[ Upstream commit 32a5ad9c22852e6bd9e74bdec5934ef9d1480bc5 ]
Currently, when writing
echo 18446744073709551616 > /proc/sys/fs/file-max
/proc/sys/fs/file-max will overflow and be set to 0. That quickly
crashes the system.
This commit sets the max and min value for file-max. The max value is
set to long int. Any higher value cannot currently be used as the
percpu counters are long ints and not unsigned integers.
Note that the file-max value is ultimately parsed via
__do_proc_doulongvec_minmax(). This function does not report error when
min or max are exceeded. Which means if a value largen that long int is
written userspace will not receive an error instead the old value will be
kept. There is an argument to be made that this should be changed and
__do_proc_doulongvec_minmax() should return an error when a dedicated min
or max value are exceeded. However this has the potential to break
userspace so let's defer this to an RFC patch.
Link: http://lkml.kernel.org/r/20190107222700.15954-3-christian@brauner.io
Signed-off-by: Christian Brauner <christian@brauner.io>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Joe Lawrence <joe.lawrence@redhat.com>
Cc: Luis Chamberlain <mcgrof@kernel.org>
Cc: Waiman Long <longman@redhat.com>
[christian@brauner.io: v4]
Link: http://lkml.kernel.org/r/20190210203943.8227-3-christian@brauner.io
commit 8cf7630b29701d364f8df4a50e4f1f5e752b2778 upstream.
This bug has apparently existed since the introduction of this function
in the pre-git era (4500e91754d3 in Thomas Gleixner's history.git,
"[NET]: Add proc_dointvec_userhz_jiffies, use it for proper handling of
neighbour sysctls.").
As a minimal fix we can simply duplicate the corresponding check in
do_proc_dointvec_conv().
Link: http://lkml.kernel.org/r/20190207123426.9202-3-zev@bewilderbeest.net
Signed-off-by: Zev Weiss <zev@bewilderbeest.net>
Cc: Brendan Higgins <brendanhiggins@google.com>
Cc: Iurii Zaikin <yzaikin@google.com>
Cc: <stable@vger.kernel.org> [2.6.2+]
So that we can also runtime chose to print out the needed system info
for panic, other than setting the kernel cmdline.
Link: http://lkml.kernel.org/r/1543398842-19295-3-git-send-email-feng.tang@intel.com
Signed-off-by: Feng Tang <feng.tang@intel.com>
Suggested-by: Steven Rostedt <rostedt@goodmis.org>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Cc: John Stultz <john.stultz@linaro.org>
If the number of input parameters is less than the total parameters, an
EINVAL error will be returned.
For example, we use proc_doulongvec_minmax to pass up to two parameters
with kern_table:
.procname = "monitor_signals",
.data = &monitor_sigs,
.maxlen = 2*sizeof(unsigned long),
.mode = 0644,
.proc_handler = proc_doulongvec_minmax,
Reproduce:
When passing two parameters, it's work normal. But passing only one
parameter, an error "Invalid argument"(EINVAL) is returned.
[root@cl150 ~]# echo 1 2 > /proc/sys/kernel/monitor_signals
[root@cl150 ~]# cat /proc/sys/kernel/monitor_signals
1 2
[root@cl150 ~]# echo 3 > /proc/sys/kernel/monitor_signals
-bash: echo: write error: Invalid argument
[root@cl150 ~]# echo $?
1
3 2
[root@cl150 ~]#
The following is the result after apply this patch. No error is
returned when the number of input parameters is less than the total
parameters.
1 2
0
3 2
[root@cl150 ~]#
There are three processing functions dealing with digital parameters,
__do_proc_dointvec/__do_proc_douintvec/__do_proc_doulongvec_minmax.
This patch deals with __do_proc_doulongvec_minmax, just as
__do_proc_dointvec does, adding a check for parameters 'left'. In
__do_proc_douintvec, its code implementation explicitly does not support
multiple inputs.
static int __do_proc_douintvec(...){
* Arrays are not supported, keep this simple. *Do not* add
* support for them.
if (vleft != 1) {
*lenp = 0;
return -EINVAL;
So, just __do_proc_doulongvec_minmax has the problem. And most use of
proc_doulongvec_minmax/proc_doulongvec_ms_jiffies_minmax just have one
parameter.
Link: http://lkml.kernel.org/r/1544081775-15720-1-git-send-email-cheng.lin130@zte.com.cn
Signed-off-by: Cheng Lin <cheng.lin130@zte.com.cn>
Acked-by: Luis Chamberlain <mcgrof@kernel.org>
An external fragmentation event was previously described as
When the page allocator fragments memory, it records the event using
the mm_page_alloc_extfrag event. If the fallback_order is smaller
than a pageblock order (order-9 on 64-bit x86) then it's considered
an event that will cause external fragmentation issues in the future.
The kernel reduces the probability of such events by increasing the
watermark sizes by calling set_recommended_min_free_kbytes early in the
lifetime of the system. This works reasonably well in general but if
there are enough sparsely populated pageblocks then the problem can still
occur as enough memory is free overall and kswapd stays asleep.
This patch introduces a watermark_boost_factor sysctl that allows a zone
watermark to be temporarily boosted when an external fragmentation causing
events occurs. The boosting will stall allocations that would decrease
free memory below the boosted low watermark and kswapd is woken if the
calling context allows to reclaim an amount of memory relative to the size
of the high watermark and the watermark_boost_factor until the boost is
cleared. When kswapd finishes, it wakes kcompactd at the pageblock order
to clean some of the pageblocks that may have been affected by the
fragmentation event. kswapd avoids any writeback, slab shrinkage and swap
from reclaim context during this operation to avoid excessive system
disruption in the name of fragmentation avoidance. Care is taken so that
kswapd will do normal reclaim work if the system is really low on memory.
This was evaluated using the same workloads as "mm, page_alloc: Spread
allocations across zones before introducing fragmentation".
