Rename several local functions related to platform handling during
system suspend resume in suspend.c so that their names better
reflect their roles.
Subsequent change sets will add platform-related operations between
dpm_suspend_late() and dpm_suspend_noirq() as well as between
dpm_resume_noirq() and dpm_resume_early() in suspend_enter(), so
export these functions for suspend_enter() to be able to call them
separately and split the invocations of dpm_suspend_end() and
dpm_resume_start() in there accordingly.
Also adds a class type PM_QOS_SUM that aggregates the values by summing them.
It can be used by memory controllers to calculate the optimum clock frequency
based on the bandwidth needs of the different memory clients.
Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
Revert commit 6efde38f0769 (PM / Hibernate: Iterate over set bits
instead of PFNs in swsusp_free()) that introduced a NULL pointer
dereference during system resume from hibernation:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff810a8cc1>] swsusp_free+0x21/0x190
PGD b39c2067 PUD b39c1067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in: <irrelevant list of modules>
CPU: 1 PID: 4898 Comm: s2disk Tainted: G C 3.17-rc5-amd64 #1 Debian 3.17~rc5-1~exp1
Hardware name: LENOVO 2776LEG/2776LEG, BIOS 6EET55WW (3.15 ) 12/19/2011
task: ffff88023155ea40 ti: ffff8800b3b14000 task.ti: ffff8800b3b14000
RIP: 0010:[<ffffffff810a8cc1>] [<ffffffff810a8cc1>]
RSP: 0018:ffff8800b3b17ea8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff8800b39bab00 RCX: 0000000000000001
RDX: ffff8800b39bab10 RSI: ffff8800b39bab00 RDI: 0000000000000000
RBP: 0000000000000010 R08: 0000000000000000 R09: 0000000000000000
R10: ffff8800b39bab10 R11: 0000000000000246 R12: ffffea0000000000
R13: ffff880232f485a0 R14: ffff88023ac27cd8 R15: ffff880232927590
FS: 00007f406d83b700(0000) GS:ffff88023bc80000(0000)
knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000000 CR3: 00000000b3a62000 CR4: 00000000000007e0
Stack:
ffff8800b39bab00 0000000000000010 ffff880232927590 ffffffff810acb4a
ffff8800b39bab00 ffffffff811a955a ffff8800b39bab10 0000000000000000
ffff88023155f098 ffffffff81a6b8c0 ffff88023155ea40 0000000000000007
Call Trace:
[<ffffffff810acb4a>] ? snapshot_release+0x2a/0xb0
[<ffffffff811a955a>] ? __fput+0xca/0x1d0
[<ffffffff81080627>] ? task_work_run+0x97/0xd0
[<ffffffff81012d89>] ? do_notify_resume+0x69/0xa0
[<ffffffff8151452a>] ? int_signal+0x12/0x17
Code: 66 2e 0f 1f 84 00 00 00 00 00 66 66 66 66 90 41 54 48 8b 05 ba 62 9c 00 49 bc 00 00 00 00 00 ea ff ff 48 8b 3d a1 62 9c 00 55 53 <48> 8b 10 48 89 50 18 48 8b 52 20 48 c7 40 28 00 00 00 00 c7 40
RIP [<ffffffff810a8cc1>] swsusp_free+0x21/0x190
RSP <ffff8800b3b17ea8>
---[ end trace f02be86a1ec0cccb ]---
due to forbidden_pages_map being NULL in swsusp_free().
Fixes: 6efde38f0769 "PM / Hibernate: Iterate over set bits instead of PFNs in swsusp_free()"
Reported-by: Bjørn Mork <bjorn@mork.no>
This patch moves Exynos PM domain code to use the new generic PM domain
look-up framework introduced in previous patches, thus also allowing
the new code to be compiled with CONFIG_ARCH_EXYNOS.
This patch was originally submitted by Tomasz Figa when he was employed
by Samsung.
