path: root/kernel/timer.c
2006-07-03[PATCH] sched: cleanup, remove task_t, convert to struct task_structIngo Molnar
cleanup: remove task_t and convert all the uses to struct task_struct. I introduced it for the scheduler anno and it was a mistake. Conversion was mostly scripted, the result was reviewed and all secondary whitespace and style impact (if any) was fixed up by hand. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: annotate timer base locksIngo Molnar
Split the per-CPU timer base locks up into separate lock classes, because they are used recursively. Has no effect on non-lockdep kernels. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: locking init debugging improvementIngo Molnar
Locking init improvement: - introduce and use __SPIN_LOCK_UNLOCKED for array initializations, to pass in the name string of locks, used by debugging Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] cpu hotplug: revert initdata patch submitted for 2.6.17Chandra Seetharaman
This patch reverts notifier_block changes made in 2.6.17 Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] cpu hotplug: revert init patch submitted for 2.6.17Chandra Seetharaman
In 2.6.17, there was a problem with cpu_notifiers and XFS. I provided a band-aid solution to solve that problem. In the process, i undid all the changes you both were making to ensure that these notifiers were available only at init time (unless CONFIG_HOTPLUG_CPU is defined). We deferred the real fix to 2.6.18. Here is a set of patches that fixes the XFS problem cleanly and makes the cpu notifiers available only at init time (unless CONFIG_HOTPLUG_CPU is defined). If CONFIG_HOTPLUG_CPU is defined then cpu notifiers are available at run time. This patch reverts the notifier_call changes made in 2.6.17 Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] fix and optimize clock source updateRoman Zippel
This fixes the clock source updates in update_wall_time() to correctly track the time coming in via current_tick_length(). Optimize the fast paths to be as short as possible to keep the overhead low. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] time: rename clocksource functionsjohn stultz
As suggested by Roman Zippel, change clocksource functions to use clocksource_xyz rather then xyz_clocksource to avoid polluting the namespace. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Time: Introduce arch generic time accessorsjohn stultz
Introduces clocksource switching code and the arch generic time accessor functions that use the clocksource infrastructure. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Time: Use clocksource abstraction for NTP adjustmentsjohn stultz
Instead of incrementing xtime by tick_nsec + ntp adjustments, use the clocksource abstraction to increment and scale time. Using the clocksource abstraction allows other clocksources to be used consistently in the face of late or lost ticks, while preserving the existing behavior via the jiffies clocksource. This removes the need to keep time_phase adjustments as we just use the current_tick_length() function as the NTP interface and accumulate time using shifted nanoseconds. The basics of this design was by Roman Zippel, however it is my own interpretation and implementation, so the credit should go to him and the blame to me. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Time: Let user request precision from current_tick_length()john stultz
Change the current_tick_length() function so it takes an argument which specifies how much precision to return in shifted nanoseconds. This provides a simple way to convert between NTPs internal nanoseconds shifted by (SHIFT_SCALE - 10) to other shifted nanosecond units that are used by the clocksource abstraction. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Time: Use clocksource infrastructure for update_wall_timejohn stultz
Modify the update_wall_time function so it increments time using the clocksource abstraction instead of jiffies. Since the only clocksource driver currently provided is the jiffies clocksource, this should result in no functional change. Additionally, a timekeeping_init and timekeeping_resume function has been added to initialize and maintain some of the new timekeping state. [hirofumi@mail.parknet.co.jp: fixlet] Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Define __raw_get_cpu_var and use itPaul Mackerras
There are several instances of per_cpu(foo, raw_smp_processor_id()), which is semantically equivalent to __get_cpu_var(foo) but without the warning that smp_processor_id() can give if CONFIG_DEBUG_PREEMPT is enabled. For those architectures with optimized per-cpu implementations, namely ia64, powerpc, s390, sparc64 and x86_64, per_cpu() turns into more and slower code than __get_cpu_var(), so it would be preferable to use __get_cpu_var on those platforms. This defines a __raw_get_cpu_var(x) macro which turns into per_cpu(x, raw_smp_processor_id()) on architectures that use the generic per-cpu implementation, and turns into __get_cpu_var(x) on the architectures that have an optimized per-cpu implementation. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] When CONFIG_BASE_SMALL=1, cascade() may enter an infinite loopPorpoise
