commit 3f2552f7e9c5abef2775c53f7af66532f8bf65bc upstream.
tick_freeze() introduced by suspend-to-idle in commit 124cf9117c5f ("PM /
sleep: Make it possible to quiesce timers during suspend-to-idle") uses
timekeeping_suspend() instead of syscore_suspend() during
suspend-to-idle. As a consequence generic sched_clock will keep going
because sched_clock_suspend() and sched_clock_resume() are not invoked
during suspend-to-idle which can result in a generic sched_clock wrap.
On a ARM system with suspend-to-idle enabled, sched_clock is registered
as "56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns", which
means the real wrapping duration is 8796093022202ns.
[ 134.551779] suspend-to-idle suspend (timekeeping_suspend())
[ 1204.912239] suspend-to-idle resume (timekeeping_resume())
[ 1206.912239] suspend-to-idle suspend (timekeeping_suspend())
[ 5880.502807] suspend-to-idle resume (timekeeping_resume())
[ 6000.403724] suspend-to-idle suspend (timekeeping_suspend())
[ 8035.753167] suspend-to-idle resume (timekeeping_resume())
[ 8795.786684] (2)[321:charger_thread]......
[ 8795.788387] (2)[321:charger_thread]......
[ 0.057226] (0)[0:swapper/0]......
[ 0.061447] (2)[0:swapper/2]......
sched_clock was not stopped during suspend-to-idle, and sched_clock_poll
hrtimer was not expired because timekeeping_suspend() was invoked during
suspend-to-idle. It makes sched_clock wrap at kernel time 8796s.
To prevent this, invoke sched_clock_suspend() and sched_clock_resume() in
tick_freeze() together with timekeeping_suspend() and timekeeping_resume().
Fixes: 124cf9117c5f (PM / sleep: Make it possible to quiesce timers during suspend-to-idle)
Signed-off-by: Chang-An Chen <chang-an.chen@mediatek.com>
Cc: Matthias Brugger <matthias.bgg@gmail.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Corey Minyard <cminyard@mvista.com>
Cc: <linux-mediatek@lists.infradead.org>
Cc: <linux-arm-kernel@lists.infradead.org>
Cc: Stanley Chu <stanley.chu@mediatek.com>
Cc: <kuohong.wang@mediatek.com>
Cc: <freddy.hsin@mediatek.com>
Cc: stable@vger.kernel.org
Link: https://lkml.kernel.org/r/1553828349-8914-1-git-send-email-chang-an.chen@mediatek.com
commit 07d7e12091f4ab869cc6a4bb276399057e73b0b3 upstream.
To calculate a remaining time, it's required to subtract the current time
from the expiration time. In alarm_timer_remaining() the arguments of
ktime_sub are swapped.
Fixes: d653d8457c76 ("alarmtimer: Implement remaining callback")
Signed-off-by: Andrei Vagin <avagin@gmail.com>
Reviewed-by: Mukesh Ojha <mojha@codeaurora.org>
Cc: Stephen Boyd <sboyd@kernel.org>
Link: https://lkml.kernel.org/r/20190408041542.26338-1-avagin@gmail.com
The recent commit which prevented a division by 0 issue in the alarm timer
code broke posix CPU timers as an unwanted side effect.
The reason is that the common rearm code checks for timer->it_interval
being 0 now. What went unnoticed is that the posix cpu timer setup does not
initialize timer->it_interval as it stores the interval in CPU timer
specific storage. The reason for the separate storage is historical as the
posix CPU timers always had a 64bit nanoseconds representation internally
while timer->it_interval is type ktime_t which used to be a modified
timespec representation on 32bit machines.
Instead of reverting the offending commit and fixing the alarmtimer issue
in the alarmtimer code, store the interval in timer->it_interval at CPU
timer setup time so the common code check works. This also repairs the
existing inconistency of the posix CPU timer code which kept a single shot
timer armed despite of the interval being 0.
The separate storage can be removed in mainline, but that needs to be a
separate commit as the current one has to be backported to stable kernels.
Fixes: 0e334db6bb4b ("posix-timers: Fix division by zero bug")
Reported-by: H.J. Lu <hjl.tools@gmail.com>
Link: https://lkml.kernel.org/r/20190111133500.840117406@linutronix.de
ssh://gitolite.kernel.org:/pub/scm/linux/kernel/git/arnd/playground
Pull y2038 updates from Arnd Bergmann:
"More syscalls and cleanups
This concludes the main part of the system call rework for 64-bit
time_t, which has spread over most of year 2018, the last six system
calls being
- ppoll
- pselect6
- io_pgetevents
- recvmmsg
- futex
- rt_sigtimedwait
As before, nothing changes for 64-bit architectures, while 32-bit
architectures gain another entry point that differs only in the layout
of the timespec structure. Hopefully in the next release we can wire
up all 22 of those system calls on all 32-bit architectures, which
gives us a baseline version for glibc to start using them.
This does not include the clock_adjtime, getrusage/waitid, and
getitimer/setitimer system calls. I still plan to have new versions of
those as well, but they are not required for correct operation of the
C library since they can be emulated using the old 32-bit time_t based
system calls.
