path: root/kernel/sched_fair.c
2008-07-04sched: add avg-overlap support to RT tasksGregory Haskins
We have the notion of tracking process-coupling (a.k.a. buddy-wake) via the p->se.last_wake / p->se.avg_overlap facilities, but it is only used for cfs to cfs interactions. There is no reason why an rt to cfs interaction cannot share in establishing a relationhip in a similar manner. Because PREEMPT_RT runs many kernel threads as FIFO priority, we often times have heavy interaction between RT threads waking CFS applications. This patch offers a substantial boost (50-60%+) in perfomance under those circumstances. Signed-off-by: Gregory Haskins <ghaskins@novell.com> Cc: npiggin@suse.de Cc: rostedt@goodmis.org Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: make sched_{rt,fair}.c ifdefs more readableDhaval Giani
Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: bias effective_load() error towards failing wake_affine().Peter Zijlstra
Measurement shows that the difference between cgroup:/ and cgroup:/foo wake_affine() results is that the latter succeeds significantly more. Therefore bias the calculations towards failing the test. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: incremental effective_load()Peter Zijlstra
Increase the accuracy of the effective_load values. Not only consider the current increment (as per the attempted wakeup), but also consider the delta between when we last adjusted the shares and the current situation. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: correct wakeup weight calculationsPeter Zijlstra
rw_i = {2, 4, 1, 0} s_i = {2/7, 4/7, 1/7, 0} wakeup on cpu0, weight=1 rw'_i = {3, 4, 1, 0} s'_i = {3/8, 4/8, 1/8, 0} s_0 = S * rw_0 / \Sum rw_j -> \Sum rw_j = S*rw_0/s_0 = 1*2*7/2 = 7 (correct) s'_0 = S * (rw_0 + 1) / (\Sum rw_j + 1) = 1 * (2+1) / (7+1) = 3/8 (correct so we find that adding 1 to cpu0 gains 5/56 in weight if say the other cpu were, cpu1, we'd also have to calculate its 4/56 loss Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: fix mult overflowSrivatsa Vaddagiri
It was observed these mults can overflow. Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: optimize effective_load()Peter Zijlstra
s_i = S * rw_i / \Sum_j rw_j -> \Sum_j rw_j = S * rw_i / s_i -> s'_i = S * (rw_i + w) / (\Sum_j rw_j + w) delta s = s' - s = S * (rw + w) / ((S * rw / s) + w) = s * (S * (rw + w) / (S * rw + s * w) - 1) a = S*(rw+w), b = S*rw + s*w delta s = s * (a-b) / b IOW, trade one divide for two multiplies Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: fix task_h_load()Peter Zijlstra
Currently task_h_load() computes the load of a task and uses that to either subtract it from the total, or add to it. However, removing or adding a task need not have any effect on the total load at all. Imagine adding a task to a group that is local to one cpu - in that case the total load of that cpu is unaffected. So properly compute addition/removal: s_i = S * rw_i / \Sum_j rw_j s'_i = S * (rw_i + wl) / (\Sum_j rw_j + wg) then s'_i - s_i gives the change in load. Where s_i is the shares for cpu i, S the group weight, rw_i the runqueue weight for that cpu, wl the weight we add (subtract) and wg the weight contribution to the runqueue. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: fix load scaling in group balancingPeter Zijlstra
doing the load balance will change cfs_rq->load.weight (that's the whole point) but since that's part of the scale factor, we'll scale back with a different amount. Weight getting smaller would result in an inflated moved_load which causes it to stop balancing too soon. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: hierarchical load vs affine wakeupsPeter Zijlstra
With hierarchical grouping we can't just compare task weight to rq weight - we need to scale the weight appropriately. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: simplify the group load balancerPeter Zijlstra
While thinking about the previous patch - I realized that using per domain aggregate load values in load_balance_fair() is wrong. We should use the load value for that CPU. By not needing per domain hierarchical load values we don't need to store per domain aggregate shares, which greatly simplifies all the math. It basically falls apart in two separate computations: - per domain update of the shares - per CPU update of the hierarchical load Also get rid of the move_group_shares() stuff - just re-compute the shares again after a successful load balance. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: no need to aggregate task_weightPeter Zijlstra
We only need to know the task_weight of the busiest rq - nothing to do if there are no tasks there. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: kill task_group balancingSrivatsa Vaddagiri
The idea was to balance groups until we've reached the global goal, however Vatsa rightly pointed out that we might never reach that goal this way - hence take out this logic. [ the initial rationale for this 'feature' was to promote max concurrency within a group - it does not however affect fairness ] Reported-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: fix sched_domain aggregationPeter Zijlstra
