path: root/kernel/sysctl.c
2007-07-19coredump masking: bound suid_dumpable sysctlKawai, Hidehiro
This patch series is version 5 of the core dump masking feature, which controls which VMAs should be dumped based on their memory types and per-process flags. I adopted most of Andrew's suggestion at the previous version. He also suggested using system call instead of /proc/<pid>/ interface, I decided to use the latter continuously because adding new system call with pid argument will give a big impact on the kernel. You can access the per-process flags via /proc/<pid>/coredump_filter interface. coredump_filter represents a bitmask of memory types, and if a bit is set, VMAs of corresponding memory type are written into a core file when the process is dumped. The bitmask is inherited from the parent process when a process is created. The original purpose is to avoid longtime system slowdown when a number of processes which share a huge shared memory are dumped at the same time. To achieve this purpose, this patch series adds an ability to suppress dumping anonymous shared memory for specified processes. In this version, three other memory types are also supported. Here are the coredump_filter bits: bit 0: anonymous private memory bit 1: anonymous shared memory bit 2: file-backed private memory bit 3: file-backed shared memory The default value of coredump_filter is 0x3. This means the new core dump routine has the same behavior as conventional behavior by default. In this version, coredump_filter bits and mm.dumpable are merged into mm.flags, and it is accessed by atomic bitops. The supported core file formats are ELF and ELF-FDPIC. ELF has been tested, but ELF-FDPIC has not been built and tested because I don't have the test environment. This patch limits a value of suid_dumpable sysctl to the range of 0 to 2. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19audit: rework execve auditPeter Zijlstra
The purpose of audit_bprm() is to log the argv array to a userspace daemon at the end of the execve system call. Since user-space hasn't had time to run, this array is still in pristine state on the process' stack; so no need to copy it, we can just grab it from there. In order to minimize the damage to audit_log_*() copy each string into a temporary kernel buffer first. Currently the audit code requires that the full argument vector fits in a single packet. So currently it does clip the argv size to a (sysctl) limit, but only when execve auditing is enabled. If the audit protocol gets extended to allow for multiple packets this check can be removed. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ollie Wild <aaw@google.com> Cc: <linux-audit@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19PM: Integrate beeping flag with existing acpi_sleep flagsPavel Machek
Move "debug during resume from s2ram" into the variable we already use for real-mode flags to simplify code. It also closes nasty trap for the user in acpi_sleep_setup; order of parameters actually mattered there, acpi_sleep=s3_bios,s3_mode doing something different from acpi_sleep=s3_mode,s3_bios. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18Add common orderly_poweroff()Jeremy Fitzhardinge
Various pieces of code around the kernel want to be able to trigger an orderly poweroff. This pulls them together into a single implementation. By default the poweroff command is /sbin/poweroff, but it can be set via sysctl: kernel/poweroff_cmd. This is split at whitespace, so it can include command-line arguments. This patch replaces four other instances of invoking either "poweroff" or "shutdown -h now": two sbus drivers, and acpi thermal management. sparc64 has its own "powerd"; still need to determine whether it should be replaced by orderly_poweroff(). Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Acked-by: Len Brown <lenb@kernel.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Andi Kleen <ak@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: David S. Miller <davem@davemloft.net>
2007-07-17proper prototype for proc_nr_files()Adrian Bunk
Add a proper prototype for proc_nr_files() in include/linux/fs.h Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Allow huge page allocations to use GFP_HIGH_MOVABLEMel Gorman
Huge pages are not movable so are not allocated from ZONE_MOVABLE. However, as ZONE_MOVABLE will always have pages that can be migrated or reclaimed, it can be used to satisfy hugepage allocations even when the system has been running a long time. This allows an administrator to resize the hugepage pool at runtime depending on the size of ZONE_MOVABLE. This patch adds a new sysctl called hugepages_treat_as_movable. When a non-zero value is written to it, future allocations for the huge page pool will use ZONE_MOVABLE. Despite huge pages being non-movable, we do not introduce additional external fragmentation of note as huge pages are always the largest contiguous block we care about. [akpm@linux-foundation.org: various fixes] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Remove duplicate comments from sysctl.cLinus Torvalds
