path: root/kernel/softirq.c
2013-04-30kernel/smp.c: remove 'priv' of call_single_dataliguang
The 'priv' field is redundant; we can pass data via 'info'. Signed-off-by: liguang <lig.fnst@cn.fujitsu.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-05Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes and cleanups from Thomas Gleixner: "Commit e5ab012c3271 ("nohz: Make tick_nohz_irq_exit() irq safe") is the first commit in the series and the minimal necessary bugfix, which needs to go back into stable. The remanining commits enforce irq disabling in irq_exit(), sanitize the hardirq/softirq preempt count transition and remove a bunch of no longer necessary conditionals." I personally love getting rid of the very subtle and confusing IRQ_EXIT_OFFSET thing. Even apart from the whole "more lines removed than added" thing. * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irq: Don't re-enable interrupts at the end of irq_exit irq: Remove IRQ_EXIT_OFFSET workaround Revert "nohz: Make tick_nohz_irq_exit() irq safe" irq: Sanitize invoke_softirq irq: Ensure irq_exit() code runs with interrupts disabled nohz: Make tick_nohz_irq_exit() irq safe
2013-02-28irq: Don't re-enable interrupts at the end of irq_exitFrederic Weisbecker
Commit 74eed0163d0def3fce27228d9ccf3d36e207b286 "irq: Ensure irq_exit() code runs with interrupts disabled" restore interrupts flags in the end of irq_exit() for archs that don't define __ARCH_IRQ_EXIT_IRQS_DISABLED. However always returning from irq_exit() with interrupts disabled should not be a problem for these archs. Prior to this commit this was already happening anytime we processed pending softirqs anyway. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2013-02-22irq: Remove IRQ_EXIT_OFFSET workaroundFrederic Weisbecker
The IRQ_EXIT_OFFSET trick was used to make sure the irq doesn't get preempted after we substract the HARDIRQ_OFFSET until we are entirely done with any code in irq_exit(). This workaround was necessary because some archs may call irq_exit() with irqs enabled and there is still some code in the end of this function that is not covered by the HARDIRQ_OFFSET but want to stay non-preemptible. Now that irq are always disabled in irq_exit(), the whole code is guaranteed not to be preempted. We can thus remove this hack. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2013-02-21irq: Sanitize invoke_softirqThomas Gleixner
With the irq protection in irq_exit, we can remove the #ifdeffery and the bh_disable/enable dance in invoke_softirq() Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linuxfoundation.org> Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1302202155320.22263@ionos
2013-02-21irq: Ensure irq_exit() code runs with interrupts disabledThomas Gleixner
We had already a few problems with code called from irq_exit() when interrupted from a nesting interrupt. This can happen on architectures which do not define __ARCH_IRQ_EXIT_IRQS_DISABLED. __ARCH_IRQ_EXIT_IRQS_DISABLED should go away and we want to make it mandatory to call irq_exit() with interrupts disabled. As a temporary protection disable interrupts for those architectures which do not define __ARCH_IRQ_EXIT_IRQS_DISABLED and add a WARN_ONCE when an architecture which defines __ARCH_IRQ_EXIT_IRQS_DISABLED calls irq_exit() with interrupts enabled. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linuxfoundation.org> Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1302202155320.22263@ionos
2013-02-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking update from David Miller: 1) Checkpoint/restarted TCP sockets now can properly propagate the TCP timestamp offset. From Andrey Vagin. 2) VMWARE VM VSOCK layer, from Andy King. 3) Much improved support for virtual functions and SR-IOV in bnx2x, from Ariel ELior. 4) All protocols on ipv4 and ipv6 are now network namespace aware, and all the compatability checks for initial-namespace-only protocols is removed. Thanks to Tom Parkin for helping deal with the last major holdout, L2TP. 5) IPV6 support in netpoll and network namespace support in pktgen, from Cong Wang. 6) Multiple Registration Protocol (MRP) and Multiple VLAN Registration Protocol (MVRP) support, from David Ward. 7) Compute packet lengths more accurately in the packet scheduler, from Eric Dumazet. 8) Use per-task page fragment allocator in skb_append_datato_frags(), also from Eric Dumazet. 9) Add support for connection tracking labels in netfilter, from Florian Westphal. 10) Fix default multicast group joining on ipv6, and add anti-spoofing checks to 6to4 and 6rd. From Hannes Frederic Sowa. 11) Make ipv4/ipv6 fragmentation memory limits more reasonable in modern times, rearrange inet frag datastructures for better cacheline locality, and move more operations outside of locking. From Jesper Dangaard Brouer. 12) Instead of strict master <--> slave relationships, allow arbitrary scenerios with "upper device lists". From Jiri Pirko. 13) Improve rate limiting accuracy in TBF and act_police, also from Jiri Pirko. 14) Add a BPF filter netfilter match target, from Willem de Bruijn. 15) Orphan and delete a bunch of pre-historic networking drivers from Paul Gortmaker. 16) Add TSO support for GRE tunnels, from Pravin B SHelar. Although this still needs some minor bug fixing before it's %100 correct in all cases. 17) Handle unresolved IPSEC states like ARP, with a resolution packet queue. From Steffen Klassert. 18) Remove TCP Appropriate Byte Count support (ABC), from Stephen Hemminger. This was long overdue. 19) Support SO_REUSEPORT, from Tom Herbert. 20) Allow locking a socket BPF filter, so that it cannot change after a process drops capabilities. 21) Add VLAN filtering to bridge, from Vlad Yasevich. 22) Bring ipv6 on-par with ipv4 and do not cache neighbour entries in the ipv6 routes, from YOSHIFUJI Hideaki. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1538 commits) ipv6: fix race condition regarding dst->expires and dst->from. net: fix a wrong assignment in skb_split() ip_gre: remove an extra dst_release() ppp: set qdisc_tx_busylock to avoid LOCKDEP splat atl1c: restore buffer state net: fix a build failure when !CONFIG_PROC_FS net: ipv4: fix waring -Wunused-variable net: proc: fix build failed when procfs is not configured Revert "xen: netback: remove redundant xenvif_put" net: move procfs code to net/core/net-procfs.c qmi_wwan, cdc-ether: add ADU960S bonding: set sysfs device_type to 'bond' bonding: fix bond_release_all inconsistencies b44: use netdev_alloc_skb_ip_align() xen: netback: remove redundant xenvif_put net: fec: Do a sanity check on the gpio number ip_gre: propogate target device GSO capability to the tunnel device ip_gre: allow CSUM capable devices to handle packets bonding: Fix initialize after use for 3ad machine state spinlock bonding: Fix race condition between bond_enslave() and bond_3ad_update_lacp_rate() ...
