path: root/kernel/nsproxy.c
2007-10-10[NET]: Add network namespace clone & unshare support.Eric W. Biederman
This patch allows you to create a new network namespace using sys_clone, or sys_unshare. As the network namespace is still experimental and under development clone and unshare support is only made available when CONFIG_NET_NS is selected at compile time. As this patch introduces network namespace support into code paths that exist when the CONFIG_NET is not selected there are a few additions made to net_namespace.h to allow a few more functions to be used when the networking stack is not compiled in. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-16namespace: ensure clone_flags are always stored in an unsigned longEric W. Biederman
While working on unshare support for the network namespace I noticed we were putting clone flags in an int. Which is weird because the syscall uses unsigned long and we at least need an unsigned to properly hold all of the unshare flags. So to make the code consistent, this patch updates the code to use unsigned long instead of int for the clone flags in those places where we get it wrong today. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16add a kmem_cache for nsproxy objectsCedric Le Goater
It should improve performance in some scenarii where a lot of these nsproxy objects are created by unsharing namespaces. This is a typical use of virtual servers that are being created or entered. This is also a good tool to find leaks and gather statistics on namespace usage. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Pavel Emelianov <xemul@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fix create_new_namespaces() return valueCedric Le Goater
dup_mnt_ns() and clone_uts_ns() return NULL on failure. This is wrong, create_new_namespaces() uses ERR_PTR() to catch an error. This means that the subsequent create_new_namespaces() will hit BUG_ON() in copy_mnt_ns() or copy_utsname(). Modify create_new_namespaces() to also use the errors returned by the copy_*_ns routines and not to systematically return ENOMEM. [oleg@tv-sign.ru: better changelog] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16user namespace: add unshareSerge E. Hallyn
This patch enables the unshare of user namespaces. It adds a new clone flag CLONE_NEWUSER and implements copy_user_ns() which resets the current user_struct and adds a new root user (uid == 0) For now, unsharing the user namespace allows a process to reset its user_struct accounting and uid 0 in the new user namespace should be contained using appropriate means, for instance selinux The plan, when the full support is complete (all uid checks covered), is to keep the original user's rights in the original namespace, and let a process become uid 0 in the new namespace, with full capabilities to the new namespace. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Andrew Morgan <agm@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16user namespace: add the frameworkCedric Le Goater
Basically, it will allow a process to unshare its user_struct table, resetting at the same time its own user_struct and all the associated accounting. A new root user (uid == 0) is added to the user namespace upon creation. Such root users have full privileges and it seems that theses privileges should be controlled through some means (process capabilities ?) The unshare is not included in this patch. Changes since [try #4]: - Updated get_user_ns and put_user_ns to accept NULL, and get_user_ns to return the namespace. Changes since [try #3]: - moved struct user_namespace to files user_namespace.{c,h} Changes since [try #2]: - removed struct user_namespace* argument from find_user() Changes since [try #1]: - removed struct user_namespace* argument from find_user() - added a root_user per user namespace Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Andrew Morgan <agm@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16remove CONFIG_UTS_NS and CONFIG_IPC_NSCedric Le Goater
CONFIG_UTS_NS and CONFIG_IPC_NS have very little value as they only deactivate the unshare of the uts and ipc namespaces and do not improve performance. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Acked-by: "Serge E. Hallyn" <serue@us.ibm.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-24fix refcounting of nsproxy object when unsharedCedric Le Goater
When a namespace is unshared, a refcount on the previous nsproxy is abusively taken, leading to a memory leak of nsproxy objects. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Merge sys_clone()/sys_unshare() nsproxy and namespace handlingBadari Pulavarty
sys_clone() and sys_unshare() both makes copies of nsproxy and its associated namespaces. But they have different code paths. This patch merges all the nsproxy and its associated namespace copy/clone handling (as much as possible). Posted on container list earlier for feedback. - Create a new nsproxy and its associated namespaces and pass it back to caller to attach it to right process. - Changed all copy_*_ns() routines to return a new copy of namespace instead of attaching it to task->nsproxy. - Moved the CAP_SYS_ADMIN checks out of copy_*_ns() routines. - Removed unnessary !ns checks from copy_*_ns() and added BUG_ON() just incase. - Get rid of all individual unshare_*_ns() routines and make use of copy_*_ns() instead. [akpm@osdl.org: cleanups, warning fix] [clg@fr.ibm.com: remove dup_namespaces() declaration] [serue@us.ibm.com: fix CONFIG_IPC_NS=n, clone(CLONE_NEWIPC) retval] [akpm@linux-foundation.org: fix build with CONFIG_SYSVIPC=n] Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: <containers@lists.osdl.org> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30Revert "[PATCH] namespaces: fix exit race by splitting exit"Linus Torvalds