Aside from the system calls, there are also a few cleanups here,
removing old kernel internal interfaces that have become unused after
all references got removed. The arch/sh cleanups are part of this,
there were posted several times over the past year without a reaction
from the maintainers, while the corresponding changes made it into all
other architectures"
* tag 'y2038-for-4.21' of ssh://gitolite.kernel.org:/pub/scm/linux/kernel/git/arnd/playground:
timekeeping: remove obsolete time accessors
vfs: replace current_kernel_time64 with ktime equivalent
timekeeping: remove timespec_add/timespec_del
timekeeping: remove unused {read,update}_persistent_clock
sh: remove board_time_init() callback
sh: remove unused rtc_sh_get/set_time infrastructure
sh: sh03: rtc: push down rtc class ops into driver
sh: dreamcast: rtc: push down rtc class ops into driver
y2038: signal: Add compat_sys_rt_sigtimedwait_time64
y2038: signal: Add sys_rt_sigtimedwait_time32
y2038: socket: Add compat_sys_recvmmsg_time64
y2038: futex: Add support for __kernel_timespec
y2038: futex: Move compat implementation into futex.c
io_pgetevents: use __kernel_timespec
pselect6: use __kernel_timespec
ppoll: use __kernel_timespec
signal: Add restore_user_sigmask()
signal: Add set_user_sigmask()
Pull timer updates from Thomas Gleixner:
"The timer department delivers the following christmas presents:
Core code:
- Use proper seqcount initializer to make lockdep happy
- SPDX annotations and cleanup of license boilerplates
- Use DEFINE_SHOW_ATTRIBUTE() instead of open coding it
- Minor cleanups
Driver code:
- Add the sched_clock for the arc timer (Alexey Brodkin)
- Change the file timer names for riscv, rockchip, tegra20, sun4i and
meson6 (Daniel Lezcano)
- Add the DT bindings for r8a7796, r8a77470 and r8a774a1 (Biju Das)
- Remove the early platform driver registration for timer-ti-dm
(Bartosz Golaszewski)
- Provide the sched_clock for the riscv timer (Anup Patel)
- Add support for ARM64 for the imx-gpt and convert the imx-tpm to
the timer-of API (Anson Huang)
- Remove useless irq protection for the imx-gpt (Clément Péron)
- Remove a duplicate function name for the vt8500 (Dan Carpenter)
- Remove obsolete inclusion of <asm/smp_twd.h> for the tegra20 (Geert
Uytterhoeven)
- Demote the prcmu and the custom sched_clock for the dbx500 and the
ux500 (Linus Walleij)
- Add a new timer clock for the RDA8810PL (Manivannan Sadhasivam)
- Rename the macro to stick to the register name and add the delay
timer (Martin Blumenstingl)
- Switch the bcm2835 to the SPDX identifier (Stefan Wahren)
- Fix the interrupt register access on the fttmr010 (Tao Ren)
- Add missing of_node_put in the initialization path on the
integrator-ap (Yangtao Li)"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (39 commits)
dt-bindings: timer: Document RDA8810PL SoC timer
clocksource/drivers/rda: Add clock driver for RDA8810PL SoC
clocksource/drivers/meson6: Change name meson6_timer timer-meson6
clocksource/drivers/sun4i: Change name sun4i_timer to timer-sun4i
clocksource/drivers/tegra20: Change name tegra20_timer to timer-tegra20
clocksource/drivers/rockchip: Change name rockchip_timer to timer-rockchip
clocksource/drivers/riscv: Change name riscv_timer to timer-riscv
clocksource/drivers/riscv_timer: Provide the sched_clock
clocksource/drivers/timer-imx-tpm: Specify clock name for timer-of
clocksource/drivers/fttmr010: Fix invalid interrupt register access
clocksource/drivers/integrator-ap: Add missing of_node_put()
clocksource/drivers/bcm2835: Switch to SPDX identifier
dt-bindings: timer: renesas, cmt: Document r8a774a1 CMT support
clocksource/drivers/timer-imx-tpm: Convert the driver to timer-of
clocksource/drivers/arc_timer: Utilize generic sched_clock
dt-bindings: timer: renesas, cmt: Document r8a77470 CMT support
dt-bindings: timer: renesas, cmt: Document r8a7796 CMT support
clocksource/drivers/imx-gpt: Remove unnecessary irq protection
clocksource/drivers/imx-gpt: Add support for ARM64
clocksource/drivers/meson6_timer: Implement the ARM delay timer
The last users were removed a while ago since everyone moved to ktime_t,
so we can remove the two unused interfaces for old timespec structures.
With those two gone, set_normalized_timespec() is also unused, so
remove that as well.
Acked-by: John Stultz <john.stultz@linaro.org>
After arch/sh has removed the last reference to these functions,
we can remove them completely and just rely on the 64-bit time_t
based versions. This cleans up a rather ugly use of __weak
functions.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Cc: <john.stultz@linaro.org>
Cc: <sboyd@kernel.org>
Link: https://lkml.kernel.org/r/20181209062225.4344-1-yuehaibing@huawei.com
The signal delivery path of posix-timers can try to rearm the timer even if
the interval is zero. That's handled for the common case (hrtimer) but not
for alarm timers. In that case the forwarding function raises a division by
zero exception.