Link: http://marc.info/?l=linux-pm&m=139955336002083&w=2
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Reviewed-by: Kevin Hilman <khilman@linaro.org>
Reviewed-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
This patch introduces generic code to perform PM domain look-up using
device tree and automatically bind devices to their PM domains.
Generic device tree bindings are introduced to specify PM domains of
devices in their device tree nodes.
Backwards compatibility with legacy Samsung-specific PM domain bindings
is provided, but for now the new code is not compiled when
CONFIG_ARCH_EXYNOS is selected to avoid collision with legacy code.
This will change as soon as the Exynos PM domain code gets converted to
use the generic framework in further patch.
by Samsung.
Link: http://marc.info/?l=linux-pm&m=139955349702152&w=2
Acked-by: Rob Herring <robh@kernel.org>
Tested-by: Philipp Zabel <p.zabel@pengutronix.de>
This patch adds another suspend_resume trace event for analyze_suspend
to capture. The resume_console call can take several hundred milliseconds
if the printk buffer is full of debug info. The tool will now inform
testers of the wasted time and encourage them to disable it in
production builds.
Signed-off-by: Todd Brandt <todd.e.brandt@intel.com>
Enhanced test_suspend boot paramter to repeat tests multiple times,
by adding optional repeat count. The new boot param syntax:
test_suspend="mem|freeze|standby[,N]"
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Added freeze as one of the option for test_suspend boot param.
After commit d431cbc53cb7 (PM / sleep: Simplify sleep states sysfs
interface code) the pm_states[] array is not populated initially,
which causes setup_test_suspend() to always fail and the suspend
testing during boot doesn't work any more.
Fix the problem by using pm_labels[] instead of pm_states[] in
setup_test_suspend() and storing a pointer to the label of the
sleep state to test rather than the number representing it,
because the connection between the state numbers and labels is
only established by suspend_set_ops().
Fixes: d431cbc53cb7 (PM / sleep: Simplify sleep states sysfs interface code)
Reported-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
It sometimes may be necessary to abort a system suspend in
progress or wake up the system from suspend-to-idle even if the
pm_wakeup_event()/pm_stay_awake() mechanism is not enabled.
For this purpose, introduce a new global variable pm_abort_suspend
and make pm_wakeup_pending() check its value. Also add routines
for manipulating that variable.
* pm-sleep:
PM / hibernate: avoid unsafe pages in e820 reserved regions
* pm-cpufreq:
cpufreq: arm_big_little: fix module license spec
cpufreq: speedstep-smi: fix decimal printf specifiers
cpufreq: OPP: Avoid sleeping while atomic
cpufreq: cpu0: Do not print error message when deferring
cpufreq: integrator: Use set_cpus_allowed_ptr
* pm-cpuidle:
cpuidle: menu: Lookup CPU runqueues less
cpuidle: menu: Call nr_iowait_cpu less times
cpuidle: menu: Use ktime_to_us instead of reinventing the wheel
cpuidle: menu: Use shifts when calculating averages where possible
Pull ACPI and power management updates from Rafael Wysocki:
"Again, ACPICA leads the pack (47 commits), followed by cpufreq (18
commits) and system suspend/hibernation (9 commits).
From the new code perspective, the ACPICA update brings ACPI 5.1 to
the table, including a new device configuration object called _DSD
(Device Specific Data) that will hopefully help us to operate device
properties like Device Trees do (at least to some extent) and changes
related to supporting ACPI on ARM.
Apart from that we have hibernation changes making it use radix trees
to store memory bitmaps which should speed up some operations carried
out by it quite significantly. We also have some power management
changes related to suspend-to-idle (the "freeze" sleep state) support
and more preliminary changes needed to support ACPI on ARM (outside of
ACPICA).
The rest is fixes and cleanups pretty much everywhere.
Specifics:
- ACPICA update to upstream version 20140724. That includes ACPI 5.1
material (support for the _CCA and _DSD predefined names, changes
related to the DMAR and PCCT tables and ARM support among other
things) and cleanups related to using ACPICA's header files. A
major part of it is related to acpidump and the core code used by
that utility. Changes from Bob Moore, David E Box, Lv Zheng,
Sascha Wildner, Tomasz Nowicki, Hanjun Guo.