When CONFIG_BASE_SAMLL=1, cascade() in may enter the infinite loop. Because of CONFIG_BASE_SMALL=1(TVR_BITS=6 and TVN_BITS=4), the list base->tv5 may cascade into base->tv5. So, the kernel enters the infinite loop in the function cascade(). I created a test module to verify this bug, and a patch to fix it. #include <linux/kernel.h> #include <linux/module.h> #include <linux/init.h> #include <linux/timer.h> #if 0 #include <linux/kdb.h> #else #define kdb_printf printk #endif #define TVN_BITS (CONFIG_BASE_SMALL ? 4 : 6) #define TVR_BITS (CONFIG_BASE_SMALL ? 6 : 8) #define TVN_SIZE (1 << TVN_BITS) #define TVR_SIZE (1 << TVR_BITS) #define TVN_MASK (TVN_SIZE - 1) #define TVR_MASK (TVR_SIZE - 1) #define TV_SIZE(N) (N*TVN_BITS + TVR_BITS) struct timer_list timer0; struct timer_list dummy_timer1; struct timer_list dummy_timer2; void dummy_timer_fun(unsigned long data) { } unsigned long j=0; void check_timer_base(unsigned long data) { kdb_printf("check_timer_base %08x\n",jiffies); mod_timer(&timer0,(jiffies & (~0xFFF)) + 0x1FFF); } int init_module(void) { init_timer(&timer0); timer0.data = (unsigned long)0; timer0.function = check_timer_base; mod_timer(&timer0,jiffies+1); init_timer(&dummy_timer1); dummy_timer1.data = (unsigned long)0; dummy_timer1.function = dummy_timer_fun; init_timer(&dummy_timer2); dummy_timer2.data = (unsigned long)0; dummy_timer2.function = dummy_timer_fun; j=jiffies; j&=(~((1<<TV_SIZE(3))-1)); j+=(1<<TV_SIZE(3)); j+=(1<<TV_SIZE(4)); kdb_printf("mod_timer %08x\n",j); mod_timer(&dummy_timer1, j ); mod_timer(&dummy_timer2, j ); return 0; } void cleanup_module() { del_timer_sync(&timer0); del_timer_sync(&dummy_timer1); del_timer_sync(&dummy_timer2); } (Cleanups from Oleg) [oleg@tv-sign.ru: use list_replace_init()] Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] list: use list_replace_init() instead of list_splice_init()Oleg Nesterov
list_splice_init(list, head) does unneeded job if it is known that list_empty(head) == 1. We can use list_replace_init() instead. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-21[PATCH] Fix a NO_IDLE_HZ timer bugZachary Amsden
Under certain timing conditions, a race during boot occurs where timer ticks are being processed on remote CPUs. The remote timer ticks can increment jiffies, and if this happens during a window when a timeout is very close to expiring but a local tick has not yet been delivered, you can end up with 1) No softirq pending 2) A local timer wheel which is not synced to jiffies 3) No high resolution timer active 4) A local timer which is supposed to fire before the current jiffies value. In this circumstance, the comparison in next_timer_interrupt overflows, because the base of the comparison for high resolution timers is jiffies, but for the softirq timer wheel, it is relative the the current base of the wheel (jiffies_base). Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26[PATCH] Remove __devinit and __cpuinit from notifier_call definitionsChandra Seetharaman
Few of the notifier_chain_register() callers use __init in the definition of notifier_call. It is incorrect as the function definition should be available after the initializations (they do not unregister them during initializations). This patch fixes all such usages to _not_ have the notifier_call __init section. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26[PATCH] Remove __devinitdata from notifier block definitionsChandra Seetharaman
Few of the notifier_chain_register() callers use __devinitdata in the definition of notifier_block data structure. It is incorrect as the data structure should be available after the initializations (they do not unregister them during initializations). This was leading to an oops when notifier_chain_register() call is invoked for those callback chains after initialization. This patch fixes all such usages to _not_ have the notifier_block data structure in the init data section. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] timer initialisation fixAndrew Morton
We need the boot CPU's tvec_bases[] entry to be initialised super-early in boot, for early_serial_setup(). That runs within setup_arch(), before even per-cpu areas are initialised. The patch changes tvec_bases to use compile-time initialisation, and adds a separate array `tvec_base_done' to keep track of which CPU has had its tvec_bases[] entry initialised (because we can no longer use the zeroness of that tvec_bases[] entry to determine whether it has been initialised). Thanks to Eugene Surovegin <ebs@ebshome.net> for diagnosing this. Cc: Eugene Surovegin <ebs@ebshome.net> Cc: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-09[PATCH] x86_64: Fix drift with HPET timer enabledJordan Hargrave
If the HPET timer is enabled, the clock can drift by ~3 seconds a day. This is due to the HPET timer not being initialized with the correct setting (still using PIT count). If HZ changes, this drift can become even more pronounced. HPET patch initializes tick_nsec with correct tick_nsec settings for HPET timer. Vojtech comments: "It's not entirely correct (it assumes the HPET ticks totally exactly), but it's significantly better than assuming the PIT error there." Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02BUG_ON() Conversion in kernel/signal.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-31[PATCH] sched: reduce overhead of calc_loadJack Steiner
