlikely to ever recurse. But it should still have the protection, because even a call to ring_buffer_lock_reserve() could cause ring buffer corruption if called when ring_buffer_write() is being used. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-05-27ring-buffer: Allways do the trace_recursive checksSteven Rostedt (Red Hat)
Currently the trace_recursive checks are only done if CONFIG_TRACING is enabled. That was because there use to be a dependency with tracing for the recursive checks (it used the task_struct trace recursive variable). But now it uses its own variable and there is no dependency. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-05-27ring-buffer: Move recursive check to per_cpu descriptorSteven Rostedt (Red Hat)
Instead of using a global per_cpu variable to perform the recursive checks into the ring buffer, use the already existing per_cpu descriptor that is part of the ring buffer itself. Not only does this simplify the code, it also allows for one ring buffer to be used within the guts of the use of another ring buffer. For example trace_printk() can now be used within the ring buffer to record changes done by an instance into the main ring buffer. The recursion checks will prevent the trace_printk() itself from causing recursive issues with the main ring buffer (it is just ignored), but the recursive checks wont prevent the trace_printk() from recording other ring buffers. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-05-21ring-buffer: Add unlikelys to make fast path the defaultSteven Rostedt (Red Hat)
I was running the trace_event benchmark and noticed that the times to record a trace_event was all over the place. I looked at the assembly of the ring_buffer_lock_reserver() and saw this: <ring_buffer_lock_reserve>: 31 c0 xor %eax,%eax 48 83 3d 76 47 bd 00 cmpq $0x1,0xbd4776(%rip) # ffffffff81d10d60 <ring_buffer_flags> 01 55 push %rbp 48 89 e5 mov %rsp,%rbp 75 1d jne ffffffff8113c60d <ring_buffer_lock_reserve+0x2d> 65 ff 05 69 e3 ec 7e incl %gs:0x7eece369(%rip) # a960 <__preempt_count> 8b 47 08 mov 0x8(%rdi),%eax 85 c0 test %eax,%eax +---- 74 12 je ffffffff8113c610 <ring_buffer_lock_reserve+0x30> | 65 ff 0d 5b e3 ec 7e decl %gs:0x7eece35b(%rip) # a960 <__preempt_count> | 0f 84 85 00 00 00 je ffffffff8113c690 <ring_buffer_lock_reserve+0xb0> | 31 c0 xor %eax,%eax | 5d pop %rbp | c3 retq | 90 nop +---> 65 44 8b 05 48 e3 ec mov %gs:0x7eece348(%rip),%r8d # a960 <__preempt_count> 7e 41 81 e0 ff ff ff 7f and $0x7fffffff,%r8d b0 08 mov $0x8,%al 65 8b 0d 58 36 ed 7e mov %gs:0x7eed3658(%rip),%ecx # fc80 <current_context> 41 f7 c0 00 ff 1f 00 test $0x1fff00,%r8d 74 1e je ffffffff8113c64f <ring_buffer_lock_reserve+0x6f> 41 f7 c0 00 00 10 00 test $0x100000,%r8d b0 01 mov $0x1,%al 75 13 jne ffffffff8113c64f <ring_buffer_lock_reserve+0x6f> 41 81 e0 00 00 0f 00 and $0xf0000,%r8d 49 83 f8 01 cmp $0x1,%r8 19 c0 sbb %eax,%eax 83 e0 02 and $0x2,%eax 83 c0 02 add $0x2,%eax 85 c8 test %ecx,%eax 75 ab jne ffffffff8113c5fe <ring_buffer_lock_reserve+0x1e> 09 c8 or %ecx,%eax 65 89 05 24 36 ed 7e mov %eax,%gs:0x7eed3624(%rip) # fc80 <current_context> The arrow is the fast path. After adding the unlikely's, the fast path looks a bit better: <ring_buffer_lock_reserve>: 31 c0 xor %eax,%eax 48 83 3d 76 47 bd 00 cmpq $0x1,0xbd4776(%rip) # ffffffff81d10d60 <ring_buffer_flags> 01 55 push %rbp 48 89 e5 mov %rsp,%rbp 75 7b jne ffffffff8113c66b <ring_buffer_lock_reserve+0x8b> 65 ff 05 69 e3 ec 7e incl %gs:0x7eece369(%rip) # a960 <__preempt_count> 8b 47 08 mov 0x8(%rdi),%eax 85 c0 test %eax,%eax 0f 85 9f 00 00 00 jne ffffffff8113c6a1 <ring_buffer_lock_reserve+0xc1> 65 8b 0d 57 e3 ec 7e mov %gs:0x7eece357(%rip),%ecx # a960 <__preempt_count> 81 e1 ff ff ff 7f and $0x7fffffff,%ecx b0 08 mov $0x8,%al 65 8b 15 68 36 ed 7e mov %gs:0x7eed3668(%rip),%edx # fc80 <current_context> f7 c1 00 ff 1f 00 test $0x1fff00,%ecx 75 50 jne ffffffff8113c670 <ring_buffer_lock_reserve+0x90> 85 d0 test %edx,%eax 75 7d jne ffffffff8113c6a1 <ring_buffer_lock_reserve+0xc1> 09 d0 or %edx,%eax 65 89 05 53 36 ed 7e mov %eax,%gs:0x7eed3653(%rip) # fc80 <current_context> 65 8b 05 fc da ec 7e mov %gs:0x7eecdafc(%rip),%eax # a130 <cpu_number> 89 c2 mov %eax,%edx Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-05-13tracing: Rename ftrace_event.h to trace_events.hSteven Rostedt (Red Hat)
The term "ftrace" is really the infrastructure of the function hooks, and not the trace events. Rename ftrace_event.h to trace_events.h to represent the trace_event infrastructure and decouple the term ftrace from it. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-03-30ring-buffer: Remove duplicate use of '&' in recursive codeSteven Rostedt (Red Hat)