Randy Dunlap noticed that the recent comment clarifications from Andrew had somehow gotten duplicated. Quoth Andrew: "hm, that could have been some late-night reject-fixing." Fix it up. Cc: From: Andrew Morton <akpm@linux-foundation.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16sysctl.c: add text telling people to use CTL_UNNUMBEREDAndrew Morton
Hopefully this will help people to understand the new regime. Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16vdso: print fatal signalsIngo Molnar
Add the print-fatal-signals=1 boot option and the /proc/sys/kernel/print-fatal-signals runtime switch. This feature prints some minimal information about userspace segfaults to the kernel console. This is useful to find early bootup bugs where userspace debugging is very hard. Defaults to off. [akpm@linux-foundation.org: Don't add new sysctl numbers] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16change zonelist order: zonelist order selection logicKAMEZAWA Hiroyuki
Make zonelist creation policy selectable from sysctl/boot option v6. This patch makes NUMA's zonelist (of pgdat) order selectable. Available order are Default(automatic)/ Node-based / Zone-based. [Default Order] The kernel selects Node-based or Zone-based order automatically. [Node-based Order] This policy treats the locality of memory as the most important parameter. Zonelist order is created by each zone's locality. This means lower zones (ex. ZONE_DMA) can be used before higher zone (ex. ZONE_NORMAL) exhausion. IOW. ZONE_DMA will be in the middle of zonelist. current 2.6.21 kernel uses this. Pros. * A user can expect local memory as much as possible. Cons. * lower zone will be exhansted before higher zone. This may cause OOM_KILL. Maybe suitable if ZONE_DMA is relatively big and you never see OOM_KILL because of ZONE_DMA exhaution and you need the best locality. (example) assume 2 node NUMA. node(0) has ZONE_DMA/ZONE_NORMAL, node(1) has ZONE_NORMAL. *node(0)'s memory allocation order: node(0)'s NORMAL -> node(0)'s DMA -> node(1)'s NORMAL. *node(1)'s memory allocation order: node(1)'s NORMAL -> node(0)'s NORMAL -> node(0)'s DMA. [Zone-based order] This policy treats the zone type as the most important parameter. Zonelist order is created by zone-type order. This means lower zone never be used bofere higher zone exhaustion. IOW. ZONE_DMA will be always at the tail of zonelist. Pros. * OOM_KILL(bacause of lower zone) occurs only if the whole zones are exhausted. Cons. * memory locality may not be best. (example) assume 2 node NUMA. node(0) has ZONE_DMA/ZONE_NORMAL, node(1) has ZONE_NORMAL. *node(0)'s memory allocation order: node(0)'s NORMAL -> node(1)'s NORMAL -> node(0)'s DMA. *node(1)'s memory allocation order: node(1)'s NORMAL -> node(0)'s NORMAL -> node(0)'s DMA. bootoption "numa_zonelist_order=" and proc/sysctl is supporetd. command: %echo N > /proc/sys/vm/numa_zonelist_order Will rebuild zonelist in Node-based order. command: %echo Z > /proc/sys/vm/numa_zonelist_order Will rebuild zonelist in Zone-based order. Thanks to Lee Schermerhorn, he gives me much help and codes. [Lee.Schermerhorn@hp.com: add check_highest_zone to build_zonelists_in_zone_order] [akpm@linux-foundation.org: build fix] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: "jesse.barnes@intel.com" <jesse.barnes@intel.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-11security: Protection for exploiting null dereference using mmapEric Paris
Add a new security check on mmap operations to see if the user is attempting to mmap to low area of the address space. The amount of space protected is indicated by the new proc tunable /proc/sys/vm/mmap_min_addr and defaults to 0, preserving existing behavior. This patch uses a new SELinux security class "memprotect." Policy already contains a number of allow rules like a_t self:process * (unconfined_t being one of them) which mean that putting this check in the process class (its best current fit) would make it useless as all user processes, which we also want to protect against, would be allowed. By taking the memprotect name of the new class it will also make it possible for us to move some of the other memory protect permissions out of 'process' and into the new class next time we bump the policy version number (which I also think is a good future idea) Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-07-09sched: add CFS debug sysctlsIngo Molnar
add CFS debug sysctls: only tweakable if SCHED_DEBUG is enabled. This allows for faster debugging of scheduler problems. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-05-17make sysctl/kernel/core_pattern and fs/exec.c agree on maximum core filename ↵Dan Aloni
