path: root/kernel/trace/blktrace.c
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11Merge branch 'for-2.6.31' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.31' of git://git.kernel.dk/linux-2.6-block: (153 commits) block: add request clone interface (v2) floppy: fix hibernation ramdisk: remove long-deprecated "ramdisk=" boot-time parameter fs/bio.c: add missing __user annotation block: prevent possible io_context->refcount overflow Add serial number support for virtio_blk, V4a block: Add missing bounce_pfn stacking and fix comments Revert "block: Fix bounce limit setting in DM" cciss: decode unit attention in SCSI error handling code cciss: Remove no longer needed sendcmd reject processing code cciss: change SCSI error handling routines to work with interrupts enabled. cciss: separate error processing and command retrying code in sendcmd_withirq_core() cciss: factor out fix target status processing code from sendcmd functions cciss: simplify interface of sendcmd() and sendcmd_withirq() cciss: factor out core of sendcmd_withirq() for use by SCSI error handling code cciss: Use schedule_timeout_uninterruptible in SCSI error handling code block: needs to set the residual length of a bidi request Revert "block: implement blkdev_readpages" block: Fix bounce limit setting in DM Removed reference to non-existing file Documentation/PCI/PCI-DMA-mapping.txt ... Manually fix conflicts with tracing updates in: block/blk-sysfs.c drivers/ide/ide-atapi.c drivers/ide/ide-cd.c drivers/ide/ide-floppy.c drivers/ide/ide-tape.c include/trace/events/block.h kernel/trace/blktrace.c
2009-06-09tracing/events: convert block trace points to TRACE_EVENT()Li Zefan
TRACE_EVENT is a more generic way to define tracepoints. Doing so adds these new capabilities to this tracepoint: - zero-copy and per-cpu splice() tracing - binary tracing without printf overhead - structured logging records exposed under /debug/tracing/events - trace events embedded in function tracer output and other plugins - user-defined, per tracepoint filter expressions ... Cons: - no dev_t info for the output of plug, unplug_timer and unplug_io events. no dev_t info for getrq and sleeprq events if bio == NULL. no dev_t info for rq_abort,...,rq_requeue events if rq->rq_disk == NULL. This is mainly because we can't get the deivce from a request queue. But this may change in the future. - A packet command is converted to a string in TP_assign, not TP_print. While blktrace do the convertion just before output. Since pc requests should be rather rare, this is not a big issue. - In blktrace, an event can have 2 different print formats, but a TRACE_EVENT has a unique format, which means we have some unused data in a trace entry. The overhead is minimized by using __dynamic_array() instead of __array(). I've benchmarked the ioctl blktrace vs the splice based TRACE_EVENT tracing: dd dd + ioctl blktrace dd + TRACE_EVENT (splice) 1 7.36s, 42.7 MB/s 7.50s, 42.0 MB/s 7.41s, 42.5 MB/s 2 7.43s, 42.3 MB/s 7.48s, 42.1 MB/s 7.43s, 42.4 MB/s 3 7.38s, 42.6 MB/s 7.45s, 42.2 MB/s 7.41s, 42.5 MB/s So the overhead of tracing is very small, and no regression when using those trace events vs blktrace. And the binary output of TRACE_EVENT is much smaller than blktrace: # ls -l -h -rw-r--r-- 1 root root 8.8M 06-09 13:24 sda.blktrace.0 -rw-r--r-- 1 root root 195K 06-09 13:24 sda.blktrace.1 -rw-r--r-- 1 root root 2.7M 06-09 13:25 trace_splice.out Following are some comparisons between TRACE_EVENT and blktrace: plug: kjournald-480 [000] 303.084981: block_plug: [kjournald] kjournald-480 [000] 303.084981: 8,0 P N [kjournald] unplug_io: kblockd/0-118 [000] 300.052973: block_unplug_io: [kblockd/0] 1 kblockd/0-118 [000] 300.052974: 8,0 U N [kblockd/0] 1 remap: kjournald-480 [000] 303.085042: block_remap: 8,0 W 102736992 + 8 <- (8,8) 33384 kjournald-480 [000] 303.085043: 8,0 A W 102736992 + 8 <- (8,8) 33384 bio_backmerge: kjournald-480 [000] 303.085086: block_bio_backmerge: 8,0 W 102737032 + 8 [kjournald] kjournald-480 [000] 303.085086: 8,0 M W 102737032 + 8 [kjournald] getrq: kjournald-480 [000] 