2013-01-27cputime: Safely read cputime of full dynticks CPUsFrederic Weisbecker
While remotely reading the cputime of a task running in a full dynticks CPU, the values stored in utime/stime fields of struct task_struct may be stale. Its values may be those of the last kernel <-> user transition time snapshot and we need to add the tickless time spent since this snapshot. To fix this, flush the cputime of the dynticks CPUs on kernel <-> user transition and record the time / context where we did this. Then on top of this snapshot and the current time, perform the fixup on the reader side from task_times() accessors. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> [fixed kvm module related build errors] Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
2013-01-10softirq: reduce latenciesEric Dumazet
In various network workloads, __do_softirq() latencies can be up to 20 ms if HZ=1000, and 200 ms if HZ=100. This is because we iterate 10 times in the softirq dispatcher, and some actions can consume a lot of cycles. This patch changes the fallback to ksoftirqd condition to : - A time limit of 2 ms. - need_resched() being set on current task When one of this condition is met, we wakeup ksoftirqd for further softirq processing if we still have pending softirqs. Using need_resched() as the only condition can trigger RCU stalls, as we can keep BH disabled for too long. I ran several benchmarks and got no significant difference in throughput, but a very significant reduction of latencies (one order of magnitude) : In following bench, 200 antagonist "netperf -t TCP_RR" are started in background, using all available cpus. Then we start one "netperf -t TCP_RR", bound to the cpu handling the NIC IRQ (hard+soft) Before patch : # netperf -H 7.7.7.84 -t TCP_RR -T2,2 -- -k RT_LATENCY,MIN_LATENCY,MAX_LATENCY,P50_LATENCY,P90_LATENCY,P99_LATENCY,MEAN_LATENCY,STDDEV_LATENCY MIGRATED TCP REQUEST/RESPONSE TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to 7.7.7.84 () port 0 AF_INET : first burst 0 : cpu bind RT_LATENCY=550110.424 MIN_LATENCY=146858 MAX_LATENCY=997109 P50_LATENCY=305000 P90_LATENCY=550000 P99_LATENCY=710000 MEAN_LATENCY=376989.12 STDDEV_LATENCY=184046.92 After patch : # netperf -H 7.7.7.84 -t TCP_RR -T2,2 -- -k RT_LATENCY,MIN_LATENCY,MAX_LATENCY,P50_LATENCY,P90_LATENCY,P99_LATENCY,MEAN_LATENCY,STDDEV_LATENCY MIGRATED TCP REQUEST/RESPONSE TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to 7.7.7.84 () port 0 AF_INET : first burst 0 : cpu bind RT_LATENCY=40545.492 MIN_LATENCY=9834 MAX_LATENCY=78366 P50_LATENCY=33583 P90_LATENCY=59000 P99_LATENCY=69000 MEAN_LATENCY=38364.67 STDDEV_LATENCY=12865.26 Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: David Miller <davem@davemloft.net> Cc: Tom Herbert <therbert@google.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-29cputime: Specialize irq vtime hooksFrederic Weisbecker
With CONFIG_VIRT_CPU_ACCOUNTING, when vtime_account() is called in irq entry/exit, we perform a check on the context: if we are interrupting the idle task we account the pending cputime to idle, otherwise account to system time or its sub-areas: tsk->stime, hardirq time, softirq time, ... However this check for idle only concerns the hardirq entry and softirq entry: * Hardirq may directly interrupt the idle task, in which case we need to flush the pending CPU time to idle. * The idle task may be directly interrupted by a softirq if it calls local_bh_enable(). There is probably no such call in any idle task but we need to cover every case. Ksoftirqd is not concerned because the idle time is flushed on context switch and softirq in the end of hardirq have the idle time already flushed from the hardirq entry. In the other cases we always account to system/irq time: * On hardirq exit we account the time to hardirq time. * On softirq exit we account the time to softirq time. To optimize this and avoid the indirect call to vtime_account() and the checks it performs, specialize the vtime irq APIs and only perform the check on irq entry. Irq exit can directly call vtime_account_system(). CONFIG_IRQ_TIME_ACCOUNTING behaviour doesn't change and directly maps to its own vtime_account() implementation. One may want to take benefits from the new APIs to optimize irq time accounting as well in the future. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-10-01Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "Continued quest to clean up and enhance the cputime code by Frederic Weisbecker, in preparation for future tickless kernel features. Other than that, smallish changes." Fix up trivial conflicts due to additions next to each other in arch/{x86/}Kconfig * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) cputime: Make finegrained irqtime accounting generally available cputime: Gather time/stats accounting config options into a single menu ia64: Reuse system and user vtime accounting functions on task switch ia64: Consolidate user vtime accounting vtime: Consolidate system/idle context detection cputime: Use a proper subsystem naming for vtime related APIs sched: cpu_power: enable ARCH_POWER sched/nohz: Clean up select_nohz_load_balancer() sched: Fix load avg vs. cpu-hotplug sched: Remove __ARCH_WANT_INTERRUPTS_ON_CTXSW sched: Fix nohz_idle_balance() sched: Remove useless code in yield_to() sched: Add time unit suffix to sched sysctl knobs sched/debug: Limit sd->*_idx range on sysctl sched: Remove AFFINE_WAKEUPS feature flag s390: Remove leftover account_tick_vtime() header cputime: Consolidate vtime handling on context switch sched: Move cputime code to its own file cputime: Generalize CONFIG_VIRT_CPU_ACCOUNTING tile: Remove SD_PREFER_LOCAL leftover ...