The handling for hrtimer based posix timers is wrong because it marks the
timer as active despite the fact that it is stopped.
Move the check from common_hrtimer_rearm() to posixtimer_rearm() to cure
both issues.
Reported-by: syzbot+9d38bedac9cc77b8ad5e@syzkaller.appspotmail.com
Cc: sboyd@kernel.org
Cc: syzkaller-bugs@googlegroups.com
Link: http://lkml.kernel.org/r/alpine.DEB.2.21.1812171328050.1880@nanos.tec.linutronix.de
Use DEFINE_SHOW_ATTRIBUTE macro to simplify the code.
Signed-off-by: Yangtao Li <tiny.windzz@gmail.com>
Cc: john.stultz@linaro.org
Link: https://lkml.kernel.org/r/20181211163744.22133-1-tiny.windzz@gmail.com
tk_core.seq is initialized open coded, but that misses to initialize the
lockdep map when lockdep is enabled. Lockdep splats involving tk_core seq
consequently lack a name and are hard to read.
Use the proper initializer which takes care of the lockdep map
initialization.
[ tglx: Massaged changelog ]
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Cc: peterz@infradead.org
Cc: tj@kernel.org
Cc: johannes.berg@intel.com
Link: https://lkml.kernel.org/r/20181128234325.110011-12-bvanassche@acm.org
The SPDX identifier defines the license of the file already. No need for
the boilerplate.
Remove also the completely outdated Montavista snail mail address.
Acked-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Corey Minyard <cminyard@mvista.com>
Cc: Kate Stewart <kstewart@linuxfoundation.org>
Cc: Philippe Ombredanne <pombredanne@nexb.com>
Cc: Peter Anvin <hpa@zytor.com>
Cc: Russell King <rmk+kernel@armlinux.org.uk>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
Cc: David Riley <davidriley@chromium.org>
Cc: Colin Cross <ccross@android.com>
Cc: Mark Brown <broonie@kernel.org>
Link: https://lkml.kernel.org/r/20181031182253.479792883@linutronix.de
the boilerplate.
Acked-by: Richard Cochran <richardcochran@gmail.com>
Acked-by: Manfred Rudigier <manfred.rudigier@omicronenergy.com>
Link: https://lkml.kernel.org/r/20181031182253.385909804@linutronix.de
the boilerplate.
Link: https://lkml.kernel.org/r/20181031182253.300140921@linutronix.de
the boilerplate.
Acked-by: Nicolas Pitre <nico@linaro.org>
Link: https://lkml.kernel.org/r/20181031182253.215825217@linutronix.de
The SPDX identifier defines the license of the files already. No need for
the boilerplates.
Acked-by: Paul E. McKenney <paulmck@linux.ibm.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: https://lkml.kernel.org/r/20181031182253.132458951@linutronix.de
The SPDX identifier is enough. Remove the license boilerplate.
Link: https://lkml.kernel.org/r/20181031182253.047449481@linutronix.de
"For licencing details see kernel-base/COPYING" and similar license
references have no value over the SPDX identifier. Remove them.
Link: https://lkml.kernel.org/r/20181031182252.963632760@linutronix.de
Update the time(r) core files files with the correct SPDX license
identifier based on the license text in the file itself. The SPDX
identifier is a legally binding shorthand, which can be used instead of the
full boiler plate text.
This work is based on a script and data from Philippe Ombredanne, Kate
Stewart and myself. The data has been created with two independent license
scanners and manual inspection.
The following files do not contain any direct license information and have
been omitted from the big initial SPDX changes:
timeconst.bc: The .bc files were not touched
time.c, timer.c, timekeeping.c: Licence was deduced from EXPORT_SYMBOL_GPL
As those files do not contain direct license references they fall under the
project license, i.e. GPL V2 only.
Link: https://lkml.kernel.org/r/20181031182252.879109557@linutronix.de
Remove the pointless filenames in the top level comments. They have no
value at all and just occupy space. While at it tidy up some of the
comments and remove a stale one.
Link: https://lkml.kernel.org/r/20181031182252.794898238@linutronix.de
check_dl_overrun() is used to send a SIGXCPU to users that asked to be
informed when a SCHED_DEADLINE runtime overruns occur.
The function is called by check_thread_timers() already, so the call in
check_process_timers() is redundant/wrong (even though harmless).
Remove it.
Fixes: 34be39305a77 ("sched/deadline: Implement "runtime overrun signal" support")
Signed-off-by: Juri Lelli <juri.lelli@redhat.com>
Reviewed-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Cc: linux-rt-users@vger.kernel.org
Cc: mtk.manpages@gmail.com
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Cc: Luca Abeni <luca.abeni@santannapisa.it>
Cc: Claudio Scordino <claudio@evidence.eu.com>
Link: https://lkml.kernel.org/r/20181107111032.32291-1-juri.lelli@redhat.com
WARN_ON() and WARN_ON_ONCE() already contains an unlikely(), so it's not
necessary to use unlikely.