A clean up of the recursive protection code changed val = this_cpu_read(current_context); val--; val &= this_cpu_read(current_context); to val = this_cpu_read(current_context); val &= val & (val - 1); Which has a duplicate use of '&' as the above is the same as val = val & (val - 1); Actually, it would be best to remove that line altogether and just add it to where it is used. And Christoph even mentioned that it can be further compacted to just a single line: __this_cpu_and(current_context, __this_cpu_read(current_context) - 1); Link: http://lkml.kernel.org/alpine.DEB.2.11.1503271423580.23114@gentwo.org Suggested-by: Christoph Lameter <cl@linux.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-03-25ring-buffer: Replace this_cpu_*() with __this_cpu_*()Steven Rostedt
It has come to my attention that this_cpu_read/write are horrible on architectures other than x86. Worse yet, they actually disable preemption or interrupts! This caused some unexpected tracing results on ARM. 101.356868: preempt_count_add <-ring_buffer_lock_reserve 101.356870: preempt_count_sub <-ring_buffer_lock_reserve The ring_buffer_lock_reserve has recursion protection that requires accessing a per cpu variable. But since preempt_disable() is traced, it too got traced while accessing the variable that is suppose to prevent recursion like this. The generic version of this_cpu_read() and write() are: #define this_cpu_generic_read(pcp) \ ({ typeof(pcp) ret__; \ preempt_disable(); \ ret__ = *this_cpu_ptr(&(pcp)); \ preempt_enable(); \ ret__; \ }) #define this_cpu_generic_to_op(pcp, val, op) \ do { \ unsigned long flags; \ raw_local_irq_save(flags); \ *__this_cpu_ptr(&(pcp)) op val; \ raw_local_irq_restore(flags); \ } while (0) Which is unacceptable for locations that know they are within preempt disabled or interrupt disabled locations. Paul McKenney stated that __this_cpu_() versions produce much better code on other architectures than this_cpu_() does, if we know that the call is done in a preempt disabled location. I also changed the recursive_unlock() to use two local variables instead of accessing the per_cpu variable twice. Link: http://lkml.kernel.org/r/20150317114411.GE3589@linux.vnet.ibm.com Link: http://lkml.kernel.org/r/20150317104038.312e73d1@gandalf.local.home Cc: stable@vger.kernel.org Acked-by: Christoph Lameter <cl@linux.com> Reported-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Tested-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-02-11ring-buffer: Do not wake up a splice waiter when page is not fullSteven Rostedt (Red Hat)
When an application connects to the ring buffer via splice, it can only read full pages. Splice does not work with partial pages. If there is not enough data to fill a page, the splice command will either block or return -EAGAIN (if set to nonblock). Code was added where if the page is not full, to just sleep again. The problem is, it will get woken up again on the next event. That is, when something is written into the ring buffer, if there is a waiter it will wake it up. The waiter would then check the buffer, see that it still does not have enough data to fill a page and go back to sleep. To make matters worse, when the waiter goes back to sleep, it could cause another event, which would wake it back up again to see it doesn't have enough data and sleep again. This produces a tremendous overhead and fills the ring buffer with noise. For example, recording sched_switch on an idle system for 10 seconds produces 25,350,475 events!!! Create another wait queue for those waiters wanting full pages. When an event is written, it only wakes up waiters if there's a full page of data. It does not wake up the waiter if the page is not yet full. After this change, recording sched_switch on an idle system for 10 seconds produces only 800 events. Getting rid of 25,349,675 useless events (99.9969% of events!!), is something to take seriously. Cc: stable@vger.kernel.org # 3.16+ Cc: Rabin Vincent <rabin@rab.in> Fixes: e30f53aad220 "tracing: Do not busy wait in buffer splice" Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-01-22tracing: Remove unneeded includes of debugfs.h and fs.hSteven Rostedt (Red Hat)
The creation of tracing files and directories is for the most part encapsulated in helper functions in trace.c. Other files do not need to include debugfs.h or fs.h, as they may have needed to in the past. Remove them from the files that do not need them. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-12-10Merge tag 'trace-3.19' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing updates from Steven Rostedt: "There was a lot of clean ups and minor fixes. One of those clean ups was to the trace_seq code. It also removed the return values to the trace_seq_*() functions and use trace_seq_has_overflowed() to see if the buffer filled up or not. This is similar to work being done to the seq_file code as well in another tree. Some of the other goodies include: - Added some "!" (NOT) logic to the tracing filter. - Fixed the frame pointer logic to the x86_64 mcount trampolines - Added the logic for dynamic trampolines on !CONFIG_PREEMPT systems. That is, the ftrace trampoline can be dynamically allocated and be called directly by functions that only have a single hook to them" * tag 'trace-3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (55 commits) tracing: Truncated output is better than nothing tracing: Add additional marks to signal very large time