Currently, count_active_tasks() calls both nr_running() & nr_interruptible(). Each of these functions does a "for_each_cpu" & reads values from the runqueue of each cpu. Although this is not a lot of instructions, each runqueue may be located on different node. Depending on the architecture, a unique TLB entry may be required to access each runqueue. Since there may be more runqueues than cpu TLB entries, a scan of all runqueues can trash the TLB. Each memory reference incurs a TLB miss & refill. In addition, the runqueue cacheline that contains nr_running & nr_uninterruptible may be evicted from the cache between the two passes. This causes unnecessary cache misses. Combining nr_running() & nr_interruptible() into a single function substantially reduces the TLB & cache misses on large systems. This should have no measureable effect on smaller systems. On a 128p IA64 system running a memory stress workload, the new function reduced the overhead of calc_load() from 605 usec/call to 324 usec/call. Signed-off-by: Jack Steiner <steiner@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] __mod_timer: simplify ->base changingOleg Nesterov
Since base and new_base are of the same type now, we can save one 'if' branch and simplify the code a bit. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] kill __init_timer_base in favor of boot_tvec_basesOleg Nesterov
Commit a4a6198b80cf82eb8160603c98da218d1bd5e104: [PATCH] tvec_bases too large for per-cpu data introduced "struct tvec_t_base_s boot_tvec_bases" which is visible at compile time. This means we can kill __init_timer_base and move timer_base_s's content into tvec_t_base_s. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] remove pps supportRoman Zippel
This removes the support for pps. It's completely unused within the kernel and is basically in the way for further cleanups. It should be easier to readd proper support for it after the rest has been converted to NTP4 (where the pps mechanisms are quite different from NTP3 anyway). Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] sys_alarm() unsigned signed conversion fixupThomas Gleixner
alarm() calls the kernel with an unsigend int timeout in seconds. The value is stored in the tv_sec field of a struct timeval to setup the itimer. The tv_sec field of struct timeval is of type long, which causes the tv_sec value to be negative on 32 bit machines if seconds > INT_MAX. Before the hrtimer merge (pre 2.6.16) such a negative value was converted to the maximum jiffies timeout by the timeval_to_jiffies conversion. It's not clear whether this was intended or just happened to be done by the timeval_to_jiffies code. hrtimers expect a timeval in canonical form and treat a negative timeout as already expired. This breaks the legitimate usage of alarm() with a timeout value > INT_MAX seconds. For 32 bit machines it is therefor necessary to limit the internal seconds value to avoid API breakage. Instead of doing this in all implementations of sys_alarm the duplicated sys_alarm code is moved into a common function in itimer.c Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] timer-irq-driven soft-watchdog, cleanupsIngo Molnar
Make the softlockup detector purely timer-interrupt driven, removing softirq-context (timer) dependencies. This means that if the softlockup watchdog triggers, it has truly observed a longer than 10 seconds scheduling delay of a SCHED_FIFO prio 99 task. (the patch also turns off the softlockup detector during the initial bootup phase and does small style fixes) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] tvec_bases too large for per-cpu dataJan Beulich
With internal Xen-enabled kernels we see the kernel's static per-cpu data area exceed the limit of 32k on x86-64, and even native x86-64 kernels get fairly close to that limit. I generally question whether it is reasonable to have data structures several kb in size allocated as per-cpu data when the space there is rather limited. The biggest arch-independent consumer is tvec_bases (over 4k on 32-bit archs, over 8k on 64-bit ones), which now gets converted to use dynamically allocated memory instead. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-17[PATCH] time_interpolator: add __read_mostlyChristoph Lameter
The pointer to the current time interpolator and the current list of time interpolators are typically only changed during bootup. Adding __read_mostly takes them away from possibly hot cachelines. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-06[PATCH] time: add barrier after updating jiffies_64Atsushi Nemoto
Add a compiler barrier so that we don't read jiffies before updating jiffies_64. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-06[PATCH] fix next_timer_interrupt() for hrtimerTony Lindgren