size Make sysctl/kernel/core_pattern and fs/exec.c agree on maximum core filename size and change it to 128, so that extensive patterns such as '/local/cores/%e-%h-%s-%t-%p.core' won't result in truncated filename generation. Signed-off-by: Dan Aloni <da-x@monatomic.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Make vm statistics update interval configurableChristoph Lameter
Make it configurable. Code in mm makes the vm statistics intervals independent from the cache reaper use that opportunity to make it configurable. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08proc: maps protectionKees Cook
The /proc/pid/ "maps", "smaps", and "numa_maps" files contain sensitive information about the memory location and usage of processes. Issues: - maps should not be world-readable, especially if programs expect any kind of ASLR protection from local attackers. - maps cannot just be 0400 because "-D_FORTIFY_SOURCE=2 -O2" makes glibc check the maps when %n is in a *printf call, and a setuid(getuid()) process wouldn't be able to read its own maps file. (For reference see http://lkml.org/lkml/2006/1/22/150) - a system-wide toggle is needed to allow prior behavior in the case of non-root applications that depend on access to the maps contents. This change implements a check using "ptrace_may_attach" before allowing access to read the maps contents. To control this protection, the new knob /proc/sys/kernel/maps_protect has been added, with corresponding updates to the procfs documentation. [akpm@linux-foundation.org: build fixes] [akpm@linux-foundation.org: New sysctl numbers are old hat] Signed-off-by: Kees Cook <kees@outflux.net> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-24Allow reading tainted flag as userBastian Blank
The commit 34f5a39899f3f3e815da64f48ddb72942d86c366 restricted reading of the tainted value. The attached patch changes this back to a write-only check and restores the read behaviour of older versions. Signed-off-by: Bastian Blank <bastian@waldi.eu.org> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05sysctl: Support vdso_enabled sysctl on SH.Paul Mundt
All of the logic for this was already in place, we just hadn't wired it up in the sysctl table. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-03-01[PATCH] fix the SYSCTL=n compilationAdrian Bunk
/home/bunk/linux/kernel-2.6/linux-2.6.20-mm2/kernel/sysctl.c:1411: error: conflicting types for 'register_sysctl_table' /home/bunk/linux/kernel-2.6/linux-2.6.20-mm2/include/linux/sysctl.h:1042: error: previous declaration of 'register_sysctl_table' was here make[2]: *** [kernel/sysctl.o] Error 1 Caused by commit 0b4d414714f0d2f922d39424b0c5c82ad900a381. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: add a parent entry to ctl_table and set the parent entryEric W. Biederman
Add a parent entry into the ctl_table so you can walk the list of parents and find the entire path to a ctl_table entry. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: reimplement the sysctl proc supportEric W. Biederman
With this change the sysctl inodes can be cached and nothing needs to be done when removing a sysctl table. For a cost of 2K code we will save about 4K of static tables (when we remove de from ctl_table) and 70K in proc_dir_entries that we will not allocate, or about half that on a 32bit arch. The speed feels about the same, even though we can now cache the sysctl dentries :( We get the core advantage that we don't need to have a 1 to 1 mapping between ctl table entries and proc files. Making it possible to have /proc/sys vary depending on the namespace you are in. The currently merged namespaces don't have an issue here but the network namespace under /proc/sys/net needs to have different directories depending on which network adapters are visible. By simply being a cache different directories being visible depending on who you are is trivial to implement. [akpm@osdl.org: fix uninitialised var] [akpm@osdl.org: fix ARM build] [bunk@stusta.de: make things static] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: allow sysctl_perm to be called from outside of sysctl.cEric W. Biederman
Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: factor out sysctl_head_next from do_sysctlEric W. Biederman
The current logic to walk through the list of sysctl table headers is slightly painful and implement in a way it cannot be used by code outside sysctl.c I am in the process of implementing a version of the sysctl proc support that instead of using the proc generic non-caching monster, just uses the existing sysctl data structure as backing store for building the dcache entries and for doing directory reads. To use the existing data structures however I need a way to get at them. [akpm@osdl.org: warning fix] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove support for directory strategy routinesEric W. Biederman
parse_table has support for calling a strategy routine when descending into a directory. To date no one has used this functionality and the /proc/sys interface has no analog to it. So no one is using this functionality kill it and make the binary sysctl code easier to follow. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove support for CTL_ANYEric W. Biederman
