Let kstrtos32_from_user() do the necessary calls and checks.
pm_qos_update_request_timeout() updates a qos and then schedules
a delayed work item to bring the qos back down to the default
after the timeout. When the work item runs, pm_qos_work_fn() will
call pm_qos_update_request() and deadlock because it tries to
cancel itself via cancel_delayed_work_sync(). Future callers of
that qos will also hang waiting to cancel the work that is
canceling itself. Let's extract the little bit of code that does
the real work of pm_qos_update_request() and call it from the
work function so that we don't deadlock.
Before ed1ac6e (PM: don't use [delayed_]work_pending()) this didn't
happen because the work function wouldn't try to cancel itself.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Reviewed-by: Tejun Heo <tj@kernel.org>
Cc: 3.9+ <stable@vger.kernel.org> # 3.9+
Adds tracepoints to pm_qos_add_request, pm_qos_update_request,
pm_qos_remove_request, and pm_qos_update_request_timeout.
It's useful for checking pm_qos_class, value, and timeout_us.
Signed-off-by: Sahara <keun-o.park@windriver.com>
This patch adds tracepoints to pm_qos_update_target and
pm_qos_update_flags. It's useful for checking pm qos action,
previous value and current value.
The valid start index for pm_qos_array is not 0, but
PM_QOS_CPU_DMA_LATENCY. There is a null_pm_qos at index 0 of
pm_qos_array. However, null_pm_qos is not created as misc device so
that inclusion of 0 index for checking pm_qos_class especially for
file operations is not proper here.
[rjw: Changelog, a bit]
There's no need to test whether a (delayed) work item is pending
before queueing, flushing or cancelling it, so remove work_pending()
tests used in those cases.
* pm-sleep:
PM / Freezer: Fixup compile error of try_to_freeze_nowarn()
driver core / PM: move the calling to device_pm_remove behind the calling to bus_remove_device
PM / Hibernate: use rb_entry
PM / sysfs: replace strict_str* with kstrto*
Replace strict_strtoul() with kstrtoul() in pm_async_store() and
pm_qos_power_write().
[rjw: Modified subject and changelog.]
Signed-off-by: Daniel Walter <sahne@0x90.at>
Acked-by: Pavel Machek <pavel@ucw.cz>
Introduce struct pm_qos_flags_request and struct pm_qos_flags
representing PM QoS flags request type and PM QoS flags constraint
type, respectively. With these definitions the data structures
will be arranged so that the list member of a struct pm_qos_flags
object will contain the head of a list of struct pm_qos_flags_request
objects representing all of the "flags" requests present for the
given device. Then, the effective_flags member of a struct
pm_qos_flags object will contain the bitwise OR of the flags members
of all the struct pm_qos_flags_request objects in the list.
Additionally, introduce helper function pm_qos_update_flags()
allowing the caller to manage the list of struct pm_qos_flags_request
pointed to by the list member of struct pm_qos_flags.
The flags are of type s32 so that the request's "value" field
is always of the same type regardless of what kind of request it
is (latency requests already have value fields of type s32).
Reviewed-by: Jean Pihet <j-pihet@ti.com>
Acked-by: mark gross <markgross@thegnar.org>
pm_qos_get_value don't return a return code in all cases. It's sure that
anything interesting happend after BUG() but this prevent any compilation
warning.
[rjw: Chaneged the new return value to PM_QOS_DEFAULT_VALUE.]
Signed-off-by: Luis Gonzalez Fernandez <luisgf@gmail.com>
The new API, pm_qos_update_request_timeout() is to provide a timeout
with pm_qos_update_request.
For example, pm_qos_update_request_timeout(req, 100, 1000), means that
QoS request on req with value 100 will be active for 1000 microseconds.
After 1000 microseconds, the QoS request thru req is reset. If there
were another pm_qos_update_request(req, x) during the 1000 us, this
new request with value x will override as this is another request on the
same req handle. A new request on the same req handle will always
override the previous request whether it is the conventional request or
it is the new timeout request.
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
Acked-by: Mark Gross <markgross@thegnar.org>
- Replace class ID #define with enumeration
- Loop through PM QoS objects during initialization (rather than
initializing them one-by-one)
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-by: Antti Miettinen <amiettinen@nvidia.com>
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Acked-by: markgross <markgross@thegnar.org>
Since commit 4a31a334, the name of this misc device is not initialized,
which leads to a funny device named /dev/(null) being created and
/proc/misc containing an entry with just a number but no name. The latter
leads to complaints by cryptsetup, which caused me to investigate this
matter.
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
Remove an "if" check, that repeats an equivalent one 6 lines above.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
These files were getting <linux/module.h> via an implicit non-obvious
path, but we want to crush those out of existence since they cost
time during compiles of processing thousands of lines of headers
for no reason. Give them the lightweight header that just contains
the EXPORT_SYMBOL infrastructure.
Add a global notification chain that gets called upon changes to the
aggregated constraint value for any device.
The notification callbacks are passing the full constraint request data
in order for the callees to have access to it. The current use is for the
platform low-level code to access the target device of the constraint.
Signed-off-by: Jean Pihet <j-pihet@ti.com>
Reviewed-by: Kevin Hilman <khilman@ti.com>
In preparation for the per-device constratins support:
- rename update_target to pm_qos_update_target
- generalize and export pm_qos_update_target for usage by the upcoming
per-device latency constraints framework:
* operate on struct pm_qos_constraints for constraints management,
* introduce an 'action' parameter for constraints add/update/remove,
* the return value indicates if the aggregated constraint value has
changed,
- update the internal code to operate on struct pm_qos_constraints
- add a NULL pointer check in the API functions
In preparation for the per-device constratins support, re-organize
the data strctures:
- add a struct pm_qos_constraints which contains the constraints
related data
- update struct pm_qos_object contents to the PM QoS internal object
data. Add a pointer to struct pm_qos_constraints
- update the internal code to use the new data structs.
Move around the PM QoS misc devices management code
for better readability.
- Misc fixes to improve code readability:
* rename struct pm_qos_request_list to struct pm_qos_request,
* rename pm_qos_req parameter to req in internal code,
consistenly use req in the API parameters,
* update the in-kernel API callers to the new parameters names,
* rename of fields names (requests, list, node, constraints)
The PM QoS implementation files are better named
kernel/power/qos.c and include/linux/pm_qos.h.
The PM QoS support is compiled under the CONFIG_PM option.