303.084974: block_getrq: 8,0 W 102736984 + 8 [kjournald] kjournald-480 [000] 303.084975: 8,0 G W 102736984 + 8 [kjournald] bash-2066 [001] 1072.953770: 8,0 G N [bash] bash-2066 [001] 1072.953773: block_getrq: 0,0 N 0 + 0 [bash] rq_complete: konsole-2065 [001] 300.053184: block_rq_complete: 8,0 W () 103669040 + 16 [0] konsole-2065 [001] 300.053191: 8,0 C W 103669040 + 16 [0] ksoftirqd/1-7 [001] 1072.953811: 8,0 C N (5a 00 08 00 00 00 00 00 24 00) [0] ksoftirqd/1-7 [001] 1072.953813: block_rq_complete: 0,0 N (5a 00 08 00 00 00 00 00 24 00) 0 + 0 [0] rq_insert: kjournald-480 [000] 303.084985: block_rq_insert: 8,0 W 0 () 102736984 + 8 [kjournald] kjournald-480 [000] 303.084986: 8,0 I W 102736984 + 8 [kjournald] Changelog from v2 -> v3: - use the newly introduced __dynamic_array(). Changelog from v1 -> v2: - use __string() instead of __array() to minimize the memory required to store hex dump of rq->cmd(). - support large pc requests. - add missing blk_fill_rwbs_rq() in block_rq_requeue TRACE_EVENT. - some cleanups. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4A2DF669.5070905@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-05-19blktrace: remove debugfs entries on bad pathStefan Raspl
debugfs directory entries for devices are not removed on some of the failure pathes in do_blk_trace_setup(). One way to reproduce is to start blktrace on multiple devices with insufficient Vmalloc space: Devices will fail with a message like this: BLKTRACESETUP(2) /dev/sdu failed: 5/Input/output error If so, the respective entries in debugfs (e.g. /sys/kernel/debug/block/sdu) will remain and subsequent attempts to start blktrace on the respective devices will not succeed due to existing directories. [ Impact: fix /debug/tracing file cleanup corner case ] Signed-off-by: Stefan Raspl <stefan.raspl@linux.vnet.ibm.com> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: schwidefsky@de.ibm.com Cc: heiko.carstens@de.ibm.com LKML-Reference: <4A1266CC.5040801@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-11blktrace: pdu_buf of pc events should be unsignedLi Zefan
I got this: 8,0 1 305.417782332 2037 I R 32 (ffffff9e 10 00 ...) [bash] It should be: 8,0 1 305.417782332 2037 I R 32 (9e 10 00 ...) [bash] [ Impact: fix output of pc events ] Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <4A07C6B3.9080802@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-11block: drop request->hard_* and *nr_sectorsTejun Heo
struct request has had a few different ways to represent some properties of a request. ->hard_* represent block layer's view of the request progress (completion cursor) and the ones without the prefix are supposed to represent the issue cursor and allowed to be updated as necessary by the low level drivers. The thing is that as block layer supports partial completion, the two cursors really aren't necessary and only cause confusion. In addition, manual management of request detail from low level drivers is cumbersome and error-prone at the very least. Another interesting duplicate fields are rq->[hard_]nr_sectors and rq->{hard_cur|current}_nr_sectors against rq->data_len and rq->bio->bi_size. This is more convoluted than the hard_ case. rq->[hard_]nr_sectors are initialized for requests with bio but blk_rq_bytes() uses it only for !pc requests. rq->data_len is initialized for all request but blk_rq_bytes() uses it only for pc requests. This causes good amount of confusion throughout block layer and its drivers and determining the request length has been a bit of black magic which may or may not work depending on circumstances and what the specific LLD is actually doing. rq->{hard_cur|current}_nr_sectors represent the number of sectors in the contiguous data area at the front. This is mainly used by drivers which transfers data by walking request segment-by-segment. This value always equals rq->bio->bi_size >> 9. However, data length for pc requests may not be multiple of 512 bytes and using this field becomes a bit confusing. In general, having multiple fields to represent the same property leads only to confusion