Link: https://lkml.kernel.org/r/20181104023104.2572-1-tiny.windzz@gmail.com
Now that in_compat_syscall() is consistent on all architectures and does
not longer report true on native i686, the workarounds (ifdeffery and
helpers) can be removed.
Signed-off-by: Dmitry Safonov <dima@arista.com>
Cc: Dmitry Safonov <0x7f454c46@gmail.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Andy Lutomirsky <luto@kernel.org>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: linux-efi@vger.kernel.org
Cc: netdev@vger.kernel.org
Link: https://lkml.kernel.org/r/20181012134253.23266-3-dima@arista.com
Pull timekeeping updates from Thomas Gleixner:
"The timers and timekeeping departement provides:
- Another large y2038 update with further preparations for providing
the y2038 safe timespecs closer to the syscalls.
- An overhaul of the SHCMT clocksource driver
- SPDX license identifier updates
- Small cleanups and fixes all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits)
tick/sched : Remove redundant cpu_online() check
clocksource/drivers/dw_apb: Add reset control
clocksource: Remove obsolete CLOCKSOURCE_OF_DECLARE
clocksource/drivers: Unify the names to timer-* format
clocksource/drivers/sh_cmt: Add R-Car gen3 support
dt-bindings: timer: renesas: cmt: document R-Car gen3 support
clocksource/drivers/sh_cmt: Properly line-wrap sh_cmt_of_table[] initializer
clocksource/drivers/sh_cmt: Fix clocksource width for 32-bit machines
clocksource/drivers/sh_cmt: Fixup for 64-bit machines
clocksource/drivers/sh_tmu: Convert to SPDX identifiers
clocksource/drivers/sh_mtu2: Convert to SPDX identifiers
clocksource/drivers/sh_cmt: Convert to SPDX identifiers
clocksource/drivers/renesas-ostm: Convert to SPDX identifiers
clocksource: Convert to using %pOFn instead of device_node.name
tick/broadcast: Remove redundant check
RISC-V: Request newstat syscalls
y2038: signal: Change rt_sigtimedwait to use __kernel_timespec
y2038: socket: Change recvmmsg to use __kernel_timespec
y2038: sched: Change sched_rr_get_interval to use __kernel_timespec
y2038: utimes: Rework #ifdef guards for compat syscalls
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull siginfo updates from Eric Biederman:
"I have been slowly sorting out siginfo and this is the culmination of
that work.
The primary result is in several ways the signal infrastructure has
been made less error prone. The code has been updated so that manually
specifying SEND_SIG_FORCED is never necessary. The conversion to the
new siginfo sending functions is now complete, which makes it
difficult to send a signal without filling in the proper siginfo
fields.
At the tail end of the patchset comes the optimization of decreasing
the size of struct siginfo in the kernel from 128 bytes to about 48
bytes on 64bit. The fundamental observation that enables this is by
definition none of the known ways to use struct siginfo uses the extra
bytes.
This comes at the cost of a small user space observable difference.
For the rare case of siginfo being injected into the kernel only what
can be copied into kernel_siginfo is delivered to the destination, the
rest of the bytes are set to 0. For cases where the signal and the
si_code are known this is safe, because we know those bytes are not
used. For cases where the signal and si_code combination is unknown
the bits that won't fit into struct kernel_siginfo are tested to
verify they are zero, and the send fails if they are not.
I made an extensive search through userspace code and I could not find
anything that would break because of the above change. If it turns out
I did break something it will take just the revert of a single change
to restore kernel_siginfo to the same size as userspace siginfo.
Testing did reveal dependencies on preferring the signo passed to
sigqueueinfo over si->signo, so bit the bullet and added the
complexity necessary to handle that case.
Testing also revealed bad things can happen if a negative signal
number is passed into the system calls. Something no sane application
will do but something a malicious program or a fuzzer might do. So I
have fixed the code that performs the bounds checks to ensure negative
signal numbers are handled"
* 'siginfo-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (80 commits)
signal: Guard against negative signal numbers in copy_siginfo_from_user32
signal: In sigqueueinfo prefer sig not si_signo
signal: Use a smaller struct siginfo in the kernel
signal: Distinguish between kernel_siginfo and siginfo
signal: Introduce copy_siginfo_from_user and use it's return value
signal: Remove the need for __ARCH_SI_PREABLE_SIZE and SI_PAD_SIZE
signal: Fail sigqueueinfo if si_signo != sig
signal/sparc: Move EMT_TAGOVF into the generic siginfo.h
signal/unicore32: Use force_sig_fault where appropriate
signal/unicore32: Generate siginfo in ucs32_notify_die
signal/unicore32: Use send_sig_fault where appropriate
signal/arc: Use force_sig_fault where appropriate
signal/arc: Push siginfo generation into unhandled_exception
signal/ia64: Use force_sig_fault where appropriate
signal/ia64: Use the force_sig(SIGSEGV,...) in ia64_rt_sigreturn
signal/ia64: Use the generic force_sigsegv in setup_frame
signal/arm/kvm: Use send_sig_mceerr
signal/arm: Use send_sig_fault where appropriate
signal/arm: Use force_sig_fault where appropriate
can_stop_idle_tick() checks cpu_online() twice. The first check leaves the
function when the CPU is not online, so the second check it
redundant. Remove it.
