When requesting an IRQ, the DEBUG_SHIRQ code executes a fake IRQ just to make
sure the driver is ready to receive an IRQ immediately. The problem was that
this fake IRQ was being executed even if interrupt line failed to be allocated
by __setup_irq.
Signed-off-by: Luis Henriques <henrix@sapo.pt>
LKML-Reference: <20090401170635.GA4392@hades.domain.com>
[ fixed bug pointed out by a warning reported by Stephen Rothwell ]
As discussed in the thread here:
http://marc.info/?l=linux-kernel&m=123964468521142&w=2
Eric W. Biederman observed:
> It looks like some additional bugs have slipped in since last I looked.
> set_irq_affinity does this:
> ifdef CONFIG_GENERIC_PENDING_IRQ
> if (desc->status & IRQ_MOVE_PCNTXT || desc->status & IRQ_DISABLED) {
> cpumask_copy(desc->affinity, cpumask);
> desc->chip->set_affinity(irq, cpumask);
> } else {
> desc->status |= IRQ_MOVE_PENDING;
> cpumask_copy(desc->pending_mask, cpumask);
> #else
> That IRQ_DISABLED case is a software state and as such it has nothing to
> do with how safe it is to move an irq in process context.
> The only reason we migrate MSIs in interrupt context today is that there
> wasn't infrastructure for support migration both in interrupt context
> and outside of it.
Yes. The idea here was to force the MSI migration to happen in process
context. One of the patches in the series did
disable_irq(dev->irq);
irq_set_affinity(dev->irq, cpumask_of(dev->cpu));
enable_irq(dev->irq);
with the above patch adding irq/manage code check for interrupt disabled
and moving the interrupt in process context.
IIRC, there was no IRQ_MOVE_PCNTXT when we were developing this HPET
code and we ended up having this ugly hack. IRQ_MOVE_PCNTXT was there
when we eventually submitted the patch upstream. But, looks like I did a
blind rebasing instead of using IRQ_MOVE_PCNTXT in hpet MSI code.
Below patch fixes this. i.e., revert commit 932775a4ab622e3c99bd59f14cc
and add PCNTXT to HPET MSI setup. Also removes copying of desc->affinity
in generic code as set_affinity routines are doing it internally.
Reported-by: "Eric W. Biederman" <ebiederm@xmission.com>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: "Li Shaohua" <shaohua.li@intel.com>
Cc: Gary Hade <garyhade@us.ibm.com>
Cc: "lcm@us.ibm.com" <lcm@us.ibm.com>
Cc: suresh.b.siddha@intel.com
LKML-Reference: <20090413222058.GB8211@linux-os.sc.intel.com>
include/linux/irq.h
kernel/irq/handle.c
Introduce helper functions allowing us to prevent device drivers from
getting any interrupts (without disabling interrupts on the CPU)
during suspend (or hibernation) and to make them start to receive
interrupts again during the subsequent resume. These functions make it
possible to keep timer interrupts enabled while the "late" suspend and
"early" resume callbacks provided by device drivers are being
executed. In turn, this allows device drivers' "late" suspend and
"early" resume callbacks to sleep, execute ACPI callbacks etc.
The functions introduced here will be used to rework the handling of
interrupts during suspend (hibernation) and resume. Namely,
interrupts will only be disabled on the CPU right before suspending
sysdevs, while device drivers will be prevented from receiving
interrupts, with the help of the new helper function, before their
"late" suspend callbacks run (and analogously during resume).
arch/parisc/kernel/irq.c
arch/x86/include/asm/fixmap_64.h
arch/x86/include/asm/setup.h
kernel/irq/handle.c
Semantic merge:
arch/x86/include/asm/fixmap.h
Delta patch to address the review comments.