- Radix trees for memory bitmaps used by the hibernation core from
Joerg Roedel.
- Support for waking up the system from suspend-to-idle (also known
as the "freeze" sleep state) using ACPI-based PCI wakeup signaling
(Rafael J Wysocki).
- Fixes for issues related to ACPI button events (Rafael J Wysocki).
- New device ID for an ACPI-enumerated device included into the
Wildcat Point PCH from Jie Yang.
- ACPI video updates related to backlight handling from Hans de Goede
and Linus Torvalds.
- Preliminary changes needed to support ACPI on ARM from Hanjun Guo
and Graeme Gregory.
- ACPI PNP core cleanups from Arjun Sreedharan and Zhang Rui.
- Cleanups related to ACPI_COMPANION() and ACPI_HANDLE() macros
(Rafael J Wysocki).
- ACPI-based device hotplug cleanups from Wei Yongjun and Rafael J
Wysocki.
- Cleanups and improvements related to system suspend from Lan
Tianyu, Randy Dunlap and Rafael J Wysocki.
- ACPI battery cleanup from Wei Yongjun.
- cpufreq core fixes from Viresh Kumar.
- Elimination of a deadband effect from the cpufreq ondemand governor
and intel_pstate driver cleanups from Stratos Karafotis.
- 350MHz CPU support for the powernow-k6 cpufreq driver from Mikulas
Patocka.
- Fix for the imx6 cpufreq driver from Anson Huang.
- cpuidle core and governor cleanups from Daniel Lezcano, Sandeep
Tripathy and Mohammad Merajul Islam Molla.
- Build fix for the big_little cpuidle driver from Sachin Kamat.
- Configuration fix for the Operation Performance Points (OPP)
framework from Mark Brown.
- APM cleanup from Jean Delvare.
- cpupower utility fixes and cleanups from Peter Senna Tschudin,
Andrey Utkin, Himangi Saraogi, Rickard Strandqvist, Thomas
Renninger"
* tag 'pm+acpi-3.17-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (118 commits)
ACPI / LPSS: add LPSS device for Wildcat Point PCH
ACPI / PNP: Replace faulty is_hex_digit() by isxdigit()
ACPICA: Update version to 20140724.
ACPICA: ACPI 5.1: Update for PCCT table changes.
ACPICA/ARM: ACPI 5.1: Update for GTDT table changes.
ACPICA/ARM: ACPI 5.1: Update for MADT changes.
ACPICA/ARM: ACPI 5.1: Update for FADT changes.
ACPICA: ACPI 5.1: Support for the _CCA predifined name.
ACPICA: ACPI 5.1: New notify value for System Affinity Update.
ACPICA: ACPI 5.1: Support for the _DSD predefined name.
ACPICA: Debug object: Add current value of Timer() to debug line prefix.
ACPICA: acpihelp: Add UUID support, restructure some existing files.
ACPICA: Utilities: Fix local printf issue.
ACPICA: Tables: Update for DMAR table changes.
ACPICA: Remove some extraneous printf arguments.
ACPICA: Update for comments/formatting. No functional changes.
ACPICA: Disassembler: Add support for the ToUUID opererator (macro).
ACPICA: Remove a redundant cast to acpi_size for ACPI_OFFSET() macro.
ACPICA: Work around an ancient GCC bug.