and subtle bugs. With recent block low level driver cleanups, no driver is accessing or manipulating these duplicate fields directly. Drop all the duplicates. Now rq->sector means the current sector, rq->data_len the current total length and rq->bio->bi_size the current segment length. Everything else is defined in terms of these three and available only through accessors. * blk_recalc_rq_sectors() is collapsed into blk_update_request() and now handles pc and fs requests equally other than rq->sector update. This means that now pc requests can use partial completion too (no in-kernel user yet tho). * bio_cur_sectors() is replaced with bio_cur_bytes() as block layer now uses byte count as the primary data length. * blk_rq_pos() is now guranteed to be always correct. In-block users converted. * blk_rq_bytes() is now guaranteed to be always valid as is blk_rq_sectors(). In-block users converted. * blk_rq_sectors() is now guaranteed to equal blk_rq_bytes() >> 9. More convenient one is used. * blk_rq_bytes() and blk_rq_cur_bytes() are now inlined and take const pointer to request. [ Impact: API cleanup, single way to represent one property of a request ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: implement blk_rq_pos/[cur_]sectors() and convert obvious onesTejun Heo
Implement accessors - blk_rq_pos(), blk_rq_sectors() and blk_rq_cur_sectors() which return rq->hard_sector, rq->hard_nr_sectors and rq->hard_cur_sectors respectively and convert direct references of the said fields to the accessors. This is in preparation of request data length handling cleanup. Geert : suggested adding const to struct request * parameter to accessors Sergei : spotted error in patch description [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Tested-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Ackec-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-06blktrace: from-sector redundant in trace_block_remapAlan D. Brunelle
Remove redundant from-sector parameter: it's /always/ the bio's sector passed in. [ Impact: cleanup ] Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <49FF517C.7000503@hp.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-06blktrace: correct remap namesAlan D. Brunelle
This attempts to clarify names utilized during block I/O remap operations (partition, volume manager). It correctly matches up the /from/ information for both device & sector. This takes in the concept from Kosaki Motohiro and extends it to include better naming for the "device_from" field. [ Impact: cleanup ] Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <49FF4FAE.3000301@hp.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-16blktrace: fix context-info when mixed-using blk tracer and trace eventsLi Zefan
When current tracer is set to blk tracer, TRACE_ITER_CONTEXT_INFO is unset, but actually context-info is printed: pdflush-431 [000] 821.181576: 8,0 P N [pdflush] And then if we enable TRACE_ITER_CONTEXT_INFO: # echo context-info > trace_options We'll see context-info printed twice. What's worse, when we use blk tracer and trace events at the same time, we'll see no context-info for trace events at all: jbd2_commit_logging: dev dm-0:8 transaction 333227 jbd2_end_commit: dev dm-0:8 transaction 333227 head 332814 rm-25433 [001] 9578.307485: 8,18 m N cfq25433 slice expired t=0 rm-25433 [001] 9578.307486: 8,18 m N cfq25433 put_queue This patch adds blk_tracer->set_flags(), and context-info flag is unset only when we set the output to classic mode. Note after this patch, one should unset context-info explicitly if he wants to get binary output that can be parsed by blkparse: # echo nocontext-info > trace_options # echo bin > trace_options # echo blk > current_tracer # cat trace_pipe | blkparse -i - Reported-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <49E54E60.50408@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-16blktrace: add trace/ to /sys/block/sdaLi Zefan