This reverts commit 7a238fcba0629b6f2edbcd37458bae56fcf36be5 in preparation for a better and simpler fix proposed by Eric Biederman (and fixed up by Serge Hallyn) Acked-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] namespaces: fix exit race by splitting exitSerge E. Hallyn
Fix exit race by splitting the nsproxy putting into two pieces. First piece reduces the nsproxy refcount. If we dropped the last reference, then it puts the mnt_ns, and returns the nsproxy as a hint to the caller. Else it returns NULL. The second piece of exiting task namespaces sets tsk->nsproxy to NULL, and drops the references to other namespaces and frees the nsproxy only if an nsproxy was passed in. A little awkward and should probably be reworked, but hopefully it fixes the NFS oops. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Daniel Hokka Zakrisson <daniel@hozac.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] Revert "[PATCH] identifier to nsproxy"Eric W. Biederman
This reverts commit 373beb35cd6b625e0ba4ad98baace12310a26aa8. No one is using this identifier yet. The purpose of this identifier is to export nsproxy to user space which is wrong. nsproxy is an internal implementation optimization, which should keep our fork times from getting slower as we increase the number of global namespaces you don't have to share. Adding a global identifier like this is inappropriate because it makes namespaces inherently non-recursive, greatly limiting what we can do with them in the future. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] to nsproxyCedric Le Goater
Add the pid namespace framework to the nsproxy object. The copy of the pid namespace only increases the refcount on the global pid namespace, init_pid_ns, and unshare is not implemented. There is no configuration option to activate or deactivate this feature because this not relevant for the moment. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] identifier to nsproxyCedric Le Goater
Add an identifier to nsproxy. The default init_ns_proxy has identifier 0 and allocated nsproxies are given -1. This identifier will be used by a new syscall sys_bind_ns. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] rename struct namespace to struct mnt_namespaceKirill Korotaev
Rename 'struct namespace' to 'struct mnt_namespace' to avoid confusion with other namespaces being developped for the containers : pid, uts, ipc, etc. 'namespace' variables and attributes are also renamed to 'mnt_ns' Signed-off-by: Kirill Korotaev <dev@sw.ru> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] kernel/nsproxy.c: use kmemdup()Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] nsproxy cloning error path fixPavel
This patch fixes copy_namespaces()'s error path. when new nsproxy (new_ns) is created pointers to namespaces (ipc, uts) are copied from the old nsproxy. Later in copy_utsname, copy_ipcs, etc. according namespaces are get-ed. On error path needed namespaces are put-ed, so there's no need to put new nsproxy itelf as it woud cause putting namespaces for the second time. Found when incorporating namespaces into OpenVZ kernel. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] IPC namespace coreKirill Korotaev
This patch set allows to unshare IPCs and have a private set of IPC objects (sem, shm, msg) inside namespace. Basically, it is another building block of containers functionality. This patch implements core IPC namespace changes: - ipc_namespace structure - new config option CONFIG_IPC_NS - adds CLONE_NEWIPC flag - unshare support [clg@fr.ibm.com: small fix for unshare of ipc namespace] [akpm@osdl.org: build fix] Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: utsname: implement CLONE_NEWUTS flagSerge E. Hallyn
Implement a CLONE_NEWUTS flag, and use it at clone and sys_unshare. [clg@fr.ibm.com: IPC unshare fix] [bunk@stusta.de: cleanup] Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: utsname: implement utsname namespacesSerge E. Hallyn
This patch defines the uts namespace and some manipulators. Adds the uts namespace to task_struct, and initializes a system-wide init namespace. It leaves a #define for system_utsname so sysctl will compile. This define will be removed in a separate patch. [akpm@osdl.org: build fix, cleanup] Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: incorporate fs namespace into nsproxySerge E. Hallyn
This moves the mount namespace into the nsproxy. The mount namespace count now refers to the number of nsproxies point to it, rather than the number of tasks. As a result, the unshare_namespace() function in kernel/fork.c no longer checks whether it is being shared. Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] nsproxy: move init_nsproxy into kernel/nsproxy.cSerge E. Hallyn
Move the init_nsproxy definition out of arch/ into kernel/nsproxy.c. This avoids all arches having to be updated. Compiles and boots on s390. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: add nsproxySerge E. Hallyn
This patch adds a nsproxy structure to the task struct. Later patches will move the fs namespace pointer into this structure, and introduce a new utsname namespace into the nsproxy. The vserver and openvz functionality, then, would be implemented in large part by virtualizing/isolating more and more resources into namespaces, each contained in the nsproxy. [akpm@osdl.org: build fix] Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
