After commit 863bffc80898 ("sched/fair: Fix group power_orig
computation"), we can dereference rq->sd before it is set.
Fix this by falling back to power_of() in this case and add a comment
explaining things.
Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
[ Added comment and tweaked patch. ]
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: mikey@neuling.org
Link: http://lkml.kernel.org/r/20131113151718.GN21461@twins.programming.kicks-ass.net
sa->runnable_avg_sum is of type u32 but after shifting it by NICE_0_SHIFT
bits it is promoted to u64. This of course makes no sense, since the
result will never be more then 32-bit long. Casting sa->runnable_avg_sum
to u64 before it is shifted, fixes this problem.
Reviewed-by: Ben Segall <bsegall@google.com>
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Link: http://lkml.kernel.org/r/1384112521-25177-1-git-send-email-mpn@google.com
Because we're completely unserialized against hotplug its well
possible to try and generate numa stats for an offlined node.
Bail out early (and avoid a /0) in this case. The resulting stats are
all 0 which should result in an undesirable balance target -- not to
mention that actually trying to migrate to an offline CPU will fail.
Reported-by: Prarit Bhargava <prarit@redhat.com>
Link: http://lkml.kernel.org/n/tip-orja0qylcvyhxfsuebcyL5sI@git.kernel.org
The cpusets code can split up the scheduler's domain tree into
smaller domains. Some of those smaller domains may not cross
NUMA nodes at all, leading to a NULL pointer dereference on the
per-cpu sd_numa pointer.
Tasks cannot be migrated out of their domain, so the patch
also sets p->numa_preferred_nid to whereever they are, to
prevent the migration from being retried over and over again.
Signed-off-by: Rik van Riel <riel@redhat.com>
Link: http://lkml.kernel.org/n/tip-oosqomw0Jput0Jkvoowhrqtu@git.kernel.org
nr_busy_cpus parameter is used by nohz_kick_needed() to find out the
number of busy cpus in a sched domain which has SD_SHARE_PKG_RESOURCES
flag set. Therefore instead of updating nr_busy_cpus at every level
of sched domain, since it is irrelevant, we can update this parameter
only at the parent domain of the sd which has this flag set. Introduce
a per-cpu parameter sd_busy which represents this parent domain.
In nohz_kick_needed() we directly query the nr_busy_cpus parameter
associated with the groups of sd_busy.
By associating sd_busy with the highest domain which has
SD_SHARE_PKG_RESOURCES flag set, we cover all lower level domains
which could have this flag set and trigger nohz_idle_balancing if any
of the levels have more than one busy cpu.
sd_busy is irrelevant for asymmetric load balancing. However sd_asym
has been introduced to represent the highest sched domain which has
SD_ASYM_PACKING flag set so that it can be queried directly when
required.
While we are at it, we might as well change the nohz_idle parameter to
be updated at the sd_busy domain level alone and not the base domain
level of a CPU. This will unify the concept of busy cpus at just one
level of sched domain where it is currently used.
Signed-off-by: Preeti U Murthy<preeti@linux.vnet.ibm.com>
Cc: svaidy@linux.vnet.ibm.com
Cc: vincent.guittot@linaro.org
Cc: bitbucket@online.de
Cc: benh@kernel.crashing.org
Cc: anton@samba.org
Cc: Morten.Rasmussen@arm.com
Cc: pjt@google.com
Cc: peterz@infradead.org
Link: http://lkml.kernel.org/r/20131030031252.23426.4417.stgit@preeti.in.ibm.com
Asymmetric scheduling within a core is a scheduler loadbalancing
feature that is triggered when SD_ASYM_PACKING flag is set. The goal
for the load balancer is to move tasks to lower order idle SMT threads
within a core on a POWER7 system.
In nohz_kick_needed(), we intend to check if our sched domain (core)
is completely busy or we have idle cpu.
