path: root/kernel/time/hrtimer.c
2017-10-21hrtimer: Catch invalid clockids againMarc Zyngier
[ Upstream commit 336a9cde10d641e70bac67d90ae91b3190c3edca ] commit 82e88ff1ea94 ("hrtimer: Revert CLOCK_MONOTONIC_RAW support") removed unfortunately a sanity check in the hrtimer code which was part of that MONOTONIC_RAW patch series. It would have caught the bogus usage of CLOCK_MONOTONIC_RAW in the wireless code. So bring it back. It is way too easy to take any random clockid and feed it to the hrtimer subsystem. At best, it gets mapped to a monotonic base, but it would be better to just catch illegal values as early as possible. Detect invalid clockids, map them to CLOCK_MONOTONIC and emit a warning. [ tglx: Replaced the BUG by a WARN and gracefully map to CLOCK_MONOTONIC ] Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Cc: Tomasz Nowicki <tn@semihalf.com> Cc: Christoffer Dall <christoffer.dall@linaro.org> Link: http://lkml.kernel.org/r/1452879670-16133-3-git-send-email-marc.zyngier@arm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-31time: Avoid undefined behaviour in ktime_add_safe()Vegard Nossum
I ran into this: ================================================================================ UBSAN: Undefined behaviour in kernel/time/hrtimer.c:310:16 signed integer overflow: 9223372036854775807 + 50000 cannot be represented in type 'long long int' CPU: 2 PID: 4798 Comm: trinity-c2 Not tainted 4.8.0-rc1+ #91 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.org 04/01/2014 0000000000000000 ffff88010ce6fb88 ffffffff82344740 0000000041b58ab3 ffffffff84f97a20 ffffffff82344694 ffff88010ce6fbb0 ffff88010ce6fb60 000000000000c350 ffff88010ce6f968 dffffc0000000000 ffffffff857bc320 Call Trace: [<ffffffff82344740>] dump_stack+0xac/0xfc [<ffffffff82344694>] ? _atomic_dec_and_lock+0xc4/0xc4 [<ffffffff8242df78>] ubsan_epilogue+0xd/0x8a [<ffffffff8242e6b4>] handle_overflow+0x202/0x23d [<ffffffff8242e4b2>] ? val_to_string.constprop.6+0x11e/0x11e [<ffffffff8236df71>] ? timerqueue_add+0x151/0x410 [<ffffffff81485c48>] ? hrtimer_start_range_ns+0x3b8/0x1380 [<ffffffff81795631>] ? memset+0x31/0x40 [<ffffffff8242e6fd>] __ubsan_handle_add_overflow+0xe/0x10 [<ffffffff81488ac9>] hrtimer_nanosleep+0x5d9/0x790 [<ffffffff814884f0>] ? hrtimer_init_sleeper+0x80/0x80 [<ffffffff813a9ffb>] ? __might_sleep+0x5b/0x260 [<ffffffff8148be10>] common_nsleep+0x20/0x30 [<ffffffff814906c7>] SyS_clock_nanosleep+0x197/0x210 [<ffffffff81490530>] ? SyS_clock_getres+0x150/0x150 [<ffffffff823c7113>] ? __this_cpu_preempt_check+0x13/0x20 [<ffffffff8162ef60>] ? __context_tracking_exit.part.3+0x30/0x1b0 [<ffffffff81490530>] ? SyS_clock_getres+0x150/0x150 [<ffffffff81007bd3>] do_syscall_64+0x1b3/0x4b0 [<ffffffff845f85aa>] entry_SYSCALL64_slow_path+0x25/0x25 ================================================================================ Add a new ktime_add_unsafe() helper which doesn't check for overflow, but doesn't throw a UBSAN warning when it does overflow either. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2016-08-31hrtimer: Spelling fixesPratyush Patel
Fix a minor spelling error. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Pratyush Patel <pratyushpatel.1995@gmail.com> [jstultz: Added commit message] Signed-off-by: John Stultz <john.stultz@linaro.org>
2016-07-15hrtimer: Convert to hotplug state machineThomas Gleixner
Split out the clockevents callbacks instead of piggybacking them on hrtimers. This gets rid of a POST_DEAD user. See commit: 54e88fad223c ("sched: Make sure timers have migrated before killing the migration_thread") We just move the callback state to the proper place in the state machine. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de> Reviewed-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160713153337.485419196@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-10hrtimer: Remove redundant #ifdef blockPratyush Patel
Only need CONFIG_NO_HZ_COMMON as this block is already in a CONFIG_SMP block. Signed-off-by: Pratyush Patel <pratyushpatel.1995@gmail.com> Link: http://lkml.kernel.org/r/20160301172849.GA18152@cyborg Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-05-31timer: Export destroy_hrtimer_on_stack()Guenter Roeck
hrtimer_init_on_stack() needs a matching call to destroy_hrtimer_on_stack(), so both need to be exported. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-19debugobjects: insulate non-fixup logic related to static obj from fixup ↵Du, Changbin