Impact: allow ftrace-plugin blktrace to trace device-mapper devices To trace a single partition: # echo 1 > /sys/block/sda/sda1/enable To trace the whole sda instead: # echo 1 > /sys/block/sda/enable Thus we also fix an issue reported by Ted, that ftrace-plugin blktrace can't be used to trace device-mapper devices. Now: # echo 1 > /sys/block/dm-0/trace/enable echo: write error: No such device or address # mount -t ext4 /dev/dm-0 /mnt # echo 1 > /sys/block/dm-0/trace/enable # echo blk > /debug/tracing/current_tracer Reported-by: Theodore Tso <tytso@mit.edu> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Shawn Du <duyuyang@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> LKML-Reference: <49E42665.6020506@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-16blktrace: support per-partition tracing for ftrace pluginLi Zefan
The previous patch adds support to trace a single partition for relay+ioctl blktrace, and this patch is for ftrace plugin blktrace: # echo 1 > /sys/block/sda/sda7/enable # cat start_lba 102398373 # cat end_lba 102703545 Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Shawn Du <duyuyang@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> LKML-Reference: <49E42646.4060608@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-16blktrace: support per-partition tracingShawn Du
Though one can specify '-d /dev/sda1' when using blktrace, it still traces the whole sda. To support per-partition tracing, when we start tracing, we initialize bt->start_lba and bt->end_lba to the start and end sector of that partition. Note some actions are per device, thus we don't filter 0-sector events. The original patch and discussion can be found here: http://marc.info/?l=linux-btrace&m=122949374214540&w=2 Signed-off-by: Shawn Du <duyuyang@gmail.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> LKML-Reference: <49E42620.4050701@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-12blktrace: fix output of BLK_TC_PC eventsLi Zefan
BLK_TC_PC events should be treated differently with BLK_TC_FS events. Before this patch: # echo 1 > /sys/block/sda/sda1/trace/enable # echo pc > /sys/block/sda/sda1/trace/act_mask # echo blk > /debugfs/tracing/current_tracer # (generate some BLK_TC_PC events) # cat trace bash-2184 [000] 1774.275413: 8,7 I N [bash] bash-2184 [000] 1774.275435: 8,7 D N [bash] bash-2184 [000] 1774.275540: 8,7 I R [bash] bash-2184 [000] 1774.275547: 8,7 D R [bash] ksoftirqd/0-4 [000] 1774.275580: 8,7 C N 0 [0] bash-2184 [000] 1774.275648: 8,7 I R [bash] bash-2184 [000] 1774.275653: 8,7 D R [bash] ksoftirqd/0-4 [000] 1774.275682: 8,7 C N 0 [0] bash-2184 [000] 1774.275739: 8,7 I R [bash] bash-2184 [000] 1774.275744: 8,7 D R [bash] ksoftirqd/0-4 [000] 1774.275771: 8,7 C N 0 [0] bash-2184 [000] 1774.275804: 8,7 I R [bash] bash-2184 [000] 1774.275808: 8,7 D R [bash] ksoftirqd/0-4 [000] 1774.275836: 8,7 C N 0 [0] After this patch: # cat trace bash-2263 [000] 366.782149: 8,7 I N 0 (00 ..) [bash] bash-2263 [000] 366.782323: 8,7 D N 0 (00 ..) [bash] bash-2263 [000] 366.782557: 8,7 I R 8 (25 00 ..) [bash] bash-2263 [000] 366.782560: 8,7 D R 8 (25 00 ..) [bash] ksoftirqd/0-4 [000] 366.782582: 8,7 C N (25 00 ..) [0] bash-2263 [000] 366.782648: 8,7 I R 8 (5a 00 3f 00) [bash] bash-2263 [000] 366.782650: 8,7 D R 8 (5a 00 3f 00) [bash] ksoftirqd/0-4 [000] 366.782669: 8,7 C N (5a 00 3f 00) [0] bash-2263 [000] 366.782710: 8,7 I R 8 (5a 00 08 00) [bash] bash-2263 [000] 366.782713: 8,7 D R 8 (5a 00 08 00) [bash] ksoftirqd/0-4 [000] 366.782730: 8,7 C N (5a 00 08 00) [0] bash-2263 [000] 366.783375: 8,7 I R 36 (5a 00 08 00) [bash] bash-2263 [000] 366.783379: 8,7 D R 36 (5a 00 08 00) [bash] ksoftirqd/0-4 [000] 366.783404: 8,7 C N (5a 00 08 00) [0] This is what we do with PC events in user-space blktrace. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <49D32387.9040106@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-12blktrace: fix output of unknown eventsLi Zefan
Not all events are pc (packet command) events. An event is a pc event only if it has BLK_TC_PC bit set. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <49D3236D.3090705@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-09blktrace: pass the right pointer to kfree()Li Zefan