1-socket Skylake machine
config-global-dhp__workload_thpfioscale XFS (no special madvise)
4 fio threads, 1 THP allocating thread
4.20-rc3 extfrag events < order 9: 804694
4.20-rc3+patch: 408912 (49% reduction)
4.20-rc3+patch1-4: 18421 (98% reduction)
4.20.0-rc3 4.20.0-rc3
lowzone-v5r8 boost-v5r8
Amean fault-base-1 653.58 ( 0.00%) 652.71 ( 0.13%)
Amean fault-huge-1 0.00 ( 0.00%) 178.93 * -99.00%*
Percentage huge-1 0.00 ( 0.00%) 5.12 ( 100.00%)
Note that external fragmentation causing events are massively reduced by
this path whether in comparison to the previous kernel or the vanilla
kernel. The fault latency for huge pages appears to be increased but that
is only because THP allocations were successful with the patch applied.
global-dhp__workload_thpfioscale-madvhugepage-xfs (MADV_HUGEPAGE)
4.20-rc3 extfrag events < order 9: 291392
4.20-rc3+patch: 191187 (34% reduction)
4.20-rc3+patch1-4: 13464 (95% reduction)
thpfioscale Fault Latencies
Min fault-base-1 912.00 ( 0.00%) 905.00 ( 0.77%)
Min fault-huge-1 127.00 ( 0.00%) 135.00 ( -6.30%)
Amean fault-base-1 1467.55 ( 0.00%) 1481.67 ( -0.96%)
Amean fault-huge-1 1127.11 ( 0.00%) 1063.88 * 5.61%*
Percentage huge-1 77.64 ( 0.00%) 83.46 ( 7.49%)
As before, massive reduction in external fragmentation events, some jitter
on latencies and an increase in THP allocation success rates.
2-socket Haswell machine
4 fio threads, 5 THP allocating threads
4.20-rc3 extfrag events < order 9: 215698
4.20-rc3+patch: 200210 (7% reduction)
4.20-rc3+patch1-4: 14263 (93% reduction)
Amean fault-base-5 1346.45 ( 0.00%) 1306.87 ( 2.94%)
Amean fault-huge-5 3418.60 ( 0.00%) 1348.94 ( 60.54%)
Percentage huge-5 0.78 ( 0.00%) 7.91 ( 910.64%)
There is a 93% reduction in fragmentation causing events, there is a big
reduction in the huge page fault latency and allocation success rate is
higher.
4.20-rc3 extfrag events < order 9: 166352
4.20-rc3+patch: 147463 (11% reduction)
4.20-rc3+patch1-4: 11095 (93% reduction)
Amean fault-base-5 6217.43 ( 0.00%) 7419.67 * -19.34%*
Amean fault-huge-5 3163.33 ( 0.00%) 3263.80 ( -3.18%)
Percentage huge-5 95.14 ( 0.00%) 87.98 ( -7.53%)
There is a large reduction in fragmentation events with some jitter around
the latencies and success rates. As before, the high THP allocation
success rate does mean the system is under a lot of pressure. However, as
the fragmentation events are reduced, it would be expected that the
long-term allocation success rate would be higher.
Link: http://lkml.kernel.org/r/20181123114528.28802-5-mgorman@techsingularity.net
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Zi Yan <zi.yan@cs.rutgers.edu>
Remove one include of <linux/pipe_fs_i.h>.
No functional changes.
Link: http://lkml.kernel.org/r/20181004134223.17735-1-michael@schupikov.de
Signed-off-by: Michael Schupikov <michael@schupikov.de>
Reviewed-by: Richard Weinberger <richard@nod.at>
Introduce CONFIG_STACKLEAK_RUNTIME_DISABLE option, which provides
'stack_erasing' sysctl. It can be used in runtime to control kernel
stack erasing for kernels built with CONFIG_GCC_PLUGIN_STACKLEAK.
Suggested-by: Ingo Molnar <mingo@kernel.org>
Signed-off-by: Alexander Popov <alex.popov@linux.com>
Tested-by: Laura Abbott <labbott@redhat.com>
Disallows open of FIFOs or regular files not owned by the user in world
writable sticky directories, unless the owner is the same as that of the
directory or the file is opened without the O_CREAT flag. The purpose
is to make data spoofing attacks harder. This protection can be turned
on and off separately for FIFOs and regular files via sysctl, just like
the symlinks/hardlinks protection. This patch is based on Openwall's
"HARDEN_FIFO" feature by Solar Designer.
This is a brief list of old vulnerabilities that could have been prevented
by this feature, some of them even allow for privilege escalation:
CVE-2000-1134
CVE-2007-3852
CVE-2008-0525
CVE-2009-0416
CVE-2011-4834
CVE-2015-1838
CVE-2015-7442
CVE-2016-7489
This list is not meant to be complete. It's difficult to track down all
vulnerabilities of this kind because they were often reported without any
mention of this particular attack vector. In fact, before
hardlinks/symlinks restrictions, fifos/regular files weren't the favorite
vehicle to exploit them.
[s.mesoraca16@gmail.com: fix bug reported by Dan Carpenter]
Link: https://lkml.kernel.org/r/20180426081456.GA7060@mwanda
Link: http://lkml.kernel.org/r/1524829819-11275-1-git-send-email-s.mesoraca16@gmail.com
[keescook@chromium.org: drop pr_warn_ratelimited() in favor of audit changes in the future]
[keescook@chromium.org: adjust commit subjet]
Link: http://lkml.kernel.org/r/20180416175918.GA13494@beast
Signed-off-by: Salvatore Mesoraca <s.mesoraca16@gmail.com>
Suggested-by: Solar Designer <solar@openwall.com>
Suggested-by: Kees Cook <keescook@chromium.org>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Fix a few typos/spellos in kernel/sysctl.c.
Link: http://lkml.kernel.org/r/bb09a8b9-f984-6dd4-b07b-3ecaf200862e@infradead.org
Cc: "Luis R. Rodriguez" <mcgrof@kernel.org>
Currently task hung checking interval is equal to timeout, as the result
hung is detected anywhere between timeout and 2*timeout. This is fine for
most interactive environments, but this hurts automated testing setups
(syzbot). In an automated setup we need to strictly order CPU lockup <
RCU stall < workqueue lockup < task hung < silent loss, so that RCU stall
is not detected as task hung and task hung is not detected as silent
machine loss. The large variance in task hung detection timeout requires
setting silent machine loss timeout to a very large value (e.g. if task
hung is 3 mins, then silent loss need to be set to ~7 mins). The
additional 3 minutes significantly reduce testing efficiency because
usually we crash kernel within a minute, and this can add hours to bug
localization process as it needs to do dozens of tests.
Allow setting checking interval separately from timeout. This allows to
set timeout to, say, 3 minutes, but checking interval to 10 secs.
The interval is controlled via a new hung_task_check_interval_secs sysctl,
similar to the existing hung_task_timeout_secs sysctl. The default value
of 0 results in the current behavior: checking interval is equal to
timeout.
[akpm@linux-foundation.org: update hung_task_timeout_max's comment]
Link: http://lkml.kernel.org/r/20180611111004.203513-1-dvyukov@google.com
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
/proc/sys/kernel/sched_time_avg_ms entry is not used anywhere,
remove it.