callbacks When activating a static object we need make sure that the object is tracked in the object tracker. If it is a non-static object then the activation is illegal. In previous implementation, each subsystem need take care of this in their fixup callbacks. Actually we can put it into debugobjects core. Thus we can save duplicated code, and have *pure* fixup callbacks. To achieve this, a new callback "is_static_object" is introduced to let the type specific code decide whether a object is static or not. If yes, we take it into object tracker, otherwise give warning and invoke fixup callback. This change has paassed debugobjects selftest, and I also do some test with all debugobjects supports enabled. At last, I have a concern about the fixups that can it change the object which is in incorrect state on fixup? Because the 'addr' may not point to any valid object if a non-static object is not tracked. Then Change such object can overwrite someone's memory and cause unexpected behaviour. For example, the timer_fixup_activate bind timer to function stub_timer. Link: http://lkml.kernel.org/r/1462576157-14539-1-git-send-email-changbin.du@intel.com [changbin.du@intel.com: improve code comments where invoke the new is_static_object callback] Link: http://lkml.kernel.org/r/1462777431-8171-1-git-send-email-changbin.du@intel.com Signed-off-by: Du, Changbin <changbin.du@intel.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tejun Heo <tj@kernel.org> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19timer: update debugobjects fixup callbacks return typeDu, Changbin
Update the return type to use bool instead of int, corresponding to cheange (debugobjects: make fixup functions return bool instead of int). Signed-off-by: Du, Changbin <changbin.du@intel.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Josh Triplett <josh@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tejun Heo <tj@kernel.org> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17param: convert some "on"/"off" users to strtoboolKees Cook
This changes several users of manual "on"/"off" parsing to use strtobool. Some side-effects: - these uses will now parse y/n/1/0 meaningfully too - the early_param uses will now bubble up parse errors Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Michael Ellerman <mpe@ellerman.id.au> Cc: Amitkumar Karwar <akarwar@marvell.com> Cc: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: Joe Perches <joe@perches.com> Cc: Kalle Valo <kvalo@codeaurora.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Nishant Sarmukadam <nishants@marvell.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Steve French <sfrench@samba.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-17timer: convert timer_slack_ns from unsigned long to u64John Stultz
This patchset introduces a /proc/<pid>/timerslack_ns interface which would allow controlling processes to be able to set the timerslack value on other processes in order to save power by avoiding wakeups (Something Android currently does via out-of-tree patches). The first patch tries to fix the internal timer_slack_ns usage which was defined as a long, which limits the slack range to ~4 seconds on 32bit systems. It converts it to a u64, which provides the same basically unlimited slack (500 years) on both 32bit and 64bit machines. The second patch introduces the /proc/<pid>/timerslack_ns interface which allows the full 64bit slack range for a task to be read or set on both 32bit and 64bit machines. With these two patches, on a 32bit machine, after setting the slack on bash to 10 seconds: $ time sleep 1 real 0m10.747s user 0m0.001s sys 0m0.005s The first patch is a little ugly, since I had to chase the slack delta arguments through a number of functions converting them to u64s. Let me know if it makes sense to break that up more or not. Other than that things are fairly straightforward. This patch (of 2): The timer_slack_ns value in the task struct is currently a unsigned long. This means that on 32bit applications, the maximum slack is just over 4 seconds. However, on 64bit machines, its much much larger (~500 years). This disparity could make application development a little (as well as the default_slack) to a u64. This means both 32bit and 64bit systems have the same effective internal slack range. Now the existing ABI via PR_GET_TIMERSLACK and PR_SET_TIMERSLACK specify the interface as a unsigned long, so we preserve that limitation on 32bit systems, where SET_TIMERSLACK can only set the slack to a unsigned long value, and GET_TIMERSLACK will return ULONG_MAX if the slack is actually larger then what can be stored by an unsigned long. This patch also modifies hrtimer functions which specified the slack delta as a unsigned long. Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Oren Laadan <orenl@cellrox.com> Cc: Ruchi Kandoi <kandoiruchi@google.com> Cc: Rom Lemarchand <romlem@android.com> Cc: Kees Cook <keescook@chromium.org> Cc: Android Kernel Team <kernel-team@android.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-17hrtimer: Handle remaining time proper for TIME_LOW_RESThomas Gleixner