2012-09-25cputime: Use a proper subsystem naming for vtime related APIsFrederic Weisbecker
Use a naming based on vtime as a prefix for virtual based cputime accounting APIs: - account_system_vtime() -> vtime_account() - account_switch_vtime() -> vtime_task_switch() It makes it easier to allow for further declension such as vtime_account_system(), vtime_account_idle(), ... if we want to find out the context we account to from generic code. This also make it better to know on which subsystem these APIs refer to. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2012-08-13softirq: Use hotplug thread infrastructureThomas Gleixner
[ paulmck: Call rcu_note_context_switch() with interrupts enabled. ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20120716103948.456416747@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-07-31mm: allow PF_MEMALLOC from softirq contextMel Gorman
This is needed to allow network softirq packet processing to make use of PF_MEMALLOC. Currently softirq context cannot use PF_MEMALLOC due to it not being associated with a task, and therefore not having task flags to fiddle with - thus the gfp to alloc flag mapping ignores the task flags when in interrupts (hard or soft) context. Allowing softirqs to make use of PF_MEMALLOC therefore requires some trickery. This patch borrows the task flags from whatever process happens to be preempted by the softirq. It then modifies the gfp to alloc flags mapping to not exclude task flags in softirq context, and modify the softirq code to save, clear and restore the PF_MEMALLOC flag. The save and clear, ensures the preempted task's PF_MEMALLOC flag doesn't leak into the softirq. The restore ensures a softirq's PF_MEMALLOC flag cannot leak back into the preempted process. This should be safe due to the following reasons Softirqs can run on multiple CPUs sure but the same task should not be executing the same softirq code. Neither should the softirq handler be preempted by any other softirq handler so the flags should not leak to an unrelated softirq. Softirqs re-enable hardware interrupts in __do_softirq() so can be preempted by hardware interrupts so PF_MEMALLOC is inherited by the hard IRQ. However, this is similar to a process in reclaim being preempted by a hardirq. While PF_MEMALLOC is set, gfp_to_alloc_flags() distinguishes between hard and soft irqs and avoids giving a hardirq the ALLOC_NO_WATERMARKS flag. If the softirq is deferred to ksoftirq then its flags may be used instead of a normal tasks but as the softirq cannot be preempted, the PF_MEMALLOC flag does not leak to other code by accident. [davem@davemloft.net: Document why PF_MEMALLOC is safe] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: David Miller <davem@davemloft.net> Cc: Neil Brown <neilb@suse.de> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: Eric B Munson <emunson@mgebm.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: Mel Gorman <mgorman@suse.de> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-20Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer changes for v3.4 from Ingo Molnar * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (32 commits) ntp: Fix integer overflow when setting time math: Introduce div64_long cs5535-clockevt: Allow the MFGPT IRQ to be shared cs5535-clockevt: Don't ignore MFGPT on SMP-capable kernels x86/time: Eliminate unused irq0_irqs counter clocksource: scx200_hrt: Fix the build x86/tsc: Reduce the TSC sync check time for core-siblings timer: Fix bad idle check on irq entry nohz: Remove ts->Einidle checks before restarting the tick nohz: Remove update_ts_time_stat from tick_nohz_start_idle clockevents: Leave the broadcast device in shutdown mode when not needed clocksource: Load the ACPI PM clocksource asynchronously clocksource: scx200_hrt: Convert scx200 to use clocksource_register_hz clocksource: Get rid of clocksource_calc_mult_shift() clocksource: dbx500: convert to clocksource_register_hz() clocksource: scx200_hrt: use pr_<level> instead of printk time: Move common updates to a function time: Reorder so the hot data is together time: Remove most of xtime_lock usage in timekeeping.c ntp: Add ntp_lock to replace xtime_locking ...
2012-03-20Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes for v3.4 from Ingo Molnar * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits) printk: Make it compile with !CONFIG_PRINTK sched/x86: Fix overflow in cyc2ns_offset sched: Fix nohz load accounting -- again! sched: Update yield() docs printk/sched: Introduce special printk_sched() for those awkward moments sched/nohz: Correctly initialize 'next_balance' in 'nohz' idle balancer sched: Cleanup cpu_active madness sched: Fix load-balance wreckage sched: Clean up parameter passing of proc_sched_autogroup_set_nice() sched: Ditch per cgroup task lists for load-balancing sched: Rename load-balancing fields sched: Move load-balancing arguments into helper struct sched/rt: Do not submit new work when PI-blocked sched/rt: Prevent idle task boosting sched/wait: Add __wake_up_all_locked() API sched/rt: Document scheduler related skip-resched-check sites sched/rt: Use schedule_preempt_disabled() sched/rt: Add schedule_preempt_disabled() sched/rt: Do not throttle when PI boosting sched/rt: Keep period timer ticking when rt throttling is active ...