The following check for SD_ASYM_PACKING:
(cpumask_first_and(nohz.idle_cpus_mask, sched_domain_span(sd)) < cpu)
already covers the case of checking if the domain has an idle cpu,
because cpumask_first_and() will not yield any set bits if this domain
has no idle cpu.
Hence, nr_busy check against group weight can be removed.
Reported-by: Michael Neuling <michael.neuling@au1.ibm.com>
Signed-off-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com>
Signed-off-by: Preeti U Murthy <preeti@linux.vnet.ibm.com>
Tested-by: Michael Neuling <mikey@neuling.org>
Cc: anton@samba.org
Cc: pjt@google.com
Link: http://lkml.kernel.org/r/20131030031242.23426.13019.stgit@preeti.in.ibm.com
throttle_cfs_rq() doesn't check to make sure that period_timer is running,
and while update_curr/assign_cfs_runtime does, a concurrently running
period_timer on another cpu could cancel itself between this cpu's
update_curr and throttle_cfs_rq(). If there are no other cfs_rqs running
in the tg to restart the timer, this causes the cfs_rq to be stranded
forever.
Fix this by calling __start_cfs_bandwidth() in throttle if the timer is
inactive.
(Also add some sched_debug lines for cfs_bandwidth.)
Tested: make a run/sleep task in a cgroup, loop switching the cgroup
between 1ms/100ms quota and unlimited, checking for timer_active=0 and
throttled=1 as a failure. With the throttle_cfs_rq() change commented out
this fails, with the full patch it passes.
Signed-off-by: Ben Segall <bsegall@google.com>
Cc: pjt@google.com
Link: http://lkml.kernel.org/r/20131016181632.22647.84174.stgit@sword-of-the-dawn.mtv.corp.google.com
Currently, group entity load-weights are initialized to zero. This
admits some races with respect to the first time they are re-weighted in
earlty use. ( Let g[x] denote the se for "g" on cpu "x". )
Suppose that we have root->a and that a enters a throttled state,
immediately followed by a[0]->t1 (the only task running on cpu[0])
blocking:
put_prev_task(group_cfs_rq(a[0]), t1)
put_prev_entity(..., t1)
check_cfs_rq_runtime(group_cfs_rq(a[0]))
throttle_cfs_rq(group_cfs_rq(a[0]))
Then, before unthrottling occurs, let a[0]->b[0]->t2 wake for the first
time:
enqueue_task_fair(rq[0], t2)
enqueue_entity(group_cfs_rq(b[0]), t2)
enqueue_entity_load_avg(group_cfs_rq(b[0]), t2)
account_entity_enqueue(group_cfs_ra(b[0]), t2)
update_cfs_shares(group_cfs_rq(b[0]))
< skipped because b is part of a throttled hierarchy >
enqueue_entity(group_cfs_rq(a[0]), b[0])
We now have b[0] enqueued, yet group_cfs_rq(a[0])->load.weight == 0
which violates invariants in several code-paths. Eliminate the
possibility of this by initializing group entity weight.
Signed-off-by: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/r/20131016181627.22647.47543.stgit@sword-of-the-dawn.mtv.corp.google.com
__start_cfs_bandwidth calls hrtimer_cancel while holding rq->lock,
waiting for the hrtimer to finish. However, if sched_cfs_period_timer
runs for another loop iteration, the hrtimer can attempt to take
rq->lock, resulting in deadlock.
Fix this by ensuring that cfs_b->timer_active is cleared only if the
_latest_ call to do_sched_cfs_period_timer is returning as idle. Then
__start_cfs_bandwidth can just call hrtimer_try_to_cancel and wait for
that to succeed or timer_active == 1.
Cc: pjt@google.com
Link: http://lkml.kernel.org/r/20131016181622.22647.16643.stgit@sword-of-the-dawn.mtv.corp.google.com
hrtimer_expires_remaining does not take internal hrtimer locks and thus
must be guarded against concurrent __hrtimer_start_range_ns (but
returning HRTIMER_RESTART is safe). Use cfs_b->lock to make it safe.