Impact: fix kfree crash with non-standard act_mask string If passing a string with leading white spaces to strstrip(), the returned ptr != the original ptr. This bug was introduced by me. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <49DD694C.8020902@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03blktrace: fix pdu_len when tracing packet command requestsLi Zefan
Impact: output all of packet commands - not just the first 4 / 8 bytes Since commit d7e3c3249ef23b4617393c69fe464765b4ff1645 ("block: add large command support"), struct request->cmd has been changed from unsinged char cmd[BLK_MAX_CDB] to unsigned char *cmd. v1 -> v2: by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> - make sure rq->cmd_len is always intialized, and then we can use rq->cmd_len instead of BLK_MAX_CDB. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> LKML-Reference: <49D4507E.2060602@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03blktrace: small cleanup in blk_msg_write()Li Zefan
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: "Alan D. Brunelle" <alan.brunelle@hp.com> Cc: Jens Axboe <jens.axboe@oracle.com> LKML-Reference: <49D5BB56.7000807@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-03blktrace: NUL-terminate user space messagesCarl Henrik Lunde
Impact: fix corrupted blkparse output Make sure messages from user space are NUL-terminated strings, otherwise we could dump random memory to the block trace file. Additionally, I've limited the message to BLK_TN_MAX_MSG-1 characters, because the last character would be stripped by vscnprintf anyway. Signed-off-by: Carl Henrik Lunde <chlunde@ping.uio.no> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: "Alan D. Brunelle" <alan.brunelle@hp.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20090403122714.GT5178@kernel.dk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-31blktrace: print out BLK_TN_MESSAGE properlyLi Zefan
Impact: improve ftrace plugin output Before this patch: # cat trace make-5383 [001] 741.240059: 8,7 P N [make] __trace_note_message: cfq1074 # echo 1 > options/blk_classic # cat trace 8,7 1 0.692221252 0 C W 130411392 + 1024 [0] Bad pc action 6361 Bad pc action 283d # echo 0 > options/blk_classic # echo bin > trace_options # cat trace_pipe | blkparse -i - (can't parse messages generated by blk_add_trace_msg()) After this patch: # cat trace <idle>-0 [001] 187.600933: 8,7 C W 145220224 + 8 [0] <idle>-0 [001] 187.600946: 8,7 m N cfq1076 complete # echo 1 > options/blk_classic # cat trace 8,7 1 0.256378996 238 I W 113190728 + 8 [pdflush] 8,7 1 0.256378998 238 m N cfq1076 insert_request # echo 0 > options/blk_classic # echo bin > trace_options # cat trace_pipe | blkparse -i - 8,7 1 0 22.973250293 0 C W 102770576 + 8 [0] 8,7 1 0 22.973259213 0 m N cfq1076 complete Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-31blktrace: extract duplidate codeLi Zefan
Impact: cleanup blk_trace_event_print() and blk_tracer_print_line() share most of the code. text data bss dec hex filename 8605 393 12 9010 2332 kernel/trace/blktrace.o.orig text data bss dec hex filename 8555 393 12 8960 2300 kernel/trace/blktrace.o This patch also prepares for the next patch, that prints out BLK_TN_MESSAGE. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-31blktrace: fix memory leak when freeing struct blk_io_traceLi Zefan
Impact: fix mixed ioctl and ftrace-plugin blktrace use memory leak When mixing the use of ioctl-based blktrace and ftrace-based blktrace, we can leak memory in this way: # btrace /dev/sda > /dev/null & # echo 0 > /sys/block/sda/sda1/trace/enable now we leak bt->dropped_file, bt->msg_file, bt->rchan... Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-31blktrace: fix blk_probes_ref chaosLi Zefan