If CONFIG_TIME_LOW_RES is enabled we add a jiffie to the relative timeout to prevent short sleeps, but we do not account for that in interfaces which retrieve the remaining time. Helge observed that timerfd can return a remaining time larger than the relative timeout. That's not expected and breaks userland test programs. Store the information that the timer was armed relative and provide functions to adjust the remaining time. To avoid bloating the hrtimer struct make state a u8, which as a bonus results in better code on x86 at least. Reported-and-tested-by: Helge Deller <deller@gmx.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: John Stultz <john.stultz@linaro.org> Cc: linux-m68k@lists.linux-m68k.org Cc: dhowells@redhat.com Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/20160114164159.273328486@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-09-22time: Fix spelling in commentsZhen Lei
Signed-off-by: Zhen Lei <thunder.leizhen@huawei.com> Cc: Hanjun Guo <guohanjun@huawei.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tianhong Ding <dingtianhong@huawei.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Xinwei Hu <huxinwei@huawei.com> Cc: Xunlei Pang <pang.xunlei@linaro.org> Cc: Zefan Li <lizefan@huawei.com> Link: http://lkml.kernel.org/r/1440484973-13892-1-git-send-email-thunder.leizhen@huawei.com [ Fixed yet another typo in one of the sentences fixed. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-22hrtimer: Handle failure of tick_init_highres() gracefullyGuenter Roeck
Commit 75e3b37d0598 ("hrtimer: Drop return code of hrtimer_switch_to_hres()") drops the return code of hrtimer_switch_to_hres(). While doing so, it also drops the return statement itself on failure. This may cause a system hang. Seen when running arm:multi_v7_defconfig in qemu with devicetree file vexpress-v2p-ca9. Fixes: 75e3b37d0598 ("hrtimer: Drop return code of hrtimer_switch_to_hres()") Cc: Luiz Capitulino <lcapitulino@redhat.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Link: http://lkml.kernel.org/r/1440231047-16256-1-git-send-email-linux@roeck-us.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-08-18hrtimer: Unconfuse switch_hrtimer_base() a bitFrederic Weisbecker
The variable called "this_base" is confusing because its name suggests it's of "struct hrtimer_clock_base" type, along with "base" and "new_base" which doesn't help understanding this complicated function. Make its name clearer and fix the misleading comment while at it. [ tglx: Fixed the comment for real ] Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/1439907509-9553-3-git-send-email-fweisbec@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-08-18hrtimer: Simplify get_target_base() by returning current baseFrederic Weisbecker
Instead of fetching again the current cpu base, just take it from the parameter. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/1439907509-9553-2-git-send-email-fweisbec@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-08-17hrtimer: Drop return code of hrtimer_switch_to_hres()Luiz Capitulino
It's not checked by the caller. Signed-off-by: Luiz Capitulino <lcapitulino@redhat.com> Link: http://lkml.kernel.org/r/20150811164043.538241ef@redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-06-22Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner: "A rather largish update for everything time and timer related: - Cache footprint optimizations for both hrtimers and timer wheel - Lower the NOHZ impact on systems which have NOHZ or timer migration disabled at runtime. - Optimize run time overhead of hrtimer interrupt by making the clock offset updates smarter - hrtimer cleanups and removal of restrictions to tackle some problems in sched/perf - Some more leap second tweaks - Another round of changes addressing the 2038 problem - First step to change the internals of clock event devices by introducing the necessary infrastructure - Allow constant folding for usecs/msecs_to_jiffies() - The usual pile of clockevent/clocksource driver updates The hrtimer changes contain updates to sched, perf and x86 as they depend on them plus changes all over the tree to cleanup API changes and redundant code, which got copied all over the place. The y2038 changes touch s390 to remove the last non 2038 safe code related to boot/persistant clock" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (114 commits) clocksource: Increase dependencies of timer-stm32 to limit build wreckage timer: Minimize nohz off overhead timer: Reduce timer migration overhead if disabled timer: Stats: Simplify the flags handling timer: Replace timer base by a cpu index timer: Use hlist for the timer wheel hash buckets timer: Remove FIFO "guarantee" timers: Sanitize catchup_timer_jiffies() usage hrtimer: Allow hrtimer::function() to free the timer seqcount: Introduce raw_write_seqcount_barrier() seqcount: Rename write_seqcount_barrier() hrtimer: Fix hrtimer_is_queued() hole hrtimer: Remove HRTIMER_STATE_MIGRATE selftest: Timers: Avoid signal deadlock in leap-a-day timekeeping: Copy the shadow-timekeeper over the real timekeeper last clockevents: Check state instead of mode in suspend/resume path selftests: timers: Add leap-second timer edge testing to leap-a-day.c ntp: Do leapsecond adjustment in adjtimex read path time: Prevent early expiry of hrtimers[CLOCK_REALTIME] at the leap second edge ntp: Introduce and use SECS_PER_DAY macro instead of 86400 ...