Signed-off-by: Vincent Guittot <vincent.guittot@linaro.org>
Reviewed-by: Luis R. Rodriguez <mcgrof@kernel.org>
Cc: Morten.Rasmussen@arm.com
Cc: claudio@evidence.eu.com
Cc: daniel.lezcano@linaro.org
Cc: dietmar.eggemann@arm.com
Cc: joel@joelfernandes.org
Cc: juri.lelli@redhat.com
Cc: luca.abeni@santannapisa.it
Cc: patrick.bellasi@arm.com
Cc: quentin.perret@arm.com
Cc: rjw@rjwysocki.net
Cc: valentin.schneider@arm.com
Cc: viresh.kumar@linaro.org
Link: http://lkml.kernel.org/r/1530200714-4504-12-git-send-email-vincent.guittot@linaro.org
The kzalloc() function has a 2-factor argument form, kcalloc(). This
patch replaces cases of:
kzalloc(a * b, gfp)
with:
kcalloc(a * b, gfp)
as well as handling cases of:
kzalloc(a * b * c, gfp)
with:
kzalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kzalloc_array(array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
kzalloc(4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
kzalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
kzalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
kzalloc(
- sizeof(u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(u8) * COUNT
+ COUNT
kzalloc(
- sizeof(__u8) * COUNT
+ COUNT
kzalloc(
- sizeof(char) * COUNT
+ COUNT
kzalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_CONST
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
- kzalloc
+ kcalloc
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
kzalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
kzalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
kzalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
kzalloc(
- sizeof(TYPE) * COUNT * STRIDE
kzalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
kzalloc(
- sizeof(THING) * (COUNT) * STRIDE
kzalloc(
- sizeof(THING) * COUNT * (STRIDE)
kzalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
kzalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
kzalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
kzalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
kzalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
kzalloc(
- COUNT * (STRIDE) * SIZE
kzalloc(
- COUNT * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * SIZE
kzalloc(
- COUNT * (STRIDE) * (SIZE)
kzalloc(
- (COUNT) * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * (SIZE)
kzalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
kzalloc(C1 * C2 * C3, ...)
kzalloc(
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
kzalloc(
- (E1) * (E2) * E3
kzalloc(
- (E1) * (E2) * (E3)
kzalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kzalloc(sizeof(THING) * C2, ...)
kzalloc(sizeof(TYPE) * C2, ...)
kzalloc(C1 * C2, ...)
- kzalloc
+ kcalloc
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- (E1) * E2
+ E1, E2
- kzalloc
+ kcalloc
- (E1) * (E2)
+ E1, E2
- kzalloc
+ kcalloc
- E1 * E2
+ E1, E2
Kdoc comments are added to the do_proc_dointvec_minmax_conv_param and
do_proc_douintvec_minmax_conv_param structures thare are used internally
for range checking.
The error codes returned by proc_dointvec_minmax() and
proc_douintvec_minmax() are also documented.
Link: http://lkml.kernel.org/r/1519926220-7453-3-git-send-email-longman@redhat.com
Signed-off-by: Waiman Long <longman@redhat.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Acked-by: Luis R. Rodriguez <mcgrof@kernel.org>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: Manfred Spraul <manfred@colorfullife.com>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Randy Dunlap <rdunlap@infradead.org>
Fix sizeof argument to be the same as the data variable name. Probably
a copy/paste error.
Mostly harmless since both variables are unsigned int.
Fixes kernel bugzilla #197371:
Possible access to unintended variable in "kernel/sysctl.c" line 1339
https://bugzilla.kernel.org/show_bug.cgi?id=197371
Link: http://lkml.kernel.org/r/e0d0531f-361e-ef5f-8499-32743ba907e1@infradead.org
Reported-by: Petru Mihancea <petrum@gmail.com>
Currently one requires to test four kernel configurations to test the
firmware API completely:
0)
CONFIG_FW_LOADER=y
1)
o CONFIG_FW_LOADER=y
o CONFIG_FW_LOADER_USER_HELPER=y
2)
o CONFIG_FW_LOADER_USER_HELPER_FALLBACK=y
3) When CONFIG_FW_LOADER=m the built-in stuff is disabled, we have
no current tests for this.
We can reduce the requirements to three kernel configurations by making
fw_config.force_sysfs_fallback a proc knob we flip on off. For kernels that
disable CONFIG_IKCONFIG_PROC this can also enable one to inspect if
CONFIG_FW_LOADER_USER_HELPER_FALLBACK was enabled at build time by checking
the proc value at boot time.
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
A pipe's size is represented as an 'unsigned int'. As expected, writing a
value greater than UINT_MAX to /proc/sys/fs/pipe-max-size fails with
EINVAL. However, the F_SETPIPE_SZ fcntl silently truncates such values to
32 bits, rather than failing with EINVAL as expected. (It *does* fail
with EINVAL for values above (1 << 31) but <= UINT_MAX.)
Fix this by moving the check against UINT_MAX into round_pipe_size() which
is called in both cases.
Link: http://lkml.kernel.org/r/20180111052902.14409-6-ebiggers3@gmail.com
Acked-by: Joe Lawrence <joe.lawrence@redhat.com>
Cc: "Luis R . Rodriguez" <mcgrof@kernel.org>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Mikulas Patocka <mpatocka@redhat.com>
Cc: Willy Tarreau <w@1wt.eu>
pipe_proc_fn() is no longer needed, as it only calls through to
proc_dopipe_max_size(). Just put proc_dopipe_max_size() in the ctl_table
entry directly, and remove the unneeded EXPORT_SYMBOL() and the ENOSYS
stub for it.
(The reason the ENOSYS stub isn't needed is that the pipe-max-size
ctl_table entry is located directly in 'kern_table' rather than being
registered separately. Therefore, the entry is already only defined when
the kernel is built with sysctl support.)
Link: http://lkml.kernel.org/r/20180111052902.14409-3-ebiggers3@gmail.com
Patch series "pipe: buffer limits fixes and cleanups", v2.
This series simplifies the sysctl handler for pipe-max-size and fixes
another set of bugs related to the pipe buffer limits:
- The root user wasn't allowed to exceed the limits when creating new
pipes.
- There was an off-by-one error when checking the limits, so a limit of
N was actually treated as N - 1.
- F_SETPIPE_SZ accepted values over UINT_MAX.
- Reading the pipe buffer limits could be racy.
This patch (of 7):
Before validating the given value against pipe_min_size,
do_proc_dopipe_max_size_conv() calls round_pipe_size(), which rounds the
value up to pipe_min_size. Therefore, the second check against
pipe_min_size is redundant. Remove it.