Also from Thomas Gleixner <tglx@linutronix.de> Function next_timer_interrupt() got broken with a recent patch 6ba1b91213e81aa92b5cf7539f7d2a94ff54947c as sys_nanosleep() was moved to hrtimer. This broke things as next_timer_interrupt() did not check hrtimer tree for next event. Function next_timer_interrupt() is needed with dyntick (CONFIG_NO_IDLE_HZ, VST) implementations, as the system can be in idle when next hrtimer event was supposed to happen. At least ARM and S390 currently use next_timer_interrupt(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-02[PATCH] time_interpolator: Use readq_relaxed() instead of readq().Christoph Lameter
On some platforms readq performs additional work to make sure I/O is done in a coherent way. This is not needed for time retrieval as done by the time interpolator. So we can use readq_relaxed instead which will improve performance. It affects sparc64 and ia64 only. Apparently it makes a significant difference on ia64. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: john stultz <johnstul@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17[PATCH] Provide an interface for getting the current tick lengthPaul Mackerras
This provides an interface for arch code to find out how many nanoseconds are going to be added on to xtime by the next call to do_timer. The value returned is a fixed-point number in 52.12 format in nanoseconds. The reason for this format is that it gives the full precision that the timekeeping code is using internally. The motivation for this is to fix a problem that has arisen on 32-bit powerpc in that the value returned by do_gettimeofday drifts apart from xtime if NTP is being used. PowerPC is now using a lockless do_gettimeofday based on reading the timebase register and performing some simple arithmetic. (This method of getting the time is also exported to userspace via the VDSO.) However, the factor and offset it uses were calculated based on the nominal tick length and weren't being adjusted when NTP varied the tick length. Note that 64-bit powerpc has had the lockless do_gettimeofday for a long time now. It also had an extremely hairy routine that got called from the 32-bit compat routine for adjtimex, which adjusted the factor and offset according to what it thought the timekeeping code was going to do. Not only was this only called if a 32-bit task did adjtimex (i.e. not if a 64-bit task did adjtimex), it was also duplicating computations from kernel/timer.c and it wasn't clear that it was (still) correct. The simple solution is to ask the timekeeping code how long the current jiffy will be on each timer interrupt, after calling do_timer. If this jiffy will be a different length from the last one, we then need to compute new values for the factor and offset used in the lockless do_gettimeofday. In this way we can keep xtime and do_gettimeofday in sync, even when NTP is varying the tick length. Note that when adjtimex varies the tick length, it almost always introduces the variation from the next tick on. The only case I could see where adjtimex would vary the length of the current tick is when an old-style adjtime adjustment is being cancelled. (It's not clear to me why the adjustment has to be cancelled immediately rather than from the next tick on.) Thus I don't see any real need for a hook in adjtimex; the rare case of an old-style adjustment being cancelled can be fixed up at the next tick. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: john stultz <johnstul@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] timer.c NULL noise removalAl Viro
2006-01-10[PATCH] hrtimer: switch sys_nanosleep to hrtimerThomas Gleixner
convert sys_nanosleep() to use hrtimer_nanosleep() Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: hrtimer core codeThomas Gleixner
hrtimer subsystem core. It is initialized at bootup and expired by the timer interrupt, but is otherwise not utilized by any other subsystem yet. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] kernel/: small cleanupsAdrian Bunk
This patch contains the following cleanups: - make needlessly global functions static - every file should include the headers containing the prototypes for it's global functions Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] jiffies_64 cleanupThomas Gleixner
Define jiffies_64 in kernel/timer.c rather than having 24 duplicated defines in each architecture. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] remove timer debug fieldAndrew Morton
Remove timer_list.magic and associated debugging code. I originally added this when a spinlock was added to timer_list - this meant that an all-zeroes timer became illegal and init_timer() was required. That spinlock isn't even there any more, although timer.base must now be initialised. I'll keep this debugging code in -mm. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] ntp whitespace cleanupAndrew Morton
Fix bizarre 4-space coding style in the NTP code. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] NTP shift_right cleanupjohn stultz