deltas Documentation: describe trace_buf_size parameter more accurately tracing: Allow NOT to filter AND and OR clauses tracing: Add NOT to filtering logic ftrace/fgraph/x86: Have prepare_ftrace_return() take ip as first parameter ftrace/x86: Get rid of ftrace_caller_setup ftrace/x86: Have save_mcount_regs macro also save stack frames if needed ftrace/x86: Add macro MCOUNT_REG_SIZE for amount of stack used to save mcount regs ftrace/x86: Simplify save_mcount_regs on getting RIP ftrace/x86: Have save_mcount_regs store RIP in %rdi for first parameter ftrace/x86: Rename MCOUNT_SAVE_FRAME and add more detailed comments ftrace/x86: Move MCOUNT_SAVE_FRAME out of header file ftrace/x86: Have static tracing also use ftrace_caller_setup ftrace/x86: Have static function tracing always test for function graph kprobes: Add IPMODIFY flag to kprobe_ftrace_ops ftrace, kprobes: Support IPMODIFY flag to find IP modify conflict kprobes/ftrace: Recover original IP if pre_handler doesn't change it tracing/trivial: Fix typos and make an int into a bool tracing: Deletion of an unnecessary check before iput() ...
2014-11-19ring-buffer: Remove check of trace_seq_{puts,printf}() return valuesSteven Rostedt (Red Hat)
Remove checking the return value of all trace_seq_puts(). It was wrong anyway as only the last return value mattered. But as the trace_seq_puts() is going to be a void function in the future, we should not be checking the return value of it anyway. Just return !trace_seq_has_overflowed() instead. Reviewed-by: Petr Mladek <pmladek@suse.cz> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-11-10tracing: Do not busy wait in buffer spliceRabin Vincent
On a !PREEMPT kernel, attempting to use trace-cmd results in a soft lockup: # trace-cmd record -e raw_syscalls:* -F false NMI watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [trace-cmd:61] ... Call Trace: [<ffffffff8105b580>] ? __wake_up_common+0x90/0x90 [<ffffffff81092e25>] wait_on_pipe+0x35/0x40 [<ffffffff810936e3>] tracing_buffers_splice_read+0x2e3/0x3c0 [<ffffffff81093300>] ? tracing_stats_read+0x2a0/0x2a0 [<ffffffff812d10ab>] ? _raw_spin_unlock+0x2b/0x40 [<ffffffff810dc87b>] ? do_read_fault+0x21b/0x290 [<ffffffff810de56a>] ? handle_mm_fault+0x2ba/0xbd0 [<ffffffff81095c80>] ? trace_event_buffer_lock_reserve+0x40/0x80 [<ffffffff810951e2>] ? trace_buffer_lock_reserve+0x22/0x60 [<ffffffff81095c80>] ? trace_event_buffer_lock_reserve+0x40/0x80 [<ffffffff8112415d>] do_splice_to+0x6d/0x90 [<ffffffff81126971>] SyS_splice+0x7c1/0x800 [<ffffffff812d1edd>] tracesys_phase2+0xd3/0xd8 The problem is this: tracing_buffers_splice_read() calls ring_buffer_wait() to wait for data in the ring buffers. The buffers are not empty so ring_buffer_wait() returns immediately. But tracing_buffers_splice_read() calls ring_buffer_read_page() with full=1, meaning it only wants to read a full page. When the full page is not available, tracing_buffers_splice_read() tries to wait again with ring_buffer_wait(), which again returns immediately, and so on. Fix this by adding a "full" argument to ring_buffer_wait() which will make ring_buffer_wait() wait until the writer has left the reader's page, i.e. until full-page reads will succeed. Link: http://lkml.kernel.org/r/1415645194-25379-1-git-send-email-rabin@rab.in Cc: stable@vger.kernel.org # 3.16+ Fixes: b1169cc69ba9 ("tracing: Remove mock up poll wait function") Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-10-02ring-buffer: Fix infinite spin in reading bufferSteven Rostedt (Red Hat)
Commit 651e22f2701b "ring-buffer: Always reset iterator to reader page" fixed one bug but in the process caused another one. The reset is to update the header page, but that fix also changed the way the cached reads were updated. The cache reads are used to test if an iterator needs to be updated or not. A ring buffer iterator, when created, disables writes to the ring buffer but does not stop other readers or consuming reads from happening. Although all readers are synchronized via a lock, they are only synchronized when in the ring buffer functions. Those functions may be called by any number of readers. The iterator continues down when its not interrupted by a consuming reader. If a consuming read occurs, the iterator starts from the beginning of the buffer. The way the iterator sees that a consuming read has happened since its last read is by checking the reader "cache". The cache holds the last counts of the read and the reader page itself. Commit 651e22f2701b changed what was saved by the cache_read when the rb_iter_reset() occurred, making the iterator never match the cache. Then if the iterator calls rb_iter_reset(), it will go into an infinite loop by checking if the cache doesn't match, doing the reset and retrying, just to see that the cache still doesn't match! Which should never happen as the reset is suppose to set the cache to the current value and there's locks that keep a consuming reader from having access to the data. Fixes: 651e22f2701b "ring-buffer: Always reset iterator to reader page" Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-08-25trace: Fix epoll hang when we race with new entriesJosef Bacik