2015-06-19timer: Minimize nohz off overheadThomas Gleixner
If nohz is disabled on the kernel command line the [hr]timer code still calls wake_up_nohz_cpu() and tick_nohz_full_cpu(), a pretty pointless exercise. Cache nohz_active in [hr]timer per cpu bases and avoid the overhead. Before: 48.10% hog [.] main 15.25% [kernel] [k] _raw_spin_lock_irqsave 9.76% [kernel] [k] _raw_spin_unlock_irqrestore 6.50% [kernel] [k] mod_timer 6.44% [kernel] [k] lock_timer_base.isra.38 3.87% [kernel] [k] detach_if_pending 3.80% [kernel] [k] del_timer 2.67% [kernel] [k] internal_add_timer 1.33% [kernel] [k] __internal_add_timer 0.73% [kernel] [k] timerfn 0.54% [kernel] [k] wake_up_nohz_cpu After: 48.73% hog [.] main 15.36% [kernel] [k] _raw_spin_lock_irqsave 9.77% [kernel] [k] _raw_spin_unlock_irqrestore 6.61% [kernel] [k] lock_timer_base.isra.38 6.42% [kernel] [k] mod_timer 3.90% [kernel] [k] detach_if_pending 3.76% [kernel] [k] del_timer 2.41% [kernel] [k] internal_add_timer 1.39% [kernel] [k] __internal_add_timer 0.76% [kernel] [k] timerfn We probably should have a cached value for nohz full in the per cpu bases as well to avoid the cpumask check. The base cache line is hot already, the cpumask not necessarily. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: John Stultz <john.stultz@linaro.org> Cc: Joonwoo Park <joonwoop@codeaurora.org> Cc: Wenbo Wang <wenbo.wang@memblaze.com> Link: http://lkml.kernel.org/r/20150526224512.207378134@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-06-19timer: Reduce timer migration overhead if disabledThomas Gleixner
Eric reported that the timer_migration sysctl is not really nice performance wise as it needs to check at every timer insertion whether the feature is enabled or not. Further the check does not live in the timer code, so we have an extra function call which checks an extra cache line to figure out that it is disabled. We can do better and store that information in the per cpu (hr)timer bases. I pondered to use a static key, but that's a nightmare to update from the nohz code and the timer base cache line is hot anyway when we select a timer base. The old logic enabled the timer migration unconditionally if CONFIG_NO_HZ was set even if nohz was disabled on the kernel command line. With this modification, we start off with migration disabled. The user visible sysctl is still set to enabled. If the kernel switches to NOHZ migration is enabled, if the user did not disable it via the sysctl prior to the switch. If nohz=off is on the kernel command line, migration stays disabled no matter what. Before: 47.76% hog [.] main 14.84% [kernel] [k] _raw_spin_lock_irqsave 9.55% [kernel] [k] _raw_spin_unlock_irqrestore 6.71% [kernel] [k] mod_timer 6.24% [kernel] [k] lock_timer_base.isra.38 3.76% [kernel] [k] detach_if_pending 3.71% [kernel] [k] del_timer 2.50% [kernel] [k] internal_add_timer 1.51% [kernel] [k] get_nohz_timer_target 1.28% [kernel] [k] __internal_add_timer 0.78% [kernel] [k] timerfn 0.48% [kernel] [k] wake_up_nohz_cpu After: 48.10% hog [.] main 15.25% [kernel] [k] _raw_spin_lock_irqsave 9.76% [kernel] [k] _raw_spin_unlock_irqrestore 6.50% [kernel] [k] mod_timer 6.44% [kernel] [k] lock_timer_base.isra.38 3.87% [kernel] [k] detach_if_pending 3.80% [kernel] [k] del_timer 2.67% [kernel] [k] internal_add_timer 1.33% [kernel] [k] __internal_add_timer 0.73% [kernel] [k] timerfn 0.54% [kernel] [k] wake_up_nohz_cpu Reported-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: John Stultz <john.stultz@linaro.org> Cc: Joonwoo Park <joonwoop@codeaurora.org> Cc: Wenbo Wang <wenbo.wang@memblaze.com> Link: http://lkml.kernel.org/r/20150526224512.127050787@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-06-19hrtimer: Allow hrtimer::function() to free the timerPeter Zijlstra
Currently an hrtimer callback function cannot free its own timer because __run_hrtimer() still needs to clear HRTIMER_STATE_CALLBACK after it. Freeing the timer would result in a clear use-after-free. Solve this by using a scheme similar to regular timers; track the current running timer in hrtimer_clock_base::running. Suggested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: ktkhai@parallels.com Cc: rostedt@goodmis.org Cc: juri.lelli@gmail.com Cc: pang.xunlei@linaro.org Cc: wanpeng.li@linux.intel.com Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: umgwanakikbuti@gmail.com Link: http://lkml.kernel.org/r/20150611124743.471563047@infradead.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-06-19hrtimer: Fix hrtimer_is_queued() holePeter Zijlstra
A queued hrtimer that gets restarted (hrtimer_start*() while hrtimer_is_queued()) will briefly appear as unqueued/inactive, even though the timer has always been active, we just moved it. Close this hole by preserving timer->state in hrtimer_start_range_ns()'s remove_hrtimer() call. Reported-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: ktkhai@parallels.com Cc: rostedt@goodmis.org Cc: juri.lelli@gmail.com Cc: pang.xunlei@linaro.org Cc: wanpeng.li@linux.intel.com Cc: umgwanakikbuti@gmail.com Link: http://lkml.kernel.org/r/20150611124743.175989138@infradead.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-06-19hrtimer: Remove HRTIMER_STATE_MIGRATEOleg Nesterov