- Implement warning when IRQ_WAKE_THREAD is requested and no
thread handler installed
- coding style fixes
Pointed-out-by: Christoph Hellwig <hch@infradead.org>
Add support for threaded interrupt handlers:
A device driver can request that its main interrupt handler runs in a
thread. To achive this the device driver requests the interrupt with
request_threaded_irq() and provides additionally to the handler a
thread function. The handler function is called in hard interrupt
context and needs to check whether the interrupt originated from the
device. If the interrupt originated from the device then the handler
can either return IRQ_HANDLED or IRQ_WAKE_THREAD. IRQ_HANDLED is
returned when no further action is required. IRQ_WAKE_THREAD causes
the genirq code to invoke the threaded (main) handler. When
IRQ_WAKE_THREAD is returned handler must have disabled the interrupt
on the device level. This is mandatory for shared interrupt handlers,
but we need to do it as well for obscure x86 hardware where disabling
an interrupt on the IO_APIC level redirects the interrupt to the
legacy PIC interrupt lines.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
kernel/irq/handle.c
Impact: simplification
Reviewed-by: Peter Zijlstra <peterz@infradead.org>
Impact: cleanup
The code is only compiled if CONFIG_GENERIC_HARDIRQS=y so another
check for this define in the code is redundant. Remove it.
Export the setup_irq() and remove_irq() symbols.
I'd like to export these functions since I have timer
code that needs to use setup_irq() early on (too early
for request_irq()), and the same code can also be
compiled as a module.
Signed-off-by: Magnus Damm <damm@igel.co.jp>
LKML-Reference: <20090312120559.2926.82371.sendpatchset@rx1.opensource.se>
[ changed to _GPL as these are special APIs deep inside the irq layer. ]
Modify remove_irq() to match setup_irq().
LKML-Reference: <20090312120551.2926.43942.sendpatchset@rx1.opensource.se>
Impact: add new API
This patch adds a remove_irq() function for releasing
interrupts requested with setup_irq().
Without this patch we have no way of releasing such
interrupts since free_irq() today tries to kfree()
the irqaction passed with setup_irq().
LKML-Reference: <20090312120542.2926.56609.sendpatchset@rx1.opensource.se>
'p' stands for pointer - make it clear in setup_irq() and free_irq()
what kind of pointer it is.
Linus noticed that the 'pp' variable can be eliminated
altogether, and the loop can be cleaned up further.
Impact: cleanup
- separate out the loop from the actual freeing logic, this wins us
two indentation levels allowing a number of followup prettifications
- turn the WARN_ON() into a more informative WARN().
- clean up the comments and the code flow some more
- make printk message git-greppable
- fix a few style details
request_irq() calls into proc code via __setup_irq() which is not safe
in an atomic context, so request_irq() can itself use the more
reliable GFP_KERNEL allocation for the action descriptor.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
While being at it make every occurrence of 'do_irq_select_affinity'
have the same signature in terms of signedness of the first argument.
Fix this sparse warning:
kernel/irq/manage.c:112:5: warning: symbol 'do_irq_select_affinity' was not declared. Should it be static?
Also rename do_irq_select_affinity() to setup_affinity() - shorter name
and clearer naming.
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
Acked-by: Matthew Wilcox <matthew@wil.cx>
kernel/irq/handle.c
kernel/irq/handle.c
Move the initialization of irq_default_affinity to early_irq_init as
core_initcall is too late.
irq_default_affinity can be used in init_IRQ and potentially timer and
SMP init as well. All of these happen before core_initcall. Moving
the initialization to early_irq_init ensures that it is initialized
before it is used.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Acked-by: Mike Travis <travis@sgi.com>
In interrupt.h these functions are declared only if
CONFIG_GENERIC_HARDIRQS is set. We should define them under identical
conditions.
Impact: reduce memory usage, use new cpumask API.
Replace the affinity and pending_masks with cpumask_var_t's. This adds
to the significant size reduction done with the SPARSE_IRQS changes.
The added functions (init_alloc_desc_masks & init_copy_desc_masks) are
in the include file so they can be inlined (and optimized out for the
!CONFIG_CPUMASKS_OFFSTACK case.) [Naming chosen to be consistent with
the other init*irq functions, as well as the backwards arg declaration
of "from, to" instead of the more common "to, from" standard.]