Epoll on trace_pipe can sometimes hang in a weird case. If the ring buffer is empty when we set waiters_pending but an event shows up exactly at that moment we can miss being woken up by the ring buffers irq work. Since ring_buffer_empty() is inherently racey we will sometimes think that the buffer is not empty. So we don't get woken up and we don't think there are any events even though there were some ready when we added the watch, which makes us hang. This patch fixes this by making sure that we are actually on the wait list before we set waiters_pending, and add a memory barrier to make sure ring_buffer_empty() is going to be correct. Link: http://lkml.kernel.org/p/1408989581-23727-1-git-send-email-jbacik@fb.com Cc: stable@vger.kernel.org # 3.10+ Cc: Martin Lau <kafai@fb.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-08-09Merge tag 'trace-fixes-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull trace file read iterator fixes from Steven Rostedt: "This contains a fix for two long standing bugs. Both of which are rarely ever hit, and requires the user to do something that users rarely do. It took a few special test cases to even trigger this bug, and one of them was just one test in the process of finishing up as another one started. Both bugs have to do with the ring buffer iterator rb_iter_peek(), but one is more indirect than the other. The fist bug fix is simply an increase in the safety net loop counter. The counter makes sure that the rb_iter_peek() only iterates the number of times we expect it can, and no more. Well, there was one way it could iterate one more than we expected, and that caused the ring buffer to shutdown with a nasty warning. The fix was simply to up that counter by one. The other bug has to be with rb_iter_reset() (called by rb_iter_peek()). This happens when a user reads both the trace_pipe and trace files. The trace_pipe is a consuming read and does not use the ring buffer iterator, but the trace file is not a consuming read and does use the ring buffer iterator. When the trace file is being read, if it detects that a consuming read occurred, it resets the iterator and starts over. But the reset code that does this (rb_iter_reset()), checks if the reader_page is linked to the ring buffer or not, and will look into the ring buffer itself if it is not. This is wrong, as it should always try to read the reader page first. Not to mention, the code that looked into the ring buffer did it wrong, and used the header_page "read" offset to start reading on that page. That offset is bogus for pages in the writable ring buffer, and was corrupting the iterator, and it would start returning bogus events" * tag 'trace-fixes-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: ring-buffer: Always reset iterator to reader page ring-buffer: Up rb_iter_peek() loop count to 3
2014-08-06ring-buffer: Always reset iterator to reader pageSteven Rostedt (Red Hat)
When performing a consuming read, the ring buffer swaps out a page from the ring buffer with a empty page and this page that was swapped out becomes the new reader page. The reader page is owned by the reader and since it was swapped out of the ring buffer, writers do not have access to it (there's an exception to that rule, but it's out of scope for this commit). When reading the "trace" file, it is a non consuming read, which means that the data in the ring buffer will not be modified. When the trace file is opened, a ring buffer iterator is allocated and writes to the ring buffer are disabled, such that the iterator will not have issues iterating over the data. Although the ring buffer disabled writes, it does not disable other reads, or even consuming reads. If a consuming read happens, then the iterator is reset and starts reading from the beginning again. My tests would sometimes trigger this bug on my i386 box: WARNING: CPU: 0 PID: 5175 at kernel/trace/trace.c:1527 __trace_find_cmdline+0x66/0xaa() Modules linked in: CPU: 0 PID: 5175 Comm: grep Not tainted 3.16.0-rc3-test+ #8 Hardware name: /DG965MQ, BIOS MQ96510J.86A.0372.2006.0605.1717 06/05/2006 00000000 00000000 f09c9e1c c18796b3 c1b5d74c f09c9e4c c103a0e3 c1b5154b f09c9e78 00001437 c1b5d74c 000005f7 c10bd85a c10bd85a c1cac57c f09c9eb0 ed0e0000 f09c9e64 c103a185 00000009 f09c9e5c c1b5154b f09c9e78 f09c9e80^M Call Trace: [<c18796b3>] dump_stack+0x4b/0x75 [<c103a0e3>] warn_slowpath_common+0x7e/0x95 [<c10bd85a>] ? __trace_find_cmdline+0x66/0xaa [<c10bd85a>] ? __trace_find_cmdline+0x66/0xaa [<c103a185>] warn_slowpath_fmt+0x33/0x35 [<c10bd85a>] __trace_find_cmdline+0x66/0xaa^M [<c10bed04>] trace_find_cmdline+0x40/0x64 [<c10c3c16>] trace_print_context+0x27/0xec [<c10c4360>] ? trace_seq_printf+0x37/0x5b [<c10c0b15>] print_trace_line+0x319/0x39b [<c10ba3fb>] ? ring_buffer_read+0x47/0x50 [<c10c13b1>] s_show+0x192/0x1ab [<c10bfd9a>] ? s_next+0x5a/0x7c [<c112e76e>] seq_read+0x267/0x34c [<c1115a25>] vfs_read+0x8c/0xef [<c112e507>] ? seq_lseek+0x154/0x154 [<c1115ba2>] SyS_read+0x54/0x7f [<c188488e>] syscall_call+0x7/0xb ---[ end trace 3f507febd6b4cc83 ]--- >>>> ##### CPU 1 buffer started #### Which was the __trace_find_cmdline() function complaining about the pid in the event record being negative. After adding more test cases, this would trigger more often. Strangely enough, it would never trigger on a single test, but instead would trigger only when running all the tests. I believe that was the case because it required one of the tests to be shutting down via delayed instances while a new test started up. After spending several days debugging this, I found that it was caused by the iterator becoming corrupted. Debugging further, I found out why the iterator became corrupted. It happened with the rb_iter_reset(). As consuming reads may not read the full reader page, and only part of it, there's a "read" field to know where the last read took place. The iterator, must also start at the read position. In the rb_iter_reset() code, if the reader page was disconnected from the ring buffer, the iterator would start at the head page within the ring buffer (where writes still happen). But the mistake there was that it still used the "read" field to start the iterator on the head page, where it should always start at zero because readers never read from within the ring buffer where writes occur. I originally wrote a patch to have it set the iter->head to 0 instead of iter->head_page->read, but then I questioned why it wasn't always setting the iter to point to the reader page, as the reader page is still valid. The list_empty(reader_page->list) just means that it was successful in swapping out. But the reader_page may still have data. There was a bug report a long time ago that was not reproducible that had something about trace_pipe (consuming read) not matching trace (iterator read). This may explain why that happened. Anyway, the correct answer to this bug is to always use the reader page an not reset the iterator to inside the writable ring buffer. Cc: stable@vger.kernel.org # 2.6.28+ Fixes: d769041f8653 "ring_buffer: implement new locking" Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-08-06ring-buffer: Up rb_iter_peek() loop count to 3Steven Rostedt (Red Hat)
After writting a test to try to trigger the bug that caused the ring buffer iterator to become corrupted, I hit another bug: WARNING: CPU: 1 PID: 5281 at kernel/trace/ring_buffer.c:3766 rb_iter_peek+0x113/0x238() Modules linked in: ipt_MASQUERADE sunrpc [...] CPU: 1 PID: 5281 Comm: grep Tainted: G W 3.16.0-rc3-test+ #143 Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007 0000000000000000 ffffffff81809a80 ffffffff81503fb0 0000000000000000 ffffffff81040ca1 ffff8800796d6010 ffffffff810c138d ffff8800796d6010 ffff880077438c80 ffff8800796d6010 ffff88007abbe600 0000000000000003 Call Trace: [<ffffffff81503fb0>] ? dump_stack+0x4a/0x75 [<ffffffff81040ca1>] ? warn_slowpath_common+0x7e/0x97 [<ffffffff810c138d>] ? rb_iter_peek+0x113/0x238 [<ffffffff810c138d>] ? rb_iter_peek+0x113/0x238 [<ffffffff810c14df>] ? ring_buffer_iter_peek+0x2d/0x5c [<ffffffff810c6f73>] ? tracing_iter_reset+0x6e/0x96 [<ffffffff810c74a3>] ? s_start+0xd7/0x17b [<ffffffff8112b13e>] ? kmem_cache_alloc_trace+0xda/0xea [<ffffffff8114cf94>] ? seq_read+0x148/0x361 [<ffffffff81132d98>] ? vfs_read+0x93/0xf1 [<ffffffff81132f1b>] ? SyS_read+0x60/0x8e [<ffffffff8150bf9f>] ? tracesys+0xdd/0xe2 Debugging this bug, which triggers when the rb_iter_peek() loops too many times (more than 2 times), I discovered there's a case that can cause that function to legitimately loop 3 times! rb_iter_peek() is different than rb_buffer_peek() as the rb_buffer_peek() only deals with the reader page (it's for consuming reads). The rb_iter_peek() is for traversing the buffer without consuming it, and as such, it can loop for one more reason. That is, if we hit the end of the reader page or any page, it will go to the next page and try again. That is, we have this: 1. iter->head > iter->head_page->page->commit (rb_inc_iter() which moves the iter to the next page) try again 2. event = rb_iter_head_event() event->type_len == RINGBUF_TYPE_TIME_EXTEND rb_advance_iter() try again 3. read the event. But we never get to 3, because the count is greater than 2 and we cause the WARNING and return NULL. Up the counter to 3. Cc: stable@vger.kernel.org # 2.6.37+ Fixes: 69d1b839f7ee "ring-buffer: Bind time extend and data events together" Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-08-04Merge tag 'trace-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing updates from Steven Rostedt: "This pull request has a lot of work done. The main thing is the changes to the ftrace function callback infrastructure. It's introducing a way to allow different functions to call directly different trampolines instead of all calling the same "mcount" one. The only user of this for now is the function graph tracer, which always had a different trampoline, but the function tracer trampoline was called and did basically nothing, and then the function graph tracer trampoline was called. The