Signed-off-by: Peng Hao <peng.hao2@zte.com.cn>
Cc: fweisbec@gmail.com
Link: https://lkml.kernel.org/r/1539099815-2943-1-git-send-email-penghao122@sina.com.cn
Architectures have extra archdata in the clocksource, e.g. for VDSO
support. There are no sanity checks or general initializations for this
available. Add support for that.
Acked-by: Andy Lutomirski <luto@kernel.org>
Cc: Matt Rickard <matt@softrans.com.au>
Cc: Florian Weimer <fweimer@redhat.com>
Cc: "K. Y. Srinivasan" <kys@microsoft.com>
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: devel@linuxdriverproject.org
Cc: virtualization@lists.linux-foundation.org
Cc: Juergen Gross <jgross@suse.com>
Link: https://lkml.kernel.org/r/20180917130706.973042587@linutronix.de
Linus recently observed that if we did not worry about the padding
member in struct siginfo it is only about 48 bytes, and 48 bytes is
much nicer than 128 bytes for allocating on the stack and copying
around in the kernel.
The obvious thing of only adding the padding when userspace is
including siginfo.h won't work as there are sigframe definitions in
the kernel that embed struct siginfo.
So split siginfo in two; kernel_siginfo and siginfo. Keeping the
traditional name for the userspace definition. While the version that
is used internally to the kernel and ultimately will not be padded to
128 bytes is called kernel_siginfo.
The definition of struct kernel_siginfo I have put in include/signal_types.h
A set of buildtime checks has been added to verify the two structures have
the same field offsets.
To make it easy to verify the change kernel_siginfo retains the same
size as siginfo. The reduction in size comes in a following change.
tick_device_is_functional() is called early in tick_broadcast_control(), so
no need to call it again later.
Link: https://lkml.kernel.org/r/1538150608-2599-1-git-send-email-penghao122@sina.com.cn
I turns out that the silly spawn kthread from worker was actually needed.
clocksource_watchdog_kthread() cannot be called directly from
clocksource_watchdog_work(), because clocksource_select() calls
timekeeping_notify() which uses stop_machine(). One cannot use
stop_machine() from a workqueue() due lock inversions wrt CPU hotplug.
Revert the patch but add a comment that explain why we jump through such
apparently silly hoops.
Fixes: 7197e77abcb6 ("clocksource: Remove kthread")
Reported-by: Siegfried Metz <frame@mailbox.org>
Tested-by: Niklas Cassel <niklas.cassel@linaro.org>
Tested-by: Kevin Shanahan <kevin@shanahan.id.au>
Tested-by: viktor_jaegerskuepper@freenet.de
Tested-by: Siegfried Metz <frame@mailbox.org>
Cc: rafael.j.wysocki@intel.com
Cc: len.brown@intel.com
Cc: diego.viola@gmail.com
Cc: rui.zhang@intel.com
Cc: bjorn.andersson@linaro.org
Link: https://lkml.kernel.org/r/20180905084158.GR24124@hirez.programming.kicks-ass.net
The kbuild test robot reports two new warnings with the previous
patch:
kernel/time/time.c:866:5: sparse: symbol '__get_old_timespec32' was not declared. Should it be static?
kernel/time/time.c:882:5: sparse: symbol '__put_old_timespec32' was not declared. Should it be static?
These are actually older bugs, but came up now after the
symbol got renamed. Fortunately, commit afef05cf238c ("time:
Enable get/put_compat_itimerspec64 always") makes the two functions
(__compat_get_timespec64/__compat_get_timespec64) local to time.c already,
so we can mark them as 'static'.
Fixes: ee16c8f415e4 ("y2038: Globally rename compat_time to old_time32")
Signed-off-by: kbuild test robot <fengguang.wu@intel.com>
[arnd: added changelog text]
Christoph Hellwig suggested a slightly different path for handling
backwards compatibility with the 32-bit time_t based system calls:
Rather than simply reusing the compat_sys_* entry points on 32-bit
architectures unchanged, we get rid of those entry points and the
compat_time types by renaming them to something that makes more sense
on 32-bit architectures (which don't have a compat mode otherwise),
and then share the entry points under the new name with the 64-bit
architectures that use them for implementing the compatibility.
The following types and interfaces are renamed here, and moved
from linux/compat_time.h to linux/time32.h:
old new
compat_time_t old_time32_t
struct compat_timeval struct old_timeval32
struct compat_timespec struct old_timespec32
struct compat_itimerspec struct old_itimerspec32
ns_to_compat_timeval() ns_to_old_timeval32()
get_compat_itimerspec64() get_old_itimerspec32()
put_compat_itimerspec64() put_old_itimerspec32()
compat_get_timespec64() get_old_timespec32()
compat_put_timespec64() put_old_timespec32()
As we already have aliases in place, this patch addresses only the
instances that are relevant to the system call interface in particular,
not those that occur in device drivers and other modules. Those
will get handled separately, while providing the 64-bit version
of the respective interfaces.