Impact: fix mixed ioctl and ftrace-plugin blktrace use refcount bugs ioctl-based blktrace allocates bt and registers tracepoints when ioctl(BLKTRACESETUP), and do all cleanups when ioctl(BLKTRACETEARDOWN). while ftrace-based blktrace allocates/frees bt when: # echo 1/0 > /sys/block/sda/sda1/trace/enable and registers/unregisters tracepoints when: # echo blk/nop > /debugfs/tracing/current_tracer or # echo 1/0 > /debugfs/tracing/tracing_enable The separatation of allocation and registeration causes 2 problems: 1. current user-space blktrace still calls ioctl(TEARDOWN) when ioctl(SETUP) failed: # echo 1 > /sys/block/sda/sda1/trace/enable # blktrace /dev/sda BLKTRACESETUP: Device or resource busy ^C and now blk_probes_ref == -1 2. Another way to make blk_probes_ref == -1: # plugin sdb && mount sdb1 # echo 1 > /sys/block/sdb/sdb1/trace/enable # remove sdb This patch does the allocation and registeration when writing sdaX/trace/enable. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-31blktrace: make classic output more classicLi Zefan
Impact: fix ftrace plugin timestamp output In the classic user-space blktrace, the output timestamp is sec.nsec not sec.usec. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-31blktrace: fix off-by-one bugLi Zefan
'what' is used as the index of array what2act, so it can't >= the array size. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-31blktrace: fix the original blktraceLi Zefan
Currently the original blktrace, which is using relay and is used via ioctl, is broken. You can use ftrace to see the output of blktrace, but user-space blktrace is unusable. It's broken by "blktrace: add ftrace plugin" (c71a896154119f4ca9e89d6078f5f63ad60ef199) - if (unlikely(bt->trace_state != Blktrace_running)) + if (unlikely(bt->trace_state != Blktrace_running || !blk_tracer_enabled)) return; With this patch, both ioctl and ftrace can be used, but of course you can't use both of them at the same time. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-31blktrace: fix a race when creating blk_tree_root in debugfsLi Zefan
t1 t2 ------ ------ do_blk_trace_setup() do_blk_trace_setup() if (!blk_tree_root) { if (!blk_tree_root) blk_tree_root = create_dir() blk_tree_root = create_dir(); (now blk_tree_root == NULL) ... dir = create_dir(name, blk_tree_root); Due to this race, t1 will create 'dir' in /debugfs but not /debugfs/block. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-31blktrace: fix timestamp in binary outputLi Zefan
I found the timestamp is wrong: # echo bin > trace_option # echo blk > current_tracer # cat trace_pipe | blkparse -i - 8,0 0 0 0.000000000 504 A W ... ... 8,7 1 0 0.008534097 0 C R ... (should be 8.534097xxx) user-space blkparse expects the timestamp to be nanosecond. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-24blktrace: print human-readable act_maskLi Zefan
Impact: new feature, allow symbolic values in /debug/tracing/act_mask Print stringified act_mask instead of hex value: # cat act_mask read,write,barrier,sync,queue,requeue,issue,complete,fs,pc,ahead,meta, discard,drv_data # echo "meta,write" > act_mask # cat act_mask write,meta Also: - make act_mask accept "ahead", "meta", "discard" and "drv_data" - use strsep() instead of strchr() to parse user input - return -EINVAL if a token is not found in the mask map - fix a bug that 'value' is unsigned, so it can < 0 - propagate error value of blk_trace_mask2str() to userspace, but not always return -ENXIO. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <49C8AB42.1000802@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-24blktrace: fix t_error()Li Zefan
Impact: fix error flag output t_error() should return t->error but not t->sector. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <49C8945F.5020802@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-24blktrace: fix wrong calculation of RWBSLi Zefan
Impact: fix the output of IO type category characters Trace categories are the upper 16 bits, not the lower 16 bits. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <49C89432.8010805@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-24blktrace: mark ddir_act[] constLi Zefan
Impact: cleanup ddir_act and what2act always stay immutable. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <49C89415.5080503@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-21blktrace: avoid accessing NULL bdev->bd_diskLi Zefan