ACPI / processor: Make it possible to get local x2apic id via _MAT
When the machine doesn't well handle the e820 persistent when hibernate
resuming, then it may cause page fault when writing image to snapshot
buffer:
[ 17.929495] BUG: unable to handle kernel paging request at ffff880069d4f000
[ 17.933469] IP: [<ffffffff810a1cf0>] load_image_lzo+0x810/0xe40
[ 17.933469] PGD 2194067 PUD 77ffff067 PMD 2197067 PTE 0
[ 17.933469] Oops: 0002 [#1] SMP
The ffff880069d4f000 page is in e820 reserved region of resume boot
kernel:
[ 0.000000] BIOS-e820: [mem 0x0000000069d4f000-0x0000000069e12fff] reserved
[ 0.000000] PM: Registered nosave memory: [mem 0x69d4f000-0x69e12fff]
So snapshot.c mark the pfn to forbidden pages map. But, this
page is also in the memory bitmap in snapshot image because it's an
original page used by image kernel, so it will also mark as an
unsafe(free) page in prepare_image().
That means the page in e820 when resuming mark as "forbidden" and
"free", it causes get_buffer() treat it as an allocated unsafe page.
Then snapshot_write_next() return this page to load_image, load_image
writing content to this address, but this page didn't really allocated
. So, we got page fault.
Although the root cause is from BIOS, I think aggressive check and
significant message in kernel will better then a page fault for
issue tracking, especially when serial console unavailable.
This patch adds code in mark_unsafe_pages() for check does free pages in
nosave region. If so, then it print message and return fault to stop whole
S4 resume process:
[ 8.166004] PM: Image loading progress: 0%
[ 8.658717] PM: 0x6796c000 in e820 nosave region: [mem 0x6796c000-0x6796cfff]
[ 8.918737] PM: Read 2511940 kbytes in 1.04 seconds (2415.32 MB/s)
[ 8.926633] PM: Error -14 resuming
[ 8.933534] PM: Failed to load hibernation image, recovering.
Reviewed-by: Takashi Iwai <tiwai@suse.de>
Signed-off-by: Lee, Chun-Yi <jlee@suse.com>
[rjw: Subject]
* pm-sleep:
PM / Hibernate: Touch Soft Lockup Watchdog in rtree_next_node
PM / Hibernate: Remove the old memory-bitmap implementation
PM / Hibernate: Implement position keeping in radix tree
PM / Hibernate: Add memory_rtree_find_bit function
PM / Hibernate: Create a Radix-Tree to store memory bitmap
PM / sleep: fix kernel-doc warnings in drivers/base/power/main.c
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing updates from Steven Rostedt:
"This pull request has a lot of work done. The main thing is the
changes to the ftrace function callback infrastructure. It's
introducing a way to allow different functions to call directly
different trampolines instead of all calling the same "mcount" one.
The only user of this for now is the function graph tracer, which
always had a different trampoline, but the function tracer trampoline
was called and did basically nothing, and then the function graph
tracer trampoline was called. The difference now, is that the
function graph tracer trampoline can be called directly if a function
is only being traced by the function graph trampoline. If function
tracing is also happening on the same function, the old way is still
done.
The accounting for this takes up more memory when function graph
tracing is activated, as it needs to keep track of which functions it
uses. I have a new way that wont take as much memory, but it's not
ready yet for this merge window, and will have to wait for the next
one.