difference now, is that the function graph tracer trampoline can be called directly if a function is only being traced by the function graph trampoline. If function tracing is also happening on the same function, the old way is still done. The accounting for this takes up more memory when function graph tracing is activated, as it needs to keep track of which functions it uses. I have a new way that wont take as much memory, but it's not ready yet for this merge window, and will have to wait for the next one. Another big change was the removal of the ftrace_start/stop() calls that were used by the suspend/resume code that stopped function tracing when entering into suspend and resume paths. The stop of ftrace was done because there was some function that would crash the system if one called smp_processor_id()! The stop/start was a big hammer to solve the issue at the time, which was when ftrace was first introduced into Linux. Now ftrace has better infrastructure to debug such issues, and I found the problem function and labeled it with "notrace" and function tracing can now safely be activated all the way down into the guts of suspend and resume Other changes include clean ups of uprobe code, clean up of the trace_seq() code, and other various small fixes and clean ups to ftrace and tracing" * tag 'trace-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (57 commits) ftrace: Add warning if tramp hash does not match nr_trampolines ftrace: Fix trampoline hash update check on rec->flags ring-buffer: Use rb_page_size() instead of open coded head_page size ftrace: Rename ftrace_ops field from trampolines to nr_trampolines tracing: Convert local function_graph functions to static ftrace: Do not copy old hash when resetting tracing: let user specify tracing_thresh after selecting function_graph ring-buffer: Always run per-cpu ring buffer resize with schedule_work_on() tracing: Remove function_trace_stop and HAVE_FUNCTION_TRACE_MCOUNT_TEST s390/ftrace: remove check of obsolete variable function_trace_stop arm64, ftrace: Remove check of obsolete variable function_trace_stop Blackfin: ftrace: Remove check of obsolete variable function_trace_stop metag: ftrace: Remove check of obsolete variable function_trace_stop microblaze: ftrace: Remove check of obsolete variable function_trace_stop MIPS: ftrace: Remove check of obsolete variable function_trace_stop parisc: ftrace: Remove check of obsolete variable function_trace_stop sh: ftrace: Remove check of obsolete variable function_trace_stop sparc64,ftrace: Remove check of obsolete variable function_trace_stop tile: ftrace: Remove check of obsolete variable function_trace_stop ftrace: x86: Remove check of obsolete variable function_trace_stop ...
2014-07-23ring-buffer: Use rb_page_size() instead of open coded head_page sizeSteven Rostedt (Red Hat)
There's a helper function to get a ring buffer page size (the number of bytes of data recorded on the page), called rb_page_size(). Use that instead of open coding it. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-07-18ring-buffer: Always run per-cpu ring buffer resize with schedule_work_on()Corey Minyard
The code for resizing the trace ring buffers has to run the per-cpu resize on the CPU itself. The code was using preempt_off() and running the code for the current CPU directly, otherwise calling schedule_work_on(). At least on RT this could result in the following: |BUG: sleeping function called from invalid context at kernel/rtmutex.c:673 |in_atomic(): 1, irqs_disabled(): 0, pid: 607, name: bash |3 locks held by bash/607: |CPU: 0 PID: 607 Comm: bash Not tainted 3.12.15-rt25+ #124 |(rt_spin_lock+0x28/0x68) |(free_hot_cold_page+0x84/0x3b8) |(free_buffer_page+0x14/0x20) |(rb_update_pages+0x280/0x338) |(ring_buffer_resize+0x32c/0x3dc) |(free_snapshot+0x18/0x38) |(tracing_set_tracer+0x27c/0x2ac) probably via |cd /sys/kernel/debug/tracing/ |echo 1 > events/enable ; sleep 2 |echo 1024 > buffer_size_kb If we just always use schedule_work_on(), there's no need for the preempt_off(). So do that. Link: http://lkml.kernel.org/p/1405537633-31518-1-git-send-email-cminyard@mvista.com Reported-by: Stanislav Meduna <stano@meduna.org> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-07-15ring-buffer: Fix polling on trace_pipeMartin Lau
ring_buffer_poll_wait() should always put the poll_table to its wait_queue even there is immediate data available. Otherwise, the following epoll and read sequence will eventually hang forever: 1. Put some data to make the trace_pipe ring_buffer read ready first 2. epoll_ctl(efd, EPOLL_CTL_ADD, trace_pipe_fd, ee) 3. epoll_wait() 4. read(trace_pipe_fd) till EAGAIN 5. Add some more data to the trace_pipe ring_buffer 6. epoll_wait() -> this epoll_wait() will block forever ~ During the epoll_ctl(efd, EPOLL_CTL_ADD,...) call in step 2, ring_buffer_poll_wait() returns immediately without adding poll_table, which has poll_table->_qproc pointing to ep_poll_callback(), to its wait_queue. ~ During the epoll_wait() call in step 3 and step 6, ring_buffer_poll_wait() cannot add ep_poll_callback() to its wait_queue because the poll_table->_qproc is NULL and it is how epoll works. ~ When there is new data available in step 6, ring_buffer does not know it has to call ep_poll_callback() because it is not in its wait queue. Hence, block forever. Other poll implementation seems to call poll_wait() unconditionally as the very first thing to do. For example, tcp_poll() in tcp.c. Link: http://lkml.kernel.org/p/20140610060637.GA14045@devbig242.prn2.facebook.com Cc: stable@vger.kernel.org # 2.6.27 Fixes: 2a2cc8f7c4d0 "ftrace: allow the event pipe to be polled" Reviewed-by: Chris Mason <clm@fb.com> Signed-off-by: Martin Lau <kafai@fb.