Link: http://lkml.kernel.org/r/20180111052902.14409-2-ebiggers3@gmail.com
hugepages_treat_as_movable has been introduced by 396faf0303d2 ("Allow
huge page allocations to use GFP_HIGH_MOVABLE") to allow hugetlb
allocations from ZONE_MOVABLE even when hugetlb pages were not
migrateable. The purpose of the movable zone was different at the time.
It aimed at reducing memory fragmentation and hugetlb pages being long
lived and large werre not contributing to the fragmentation so it was
acceptable to use the zone back then.
Things have changed though and the primary purpose of the zone became
migratability guarantee. If we allow non migrateable hugetlb pages to
be in ZONE_MOVABLE memory hotplug might fail to offline the memory.
Remove the knob and only rely on hugepage_migration_supported to allow
movable zones.
Mel said:
: Primarily it was aimed at allowing the hugetlb pool to safely shrink with
: the ability to grow it again. The use case was for batched jobs, some of
: which needed huge pages and others that did not but didn't want the memory
: useless pinned in the huge pages pool.
: I suspect that more users rely on THP than hugetlbfs for flexible use of
: huge pages with fallback options so I think that removing the option
: should be ok.
Link: http://lkml.kernel.org/r/20171003072619.8654-1-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Reported-by: Alexandru Moise <00moses.alexander00@gmail.com>
Cc: Alexandru Moise <00moses.alexander00@gmail.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Remove unnecessary else block, remove redundant return and call to kfree
in if block.
Link: http://lkml.kernel.org/r/1510238435-1655-1-git-send-email-mail@okal.no
Signed-off-by: Ola N. Kaldestad <mail@okal.no>
Mikulas noticed in the existing do_proc_douintvec_minmax_conv() and
do_proc_dopipe_max_size_conv() introduced in this patchset, that they
inconsistently handle overflow and min/max range inputs:
For example:
0 ... param->min - 1 ---> ERANGE
param->min ... param->max ---> the value is accepted
param->max + 1 ... 0x100000000L + param->min - 1 ---> ERANGE
0x100000000L + param->min ... 0x100000000L + param->max ---> EINVAL
0x100000000L + param->max + 1, 0x200000000L + param->min - 1 ---> ERANGE
0x200000000L + param->min ... 0x200000000L + param->max ---> EINVAL
0x200000000L + param->max + 1, 0x300000000L + param->min - 1 ---> ERANGE
In do_proc_do*() routines which store values into unsigned int variables
(4 bytes wide for 64-bit builds), first validate that the input unsigned
long value (8 bytes wide for 64-bit builds) will fit inside the smaller
unsigned int variable. Then check that the unsigned int value falls
inside the specified parameter min, max range. Otherwise the unsigned
long -> unsigned int conversion drops leading bits from the input value,
leading to the inconsistent pattern Mikulas documented above.
Link: http://lkml.kernel.org/r/1507658689-11669-5-git-send-email-joe.lawrence@redhat.com
Signed-off-by: Joe Lawrence <joe.lawrence@redhat.com>
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Reviewed-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
pipe_max_size is assigned directly via procfs sysctl:
static struct ctl_table fs_table[] = {
.procname = "pipe-max-size",
.data = &pipe_max_size,
.maxlen = sizeof(int),
.mode = 0644,
.proc_handler = &pipe_proc_fn,
.extra1 = &pipe_min_size,
int pipe_proc_fn(struct ctl_table *table, int write, void __user *buf,
size_t *lenp, loff_t *ppos)
ret = proc_dointvec_minmax(table, write, buf, lenp, ppos)
and then later rounded in-place a few statements later:
pipe_max_size = round_pipe_size(pipe_max_size);
This leaves a window of time between initial assignment and rounding
that may be visible to other threads. (For example, one thread sets a
non-rounded value to pipe_max_size while another reads its value.)
Similar reads of pipe_max_size are potentially racy:
pipe.c :: alloc_pipe_info()
pipe.c :: pipe_set_size()
Add a new proc_dopipe_max_size() that consolidates reading the new value
from the user buffer, verifying bounds, and calling round_pipe_size()
with a single assignment to pipe_max_size.
Link: http://lkml.kernel.org/r/1507658689-11669-4-git-send-email-joe.lawrence@redhat.com
Patch series "A few round_pipe_size() and pipe-max-size fixups", v3.
While backporting Michael's "pipe: fix limit handling" patchset to a
distro-kernel, Mikulas noticed that current upstream pipe limit handling
contains a few problems:
1 - procfs signed wrap: echo'ing a large number into
/proc/sys/fs/pipe-max-size and then cat'ing it back out shows a
negative value.
2 - round_pipe_size() nr_pages overflow on 32bit: this would
subsequently try roundup_pow_of_two(0), which is undefined.
3 - visible non-rounded pipe-max-size value: there is no mutual
exclusion or protection between the time pipe_max_size is assigned
a raw value from proc_dointvec_minmax() and when it is rounded.
4 - unsigned long -> unsigned int conversion makes for potential odd
return errors from do_proc_douintvec_minmax_conv() and
do_proc_dopipe_max_size_conv().
This version underwent the same testing as v1:
https://marc.info/?l=linux-kernel&m=150643571406022&w=2
This patch (of 4):
pipe_max_size is defined as an unsigned int:
unsigned int pipe_max_size = 1048576;
but its procfs/sysctl representation is an integer:
.mode = 0644,
that is signed:
This leads to signed results via procfs for large values of pipe_max_size:
% echo 2147483647 >/proc/sys/fs/pipe-max-size
% cat /proc/sys/fs/pipe-max-size
-2147483648
Use unsigned operations on this variable to avoid such negative values.
Link: http://lkml.kernel.org/r/1507658689-11669-2-git-send-email-joe.lawrence@redhat.com
This is the second step which introduces a tunable interface that allow
numa stats configurable for optimizing zone_statistics(), as suggested
by Dave Hansen and Ying Huang.
When page allocation performance becomes a bottleneck and you can
tolerate some possible tool breakage and decreased numa counter
precision, you can do:
echo 0 > /proc/sys/vm/numa_stat
In this case, numa counter update is ignored. We can see about
*4.8%*(185->176) drop of cpu cycles per single page allocation and
reclaim on Jesper's page_bench01 (single thread) and *8.1%*(343->315)
drop of cpu cycles per single page allocation and reclaim on Jesper's
page_bench03 (88 threads) running on a 2-Socket Broadwell-based server
(88 threads, 126G memory).
Benchmark link provided by Jesper D Brouer (increase loop times to
10000000):
https://github.com/netoptimizer/prototype-kernel/tree/master/kernel/mm/bench
When page allocation performance is not a bottleneck and you want all
tooling to work, you can do:
echo 1 > /proc/sys/vm/numa_stat
This is system default setting.