Another big change was the removal of the ftrace_start/stop() calls
that were used by the suspend/resume code that stopped function
tracing when entering into suspend and resume paths. The stop of
ftrace was done because there was some function that would crash the
system if one called smp_processor_id()! The stop/start was a big
hammer to solve the issue at the time, which was when ftrace was first
introduced into Linux. Now ftrace has better infrastructure to debug
such issues, and I found the problem function and labeled it with
"notrace" and function tracing can now safely be activated all the way
down into the guts of suspend and resume
Other changes include clean ups of uprobe code, clean up of the
trace_seq() code, and other various small fixes and clean ups to
ftrace and tracing"
* tag 'trace-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (57 commits)
ftrace: Add warning if tramp hash does not match nr_trampolines
ftrace: Fix trampoline hash update check on rec->flags
ring-buffer: Use rb_page_size() instead of open coded head_page size
ftrace: Rename ftrace_ops field from trampolines to nr_trampolines
tracing: Convert local function_graph functions to static
ftrace: Do not copy old hash when resetting
tracing: let user specify tracing_thresh after selecting function_graph
ring-buffer: Always run per-cpu ring buffer resize with schedule_work_on()
tracing: Remove function_trace_stop and HAVE_FUNCTION_TRACE_MCOUNT_TEST
s390/ftrace: remove check of obsolete variable function_trace_stop
arm64, ftrace: Remove check of obsolete variable function_trace_stop
Blackfin: ftrace: Remove check of obsolete variable function_trace_stop
metag: ftrace: Remove check of obsolete variable function_trace_stop
microblaze: ftrace: Remove check of obsolete variable function_trace_stop
MIPS: ftrace: Remove check of obsolete variable function_trace_stop
parisc: ftrace: Remove check of obsolete variable function_trace_stop
sh: ftrace: Remove check of obsolete variable function_trace_stop
sparc64,ftrace: Remove check of obsolete variable function_trace_stop
tile: ftrace: Remove check of obsolete variable function_trace_stop
ftrace: x86: Remove check of obsolete variable function_trace_stop
When a memory bitmap is fully populated on a large memory
machine (several TB of RAM) it can take more than a minute
to walk through all bits. This causes the soft lockup
detector on these machine to report warnings.
Avoid this by touching the soft lockup watchdog in the
memory bitmap walking code.
Signed-off-by: Joerg Roedel <jroedel@suse.de>
The radix tree implementatio is proved to work the same as
the old implementation now. So the old implementation can be
removed to finish the switch to the radix tree for the
memory bitmaps.
The existing implementation of swsusp_free iterates over all
pfns in the system and checks every bit in the two memory
bitmaps.
This doesn't scale very well with large numbers of pfns,
especially when the bitmaps are not populated very densly.
Change the algorithm to iterate over the set bits in the
bitmaps instead to make it scale better in large memory
configurations.
Also add a memory_bm_clear_current() helper function that
clears the bit for the last position returned from the
memory bitmap.
Add code to remember the last position that was requested in
the radix tree. Use it as a cache for faster linear walking
of the bitmap in the memory_bm_rtree_next_pfn() function
which is also added with this patch.
Add a function to find a bit in the radix tree for a given
pfn. Also add code to the memory bitmap wrapper functions to
use the radix tree together with the existing memory bitmap
implementation.
On read accesses compare the results of both bitmaps to make
sure the radix tree behaves the same way.
This patch adds the code to allocate and build the radix
tree to store the memory bitmap. The old data structure is
left in place until the radix tree implementation is
finished.
* pm-opp:
PM / OPP: Remove ARCH_HAS_OPP
* pm-general:
MAINTAINERS: power_supply: update maintainership
* pm-apm:
x86, apm: Remove unused variable
* pm-sleep:
PM / sleep: Move platform suspend operations to separate functions
The PM workqueue is going to be used by ACPI PM notify handlers
regardless of whether or not runtime PM is configured, so move
it out of #ifdef CONFIG_PM_RUNTIME.
Do that in three places in the ACPI device PM code.
After the introduction of freeze_ops it makes more sense to move
all of the platform suspend operations to separate functions that
each will do all of the necessary checks and choose the right
callback to execute istead of doing all that in the core code
which makes it generally harder to follow.
Since the OPP layer is a kernel library which has been converted to be
directly selectable by its callers rather than user selectable and
requiring architectures to enable it explicitly the ARCH_HAS_OPP symbol
has become redundant and can be removed. Do so.
Signed-off-by: Mark Brown <broonie@linaro.org>
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Nishanth Menon <nm@ti.com>
Acked-by: Shawn Guo <shawn.guo@freescale.com>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Simplify the sleep states sysfs interface /sys/power/state code by
redefining pm_states[] as an array of pointers to constant strings
such that only the entries corresponding to valid states are set.
ftrace_stop() and ftrace_start() were added to the suspend and hibernate
process because there was some function within the work flow that caused
the system to reboot if it was traced. This function has recently been
found (restore_processor_state()). Now there's no reason to disable
function tracing while we are going into suspend or hibernate, which means
that being able to trace this will help tremendously in debugging any
issues with suspend or hibernate.