2012-03-20Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf events changes for v3.4 from Ingo Molnar: - New "hardware based branch profiling" feature both on the kernel and the tooling side, on CPUs that support it. (modern x86 Intel CPUs with the 'LBR' hardware feature currently.) This new feature is basically a sophisticated 'magnifying glass' for branch execution - something that is pretty difficult to extract from regular, function histogram centric profiles. The simplest mode is activated via 'perf record -b', and the result looks like this in perf report: $ perf record -b any_call,u -e cycles:u branchy $ perf report -b --sort=symbol 52.34% [.] main [.] f1 24.04% [.] f1 [.] f3 23.60% [.] f1 [.] f2 0.01% [k] _IO_new_file_xsputn [k] _IO_file_overflow 0.01% [k] _IO_vfprintf_internal [k] _IO_new_file_xsputn 0.01% [k] _IO_vfprintf_internal [k] strchrnul 0.01% [k] __printf [k] _IO_vfprintf_internal 0.01% [k] main [k] __printf This output shows from/to branch columns and shows the highest percentage (from,to) jump combinations - i.e. the most likely taken branches in the system. "branches" can also include function calls and any other synchronous and asynchronous transitions of the instruction pointer that are not 'next instruction' - such as system calls, traps, interrupts, etc. This feature comes with (hopefully intuitive) flat ascii and TUI support in perf report. - Various 'perf annotate' visual improvements for us assembly junkies. It will now recognize function calls in the TUI and by hitting enter you can follow the call (recursively) and back, amongst other improvements. - Multiple threads/processes recording support in perf record, perf stat, perf top - which is activated via a comma-list of PIDs: perf top -p 21483,21485 perf stat -p 21483,21485 -ddd perf record -p 21483,21485 - Support for per UID views, via the --uid paramter to perf top, perf report, etc. For example 'perf top --uid mingo' will only show the tasks that I am running, excluding other users, root, etc. - Jump label restructurings and improvements - this includes the factoring out of the (hopefully much clearer) include/linux/static_key.h generic facility: struct static_key key = STATIC_KEY_INIT_FALSE; ... if (static_key_false(&key)) do unlikely code else do likely code ... static_key_slow_inc(); ... static_key_slow_inc(); ... The static_key_false() branch will be generated into the code with as little impact to the likely code path as possible. the static_key_slow_*() APIs flip the branch via live kernel code patching. This facility can now be used more widely within the kernel to micro-optimize hot branches whose likelihood matches the static-key usage and fast/slow cost patterns. - SW function tracer improvements: perf support and filtering support. - Various hardenings of the perf.data ABI, to make older perf.data's smoother on newer tool versions, to make new features integrate more smoothly, to support cross-endian recording/analyzing workflows better, etc. - Restructuring of the kprobes code, the splitting out of 'optprobes', and a corner case bugfix. - Allow the tracing of kernel console output (printk). - Improvements/fixes to user-space RDPMC support, allowing user-space self-profiling code to extract PMU counts without performing any system calls, while playing nice with the kernel side. - 'perf bench' improvements - ... and lots of internal restructurings, cleanups and fixes that made these features possible. And, as usual this list is incomplete as there were also lots of other improvements * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (120 commits) perf report: Fix annotate double quit issue in branch view mode perf report: Remove duplicate annotate choice in branch view mode perf/x86: Prettify pmu config literals perf report: Enable TUI in branch view mode perf report: Auto-detect branch stack sampling mode perf record: Add HEADER_BRANCH_STACK tag perf record: Provide default branch stack sampling mode option perf tools: Make perf able to read files from older ABIs perf tools: Fix ABI compatibility bug in print_event_desc() perf tools: Enable reading of perf.data files from different ABI rev perf: Add ABI reference sizes perf report: Add support for taken branch sampling perf record: Add support for sampling taken branch perf tools: Add code to support PERF_SAMPLE_BRANCH_STACK x86/kprobes: Split out optprobe related code to kprobes-opt.c x86/kprobes: Fix a bug which can modify kernel code permanently x86/kprobes: Fix instruction recovery on optimized path perf: Add callback to flush branch_stack on context switch perf: Disable PERF_SAMPLE_BRANCH_* when not supported perf/x86: Add LBR software filter support for Intel CPUs ...
2012-03-06softirq: Reduce invoke_softirq() code duplicationHeiko Carstens
The two invoke_softirq() variants are identical except for a single line. So move the #ifdef __ARCH_IRQ_EXIT_IRQS_DISABLED inside one of the functions and get rid of the other one. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-01sched/rt: Document scheduler related skip-resched-check sitesThomas Gleixner
Create a distinction between scheduler related preempt_enable_no_resched() calls and the nearly one hundred other places in the kernel that do not want to reschedule, for one reason or another. This distinction matters for -rt, where the scheduler and the non-scheduler preempt models (and checks) are different. For upstream it's purely documentational. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/n/tip-gs88fvx2mdv5psnzxnv575ke@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-01sched/rt: Use schedule_preempt_disabled()Thomas Gleixner
Coccinelle based conversion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-15timer: Fix bad idle check on irq entryFrederic Weisbecker