Includes a slight change to the declaration of struct irq_desc to embed
the pending_mask within ifdef(CONFIG_SMP) to be consistent with other
references, and some small changes to Xen.
Tested: sparse/non-sparse/cpumask_offstack/non-cpumask_offstack/nonuma/nosmp on x86_64
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Jeremy Fitzhardinge <jeremy@xensource.com>
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: virtualization@lists.osdl.org
Cc: xen-devel@lists.xensource.com
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Impact: Reduce stack usage, use new cpumask API. ALPHA mod!
Main change is that irq_default_affinity becomes a cpumask_var_t, so
treat it as a pointer (this effects alpha).
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
arch/x86/kernel/io_apic.c
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, sparseirq: clean up Kconfig entry
x86: turn CONFIG_SPARSE_IRQ off by default
sparseirq: fix numa_migrate_irq_desc dependency and comments
sparseirq: add kernel-doc notation for new member in irq_desc, -v2
locking, irq: enclose irq_desc_lock_class in CONFIG_LOCKDEP
sparseirq, xen: make sure irq_desc is allocated for interrupts
sparseirq: fix !SMP building, #2
x86, sparseirq: move irq_desc according to smp_affinity, v7
proc: enclose desc variable of show_stat() in CONFIG_SPARSE_IRQ
sparse irqs: add irqnr.h to the user headers list
sparse irqs: handle !GENIRQ platforms
sparseirq: fix !SMP && !PCI_MSI && !HT_IRQ build
sparseirq: fix Alpha build failure
sparseirq: fix typo in !CONFIG_IO_APIC case
x86, MSI: pass irq_cfg and irq_desc
x86: MSI start irq numbering from nr_irqs_gsi
x86: use NR_IRQS_LEGACY
sparse irq_desc[] array: core kernel and x86 changes
genirq: record IRQ_LEVEL in irq_desc[]
irq.h: remove padding from irq_desc on 64bits
Impact: change existing irq_chip API
Not much point with gentle transition here: the struct irq_chip's
setaffinity method signature needs to change.
Fortunately, not widely used code, but hits a few architectures.
Note: In irq_select_affinity() I save a temporary in by mangling
irq_desc[irq].affinity directly. Ingo, does this break anything?
(Folded in fix from KOSAKI Motohiro)
Reviewed-by: Grant Grundler <grundler@parisc-linux.org>
Acked-by: Ingo Molnar <mingo@redhat.com>
Cc: ralf@linux-mips.org
Cc: grundler@parisc-linux.org
Cc: jeremy@xensource.com
Impact: emit new warning
We periodically waste time tracking down problems from the genirq
framework not respecting IRQF_DISABLED for some shared IRQ cases. Linus
views this as "will not fix", but we're still left with the bugs caused by
this misbehavior.
This patch adds a nag message in request_irq(), so that drivers can fix
their IRQ handlers to avoid this problem.
Note that developers will never see the relevant bugs when they run with
LOCKDEP, so it's no wonder these bugs are hard to find. (That also means
LOCKDEP is overlooking some IRQ-related bugs involving IRQ handlers that
don't set IRQF_DISABLED...)
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Impact: fix __irq_set_trigger() for IRQ_LEVEL
When recording the irq trigger type, let's also make sure
that IRQ_LEVEL gets set correctly.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Commit 0c5d1eb77a8be917b638344a22afe1398236482b (genirq: record trigger
type) caused powerpc platforms that had no set_type() function in their
struct irq_chip to spew out warnings about "No set_type function for
IRQ...". This warning isn't necessarily justified though because the
generic powerpc platform code calls set_irq_type() (which in turn calls
__irq_set_trigger) with information from the device tree to establish
the interrupt mappings, regardless of whether the PIC can actually set
a type.
A platform's irq_chip might not have a set_type function for a variety
of reasons, for example: the platform may have the type essentially
hard-coded, or as in the case for Cell interrupts are just messages
past around that have no real concept of type, or the platform
could even have a virtual PIC as on the PS3.