Keeping the aggregate on the first cpu of the sched domain has two problems: - it could collide between different sched domains on different cpus - it could slow things down because of the remote accesses Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: fix wakeup granularity and buddy granularityPeter Zijlstra
Uncouple buddy selection from wakeup granularity. The initial idea was that buddies could run ahead as far as a normal task can - do this by measuring a pair 'slice' just as we do for a normal task. This means we can drop the wakeup_granularity back to 5ms. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: revert revert of: fair-group: SMP-nice for group schedulingPeter Zijlstra
Try again.. Initial commit: 18d95a2832c1392a2d63227a7a6d433cb9f2037e Revert: 6363ca57c76b7b83639ca8c83fc285fa26a7880e Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: fix calc_delta_asym, #2Peter Zijlstra
Ok, so why are we in this mess, it was: 1/w but now we mixed that rw in the mix like: rw/w rw being \Sum w suggests: fiddling w, we should also fiddle rw, humm? Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: fix calc_delta_asym()Peter Zijlstra
calc_delta_asym() is supposed to do the same as calc_delta_fair() except linearly shrink the result for negative nice processes - this causes them to have a smaller preemption threshold so that they are more easily preempted. The problem is that for task groups se->load.weight is the per cpu share of the actual task group weight; take that into account. Also provide a debug switch to disable the asymmetry (which I still don't like - but it does greatly benefit some workloads) This would explain the interactivity issues reported against group scheduling. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-27sched: revert the revert of: weight calculationsPeter Zijlstra
Try again.. initial commit: 8f1bc385cfbab474db6c27b5af1e439614f3025c revert: f9305d4a0968201b2818dbed0dc8cb0d4ee7aeb3 Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-06sched: fix SCHED_OTHER balance iterator to include all tasksGregory Haskins
The currently logic inadvertently skips the last task on the run-queue, resulting in missed balance opportunities. Signed-off-by: Gregory Haskins <ghaskins@novell.com> Signed-off-by: David Bahi <dbahi@novell.com> CC: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-29sched: stop wake_affine from causing serious imbalanceMike Galbraith
Prevent short-running wakers of short-running threads from overloading a single cpu via wakeup affinity, and wire up disconnected debug option. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-29revert ("sched: fair-group: SMP-nice for group scheduling")Ingo Molnar
Yanmin Zhang reported: Comparing with 2.6.25, volanoMark has big regression with kernel 2.6.26-rc1. It's about 50% on my 8-core stoakley, 16-core tigerton, and Itanium Montecito. With bisect, I located the following patch: | 18d95a2832c1392a2d63227a7a6d433cb9f2037e is first bad commit | commit 18d95a2832c1392a2d63227a7a6d433cb9f2037e | Author: Peter Zijlstra <a.p.zijlstra@chello.nl> | Date: Sat Apr 19 19:45:00 2008 +0200 | | sched: fair-group: SMP-nice for group scheduling Revert it so that we get v2.6.25 behavior. Bisected-by: Yanmin Zhang <yanmin_zhang@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-29revert ("sched: fair: weight calculations")Ingo Molnar
Yanmin Zhang reported: Comparing with kernel 2.6.25, sysbench+mysql(oltp, readonly) has many regressions with 2.6.26-rc1: 1) 8-core stoakley: 28%; 2) 16-core tigerton: 20%; 3) Itanium Montvale: 50%. Bisect located this patch: | 8f1bc385cfbab474db6c27b5af1e439614f3025c is first bad commit | commit 8f1bc385cfbab474db6c27b5af1e439614f3025c | Author: Peter Zijlstra <a.p.zijlstra@chello.nl> | Date: Sat Apr 19 19:45:00 2008 +0200 | | sched: fair: weight calculations Revert it to the 2.6.25 state. Bisected-by: Yanmin Zhang <yanmin_zhang@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-08sched: fix weight calculationsMike Galbraith
The conversion between virtual and real time is as follows: dvt = rw/w * dt <=> dt = w/rw * dvt Since we want the fair sleeper granularity to be in real time, we actually need to do: dvt = - rw/w * l This bug could be related to the regression reported by Yanmin Zhang: | Comparing with kernel 2.6.25, sysbench+mysql(oltp, readonly) has lots | of regressions with 2.6.26-rc1: | | 1) 8-core stoakley: 28%; | 2) 16-core tigerton: 20%; | 3) Itanium Montvale: 50%. Reported-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com> Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-05sched: add optional support for CONFIG_HAVE_UNSTABLE_SCHED_CLOCKPeter Zijlstra
this replaces the rq->clock stuff (and possibly cpu_clock()). - architectures that have an 'imperfect' hardware clock can set CONFIG_HAVE_UNSTABLE_SCHED_CLOCK - the 'jiffie' window might be superfulous when we update tick_gtod before the __update_sched_clock() call in sched_clock_tick() - cpu_clock() might be implemented as: sched_clock_cpu(smp_processor_id()) if the accuracy proves good enough - how far can TSC drift in a single jiffie when considering the filtering and idle hooks? [ mingo@elte.hu: various fixes and cleanups ] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-05sched: fix debuggingMike Galbraith