idle_cpu() is called on irq entry to guess if we need to call tick_check_idle(). This way we can catch up with jiffies if the tick was stopped, stop accounting idle time during the interrupt and maintain the sched clock if it is unstable. But if we are going to exit the idle loop to schedule a new task (ie: if we have a task in the runqueue or a remotely enqueued ttwu to perform), the idle_cpu() check will return 0 such that we miss the call to tick_check_idle() for all interrupts happening before we schedule the new task. As a result these interrupts and the softirqs coming along may deal with stale jiffies values, bad sched clock values, and won't substract their time from the idle time accounting. Fix this with using is_idle_task() instead that strictly checks that we are running the idle task, without caring about the fact we are going to schedule a task soon. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: John Stultz <john.stultz@linaro.org> Cc: Ingo Molnar <mingo@elte.hu> Link: http://lkml.kernel.org/r/1327427984-23282-3-git-send-email-fweisbec@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-02-03tracing/softirq: Move __raise_softirq_irqoff() out of headerSteven Rostedt
The __raise_softirq_irqoff() contains a tracepoint. As tracepoints in headers can cause issues, and not to mention, bloats the kernel when they are in a static inline, it is best to move the function that contains the tracepoint out of the header and into softirq.c. Link: http://lkml.kernel.org/r/20120118120711.GB14863@elte.hu Suggested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-12-11rcu: Fix early call to rcu_idle_enter()Frederic Weisbecker
On the irq exit path, tick_nohz_irq_exit() may raise a softirq, which action leads to the wake up path and select_task_rq_fair() that makes use of rcu to iterate the domains. This is an illegal use of RCU because we may be in RCU extended quiescent state if we interrupted an RCU-idle window in the idle loop: [ 132.978883] =============================== [ 132.978883] [ INFO: suspicious RCU usage. ] [ 132.978883] ------------------------------- [ 132.978883] kernel/sched_fair.c:1707 suspicious rcu_dereference_check() usage! [ 132.978883] [ 132.978883] other info that might help us debug this: [ 132.978883] [ 132.978883] [ 132.978883] rcu_scheduler_active = 1, debug_locks = 0 [ 132.978883] RCU used illegally from extended quiescent state! [ 132.978883] 2 locks held by swapper/0: [ 132.978883] #0: (&p->pi_lock){-.-.-.}, at: [<ffffffff8105a729>] try_to_wake_up+0x39/0x2f0 [ 132.978883] #1: (rcu_read_lock){.+.+..}, at: [<ffffffff8105556a>] select_task_rq_fair+0x6a/0xec0 [ 132.978883] [ 132.978883] stack backtrace: [ 132.978883] Pid: 0, comm: swapper Tainted: G W 3.0.0+ #178 [ 132.978883] Call Trace: [ 132.978883] <IRQ> [<ffffffff810a01f6>] lockdep_rcu_suspicious+0xe6/0x100 [ 132.978883] [<ffffffff81055c49>] select_task_rq_fair+0x749/0xec0 [ 132.978883] [<ffffffff8105556a>] ? select_task_rq_fair+0x6a/0xec0 [ 132.978883] [<ffffffff812fe494>] ? do_raw_spin_lock+0x54/0x150 [ 132.978883] [<ffffffff810a1f2d>] ? trace_hardirqs_on+0xd/0x10 [ 132.978883] [<ffffffff8105a7c3>] try_to_wake_up+0xd3/0x2f0 [ 132.978883] [<ffffffff81094f98>] ? ktime_get+0x68/0xf0 [ 132.978883] [<ffffffff8105aa35>] wake_up_process+0x15/0x20 [ 132.978883] [<ffffffff81069dd5>] raise_softirq_irqoff+0x65/0x110 [ 132.978883] [<ffffffff8108eb65>] __hrtimer_start_range_ns+0x415/0x5a0 [ 132.978883] [<ffffffff812fe3ee>] ? do_raw_spin_unlock+0x5e/0xb0 [ 132.978883] [<ffffffff8108ed08>] hrtimer_start+0x18/0x20 [ 132.978883] [<ffffffff8109c9c3>] tick_nohz_stop_sched_tick+0x393/0x450 [ 132.978883] [<ffffffff810694f2>] irq_exit+0xd2/0x100 [ 132.978883] [<ffffffff81829e96>] do_IRQ+0x66/0xe0 [ 132.978883] [<ffffffff81820d53>] common_interrupt+0x13/0x13 [ 132.978883] <EOI> [<ffffffff8103434b>] ? native_safe_halt+0xb/0x10 [ 132.978883] [<ffffffff810a1f2d>] ? trace_hardirqs_on+0xd/0x10 [ 132.978883] [<ffffffff810144ea>] default_idle+0xba/0x370 [ 132.978883] [<ffffffff810147fe>] amd_e400_idle+0x5e/0x130 [ 132.978883] [<ffffffff8100a9f6>] cpu_idle+0xb6/0x120 [ 132.978883] [<ffffffff817f217f>] rest_init+0xef/0x150 [ 132.978883] [<ffffffff817f20e2>] ? rest_init+0x52/0x150 [ 132.978883] [<ffffffff81ed9cf3>] start_kernel+0x3da/0x3e5 [ 132.978883] [<ffffffff81ed9346>] x86_64_start_reservations+0x131/0x135 [ 132.978883] [<ffffffff81ed944d>] x86_64_start_kernel+0x103/0x112 Fix this by calling rcu_idle_enter() after tick_nohz_irq_exit(). Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-12-11nohz: Separate out irq exit and idle loop dyntick logicFrederic Weisbecker
The tick_nohz_stop_sched_tick() function, which tries to delay the next timer tick as long as possible, can be called from two places: - From the idle loop to start the dytick idle mode - From interrupt exit if we have interrupted the dyntick idle mode, so that we reprogram the next tick event in case the irq changed some internal state that requires this action. There are only few minor differences between both that are handled by that function, driven by the ts->inidle cpu variable and the inidle parameter. The whole guarantees that we only update the dyntick mode on irq exit if we actually interrupted the dyntick idle mode, and that we enter in RCU extended quiescent state from idle loop entry only. Split this function into: - tick_nohz_idle_enter(), which sets ts->inidle to 1, enters dynticks idle mode unconditionally if it can, and enters into RCU extended quiescent state. - tick_nohz_irq_exit() which only updates the dynticks idle mode when ts->inidle is set (ie: if tick_nohz_idle_enter() has been called). To maintain symmetry, tick_nohz_restart_sched_tick() has been renamed into tick_nohz_idle_exit(). This simplifies the code and micro-optimize the irq exit path (no need for local_irq_save there). This also prepares for the split between dynticks and rcu extended quiescent state logics. We'll need this split to further fix illegal uses of RCU in extended quiescent states in the idle loop. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: David Miller <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-10-31kernel: Map most files to use export.h instead of module.hPaul Gortmaker