There are currently no users in the kernel for CTL_ANY and it only has effect on the binary interface which is practically unused. So this complicates sysctl lookups for no good reason so just remove it. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: create sys/fs/binfmt_misc as an ordinary sysctl entryEric W. Biederman
binfmt_misc has a mount point in the middle of the sysctl and that mount point is created as a proc_generic directory. Doing it that way gets in the way of cleaning up the sysctl proc support as it continues the existence of a horrible hack. So instead simply create the directory as an ordinary sysctl directory. At least that removes the magic special case. [akpm@osdl.org: warning fix] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: move SYSV IPC sysctls to their own fileEric W. Biederman
This is just a simple cleanup to keep kernel/sysctl.c from getting to crowded with special cases, and by keeping all of the ipc logic to together it makes the code a little more readable. [gcoady.lk@gmail.com: build fix] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Grant Coady <gcoady.lk@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: move utsname sysctls to their own fileEric W. Biederman
This is just a simple cleanup to keep kernel/sysctl.c from getting to crowded with special cases, and by keeping all of the utsname logic to together it makes the code a little more readable. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: move init_irq_proc into init/main where it belongsEric W. Biederman
2007-02-11[PATCH] _proc_do_string(): fix short readsOleg Nesterov
If you try to read things like /proc/sys/kernel/osrelease with single-byte reads, you get just one byte and then EOF. This is because _proc_do_string() assumes that the caller is read()ing into a buffer which is large enough to fit the whole string in a single hit. Fix. Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Michael Tokarev <mjt@tls.msk.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] sysctl warning fixAndrew Morton
kernel/sysctl.c:2816: warning: 'sysctl_ipc_data' defined but not used Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Add TAINT_USER and ability to set taint flags from userspaceTheodore Ts'o
Allow taint flags to be set from userspace by writing to /proc/sys/kernel/tainted, and add a new taint flag, TAINT_USER, to be used when userspace has potentially done something dangerous that might compromise the kernel. This will allow support personnel to ask further questions about what may have caused the user taint flag to have been set. For example, they might examine the logs of the realtime JVM to see if the Java program has used the really silly, stupid, dangerous, and completely-non-portable direct access to physical memory feature which MUST be implemented according to the Real-Time Specification for Java (RTSJ). Sigh. What were those silly people at Sun thinking? [akpm@osdl.org: build fix] [bunk@stusta.de: cleanup] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] sysctl_{,ms_}jiffies: fix oldlen semanticsAlexey Dobriyan
currently it's 1) if *oldlenp == 0, don't writeback anything 2) if *oldlenp >= table->maxlen, don't writeback more than table->maxlen bytes and rewrite *oldlenp don't look at underlying type granularity 3) if 0 < *oldlenp < table->maxlen, *cough* string sysctls don't writeback more than *oldlenp bytes. OK, that's because sizeof(char) == 1 int sysctls writeback anything in (0, table->maxlen] range Though accept integers divisible by sizeof(int) for writing. sysctl_jiffies and sysctl_ms_jiffies don't writeback anything but sizeof(int), which violates 1) and 2). So, make sysctl_jiffies and sysctl_ms_jiffies accept a) *oldlenp == 0, not doing writeback b) *oldlenp >= sizeof(int), writing one integer. -EINVAL still returned for *oldlenp == 1, 2, 3. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] make reading /proc/sys/kernel/cap-bould not require CAP_SYS_MODULEEric Paris
Reading /proc/sys/kernel/cap-bound requires CAP_SYS_MODULE. (see proc_dointvec_bset in kernel/sysctl.c) sysctl appears to drive all over proc reading everything it can get it's hands on and is complaining when it is being denied access to read cap-bound. Clearly writing to cap-bound should be a sensitive operation but requiring CAP_SYS_MODULE to read cap-bound seems a bit to strong. I believe the information could with reasonable certainty be obtained by looking at a bunch of the output of /proc/pid/status which has very low security protection, so at best we are just getting a little obfuscation of information. Currently SELinux policy has to 'dontaudit' capability checks for CAP_SYS_MODULE for things like sysctl which just want to read cap-bound. In doing so we also as a byproduct have to hide warnings of potential exploits such as if at some time that sysctl actually tried to load a module. I wondered if anyone would have a problem opening cap-bound up to read from anyone? Acked-by: Chris Wright <chrisw@sous-sol.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] debug: add sysrq_always_enabled boot optionIngo Molnar