Revert debugging commit 7ba2e74ab5a0518bc953042952dd165724bc70c9. print_cfs_rq_tasks() can induce live-lock if a task is dequeued during list traversal. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-05sched: fix SCHED_FAIR wake-idle logic errorGregory Haskins
We currently use an optimization to skip the overhead of wake-idle processing if more than one task is assigned to a run-queue. The assumption is that the system must already be load-balanced or we wouldnt be overloaded to begin with. The problem is that we are looking at rq->nr_running, which may include RT tasks in addition to CFS tasks. Since the presence of RT tasks really has no bearing on the balance status of CFS tasks, this throws the calculation off. This patch changes the logic to only consider the number of CFS tasks when making the decision to optimze the wake-idle. Signed-off-by: Gregory Haskins <ghaskins@novell.com> CC: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-05sched: add statics, don't return void expressionsHarvey Harrison
Noticed by sparse: kernel/sched.c:760:20: warning: symbol 'sched_feat_names' was not declared. Should it be static? kernel/sched.c:767:5: warning: symbol 'sched_feat_open' was not declared. Should it be static? kernel/sched_fair.c:845:3: warning: returning void-valued expression kernel/sched.c:4386:3: warning: returning void-valued expression Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-05sched: fix normalized sleeperPeter Zijlstra
Normalized sleeper uses calc_delta*() which requires that the rq load is already updated, so move account_entity_enqueue() before place_entity() Tested-by: Frans Pop <elendil@planet.nl> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19sched: debug: show a weight treePeter Zijlstra
Print a tree of weights. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19sched: fair: weight calculationsPeter Zijlstra
In order to level the hierarchy, we need to calculate load based on the root view. That is, each task's load is in the same unit. A / \ B 1 / \ 2 3 To compute 1's load we do: weight(1) -------------- rq_weight(A) To compute 2's load we do: weight(2) weight(B) ------------ * ----------- rq_weight(B) rw_weight(A) This yields load fractions in comparable units. The consequence is that it changes virtual time. We used to have: time_{i} vtime_{i} = ------------ weight_{i} vtime = \Sum vtime_{i} = time / rq_weight. But with the new way of load calculation we get that vtime equals time. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19sched: fair-group: de-couple load-balancing from the rb-treesPeter Zijlstra
De-couple load-balancing from the rb-trees, so that I can change their organization. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19sched: fair-group scheduling vs latencyPeter Zijlstra
Currently FAIR_GROUP sched grows the scheduler latency outside of sysctl_sched_latency, invert this so it stays within. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19sched: fair-group: SMP-nice for group schedulingPeter Zijlstra
Implement SMP nice support for the full group hierarchy. On each load-balance action, compile a sched_domain wide view of the full task_group tree. We compute the domain wide view when walking down the hierarchy, and readjust the weights when walking back up. After collecting and readjusting the domain wide view, we try to balance the tasks within the task_groups. The current approach is a naively balance each task group until we've moved the targeted amount of load. Inspired by Srivatsa Vaddsgiri's previous code and Abhishek Chandra's H-SMP paper. XXX: there will be some numerical issues due to the limited nature of SCHED_LOAD_SCALE wrt to representing a task_groups influence on the total weight. When the tree is deep enough, or the task weight small enough, we'll run out of bits. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> CC: Abhishek Chandra <chandra@cs.umn.edu> CC: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19sched, cpuset: customize sched domains, coreHidetoshi Seto
[rebased for sched-devel/latest] - Add a new cpuset file, having levels: sched_relax_domain_level - Modify partition_sched_domains() and build_sched_domains() to take attributes parameter passed from cpuset. - Fill newidle_idx for node domains which currently unused but might be required if sched_relax_domain_level become higher. - We can change the default level by boot option 'relax_domain_level='. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19sched: prepatory code movementPeter Zijlstra
2008-04-19sched: mix tasks and groupsDhaval Giani
This patch allows tasks and groups to exist in the same cfs_rq. With this change the CFS group scheduling follows a 1/(M+N) model from a 1/(1+N) fairness model where M tasks and N groups exist at the cfs_rq level. [a.p.zijlstra@chello.nl: rt bits and assorted fixes] Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19sched: old sleeper bonusPeter Zijlstra