The changed files were only including linux/module.h for the EXPORT_SYMBOL infrastructure, and nothing else. Revector them onto the isolated export header for faster compile times. Nothing to see here but a whole lot of instances of: -#include <linux/module.h> +#include <linux/export.h> This commit is only changing the kernel dir; next targets will probably be mm, fs, the arch dirs, etc. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-07-20softirq,rcu: Inform RCU of irq_exit() activityPeter Zijlstra
The rcu_read_unlock_special() function relies on in_irq() to exclude scheduler activity from interrupt level. This fails because exit_irq() can invoke the scheduler after clearing the preempt_count() bits that in_irq() uses to determine that it is at interrupt level. This situation can result in failures as follows: $task IRQ SoftIRQ rcu_read_lock() /* do stuff */ <preempt> |= UNLOCK_BLOCKED rcu_read_unlock() --t->rcu_read_lock_nesting irq_enter(); /* do stuff, don't use RCU */ irq_exit(); sub_preempt_count(IRQ_EXIT_OFFSET); invoke_softirq() ttwu(); spin_lock_irq(&pi->lock) rcu_read_lock(); /* do stuff */ rcu_read_unlock(); rcu_read_unlock_special() rcu_report_exp_rnp() ttwu() spin_lock_irq(&pi->lock) /* deadlock */ rcu_read_unlock_special(t); Ed can simply trigger this 'easy' because invoke_softirq() immediately does a ttwu() of ksoftirqd/# instead of doing the in-place softirq stuff first, but even without that the above happens. Cure this by also excluding softirqs from the rcu_read_unlock_special() handler and ensuring the force_irqthreads ksoftirqd/# wakeup is done from full softirq context. [ Alternatively, delaying the ->rcu_read_lock_nesting decrement until after the special handling would make the thing more robust in the face of interrupts as well. And there is a separate patch for that. ] Cc: Thomas Gleixner <tglx@linutronix.de> Reported-and-tested-by: Ed Tomlinson <edt@aei.ca> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-06-14rcu: Use softirq to address performance regressionShaohua Li
Commit a26ac2455ffcf3(rcu: move TREE_RCU from softirq to kthread) introduced performance regression. In an AIM7 test, this commit degraded performance by about 40%. The commit runs rcu callbacks in a kthread instead of softirq. We observed high rate of context switch which is caused by this. Out test system has 64 CPUs and HZ is 1000, so we saw more than 64k context switch per second which is caused by RCU's per-CPU kthread. A trace showed that most of the time the RCU per-CPU kthread doesn't actually handle any callbacks, but instead just does a very small amount of work handling grace periods. This means that RCU's per-CPU kthreads are making the scheduler do quite a bit of work in order to allow a very small amount of RCU-related processing to be done. Alex Shi's analysis determined that this slowdown is due to lock contention within the scheduler. Unfortunately, as Peter Zijlstra points out, the scheduler's real-time semantics require global action, which means that this contention is inherent in real-time scheduling. (Yes, perhaps someone will come up with a workaround -- otherwise, -rt is not going to do well on large SMP systems -- but this patch will work around this issue in the meantime. And "the meantime" might well be forever.) This patch therefore re-introduces softirq processing to RCU, but only for core RCU work. RCU callbacks are still executed in kthread context, so that only a small amount of RCU work runs in softirq context in the common case. This should minimize ksoftirqd execution, allowing us to skip boosting of ksoftirqd for CONFIG_RCU_BOOST=y kernels. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Tested-by: "Alex,Shi" <alex.shi@intel.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-05-05rcu: move TREE_RCU from softirq to kthreadPaul E. McKenney
If RCU priority boosting is to be meaningful, callback invocation must be boosted in addition to preempted RCU readers. Otherwise, in presence of CPU real-time threads, the grace period ends, but the callbacks don't get invoked. If the callbacks don't get invoked, the associated memory doesn't get freed, so the system is still subject to OOM. But it is not reasonable to priority-boost RCU_SOFTIRQ, so this commit moves the callback invocations to a kthread, which can be boosted easily. Also add comments and properly synchronized all accesses to rcu_cpu_kthread_task, as suggested by Lai Jiangshan. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-03-22kthread: use kthread_create_on_node()Eric Dumazet
ksoftirqd, kworker, migration, and pktgend kthreads can be created with kthread_create_on_node(), to get proper NUMA affinities for their stack and task_struct. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Tejun Heo <tj@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-15Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (116 commits) x86: Enable forced interrupt threading support x86: Mark low level interrupts IRQF_NO_THREAD x86: Use generic show_interrupts x86: ioapic: Avoid redundant lookup of irq_cfg x86: ioapic: Use new move_irq functions x86: Use the proper accessors in fixup_irqs() x86: ioapic: Use irq_data->state x86: ioapic: Simplify irq chip and handler setup x86: Cleanup the genirq name space genirq: Add chip flag to force mask on suspend genirq: Add desc->irq_data accessor genirq: Add comments to Kconfig switches genirq: Fixup fasteoi handler for oneshot mode genirq: Provide forced interrupt threading sched: Switch wait_task_inactive to schedule_hrtimeout() genirq: Add IRQF_NO_THREAD genirq: Allow shared oneshot interrupts genirq: Prepare the handling of shared oneshot interrupts genirq: Make warning in handle_percpu_event useful x86: ioapic: Move trigger defines to io_apic.h ... Fix up trivial(?) conflicts in arch/x86/pci/xen.c due to genirq name space changes clashing with the Xen cleanups. The set_irq_msi() had moved to xen_bind_pirq_msi_to_irq().