I'm not renaming the timex, rusage and itimerval structures, as we are
still debating what the new interface will look like, and whether we
will need a replacement at all.
This also doesn't change the names of the syscall entry points, which can
be done more easily when we actually switch over the 32-bit architectures
to use them, at that point we need to change COMPAT_SYSCALL_DEFINEx to
SYSCALL_DEFINEx with a new name, e.g. with a _time32 suffix.
Suggested-by: Christoph Hellwig <hch@infradead.org>
Link: https://lore.kernel.org/lkml/20180705222110.GA5698@infradead.org/
get_seconds() and do_gettimeofday() are only used by a few modules now any
more (waiting for the respective patches to get accepted), and they are
among the last holdouts of code that is not y2038 safe in the core kernel.
Move the implementation into the timekeeping32.h header to clean up
the core kernel and isolate the old interfaces further.
After many small patches, at least some of the deprecated interfaces
have no remaining users any more and can be removed:
current_kernel_time
do_settimeofday
get_monotonic_boottime
get_monotonic_boottime64
get_monotonic_coarse
get_monotonic_coarse64
getrawmonotonic64
ktime_get_real_ts
timekeeping_clocktai
timespec_trunc
timespec_valid_strict
time_to_tm
For many of the remaining time functions, we are missing one or
two patches that failed to make it into 4.19, they will be removed
in the following merge window.
The replacement functions for the removed interfaces are documented in
Documentation/core-api/timekeeping.rst.
Pull core signal handling updates from Eric Biederman:
"It was observed that a periodic timer in combination with a
sufficiently expensive fork could prevent fork from every completing.
This contains the changes to remove the need for that restart.
This set of changes is split into several parts:
- The first part makes PIDTYPE_TGID a proper pid type instead
something only for very special cases. The part starts using
PIDTYPE_TGID enough so that in __send_signal where signals are
actually delivered we know if the signal is being sent to a a group
of processes or just a single process.
- With that prep work out of the way the logic in fork is modified so
that fork logically makes signals received while it is running
appear to be received after the fork completes"
* 'siginfo-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (22 commits)
signal: Don't send signals to tasks that don't exist
signal: Don't restart fork when signals come in.
fork: Have new threads join on-going signal group stops
fork: Skip setting TIF_SIGPENDING in ptrace_init_task
signal: Add calculate_sigpending()
fork: Unconditionally exit if a fatal signal is pending
fork: Move and describe why the code examines PIDNS_ADDING
signal: Push pid type down into complete_signal.
signal: Push pid type down into __send_signal
signal: Push pid type down into send_signal
signal: Pass pid type into do_send_sig_info
signal: Pass pid type into send_sigio_to_task & send_sigurg_to_task
signal: Pass pid type into group_send_sig_info
signal: Pass pid and pid type into send_sigqueue
posix-timers: Noralize good_sigevent
signal: Use PIDTYPE_TGID to clearly store where file signals will be sent
pid: Implement PIDTYPE_TGID
pids: Move the pgrp and session pid pointers from task_struct to signal_struct
kvm: Don't open code task_pid in kvm_vcpu_ioctl
pids: Compute task_tgid using signal->leader_pid
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux
Pull parisc updates from Helge Deller:
- parisc now uses the generic dma_noncoherent_ops implementation
(Christoph Hellwig)
- further memory barrier and spinlock improvements (John David Anglin)
- prepare removal of current_text_addr() functions (Nick Desaulniers)
- improve kernel stack unwinding on parisc (me)
- drop ENOTSUP which was defined on parisc only (me)
* 'parisc-4.19-1' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: Fix and improve kernel stack unwinding
parisc: Remove unnecessary barriers from spinlock.h
parisc: Remove ordered stores from syscall.S
parisc: prefer _THIS_IP_ and _RET_IP_ statement expressions
parisc: Add HAVE_REGS_AND_STACK_ACCESS_API feature
parisc: Drop architecture-specific ENOTSUP define
parisc: use generic dma_noncoherent_ops
parisc: always use flush_kernel_dcache_range for DMA cache maintainance
parisc: merge pcx_dma_ops and pcxl_dma_ops
Pull x86 timer updates from Thomas Gleixner:
"Early TSC based time stamping to allow better boot time analysis.
This comes with a general cleanup of the TSC calibration code which
grew warts and duct taping over the years and removes 250 lines of
code. Initiated and mostly implemented by Pavel with help from various
folks"
* 'x86-timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (37 commits)
x86/kvmclock: Mark kvm_get_preset_lpj() as __init
x86/tsc: Consolidate init code
sched/clock: Disable interrupts when calling generic_sched_clock_init()
timekeeping: Prevent false warning when persistent clock is not available
sched/clock: Close a hole in sched_clock_init()
x86/tsc: Make use of tsc_calibrate_cpu_early()
x86/tsc: Split native_calibrate_cpu() into early and late parts
sched/clock: Use static key for sched_clock_running
sched/clock: Enable sched clock early
sched/clock: Move sched clock initialization and merge with generic clock
x86/tsc: Use TSC as sched clock early
x86/tsc: Initialize cyc2ns when tsc frequency is determined
x86/tsc: Calibrate tsc only once
ARM/time: Remove read_boot_clock64()
s390/time: Remove read_boot_clock64()
timekeeping: Default boot time offset to local_clock()
timekeeping: Replace read_boot_clock64() with read_persistent_wall_and_boot_offset()
s390/time: Add read_persistent_wall_and_boot_offset()
x86/xen/time: Output xen sched_clock time from 0
x86/xen/time: Initialize pv xen time in init_hypervisor_platform()
"The timers departement more or less proudly presents:
- More Y2038 timekeeping work mostly in the core code. The work is
slowly, but steadily targeting the actuall syscalls.