2008-04-19sched: fix regression with sched yieldPeter Zijlstra
Balbir Singh reported: > 1:mon> t > [c0000000e7677da0] c000000000067de0 .sys_sched_yield+0x6c/0xbc > [c0000000e7677e30] c000000000008748 syscall_exit+0x0/0x40 > --- Exception: c01 (System Call) at 00000400001d09e4 > SP (4000664cb10) is in userspace > 1:mon> r > cpu 0x1: Vector: 300 (Data Access) at [c0000000e7677aa0] > pc: c000000000068e50: .yield_task_fair+0x94/0xc4 > lr: c000000000067de0: .sys_sched_yield+0x6c/0xbc the check that should have avoided that is: /* * Are we the only task in the tree? */ if (unlikely(rq->load.weight == curr->se.load.weight)) return; But I guess that overlooks rt tasks, they also increase the load. So I guess something like this ought to fix it.. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19sched: remove sysctl_sched_batch_wakeup_granularityIngo Molnar
it's unused. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19sched: fix wakeup granularity for buddiesPeter Zijlstra
The wakeup buddy logic didn't use the same wakeup granularity logic as the wakeup preemption did, this might cause the ->next buddy to be selected past the point where we would have preempted had the task been a single running instance. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19sched: re-do "sched: fix fair sleepers"Ingo Molnar
re-apply: | commit e22ecef1d2658ba54ed7d3fdb5d60829fb434c23 | Author: Ingo Molnar <mingo@elte.hu> | Date: Fri Mar 14 22:16:08 2008 +0100 | | sched: fix fair sleepers | | Fair sleepers need to scale their latency target down by runqueue | weight. Otherwise busy systems will gain ever larger sleep bonus. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-14revert "sched: fix fair sleepers"Ingo Molnar
revert "sched: fix fair sleepers" (e22ecef1d2658ba54ed7d3fdb5d60829fb434c23), because it is causing audio skipping, see: http://bugzilla.kernel.org/show_bug.cgi?id=10428 the patch is correct and the real cause of the skipping is not understood (tracing makes it go away), but time has run out so we'll revert it and re-try in 2.6.26. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-21sched: cleanup old and rarely used 'debug' features.Peter Zijlstra
TREE_AVG and APPROX_AVG are initial task placement policies that have been disabled for a long while.. time to remove them. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> CC: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-19sched: retune wake granularityIngo Molnar
reduce wake-up granularity for better interactivity. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-19sched: improve affine wakeupsIngo Molnar
improve affine wakeups. Maintain the 'overlap' metric based on CFS's sum_exec_runtime - which means the amount of time a task executes after it wakes up some other task. Use the 'overlap' for the wakeup decisions: if the 'overlap' is short, it means there's strong workload coupling between this task and the woken up task. If the 'overlap' is large then the workload is decoupled and the scheduler will move them to separate CPUs more easily. ( Also slightly move the preempt_check within try_to_wake_up() - this has no effect on functionality but allows 'early wakeups' (for still-on-rq tasks) to be correctly accounted as well.) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-19sched: clean up wakeup balancing, code flowIngo Molnar
Clean up the code flow. No code changed: kernel/sched.o: text data bss dec hex filename 42521 2858 232 45611 b22b sched.o.before 42521 2858 232 45611 b22b sched.o.after md5: 09b31c44e9aff8666f72773dc433e2df sched.o.before.asm 09b31c44e9aff8666f72773dc433e2df sched.o.after.asm Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-19sched: clean up wakeup balancing, rename variablesIngo Molnar
rename 'cpu' to 'prev_cpu'. No code changed: kernel/sched.o: text data bss dec hex filename 42521 2858 232 45611 b22b sched.o.before 42521 2858 232 45611 b22b sched.o.after md5: 09b31c44e9aff8666f72773dc433e2df sched.o.before.asm 09b31c44e9aff8666f72773dc433e2df sched.o.after.asm Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-19sched: clean up wakeup balancing, move wake_affine()Ingo Molnar
split out the affine-wakeup bits. No code changed: kernel/sched.o: text data bss dec hex filename 42521 2858 232 45611 b22b sched.o.before 42521 2858 232 45611 b22b sched.o.after md5: 9d76738f1272aa82f0b7affd2f51df6b sched.o.before.asm 09b31c44e9aff8666f72773dc433e2df sched.o.after.asm (the md5's changed because stack slots changed and some registers get scheduled by gcc in a different order - but otherwise the before and after assembly is instruction for instruction equivalent.) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-15sched: simplify sched_slice()Ingo Molnar
Use the existing calc_delta_mine() calculation for sched_slice(). This saves a divide and simplifies the code because we share it with the other /cfs_rq->load users. It also improves code size: text data bss dec hex filename 42659 2740 144 45543 b1e7 sched.o.before 42093 2740 144 44977 afb1 sched.o.after Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