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-06-10ring-buffer: Check if buffer exists before pollingSteven Rostedt (Red Hat)
The per_cpu buffers are created one per possible CPU. But these do not mean that those CPUs are online, nor do they even exist. With the addition of the ring buffer polling, it assumes that the caller polls on an existing buffer. But this is not the case if the user reads trace_pipe from a CPU that does not exist, and this causes the kernel to crash. Simple fix is to check the cpu against buffer bitmask against to see if the buffer was allocated or not and return -ENODEV if it is not. More updates were done to pass the -ENODEV back up to userspace. Link: http://lkml.kernel.org/r/5393DB61.6060707@oracle.com Reported-by: Sasha Levin <sasha.levin@oracle.com> Cc: stable@vger.kernel.org # 3.10+ Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-03-20trace, ring-buffer: Fix CPU hotplug callback registrationSrivatsa S. Bhat
Subsystems that want to register CPU hotplug callbacks, as well as perform initialization for the CPUs that are already online, often do it as shown below: get_online_cpus(); for_each_online_cpu(cpu) init_cpu(cpu); register_cpu_notifier(&foobar_cpu_notifier); put_online_cpus(); This is wrong, since it is prone to ABBA deadlocks involving the cpu_add_remove_lock and the cpu_hotplug.lock (when running concurrently with CPU hotplug operations). Instead, the correct and race-free way of performing the callback registration is: cpu_notifier_register_begin(); for_each_online_cpu(cpu) init_cpu(cpu); /* Note the use of the double underscored version of the API */ __register_cpu_notifier(&foobar_cpu_notifier); cpu_notifier_register_done(); Fix the tracing ring-buffer code by using this latter form of callback registration. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-11ring-buffer: Fix first commit on sub-buffer having non-zero deltaSteven Rostedt (Red Hat)
Each sub-buffer (buffer page) has a full 64 bit timestamp. The events on that page use a 27 bit delta against that timestamp in order to save on bits written to the ring buffer. If the time between events is larger than what the 27 bits can hold, a "time extend" event is added to hold the entire 64 bit timestamp again and the events after that hold a delta from that timestamp. As a "time extend" is always paired with an event, it is logical to just allocate the event with the time extend, to make things a bit more efficient. Unfortunately, when the pairing code was written, it removed the "delta = 0" from the first commit on a page, causing the events on the page to be slightly skewed. Fixes: 69d1b839f7ee "ring-buffer: Bind time extend and data events together" Cc: stable@vger.kernel.org # 2.6.37+ Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-01-13sched/clock, x86: Use a static_key for sched_clock_stablePeter Zijlstra
In order to avoid the runtime condition and variable load turn sched_clock_stable into a static_key. Also provide a shorter implementation of local_clock() and cpu_clock(int) when sched_clock_stable==1. MAINLINE PRE POST sched_clock_stable: 1 1 1 (cold) sched_clock: 329841 221876 215295 (cold) local_clock: 301773 234692 220773 (warm) sched_clock: 38375 25602 25659 (warm) local_clock: 100371 33265 27242 (warm) rdtsc: 27340 24214 24208 sched_clock_stable: 0 0 0 (cold) sched_clock: 382634 235941 237019 (cold) local_clock: 396890 297017 294819 (warm) sched_clock: 38194 25233 25609 (warm) local_clock: 143452 71234 71232 (warm) rdtsc: 27345 24245 24243 Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-eummbdechzz37mwmpags1gjr@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-07-18tracing: Typo fix on ring buffer commentszhangwei(Jovi)
There have some mismatch between comments with real function name, update it. This patch also add some missed function arguments description. Link: http://lkml.kernel.org/r/51E3B3B2.4080307@huawei.com Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-07-18tracing: Use trace_seq_puts()/trace_seq_putc() where possiblezhangwei(Jovi)
For string without format specifiers, use trace_seq_puts() or trace_seq_putc(). Link: http://lkml.kernel.org/r/51E3B3AC.1000605@huawei.com Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> [ fixed a trace_seq_putc(s, " ") to trace_seq_putc(s, ' ') ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-05-28ring-buffer: Do not poll non allocated cpu buffersSteven Rostedt (Red Hat)