I do not understand HRTIMER_STATE_MIGRATE. Unless I am totally confused it looks buggy and simply unneeded. migrate_hrtimer_list() sets it to keep hrtimer_active() == T, but this is not enough: this can fool, say, hrtimer_is_queued() in dequeue_signal(). Can't migrate_hrtimer_list() simply use HRTIMER_STATE_ENQUEUED? This fixes the race and we can kill STATE_MIGRATE. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: ktkhai@parallels.com Cc: rostedt@goodmis.org Cc: juri.lelli@gmail.com Cc: pang.xunlei@linaro.org Cc: wanpeng.li@linux.intel.com Cc: umgwanakikbuti@gmail.com Link: http://lkml.kernel.org/r/20150611124743.072387650@infradead.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-05-19clockevents: Stop unused clockevent devicesViresh Kumar
To avoid getting spurious interrupts on a tickless CPU, clockevent device can now be stopped by switching to ONESHOT_STOPPED state. The natural place for handling this transition is tick_program_event(). On 'expires == KTIME_MAX', we skip programming the event and so we need to fix such call sites as well, to always call tick_program_event() irrespective of the expires value. Once the clockevent device is required again, check if it was earlier put into ONESHOT_STOPPED state. If yes, switch its state to ONESHOT before programming its event. To make sure we haven't missed any corner case, add a WARN() for the case where we try to reprogram clockevent device while we aren't configured in ONESHOT_STOPPED state. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: linaro-kernel@lists.linaro.org Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Kevin Hilman <khilman@linaro.org> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/5146b07be7f0bc497e0ebae036590ec2fa73e540.1428031396.git.viresh.kumar@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-05-13ktime: Fix ktime_divns to do signed divisionJohn Stultz
It was noted that the 32bit implementation of ktime_divns() was doing unsigned division and didn't properly handle negative values. And when a ktime helper was changed to utilize ktime_divns, it caused a regression on some IR blasters. See the following bugzilla for details: https://bugzilla.redhat.com/show_bug.cgi?id=1200353 This patch fixes the problem in ktime_divns by checking and preserving the sign bit, and then reapplying it if appropriate after the division, it also changes the return type to a s64 to make it more obvious this is expected. Nicolas also pointed out that negative dividers would cause infinite loops on 32bit systems, negative dividers is unlikely for users of this function, but out of caution this patch adds checks for negative dividers for both 32-bit (BUG_ON) and 64-bit(WARN_ON) versions to make sure no such use cases creep in. [ tglx: Hand an u64 to do_div() to avoid the compiler warning ] Fixes: 166afb64511e 'ktime: Sanitize ktime_to_us/ms conversion' Reported-and-tested-by: Trevor Cordes <trevor@tecnopolis.ca> Signed-off-by: John Stultz <john.stultz@linaro.org> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Josh Boyer <jwboyer@redhat.com> Cc: One Thousand Gnomes <gnomes@lxorguk.ukuu.org.uk> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/1431118043-23452-1-git-send-email-john.stultz@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Allow concurrent hrtimer_start() for self restarting timersPeter Zijlstra
Because we drop cpu_base->lock around calling hrtimer::function, it is possible for hrtimer_start() to come in between and enqueue the timer. If hrtimer::function then returns HRTIMER_RESTART we'll hit the BUG_ON because HRTIMER_STATE_ENQUEUED will be set. Since the above is a perfectly valid scenario, remove the BUG_ON and make the enqueue_hrtimer() call conditional on the timer not being enqueued already. NOTE: in that concurrent scenario its entirely common for both sites to want to modify the hrtimer, since hrtimers don't provide serialization themselves be sure to provide some such that the hrtimer::function and the hrtimer_start() caller don't both try and fudge the expiration state at the same time. To that effect, add a WARN when someone tries to forward an already enqueued timer, the most common way to change the expiry of self restarting timers. Ideally we'd put the WARN in everything modifying the expiry but most of that is inlines and we don't need the bloat. Fixes: 2d44ae4d7135 ("hrtimer: clean up cpu->base locking tricks") Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Ben Segall <bsegall@google.com> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Paul Turner <pjt@google.com> Link: http://lkml.kernel.org/r/20150415113105.GT5029@twins.programming.kicks-ass.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Avoid locking in hrtimer_cancel() if timer not activeThomas Gleixner