- Enhanced timekeeping suspend/resume support by utilizing
clocksources which do not stop during suspend, but are otherwise
not the main timekeeping clocksources.
- Make NTP adjustmets more accurate and immediate when the frequency
is set directly and not incrementally.
- Sanitize the overrung handing of posix timers
- A new timer driver for Mediatek SoCs
- The usual pile of fixes and updates all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (32 commits)
clockevents: Warn if cpu_all_mask is used as cpumask
tick/broadcast-hrtimer: Use cpu_possible_mask for ce_broadcast_hrtimer
clocksource/drivers/arm_arch_timer: Fix bogus cpu_all_mask usage
clocksource: ti-32k: Remove CLOCK_SOURCE_SUSPEND_NONSTOP flag
timers: Clear timer_base::must_forward_clk with timer_base::lock held
clocksource/drivers/sprd: Register one always-on timer to compensate suspend time
clocksource/drivers/timer-mediatek: Add support for system timer
clocksource/drivers/timer-mediatek: Convert the driver to timer-of
clocksource/drivers/timer-mediatek: Use specific prefix for GPT
clocksource/drivers/timer-mediatek: Rename mtk_timer to timer-mediatek
clocksource/drivers/timer-mediatek: Add system timer bindings
clocksource/drivers: Set clockevent device cpumask to cpu_possible_mask
time: Introduce one suspend clocksource to compensate the suspend time
time: Fix extra sleeptime injection when suspend fails
timekeeping/ntp: Constify some function arguments
ntp: Use kstrtos64 for s64 variable
ntp: Remove redundant arguments
timer: Fix coding style
ktime: Provide typesafe ktime_to_ns()
hrtimer: Improve kernel message printing
parisc is the only Linux architecture which has defined a value for ENOTSUP.
All other architectures #define ENOTSUP as EOPNOTSUPP in their libc headers.
Having an own value for ENOTSUP which is different than EOPNOTSUPP often gives
problems with userspace programs which expect both to be the same. One such
example is a build error in the libuv package, as can be seen in
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=900237.
Since we dropped HP-UX support, there is no real benefit in keeping an own
value for ENOTSUP. This patch drops the parisc value for ENOTSUP from the
kernel sources. glibc needs no patch, it reuses the exported headers.
Signed-off-by: Helge Deller <deller@gmx.de>
Using cpu_all_mask in clockevents cpumask may result in issues while
comparing multiple clockevent devices to choose the preferred one.
On one of the platforms with 2 system (i.e. non per-CPU) timers with
different ratings, having cpu_all_mask for one of the device resulted in a
boot hang due to a endless loop in clockevents_notify_released() as both
were clocksources were selected as preferred.
In order to prevent such issues in the future, warn if any clockevent
driver sets cpu_all_mask as it's cpumask and just override it to use
cpu_possible_mask. All the existing occurrences of cpu_all_mask are already
replaced with cpu_possible_mask.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Link: https://lkml.kernel.org/r/1531308264-24220-3-git-send-email-sudeep.holla@arm.com
This is the last instance of cpu_all_mask usage in the core framework.
Replace it with cpu_possible_mask like all other instances in the
clockevent drivers. This makes it possible to add a warning in the core
clockevents_register_device on usage of cpu_all_mask from any clockevent
drivers in the future.
Link: https://lkml.kernel.org/r/1531308264-24220-2-git-send-email-sudeep.holla@arm.com
timer_base::must_forward_clock is indicating that the base clock might be
stale due to a long idle sleep.
The forwarding of the base clock takes place in the timer softirq or when a
timer is enqueued to a base which is idle. If the enqueue of timer to an
idle base happens from a remote CPU, then the following race can happen:
CPU0 CPU1
run_timer_softirq mod_timer
base = lock_timer_base(timer);
base->must_forward_clk = false
if (base->must_forward_clk)
forward(base); -> skipped
enqueue_timer(base, timer, idx);
-> idx is calculated high due to
stale base
unlock_timer_base(timer);
forward(base);
The root cause is that timer_base::must_forward_clk is cleared outside the
timer_base::lock held region, so the remote queuing CPU observes it as
cleared, but the base clock is still stale. This can cause large
granularity values for timers, i.e. the accuracy of the expiry time
suffers.
Prevent this by clearing the flag with timer_base::lock held, so that the
forwarding takes place before the cleared flag is observable by a remote
CPU.
Signed-off-by: Gaurav Kohli <gkohli@codeaurora.org>
Cc: linux-arm-msm@vger.kernel.org
Link: https://lkml.kernel.org/r/1533199863-22748-1-git-send-email-gkohli@codeaurora.org
local_timer_softirq_pending() checks whether the timer softirq is
pending with: local_softirq_pending() & TIMER_SOFTIRQ.