This also means that the ftrace_stop/start() functions can be removed
and simplify the function tracing code a bit.
Link: http://lkml.kernel.org/r/1518201.VD9cU33jRU@vostro.rjw.lan
Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
This patch fixes a NULL pointer dereference issue introduced by
commit 1f0b63866fc1 (ACPI / PM: Hold ACPI scan lock over the "freeze"
sleep state).
Fixes: 1f0b63866fc1 (ACPI / PM: Hold ACPI scan lock over the "freeze" sleep state)
Link: http://marc.info/?l=linux-pm&m=140541182017443&w=2
Reported-and-tested-by: Alexander Stein <alexander.stein@systec-electronic.com>
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
The commit [247bc037: PM / Sleep: Mitigate race between the freezer
and request_firmware()] introduced the finer state control, but it
also leads to a new bug; for example, a bug report regarding the
firmware loading of intel BT device at suspend/resume:
https://bugzilla.novell.com/show_bug.cgi?id=873790
The root cause seems to be a small window between the process resume
and the clear of usermodehelper lock. The request_firmware() function
checks the UMH lock and gives up when it's in UMH_DISABLE state. This
is for avoiding the invalid f/w loading during suspend/resume phase.
The problem is, however, that usermodehelper_enable() is called at the
end of thaw_processes(). Thus, a thawed process in between can kick
off the f/w loader code path (in this case, via btusb_setup_intel())
even before the call of usermodehelper_enable(). Then
usermodehelper_read_trylock() returns an error and request_firmware()
spews WARN_ON() in the end.
This oneliner patch fixes the issue just by setting to UMH_FREEZING
state again before restarting tasks, so that the call of
request_firmware() will be blocked until the end of this function
instead of returning an error.
Fixes: 247bc0374254 (PM / Sleep: Mitigate race between the freezer and request_firmware())
Link: https://bugzilla.novell.com/show_bug.cgi?id=873790
Cc: 3.4+ <stable@vger.kernel.org> # 3.4+
Changes kASLR from being compile-time selectable (blocked by
CONFIG_HIBERNATION), to being boot-time selectable (with hibernation
available by default) via the "kaslr" kernel command line.
To support using kernel features that are not compatible with hibernation,
this creates the "nohibernate" kernel boot parameter to disable both
hibernation and resume. This allows hibernation support to be a boot-time
choice instead of only a compile-time choice.
* pm-sleep:
PM / sleep: trace events for device PM callbacks
PM / sleep: trace events for suspend/resume
Adds trace events that give finer resolution into suspend/resume. These
events are graphed in the timelines generated by the analyze_suspend.py
script. They represent large areas of time consumed that are typical to
suspend and resume.
The event is triggered by calling the function "trace_suspend_resume"
with three arguments: a string (the name of the event to be displayed
in the timeline), an integer (case specific number, such as the power
state or cpu number), and a boolean (where true is used to denote the start
of the timeline event, and false to denote the end).
