path: root/kernel/kmod.c
2007-02-23Revert "Driver core: let request_module() send a /sys/modules/kmod/-uevent"Greg Kroah-Hartman
This reverts commit c353c3fb0700a3c17ea2b0237710a184232ccd7f. It turns out that we end up with a loop trying to load the unix module and calling netfilter to do that. Will redo the patch later to not have this loop. Acked-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-23make kernel/kmod.c:kmod_mk staticAdrian Bunk
This patch makes the needlessly global struct kmod_mk static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16Driver core: let request_module() send a /sys/modules/kmod/-ueventKay Sievers
On recent systems, calls to /sbin/modprobe are handled by udev depending on the kind of device the kernel has discovered. This patch creates an uevent for the kernels internal request_module(), to let udev take control over the request, instead of forking the binary directly by the kernel. The direct execution of /sbin/modprobe can be disabled by setting: /sys/module/kmod/mod_request_helper (/proc/sys/kernel/modprobe) to an empty string, the same way /proc/sys/kernel/hotplug is disabled on an udev system. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-13[PATCH] x86-64: Allow to run a program when a machine check event is detectedAndi Kleen
When a machine check event is detected (including a AMD RevF threshold overflow event) allow to run a "trigger" program. This allows user space to react to such events sooner. The trigger is configured using a new trigger entry in the machinecheck sysfs interface. It is currently shared between all CPUs. I also fixed the AMD threshold handler to run the machine check polling code immediately to actually log any events that might have caused the threshold interrupt. Also added some documentation for the mce sysfs interface. Signed-off-by: Andi Kleen <ak@suse.de>
2006-12-08[PATCH] rename struct namespace to struct mnt_namespaceKirill Korotaev
Rename 'struct namespace' to 'struct mnt_namespace' to avoid confusion with other namespaces being developped for the containers : pid, uts, ipc, etc. 'namespace' variables and attributes are also renamed to 'mnt_ns' Signed-off-by: Kirill Korotaev <dev@sw.ru> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-28[PATCH] fix create_write_pipe() error checkAkinobu Mita
The return value of create_write_pipe()/create_read_pipe() should be checked by IS_ERR(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-22WorkStruct: Pass the work_struct pointer instead of context dataDavid Howells
Pass the work_struct pointer to the work function rather than context data. The work function can use container_of() to work out the data. For the cases where the container of the work_struct may go away the moment the pending bit is cleared, it is made possible to defer the release of the structure by deferring the clearing of the pending bit. To make this work, an extra flag is introduced into the management side of the work_struct. This governs auto-release of the structure upon execution. Ordinarily, the work queue executor would release the work_struct for further scheduling or deallocation by clearing the pending bit prior to jumping to the work function. This means that, unless the driver makes some guarantee itself that the work_struct won't go away, the work function may not access anything else in the work_struct or its container lest they be deallocated.. This is a problem if the auxiliary data is taken away (as done by the last patch). However, if the pending bit is *not* cleared before jumping to the work function, then the work function *may* access the work_struct and its container with no problems. But then the work function must itself release the work_struct by calling work_release(). In most cases, automatic release is fine, so this is the default. Special initiators exist for the non-auto-release case (ending in _NAR). Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-02[PATCH] introduce kernel_execveArnd Bergmann
The use of execve() in the kernel is dubious, since it relies on the __KERNEL_SYSCALLS__ mechanism that stores the result in a global errno variable. As a first step of getting rid of this, change all users to a global kernel_execve function that returns a proper error code. This function is a terrible hack, and a later patch removes it again after the kernel syscalls are gone. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Support piping into commands in /proc/sys/kernel/core_patternAndi Kleen