The tracing infrastructure sets up for possible CPUs, but it uses the ring buffer polling, it is possible to call the ring buffer polling code with a CPU that hasn't been allocated. This will cause a kernel oops when it access a ring buffer cpu buffer that is part of the possible cpus but hasn't been allocated yet as the CPU has never been online. Reported-by: Mauro Carvalho Chehab <mchehab@redhat.com> Tested-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-04-29Merge tag 'trace-3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing updates from Steven Rostedt: "Along with the usual minor fixes and clean ups there are a few major changes with this pull request. 1) Multiple buffers for the ftrace facility This feature has been requested by many people over the last few years. I even heard that Google was about to implement it themselves. I finally had time and cleaned up the code such that you can now create multiple instances of the ftrace buffer and have different events go to different buffers. This way, a low frequency event will not be lost in the noise of a high frequency event. Note, currently only events can go to different buffers, the tracers (ie function, function_graph and the latency tracers) still can only be written to the main buffer. 2) The function tracer triggers have now been extended. The function tracer had two triggers. One to enable tracing when a function is hit, and one to disable tracing. Now you can record a stack trace on a single (or many) function(s), take a snapshot of the buffer (copy it to the snapshot buffer), and you can enable or disable an event to be traced when a function is hit. 3) A perf clock has been added. A "perf" clock can be chosen to be used when tracing. This will cause ftrace to use the same clock as perf uses, and hopefully this will make it easier to interleave the perf and ftrace data for analysis." * tag 'trace-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (82 commits) tracepoints: Prevent null probe from being added tracing: Compare to 1 instead of zero for is_signed_type() tracing: Remove obsolete macro guard _TRACE_PROFILE_INIT ftrace: Get rid of ftrace_profile_bits tracing: Check return value of tracing_init_dentry() tracing: Get rid of unneeded key calculation in ftrace_hash_move() tracing: Reset ftrace_graph_filter_enabled if count is zero tracing: Fix off-by-one on allocating stat->pages kernel: tracing: Use strlcpy instead of strncpy tracing: Update debugfs README file tracing: Fix ftrace_dump() tracing: Rename trace_event_mutex to trace_event_sem tracing: Fix comment about prefix in arch_syscall_match_sym_name() tracing: Convert trace_destroy_fields() to static tracing: Move find_event_field() into trace_events.c tracing: Use TRACE_MAX_PRINT instead of constant tracing: Use pr_warn_once instead of open coded implementation ring-buffer: Add ring buffer startup selftest tracing: Bring Documentation/trace/ftrace.txt up to date tracing: Add "perf" trace_clock ... Conflicts: kernel/trace/ftrace.c kernel/trace/trace.c
2013-03-15ring-buffer: Add ring buffer startup selftestSteven Rostedt (Red Hat)
When testing my large changes to the ftrace system, there was a bug that looked like the ring buffer was dropping events. I wrote up a quick integrity checker of the ring buffer to see if it was. Although the bug ended up being something stupid I did in ftrace, and had nothing to do with the ring buffer, I figured if I spent the time to write up this test, I might as well include it in the kernel. I cleaned it up a bit, as the original version was rather ugly. Not saying this version is pretty, but it's a beauty queen compared to what I original wrote. To enable the start up test, set CONFIG_RING_BUFFER_STARTUP_TEST. Note, it runs for 10 seconds, so it will slow your boot time by at least 10 more seconds. What it does is documented in both the comments and the Kconfig help. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-03-15ring-buffer: Do not use schedule_work_on() for current CPUSteven Rostedt (Red Hat)
The ring buffer updates when done while the ring buffer is active, needs to be completed on the CPU that is used for the ring buffer per_cpu buffer. To accomplish this, schedule_work_on() is used to schedule work on the given CPU. Now there's no reason to use schedule_work_on() if the process doing the update happens to be on the CPU that it is processing. It has already filled the requirement. Instead, just do the work and continue. This is needed for tracing_snapshot_alloc() where it may be called really early in boot, where the work queues have not been set up yet. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-03-15ring-buffer: Init waitqueue for blocked readersSteven Rostedt (Red Hat)
The move of blocked readers to the ring buffer left out the init of the wait queue that is used. Tests missed this due to running stress tests against the buffers, which didn't allow for any readers to end up waiting. Running a simple read and wait triggered a bug. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