bdev->bd_disk can be NULL, if the block device is not opened. Try this against an unmounted partition, and you'll see NULL dereference: # echo 1 > /sys/block/sda/sda5/enable Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <49C30098.6080107@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-21blktrace: remove sysfs_blk_trace_enable_show/store()Li Zefan
sysfs_blk_trace_enable_show()/store() share most of code with sysfs_blk_trace_attr_show()/store(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <49C30EA3.1060004@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-21blktrace: report EBUSY correctlyLi Zefan
blk_trace_remove_queue() returns EINVAL if q->blk_trace == NULL, but blk_trace_setup_queue() doesn't return EBUSY if q->blk_trace != NULL. # echo 0 > sdaX/trace/enable # echo 0 > sdaX/trace/enable bash: echo: write error: Invalid argument # echo 1 > sdaX/trace/enable # echo 1 > sdaX/trace/enable (should return EBUSY) Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <49C2F614.2010101@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-21blktrace: don't increase blk_probes_ref if failed to setup blk traceLi Zefan
do_blk_trace_setup() may return EBUSY, but the current code doesn't decrease blk_probes_ref in this case. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <49C2F5FF.80002@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-21blktrace: remove blk_probe_mutexLi Zefan
blk_register_tracepoints() always returns 0, so make it return void, thus we don't need to use blk_probe_mutex to protect blk_probes_ref. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <49C2F5EA.8060606@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-21blktrace: make blk_tracer_enabled a bool flagLi Zefan
It doesn't have to be a counter, and it can be a bool flag instead. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Steven Rostedt <rostedt@goodmis.org> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <49C2F5D3.8090104@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-21blktrace: fix possible memory leakLi Zefan
When we failed to create "block" debugfs dir, we should do some cleanups. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <49C2F5B2.8000800@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-16tracing: protect reader of cmdline outputSteven Rostedt
Impact: fix to one cause of incorrect comm outputs in trace The spinlock only protected the creation of a comm <=> pid pair. But it was possible that a reader could look up a pid, and get the wrong comm because it had no locking. This also required changing trace_find_cmdline to copy the comm cache and not just send back a pointer to it. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-10Merge branch 'tip/tracing/ftrace' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into tracing/ftrace
2009-03-10tracing: remove funky whitespace in the trace codeSteven Rostedt
Impact: clean up There existed a lot of <space><tab>'s in the tracing code. This patch removes them. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-06Merge branch 'x86/core' into tracing/texteditIngo Molnar
Conflicts: arch/x86/Kconfig block/blktrace.c kernel/irq/handle.c Semantic conflict: kernel/trace/blktrace.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-04tracing: remove extra latency_trace method from trace structureSteven Rostedt
Impact: clean up The trace and latency_trace function pointers are identical for every tracer but the function tracer. The differences in the function tracer are trivial (latency output puts paranthesis around parent). This patch removes the latency_trace pointer and all prints will now just use the trace output function pointer. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-19Merge branch 'linus' into tracing/blktraceIngo Molnar
Conflicts: block/blktrace.c Semantic merge: kernel/trace/blktrace.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-09tracing/blktrace: move the tracing file to kernel/traceFrederic Weisbecker
Impact: cleanup Move blktrace.c to kernel/trace, also move its config entry. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