This is wrong because TIMER_SOFTIRQ is the softirq number and not a
bitmask. So the test checks for the wrong bit.
Use BIT(TIMER_SOFTIRQ) instead.
Fixes: 5d62c183f9e9 ("nohz: Prevent a timer interrupt storm in tick_nohz_stop_sched_tick()")
Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Acked-by: Frederic Weisbecker <frederic@kernel.org>
Cc: bigeasy@linutronix.de
Link: https://lkml.kernel.org/r/20180731161358.29472-1-anna-maria@linutronix.de
On arches with no persistent clock a message like this is printed during
boot:
[ 0.000000] Persistent clock returned invalid value
The value is not invalid: Zero means that no persistent clock is available
and the absence of persistent clock should be quietly accepted.
Fixes: 3eca993740b8 ("timekeeping: Replace read_boot_clock64() with read_persistent_wall_and_boot_offset()")
Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com>
Cc: steven.sistare@oracle.com
Cc: daniel.m.jordan@oracle.com
Link: https://lkml.kernel.org/r/20180725200018.23722-1-pasha.tatashin@oracle.com
Make the code more maintainable by performing more of the signal
related work in send_sigqueue.
A quick inspection of do_timer_create will show that this code path
does not lookup a thread group by a thread's pid. Making it safe
to find the task pointed to by it_pid with "pid_task(it_pid, type)";
This supports the changes needed in fork to tell if a signal was sent
to a single process or a group of processes.
Having the pid to task transition in signal.c will also make it easier
to sort out races with de_thread and and the thread group leader
exiting when it comes time to address that.
In good_sigevent directly compute the default return value as
"task_tgid(current)". This is exactly the same as
"task_pid(current->group_leader)" but written more clearly.
In the thread case first compute the thread's pid. Then veify that
attached to that pid is a thread of the current thread group.
This has the net effect of making the code a little clearer, and
making it obvious that posix timers never look up a process by a the
pid of a thread.
Everywhere except in the pid array we distinguish between a tasks pid and
a tasks tgid (thread group id). Even in the enumeration we want that
distinction sometimes so we have added __PIDTYPE_TGID. With leader_pid
we almost have an implementation of PIDTYPE_TGID in struct signal_struct.
Add PIDTYPE_TGID as a first class member of the pid_type enumeration and
into the pids array. Then remove the __PIDTYPE_TGID special case and the
leader_pid in signal_struct.
The net size increase is just an extra pointer added to struct pid and
an extra pair of pointers of an hlist_node added to task_struct.
The effect on code maintenance is the removal of a number of special
cases today and the potential to remove many more special cases as
PIDTYPE_TGID gets used to it's fullest. The long term potential
is allowing zombie thread group leaders to exit, which will remove
a lot more special cases in the code.
https://git.linaro.org/people/john.stultz/linux into timers/core
Pull the second set of timekeeping things for 4.19 from John Stultz
* NTP argument clenaups and constification from Ondrej Mosnacek
* Fix to avoid RTC injecting sleeptime when suspend fails from
Mukesh Ojha
* Broading suspsend-timing to include non-stop clocksources that
aren't currently used for timekeeping from Baolin Wang
On some hardware with multiple clocksources, we have coarse grained
clocksources that support the CLOCK_SOURCE_SUSPEND_NONSTOP flag, but
which are less than ideal for timekeeping whereas other clocksources
can be better candidates but halt on suspend.
Currently, the timekeeping core only supports timing suspend using
CLOCK_SOURCE_SUSPEND_NONSTOP clocksources if that clocksource is the
current clocksource for timekeeping.
As a result, some architectures try to implement read_persistent_clock64()
using those non-stop clocksources, but isn't really ideal, which will
introduce more duplicate code. To fix this, provide logic to allow a
registered SUSPEND_NONSTOP clocksource, which isn't the current
clocksource, to be used to calculate the suspend time.
Cc: Miroslav Lichvar <mlichvar@redhat.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Reviewed-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: Baolin Wang <baolin.wang@linaro.org>
[jstultz: minor tweaks to merge with previous resume changes]
Signed-off-by: John Stultz <john.stultz@linaro.org>
Currently, there exists a corner case assuming when there is
only one clocksource e.g RTC, and system failed to go to
suspend mode. While resume rtc_resume() injects the sleeptime
as timekeeping_rtc_skipresume() returned 'false' (default value
of sleeptime_injected) due to which we can see mismatch in
timestamps.
This issue can also come in a system where more than one
clocksource are present and very first suspend fails.
Success case:
{sleeptime_injected=false}
rtc_suspend() => timekeeping_suspend() => timekeeping_resume() =>
(sleeptime injected)
rtc_resume()
Failure case:
{failure in sleep path} {sleeptime_injected=false}
rtc_suspend() => rtc_resume()
{sleeptime injected again which was not required as the suspend failed}
Fix this by handling the boolean logic properly.
Originally-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: Mukesh Ojha <mojha@codeaurora.org>