We can do a lockless check for hrtimer_active before actually taking the lock in hrtimer[_try_to]_cancel. This is useful for hotpath users like nanosleep as they avoid the lock dance when the timer has expired. This is safe because active is true when the timer is enqueued or the callback is running. Taking the hrtimer base lock does not protect against concurrent hrtimer_start calls, the callsite has to do the proper serialization itself. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203503.580273114@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Remove hrtimer_start() return valueThomas Gleixner
No user was ever interested whether the timer was active or not when it was started. All abusers of the return value are gone, so get rid of it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203503.483556394@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Remove bogus hrtimer_active() checkThomas Gleixner
The check for hrtimer_active() after starting the timer is pointless. If the timer is inactive it has expired already and therefor the task pointer is already NULL. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203502.907149271@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Make hrtimer_start() a inline wrapperThomas Gleixner
No point for an extra export just to set the extra argument of hrtimer_start_range_ns() to 0. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203502.808544539@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Get rid of __hrtimer_start_range_ns()Thomas Gleixner
No more callers. Remove the leftovers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203502.707871492@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22tick: Nohz: Rework next timer evaluationThomas Gleixner
The evaluation of the next timer in the nohz code is based on jiffies while all the tick internals are nano seconds based. We have also to convert hrtimer nanoseconds to jiffies in the !highres case. That's just wrong and introduces interesting corner cases. Turn it around and convert the next timer wheel timer expiry and the rcu event to clock monotonic and base all calculations on nanoseconds. That identifies the case where no timer is pending clearly with an absolute expiry value of KTIME_MAX. Makes the code more readable and gets rid of the jiffies magic in the nohz code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Link: http://lkml.kernel.org/r/20150414203502.184198593@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Get rid of hrtimer softirqThomas Gleixner
hrtimer softirq is a leftover from the initial implementation and serves only the purpose to handle the enqueueing of already expired timers in the high resolution timer mode. We discussed whether we change the return value and force all start sites to handle that the timer is already expired, but that would be a Herculean task and I'm not sure whether its a good idea to enforce that handling on everyone. A simpler solution is to enforce a timer interrupt instead of raising and scheduling a softirq. Just use the existing infrastructure to do so and remove all the softirq leftovers. The HRTIMER softirq enum is now unused, but kept around because trace parsers rely on the existing numbering. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203501.840834708@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Keep pointer to first timer and simplify __remove_hrtimer()Thomas Gleixner
__remove_hrtimer() needs to evaluate the expiry time to figure out whether the timer which is removed is eventually the first expiring timer on the cpu. Keep a pointer to it, which is lazily updated, so we can avoid the evaluation dance and retrieve the information from there. Generates slightly better code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203501.752838019@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Make use of timerqueue_add/del return valuesThomas Gleixner
Use the return value instead of reevaluating the information. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203501.658152945@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Use cpu_base->active_base for hotpath iteratorsThomas Gleixner
The active_bases field is guaranteed to be in sync with the timerqueue of the corresponding clock base. So we can use it for iterating over the clock bases. This allows to break out early if no more active clock bases are available and avoids touching the cache lines of inactive clock bases. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Preeti U Murthy <preeti@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203501.322887675@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Use bits for various boolean indicatorsThomas Gleixner