2011-02-26genirq: Provide forced interrupt threadingThomas Gleixner
Add a commandline parameter "threadirqs" which forces all interrupts except those marked IRQF_NO_THREAD to run threaded. That's mostly a debug option to allow retrieving better debug data from crashing interrupt handlers. If "threadirqs" is not enabled on the kernel command line, then there is no impact in the interrupt hotpath. Architecture code needs to select CONFIG_IRQ_FORCED_THREADING after marking the interrupts which cant be threaded IRQF_NO_THREAD. All interrupts which have IRQF_TIMER set are implict marked IRQF_NO_THREAD. Also all PER_CPU interrupts are excluded. Forced threading hard interrupts also forces all soft interrupt handling into thread context. When enabled it might slow down things a bit, but for debugging problems in interrupt code it's a reasonable penalty as it does not immediately crash and burn the machine when an interrupt handler is buggy. Some test results on a Core2Duo machine: Cache cold run of: # time git grep irq_desc non-threaded threaded real 1m18.741s 1m19.061s user 0m1.874s 0m1.757s sys 0m5.843s 0m5.427s # iperf -c server non-threaded [ 3] 0.0-10.0 sec 1.09 GBytes 933 Mbits/sec [ 3] 0.0-10.0 sec 1.09 GBytes 934 Mbits/sec [ 3] 0.0-10.0 sec 1.09 GBytes 933 Mbits/sec threaded [ 3] 0.0-10.0 sec 1.09 GBytes 939 Mbits/sec [ 3] 0.0-10.0 sec 1.09 GBytes 934 Mbits/sec [ 3] 0.0-10.0 sec 1.09 GBytes 937 Mbits/sec Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20110223234956.772668648@linutronix.de>
2011-02-08softirq: Avoid stack switch from ksoftirqdThomas Gleixner
ksoftirqd() calls do_softirq() which switches stacks on several architectures. That makes no sense at all. ksoftirqd's stack is sufficient. Call __do_softirq() directly. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: David Miller <davem@davemloft.net> Cc: Paul Mundt <lethal@linux-sh.org> Reviewed-by: Frank Rowand <frank.rowand@am.sony.com> LKML-Reference: <alpine.LFD.2.00.1102021704530.31804@localhost6.localdomain6>
2011-01-26softirqs: Free up pf flag PF_KSOFTIRQDVenkatesh Pallipadi
Cleanup patch, freeing up PF_KSOFTIRQD and use per_cpu ksoftirqd pointer instead, as suggested by Eric Dumazet. Tested-by: Shaun Ruffell <sruffell@digium.com> Signed-off-by: Venkatesh Pallipadi <venki@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1292980144-28796-2-git-send-email-venki@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-13kernel: clean up USE_GENERIC_SMP_HELPERSAmerigo Wang
For arch which needs USE_GENERIC_SMP_HELPERS, it has to select USE_GENERIC_SMP_HELPERS, rather than leaving a choice to user, since they don't provide their own implementions. Also, move on_each_cpu() to kernel/smp.c, it is strange to put it in kernel/softirq.c. For arch which doesn't use USE_GENERIC_SMP_HELPERS, e.g. blackfin, only on_each_cpu() is compiled. Signed-off-by: Amerigo Wang <amwang@redhat.com> Cc: David Howells <dhowells@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07Merge branch 'for-2.6.38' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (30 commits) gameport: use this_cpu_read instead of lookup x86: udelay: Use this_cpu_read to avoid address calculation x86: Use this_cpu_inc_return for nmi counter x86: Replace uses of current_cpu_data with this_cpu ops x86: Use this_cpu_ops to optimize code vmstat: User per cpu atomics to avoid interrupt disable / enable irq_work: Use per cpu atomics instead of regular atomics cpuops: Use cmpxchg for xchg to avoid lock semantics x86: this_cpu_cmpxchg and this_cpu_xchg operations percpu: Generic this_cpu_cmpxchg() and this_cpu_xchg support percpu,x86: relocate this_cpu_add_return() and friends connector: Use this_cpu operations xen: Use this_cpu_inc_return taskstats: Use this_cpu_ops random: Use this_cpu_inc_return fs: Use this_cpu_inc_return in buffer.c highmem: Use this_cpu_xx_return() operations vmstat: Use this_cpu_inc_return for vm statistics x86: Support for this_cpu_add, sub, dec, inc_return percpu: Generic support for this_cpu_add, sub, dec, inc_return ... Fixed up conflicts: in arch/x86/kernel/{apic/nmi.c, apic/x2apic_uv_x.c, process.c} as per Tejun.
2011-01-07sched: Constify function scope static struct sched_param usagePeter Zijlstra
Function-scope statics are discouraged because they are easily overlooked and can cause subtle bugs/races due to their global (non-SMP safe) nature. Linus noticed that we did this for sched_param - at minimum make the const. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: Message-ID: <AANLkTinotRxScOHEb0HgFgSpGPkq_6jKTv5CfvnQM=ee@mail.gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-17core: Replace __get_cpu_var with __this_cpu_read if not used for an address.Christoph Lameter
__get_cpu_var() can be replaced with this_cpu_read and will then use a single read instruction with implied address calculation to access the correct per cpu instance. However, the address of a per cpu variable passed to __this_cpu_read() cannot be determined (since it's an implied address conversion through segment prefixes). Therefore apply this only to uses of __get_cpu_var where the address of the variable is not used. Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Hugh Dickins <hughd@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-11-18Merge commit 'v2.6.37-rc2' into sched/coreIngo Molnar
Merge reason: Move to a .37-rc base. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-27Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (50 commits) perf python scripting: Add futex-contention script perf python scripting: Fixup cut'n'paste error in sctop script perf scripting: Shut up 'perf record' final status perf record: Remove newline character from perror() argument perf python scripting: Support fedora 11 (audit 1.7.17) perf python scripting: Improve the syscalls-by-pid script perf python scripting: print the syscall name on sctop perf python scripting: Improve the syscalls-counts script perf python scripting: Improve the failed-syscalls-by-pid script kprobes: Remove redundant text_mutex lock in optimize x86/oprofile: Fix uninitialized variable use in debug printk tracing: Fix 'faild' -> 'failed' typo perf probe: Fix format specified for Dwarf_Off parameter perf trace: Fix detection of script extension perf trace: Use $PERF_EXEC_PATH in canned report scripts perf tools: Document event modifiers perf tools: Remove direct slang.h include perf_events: Fix for transaction recovery in group_sched_in() perf_events: Revert: Fix transaction recovery in group_sched_in() perf, x86: Use NUMA aware allocations for PEBS/BTS/DS allocations ...