Signed-off-by: Mark Nelson <markn@au1.ibm.com>
Impact: build fix
fix build failure on UP.
The affinity setting in setup irq is called before the NO_BALANCING
flag is checked and might therefore override affinity settings from the
calling code with the default setting.
Move the NO_BALANCING flag check before the call to the affinity
setting.
Impact: preserve user-modified affinities on interrupts
Kumar Galak noticed that commit
18404756765c713a0be4eb1082920c04822ce588 (genirq: Expose default irq
affinity mask (take 3))
overrides an already set affinity setting across a free /
request_irq(). Happens e.g. with ifdown/ifup of a network device.
Change the logic to mark the affinities as set and keep them
intact. This also fixes the unlocked access to irq_desc in
irq_select_affinity() when called from irq_affinity_proc_write()
Change the IRQ affinity in the process context when the IRQ is disabled.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
This has been deprecated for years, the user space irqbalanced utility
works better with numa, has configurable policies, etc...
Signed-off-by: Yinghai Lu <yhlu.kernel@gmai.com>
change names:
irq_desc() ==> irq_desc_alloc
__irq_desc() ==> irq_desc
Also split a few of the uses in lowlevel x86 code.
v2: need to check if desc is null in smp_irq_move_cleanup
Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com>
remove irq limit checks - nr_irqs is dynamic and we expand anytime.
v2: fix checking about result irq_cfg_without_new, so could use msi again
v3: use irq_desc_without_new to check irq is valid
There are a handful of loops that go from 0 to nr_irqs and use
get_irq_desc() on them. These would allocate all the irq_desc
entries, regardless of the need for them.
Use the smarter for_each_irq_desc() iterator that will only iterate
over the present ones.
v2: make sure arch without GENERIC_HARDIRQS work too
irq_desc[]
add CONFIG_HAVE_SPARSE_IRQ to for use condensed array.
Get rid of irq_desc[] array assumptions.
Preallocate 32 irq_desc, and irq_desc() will try to get more.
( No change in functionality is expected anywhere, except the odd build
failure where we missed a code site or where a crossing commit itroduces
new irq_desc[] usage. )
v2: according to Eric, change get_irq_desc() to irq_desc()
at this point nr_irqs is equal NR_IRQS
convert a few easy users from NR_IRQS to dynamic nr_irqs.
v2: according to Eric, we need to take care of arch without generic_hardirqs
Genirq hasn't previously recorded the trigger type used by any given IRQ,
although some irq_chip support has done so. That data can be useful when
troubleshooting. This patch records it in the relevant irq_desc.status
bits, and improves consistency between the two driver-visible calls
affected:
- Make set_irq_type() usage match request_irq() usage:
* IRQ_TYPE_NONE should be a NOP; succeed, so irq_chip methods
won't have to handle that case any more (many do it wrong).
* IRQ_TYPE_PROBE is ignored; any buggy out-of-tree callers
might need to switch over to the real IRQ probing code.
* emit the same diagnostics (from shared utility code)
- Their kerneldoc now reflects usage:
* request_irq() flags include IRQF_TRIGGER_* to specify
active edge(s)/level ... docs previously omitted that
* set_irq_type() is declared in <linux/irq.h> so callers
should use the (bit-equivalent) IRQ_TYPE_* symbols there
Also: adds a warning about shared IRQs that don't end up using the
requested trigger mode; and fix an unrelated "sparse" warning.
This patch clarifies usage of irq_chip->startup() callback:
1. The "if (startup) startup(); else enabled();" code in setup_irq()
is unnecessary, as startup() falls back to enabled() via
default callbacks, set by irq_chip_set_defaults().
2. When using set_irq_chained_handler() the startup() was never called,
which is not good at all... Fixed. And again - when startup() is not
defined the call will fall back to enable() than to unmask() via
default callbacks.
Signed-off-by: Pawel Moll <pawel.moll@st.com>