No point in wasting 12 byte storage space. Generates better code as well. Text size reduction: x8664 -64, i386 -16, ARM -132, ARM64 -0, power64 -48 Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203501.227955358@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Make offset update smarterThomas Gleixner
On every tick/hrtimer interrupt we update the offset variables of the clock bases. That's silly because these offsets change very seldom. Add a sequence counter to the time keeping code which keeps track of the offset updates (clock_was_set()). Have a sequence cache in the hrtimer cpu bases to evaluate whether the offsets must be updated or not. This allows us later to avoid pointless cacheline pollution. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Preeti U Murthy <preeti@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: John Stultz <john.stultz@linaro.org> Link: http://lkml.kernel.org/r/20150414203501.132820245@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: John Stultz <john.stultz@linaro.org>
2015-04-22hrtimer: Get rid of softirq timeThomas Gleixner
The softirq time field in the clock bases is an optimization from the early days of hrtimers. It provides a coarse "jiffies" like time mostly for self rearming timers. But that comes with a price: - Larger code size - Extra storage space - Duplicated functions with really small differences The benefit of this is optimization is marginal for contemporary systems. Consolidate everything on the high resolution timer implementation. This makes further optimizations possible. Text size reduction: x8664 -95, i386 -356, ARM -148, ARM64 -40, power64 -16 Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203501.039977424@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Make the statistics fields smallerThomas Gleixner
No point in having usigned long for /proc/timer_list statistics. Make them unsigned int. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203500.959773467@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Get rid of hrtimer_get_res()Thomas Gleixner
The resolution is directly accessible now. So its simpler just to fill in the values of the timespec and be done with it. Text size reduction (combined with "hrtimer: Get rid of the resolution field in hrtimer_clock_base"): x8664 -61, i386 -221, ARM -60, power64 -48 Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203500.879888080@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Get rid of the resolution field in hrtimer_clock_baseThomas Gleixner
The field has no value because all clock bases have the same resolution. The resolution only changes when we switch to high resolution timer mode. We can evaluate that from a single static variable as well. In the !HIGHRES case its simply a constant. Export the variable, so we can simplify the usage sites. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Preeti U Murthy <preeti@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203500.645454122@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Update active_bases before calling hrtimer_force_reprogram()Viresh Kumar
'active_bases' indicates which clock-base have active timer. The intention of this bit field was to avoid evaluating inactive bases. It was introduced with the introduction of the BOOTTIME and TAI clock bases, but it was never brought into full use. We want to use it now, but in __remove_hrtimer() the update happens after the calling hrtimer_force_reprogram() which has to evaluate all clock bases for the next expiring timer. So in case the last timer of a clock base got removed we still see the active bit and therefor evaluate the clock base for no value. There are further optimizations possible when active_bases is updated in the right place. Move the update before the call to hrtimer_force_reprogram() [ tglx: Massaged changelog ] Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Reviewed-by: Preeti U Murthy <preeti@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: linaro-kernel@lists.linaro.org Link: http://lkml.kernel.org/r/20150414203500.533438642@linutronix.de Link: http://lkml.kernel.org/r/c7c8ebcd9ed88bb09d76059c745a1fafb48314e7.1428039899.git.viresh.kumar@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Document hrtimer_forward[_now]() properThomas Gleixner
Document the calling context conditions. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20150413210035.178751779@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-03clockevents: Cleanup dead cpu explicitelyThomas Gleixner
clockevents_notify() is a leftover from the early design of the clockevents facility. It's really not a notification mechanism, it's a multiplex call. We are way better off to have explicit calls instead of this monstrosity. Split out the cleanup function for a dead cpu and invoke it directly from the cpu down code. Make it conditional on CPU_HOTPLUG as well. Temporary change, will be refined in the future. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> [ Rebased, added clockevents_notify() removal ] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1735025.raBZdQHM3m@vostro.rjw.lan Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-04-03clockevents: Make tick handover explicitThomas Gleixner