The suspend_resume trace event reproduces the data that the machine_suspend
trace event did, so the latter has been removed.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
* pnp:
MAINTAINERS: Remove Bjorn Helgaas as PNP maintainer
PNP / resources: remove positive test on unsigned values
* powercap:
powercap / RAPL: add new CPU IDs
powercap / RAPL: further relax energy counter checks
* pm-runtime:
PM / runtime: Update documentation to reflect the current code flow
* pm-opp:
PM / OPP: discard duplicate OPPs
PM / OPP: Make OPP invisible to users in Kconfig
PM / OPP: fix incorrect OPP count handling in of_init_opp_table
* acpi-pm:
ACPI / PM: Export rest of the subsys PM callbacks
ACPI / PM: Avoid resuming devices in ACPI PM domain during system suspend
ACPI / PM: Export acpi_target_system_state() to modules
* pm-sleep:
PM / hibernate: fixed typo in comment
PM / sleep: unregister wakeup source when disabling device wakeup
PM / sleep: Introduce command line argument for sleep state enumeration
PM / sleep: Use valid_state() for platform-dependent sleep states only
PM / sleep: Add state field to pm_states[] entries
PM / sleep: Update device PM documentation to cover direct_complete
PM / sleep: Mechanism to avoid resuming runtime-suspended devices unnecessarily
PM / hibernate: Fix memory corruption in resumedelay_setup()
PM / hibernate: convert simple_strtoul to kstrtoul
PM / hibernate: Documentation: Fix script for unswapping
PM / hibernate: no kernel_power_off when pm_power_off NULL
PM / hibernate: use unsigned local variables in swsusp_show_speed()
* pm-cpuidle:
PM / suspend: Always use deepest C-state in the "freeze" sleep state
cpuidle / menu: move repeated correction factor check to init
cpuidle / menu: Return (-1) if there are no suitable states
cpuidle: Combine cpuidle_enabled() with cpuidle_select()
ARM: clps711x: Add cpuidle driver
Fix a trivial comment typo (s/mam/map) in kernel/power/swap.c.
Signed-off-by: Niv Yehezkel <executerx@gmail.com>
On some systems the platform doesn't support neither
PM_SUSPEND_MEM nor PM_SUSPEND_STANDBY, so PM_SUSPEND_FREEZE is the
only available system sleep state. However, some user space frameworks
only use the "mem" and (sometimes) "standby" sleep state labels, so
the users of those systems need to modify user space in order to be
able to use system suspend at all and that is not always possible.
For this reason, add a new kernel command line argument,
relative_sleep_states, allowing the users of those systems to change
the way in which the kernel assigns labels to system sleep states.
Namely, for relative_sleep_states=1, the "mem", "standby" and "freeze"
labels will enumerate the available system sleem states from the
deepest to the shallowest, respectively, so that "mem" is always
present in /sys/power/state and the other state strings may or may
not be presend depending on what is supported by the platform.
Update system sleep states documentation to reflect this change.
Use the observation that, for platform-dependent sleep states
(PM_SUSPEND_STANDBY, PM_SUSPEND_MEM), a given state is either
always supported or always unsupported and store that information
in pm_states[] instead of calling valid_state() every time we
need to check it.
Also do not use valid_state() for PM_SUSPEND_FREEZE, which is always
valid, and move the pm_test_level validity check for PM_SUSPEND_FREEZE
directly into enter_state().
To allow sleep states corresponding to the "mem", "standby" and
"freeze" lables to be different from the pm_states[] indexes of
those strings, introduce struct pm_sleep_state, consisting of
a string label and a state number, and turn pm_states[] into an
array of objects of that type.
This modification should not lead to any functional changes.
The OPP code is an in kernel library selected by its users, there is no
no architecture code required to implement it and enabling it without a
user just increases the kernel size. Since the users select rather than
depend on it just remove the ability to directly set the option from
Kconfig.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
In the original code "resume_delay" is an int so on 64 bits, the call to
kstrtoul() will cause memory corruption. We may as well fix a style
issue here as well and make "resume_delay" unsigned int, since that's
what we pass to ssleep().
Fixes: 317cf7e5e85e (PM / hibernate: convert simple_strtoul to kstrtoul)
The "freeze" sleep state suffers from the same issue that was
addressed by commit ad07277e82de (ACPI / PM: Hold acpi_scan_lock over
system PM transitions) for ACPI sleep states, that is, things break
if ->remove() is called for devices whose system resume callbacks
haven't been executed yet.
It also can be addressed in the same way, by holding the ACPI scan
lock over the "freeze" sleep state and PM transitions to and from
that state, but ->begin() and ->end() platform operations for the
"freeze" sleep state are needed for this purpose.
This change has been tested on Acer Aspire S5 with Thunderbolt.