Cc: pjt@google.com
Link: http://lkml.kernel.org/r/20131016181617.22647.73829.stgit@sword-of-the-dawn.mtv.corp.google.com
When we transition cfs_bandwidth_used to false, any currently
throttled groups will incorrectly return false from cfs_rq_throttled.
While tg_set_cfs_bandwidth will unthrottle them eventually, currently
running code (including at least dequeue_task_fair and
distribute_cfs_runtime) will cause errors.
Fix this by turning off cfs_bandwidth_used only after unthrottling all
cfs_rqs.
Tested: toggle bandwidth back and forth on a loaded cgroup. Caused
crashes in minutes without the patch, hasn't crashed with it.
Cc: pjt@google.com
Link: http://lkml.kernel.org/r/20131016181611.22647.80365.stgit@sword-of-the-dawn.mtv.corp.google.com
There is a subtle race in migrate_swap, when task P, on CPU A, decides to swap
places with task T, on CPU B.
Task P:
- call migrate_swap
Task T:
- go to sleep, removing itself from the runqueue
Task P:
- double lock the runqueues on CPU A & B
Task T:
- get woken up, place itself on the runqueue of CPU C
Task P:
- see that task T is on a runqueue, and pretend to remove it
from the runqueue on CPU B
Now CPUs B & C both have corrupted scheduler data structures.
This patch fixes it, by holding the pi_lock for both of the tasks
involved in the migrate swap. This prevents task T from waking up,
and placing itself onto another runqueue, until after migrate_swap
has released all locks.
This means that, when migrate_swap checks, task T will be either
on the runqueue where it was originally seen, or not on any
runqueue at all. Migrate_swap deals correctly with of those cases.
Tested-by: Joe Mario <jmario@redhat.com>
Cc: hannes@cmpxchg.org
Cc: aarcange@redhat.com
Cc: srikar@linux.vnet.ibm.com
Cc: tglx@linutronix.de
Cc: hpa@zytor.com
Link: http://lkml.kernel.org/r/20131010181722.GO13848@laptop.programming.kicks-ass.net
- 'load_icx' => 'load_idx'
- 'calculcate_imbalance' => 'calculate_imbalance'
Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1381685775-3544-1-git-send-email-kamalesh@linux.vnet.ibm.com
[ Also, don't capitalize 'idle' unnecessarily. ]
The balance parameter was removed by 23f0d20 ("sched: Factor out
code to should_we_balance()", 2013-08-06).
Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Link: http://lkml.kernel.org/r/1381400433-2030-1-git-send-email-artagnon@gmail.com
Reflow the function a bit because GCC gets confused:
kernel/sched/fair.c: In function ‘task_numa_fault’:
kernel/sched/fair.c:1448:3: warning: ‘my_grp’ may be used uninitialized in this function [-Wmaybe-uninitialized]
kernel/sched/fair.c:1463:27: note: ‘my_grp’ was declared here
Link: http://lkml.kernel.org/n/tip-6ebt6x7u64pbbonq1khqu2z9@git.kernel.org
Short spikes of CPU load can lead to a task being migrated
away from its preferred node for temporary reasons.
It is important that the task is migrated back to where it
belongs, in order to avoid migrating too much memory to its
new location, and generally disturbing a task's NUMA location.
This patch fixes NUMA placement for 4 specjbb instances on
a 4 node system. Without this patch, things take longer to
converge, and processes are not always completely on their
own node.
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1381141781-10992-64-git-send-email-mgorman@suse.de
As Peter says "If you're going to hold locks you can also do away with all
that atomic_long_*() nonsense". Lock aquisition moved slightly to protect
the updates.
Link: http://lkml.kernel.org/r/1381141781-10992-63-git-send-email-mgorman@suse.de
Shared faults can lead to lots of unnecessary page migrations,
slowing down the system, and causing private faults to hit the
per-pgdat migration ratelimit.