clockevents_notify() is a leftover from the early design of the clockevents facility. It's really not a notification mechanism, it's a multiplex call. We are way better off to have explicit calls instead of this monstrosity. Split out the tick_handover call and invoke it explicitely from the hotplug code. Temporary solution will be cleaned up in later patches. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> [ Rebase ] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: John Stultz <john.stultz@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/1658173.RkEEILFiQZ@vostro.rjw.lan Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-04-01tick: Move core only declarations and functions to coreThomas Gleixner
No point to expose everything to the world. People just believe such functions can be abused for whatever purposes. Sigh. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> [ Rebased on top of 4.0-rc5 ] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Nicolas Pitre <nico@linaro.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/28017337.VbCUc39Gme@vostro.rjw.lan [ Merged to latest timers/core ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-02-12all arches, signal: move restart_block to struct task_structAndy Lutomirski
If an attacker can cause a controlled kernel stack overflow, overwriting the restart block is a very juicy exploit target. This is because the restart_block is held in the same memory allocation as the kernel stack. Moving the restart block to struct task_struct prevents this exploit by making the restart_block harder to locate. Note that there are other fields in thread_info that are also easy targets, at least on some architectures. It's also a decent simplification, since the restart code is more or less identical on all architectures. [james.hogan@imgtec.com: metag: align thread_info::supervisor_stack] Signed-off-by: Andy Lutomirski <luto@amacapital.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Kees Cook <keescook@chromium.org> Cc: David Miller <davem@davemloft.net> Acked-by: Richard Weinberger <richard@nod.at> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Steven Miao <realmz6@gmail.com> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc) Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Chris Zankel <chris@zankel.net> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-09Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Ingo Molnar: "The main changes in this cycle were: - rework hrtimer expiry calculation in hrtimer_interrupt(): the previous code had a subtle bug where expiry caching would miss an expiry, resulting in occasional bogus (late) expiry of hrtimers. - continuing Y2038 fixes - ktime division optimization - misc smaller fixes and cleanups" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: hrtimer: Make __hrtimer_get_next_event() static rtc: Convert rtc_set_ntp_time() to use timespec64 rtc: Remove redundant rtc_valid_tm() from rtc_hctosys() rtc: Modify rtc_hctosys() to address y2038 issues rtc: Update rtc-dev to use y2038-safe time interfaces rtc: Update interface.c to use y2038-safe time interfaces time: Expose get_monotonic_boottime64 for in-kernel use time: Expose getboottime64 for in-kernel uses ktime: Optimize ktime_divns for constant divisors hrtimer: Prevent stale expiry time in hrtimer_interrupt() ktime.h: Introduce ktime_ms_delta
2015-02-05hrtimer: Fix incorrect tai offset calculation for non high-res timer systemsJohn Stultz
I noticed some CLOCK_TAI timer test failures on one of my less-frequently used configurations. And after digging in I found in 76f4108892d9 (Cleanup hrtimer accessors to the timekepeing state), the hrtimer_get_softirq_time tai offset calucation was incorrectly rewritten, as the tai offset we return shold be from CLOCK_MONOTONIC, and not CLOCK_REALTIME. This results in CLOCK_TAI timers expiring early on non-highres capable machines. This patch fixes the issue, calculating the tai time properly from the monotonic base. Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: stable <stable@vger.kernel.org> # 3.17+ Link: http://lkml.kernel.org/r/1423097126-10236-1-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-01-24hrtimer: Make __hrtimer_get_next_event() statickbuild test robot
kernel/time/hrtimer.c:444:9: sparse: symbol '__hrtimer_get_next_event' was not declared. Should it be static? Fixes: 9bc7491906b4 hrtimer: Prevent stale expiry time in hrtimer_interrupt() Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Cc: kbuild-all@01.org Link: http://lkml.kernel.org/r/20150123121206.GA4766@snb Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