Many thanks to Michal Hocko, Dave Hansen, Ying Huang and Vlastimil Babka
for comments to help improve the original patch.
[keescook@chromium.org: make sure mutex is a global static]
Link: http://lkml.kernel.org/r/20171107213809.GA4314@beast
Link: http://lkml.kernel.org/r/1508290927-8518-1-git-send-email-kemi.wang@intel.com
Signed-off-by: Kemi Wang <kemi.wang@intel.com>
Reported-by: Jesper Dangaard Brouer <brouer@redhat.com>
Suggested-by: Dave Hansen <dave.hansen@intel.com>
Suggested-by: Ying Huang <ying.huang@intel.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Christopher Lameter <cl@linux.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Tim Chen <tim.c.chen@intel.com>
Cc: Andi Kleen <andi.kleen@intel.com>
Cc: Aaron Lu <aaron.lu@intel.com>
Fix up makefiles, remove references, and git rm kmemcheck.
Link: http://lkml.kernel.org/r/20171007030159.22241-4-alexander.levin@verizon.com
Cc: Vegard Nossum <vegardno@ifi.uio.no>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Tim Hansen <devtimhansen@gmail.com>
Pull core block layer updates from Jens Axboe:
"This is the main pull request for block storage for 4.15-rc1.
Nothing out of the ordinary in here, and no API changes or anything
like that. Just various new features for drivers, core changes, etc.
In particular, this pull request contains:
- A patch series from Bart, closing the whole on blk/scsi-mq queue
quescing.
- A series from Christoph, building towards hidden gendisks (for
multipath) and ability to move bio chains around.
- NVMe
- Support for native multipath for NVMe (Christoph).
- Userspace notifications for AENs (Keith).
- Command side-effects support (Keith).
- SGL support (Chaitanya Kulkarni)
- FC fixes and improvements (James Smart)
- Lots of fixes and tweaks (Various)
- bcache
- New maintainer (Michael Lyle)
- Writeback control improvements (Michael)
- Various fixes (Coly, Elena, Eric, Liang, et al)
- lightnvm updates, mostly centered around the pblk interface
(Javier, Hans, and Rakesh).
- Removal of unused bio/bvec kmap atomic interfaces (me, Christoph)
- Writeback series that fix the much discussed hundreds of millions
of sync-all units. This goes all the way, as discussed previously
(me).
- Fix for missing wakeup on writeback timer adjustments (Yafang
Shao).
- Fix laptop mode on blk-mq (me).
- {mq,name} tupple lookup for IO schedulers, allowing us to have
alias names. This means you can use 'deadline' on both !mq and on
mq (where it's called mq-deadline). (me).
- blktrace race fix, oopsing on sg load (me).
- blk-mq optimizations (me).
- Obscure waitqueue race fix for kyber (Omar).
- NBD fixes (Josef).
- Disable writeback throttling by default on bfq, like we do on cfq
(Luca Miccio).
- Series from Ming that enable us to treat flush requests on blk-mq
like any other request. This is a really nice cleanup.
- Series from Ming that improves merging on blk-mq with schedulers,
getting us closer to flipping the switch on scsi-mq again.
- BFQ updates (Paolo).
- blk-mq atomic flags memory ordering fixes (Peter Z).
- Loop cgroup support (Shaohua).
- Lots of minor fixes from lots of different folks, both for core and
driver code"
* 'for-4.15/block' of git://git.kernel.dk/linux-block: (294 commits)
nvme: fix visibility of "uuid" ns attribute
blk-mq: fixup some comment typos and lengths
ide: ide-atapi: fix compile error with defining macro DEBUG
blk-mq: improve tag waiting setup for non-shared tags
brd: remove unused brd_mutex
blk-mq: only run the hardware queue if IO is pending
block: avoid null pointer dereference on null disk
fs: guard_bio_eod() needs to consider partitions
xtensa/simdisk: fix compile error
nvme: expose subsys attribute to sysfs
nvme: create 'slaves' and 'holders' entries for hidden controllers
block: create 'slaves' and 'holders' entries for hidden gendisks
nvme: also expose the namespace identification sysfs files for mpath nodes
nvme: implement multipath access to nvme subsystems
nvme: track shared namespaces
nvme: introduce a nvme_ns_ids structure
nvme: track subsystems
block, nvme: Introduce blk_mq_req_flags_t
block, scsi: Make SCSI quiesce and resume work reliably
block: Add the QUEUE_FLAG_PREEMPT_ONLY request queue flag
Pull watchddog clean-up and fixes from Thomas Gleixner:
"The watchdog (hard/softlockup detector) code is pretty much broken in
its current state. The patch series addresses this by removing all
duct tape and refactoring it into a workable state.
The reasons why I ask for inclusion that late in the cycle are:
1) The code causes lockdep splats vs. hotplug locking which get
reported over and over. Unfortunately there is no easy fix.
2) The risk of breakage is minimal because it's already broken
3) As 4.14 is a long term stable kernel, I prefer to have working
watchdog code in that and the lockdep issues resolved. I wouldn't
ask you to pull if 4.14 wouldn't be a LTS kernel or if the
solution would be easy to backport.
4) The series was around before the merge window opened, but then got
delayed due to the UP failure caused by the for_each_cpu()
surprise which we discussed recently.
Changes vs. V1:
- Addressed your review points
- Addressed the warning in the powerpc code which was discovered late
- Changed two function names which made sense up to a certain point
in the series. Now they match what they do in the end.
- Fixed a 'unused variable' warning, which got not detected by the
intel robot. I triggered it when trying all possible related config
combinations manually. Randconfig testing seems not random enough.
The changes have been tested by and reviewed by Don Zickus and tested
and acked by Micheal Ellerman for powerpc"
* 'core-watchdog-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (36 commits)
watchdog/core: Put softlockup_threads_initialized under ifdef guard
watchdog/core: Rename some softlockup_* functions
powerpc/watchdog: Make use of watchdog_nmi_probe()
watchdog/core, powerpc: Lock cpus across reconfiguration
watchdog/core, powerpc: Replace watchdog_nmi_reconfigure()
watchdog/hardlockup/perf: Fix spelling mistake: "permanetely" -> "permanently"
watchdog/hardlockup/perf: Cure UP damage
watchdog/hardlockup: Clean up hotplug locking mess
watchdog/hardlockup/perf: Simplify deferred event destroy
watchdog/hardlockup/perf: Use new perf CPU enable mechanism
watchdog/hardlockup/perf: Implement CPU enable replacement
watchdog/hardlockup/perf: Implement init time detection of perf
watchdog/hardlockup/perf: Implement init time perf validation
watchdog/core: Get rid of the racy update loop
watchdog/core, powerpc: Make watchdog_nmi_reconfigure() two stage
watchdog/sysctl: Clean up sysctl variable name space
watchdog/sysctl: Get rid of the #ifdeffery
watchdog/core: Clean up header mess
watchdog/core: Further simplify sysctl handling
watchdog/core: Get rid of the thread teardown/setup dance
This tunable has been obsolete since 2.6.32, and writes to the
file have been failing and complaining in dmesg since then:
nr_pdflush_threads exported in /proc is scheduled for removal
That was 8 years ago. Remove the file ABI obsolete notice, and
the sysfs file.
do_proc_douintvec_conv() has two UINT_MAX checks, we can remove one.