Most distributions enable sysrq support but set it to 0 by default. Add a sysrq_always_enabled boot option to always-enable sysrq keys. Useful for debugging - without having to modify the disribution's config files (which might not be possible if the kernel is on a live CD, etc.). Also, while at it, clean up the sysrq interfaces. [bunk@stusta.de: make sysrq_always_enabled_setup() static] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[PATCH] sysctl: remove unused "context" paramAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andi Kleen <ak@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: David Howells <dhowells@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[PATCH] sysctl: remove some OPsAlexey Dobriyan
kernel.cap-bound uses only OP_SET and OP_AND Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[PATCH] ipc-procfs-sysctl mixupsRandy Dunlap
When CONFIG_PROC_FS=n and CONFIG_PROC_SYSCTL=n but CONFIG_SYSVIPC=y, we get this build error: kernel/built-in.o:(.data+0xc38): undefined reference to `proc_ipc_doulongvec_minmax' kernel/built-in.o:(.data+0xc88): undefined reference to `proc_ipc_doulongvec_minmax' kernel/built-in.o:(.data+0xcd8): undefined reference to `proc_ipc_dointvec' kernel/built-in.o:(.data+0xd28): undefined reference to `proc_ipc_dointvec' kernel/built-in.o:(.data+0xd78): undefined reference to `proc_ipc_dointvec' kernel/built-in.o:(.data+0xdc8): undefined reference to `proc_ipc_dointvec' kernel/built-in.o:(.data+0xe18): undefined reference to `proc_ipc_dointvec' make: *** [vmlinux] Error 1 Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] sysctl: fix sys_sysctl interface of ipc sysctlsEric W. Biederman
Currently there is a regression and the ipc sysctls don't show up in the binary sysctl namespace. This patch adds sysctl_ipc_data to read data/write from the appropriate namespace and deliver it in the expected manner. [akpm@osdl.org: warning fix] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] sysctl: simplify ipc ns specific sysctlsEric W. Biederman
Refactor the ipc sysctl support so that it is simpler, more readable, and prepares for fixing the bug with the wrong values being returned in the sys_sysctl interface. The function proc_do_ipc_string() was misnamed as it never handled strings. It's magic of when to work with strings and when to work with longs belonged in the sysctl table. I couldn't tell if the code would work if you disabled the ipc namespace but it certainly looked like it would have problems. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] sysctl: implement sysctl_uts_string()Eric W. Biederman
The problem: When using sys_sysctl we don't read the proper values for the variables exported from the uts namespace, nor do we do the proper locking. This patch introduces sysctl_uts_string which properly fetches the values and does the proper locking. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] sysctl: simplify sysctl_uts_stringEric W. Biederman
The binary interface to the namespace sysctls was never implemented resulting in some really weird things if you attempted to use sys_sysctl to read your hostname for example. This patch series simples the code a little and implements the binary sysctl interface. In testing this patch series I discovered that our 32bit compatibility for the binary sysctl interface is imperfect. In particular KERN_SHMMAX and KERN_SMMALL are size_t sized quantities and are returned as 8 bytes on to 32bit binaries using a x86_64 kernel. However this has existing for a long time so it is not a new regression with the namespace work. Gads the whole sysctl thing needs work before it stops being easy to shoot yourself in the foot. Looking forward a little bit we need a better way to handle sysctls and namespaces as our current technique will not work for the network namespace. I think something based on the current overlapping sysctl trees will work but the proc side needs to be redone before we can use it. This patch: Introduce get_uts() and put_uts() (used later) and remove most of the special cases for when UTS namespace is compiled in. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] kernel: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in linux/kernel/. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (156 commits) [PATCH] x86-64: Export smp_call_function_single [PATCH] i386: Clean up smp_tune_scheduling() [PATCH] unwinder: move .eh_frame to RODATA [PATCH] unwinder: fully support linker generated .eh_frame_hdr section [PATCH] x86-64: don't use set_irq_regs() [PATCH] x86-64: check vector in setup_ioapic_dest to verify if need setup_IO_APIC_irq [PATCH] x86-64: Make ix86 default to HIGHMEM4G instead of NOHIGHMEM [PATCH] i386: replace kmalloc+memset with kzalloc [PATCH] x86-64: remove remaining pc98 code [PATCH] x86-64: remove unused variable [PATCH] x86-64: Fix constraints in atomic_add_return() [PATCH] x86-64: fix asm constraints in i386 atomic_add_return [PATCH] x86-64: Correct documentation for bzImage protocol v2.05 [PATCH] x86-64: replace kmalloc+memset with kzalloc in MTRR code [PATCH] x86-64: Fix numaq build error [PATCH] x86-64: include/asm-x86_64/cpufeature.h isn't a userspace header [PATCH] unwinder: Add debugging output to the Dwarf2 unwinder [PATCH] x86-64: Clarify error message in GART code [PATCH] x86-64: Fix interrupt race in idle callback (3rd try) [PATCH] x86-64: Remove unwind stack pointer alignment forcing again ... Fixed conflict in include/linux/uaccess.h manually Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] struct seq_operations and struct file_operations constificationHelge Deller
- move some file_operations structs into the .rodata section - move static strings from policy_types[] array into the .rodata section - fix generic seq_operations usages, so that those structs may be defined as "const" as well [akpm@osdl.org: couple of fixes] Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] sysctl: string length calculated is wrong if it contains negative ↵BP, Praveen
numbers In the functions do_proc_dointvec() and do_proc_doulongvec_minmax(), there seems to be a bug in string length calculation if string contains negative integer. The console log given below explains the bug. Setting negative values may not be a right thing to do for "console log level" but then the test (given below) can be used to demonstrate the bug in the code. # echo "-1 -1 -1 -123456" > /proc/sys/kernel/printk # cat /proc/sys/kernel/printk -1 -1 -1 -1234 # # echo "-1 -1 -1 123456" > /proc/sys/kernel/printk # cat /proc/sys/kernel/printk -1 -1 -1 1234 # (akpm: the bug is that 123456 gets truncated) It works as expected if string contains all +ve integers # echo "1 2 3 4" > /proc/sys/kernel/printk # cat /proc/sys/kernel/printk 1 2 3 4 # The patch given below fixes the issue. Signed-off-by: Praveen BP <praveenbp@ti.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] new scheme to preempt swap tokenAshwin Chaugule
The new swap token patches replace the current token traversal algo. The old algo had a crude timeout parameter that was used to handover the token from one task to another. This algo, transfers the token to the tasks that are in need of the token. The urgency for the token is based on the number of times a task is required to swap-in pages. Accordingly, the priority of a task is incremented if it has been badly affected due to swap-outs. To ensure that the token doesnt bounce around rapidly, the token holders are given a priority boost. The priority of tasks is also decremented, if their rate of swap-in's keeps reducing. This way, the condition to check whether to pre-empt the swap token, is a matter of comparing two task's priority fields. [akpm@osdl.org: cleanups] Signed-off-by: Ashwin Chaugule <ashwin.chaugule@celunite.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] x86: add sysctl for kstack_depth_to_printChuck Ebbert
Add sysctl for kstack_depth_to_print. This lets users change the amount of raw stack data printed in dump_stack() without having to reboot. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-11-06[PATCH] sysctl: allow a zero ctl_name in the middle of a sysctl tableEric W. Biederman
Since it is becoming clear that there are just enough users of the binary sysctl interface that completely removing the binary interface from the kernel will not be an option for foreseeable future, we need to find a way to address the sysctl maintenance issues. The basic problem is that sysctl requires one central authority to allocate sysctl numbers, or else conflicts and ABI breakage occur. The proc interface to sysctl does not have that problem, as names are not densely allocated. By not terminating a sysctl table until I have neither a ctl_name nor a procname, it becomes simple to add sysctl entries that don't show up in the binary sysctl interface. Which allows people to avoid allocating a binary sysctl value when not needed. I have audited the kernel code and in my reading I have not found a single sysctl table that wasn't terminated by a completely zero filled entry. So this change in behavior should not affect anything. I think this mechanism eases the pain enough that combined with a little disciple we can solve the reoccurring sysctl ABI breakage. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-06[PATCH] Improve the removed sysctl warningsEric W. Biederman
Don't warn about libpthread's access to kernel.version. When it receives -ENOSYS it will read /proc/sys/kernel/version. If anything else shows up print the sysctl number string. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Cal Peake <cp@absolutedigital.net> Cc: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