This patch adds sysctl numa_balancing_migrate_deferred, which specifies
how many shared page migrations to skip unconditionally, after each page
migration that is skipped because it is a shared fault.
This reduces the number of page migrations back and forth in
shared fault situations. It also gives a strong preference to
the tasks that are already running where most of the memory is,
and to moving the other tasks to near the memory.
Testing this with a much higher scan rate than the default
still seems to result in fewer page migrations than before.
Memory seems to be somewhat better consolidated than previously,
with multi-instance specjbb runs on a 4 node system.
Link: http://lkml.kernel.org/r/1381141781-10992-62-git-send-email-mgorman@suse.de
With the scan rate code working (at least for multi-instance specjbb),
the large hammer that is "sched: Do not migrate memory immediately after
switching node" can be replaced with something smarter. Revert temporarily
migration disabling and all traces of numa_migrate_seq.
Link: http://lkml.kernel.org/r/1381141781-10992-61-git-send-email-mgorman@suse.de
With scan rate adaptions based on whether the workload has properly
converged or not there should be no need for the scan period reset
hammer. Get rid of it.
Link: http://lkml.kernel.org/r/1381141781-10992-60-git-send-email-mgorman@suse.de
Adjust numa_scan_period in task_numa_placement, depending on how much
useful work the numa code can do. The more local faults there are in a
given scan window the longer the period (and hence the slower the scan rate)
during the next window. If there are excessive shared faults then the scan
period will decrease with the amount of scaling depending on whether the
ratio of shared/private faults. If the preferred node changes then the
scan rate is reset to recheck if the task is properly placed.
Link: http://lkml.kernel.org/r/1381141781-10992-59-git-send-email-mgorman@suse.de
Scan rate is altered based on whether shared/private faults dominated.
task_numa_group() may detect false sharing but that information is not
taken into account when adapting the scan rate. Take it into account.
Link: http://lkml.kernel.org/r/1381141781-10992-58-git-send-email-mgorman@suse.de
Due to the way the pid is truncated, and tasks are moved between
CPUs by the scheduler, it is possible for the current task_numa_fault
to group together tasks that do not actually share memory together.
This patch adds a few easy sanity checks to task_numa_fault, joining
tasks together if they share the same tsk->mm, or if the fault was on
a page with an elevated mapcount, in a shared VMA.
Link: http://lkml.kernel.org/r/1381141781-10992-57-git-send-email-mgorman@suse.de
This patch classifies scheduler domains and runqueues into types depending
the number of tasks that are about their NUMA placement and the number
that are currently running on their preferred node. The types are
regular: There are tasks running that do not care about their NUMA
placement.
remote: There are tasks running that care about their placement but are
currently running on a node remote to their ideal placement
all: No distinction
To implement this the patch tracks the number of tasks that are optimally
NUMA placed (rq->nr_preferred_running) and the number of tasks running
that care about their placement (nr_numa_running). The load balancer
uses this information to avoid migrating idea placed NUMA tasks as long
as better options for load balancing exists. For example, it will not
consider balancing between a group whose tasks are all perfectly placed
and a group with remote tasks.
Link: http://lkml.kernel.org/r/1381141781-10992-56-git-send-email-mgorman@suse.de
This patch separately considers task and group affinities when
searching for swap candidates during NUMA placement. If tasks
are part of the same group, or no group at all, the task weights
are considered.
Some hysteresis is added to prevent tasks within one group from
getting bounced between NUMA nodes due to tiny differences.
If tasks are part of different groups, the code compares group
weights, in order to favor grouping task groups together.
The patch also changes the group weight multiplier to be the
same as the task weight multiplier, since the two are no longer
added up like before.
Link: http://lkml.kernel.org/r/1381141781-10992-55-git-send-email-mgorman@suse.de
candidate relationships
This patch separately considers task and group affinities when searching
for swap candidates during task NUMA placement. If tasks are not part of
a group or the same group then the task weights are considered.