Create a macro shift_right() that avoids the numerous ugly conditionals in the NTP code that look like: if(a < 0) b = -(-a >> shift); else b = a >> shift; Replacing it with: b = shift_right(a, shift); This should have zero effect on the logic, however it should probably have a bit of testing just to be sure. Also replace open-coded min/max with the macros. Signed-off-by : John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] introduce setup_timer() helperOleg Nesterov
Every user of init_timer() also needs to initialize ->function and ->data fields. This patch adds a simple setup_timer() helper for that. The schedule_timeout() is patched as an example of usage. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] TIMERS: add missing compensation for HZ == 250YOSHIFUJI Hideaki
Add missing compensation for (HZ == 250) != (1 << SHIFT_HZ) in second_overflow(). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] schedule_timeout_[un]interruptible() speedupAndrew Morton
These functions don't need schedule_timeout()'s barrier. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] kernel: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_{,un}interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] add schedule_timeout_{,un}interruptible() interfacesNishanth Aravamudan
Add schedule_timeout_{,un}interruptible() interfaces so that schedule_timeout() callers don't have to worry about forgetting to add the set_current_state() call beforehand. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] optimize writer path in time_interpolator_get_counter()Alex Williamson
Christoph Lameter <clameter@engr.sgi.com> When using a time interpolator that is susceptible to jitter there's potentially contention over a cmpxchg used to prevent time from going backwards. This is unnecessary when the caller holds the xtime write seqlock as all readers will be blocked from returning until the write is complete. We can therefore allow writers to insert a new value and exit rather than fight with CPUs who only hold a reader lock. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] detect soft lockupsIngo Molnar
This patch adds a new kernel debug feature: CONFIG_DETECT_SOFTLOCKUP. When enabled then per-CPU watchdog threads are started, which try to run once per second. If they get delayed for more than 10 seconds then a callback from the timer interrupt detects this condition and prints out a warning message and a stack dump (once per lockup incident). The feature is otherwise non-intrusive, it doesnt try to unlock the box in any way, it only gets the debug info out, automatically, and on all CPUs affected by the lockup. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-Off-By: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] preempt race in getppidDavid Meybohm
With CONFIG_PREEMPT && !CONFIG_SMP, it's possible for sys_getppid to return a bogus value if the parent's task_struct gets reallocated after current->group_leader->real_parent is read: asmlinkage long sys_getppid(void) { int pid; struct task_struct *me = current; struct task_struct *parent; parent = me->group_leader->real_parent; RACE HERE => for (;;) { pid = parent->tgid; #ifdef CONFIG_SMP { struct task_struct *old = parent; /* * Make sure we read the pid before re-reading the * parent pointer: */ smp_rmb(); parent = me->group_leader->real_parent; if (old != parent) continue; } #endif break; } return pid; } If the process gets preempted at the indicated point, the parent process can go ahead and call exit() and then get wait()'d on to reap its task_struct. When the preempted process gets resumed, it will not do any further checks of the parent pointer on !CONFIG_SMP: it will read the bad pid and return. So, the same algorithm used when SMP is enabled should be used when preempt is enabled, which will recheck ->real_parent in this case. Signed-off-by: David Meybohm <dmeybohmlkml@bellsouth.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kernel/timer: fix msleep_interruptible() commentDomen Puncer
The comment for msleep_interruptible() is wrong, as it will ignore wait-queue events, but will wake up early for signals. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] preempt_count is int - remove cast and don't assign to unsigned typeJesper Juhl
In kernel/sched.c the return value from preempt_count() is cast to an int. That made sense when preempt_count was defined as different types on is not needed and should go away. The patch removes the cast. In kernel/timer.c the return value from preempt_count() is assigned to a variable of type u32 and then that unsigned value is later compared to preempt_count(). Since preempt_count() returns an int, an int is what should be used to store its return value. Storing the result in an unsigned 32bit integer made a tiny bit of sense back when preempt_count was different types on different archs, but no more - let's not play signed vs unsigned comparison games when we don't have to. The patch modifies the code to use an int to hold the value. While I was around that bit of code I also made two changes to a nearby (related) printk() - I modified it to specify the loglevel explicitly and also broke the line into a few pieces to avoid it being longer than 80 chars and clarified the text a bit. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