This has no functional changes other than fixing a compiler warning:
kernel/sysctl.c:2190]: (warning) Identical condition '*lvalp>UINT_MAX', second condition is always false
Fixes: 4f2fec00afa60 ("sysctl: simplify unsigned int support")
Link: http://lkml.kernel.org/r/20170919072918.12066-1-mcgrof@kernel.org
Reported-by: David Binderman <dcb314@hotmail.com>
System will hang if user set sysctl_sched_time_avg to 0:
[root@XXX ~]# sysctl kernel.sched_time_avg_ms=0
Stack traceback for pid 0
0xffff883f6406c600 0 0 1 3 R 0xffff883f6406cf50 *swapper/3
ffff883f7ccc3ae8 0000000000000018 ffffffff810c4dd0 0000000000000000
0000000000017800 ffff883f7ccc3d78 0000000000000003 ffff883f7ccc3bf8
ffffffff810c4fc9 ffff883f7ccc3c08 00000000810c5043 ffff883f7ccc3c08
Call Trace:
<IRQ> [<ffffffff810c4dd0>] ? update_group_capacity+0x110/0x200
[<ffffffff810c4fc9>] ? update_sd_lb_stats+0x109/0x600
[<ffffffff810c5507>] ? find_busiest_group+0x47/0x530
[<ffffffff810c5b84>] ? load_balance+0x194/0x900
[<ffffffff810ad5ca>] ? update_rq_clock.part.83+0x1a/0xe0
[<ffffffff810c6d42>] ? rebalance_domains+0x152/0x290
[<ffffffff810c6f5c>] ? run_rebalance_domains+0xdc/0x1d0
[<ffffffff8108a75b>] ? __do_softirq+0xfb/0x320
[<ffffffff8108ac85>] ? irq_exit+0x125/0x130
[<ffffffff810b3a17>] ? scheduler_ipi+0x97/0x160
[<ffffffff81052709>] ? smp_reschedule_interrupt+0x29/0x30
[<ffffffff8173a1be>] ? reschedule_interrupt+0x6e/0x80
<EOI> [<ffffffff815bc83c>] ? cpuidle_enter_state+0xcc/0x230
[<ffffffff815bc80c>] ? cpuidle_enter_state+0x9c/0x230
[<ffffffff815bc9d7>] ? cpuidle_enter+0x17/0x20
[<ffffffff810cd6dc>] ? cpu_startup_entry+0x38c/0x420
[<ffffffff81053373>] ? start_secondary+0x173/0x1e0
Because divide-by-zero error happens in function:
update_group_capacity()
update_cpu_capacity()
scale_rt_capacity()
total = sched_avg_period() + delta;
used = div_u64(avg, total);
To fix this issue, check user input value of sysctl_sched_time_avg, keep
it unchanged when hitting invalid input, and set the minimum limit of
sysctl_sched_time_avg to 1 ms.
Reported-by: James Puthukattukaran <james.puthukattukaran@oracle.com>
Signed-off-by: Ethan Zhao <ethan.zhao@oracle.com>
Cc: efault@gmx.de
Cc: ethan.kernel@gmail.com
Cc: keescook@chromium.org
Cc: mcgrof@kernel.org
Link: http://lkml.kernel.org/r/1504504774-18253-1-git-send-email-ethan.zhao@oracle.com
Reflect that these variables are user interface related and remove the
whitespace damage in the sysctl table while at it.
Reviewed-by: Don Zickus <dzickus@redhat.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Nicholas Piggin <npiggin@gmail.com>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Cc: Ulrich Obergfell <uobergfe@redhat.com>
Link: http://lkml.kernel.org/r/20170912194147.783210221@linutronix.de
The sysctl of the nmi_watchdog file prevents writes by setting:
min = max = 0
if none of the users is enabled. That involves ifdeffery and is competely
non obvious.
If none of the facilities is enabeld, then the file can simply be made read
only. Move the ifdeffery into the header and use a constant for file
permissions.
Link: http://lkml.kernel.org/r/20170912194147.706073616@linutronix.de
Split SOFTLOCKUP_DETECTOR from LOCKUP_DETECTOR, and split
HARDLOCKUP_DETECTOR_PERF from HARDLOCKUP_DETECTOR.
LOCKUP_DETECTOR implies the general boot, sysctl, and programming
interfaces for the lockup detectors.
An architecture that wants to use a hard lockup detector must define
HAVE_HARDLOCKUP_DETECTOR_PERF or HAVE_HARDLOCKUP_DETECTOR_ARCH.
Alternatively an arch can define HAVE_NMI_WATCHDOG, which provides the
minimum arch_touch_nmi_watchdog, and it otherwise does its own thing and
does not implement the LOCKUP_DETECTOR interfaces.
sparc is unusual in that it has started to implement some of the
interfaces, but not fully yet. It should probably be converted to a full
[npiggin@gmail.com: fix]
Link: http://lkml.kernel.org/r/20170617223522.66c0ad88@roar.ozlabs.ibm.com
Link: http://lkml.kernel.org/r/20170616065715.18390-4-npiggin@gmail.com
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Reviewed-by: Babu Moger <babu.moger@oracle.com>
Tested-by: Babu Moger <babu.moger@oracle.com> [sparc]
Cc: Michael Ellerman <mpe@ellerman.id.au>
To keep parity with regular int interfaces provide the an unsigned int
proc_douintvec_minmax() which allows you to specify a range of allowed
valid numbers.
Adding proc_douintvec_minmax_sysadmin() is easy but we can wait for an
actual user for that.