Using the infrastructure created in previous patches implement support to pipe core dumps into programs. This is done by overloading the existing core_pattern sysctl with a new syntax: |program When the first character of the pattern is a '|' the kernel will instead threat the rest of the pattern as a command to run. The core dump will be written to the standard input of that program instead of to a file. This is useful for having automatic core dump analysis without filling up disks. The program can do some simple analysis and save only a summary of the core dump. The core dump proces will run with the privileges and in the name space of the process that caused the core dump. I also increased the core pattern size to 128 bytes so that longer command lines fit. Most of the changes comes from allowing core dumps without seeks. They are fairly straight forward though. One small incompatibility is that if someone had a core pattern previously that started with '|' they will get suddenly new behaviour. I think that's unlikely to be a real problem though. Additional background: > Very nice, do you happen to have a program that can accept this kind of > input for crash dumps? I'm guessing that the embedded people will > really want this functionality. I had a cheesy demo/prototype. Basically it wrote the dump to a file again, ran gdb on it to get a backtrace and wrote the summary to a shared directory. Then there was a simple CGI script to generate a "top 10" crashes HTML listing. Unfortunately this still had the disadvantage to needing full disk space for a dump except for deleting it afterwards (in fact it was worse because over the pipe holes didn't work so if you have a holey address map it would require more space). Fortunately gdb seems to be happy to handle /proc/pid/fd/xxx input pipes as cores (at least it worked with zsh's =(cat core) syntax), so it would be likely possible to do it without temporary space with a simple wrapper that calls it in the right way. I ran out of time before doing that though. The demo prototype scripts weren't very good. If there is really interest I can dig them out (they are currently on a laptop disk on the desk with the laptop itself being in service), but I would recommend to rewrite them for any serious application of this and fix the disk space problem. Also to be really useful it should probably find a way to automatically fetch the debuginfos (I cheated and just installed them in advance). If nobody else does it I can probably do the rewrite myself again at some point. My hope at some point was that desktops would support it in their builtin crash reporters, but at least the KDE people I talked too seemed to be happy with their user space only solution. Alan sayeth: I don't believe that piping as such as neccessarily the right model, but the ability to intercept and processes core dumps from user space is asked for by many enterprise users as well. They want to know about, capture, analyse and process core dumps, often centrally and in automated form. [akpm@osdl.org: loff_t != unsigned long] Signed-off-by: Andi Kleen <ak@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Create call_usermodehelper_pipe()Andi Kleen
A new member in the ever growing family of call_usermode* functions is born. The new call_usermodehelper_pipe() function allows to pipe data to the stdin of the called user mode progam and behaves otherwise like the normal call_usermodehelp() (except that it always waits for the child to finish) Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Fix ____call_usermodehelper errors being silently ignoredBjörn Steinbrink
If ____call_usermodehelper fails, we're not interested in the child process' exit value, but the real error, so let's stop wait_for_helper from overwriting it in that case. Issue discovered by Benedikt Böhm while working on a Linux-VServer usermode helper. Signed-off-by: Björn Steinbrink <B.Steinbrink@gmx.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-16[PATCH] bug fix in kernel/kmod.cKenneth Lee
I think there is a bug in kmod.c: In __call_usermodehelper(), when kernel_thread(wait_for_helper, ...) return success, since wait_for_helper() might call complete() at any time, the sub_info should not be used any more. Normally wait_for_helper() take a long time to finish, you may not get problem for most of the case. But if you remove /sbin/modprobe, it may become easier for you to get a oop in khelper. Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: annotate on-stack completionsIngo Molnar
lockdep needs to have the waitqueue lock initialized for on-stack waitqueues implicitly initialized by DECLARE_COMPLETION(). Annotate on-stack completions accordingly. Has no effect on non-lockdep kernels. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] wait_for_helper: trivial style cleanupOleg Nesterov
Use NULL instead of (... *)0 Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] Keys: Get rid of warning in kmod.c if keys disabledDavid Howells
The attached patch gets rid of a "statement without effect" warning when CONFIG_KEYS is disabled by making use of the return value of key_get(). The compiler will optimise all of this away when keys are disabled. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] Keys: Pass session keyring to call_usermodehelper()David Howells
The attached patch makes it possible to pass a session keyring through to the process spawned by call_usermodehelper(). This allows patch 3/3 to pass an authorisation key through to /sbin/request-key, thus permitting better access controls when doing just-in-time key creation. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
