path: root/kernel/irq/resend.c
2012-05-04genirq: Allow check_wakeup_irqs to notice level-triggered interruptsThomas Gleixner
Level triggered interrupts do not cause IRQS_PENDING to be set when they fire while "disabled" as the 'pending' state is always present in the level - they automatically refire where re-enabled. However the IRQS_PENDING flag is also used to abort a suspend cycle - if any 'is_wakeup_set' interrupt is PENDING, check_wakeup_irqs() will cause suspend to abort. Without IRQS_PENDING, suspend won't abort. Consequently, level-triggered interrupts that fire during the 'noirq' phase of suspend do not currently abort suspend. So set IRQS_PENDING even for level triggered interrupts, and make sure to clear the flag in check_irq_resend. [ Changelog by courtesy of Neil ] Tested-by: NeilBrown <neilb@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29genirq: Remove compat codeThomas Gleixner
2011-02-19genirq: Mirror irq trigger type bits in irq_data.stateThomas Gleixner
That's the data structure chip functions get provided. Also allow them to signal the core code that they updated the flags in irq_data.state by returning IRQ_SET_MASK_OK_NOCOPY. The default is unchanged. The type bits should be accessed via: val = irqd_get_trigger_type(irqdata); and irqd_set_trigger_type(irqdata, val); Coders who access them directly will be tracked down and slapped with stinking trouts. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-19genirq: Move IRQ_PENDING flag to coreThomas Gleixner
Keep status in sync until all users are fixed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-19genirq: Move IRQ_REPLAY and IRQ_WAITING to coreThomas Gleixner
No users outside of core. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-19genirq: Consolidate IRQ_DISABLEDThomas Gleixner
Handle IRQ_DISABLED consistent. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-19genirq: Consolidate disable/enableThomas Gleixner
Create irq_disable/enable and use them to keep the flags consistent. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-19genirq: Prevent access beyond allocated_irqs bitmapThomas Gleixner
Lars-Peter Clausen pointed out: I stumbled upon this while looking through the existing archs using SPARSE_IRQ. Even with SPARSE_IRQ the NR_IRQS is still the upper limit for the number of IRQs. Both PXA and MMP set NR_IRQS to IRQ_BOARD_START, with IRQ_BOARD_START being the number of IRQs used by the core. In various machine files the nr_irqs field of the ARM machine defintion struct is then set to "IRQ_BOARD_START + NR_BOARD_IRQS". As a result "nr_irqs" will greater then NR_IRQS which then again causes the "allocated_irqs" bitmap in the core irq code to be accessed beyond its size overwriting unrelated data. The core code really misses a sanity check there. This went unnoticed so far as by chance the compiler/linker places data behind that bitmap which gets initialized later on those affected platforms. So the obvious fix would be to add a sanity check in early_irq_init() and break all affected platforms. Though that check wants to be backported to stable as well, which will require to fix all known problematic platforms and probably some more yet not known ones as well. Lots of churn. A way simpler solution is to allocate a slightly larger bitmap and avoid the whole churn w/o breaking anything. Add a few warnings when an arch returns utter crap. Reported-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@kernel.org # .37 Cc: Haojian Zhuang <haojian.zhuang@marvell.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org>
2010-10-04genirq: Provide compat handling for chip->retrigger()Thomas Gleixner
Wrap the old chip function retrigger() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121843.025801092@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Provide compat handling for chip->enable()Thomas Gleixner
Wrap the old chip function enable() until the migration is complete and the old chip functions are removed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20100927121842.437159182@linutronix.de> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2010-10-04genirq: Convert core code to irq_dataThomas Gleixner
Convert all references in the core code to orq, chip, handler_data, chip_data, msi_desc, affinity to irq_data.* Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu>
2009-08-09irq: Remove superfluous NULL pointer check in check_irq_resend()Bartlomiej Zolnierkiewicz
This takes care of the following entry from Dan's list: kernel/irq/resend.c +73 check_irq_resend(17) warning: variable derefenced before check 'desc->chip' Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Eugene Teo <eteo@redhat.com> Cc: Julia Lawall <julia@diku.dk> LKML-Reference: <200908062146.03638.bzolnier@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-16generic: sparse irqs: use irq_desc() together with dyn_array, instead of ↵Yinghai Lu
irq_desc[] add CONFIG_HAVE_SPARSE_IRQ to for use condensed array. Get rid of irq_desc[] array assumptions. Preallocate 32 irq_desc, and irq_desc() will try to get more. ( No change in functionality is expected anywhere, except the odd build failure where we missed a code site or where a crossing commit itroduces new irq_desc[] usage. ) v2: according to Eric, change get_irq_desc() to irq_desc() Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-16irq: introduce nr_irqsYinghai Lu
at this point nr_irqs is equal NR_IRQS convert a few easy users from NR_IRQS to dynamic nr_irqs. v2: according to Eric, we need to take care of arch without generic_hardirqs Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-12genirq: suppress resend of level interruptsThomas Gleixner
Level type interrupts are resent by the interrupt hardware when they are still active at irq_enable(). Suppress the resend mechanism for interrupts marked as level. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-09Revert "genirq: temporary fix for level-triggered IRQ resend"Linus Torvalds
This reverts commit 0fc4969b866671dfe39b1a9119d0fdc7ea0f63e5. It was always meant to be temporary, but it's generating more useless noise than anything else, and we probably should never have done it in the generic kernel (only had the people involved test it on their own). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-01genirq: temporary fix for level-triggered IRQ resendThomas Gleixner
Marcin Slusarz reported a ne2k-pci "hung network interface" regression. delayed disable relies on the ability to re-trigger the interrupt in the case that a real interrupt happens after the software disable was set. In this case we actually disable the interrupt on the hardware level _after_ it occurred. On enable_irq, we need to re-trigger the interrupt. On i386 this relies on a hardware resend mechanism (send_IPI_self()). Actually we only need the resend for edge type interrupts. Level type interrupts come back once enable_irq() re-enables the interrupt line. I assume that the interrupt in question is level triggered because it is shared and above the legacy irqs 0-15: 17: 12 IO-APIC-fasteoi eth1, eth0 Looking into the IO_APIC code, the resend via send_IPI_self() happens unconditionally. So the resend is done for level and edge interrupts. This makes the problem more mysterious. The code in question lib8390.c does disable_irq(); fiddle_with_the_network_card_hardware() enable_irq(); The fiddle_with_the_network_card_hardware() might cause interrupts, which are cleared in the same code path again, Marcin found that when he disables the irq line on the hardware level (removing the delayed disable) the card is kept alive. So the difference is that we can get a resend on enable_irq, when an interrupt happens during the time, where we are in the disabled region. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-06[PATCH] ixp4xxdefconfig arm fixesFrederik Deweerdt
With the following patch, the ixp4xxdefconfig builds correctly. I'll test some more configs if I get some time. Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-16[PATCH] genirq: fix typo in IRQ resendImre Deak
Fix a bug where the IRQ_PENDING flag is never cleared and the ISR is called endlessly without an actual interrupt. Signed-off-by: Imre Deak <imre.deak@solidboot.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: coreThomas Gleixner
Core genirq support: add the irq-chip and irq-flow abstractions. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: add genirq sw IRQ-retriggerThomas Gleixner
Enable platforms that do not have a hardware-assisted hardirq-resend mechanism to resend them via a softirq-driven IRQ emulation mechanism. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