Link: http://lkml.kernel.org/r/20170519033554.18592-6-mcgrof@kernel.org
Cc: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org>
Cc: Heinrich Schuchardt <xypron.glpk@gmx.de>
Commit e7d316a02f68 ("sysctl: handle error writing UINT_MAX to u32
fields") added proc_douintvec() to start help adding support for
unsigned int, this however was only half the work needed. Two fixes
have come in since then for the following issues:
o Printing the values shows a negative value, this happens since
do_proc_dointvec() and this uses proc_put_long()
This was fixed by commit 5380e5644afbba9 ("sysctl: don't print negative
flag for proc_douintvec").
o We can easily wrap around the int values: UINT_MAX is 4294967295, if
we echo in 4294967295 + 1 we end up with 0, using 4294967295 + 2 we
end up with 1.
o We echo negative values in and they are accepted
This was fixed by commit 425fffd886ba ("sysctl: report EINVAL if value
is larger than UINT_MAX for proc_douintvec").
It still also failed to be added to sysctl_check_table()... instead of
adding it with the current implementation just provide a proper and
simplified unsigned int support without any array unsigned int support
with no negative support at all.
Historically sysctl proc helpers have supported arrays, due to the
complexity this adds though we've taken a step back to evaluate array
users to determine if its worth upkeeping for unsigned int. An
evaluation using Coccinelle has been done to perform a grammatical
search to ask ourselves:
o How many sysctl proc_dointvec() (int) users exist which likely
should be moved over to proc_douintvec() (unsigned int) ?
Answer: about 8
- Of these how many are array users ?
Answer: Probably only 1
o How many sysctl array users exist ?
Answer: about 12
This last question gives us an idea just how popular arrays: they are not.
Array support should probably just be kept for strings.
The identified uint ports are:
drivers/infiniband/core/ucma.c - max_backlog
drivers/infiniband/core/iwcm.c - default_backlog
net/core/sysctl_net_core.c - rps_sock_flow_sysctl()
net/netfilter/nf_conntrack_timestamp.c - nf_conntrack_timestamp -- bool
net/netfilter/nf_conntrack_acct.c nf_conntrack_acct -- bool
net/netfilter/nf_conntrack_ecache.c - nf_conntrack_events -- bool
net/netfilter/nf_conntrack_helper.c - nf_conntrack_helper -- bool
net/phonet/sysctl.c proc_local_port_range()
The only possible array users is proc_local_port_range() but it does not
seem worth it to add array support just for this given the range support
works just as well. Unsigned int support should be desirable more for
when you *need* more than INT_MAX or using int min/max support then does
not suffice for your ranges.
If you forget and by mistake happen to register an unsigned int proc
entry with an array, the driver will fail and you will get something as
follows:
sysctl table check failed: debug/test_sysctl//uint_0002 array now allowed
CPU: 2 PID: 1342 Comm: modprobe Tainted: G W E <etc>
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS <etc>
Call Trace:
dump_stack+0x63/0x81
__register_sysctl_table+0x350/0x650
? kmem_cache_alloc_trace+0x107/0x240
__register_sysctl_paths+0x1b3/0x1e0
? 0xffffffffc005f000
register_sysctl_table+0x1f/0x30
test_sysctl_init+0x10/0x1000 [test_sysctl]
do_one_initcall+0x52/0x1a0
do_init_module+0x5f/0x200
load_module+0x1867/0x1bd0
? __symbol_put+0x60/0x60
SYSC_finit_module+0xdf/0x110
SyS_finit_module+0xe/0x10
entry_SYSCALL_64_fastpath+0x1e/0xad
RIP: 0033:0x7f042b22d119
<etc>
Fixes: e7d316a02f68 ("sysctl: handle error writing UINT_MAX to u32 fields")
Link: http://lkml.kernel.org/r/20170519033554.18592-5-mcgrof@kernel.org
Suggested-by: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Liping Zhang <zlpnobody@gmail.com>
The mode sysctl_writes_strict positional checks keep being copy and pasted
as we add new proc handlers. Just add a helper to avoid code duplication.
Link: http://lkml.kernel.org/r/20170519033554.18592-4-mcgrof@kernel.org
Document the different sysctl_writes_strict modes in code.
Link: http://lkml.kernel.org/r/20170519033554.18592-3-mcgrof@kernel.org
do_proc_dointvec_jiffies_conv() uses LONG_MAX/HZ as the max value to
avoid overflow. But actually the *valp is int type, so it still causes
overflow.
For example,
echo 2147483647 > ./sys/net/ipv4/tcp_keepalive_time
Then,
cat ./sys/net/ipv4/tcp_keepalive_time
The output is "-1", it is not expected.
Now use INT_MAX/HZ as the max value instead LONG_MAX/HZ to fix it.
Link: http://lkml.kernel.org/r/1490109532-9228-1-git-send-email-fgao@ikuai8.com
Signed-off-by: Gao Feng <fgao@ikuai8.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Eric Dumazet <edumazet@google.com>
Pull timer updates from Thomas Gleixner:
"The timer departement delivers:
- more year 2038 rework
- a massive rework of the arm achitected timer
- preparatory patches to allow NTP correction of clock event devices
to avoid early expiry
- the usual pile of fixes and enhancements all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (91 commits)
timer/sysclt: Restrict timer migration sysctl values to 0 and 1
arm64/arch_timer: Mark errata handlers as __maybe_unused
Clocksource/mips-gic: Remove redundant non devicetree init
MIPS/Malta: Probe gic-timer via devicetree
clocksource: Use GENMASK_ULL in definition of CLOCKSOURCE_MASK
acpi/arm64: Add SBSA Generic Watchdog support in GTDT driver
clocksource: arm_arch_timer: add GTDT support for memory-mapped timer
acpi/arm64: Add memory-mapped timer support in GTDT driver
clocksource: arm_arch_timer: simplify ACPI support code.
acpi/arm64: Add GTDT table parse driver
clocksource: arm_arch_timer: split MMIO timer probing.
clocksource: arm_arch_timer: add structs to describe MMIO timer
clocksource: arm_arch_timer: move arch_timer_needs_of_probing into DT init call
clocksource: arm_arch_timer: refactor arch_timer_needs_probing
clocksource: arm_arch_timer: split dt-only rate handling
x86/uv/time: Set ->min_delta_ticks and ->max_delta_ticks
unicore32/time: Set ->min_delta_ticks and ->max_delta_ticks
um/time: Set ->min_delta_ticks and ->max_delta_ticks
tile/time: Set ->min_delta_ticks and ->max_delta_ticks
score/time: Set ->min_delta_ticks and ->max_delta_ticks
timer_migration sysctl acts as a boolean switch, so the allowed values
should be restricted to 0 and 1.
Add the necessary extra fields to the sysctl table entry to enforce that.
[ tglx: Rewrote changelog ]
Signed-off-by: Myungho Jung <mhjungk@gmail.com>
Link: http://lkml.kernel.org/r/1492640690-3550-1-git-send-email-mhjungk@gmail.com
Currently, inputting the following command will succeed but actually the
value will be truncated:
# echo 0x12ffffffff > /proc/sys/net/ipv4/tcp_notsent_lowat
This is not friendly to the user, so instead, we should report error
when the value is larger than UINT_MAX.