Otherwise the group weights are compared.
Link: http://lkml.kernel.org/r/1381141781-10992-54-git-send-email-mgorman@suse.de
Link: http://lkml.kernel.org/r/1381141781-10992-53-git-send-email-mgorman@suse.de
Having multiple tasks in a group go through task_numa_placement
simultaneously can lead to a task picking a wrong node to run on, because
the group stats may be in the middle of an update. This patch avoids
parallel updates by holding the numa_group lock during placement
decisions.
Link: http://lkml.kernel.org/r/1381141781-10992-52-git-send-email-mgorman@suse.de
It is possible for a task in a numa group to call exec, and
have the new (unrelated) executable inherit the numa group
association from its former self.
This has the potential to break numa grouping, and is trivial
to fix.
Link: http://lkml.kernel.org/r/1381141781-10992-51-git-send-email-mgorman@suse.de
This patch uses the fraction of faults on a particular node for both task
and group, to figure out the best node to place a task. If the task and
group statistics disagree on what the preferred node should be then a full
rescan will select the node with the best combined weight.
Link: http://lkml.kernel.org/r/1381141781-10992-50-git-send-email-mgorman@suse.de
And here's a little something to make sure not the whole world ends up
in a single group.
As while we don't migrate shared executable pages, we do scan/fault on
them. And since everybody links to libc, everybody ends up in the same
group.
Suggested-by: Rik van Riel <riel@redhat.com>
Link: http://lkml.kernel.org/r/1381141781-10992-47-git-send-email-mgorman@suse.de
It is desirable to model from userspace how the scheduler groups tasks
over time. This patch adds an ID to the numa_group and reports it via
/proc/PID/status.
Link: http://lkml.kernel.org/r/1381141781-10992-45-git-send-email-mgorman@suse.de
While parallel applications tend to align their data on the cache
boundary, they tend not to align on the page or THP boundary.
Consequently tasks that partition their data can still "false-share"
pages presenting a problem for optimal NUMA placement.
This patch uses NUMA hinting faults to chain tasks together into
numa_groups. As well as storing the NID a task was running on when
accessing a page a truncated representation of the faulting PID is
stored. If subsequent faults are from different PIDs it is reasonable
to assume that those two tasks share a page and are candidates for
being grouped together. Note that this patch makes no scheduling
decisions based on the grouping information.
Link: http://lkml.kernel.org/r/1381141781-10992-44-git-send-email-mgorman@suse.de
Change the per page last fault tracking to use cpu,pid instead of
nid,pid. This will allow us to try and lookup the alternate task more
easily. Note that even though it is the cpu that is store in the page
flags that the mpol_misplaced decision is still based on the node.
Link: http://lkml.kernel.org/r/1381141781-10992-43-git-send-email-mgorman@suse.de
[ Fixed build failure on 32-bit systems. ]
The load balancer will spread workloads across multiple NUMA nodes,
in order to balance the load on the system. This means that sometimes
a task's preferred node has available capacity, but moving the task
there will not succeed, because that would create too large an imbalance.
In that case, other NUMA nodes need to be considered.
Link: http://lkml.kernel.org/r/1381141781-10992-42-git-send-email-mgorman@suse.de
A tasks preferred node is selected based on the number of faults
recorded for a node but the actual task_numa_migate() conducts a global
search regardless of the preferred nid. This patch checks if the
preferred nid has capacity and if so, searches for a CPU within that
node. This avoids a global search when the preferred node is not
overloaded.
Link: http://lkml.kernel.org/r/1381141781-10992-41-git-send-email-mgorman@suse.de
This patch implements a system-wide search for swap/migration candidates
based on total NUMA hinting faults. It has a balance limit, however it
doesn't properly consider total node balance.
In the old scheme a task selected a preferred node based on the highest
number of private faults recorded on the node. In this scheme, the preferred
node is based on the total number of faults. If the preferred node for a
task changes then task_numa_migrate will search the whole system looking
for tasks to swap with that would improve both the overall compute
balance and minimise the expected number of remote NUMA hinting faults.
