path: root/kernel/irq/pm.c
2011-11-11genirq: Add IRQF_RESUME_EARLY and resume such IRQs earlierIan Campbell
commit 9bab0b7fbaceec47d32db51cd9e59c82fb071f5a upstream. This adds a mechanism to resume selected IRQs during syscore_resume instead of dpm_resume_noirq. Under Xen we need to resume IRQs associated with IPIs early enough that the resched IPI is unmasked and we can therefore schedule ourselves out of the stop_machine where the suspend/resume takes place. This issue was introduced by 676dc3cf5bc3 "xen: Use IRQF_FORCE_RESUME". Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Jeremy Fitzhardinge <Jeremy.Fitzhardinge@citrix.com> Cc: xen-devel <xen-devel@lists.xensource.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Link: http://lkml.kernel.org/r/1318713254.11016.52.camel@dagon.hellion.org.uk Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-12genirq: Add chip flag to force mask on suspendThomas Gleixner
On suspend we disable all interrupts in the core code, but this does not mask the interrupt line in the default implementation as we use a lazy disable approach. That means we mark the interrupt disabled, but leave the hardware unmasked. That's an optimization because we avoid the hardware access for the common case where no interrupt happens after we marked it disabled. If an interrupt happens, then the interrupt flow handler masks the line at the hardware level and marks it pending. Suspend makes use of this delayed disable as it "disables" all interrupts when preparing the suspend transition. Right before the system goes into hardware suspend state it checks whether one of the interrupts which is marked as a wakeup interrupt came in after disabling it. Most interrupt chips have a separate register which selects the interrupts which can wake up the system from suspend, so we don't have to mask any on the non wakeup interrupts. But now we have to deal with brilliant designed hardware which lacks such a wakeup configuration facility. For such hardware it's necessary to mask all non wakeup interrupts before going into suspend in order to avoid the wakeup from random interrupts. Rather than working around this in the affected interrupt chip implementations we can solve this elegant in the core code itself. Add a flag IRQCHIP_MASK_ON_SUSPEND which can be set by the irq chip implementation to indicate, that the interrupts which are not selected as wakeup sources must be masked in the suspend path. Mask them in the loop which checks the wakeup interrupts pending flag. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org> LKML-Reference: <alpine.LFD.2.00.1103112112310.2787@localhost6.localdomain6>
2011-02-19genirq: Move wakeup state to irq_dataThomas Gleixner
Some irq_chips need to know the state of wakeup mode for setting the trigger type etc. Reflect it in irq_data state. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-19genirq: Move IRQ_WAKEUP to coreThomas Gleixner
No users outside of core. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-19genirq: Move IRQ_SUSPENDED to coreThomas Gleixner
2011-02-19genirq: Move IRQ_PENDING flag to coreThomas Gleixner
Keep status in sync until all users are fixed. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-08genirq: Add IRQF_FORCE_RESUMEThomas Gleixner
Xen needs to reenable interrupts which are marked IRQF_NO_SUSPEND in the resume path. Add a flag to force the reenabling in the resume code. Tested-and-acked-by: Ian Campbell <Ian.Campbell@eu.citrix.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-12-14genirq: Convert irq_desc.lock to raw_spinlockThomas Gleixner
Convert locks which cannot be sleeping locks in preempt-rt to raw_spinlocks. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-07-05genirq: Fix comment describing suspend_device_irqs()Rafael J. Wysocki
The kerneldoc comment describing suspend_device_irqs() is currently misleading, because generally the function doesn't really disable interrupt lines at the chip level. Replace it with a more accurate one. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> LKML-Reference: <200907050022.35117.rjw@sisk.pl> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-03-30PM: Introduce functions for suspending and resuming device interruptsRafael J. Wysocki
Introduce helper functions allowing us to prevent device drivers from getting any interrupts (without disabling interrupts on the CPU) during suspend (or hibernation) and to make them start to receive interrupts again during the subsequent resume. These functions make it possible to keep timer interrupts enabled while the "late" suspend and "early" resume callbacks provided by device drivers are being executed. In turn, this allows device drivers' "late" suspend and "early" resume callbacks to sleep, execute ACPI callbacks etc. The functions introduced here will be used to rework the handling of interrupts during suspend (hibernation) and resume. Namely, interrupts will only be disabled on the CPU right before suspending sysdevs, while device drivers will be prevented from receiving interrupts, with the help of the new helper function, before their "late" suspend callbacks run (and analogously during resume). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Ingo Molnar <mingo@elte.hu>