Signed-off-by: Liping Zhang <zlpnobody@gmail.com>
I saw some very confusing sysctl output on my system:
# cat /proc/sys/net/core/xfrm_aevent_rseqth
-2
# cat /proc/sys/net/core/xfrm_aevent_etime
-10
# cat /proc/sys/net/ipv4/tcp_notsent_lowat
-4294967295
Because we forget to set the *negp flag in proc_douintvec, so it will
become a garbage value.
Since the value related to proc_douintvec is always an unsigned integer,
so we can set *negp to false explictily to fix this issue.
<linux/sched/coredump.h>
We are going to split <linux/sched/coredump.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/coredump.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
milliseconds
We added the 'sched_rr_timeslice_ms' SCHED_RR tuning knob in this commit:
ce0dbbbb30ae ("sched/rt: Add a tuning knob to allow changing SCHED_RR timeslice")
... which name suggests to users that it's in milliseconds, while in reality
it's being set in milliseconds but the result is shown in jiffies.
This is obviously confusing when HZ is not 1000, it makes it appear like the
value set failed, such as HZ=100:
root# echo 100 > /proc/sys/kernel/sched_rr_timeslice_ms
root# cat /proc/sys/kernel/sched_rr_timeslice_ms
10
Fix this to be milliseconds all around.
Signed-off-by: Shile Zhang <shile.zhang@nokia.com>
Link: http://lkml.kernel.org/r/1485612049-20923-1-git-send-email-shile.zhang@nokia.com
We perform the conversion between kernel jiffies and ms only when
exporting kernel value to user space.
We need to do the opposite operation when value is written by user.
Only matters when HZ != 1000
Cc: stable@vger.kernel.org
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing updates from Steven Rostedt:
"This release has a few updates:
- STM can hook into the function tracer
- Function filtering now supports more advance glob matching
- Ftrace selftests updates and added tests
- Softirq tag in traces now show only softirqs
- ARM nop added to non traced locations at compile time
- New trace_marker_raw file that allows for binary input
- Optimizations to the ring buffer
- Removal of kmap in trace_marker
- Wakeup and irqsoff tracers now adhere to the set_graph_notrace file
- Other various fixes and clean ups"
* tag 'trace-v4.10' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (42 commits)
selftests: ftrace: Shift down default message verbosity
kprobes/trace: Fix kprobe selftest for newer gcc
tracing/kprobes: Add a helper method to return number of probe hits
tracing/rb: Init the CPU mask on allocation
tracing: Use SOFTIRQ_OFFSET for softirq dectection for more accurate results
tracing/fgraph: Have wakeup and irqsoff tracers ignore graph functions too
fgraph: Handle a case where a tracer ignores set_graph_notrace
tracing: Replace kmap with copy_from_user() in trace_marker writing
ftrace/x86_32: Set ftrace_stub to weak to prevent gcc from using short jumps to it
tracing: Allow benchmark to be enabled at early_initcall()
tracing: Have system enable return error if one of the events fail
tracing: Do not start benchmark on boot up
tracing: Have the reg function allow to fail
ring-buffer: Force rb_end_commit() and rb_set_commit_to_write() inline
ring-buffer: Froce rb_update_write_stamp() to be inlined
ring-buffer: Force inline of hotpath helper functions
tracing: Make __buffer_unlock_commit() always_inline
tracing: Make tracepoint_printk a static_key
ring-buffer: Always inline rb_event_data()
ring-buffer: Make rb_reserve_next_event() always inlined
I was amused to find "unsafe core_pattern" warning having these lines in
/etc/sysctl.conf:
fs.suid_dumpable=2
kernel.core_pattern=/core/core-%e-%p-%E
kernel.core_uses_pid=0
Turns out kernel is formally right. Default core_pattern is just "core",
which doesn't qualify for secure path while setting suid.dumpable.
Hint admins about solution, clarify sysctl names, delete unnecessary '\'
characters (string literals are concatenated regardless) and reformat for
easier grepping.
Link: http://lkml.kernel.org/r/20161029152124.GA1258@avx2
Pull x86 asm updates from Ingo Molnar:
"The main changes in this development cycle were:
- a large number of call stack dumping/printing improvements: higher
robustness, better cross-context dumping, improved output, etc.
(Josh Poimboeuf)
- vDSO getcpu() performance improvement for future Intel CPUs with
the RDPID instruction (Andy Lutomirski)
- add two new Intel AVX512 features and the CPUID support
infrastructure for it: AVX512IFMA and AVX512VBMI. (Gayatri Kammela,
He Chen)
- more copy-user unification (Borislav Petkov)
- entry code assembly macro simplifications (Alexander Kuleshov)
- vDSO C/R support improvements (Dmitry Safonov)
- misc fixes and cleanups (Borislav Petkov, Paul Bolle)"
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits)
scripts/decode_stacktrace.sh: Fix address line detection on x86
x86/boot/64: Use defines for page size
x86/dumpstack: Make stack name tags more comprehensible
selftests/x86: Add test_vdso to test getcpu()
x86/vdso: Use RDPID in preference to LSL when available
x86/dumpstack: Handle NULL stack pointer in show_trace_log_lvl()
x86/cpufeatures: Enable new AVX512 cpu features
x86/cpuid: Provide get_scattered_cpuid_leaf()
x86/cpuid: Cleanup cpuid_regs definitions
x86/copy_user: Unify the code by removing the 64-bit asm _copy_*_user() variants
x86/unwind: Ensure stack grows down
x86/vdso: Set vDSO pointer only after success
x86/prctl/uapi: Remove #ifdef for CHECKPOINT_RESTORE
x86/unwind: Detect bad stack return address
x86/dumpstack: Warn on stack recursion
x86/unwind: Warn on bad frame pointer
x86/decoder: Use stderr if insn sanity test fails
x86/decoder: Use stdout if insn decoder test is successful
mm/page_alloc: Remove kernel address exposure in free_reserved_area()
x86/dumpstack: Remove raw stack dump
Currently, when tracepoint_printk is set (enabled by the "tp_printk" kernel
command line), it causes trace events to print via printk(). This is a very
dangerous operation, but is useful for debugging.
The issue is, it's seldom used, but it is always checked even if it's not
enabled by the kernel command line. Instead of having this feature called by
a branch against a variable, turn that variable into a static key, and this
will remove the test and jump.
To simplify things, the functions output_printk() and
trace_event_buffer_commit() were moved from trace_events.c to trace.c.