Not there is no guarantee that the node the source task is placed
on by task_numa_migrate() has any relationship to the newly selected
task->numa_preferred_nid due to compute overloading.
[ Do not swap with tasks that cannot run on source cpu]
[ Fixed compiler warning on UP. ]
Link: http://lkml.kernel.org/r/1381141781-10992-40-git-send-email-mgorman@suse.de
Use the new stop_two_cpus() to implement migrate_swap(), a function that
flips two tasks between their respective cpus.
I'm fairly sure there's a less crude way than employing the stop_two_cpus()
method, but everything I tried either got horribly fragile and/or complex. So
keep it simple for now.
The notable detail is how we 'migrate' tasks that aren't runnable
anymore. We'll make it appear like we migrated them before they went to
sleep. The sole difference is the previous cpu in the wakeup path, so we
override this.
Link: http://lkml.kernel.org/r/1381141781-10992-39-git-send-email-mgorman@suse.de
NUMA hinting faults will not migrate a shared executable page mapped by
multiple processes on the grounds that the data is probably in the CPU
cache already and the page may just bounce between tasks running on multipl
nodes. Even if the migration is avoided, there is still the overhead of
trapping the fault, updating the statistics, making scheduler placement
decisions based on the information etc. If we are never going to migrate
the page, it is overhead for no gain and worse a process may be placed on
a sub-optimal node for shared executable pages. This patch avoids trapping
faults for shared libraries entirely.
Link: http://lkml.kernel.org/r/1381141781-10992-36-git-send-email-mgorman@suse.de
When a task is already running on its preferred node, increment
numa_migrate_seq to indicate that the task is settled if migration is
temporarily disabled, and memory should migrate towards it.
[ Only increment migrate_seq if migration temporarily disabled. ]
Link: http://lkml.kernel.org/r/1381141781-10992-35-git-send-email-mgorman@suse.de
When a preferred node is selected for a tasks there is an attempt to migrate
the task to a CPU there. This may fail in which case the task will only
migrate if the active load balancer takes action. This may never happen if
the conditions are not right. This patch will check at NUMA hinting fault
time if another attempt should be made to migrate the task. It will only
make an attempt once every five seconds.
Link: http://lkml.kernel.org/r/1381141781-10992-34-git-send-email-mgorman@suse.de
This patch replaces find_idlest_cpu_node with task_numa_find_cpu.
find_idlest_cpu_node has two critical limitations. It does not take the
scheduling class into account when calculating the load and it is unsuitable
for using when comparing loads between NUMA nodes.
task_numa_find_cpu uses similar load calculations to wake_affine() when
selecting the least loaded CPU within a scheduling domain common to the
source and destimation nodes. It avoids causing CPU load imbalances in
the machine by refusing to migrate if the relative load on the target
CPU is higher than the source CPU.
Link: http://lkml.kernel.org/r/1381141781-10992-33-git-send-email-mgorman@suse.de
There is a 90% regression observed with a large Oracle performance test
on a 4 node system. Profiles indicated that the overhead was due to
contention on sp_lock when looking up shared memory policies. These
policies do not have the appropriate flags to allow them to be
automatically balanced so trapping faults on them is pointless. This
patch skips VMAs that do not have MPOL_F_MOF set.
[riel@redhat.com: Initial patch]
Reported-and-tested-by: Joe Mario <jmario@redhat.com>
Link: http://lkml.kernel.org/r/1381141781-10992-32-git-send-email-mgorman@suse.de
The load balancer can move tasks between nodes and does not take NUMA
locality into account. With automatic NUMA balancing this may result in the
tasks working set being migrated to the new node. However, as the fault
buffer will still store faults from the old node the schduler may decide to
reset the preferred node and migrate the task back resulting in more
migrations.