2010-10-23Merge branch 'perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux-2.6 into perf/urgent
2010-10-23sched: Make sched_param argument static in sched_setscheduler() callersKOSAKI Motohiro
Andrew Morton pointed out almost all sched_setscheduler() callers are using fixed parameters and can be converted to static. It reduces runtime memory use a little. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reported-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: James Morris <jmorris@namei.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-23Merge branches 'softirq-for-linus', 'x86-debug-for-linus', ↵Linus Torvalds
'x86-numa-for-linus', 'x86-quirks-for-linus', 'x86-setup-for-linus', 'x86-uv-for-linus' and 'x86-vm86-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'softirq-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: softirqs: Make wakeup_softirqd static * 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, asm: Restore parentheses around one pushl_cfi argument x86, asm: Fix ancient-GAS workaround x86, asm: Fix CFI macro invocations to deal with shortcomings in gas * 'x86-numa-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, numa: Assign CPUs to nodes in round-robin manner on fake NUMA * 'x86-quirks-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: HPET force enable for CX700 / VIA Epia LT * 'x86-setup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, setup: Use string copy operation to optimze copy in kernel compression * 'x86-uv-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, UV: Use allocated buffer in tlb_uv.c:tunables_read() * 'x86-vm86-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, vm86: Fix preemption bug for int1 debug and int3 breakpoint handlers.
2010-10-21Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (96 commits) apic, x86: Use BIOS settings for IBS and MCE threshold interrupt LVT offsets apic, x86: Check if EILVT APIC registers are available (AMD only) x86: ioapic: Call free_irte only if interrupt remapping enabled arm: Use ARCH_IRQ_INIT_FLAGS genirq, ARM: Fix boot on ARM platforms genirq: Fix CONFIG_GENIRQ_NO_DEPRECATED=y build x86: Switch sparse_irq allocations to GFP_KERNEL genirq: Switch sparse_irq allocator to GFP_KERNEL genirq: Make sparse_lock a mutex x86: lguest: Use new irq allocator genirq: Remove the now unused sparse irq leftovers genirq: Sanitize dynamic irq handling genirq: Remove arch_init_chip_data() x86: xen: Sanitise sparse_irq handling x86: Use sane enumeration x86: uv: Clean up the direct access to irq_desc x86: Make io_apic.c local functions static genirq: Remove irq_2_iommu x86: Speed up the irq_remapped check in hot pathes intr_remap: Simplify the code further ... Fix up trivial conflicts in arch/x86/Kconfig
2010-10-21tracing: Cleanup the convoluted softirq tracepointsThomas Gleixner
With the addition of trace_softirq_raise() the softirq tracepoint got even more convoluted. Why the tracepoints take two pointers to assign an integer is beyond my comprehension. But adding an extra case which treats the first pointer as an unsigned long when the second pointer is NULL including the back and forth type casting is just horrible. Convert the softirq tracepoints to take a single unsigned int argument for the softirq vector number and fix the call sites. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <alpine.LFD.2.00.1010191428560.6815@localhost6.localdomain6> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: mathieu.desnoyers@efficios.com Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org>
2010-10-18sched: Call tick_check_idle before __irq_enterVenkatesh Pallipadi
When CPU is idle and on first interrupt, irq_enter calls tick_check_idle() to notify interruption from idle. But, there is a problem if this call is done after __irq_enter, as all routines in __irq_enter may find stale time due to yet to be done tick_check_idle. Specifically, trace calls in __irq_enter when they use global clock and also account_system_vtime change in this patch as it wants to use sched_clock_cpu() to do proper irq timing. But, tick_check_idle was moved after __irq_enter intentionally to prevent problem of unneeded ksoftirqd wakeups by the commit ee5f80a: irq: call __irq_enter() before calling the tick_idle_check Impact: avoid spurious ksoftirqd wakeups Moving tick_check_idle() before __irq_enter and wrapping it with local_bh_enable/disable would solve both the problems. Fixed-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: Venkatesh Pallipadi <venki@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1286237003-12406-9-git-send-email-venki@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-18sched: Add a PF flag for ksoftirqd identificationVenkatesh Pallipadi
To account softirq time cleanly in scheduler, we need to identify whether softirq is invoked in ksoftirqd context or softirq at hardirq tail context. Add PF_KSOFTIRQD for that purpose. As all PF flag bits are currently taken, create space by moving one of the infrequently used bits (PF_THREAD_BOUND) down in task_struct to be along with some other state fields. Signed-off-by: Venkatesh Pallipadi <venki@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1286237003-12406-4-git-send-email-venki@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-18sched: Fix softirq time accountingVenkatesh Pallipadi
Peter Zijlstra found a bug in the way softirq time is accounted in VIRT_CPU_ACCOUNTING on this thread: http://lkml.indiana.edu/hypermail//linux/kernel/1009.2/01366.html The problem is, softirq processing uses local_bh_disable internally. There is no way, later in the flow, to differentiate between whether softirq is being processed or is it just that bh has been disabled. So, a hardirq when bh is disabled results in time being wrongly accounted as softirq. Looking at the code a bit more, the problem exists in !VIRT_CPU_ACCOUNTING as well. As account_system_time() in normal tick based accouting also uses softirq_count, which will be set even when not in softirq with bh disabled. Peter also suggested solution of using 2*SOFTIRQ_OFFSET as irq count for local_bh_{disable,enable} and using just SOFTIRQ_OFFSET while softirq processing. The patch below does that and adds API in_serving_softirq() which returns whether we are currently processing softirq or not. Also changes one of the usages of softirq_count in net/sched/cls_cgroup.c to in_serving_softirq. Looks like many usages of in_softirq really want in_serving_softirq. Those changes can be made individually on a case by case basis. Signed-off-by: Venkatesh Pallipadi <venki@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1286237003-12406-2-git-send-email-venki@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Remove arch_init_chip_data()Thomas Gleixner
This function should have not been there in the first place. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-12genirq: Query arch for number of early descriptorsThomas Gleixner
sparse irq sets up NR_IRQS_LEGACY irq descriptors and archs then go ahead and allocate more. Use the unused return value of arch_probe_nr_irqs() to let the architecture return the number of early allocations. Fix up all users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