The ideal would be that the scheduler did not migrate tasks with a heavy
memory footprint but this may result nodes being overloaded. We could
also discard the fault information on task migration but this would still
cause all the tasks working set to be migrated. This patch simply avoids
migrating the memory for a short time after a task is migrated.
Link: http://lkml.kernel.org/r/1381141781-10992-31-git-send-email-mgorman@suse.de
Ideally it would be possible to distinguish between NUMA hinting faults that
are private to a task and those that are shared. If treated identically
there is a risk that shared pages bounce between nodes depending on
the order they are referenced by tasks. Ultimately what is desirable is
that task private pages remain local to the task while shared pages are
interleaved between sharing tasks running on different nodes to give good
average performance. This is further complicated by THP as even
applications that partition their data may not be partitioning on a huge
page boundary.
To start with, this patch assumes that multi-threaded or multi-process
applications partition their data and that in general the private accesses
are more important for cpu->memory locality in the general case. Also,
no new infrastructure is required to treat private pages properly but
interleaving for shared pages requires additional infrastructure.
To detect private accesses the pid of the last accessing task is required
but the storage requirements are a high. This patch borrows heavily from
Ingo Molnar's patch "numa, mm, sched: Implement last-CPU+PID hash tracking"
to encode some bits from the last accessing task in the page flags as
well as the node information. Collisions will occur but it is better than
just depending on the node information. Node information is then used to
determine if a page needs to migrate. The PID information is used to detect
private/shared accesses. The preferred NUMA node is selected based on where
the maximum number of approximately private faults were measured. Shared
faults are not taken into consideration for a few reasons.
First, if there are many tasks sharing the page then they'll all move
towards the same node. The node will be compute overloaded and then
scheduled away later only to bounce back again. Alternatively the shared
tasks would just bounce around nodes because the fault information is
effectively noise. Either way accounting for shared faults the same as
private faults can result in lower performance overall.
The second reason is based on a hypothetical workload that has a small
number of very important, heavily accessed private pages but a large shared
array. The shared array would dominate the number of faults and be selected
as a preferred node even though it's the wrong decision.
The third reason is that multiple threads in a process will race each
other to fault the shared page making the fault information unreliable.
[ Fix complication error when !NUMA_BALANCING. ]
Link: http://lkml.kernel.org/r/1381141781-10992-30-git-send-email-mgorman@suse.de
task_numa_work skips small VMAs. At the time the logic was to reduce the
scanning overhead which was considerable. It is a dubious hack at best.
It would make much more sense to cache where faults have been observed
and only rescan those regions during subsequent PTE scans. Remove this
hack as motivation to do it properly in the future.
Link: http://lkml.kernel.org/r/1381141781-10992-29-git-send-email-mgorman@suse.de
task_numa_placement checks current->mm but after buffers for faults
have already been uselessly allocated. Move the check earlier.
[peterz@infradead.org: Identified the problem]
Link: http://lkml.kernel.org/r/1381141781-10992-27-git-send-email-mgorman@suse.de
hinting faults
that are private to a task and those that are shared. This patch prepares
infrastructure for separately accounting shared and private faults by
allocating the necessary buffers and passing in relevant information. For
now, all faults are treated as private and detection will be introduced
later.
Link: http://lkml.kernel.org/r/1381141781-10992-26-git-send-email-mgorman@suse.de
A preferred node is selected based on the node the most NUMA hinting
faults was incurred on. There is no guarantee that the task is running
on that node at the time so this patch rescheules the task to run on
the most idle CPU of the selected node when selected. This avoids
waiting for the balancer to make a decision.
Link: http://lkml.kernel.org/r/1381141781-10992-25-git-send-email-mgorman@suse.de
Just as "sched: Favour moving tasks towards the preferred node" favours
moving tasks towards nodes with a higher number of recorded NUMA hinting
faults, this patch resists moving tasks towards nodes with lower faults.
Link: http://lkml.kernel.org/r/1381141781-10992-24-git-send-email-mgorman@suse.de
